[GRASS-SVN] r52543 - grass/trunk/lib/vector/rtree
svn_grass at osgeo.org
Sun Aug 5 13:22:06 PDT 2012
Author: mmetz
Date: 2012-08-05 13:22:06 -0700 (Sun, 05 Aug 2012)
New Revision: 52543
grass/trunk/lib/vector/rtree/indexf.c
grass/trunk/lib/vector/rtree/indexm.c
grass/trunk/lib/vector/rtree/rtree.h
rtree search optimization: pass pointer instead of struct
Modified: grass/trunk/lib/vector/rtree/indexf.c
--- grass/trunk/lib/vector/rtree/indexf.c 2012-08-05 19:42:38 UTC (rev 52542)
+++ grass/trunk/lib/vector/rtree/indexf.c 2012-08-05 20:22:06 UTC (rev 52543)
@@ -84,7 +84,7 @@
hitCount++;
if (shcb) { /* call the user-provided callback */
if (!shcb(s[top].sn.branch[i].child.id,
- s[top].sn.branch[i].rect, cbarg)) {
+ &s[top].sn.branch[i].rect, cbarg)) {
/* callback wants to terminate search early */
return hitCount;
Modified: grass/trunk/lib/vector/rtree/indexm.c
--- grass/trunk/lib/vector/rtree/indexm.c 2012-08-05 19:42:38 UTC (rev 52542)
+++ grass/trunk/lib/vector/rtree/indexm.c 2012-08-05 20:22:06 UTC (rev 52543)
@@ -77,7 +77,7 @@
hitCount++;
if (!shcb(s[top].sn->branch[i].child.id,
- s[top].sn->branch[i].rect, cbarg)) {
+ &s[top].sn->branch[i].rect, cbarg)) {
return hitCount;
Modified: grass/trunk/lib/vector/rtree/rtree.h
--- grass/trunk/lib/vector/rtree/rtree.h 2012-08-05 19:42:38 UTC (rev 52542)
+++ grass/trunk/lib/vector/rtree/rtree.h 2012-08-05 20:22:06 UTC (rev 52543)
@@ -85,11 +85,11 @@
* It can terminate the search early by returning 0 in which case
* the search will return the number of hits found up to that point.
-typedef int SearchHitCallback(int id, struct RTree_Rect rect, void *arg);
+typedef int SearchHitCallback(int id, const struct RTree_Rect *rect, void *arg);
struct RTree;
-typedef int rt_search_fn(struct RTree *, struct RTree_Rect *,
+typedef int rt_search_fn(struct RTree *, const struct RTree_Rect *,
SearchHitCallback *, void *);
typedef int rt_insert_fn(struct RTree_Rect *, union RTree_Child, int, struct RTree *);
typedef int rt_delete_fn(struct RTree_Rect *, union RTree_Child, struct RTree *);
