[GRASS-SVN] r52570 - grass/trunk/lib/vector/Vlib
Mon Aug 6 14:34:28 PDT 2012
Author: martinl
Date: 2012-08-06 14:34:28 -0700 (Mon, 06 Aug 2012)
New Revision: 52570
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/open.c
vlib: check GRASS_VECTOR_PGFILE (defined by v.out.postgis) when opening/creating vector map
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2012-08-06 20:10:39 UTC (rev 52569)
+++ grass/trunk/lib/vector/Vlib/close.c	2012-08-06 21:34:28 UTC (rev 52570)
@@ -81,7 +81,8 @@
        write mode on level 2 */
     if (strcmp(Map->mapset, G_mapset()) == 0 &&
 	Map->support_updated &&
-	Map->plus.built == GV_BUILD_ALL) {
+	Map->plus.built == GV_BUILD_ALL &&
+        getenv("GRASS_VECTOR_PGFILE") == NULL) {  /* GRASS_VECTOR_PGFILE defined by v.out.postgis */
         unlink_file(Map, GV_TOPO_ELEMENT); /* topo */
@@ -119,7 +120,8 @@
 	/* NOTE: also close sidx for GV_FORMAT_OGR if not direct OGR access */
 	if (Map->format != GV_FORMAT_OGR_DIRECT &&
 	    Map->plus.Spidx_built == TRUE &&
+            getenv("GRASS_VECTOR_PGFILE") == NULL) /* GRASS_VECTOR_PGFILE defined by v.out.postgis */
 	    fclose(Map->plus.spidx_fp.file);
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2012-08-06 20:10:39 UTC (rev 52569)
+++ grass/trunk/lib/vector/Vlib/open.c	2012-08-06 21:34:28 UTC (rev 52570)
@@ -737,7 +737,8 @@
     else
         Map->format = GV_FORMAT_NATIVE;
-    if (Map->format != GV_FORMAT_OGR_DIRECT) {
+    if (Map->format != GV_FORMAT_OGR_DIRECT &&
         G_debug(2, " using non-direct format");
         /* check if map already exists */
@@ -776,7 +777,8 @@
     Map->plus.spidx_with_z = Map->plus.with_z = Map->head.with_z = (with_z != 0);
     if ((*Open_new_array[Map->format][1]) (Map, name, with_z) < 0) {
-        Vect_delete(name); /* clean up */
+        if (getenv("GRASS_VECTOR_PGFILE") == NULL)  /* GRASS_VECTOR_PGFILE defined by v.out.postgis */
+            Vect_delete(name); /* clean up */
         return -1;
@@ -1143,7 +1145,7 @@
         ogr_info->layer_name = G_store(Map->name);
-    def_file = getenv("GRASS_VECTOR_PGFILE");
+    def_file = getenv("GRASS_VECTOR_PGFILE");  /* GRASS_VECTOR_PGFILE defined by v.out.postgis */
     if (G_find_file2("", def_file ? def_file : "PG", G_mapset())) {
         /* PostGIS */
         if (Map->fInfo.ogr.driver_name) {
