[GRASS-SVN] r52539 - grass/trunk/temporal/t.rast.aggregate
svn_grass at osgeo.org
Sun Aug 5 11:31:18 PDT 2012
Author: huhabla
Date: 2012-08-05 11:31:16 -0700 (Sun, 05 Aug 2012)
New Revision: 52539
grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html
Added manpage content
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html 2012-08-05 08:17:36 UTC (rev 52538)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html 2012-08-05 18:31:16 UTC (rev 52539)
@@ -0,0 +1,90 @@
+<h2>DESCRIPTION</h2>
+<em>t.rast.aggregate</em> temporally aggregates space time raster datasets by a specific temporal granularity.
+The granularity can be <em>seconds, minutes, hours, days, weeks, months</em> and <em>years</em>.
+Mixing of granularities is not supported.
+<p>
+This module is sensitive to the current region and mask settings, hence spatial extent and spatial resolution.
+In case the registered raster maps of the input space time raster dataset
+have different spatial resolutions, the default nearest neighbour resampling method is used for
+runtime spatial aggregation.
+<h2>NOTES</h2>
+The raster module <em>r.series</em> is used internally. Hence all aggregate
+methods of <em>r.series</em> are supported. See the <a href="r.series.html">r.series</a> manpage
+for details.
+<p>
+This module will shift the start date for each aggregation process depending on the
+provided temporal granularity. The following shifts will performed:
+<ul>
+ <li><em>granularity years</em>: will start at the first of January, hence 14-08-2012 00:01:30 will be shifted to 01-01-2012 00:00:00</li>
+ <li><em>granularity months</em>: will start at the first day of a month, hence 14-08-2012 will be shifted to 01-08-2012 00:00:00</li>
+ <li><em>granularity weeks</em>: will start at the first day of a week (monday), hence 14-08-2012 01:30:30 will be shifted to 13-08-2012 01:00:00</li>
+ <li><em>granularity days</em>: will start at the first hour of a day, hence 14-08-2012 00:01:30 will be shifted to 14-08-2012 00:00:00</li>
+ <li><em>granularity hours</em>: will start at the first minute of a hour, hence 14-08-2012 01:30:30 will be shifted to 14-08-2012 01:00:00</li>
+ <li><em>granularity minutes</em>: will start at the first second of a minute, hence 14-08-2012 01:30:30 will be shifted to 14-08-2012 01:30:00</li>
+</ul>
+<h2>EXAMPLE</h2>
+In this example we create 7 raster maps that will be registered in a single space time
+raster dataset named <em>precipitation_daily</em> using a daily temporal granularity.
+The names of the raster maps are stored in a text file that is used for raster map registration.
+<p>
+The space time raster dataset <em>precipitation_daily</em> with daily temporal granularity
+will be aggregated to weekly precipitation resulting in the output space time raster dataset
+<em>precipitation_weekly</em>. The base name of the new generated raster maps is <em>prec_weekly</em>, the
+granularity is 1 week. The aggregation method is set to <em>sum</em> to accumulate the precipitation values
+of all raster maps in a week. The sampling option assures that only raster maps that are
+temporally during a week will be considered for computation:
+<div class="code"><pre>
+MAPS="map_1 map_2 map_3 map_4 map_5 map_6 map_7"
+for map in ${MAPS} ; do
+ r.mapcalc --o expr="${map} = 1"
+ echo ${map} >> map_list.txt
+done
+t.create type=strds temporaltype=absolute \
+ output=precipitation_daily \
+ title="Daily precipitation" \
+ description="Test dataset with daily precipitation"
+t.register -i type=rast input=precipitation_daily \
+ file=map_list.txt start=20-08-2012 increment="1 days"
+t.info type=strds input=precipitation_daily
+t.rast.aggregate input=precipitation_daily \
+ output=precipitation_weekly \
+ base=prec_weekly granularity="1 weeks" \
+ method=sum sampling=during
+t.support input=precipitation_weekly \
+ title="Weekly precipitation" \
+ description="Aggregated precipitation dataset with weekly resolution"
+t.info type=strds input=precipitation_weekly
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+<a href="t.rast.aggregate.ds.html">t.rast.aggregate.ds</a><br>
+<a href="t.rast.extract.html">t.rast.extract</a><br>
+<a href="r.series.html">r.series</a><br>
+<a href="g.region.html">g.region</a><br>
+<a href="t.info.html">t.info</a><br>
+</em>
+<h2>AUTHORS</h2>
+Sören Gebbert
+<p><i>Last changed: $Date$</i>
\ No newline at end of file
