[GRASS-SVN] r52568 - in grass/trunk: include/defs lib/vector/Vlib vector/v.info
svn_grass at osgeo.org
Mon Aug 6 12:07:17 PDT 2012
Author: martinl
Date: 2012-08-06 12:07:16 -0700 (Mon, 06 Aug 2012)
New Revision: 52568
grass/trunk/include/defs/vector.h
grass/trunk/lib/vector/Vlib/header_finfo.c
grass/trunk/vector/v.info/print.c
vlib: remove Vect_get_finfo_geometry_column()
add Vect_get_finfo()
update v.info & untabify
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h 2012-08-06 18:51:29 UTC (rev 52567)
+++ grass/trunk/include/defs/vector.h 2012-08-06 19:07:16 UTC (rev 52568)
@@ -164,7 +164,7 @@
char *Vect_get_finfo_layer_name(const struct Map_info *);
const char *Vect_get_finfo_format_info(const struct Map_info *);
const char *Vect_get_finfo_geometry_type(const struct Map_info *);
-const char *Vect_get_finfo_geometry_column(const struct Map_info *);
+const struct Format_info *Vect_get_finfo(const struct Map_info *);
int Vect_is_3d(const struct Map_info *);
int Vect_set_organization(struct Map_info *, const char *);
const char *Vect_get_organization(const struct Map_info *);
Modified: grass/trunk/lib/vector/Vlib/header_finfo.c
--- grass/trunk/lib/vector/Vlib/header_finfo.c 2012-08-06 18:51:29 UTC (rev 52567)
+++ grass/trunk/lib/vector/Vlib/header_finfo.c 2012-08-06 19:07:16 UTC (rev 52568)
@@ -1,7 +1,8 @@
\file lib/vector/Vlib/header_finfo.c
- \brief Vector library - header manipulation (external formats)
+ \brief Vector library - header manipulation (relevant for external
+ formats)
Higher level functions for reading/writing/manipulating vectors.
@@ -12,7 +13,7 @@
\author Original author CERL, probably Dave Gerdes or Mike Higgins.
\author Update to GRASS 5.7 Radim Blazek and David D. Gray.
- \author Update to GRASS 7 (OGR support) by Martin Landa <landa.martin gmail.com>
+ \author Update to GRASS 7 (OGR/PostGIS support) by Martin Landa <landa.martin gmail.com>
#include <grass/vector.h>
@@ -57,7 +58,7 @@
Returns:
- layer name for OGR format (GV_FORMAT_OGR and GV_FORMAT_OGR_DIRECT)
- - table name for PostGIS format (GV_FORMAT_POSTGIS)
+ - table name for PostGIS format (GV_FORMAT_POSTGIS) including schema (<schema>.<table>)
Note: allocated string should be freed by G_free()
@@ -96,12 +97,10 @@
\brief Get format info (relevant only for non-native formats)
- Returns:
- - layer name for OGR format (GV_FORMAT_OGR and GV_FORMAT_OGR_DIRECT)
\param Map pointer to Map_info structure
- \return string containing name of OGR format (allocated by G_store())
+ \return string containing name of OGR format
+ \return "PostgreSQL" for PostGIS format (GV_FORMAT_POSTGIS)
\return NULL on error (or on missing OGR/PostgreSQL support)
const char *Vect_get_finfo_format_info(const struct Map_info *Map)
@@ -201,22 +200,19 @@
- \brief Get geometry column (relevant only for non-native DB formats)
+ \brief Get header info for non-native formats
- \param Map pointer to Map_info structure
- \return allocated string with geometry column name
- \return NULL on error (map format is native)
+ Prints a warning for native format.
+ \param Map pointer to Ma_info structure
+ \return pointer to Format_info structure
-const char *Vect_get_finfo_geometry_column(const struct Map_info *Map)
+const struct Format_info* Vect_get_finfo(const struct Map_info *Map)
- if (Map->format == GV_FORMAT_POSTGIS) {
-#ifndef HAVE_POSTGRES
- G_warning(_("GRASS is not compiled with PostgreSQL support"));
-#else
- return Map->fInfo.pg.geom_column;
-#endif
- return NULL;
+ if (Map->format == GV_FORMAT_NATIVE)
+ G_warning(_("Native vector format detected for <%s>"),
+ Vect_get_full_name(Map));
+ return &(Map->fInfo);
Modified: grass/trunk/vector/v.info/print.c
--- grass/trunk/vector/v.info/print.c 2012-08-06 18:51:29 UTC (rev 52567)
+++ grass/trunk/vector/v.info/print.c 2012-08-06 19:07:16 UTC (rev 52568)
@@ -9,10 +9,10 @@
#define printline(x) fprintf (stdout, " | %-74.74s |\n", x)
#define divider(x) \
- fprintf (stdout, " %c", x); \
- for (i = 0; i < 76; i++ ) \
- fprintf ( stdout, "-" ); \
- fprintf (stdout, "%c\n", x)
+ fprintf (stdout, " %c", x); \
+ for (i = 0; i < 76; i++ ) \
+ fprintf ( stdout, "-" ); \
+ fprintf (stdout, "%c\n", x)
/* cloned from lib/gis/wind_format.c */
void format_double(double value, char *buf)
@@ -27,7 +27,7 @@
struct bound_box box;
- /*Print the spatial extent as double values*/
+ /* print the spatial extent as double values */
Vect_get_map_box(Map, &box);
G_format_northing(box.N, tmp1, -1);
G_format_northing(box.S, tmp2, -1);
@@ -56,61 +56,61 @@
nprimitives += Vect_get_num_primitives(Map, GV_CENTROID);
if (with_z) {
- nprimitives += Vect_get_num_primitives(Map, GV_FACE);
- nprimitives += Vect_get_num_primitives(Map, GV_KERNEL);
+ nprimitives += Vect_get_num_primitives(Map, GV_FACE);
+ nprimitives += Vect_get_num_primitives(Map, GV_KERNEL);
fprintf(stdout, "nodes=%d\n",
- Vect_get_num_nodes(Map));
+ Vect_get_num_nodes(Map));
fflush(stdout);
fprintf(stdout, "points=%d\n",
- Vect_get_num_primitives(Map, GV_POINT));
+ Vect_get_num_primitives(Map, GV_POINT));
fflush(stdout);
fprintf(stdout, "lines=%d\n",
- Vect_get_num_primitives(Map, GV_LINE));
+ Vect_get_num_primitives(Map, GV_LINE));
fflush(stdout);
fprintf(stdout, "boundaries=%d\n",
- Vect_get_num_primitives(Map, GV_BOUNDARY));
+ Vect_get_num_primitives(Map, GV_BOUNDARY));
fflush(stdout);
fprintf(stdout, "centroids=%d\n",
- Vect_get_num_primitives(Map, GV_CENTROID));
+ Vect_get_num_primitives(Map, GV_CENTROID));
fflush(stdout);
fprintf(stdout, "areas=%d\n", Vect_get_num_areas(Map));
fflush(stdout);
fprintf(stdout, "islands=%d\n",
- Vect_get_num_islands(Map));
+ Vect_get_num_islands(Map));
fflush(stdout);
if (with_z) {
- fprintf(stdout, "faces=%d\n",
- Vect_get_num_primitives(Map, GV_FACE));
- fflush(stdout);
- fprintf(stdout, "kernels=%d\n",
- Vect_get_num_primitives(Map, GV_KERNEL));
- fflush(stdout);
- fprintf(stdout, "volumes=%d\n",
- Vect_get_num_primitives(Map, GV_VOLUME));
- fflush(stdout);
- fprintf(stdout, "holes=%d\n",
- Vect_get_num_holes(Map));
- fflush(stdout);
+ fprintf(stdout, "faces=%d\n",
+ Vect_get_num_primitives(Map, GV_FACE));
+ fflush(stdout);
+ fprintf(stdout, "kernels=%d\n",
+ Vect_get_num_primitives(Map, GV_KERNEL));
+ fflush(stdout);
+ fprintf(stdout, "volumes=%d\n",
+ Vect_get_num_primitives(Map, GV_VOLUME));
+ fflush(stdout);
+ fprintf(stdout, "holes=%d\n",
+ Vect_get_num_holes(Map));
+ fflush(stdout);
fprintf(stdout, "primitives=%ld\n", nprimitives);
fflush(stdout);
fprintf(stdout, "map3d=%d\n",
- Vect_is_3d(Map) ? 1 : 0);
+ Vect_is_3d(Map) ? 1 : 0);
fflush(stdout);
@@ -127,39 +127,39 @@
num_dblinks = Vect_get_num_dblinks(Map);
if (num_dblinks <= 0) {
- G_fatal_error(_("Database connection for map <%s> is not defined in DB file"),
- input_opt);
+ G_fatal_error(_("Database connection for map <%s> is not defined in DB file"),
+ input_opt);
G_message(_("Displaying column types/names for database connection of layer <%s>:"),
- field_opt);
+ field_opt);
if ((fi = Vect_get_field2(Map, field_opt)) == NULL)
- G_fatal_error(_("Database connection not defined for layer <%s>"),
- field_opt);
+ G_fatal_error(_("Database connection not defined for layer <%s>"),
+ field_opt);
driver = db_start_driver(fi->driver);
if (driver == NULL)
- G_fatal_error(_("Unable to open driver <%s>"),
- fi->driver);
+ G_fatal_error(_("Unable to open driver <%s>"),
+ fi->driver);
db_init_handle(&handle);
db_set_handle(&handle, fi->database, NULL);
if (db_open_database(driver, &handle) != DB_OK)
- G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
- fi->database, fi->driver);
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ fi->database, fi->driver);
db_init_string(&table_name);
db_set_string(&table_name, fi->table);
if (db_describe_table(driver, &table_name, &table) != DB_OK)
- G_fatal_error(_("Unable to describe table <%s>"),
- fi->table);
+ G_fatal_error(_("Unable to describe table <%s>"),
+ fi->table);
ncols = db_get_table_number_of_columns(table);
for (col = 0; col < ncols; col++)
- fprintf(stdout, "%s|%s\n",
- db_sqltype_name(db_get_column_sqltype
- (db_get_table_column
- (table, col))),
- db_get_column_name(db_get_table_column
- (table, col)));
+ fprintf(stdout, "%s|%s\n",
+ db_sqltype_name(db_get_column_sqltype
+ (db_get_table_column
+ (table, col))),
+ db_get_column_name(db_get_table_column
+ (table, col)));
db_close_database(driver);
db_shutdown_driver(driver);
@@ -172,7 +172,7 @@
char timebuff[256];
struct TimeStamp ts;
time_ok = first_time_ok = second_time_ok = FALSE;
/* Check the Timestamp */
@@ -180,88 +180,98 @@
/* Check for valid entries, show none if no timestamp available */
if (time_ok == TRUE) {
- if (ts.count > 0)
- first_time_ok = TRUE;
- if (ts.count > 1)
- second_time_ok = TRUE;
+ if (ts.count > 0)
+ first_time_ok = TRUE;
+ if (ts.count > 1)
+ second_time_ok = TRUE;
map_type = Vect_maptype(Map);
fprintf(stdout, "name=%s\n",
- Vect_get_name(Map));
+ Vect_get_name(Map));
fprintf(stdout, "mapset=%s\n",
- Vect_get_mapset(Map));
+ Vect_get_mapset(Map));
fprintf(stdout, "location=%s\n",
- G_location());
+ G_location());
fprintf(stdout, "database=%s\n",
- G_gisdbase());
+ G_gisdbase());
fprintf(stdout, "title=%s\n",
- Vect_get_map_name(Map));
+ Vect_get_map_name(Map));
fprintf(stdout, "scale=1:%d\n",
- Vect_get_scale(Map));
+ Vect_get_scale(Map));
fprintf(stdout, "creator=%s\n",
- Vect_get_person(Map));
+ Vect_get_person(Map));
fprintf(stdout, "organization=%s\n",
- Vect_get_organization(Map));
+ Vect_get_organization(Map));
fprintf(stdout, "source_date=%s\n",
- Vect_get_map_date(Map));
+ Vect_get_map_date(Map));
/* This shows the TimeStamp (if present) */
if (time_ok == TRUE && (first_time_ok || second_time_ok)) {
- G_format_timestamp(&ts, timebuff);
- fprintf(stdout, "timestamp=%s\n", timebuff);
+ G_format_timestamp(&ts, timebuff);
+ fprintf(stdout, "timestamp=%s\n", timebuff);
else {
- fprintf(stdout, "timestamp=none\n");
+ fprintf(stdout, "timestamp=none\n");
if (map_type == GV_FORMAT_OGR ||
- map_type == GV_FORMAT_OGR_DIRECT) {
- fprintf(stdout, "format=%s,%s\n",
- Vect_maptype_info(Map), Vect_get_finfo_format_info(Map));
- fprintf(stdout, "ogr_layer=%s\n",
- Vect_get_finfo_layer_name(Map));
- fprintf(stdout, "ogr_dsn=%s\n",
- Vect_get_finfo_dsn_name(Map));
- fprintf(stdout, "feature_type=%s\n",
- Vect_get_finfo_geometry_type(Map));
+ map_type == GV_FORMAT_OGR_DIRECT) {
+ fprintf(stdout, "format=%s,%s\n",
+ Vect_maptype_info(Map), Vect_get_finfo_format_info(Map));
+ fprintf(stdout, "ogr_layer=%s\n",
+ Vect_get_finfo_layer_name(Map));
+ fprintf(stdout, "ogr_dsn=%s\n",
+ Vect_get_finfo_dsn_name(Map));
+ fprintf(stdout, "feature_type=%s\n",
+ Vect_get_finfo_geometry_type(Map));
else if (map_type == GV_FORMAT_POSTGIS) {
- fprintf(stdout, "pg_table=%s\n",
- fprintf(stdout, "pg_dbname=%s\n",
- fprintf(stdout, "geometry_column=%s\n",
- Vect_get_finfo_geometry_column(Map));
+ const struct Format_info *finfo;
+ finfo = Vect_get_finfo(Map);
+ fprintf(stdout, "pg_table=%s\n",
+ fprintf(stdout, "pg_dbname=%s\n",
+ fprintf(stdout, "geometry_column=%s\n",
+ finfo->pg.geom_column);
+ if (finfo->pg.toposchema_name) {
+ fprintf(stdout, "pg_topo_schema=%s\n",
+ finfo->pg.toposchema_name);
+ fprintf(stdout, "pg_topo_column=%s\n",
+ finfo->pg.topogeom_column);
else {
- fprintf(stdout, "format=%s\n",
- Vect_maptype_info(Map));
+ fprintf(stdout, "format=%s\n",
+ Vect_maptype_info(Map));
fprintf(stdout, "level=%d\n",
- Vect_level(Map));
+ Vect_level(Map));
if (Vect_level(Map) > 0) {
- fprintf(stdout, "num_dblinks=%d\n",
- Vect_get_num_dblinks(Map));
+ fprintf(stdout, "num_dblinks=%d\n",
+ Vect_get_num_dblinks(Map));
fprintf(stdout, "projection=%s\n",
- Vect_get_proj_name(Map));
+ Vect_get_proj_name(Map));
if (G_projection() == PROJECTION_UTM) {
- fprintf(stdout, "zone=%d\n",
- Vect_get_zone(Map));
+ fprintf(stdout, "zone=%d\n",
+ Vect_get_zone(Map));
fprintf(stdout, "digitization_threshold=%f\n",
- Vect_get_thresh(Map));
+ Vect_get_thresh(Map));
fprintf(stdout, "comment=%s\n",
- Vect_get_comment(Map));
+ Vect_get_comment(Map));
void print_info(const struct Map_info *Map)
@@ -284,177 +294,193 @@
- if (ts.count > 0)
- if (ts.count > 1)
+ if (ts.count > 0)
+ if (ts.count > 1)
divider('+');
sprintf(line, "%-17s%s", _("Name:"),
printline(line);
sprintf(line, "%-17s%s", _("Mapset:"),
printline(line);
sprintf(line, "%-17s%s", _("Location:"),
- G_location());
+ G_location());
printline(line);
sprintf(line, "%-17s%s", _("Database:"),
- G_gisdbase());
+ G_gisdbase());
printline(line);
sprintf(line, "%-17s%s", _("Title:"),
printline(line);
sprintf(line, "%-17s1:%d", _("Map scale:"),
printline(line);
sprintf(line, "%-17s%s", _("Name of creator:"),
printline(line);
sprintf(line, "%-17s%s", _("Organization:"),
printline(line);
sprintf(line, "%-17s%s", _("Source date:"),
printline(line);
- sprintf(line, "%-17s%s", _("Timestamp (first layer): "), timebuff);
- printline(line);
+ sprintf(line, "%-17s%s", _("Timestamp (first layer): "), timebuff);
+ printline(line);
else {
- strcpy(line, _("Timestamp (first layer): none"));
- printline(line);
+ strcpy(line, _("Timestamp (first layer): none"));
+ printline(line);
divider('|');
- sprintf(line, "%-17s%s (%s)", _("Map format:"),
- printline(line);
- /* for OGR format print also datasource and layer */
- sprintf(line, "%-17s%s", _("OGR layer:"),
- printline(line);
- sprintf(line, "%-17s%s", _("OGR datasource:"),
- printline(line);
- sprintf(line, "%-17s%s", _("Feature type:"),
- printline(line);
+ sprintf(line, "%-17s%s (%s)", _("Map format:"),
+ printline(line);
+ /* for OGR format print also datasource and layer */
+ sprintf(line, "%-17s%s", _("OGR layer:"),
+ printline(line);
+ sprintf(line, "%-17s%s", _("OGR datasource:"),
+ printline(line);
+ sprintf(line, "%-17s%s", _("Feature type:"),
+ printline(line);
- printline(line);
- /* for PostGIS format print also datasource and layer */
- sprintf(line, "%-17s%s", _("DB table:"),
- printline(line);
- sprintf(line, "%-17s%s", _("DB name:"),
- printline(line);
- sprintf(line, "%-17s%s", _("Geometry column:"),
- printline(line);
- printline(line);
+ printline(line);
+ /* for PostGIS format print also datasource and layer */
+ sprintf(line, "%-17s%s", _("DB table:"),
+ printline(line);
+ sprintf(line, "%-17s%s", _("DB name:"),
+ printline(line);
+ sprintf(line, "%-17s%s", _("Geometry column:"),
+ printline(line);
+ printline(line);
+ sprintf(line, "%-17s%s (%s %s)", _("Topology:"), "PostGIS",
+ _("schema:"), finfo->pg.toposchema_name);
+ printline(line);
+ sprintf(line, "%-17s%s", _("Topology column:"),
+ else
+ sprintf(line, "%-17s%s", _("Topology:"), "pseudo (simple features)");
+ printline(line);
else {
- sprintf(line, "%-17s%s", _("Map format:"),
- printline(line);
+ sprintf(line, "%-17s%s", _("Map format:"),
+ printline(line);
divider('|');
sprintf(line, " %s: %s (%s: %i)",
- _("Type of map"), _("vector"), _("level"), Vect_level(Map));
+ _("Type of map"), _("vector"), _("level"), Vect_level(Map));
printline(line);
- printline("");
- sprintf(line,
- " %-24s%-9d %-22s%-9d",
- _("Number of points:"),
- Vect_get_num_primitives(Map, GV_POINT),
- _("Number of centroids:"),
- printline(line);
- sprintf(line,
- _("Number of lines:"),
- Vect_get_num_primitives(Map, GV_LINE),
- _("Number of boundaries:"),
- printline(line);
- sprintf(line,
- _("Number of areas:"),
- Vect_get_num_areas(Map),
- _("Number of islands:"),
- printline(line);
- if (Vect_is_3d(Map)) {
- sprintf(line,
- _("Number of faces:"),
- Vect_get_num_primitives(Map, GV_FACE),
- _("Number of kernels:"),
- printline(line);
- sprintf(line,
- _("Number of volumes:"),
- Vect_get_num_volumes(Map),
- _("Number of holes:"),
- printline(line);
- printline("");
+ printline("");
+ sprintf(line,
+ " %-24s%-9d %-22s%-9d",
+ _("Number of points:"),
+ Vect_get_num_primitives(Map, GV_POINT),
+ _("Number of centroids:"),
+ printline(line);
+ sprintf(line,
+ _("Number of lines:"),
+ Vect_get_num_primitives(Map, GV_LINE),
+ _("Number of boundaries:"),
+ printline(line);
+ sprintf(line,
+ _("Number of areas:"),
+ Vect_get_num_areas(Map),
+ _("Number of islands:"),
+ printline(line);
+ if (Vect_is_3d(Map)) {
+ sprintf(line,
+ _("Number of faces:"),
+ Vect_get_num_primitives(Map, GV_FACE),
+ _("Number of kernels:"),
+ printline(line);
+ sprintf(line,
+ _("Number of volumes:"),
+ Vect_get_num_volumes(Map),
+ _("Number of holes:"),
+ printline(line);
+ printline("");
- sprintf(line, " %-24s%s",
- _("Map is 3D:"),
- Vect_is_3d(Map) ? _("Yes") : _("No"));
- printline(line);
- sprintf(line, " %-24s%-9d",
- _("Number of dblinks:"),
- printline(line);
+ sprintf(line, " %-24s%s",
+ _("Map is 3D:"),
+ Vect_is_3d(Map) ? _("Yes") : _("No"));
+ printline(line);
+ sprintf(line, " %-24s%-9d",
+ _("Number of dblinks:"),
+ printline(line);
printline("");
/* this differs from r.info in that proj info IS taken from the map here, not the location settings */
/* Vect_get_proj_name() and _zone() are typically unset?! */
- utm_zone = Vect_get_zone(Map);
- if (utm_zone < 0 || utm_zone > 60)
- strcpy(tmp1, _("invalid"));
- else if (utm_zone == 0)
- strcpy(tmp1, _("unspecified"));
- else
- sprintf(tmp1, "%d", utm_zone);
+ utm_zone = Vect_get_zone(Map);
+ if (utm_zone < 0 || utm_zone > 60)
+ strcpy(tmp1, _("invalid"));
+ else if (utm_zone == 0)
+ strcpy(tmp1, _("unspecified"));
+ else
+ sprintf(tmp1, "%d", utm_zone);
- sprintf(line, " %s: %s (%s %s)",
- _("Projection"), Vect_get_proj_name(Map),
- _("zone"), tmp1);
+ sprintf(line, " %s: %s (%s %s)",
+ _("Projection"), Vect_get_proj_name(Map),
+ _("zone"), tmp1);
else
- sprintf(line, " %s: %s",
- _("Projection"), Vect_get_proj_name(Map));
+ sprintf(line, " %s: %s",
+ _("Projection"), Vect_get_proj_name(Map));
printline(line);
printline("");
@@ -464,21 +490,21 @@
G_format_northing(box.N, tmp1, G_projection());
G_format_northing(box.S, tmp2, G_projection());
sprintf(line, " %c: %17s %c: %17s",
- 'N', tmp1, 'S', tmp2);
+ 'N', tmp1, 'S', tmp2);
printline(line);
G_format_easting(box.E, tmp1, G_projection());
G_format_easting(box.W, tmp2, G_projection());
- 'E', tmp1, 'W', tmp2);
+ 'E', tmp1, 'W', tmp2);
printline(line);
- format_double(box.B, tmp1);
- format_double(box.T, tmp2);
- sprintf(line, " %c: %17s %c: %17s",
- 'B', tmp1, 'T', tmp2);
- printline(line);
+ format_double(box.B, tmp1);
+ format_double(box.T, tmp2);
+ sprintf(line, " %c: %17s %c: %17s",
+ 'B', tmp1, 'T', tmp2);
+ printline(line);
printline("");
