[GRASS-SVN] r52591 - grass-addons/grass7/vector/v.surf.icw
Wed Aug 8 02:12:53 PDT 2012
Author: hamish
Date: 2012-08-08 02:12:53 -0700 (Wed, 08 Aug 2012)
New Revision: 52591
   grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
r.what had its options changed, adapt.
Modified: grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py
--- grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py	2012-08-08 07:39:19 UTC (rev 52590)
+++ grass-addons/grass7/vector/v.surf.icw/v.surf.icw.py	2012-08-08 09:12:53 UTC (rev 52591)
@@ -252,8 +252,8 @@
 			     float(data_value)))
 	# we know the point is in the region, but is it in a non-null area of the cost surface?
-        rast_val = grass.read_command('r.what', input = area_mask,
-				      east_north = '%s,%s' % (position[0], position[1])
+        rast_val = grass.read_command('r.what', map = area_mask,
+				      coordinates = '%s,%s' % (position[0], position[1])
 				     ).strip().split('|')[-1]
 	if rast_val == '*':
 	    grass.message(_(" -- Skipping, point lays outside of cost_map."))
