[GRASS-SVN] r52584 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Aug 7 09:36:41 PDT 2012
Author: martinl
Date: 2012-08-07 09:36:40 -0700 (Tue, 07 Aug 2012)
New Revision: 52584
grass/trunk/lib/vector/Vlib/copy.c
vlib: document static fns in copy.c
Vect_copy_map_lines(): return error code when writing new feature fails
Modified: grass/trunk/lib/vector/Vlib/copy.c
--- grass/trunk/lib/vector/Vlib/copy.c 2012-08-07 16:28:53 UTC (rev 52583)
+++ grass/trunk/lib/vector/Vlib/copy.c 2012-08-07 16:36:40 UTC (rev 52584)
@@ -96,6 +96,16 @@
return ret;
+ \brief Copy vector features on level 1
+ \param In input vector map
+ \param field layer number (-1 for all layers)
+ \param Out output vector map
+ \return 0 on success
+ \return 1 on error
int copy_lines_1(struct Map_info *In, int field, struct Map_info *Out)
int ret, type;
@@ -138,6 +148,16 @@
return ret;
+ \brief Copy vector features on level 2
int copy_lines_2(struct Map_info *In, int field, int native, struct Map_info *Out)
int i, type, nlines;
@@ -217,7 +237,10 @@
continue; /* different layer */
- Vect_write_line(Out, type, Points, Cats);
+ if (-1 == Vect_write_line(Out, type, Points, Cats)) {
+ G_warning(_("Writing new feature failed"));
+ return 1;
Vect_destroy_line_struct(Points);
@@ -228,6 +251,15 @@
return ret;
+ \brief Copy nodes as points (PostGIS Topology only)
int copy_nodes(const struct Map_info *In, struct Map_info *Out)
int nnodes, node, with_z;
@@ -260,6 +292,16 @@
return nnodes;
+ \brief Copy areas as polygons (OGR/PostGIS simple features access only)
+ \param field layer number (> 0)
int copy_areas(const struct Map_info *In, int field, struct Map_info *Out)
int i, area, nareas, cat, isle, nisles, nisles_alloc;
