[GRASS-SVN] r52618 - grass/trunk/gui/wxpython/nviz
svn_grass at osgeo.org
Fri Aug 10 00:35:27 PDT 2012
Author: wenzeslaus
Date: 2012-08-10 00:35:26 -0700 (Fri, 10 Aug 2012)
New Revision: 52618
grass/trunk/gui/wxpython/nviz/wxnviz.py
dox: fixing param warnings in wxnviz
Modified: grass/trunk/gui/wxpython/nviz/wxnviz.py
--- grass/trunk/gui/wxpython/nviz/wxnviz.py 2012-08-10 04:12:24 UTC (rev 52617)
+++ grass/trunk/gui/wxpython/nviz/wxnviz.py 2012-08-10 07:35:26 UTC (rev 52618)
@@ -87,7 +87,7 @@
def __init__(self, glog, gprogress):
"""!Initialize Nviz class instance
- @param log logging area
+ @param glog logging area
@param gprogress progressbar
global errfunc, perfunc, log, progress
@@ -300,11 +300,13 @@
def SetLight(self, x, y, z, color, bright, ambient, w = 0, lid = 1):
"""!Change lighting settings
@param x,y,z position
@param color light color (as string)
@param bright light brightness
@param ambient light ambient
@param w local coordinate (default to 0)
+ @param lid light id
Nviz_set_light_position(self.data, lid, x, y, z, w)
Nviz_set_light_bright(self.data, lid, bright)
@@ -769,8 +771,8 @@
@todo all
- @param surface id (< 0 for all)
- @param color color string (R:G:B)
+ @param id surface id (< 0 for all)
+ @param color_str color string (R:G:B)
@return 1 on success
@return -1 surface not found
@@ -934,7 +936,8 @@
@param id vector id
@param width line width
- @param flat
+ @param size size of the symbol
+ @param marker type of the symbol
@return -1 vector set not found
@@ -997,7 +1000,7 @@
"""!Read vector colors
@param name vector map name
- @mapset mapset name ("" for search path)
+ @param mapset mapset name (empty string (\c "") for search path)
@return -1 on error
@return 0 if color table missing
@@ -1112,6 +1115,7 @@
@param id volume id
@param level isosurface level (topography)
+ @param isosurf_id isosurface id
@return -1 on failure
@@ -1136,6 +1140,7 @@
"""!Add new slice
@param id volume id
+ @param slice_id slice id
@return number of slices
@@ -1458,7 +1463,8 @@
def SetIsosurfaceMode(self, id, mode):
"""!Set draw mode for isosurfaces
- @param mode
+ @param id isosurface id
+ @param mode isosurface draw mode
@return -1 volume set not found
@@ -1477,7 +1483,8 @@
def SetSliceMode(self, id, mode):
"""!Set draw mode for slices
- @param mode
+ @param id slice id
+ @param mode slice draw mode
@@ -1496,6 +1503,7 @@
def SetIsosurfaceRes(self, id, res):
"""!Set draw resolution for isosurfaces
@param res resolution value
@@ -1515,6 +1523,7 @@
def SetSliceRes(self, id, res):
"""!Set draw resolution for slices
@@ -1562,7 +1571,6 @@
@param id volume id
- @param x1,x2,y1,y2,z1,z2 slice coordinates
@param value transparency value (0 - 255)
@@ -1587,6 +1595,8 @@
def SetIsosurfaceInOut(self, id, isosurf_id, inout):
"""!Set inout mode
+ @param id volume id
@param inout mode true/false
