[GRASS-SVN] r52600 - in grass/trunk: . lib/db/stubs lib/gis lib/manage lib/ogsf lib/proj lib/raster lib/raster3d lib/temporal/lib lib/vector lib/vector/Vlib lib/vector/diglib lib/vector/neta rfc
svn_grass at osgeo.org
Wed Aug 8 08:41:05 PDT 2012
Author: wenzeslaus
Date: 2012-08-08 08:41:05 -0700 (Wed, 08 Aug 2012)
New Revision: 52600
grass/trunk/grasslib.dox
grass/trunk/lib/db/stubs/add_col.c
grass/trunk/lib/db/stubs/close_cursor.c
grass/trunk/lib/gis/error.c
grass/trunk/lib/gis/gislib.dox
grass/trunk/lib/manage/sighold.c
grass/trunk/lib/ogsf/gsget.c
grass/trunk/lib/ogsf/mc33_table.h
grass/trunk/lib/proj/datum.c
grass/trunk/lib/proj/local_proto.h
grass/trunk/lib/raster/align_window.c
grass/trunk/lib/raster/cell_stats.c
grass/trunk/lib/raster/color_out.c
grass/trunk/lib/raster/rasterlib.dox
grass/trunk/lib/raster3d/raster3dlib.dox
grass/trunk/lib/temporal/lib/connect.c
grass/trunk/lib/vector/Vlib/read_ogr.c
grass/trunk/lib/vector/diglib/update.c
grass/trunk/lib/vector/neta/bridge.c
grass/trunk/lib/vector/neta/centrality.c
grass/trunk/lib/vector/vectorlib.dox
grass/trunk/rfc/RFC1_PSC.dox
grass/trunk/rfc/rfc_list.dox
dox: reducing doxygen warnings
Modified: grass/trunk/grasslib.dox
--- grass/trunk/grasslib.dox 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/grasslib.dox 2012-08-08 15:41:05 UTC (rev 52600)
@@ -352,7 +352,7 @@
and write to <b>output</b> so that data may not be lost. For example
<tt>v.spag</tt> works on <b>map</b> at in GRASS GIS 5.0 but if program
(system) crashes or threshold was specified incorrectly and vector was
-not backuped, data were lost. In this case </b>map</b> option should
+not backuped, data were lost. In this case <b>map</b> option should
be replaced by <b>input</b> and <b>output</b>.
Topology is always built by default if the coor file was modified.
Modified: grass/trunk/lib/db/stubs/add_col.c
--- grass/trunk/lib/db/stubs/add_col.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/db/stubs/add_col.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,10 +1,7 @@
#include <grass/dbmi.h>
- \fn int db__driver_add_column (dbString *tableName, dbColumn *column)
- \brief
- \return
- \param
+ This function calls db_procedure_not_implemented().
int db__driver_add_column(dbString * tableName, dbColumn * column)
Modified: grass/trunk/lib/db/stubs/close_cursor.c
--- grass/trunk/lib/db/stubs/close_cursor.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/db/stubs/close_cursor.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,10 +1,7 @@
- \fn int db__driver_close_cursor (dbCursor *cursor)
- \brief
- \return
- \param
int db__driver_close_cursor(dbCursor * cursor)
Modified: grass/trunk/lib/gis/error.c
--- grass/trunk/lib/gis/error.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/gis/error.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- * \file error.c
+ * \file lib/gis/error.c
* \brief GIS Library - Error messages functions
Modified: grass/trunk/lib/gis/gislib.dox
--- grass/trunk/lib/gis/gislib.dox 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/gis/gislib.dox 2012-08-08 15:41:05 UTC (rev 52600)
@@ -93,7 +93,7 @@
It is assumed that the reader has read \ref location for a general
description of GRASS databases, \ref Raster_File_Processing for
-details about raster map layers in GRASS, and Region_and_Mask
+details about raster map layers in GRASS, and \ref Region_and_Mask
(<b>???</b>) which discusses regions and masks. The routines in the
<em>GIS Library</em> are presented in functional groupings, rather
than in alphabetical order. The order of presentation will, it is
@@ -170,7 +170,7 @@
- G_set_error_routine() change error handling
This routine provides a different error handler for G_fatal_error()
-and G_warning(). The <m>handler</em> routine must be defined as
+and G_warning(). The <em>handler</em> routine must be defined as
follows:
\code
@@ -282,7 +282,7 @@
<em>name</em> is not set, G_getenv() issues an error message and calls
exit(). G__setenv() just returns the NULL pointer.
- - G_setenv ()
+ - G_setenv()
- G__setenv()
@@ -748,7 +748,7 @@
Latitudes and longitudes are specified in degrees. Northern latitudes
range from 0 to 90 degrees, and southern latitudes from 0 to
--90. Longitudes have no limits since longitudes ±360 degrees are
+-90. Longitudes have no limits since longitudes ±360 degrees are
equivalent.
Coordinates are represented in ASCII using the format
@@ -810,7 +810,7 @@
These next routines provide a mechanism for determining the relative
-position of a pair of longitudes. Since longitudes of ±360 are
+position of a pair of longitudes. Since longitudes of ±360 are
equivalent, but GRASS requires the east to be bigger than the west,
some adjustment of coordinates is necessary.
@@ -1477,8 +1477,9 @@
\subsection Complete_Structure_Members_Table Complete Structure Members Table
-<v>struct Flag</v>
-<table border=1>
+\subsubsection memtabFlag struct Flag
+<table>
<tr>
<td>structure member</td>
<td>C type</td>
@@ -1509,8 +1510,9 @@
</tr>
</table>
-<b>struct Option</b>
-<table border=1>
+\subsubsection memtabOption struct Option
+<table>
<tr>
<td>C type </td>
@@ -1531,7 +1533,7 @@
<td>int </td>
<td>YES </td>
<td>none </td>
- <td>Option type: <br>
+ <td>%Option type: <br>
TYPE_STRING <br>
TYPE_INTEGER <br>
TYPE_DOUBLE <br>
Modified: grass/trunk/lib/manage/sighold.c
--- grass/trunk/lib/manage/sighold.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/manage/sighold.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- \file lib/manage/sighol.c
+ \file lib/manage/sighold.c
\brief Manage Library - Hold signals
Modified: grass/trunk/lib/ogsf/gsget.c
--- grass/trunk/lib/ogsf/gsget.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/ogsf/gsget.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- \file gsd_get.c
+ \file gsget.c
\brief OGSF library - get map attribute (lower level functions)
Modified: grass/trunk/lib/ogsf/mc33_table.h
--- grass/trunk/lib/ogsf/mc33_table.h 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/ogsf/mc33_table.h 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- \file m33_table.h
+ \file mc33_table.h
Modified: grass/trunk/lib/proj/datum.c
--- grass/trunk/lib/proj/datum.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/proj/datum.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,6 +1,6 @@
- \file datum.c
+ \file lib/proj/datum.c
\brief GProj library - Functions for reading datum parameters from the location database
Modified: grass/trunk/lib/proj/local_proto.h
--- grass/trunk/lib/proj/local_proto.h 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/proj/local_proto.h 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,6 +1,6 @@
- \file local_proto.h
+ \file lib/proj/local_proto.hlocal_proto.h
Modified: grass/trunk/lib/raster/align_window.c
--- grass/trunk/lib/raster/align_window.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/raster/align_window.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- * \file gis/align_window.c
+ * \file lib/raster/align_window.c
* \brief GIS Library - Window alignment functions.
Modified: grass/trunk/lib/raster/cell_stats.c
--- grass/trunk/lib/raster/cell_stats.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/raster/cell_stats.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -174,8 +174,8 @@
* \brief Random query of cell stats
* This routine allows a random query of the Cell_stats structure. The
- * <i>count</i> associated with the raster value <i>cat</i> is
- * set. The routine returns 1 if <i>cat<i> was found in the
+ * \p count associated with the raster value \p cat is
+ * set. The routine returns 1 if \p cat was found in the
* structure, 0 otherwise.
* Allow finding the count for the NULL-value.
Modified: grass/trunk/lib/raster/color_out.c
--- grass/trunk/lib/raster/color_out.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/raster/color_out.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -34,7 +34,7 @@
\brief Print color table
\param colors pointer to Colors structure
- \param min,max minimum and maximum value for percentage output (used only when <em>perc<em> is non-zero)
+ \param min,max minimum and maximum value for percentage output (used only when \p perc is non-zero)
\param fp file where to print color table rules
\param perc TRUE for percentage output
Modified: grass/trunk/lib/raster/rasterlib.dox
--- grass/trunk/lib/raster/rasterlib.dox 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/raster/rasterlib.dox 2012-08-08 15:41:05 UTC (rev 52600)
@@ -6,6 +6,8 @@
by GRASS Development Team (http://grass.osgeo.org)
+\tableofcontents
<b>TODO: Needs to be cleaned up. The upper GRASS 4.x and the lower
GRASS 5.x/6.x parts need to me merged and updated to GRASS 7</b>
@@ -779,9 +781,10 @@
fprintf(stdout, "%ld %ld\n", (long) cat, count);
\endcode
-\section GRASS_5_raster_API GRASS 5 raster API [needs to be merged
- into above sections]
+\section GRASS_5_raster_API GRASS 5 raster API
+<em>Needs to be merged into above sections.<em>
\subsection The_CELL_Data_Type The CELL Data Type
GRASS integer raster map data is defined to be of type CELL. This data
@@ -824,7 +827,7 @@
be used in routines which do not know about the CELL type, that the
values must be cast to or from long.
-\subsection 5.0 Changes to <TT>"gis.h"</TT>
+\subsection GRASS_5_raster_API_gish Changes to gis.h
The "gis.h" contains 5 new items:
@@ -1188,7 +1191,7 @@
a null value).
For a floating-point map, any cells which were null will become zero
-(when writing FP data, a null has a zero written to the fcell/<map>
+(when writing FP data, a null has a zero written to the fcell/\<map\>
file, and the corresponding bit is set in the <tt>null</tt> file).
\section Color_Functions Color Functions (new and upgraded)
@@ -1201,7 +1204,7 @@
struct
- int version; /* set by read\_colors: -1=old,1=new */
+ int version; /* set by read_colors: -1=old,1=new */
DCELL shift;
int invert;
int is_float; /* defined on floating point raster data? */
@@ -1318,7 +1321,7 @@
Modified to return a color for the NULL-value.
-\section Changes_to_the_Colors_structure Changes to the <TT>Colors</TT> structure
+\section Changes_to_the_Colors_structure Changes to the Colors structure
Modifications to the Colors structure to support colors for
@@ -1341,7 +1344,7 @@
looking up colors instead of linearly searching through all color
rules.
-\section Changes_to_the_colr_file Changes to the <TT>colr</TT> file
+\section Changes_to_the_colr_file Changes to the \c colr file
- The rules are written out using floating-point format, removing trailing zeros (possibly producing integers) . For example, to ramp from red to green for the range [1.3,5.0]:
@@ -1640,7 +1643,7 @@
\endcode
-\section Changes_to_the_cats_file Changes to the <TT>cats</TT> file
+\section Changes_to_the_cats_file Changes to the \c cats file
The format of explicit label entries is the same for integer maps.
Modified: grass/trunk/lib/raster3d/raster3dlib.dox
--- grass/trunk/lib/raster3d/raster3dlib.dox 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/raster3d/raster3dlib.dox 2012-08-08 15:41:05 UTC (rev 52600)
@@ -106,7 +106,7 @@
\verbatim
Precision
RLE
-\endverbatim
+\endverbatim
<P>
Precision indicates how many of the mantissa bits should be stored on
@@ -307,7 +307,7 @@
int proj; /* Projection (see gis.h) */
int zone; /* Projection zone (see gis.h) */
-} RASTER3D\_Region;
+} RASTER3D_Region;
\endverbatim
<P>
@@ -608,18 +608,18 @@
No environment variable.
<P>
+\verbatim
void Rast3d_set_unit (map, unit)
RASTER3d_Map; /* the map */
char *unit; /* The data unit description */
-<P>
void Rast3d_set_vertical_unit (map, unit)
char *unit; /* Use the standard from units.c in lib/gis */
-<P>
void Rast3d_set_vertical_unit2 (map, unit)
int unit; /* defined in gis.h */
-<P>
+\endverbatim
\section Error_Handling Error Handling: Setting the error function
@@ -828,10 +828,15 @@
return value.
<P>
-double Rast3d_getDoubleRegion(void *map, int x, int y, int z)Is
- equivalent to <TT>Rast3d_getValueRegion (map, x, y, z, &value,
- DCELL_TYPE);</TT> return value.
+\code
+Rast3d_getDoubleRegion(map, x, y, z)
+\endcode
+is equivalent to
+\code
+Rast3d_getValueRegion(map, x, y, z, &value, DCELL_TYPE)
+\endcode
<P>
int Rast3d_putValue(void *map, int x, int y, int z, char *value, int
type)After converting <EM>*value</EM> of <EM>type</EM> into the type specified
@@ -1161,8 +1166,13 @@
NULL ... otherwise.
<P>
-char *Rast3d_allocTiles(void *map, int nofTiles)
-Is equivalent to Rast3d_allocTilesType (map, nofTiles, Rast3d_fileTypeMap (map)).
+\code
+Rast3d_allocTiles(map, nofTiles)
+\endcode
+is equivalent to
+\code
+Rast3d_allocTilesType(map, nofTiles, Rast3d_fileTypeMap(map)).
+\endcode
<P>
void Rast3d_freeTiles(char *tiles)
@@ -1563,9 +1573,11 @@
Rast3d_getValueRegion() (cf. Section 22.4.3).
<P>
-void Rast3d_nearestNeighbor(void *map, int row, int col, int depth, char
- *value, int type) The default resampling function which uses nearest
- neighbor resampling.
+The default resampling function which uses nearest
+neighbor resampling.
+\code
+Rast3d_nearestNeighbor(map, row, col, depth, value, type)
+\endcode
<P>
void Rast3d_getResamplingFun(void *map, void (**resampleFun)())
Modified: grass/trunk/lib/temporal/lib/connect.c
--- grass/trunk/lib/temporal/lib/connect.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/temporal/lib/connect.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- \file lib/temporal/src/connect.c
+ \file lib/temporal/lib/connect.c
\brief Temporal GIS Library - connect to TGIS DB
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- \file lib/vector/Vlib/lib/vector/Vlib/read_ogr.c
+ \file lib/vector/Vlib/read_ogr.c
\brief Vector library - reading data (OGR format)
Modified: grass/trunk/lib/vector/diglib/update.c
--- grass/trunk/lib/vector/diglib/update.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/vector/diglib/update.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,6 +1,6 @@
- * \file update.c
+ * \file lib/vector/diglib/update.c
* \brief Vector library - update topology (lower level functions)
Modified: grass/trunk/lib/vector/neta/bridge.c
--- grass/trunk/lib/vector/neta/bridge.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/vector/neta/bridge.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- \file vector/neta/bridges.c
+ \file lib/vector/neta/bridge.c
\brief Network Analysis library - bridges
Modified: grass/trunk/lib/vector/neta/centrality.c
--- grass/trunk/lib/vector/neta/centrality.c 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/vector/neta/centrality.c 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,5 +1,5 @@
- \file vector/neta/centality.c
+ \file lib/vector/neta/centrality.c
\brief Network Analysis library - centrality
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/lib/vector/vectorlib.dox 2012-08-08 15:41:05 UTC (rev 52600)
@@ -71,7 +71,7 @@
OGR sources etc.)
- <em>portability</em>: platform independent internal format, read- and
writable on 32bit, 64bit etc. computer architectures
-- integrated \ref vlibDglib - support for vector network analysis
+- integrated \ref dglib - support for vector network analysis
- <em>spatial index</em>: based on R-tree method for fast vector
geometry access (see \ref vlibSpidx)
- <em>multi-attribute</em>: attributes saved in external Relational
Modified: grass/trunk/rfc/RFC1_PSC.dox
--- grass/trunk/rfc/RFC1_PSC.dox 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/rfc/RFC1_PSC.dox 2012-08-08 15:41:05 UTC (rev 52600)
@@ -26,8 +26,8 @@
The two primary functions of the PSC are:
-# To enforce control over the GRASS codebase. This can be summarised as:
- - Enforce mechanisms to ensure quality control.</li>
- - Ensure compliance with all required legal measures.</li>
+ - Enforce mechanisms to ensure quality control.
+ - Ensure compliance with all required legal measures.
-# Project Management and responsibility for the "public face" of
GRASS.
Modified: grass/trunk/rfc/rfc_list.dox
--- grass/trunk/rfc/rfc_list.dox 2012-08-08 15:37:33 UTC (rev 52599)
+++ grass/trunk/rfc/rfc_list.dox 2012-08-08 15:41:05 UTC (rev 52600)
@@ -1,13 +1,13 @@
-\mainpage RFC List of the GRASS Project Steering Committee
+\page RFC List of the GRASS Project Steering Committee
List of \link psc_motions Motions of the GRASS Project Steering Committee\endlink
A list of all GRASS RFC documents, with status.
-- \link rfc1_psc RFC 1: Project Steering Committee Guidelines\endlink (Adopted)
-- \link rfc2_psc RFC 2: Legal aspects of code contributions\endlink (Adopted)
-- \link rfc3_psc RFC 3: PSC Voting Procedures\endlink (Proposed)
+- \subpage rfc1_psc (Adopted)
+- \subpage rfc2_psc (Adopted)
+- \subpage rfc3_psc (Proposed)
<a href="http://grass.osgeo.org/">GRASS GIS</a>
