[GRASS-SVN] r52621 - in grass/trunk: lib/python/temporal temporal/t.create temporal/t.list temporal/t.rast.aggregate temporal/t.rast.aggregate.ds temporal/t.rast.gapfill temporal/t.remove temporal/t.support temporal/t.unregister temporal/t.vect.observe.strds temporal/t.vect.what.strds
Fri Aug 10 07:48:01 PDT 2012
Author: huhabla
Date: 2012-08-10 07:48:01 -0700 (Fri, 10 Aug 2012)
New Revision: 52621
   grass/trunk/lib/python/temporal/abstract_dataset.py
   grass/trunk/lib/python/temporal/abstract_map_dataset.py
   grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
   grass/trunk/lib/python/temporal/base.py
   grass/trunk/lib/python/temporal/core.py
   grass/trunk/lib/python/temporal/extract.py
   grass/trunk/lib/python/temporal/mapcalc.py
   grass/trunk/lib/python/temporal/metadata.py
   grass/trunk/lib/python/temporal/space_time_datasets.py
   grass/trunk/lib/python/temporal/space_time_datasets_tools.py
   grass/trunk/lib/python/temporal/spatial_extent.py
   grass/trunk/lib/python/temporal/temporal_extent.py
   grass/trunk/lib/python/temporal/temporal_relationships.py
   grass/trunk/lib/python/temporal/univar_statistics.py
   grass/trunk/temporal/t.create/t.create.py
   grass/trunk/temporal/t.list/t.list.py
   grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
   grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
   grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
   grass/trunk/temporal/t.remove/t.remove.py
   grass/trunk/temporal/t.support/t.support.py
   grass/trunk/temporal/t.unregister/t.unregister.py
   grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
Major code review and application of pep8 coding standard.
Several doctests added to temporal base classes.
Modified: grass/trunk/lib/python/temporal/abstract_dataset.py
--- grass/trunk/lib/python/temporal/abstract_dataset.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/abstract_dataset.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -7,12 +7,18 @@
 Usage:
- at code
-import grass.temporal as tgis
+>>> import grass.temporal as tgis
+>>> ad = abstract_dataset()
+>>> ad.reset(ident="soil at PERMANENT")
+Traceback (most recent call last):
+  File "/usr/lib/python2.7/doctest.py", line 1289, in __run
+    compileflags, 1) in test.globs
+  File "<doctest __main__[2]>", line 1, in <module>
+    ad.reset(ident="soil at PERMANENT")
+  File "abstract_dataset.py", line 53, in reset
+    raise ImplementationError("This method must be implemented in the subclasses")
+ImplementationError: 'This method must be implemented in the subclasses'
- at endcode
 (C) 2008-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
@@ -26,74 +32,84 @@
 from spatial_extent import *
 from metadata import *
+class ImplementationError(Exception):
+    """!Exception raised for the calling of methods that should be implemented in
+       sub classes.
+    def __init__(self, msg):
+        self.msg = msg
+    def __str__(self):
+        return repr(self.msg)
 class abstract_dataset(object):
     """!This is the base class for all datasets (raster, vector, raster3d, strds, stvds, str3ds)"""
     def reset(self, ident):
-	"""!Reset the internal structure and set the identifier
+        """!Reset the internal structure and set the identifier
            @param ident: The identifier of the dataset
-	raise IOError("This method must be implemented in the subclasses")
     def get_type(self):
         """!Return the type of this class"""
     def get_new_instance(self, ident):
         """!Return a new instance with the type of this class
     def spatial_overlapping(self, dataset):
         """!Return True if the spatial extents are overlapping"""
     def spatial_relation(self, dataset):
         """Return the spatial relationship between self and dataset"""
     def print_info(self):
         """!Print information about this class in human readable style"""
     def print_shell_info(self):
         """!Print information about this class in shell style"""
     def print_self(self):
-	"""!Print the content of the internal structure to stdout"""
-	self.base.print_self()
-	if self.is_time_absolute():
-	    self.absolute_time.print_self()
+        """!Print the content of the internal structure to stdout"""
+        self.base.print_self()
+        if self.is_time_absolute():
+            self.absolute_time.print_self()
         if self.is_time_relative():
-	    self.relative_time.print_self()
-	self.spatial_extent.print_self()
-	self.metadata.print_self()
+            self.relative_time.print_self()
+        self.spatial_extent.print_self()
+        self.metadata.print_self()
     def set_id(self, ident):
-	self.base.set_id(ident)
-	    self.absolute_time.set_id(ident)
+        self.base.set_id(ident)
+            self.absolute_time.set_id(ident)
-	    self.relative_time.set_id(ident)
-	self.spatial_extent.set_id(ident)
-	self.metadata.set_id(ident)
+            self.relative_time.set_id(ident)
+        self.spatial_extent.set_id(ident)
+        self.metadata.set_id(ident)
     def get_id(self):
-	"""!Return the unique identifier of the dataset"""
+        """!Return the unique identifier of the dataset"""
         return self.base.get_id()
     def get_name(self):
-	"""!Return the name"""
+        """!Return the name"""
         return self.base.get_name()
     def get_mapset(self):
-	"""!Return the mapset"""
+        """!Return the mapset"""
         return self.base.get_mapset()
     def get_valid_time(self):
@@ -103,27 +119,27 @@
         start = None
         end = None
             start = self.absolute_time.get_start_time()
             end = self.absolute_time.get_end_time()
             start = self.relative_time.get_start_time()
             end = self.relative_time.get_end_time()
         return (start, end)
     def get_absolute_time(self):
         """!Returns a tuple of the start, the end valid time and the timezone of the map
            @return A tuple of (start_time, end_time, timezone)
         tz = self.absolute_time.get_timezone()
         return (start, end, tz)
     def get_relative_time(self):
         """!Returns the relative time interval (start_time, end_time, unit) or None if not present"""
@@ -132,7 +148,7 @@
         unit = self.relative_time.get_unit()
         return (start, end, unit)
     def get_relative_time_unit(self):
         """!Returns the relative time unit or None if not present"""
@@ -142,57 +158,49 @@
     def check_relative_time_unit(self, unit):
         """!Check if unit is of type  years, months, days, hours, minutes or seconds
-           Return True if success or False otherwise
+           Return True if success or False otherwise
         # Check unit
-        units = ["years","months","days","hours","minutes","seconds"]
+        units = ["years", "months", "days", "hours", "minutes", "seconds"]
         if unit not in units:
             return False
         return True
     def get_temporal_type(self):
         """!Return the temporal type of this dataset"""
         return self.base.get_ttype()
     def get_spatial_extent(self):
         """!Return a tuple of spatial extent (north, south, east, west, top, bottom) """
-        north = self.spatial_extent.get_north()
-        south = self.spatial_extent.get_south()
-        east = self.spatial_extent.get_east()
-        west = self.spatial_extent.get_west()
-        top = self.spatial_extent.get_top()
-        bottom = self.spatial_extent.get_bottom()
-        return (north, south, east, west, top, bottom)
+        return self.spatial_extent.get_spatial_extent()
     def select(self, dbif=None):
-	"""!Select temporal dataset entry from database and fill up the internal structure"""
+        """!Select temporal dataset entry from database and fill up the internal structure"""
         dbif, connect = init_dbif(dbif)
-	self.base.select(dbif)
-	    self.absolute_time.select(dbif)
+        self.base.select(dbif)
+            self.absolute_time.select(dbif)
-	    self.relative_time.select(dbif)
-	self.spatial_extent.select(dbif)
-	self.metadata.select(dbif)
+            self.relative_time.select(dbif)
+        self.spatial_extent.select(dbif)
+        self.metadata.select(dbif)
         if connect:
             dbif.close()
     def is_in_db(self, dbif=None):
         """!Check if the temporal dataset entry is in the database
            @param dbif: The database interface to be used
         return self.base.is_in_db(dbif)
     def delete(self):
-	"""!Delete temporal dataset entry from database if it exists"""
+        """!Delete temporal dataset entry from database if it exists"""
     def insert(self, dbif=None, execute=True):
         """!Insert temporal dataset entry into database from the internal structure
@@ -204,20 +212,22 @@
         # Build the INSERT SQL statement
         statement = self.base.get_insert_statement_mogrified(dbif)
-            statement += self.absolute_time.get_insert_statement_mogrified(dbif)
+            statement += self.absolute_time.get_insert_statement_mogrified(
+                dbif)
-            statement += self.relative_time.get_insert_statement_mogrified(dbif)
+            statement += self.relative_time.get_insert_statement_mogrified(
+                dbif)
         statement += self.spatial_extent.get_insert_statement_mogrified(dbif)
         statement += self.metadata.get_insert_statement_mogrified(dbif)
         if execute == True:
             dbif.execute_transaction(statement)
-	    if connect:
-		dbif.close()
+            if connect:
+                dbif.close()
             return ""
         if connect:
@@ -225,59 +235,64 @@
         return statement
     def update(self, dbif=None, execute=True):
-	"""!Update temporal dataset entry of database from the internal structure
-	   excluding None variables
+        """!Update temporal dataset entry of database from the internal structure
+           excluding None variables
            @param execute: If True the SQL statements will be executed.
                            If False the prepared SQL statements are returned and must be executed by the caller.
         # Build the UPDATE SQL statement
         statement = self.base.get_update_statement_mogrified(dbif)
-            statement += self.absolute_time.get_update_statement_mogrified(dbif)
+            statement += self.absolute_time.get_update_statement_mogrified(
+                dbif)
-            statement += self.relative_time.get_update_statement_mogrified(dbif)
+            statement += self.relative_time.get_update_statement_mogrified(
+                dbif)
         statement += self.spatial_extent.get_update_statement_mogrified(dbif)
         statement += self.metadata.get_update_statement_mogrified(dbif)
         if execute == True:
-	    if connect:
-		dbif.close()
+            if connect:
+                dbif.close()
             return ""
         if connect:
             dbif.close()
         return statement
     def update_all(self, dbif=None, execute=True):
-	   and include None varuables.
+           and include None variables.
         statement = self.base.get_update_all_statement_mogrified(dbif)
-            statement += self.absolute_time.get_update_all_statement_mogrified(dbif)
+            statement += self.absolute_time.get_update_all_statement_mogrified(
+                dbif)
-            statement += self.relative_time.get_update_all_statement_mogrified(dbif)
-        statement += self.spatial_extent.get_update_all_statement_mogrified(dbif)
+            statement += self.relative_time.get_update_all_statement_mogrified(
+                dbif)
+        statement += self.spatial_extent.get_update_all_statement_mogrified(
+            dbif)
         statement += self.metadata.get_update_all_statement_mogrified(dbif)
         if execute == True:
-	    if connect:
-		dbif.close()
+            if connect:
+                dbif.close()
             return ""
         if connect:
@@ -285,107 +300,33 @@
         return statement
     def set_time_to_absolute(self):
-	self.base.set_ttype("absolute")
+        self.base.set_ttype("absolute")
     def set_time_to_relative(self):
         self.base.set_ttype("relative")
     def is_time_absolute(self):
-	if self.base.D.has_key("temporal_type"):
-	    return self.base.get_ttype() == "absolute"
+        if "temporal_type" in self.base.D:
+            return self.base.get_ttype() == "absolute"
         else:
-	    return None
+            return None
     def is_time_relative(self):
-	    return self.base.get_ttype() == "relative"
+            return self.base.get_ttype() == "relative"
         else:
-	    return None
+            return None
     def temporal_relation(self, map):
-	"""!Return the temporal relation of this and the provided temporal map"""
-	if self.is_time_absolute() and map.is_time_absolute():
-	    return self.absolute_time.temporal_relation(map.absolute_time)
+        """!Return the temporal relation of this and the provided temporal map"""
+        if self.is_time_absolute() and map.is_time_absolute():
+            return self.absolute_time.temporal_relation(map.absolute_time)
         if self.is_time_relative() and map.is_time_relative():
-	    return self.relative_time.temporal_relation(map.relative_time)
-    	return None
+            return self.relative_time.temporal_relation(map.relative_time)
+        return None
-class abstract_dataset_comparison_key_start_time(object):
-    """!This comparison key can be used to sort lists of abstract datasets by start time
-        Example:
-        # Return all maps in a space time raster dataset as map objects
-	map_list = strds.get_registered_maps_as_objects()
-	# Sort the maps in the list by start time
-	sorted_map_list = sorted(map_list, key=abstract_dataset_comparison_key_start_time)
-    def __init__(self, obj, *args):
-	self.obj = obj
-    def __lt__(self, other):
-	startA, endA = self.obj.get_valid_time()
-	startB, endB = other.obj.get_valid_time()
-	return startA < startB
-    def __gt__(self, other):
-	return startA > startB
-    def __eq__(self, other):
-	return startA == startB
-    def __le__(self, other):
-	return startA <= startB
-    def __ge__(self, other):
-	return startA >= startB
-    def __ne__(self, other):
-	return startA != startB
-class abstract_dataset_comparison_key_end_time(object):
-    """!This comparison key can be used to sort lists of abstract datasets by end time
-        Example:
-	# Sort the maps in the list by end time
-	sorted_map_list = sorted(map_list, key=abstract_dataset_comparison_key_end_time)
-	self.obj = obj
-	return endA < endB
-	return endA > endB
-	return endA == endB
-	return endA <= endB
-	return endA >= endB
-	return endA != endB
\ No newline at end of file
+if __name__ == "__main__":
+    import doctest
+    doctest.testmod()
Modified: grass/trunk/lib/python/temporal/abstract_map_dataset.py
--- grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/abstract_map_dataset.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -23,14 +23,15 @@
 from abstract_dataset import *
 from datetime_math import *
-class temporal_map_relations(abstract_dataset):
+class TemporalMapRelations(abstract_dataset):
     """!This class implements a temporal topology access structure
        This object will be set up by temporal topology creation methods.
        If correctly initialize the calls next() and prev() let the user walk temporally forward
        and backward in time.
        The following temporal relations with access methods are supported:
        * equal
        * follows
@@ -39,322 +40,355 @@
        * overlapped
        * during (including starts, finishes)
        * contains (including started, finished)
        Code:
        # We have build the temporal topology and we know the first map
        start = first
        while start:
-	   # Print all maps this map temporally contains
+           # Print all maps this map temporally contains
            dlist = start.get_contains()
            for _map in dlist:
                _map.print_info()
-           start = start.next()
+           start = start.next()
     def __init__(self):
         self.reset_temporal_topology()
     def reset_temporal_topology(self):
-	"""!Reset any information about temporal topology"""
+        """!Reset any information about temporal topology"""
         self._temporal_topology = {}
         self._has_temporal_topology = False
     def set_temporal_topology_build_true(self):
-	"""!Same as name"""
-	self._has_temporal_topology = True
+        """!Same as name"""
+        self._has_temporal_topology = True
     def set_temporal_topology_build_false(self):
-	self._has_temporal_topology = False
+        self._has_temporal_topology = False
     def is_temporal_topology_build(self):
-	"""!Check if the temporal topology was build"""
-	return self._has_temporal_topology
+        """!Check if the temporal topology was build"""
+        return self._has_temporal_topology
-    def set_next(self, _map):
-	"""!Set the map that is temporally as closest located after this map.
-	   Temporally located means that the start time of the "next" map is
-	   temporally located AFTER the start time of this map, but temporally
-	   near than other maps of the same dataset.
-	   @param _map: This object should be of type abstract_map_dataset or derived classes
+    def set_temporal_next(self, _map):
+        """!Set the map that is temporally as closest located after this map.
+           Temporally located means that the start time of the "next" map is
+           temporally located AFTER the start time of this map, but temporally
+           near than other maps of the same dataset.
+           @param _map: This object should be of type abstract_map_dataset or derived classes
         self._temporal_topology["NEXT"] = _map
-    def set_prev(self, _map):
-	"""!Set the map that is temporally as closest located before this map.
-	   Temporally located means that the start time of the "previous" map is
-	   temporally located BEFORE the start time of this map, but temporally
+    def set_temporal_prev(self, _map):
+        """!Set the map that is temporally as closest located before this map.
+           Temporally located means that the start time of the "previous" map is
+           temporally located BEFORE the start time of this map, but temporally
         self._temporal_topology["PREV"] = _map
-    def next(self):
-	"""!Return the map with a start time temporally located after
-	   the start time of this map, but temporal closer than other maps
-	   @return A map object or None
-        if not self._temporal_topology.has_key("NEXT"):
+    def temporal_next(self):
+        """!Return the map with a start time temporally located after
+           the start time of this map, but temporal closer than other maps
+           @return A map object or None
+        if "NEXT" not in self._temporal_topology:
             return None
         return self._temporal_topology["NEXT"]
-    def prev(self):
-	"""!Return the map with a start time temporally located before
-        if not self._temporal_topology.has_key("PREV"):
+    def temporal_prev(self):
+        """!Return the map with a start time temporally located before
+        if "PREV" not in self._temporal_topology:
             return None
         return self._temporal_topology["PREV"]
-    def append_equivalent(self, _map):
-	"""!Append a map with equivalent temporal extent as this map
-        if not self._temporal_topology.has_key("EQUAL"):
+    def append_temporal_equivalent(self, _map):
+        """!Append a map with equivalent temporal extent as this map
+        if "EQUAL" not in self._temporal_topology:
             self._temporal_topology["EQUAL"] = []
         self._temporal_topology["EQUAL"].append(_map)
-    def get_equivalent(self):
-	"""!Return a list of map objects with equivalent temporal extent as this map
-	   @return A list of map objects or None
+    def get_temporal_equivalent(self):
+        """!Return a list of map objects with equivalent temporal extent as this map
+           @return A list of map objects or None
             return None
         return self._temporal_topology["EQUAL"]
-    def append_overlaps(self, _map):
-	"""!Append a map that this map temporally overlaps
-        if not self._temporal_topology.has_key("OVERLAPS"):
+    def append_temporal_overlaps(self, _map):
+        """!Append a map that this map temporally overlaps
+        if "OVERLAPS" not in self._temporal_topology:
             self._temporal_topology["OVERLAPS"] = []
         self._temporal_topology["OVERLAPS"].append(_map)
-    def get_overlaps(self):
-	"""!Return a list of map objects that this map temporally overlaps
+    def get_temporal_overlaps(self):
+        """!Return a list of map objects that this map temporally overlaps
             return None
         return self._temporal_topology["OVERLAPS"]
-    def append_overlapped(self, _map):
-	"""!Append a map that this map temporally overlapped
-        if not self._temporal_topology.has_key("OVERLAPPED"):
+    def append_temporal_overlapped(self, _map):
+        """!Append a map that this map temporally overlapped
+        if "OVERLAPPED" not in self._temporal_topology:
             self._temporal_topology["OVERLAPPED"] = []
         self._temporal_topology["OVERLAPPED"].append(_map)
-    def get_overlapped(self):
-	"""!Return a list of map objects that this map temporally overlapped
+    def get_temporal_overlapped(self):
+        """!Return a list of map objects that this map temporally overlapped
             return None
         return self._temporal_topology["OVERLAPPED"]
-    def append_follows(self, _map):
-	"""!Append a map that this map temporally follows
-        if not self._temporal_topology.has_key("FOLLOWS"):
+    def append_temporal_follows(self, _map):
+        """!Append a map that this map temporally follows
+        if "FOLLOWS" not in self._temporal_topology:
             self._temporal_topology["FOLLOWS"] = []
         self._temporal_topology["FOLLOWS"].append(_map)
-    def get_follows(self):
-	"""!Return a list of map objects that this map temporally follows
+    def get_temporal_follows(self):
+        """!Return a list of map objects that this map temporally follows
             return None
         return self._temporal_topology["FOLLOWS"]
-    def append_precedes(self, _map):
-	"""!Append a map that this map temporally precedes
-        if not self._temporal_topology.has_key("PRECEDES"):
+    def append_temporal_precedes(self, _map):
+        """!Append a map that this map temporally precedes
+        if "PRECEDES" not in self._temporal_topology:
             self._temporal_topology["PRECEDES"] = []
         self._temporal_topology["PRECEDES"].append(_map)
-    def get_precedes(self):
-	"""!Return a list of map objects that this map temporally precedes
+    def get_temporal_precedes(self):
+        """!Return a list of map objects that this map temporally precedes
             return None
         return self._temporal_topology["PRECEDES"]
-    def append_during(self, _map):
-	"""!Append a map that this map is temporally located during
-	   This includes temporal relationships starts and finishes
-        if not self._temporal_topology.has_key("DURING"):
+    def append_temporal_during(self, _map):
+        """!Append a map that this map is temporally located during
+           This includes temporal relationships starts and finishes
+        if "DURING" not in self._temporal_topology:
             self._temporal_topology["DURING"] = []
         self._temporal_topology["DURING"].append(_map)
-    def get_during(self):
-	"""!Return a list of map objects that this map is temporally located during
-	   This includes temporally relationships starts and finishes
+    def get_temporal_during(self):
+        """!Return a list of map objects that this map is temporally located during
+           This includes temporally relationships starts and finishes
             return None
         return self._temporal_topology["DURING"]
-    def append_contains(self, _map):
-	"""!Append a map that this map temporally contains
-	   This includes temporal relationships started and finished
-        if not self._temporal_topology.has_key("CONTAINS"):
+    def append_temporal_contains(self, _map):
+        """!Append a map that this map temporally contains
+           This includes temporal relationships started and finished
+        if "CONTAINS" not in self._temporal_topology:
             self._temporal_topology["CONTAINS"] = []
         self._temporal_topology["CONTAINS"].append(_map)
-    def get_contains(self):
-	"""!Return a list of map objects that this map temporally contains
+    def get_temporal_contains(self):
+        """!Return a list of map objects that this map temporally contains
             return None
         return self._temporal_topology["CONTAINS"]
-    def _generate_map_list_string(self, map_list, line_wrap = True):
-	count = 0
-	string = ""
-	for _map in map_list:
-	    if line_wrap and count > 0 and count % 3 == 0:
-		string += "\n | ............................ "
-		count = 0
-	    if count == 0:
-		string += _map.get_id()
-	    else:
-		string += ",%s" % _map.get_id()
-	    count += 1
-	return string
+    def _generate_map_list_string(self, map_list, line_wrap=True):
+        count = 0
+        string = ""
+        for _map in map_list:
+            if line_wrap and count > 0 and count % 3 == 0:
+                string += "\n | ............................ "
+                count = 0
+            if count == 0:
+                string += _map.get_id()
+            else:
+                string += ",%s" % _map.get_id()
+            count += 1
+        return string
+    # Set the properties
+    temporal_equivalent = property(fget=get_temporal_equivalent,
+                                       fset=append_temporal_equivalent)
+    temporal_follows = property(fget=get_temporal_follows,
+                                    fset=append_temporal_follows)
+    temporal_precedes = property(fget=get_temporal_precedes,
+                                     fset=append_temporal_precedes)
+    temporal_overlaps = property(fget=get_temporal_overlaps,
+                                     fset=append_temporal_overlaps)
+    temporal_overlapped = property(fget=get_temporal_overlapped,
+                                       fset=append_temporal_overlapped)
+    temporal_during = property(fget=get_temporal_during,
+                                   fset=append_temporal_during)
+    temporal_contains = property(fget=get_temporal_contains,
+                                     fset=append_temporal_contains)
     def print_temporal_topology_info(self):
-        """!Print information about this class in human shell style"""
-        _next = self.next()
-        _prev = self.prev()
-        _equal = self.get_equivalent()
-        _follows = self.get_follows()
-        _precedes = self.get_precedes()
-        _overlaps = self.get_overlaps()
-        _overlapped = self.get_overlapped()
-        _during = self.get_during()
-        _contains = self.get_contains()
+        """!Print information about this class in human readable style"""
+        _next = self.temporal_next()
+        _prev = self.temporal_prev()
+        _equal = self.get_temporal_equivalent()
+        _follows = self.get_temporal_follows()
+        _precedes = self.get_temporal_precedes()
+        _overlaps = self.get_temporal_overlaps()
+        _overlapped = self.get_temporal_overlapped()
+        _during = self.get_temporal_during()
+        _contains = self.get_temporal_contains()
         print " +-------------------- Temporal Topology -------------------------------------+"
         #          0123456789012345678901234567890
         if _next:
-	    print " | Next: ...................... " + str(_next.get_id())
+            print " | Next: ...................... " + str(_next.get_id())
         if _prev:
-	    print " | Previous: .................. " + str(_prev.get_id())
+            print " | Previous: .................. " + str(_prev.get_id())
         if _equal:
-	    print " | Equivalent: ................ " + self._generate_map_list_string(_equal)
+            print " | Equivalent: ................ " + \
         if _follows:
-	    print " | Follows: ................... " + self._generate_map_list_string(_follows)
+            print " | Follows: ................... " + \
         if _precedes:
-	    print " | Precedes: .................. " + self._generate_map_list_string(_precedes)
+            print " | Precedes: .................. " + \
         if _overlaps:
-	    print " | Overlaps: .................. " + self._generate_map_list_string(_overlaps)
+            print " | Overlaps: .................. " + \
         if _overlapped:
-	    print " | Overlapped: ................ " + self._generate_map_list_string(_overlapped)
+            print " | Overlapped: ................ " + \
         if _during:
-	    print " | During: .................... " + self._generate_map_list_string(_during)
+            print " | During: .................... " + \
         if _contains:
-	    print " | Contains: .................. " + self._generate_map_list_string(_contains)
+            print " | Contains: .................. " + \
     def print_temporal_topology_shell_info(self):
-        """!Print information about this class in human readable style"""
+        """!Print information about this class in shell style"""
         if _next:
-	    print "next=" + _next.get_id()
+            print "next=" + _next.get_id()
         if _prev:
-	    print "prev=" + _prev.get_id()
+            print "prev=" + _prev.get_id()
         if _equal:
-	    print "equivalent=" +self._generate_map_list_string(_equal, False)
+            print "equivalent=" + self._generate_map_list_string(_equal, False)
         if _follows:
-	    print "follows=" +self._generate_map_list_string(_follows, False)
+            print "follows=" + self._generate_map_list_string(_follows, False)
         if _precedes:
-	    print "precedes=" +self._generate_map_list_string(_precedes, False)
+            print "precedes=" + self._generate_map_list_string(
+                _precedes, False)
         if _overlaps:
-	    print "overlaps=" +self._generate_map_list_string(_overlaps, False)
+            print "overlaps=" + self._generate_map_list_string(
+                _overlaps, False)
         if _overlapped:
-	    print "overlapped=" +self._generate_map_list_string(_overlapped, False)
+            print "overlapped=" + \
+                self._generate_map_list_string(_overlapped, False)
         if _during:
-	    print "during=" +self._generate_map_list_string(_during, False)
+            print "during=" + self._generate_map_list_string(_during, False)
         if _contains:
-	    print "contains=" +self._generate_map_list_string(_contains, False)
+            print "contains=" + self._generate_map_list_string(
+                _contains, False)
-class abstract_map_dataset(temporal_map_relations):
-    """!This is the base class for all maps (raster, vector, raster3d)
+class abstract_map_dataset(TemporalMapRelations):
+    """!This is the base class for all maps (raster, vector, raster3d)
        providing additional function to set the valid time and the spatial extent.
     def __init__(self):
-	temporal_map_relations.__init__(self)
+        TemporalMapRelations.__init__(self)
     def get_new_stds_instance(self, ident):
-        """!Return a new space time dataset instance in which maps are stored with the type of this class
+        """!Return a new space time dataset instance in which maps
+           are stored with the type of this class
+            "This method must be implemented in the subclasses")
     def get_stds_register(self):
-        """!Return the space time dataset register table name in which stds are listed in which this map is registered"""
+        """!Return the space time dataset register table name in which stds
+           are listed in which this map is registered"""
     def set_stds_register(self, name):
         """!Set the space time dataset register table name.
            This table stores all space time datasets in which this map is registered.
            @param ident: The name of the register table
     def check_resolution_with_current_region(self):
         """!Check if the raster or voxel resolution is finer than the current resolution
            Return "finer" in case the raster/voxel resolution is finer than the current region
@@ -362,104 +396,111 @@
            Vector maps are alwyas finer than the current region
     def has_grass_timestamp(self):
-        """!Check if a grass file bsased time stamp exists for this map.
+        """!Check if a grass file bsased time stamp exists for this map.
     def write_timestamp_to_grass(self):
         """!Write the timestamp of this map into the map metadata in the grass file system based spatial
-           database.
+           database.
     def remove_timestamp_from_grass(self):
         """!Remove the timestamp from the grass file system based spatial database
     def map_exists(self):
         """!Return True in case the map exists in the grass spatial database
            @return True if map exists, False otherwise
     def read_info(self):
-        """!Read the map info from the grass file system based database and store the content
+        """!Read the map info from the grass file system based database and store the content
            into a dictionary
     def load(self):
         """!Load the content of this object from the grass file system based database"""
     def _convert_timestamp(self):
-	"""!Convert the valid time into a grass datetime library compatible timestamp string
-	    This methods works for reltaive and absolute time
-	    @return the grass timestamp string
-	start = ""
+        """!Convert the valid time into a grass datetime library compatible timestamp string
+            This methods works for reltaive and absolute time
+            @return the grass timestamp string
+        start = ""
-	    start_time, end_time, tz = self.get_absolute_time()
-	    start = datetime_to_grass_datetime_string(start_time)
-	    if end_time:
-		end = datetime_to_grass_datetime_string(end_time)
-		start += " / %s"%(end)
-	else:
-	    start_time, end_time, unit = self.get_relative_time()
-	    start = "%i %s"%(int(start_time), unit)
-	    if end_time != None:
-		end = "%i %s"%(int(end_time), unit)
+            start_time, end_time, tz = self.get_absolute_time()
+            start = datetime_to_grass_datetime_string(start_time)
+            if end_time:
+                end = datetime_to_grass_datetime_string(end_time)
+                start += " / %s" % (end)
+        else:
+            start_time, end_time, unit = self.get_relative_time()
+            start = "%i %s" % (int(start_time), unit)
+            if end_time is not None:
+                end = "%i %s" % (int(end_time), unit)
-	return start
+        return start
     def get_map_id(self):
-	"""!Return the map id. The map id is the unique map identifier in grass and must not be equal to the
-	   primary key identifier (id) of the map in the database. Since vector maps may have layer information,
-	   the unique id is a combination of name, layer and mapset.
-	   Use get_map_id() every time your need to access the grass map in the file system but not to identify
-	   map information in the temporal database.
+        """!Return the map id. The map id is the unique map identifier in grass and must not be equal to the
+           primary key identifier (id) of the map in the database. Since vector maps may have layer information,
+           the unique id is a combination of name, layer and mapset.
+           Use get_map_id() every time your need to access the grass map in the file system but not to identify
+           map information in the temporal database.
         return self.base.get_map_id()
     def build_id(self, name, mapset, layer=None):
-	"""!Convenient method to build the unique identifier
-	    Existing layer and mapset definitions in the name string will be reused
+        """!Convenient method to build the unique identifier
+            Existing layer and mapset definitions in the name string will be reused
            @param return the id of the vector map as name(:layer)@mapset while layer is optional
         # Check if the name includes any mapset
-	if name.find("@") >= 0:
-	    name, mapset = name.split("@")
+        if name.find("@") >= 0:
+            name, mapset = name.split("@")
         # Check for layer number in map name
-	if name.find(":") >= 0:
-	    name, layer = name.split(":")
-        if layer:
-	    return "%s:%s@%s"%(name, layer, mapset)
-	else:
-	    return "%s@%s"%(name, mapset)
+        if name.find(":") >= 0:
+            name, layer = name.split(":")
+        if layer:
+            return "%s:%s@%s" % (name, layer, mapset)
+        else:
+            return "%s@%s" % (name, mapset)
     def get_layer(self):
-	"""!Return the layer of the map or None in case no layer is defined"""
-	return self.base.get_layer()
+        """!Return the layer of the map or None in case no layer is defined"""
+        return self.base.get_layer()
         if self.get_type() == "raster":
             #                1         2         3         4         5         6         7
             #      0123456789012345678901234567890123456789012345678901234567890123456789012345678
@@ -476,13 +517,13 @@
             print ""
             print " +-------------------- Vector Dataset ----------------------------------------+"
         print " |        |"
-	self.base.print_info()
-	    self.absolute_time.print_info()
+        self.base.print_info()
+            self.absolute_time.print_info()
-	    self.relative_time.print_info()
-	self.spatial_extent.print_info()
-	self.metadata.print_info()
+            self.relative_time.print_info()
+        self.spatial_extent.print_info()
+        self.metadata.print_info()
         datasets = self.get_registered_datasets()
         count = 0
         string = ""
@@ -498,38 +539,38 @@
                 count += 1
         print " | Registered datasets ........ " + string
         if self.is_temporal_topology_build():
-	    self.print_temporal_topology_info()
+            self.print_temporal_topology_info()
         print " +----------------------------------------------------------------------------+"
-	self.base.print_shell_info()
-	    self.absolute_time.print_shell_info()
+        self.base.print_shell_info()
+            self.absolute_time.print_shell_info()
-	    self.relative_time.print_shell_info()
-	self.spatial_extent.print_shell_info()
-	self.metadata.print_shell_info()
+            self.relative_time.print_shell_info()
+        self.spatial_extent.print_shell_info()
+        self.metadata.print_shell_info()
         count = 0
         string = ""
         if datasets:
-	    for ds in datasets:
-		if count == 0:
-		    string += ds["id"]
-		else:
-		    string += ",%s" % ds["id"]
-		count += 1
-	    print "registered_datasets=" + string
+            for ds in datasets:
+                if count == 0:
+                    string += ds["id"]
+                else:
+                    string += ",%s" % ds["id"]
+                count += 1
+            print "registered_datasets=" + string
-	    self.print_temporal_topology_shell_info()
+            self.print_temporal_topology_shell_info()
-	   This functions assures that the timetsamp is written to the grass file system based database
+           This functions assures that the timetsamp is written to the grass file system based database
@@ -538,72 +579,72 @@
         return abstract_dataset.insert(self, dbif, execute)
         self.write_timestamp_to_grass()
         return abstract_dataset.update(self, dbif, execute)
+           and include None varuables.
         return abstract_dataset.update_all(self, dbif, execute)
     def set_absolute_time(self, start_time, end_time=None, timezone=None):
         """!Set the absolute time interval with start time and end time
            @param start_time: a datetime object specifying the start time of the map
            @param end_time: a datetime object specifying the end time of the map
            @param timezone: Thee timezone of the map
-        if start_time and not isinstance(start_time, datetime) :
-	    if self.get_layer():
-		core.fatal(_("Start time must be of type datetime for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
-	    else:
-		core.fatal(_("Start time must be of type datetime for %s map <%s>") % (self.get_type(), self.get_map_id()))
+        if start_time and not isinstance(start_time, datetime):
+            if self.get_layer():
+                core.fatal(_("Start time must be of type datetime for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
+            else:
+                core.fatal(_("Start time must be of type datetime for %s map <%s>") % (self.get_type(), self.get_map_id()))
-        if end_time and not isinstance(end_time, datetime) :
-		core.fatal(_("End time must be of type datetime for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
-	    else:
-		core.fatal(_("End time must be of type datetime for %s map <%s>") % (self.get_type(), self.get_map_id()))
+        if end_time and not isinstance(end_time, datetime):
+                core.fatal(_("End time must be of type datetime for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
+            else:
+                core.fatal(_("End time must be of type datetime for %s map <%s>") % (self.get_type(), self.get_map_id()))
         if start_time and end_time:
             if start_time > end_time:
-		    core.fatal(_("End time must be greater than start time for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
-		else:
-		    core.fatal(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_map_id()))
+                    core.fatal(_("End time must be greater than start time for %s map <%s> with layer: %s") % (self.get_type(), self.get_map_id(), self.get_layer()))
+                else:
+                    core.fatal(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_map_id()))
             else:
                 # Do not create an interval in case start and end time are equal
                 if start_time == end_time:
                     end_time = None
         self.absolute_time.set_start_time(start_time)
         self.absolute_time.set_end_time(end_time)
         self.absolute_time.set_timezone(timezone)
-    def update_absolute_time(self, start_time, end_time=None, timezone=None, dbif = None):
+    def update_absolute_time(self, start_time, end_time=None, timezone=None, dbif=None):
         """!Update the absolute time
@@ -619,12 +660,12 @@
             dbif.close()
     def set_relative_time(self, start_time, end_time, unit):
-        """!Set the relative time interval
-           @param start_time: A double value
-           @param end_time: A double value
+        """!Set the relative time interval
+           @param start_time: A double value
+           @param end_time: A double value
            @param unit: The unit of the relative time. Supported units: years, months, days, hours, minutes, seconds
            Return True for success and False otherwise
@@ -632,19 +673,18 @@
         if not self.check_relative_time_unit(unit):
-		core.error(_("Unsupported relative time unit type for %s map <%s> with layer %s: %s") % (self.get_type(), self.get_id(), self.get_layer(), unit))
-	    else:
-		core.error(_("Unsupported relative time unit type for %s map <%s>: %s") % (self.get_type(), self.get_id(), unit))
+                core.error(_("Unsupported relative time unit type for %s map <%s> with layer %s: %s") % (self.get_type(), self.get_id(), self.get_layer(), unit))
+            else:
+                core.error(_("Unsupported relative time unit type for %s map <%s>: %s") % (self.get_type(), self.get_id(), unit))
             return False
-        if start_time != None and end_time != None:
+        if start_time is not None and end_time is not None:
             if int(start_time) > int(end_time):
-		    core.error(_("End time must be greater than start time for %s map <%s> with layer %s") % (self.get_type(), self.get_id(), self.get_layer()))
-		else:
-		    core.error(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_id()))
+                    core.error(_("End time must be greater than start time for %s map <%s> with layer %s") % (self.get_type(), self.get_id(), self.get_layer()))
+                else:
+                    core.error(_("End time must be greater than start time for %s map <%s>") % (self.get_type(), self.get_id()))
                 return False
             else:
@@ -652,23 +692,23 @@
                     end_time = None
         self.relative_time.set_unit(unit)
         self.relative_time.set_start_time(int(start_time))
             self.relative_time.set_end_time(int(end_time))
         else:
             self.relative_time.set_end_time(None)
         return True
-    def update_relative_time(self, start_time, end_time, unit, dbif = None):
+    def update_relative_time(self, start_time, end_time, unit, dbif=None):
         """!Update the relative time interval
@@ -692,8 +732,9 @@
            @param top: The top edge
            @param bottom: The bottom edge
-        self.spatial_extent.set_spatial_extent(north, south, east, west, top, bottom)
+        self.spatial_extent.set_spatial_extent(
+            north, south, east, west, top, bottom)
     def check_valid_time(self):
         """!Check for correct valid time"""
@@ -701,29 +742,30 @@
         else:
             start, end, unit = self.get_relative_time()
-        if start != None:
-            if end != None:
+        if start is not None:
+            if end is not None:
                 if start >= end:
-			core.error(_("Map <%s> with layer %s has incorrect time interval, start time is greater than end time") % (self.get_map_id(), self.get_layer()))
-		    else:
-			core.error(_("Map <%s> has incorrect time interval, start time is greater than end time") % (self.get_map_id()))
+                        core.error(_("Map <%s> with layer %s has incorrect time interval, start time is greater than end time") % (self.get_map_id(), self.get_layer()))
+                    else:
+                        core.error(_("Map <%s> has incorrect time interval, start time is greater than end time") % (self.get_map_id()))
                     return False
         else:
-            core.error(_("Map <%s> has incorrect start time") % (self.get_map_id()))
+            core.error(_("Map <%s> has incorrect start time") %
+                       (self.get_map_id()))
             return False
         return True
-    def delete(self, dbif=None, update=True, execute = True):
-	"""!Delete a map entry from database if it exists
+    def delete(self, dbif=None, update=True, execute=True):
+        """!Delete a map entry from database if it exists
             Remove dependent entries:
             * Remove the map entry in each space time dataset in which this map is registered
             * Remove the space time dataset register table
-           @param update: Call for each unregister statement the update from registered maps
+           @param update: Call for each unregister statement the update from registered maps
                           of the space time dataset. This can slow down the un-registration process significantly.
            @param execute: If True the SQL DELETE and DROP table statements will be executed.
@@ -735,18 +777,20 @@
         statement = ""
         if self.is_in_db(dbif):
             # SELECT all needed information from the database
             # First we unregister from all dependent space time datasets
-            statement += self.unregister(dbif=dbif, update=update, execute=False)
+            statement += self.unregister(
+                dbif=dbif, update=update, execute=False)
             # Remove the strds register table
             if self.get_stds_register():
                 statement += "DROP TABLE " + self.get_stds_register() + ";\n"
-            core.verbose(_("Delete %s dataset <%s> from temporal database") % (self.get_type(), self.get_id()))
+            core.verbose(_("Delete %s dataset <%s> from temporal database")
+                         % (self.get_type(), self.get_id()))
             # Delete yourself from the database, trigger functions will take care of dependencies
             statement += self.base.get_delete_statement()
@@ -756,22 +800,22 @@
         # Remove the timestamp from the file system
         self.remove_timestamp_from_grass()
         self.reset(None)
         if connect == True:
             dbif.close()
         if execute:
             return ""
         return statement
     def unregister(self, dbif=None, update=True, execute=True):
-	"""! Remove the map entry in each space time dataset in which this map is registered
+        """! Remove the map entry in each space time dataset in which this map is registered
@@ -779,15 +823,16 @@
            @return The SQL statements if execute == False, else an empty string
-	    core.verbose(_("Unregister %s map <%s> with layer %s from space time datasets") % \
-	                   (self.get_type(), self.get_map_id(), self.get_layer()))
-	else:
-	    core.verbose(_("Unregister %s map <%s> from space time datasets") % (self.get_type(), self.get_map_id()))
+            core.verbose(_("Unregister %s map <%s> with layer %s from space time datasets") %
+                         (self.get_type(), self.get_map_id(), self.get_layer()))
+        else:
+            core.verbose(_("Unregister %s map <%s> from space time datasets")
+                         % (self.get_type(), self.get_map_id()))
         statement = ""
         # Get all datasets in which this map is registered
         rows = self.get_registered_datasets(dbif)
@@ -809,7 +854,7 @@
                     stds.update_from_registered_maps(dbif)
             core.percent(1, 1, 1)
         if execute == True:
@@ -820,7 +865,7 @@
             return ""
         return statement
     def get_registered_datasets(self, dbif=None):
         """!Return all space time dataset ids in which this map is registered as
            dictionary like rows with column "id" or None if this map is not registered in any
@@ -833,7 +878,7 @@
         rows = None
         try:
-            if self.get_stds_register() != None:
+            if self.get_stds_register() is not None:
                 # Select all stds tables in which this map is registered
                 sql = "SELECT id FROM " + self.get_stds_register()
                 dbif.cursor.execute(sql)
@@ -843,6 +888,5 @@
         if connect == True:
             dbif.close()
         return rows
Modified: grass/trunk/lib/python/temporal/abstract_space_time_dataset.py
--- grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/abstract_space_time_dataset.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -47,11 +47,11 @@
            @param ident: The unique identifier of the new object
     def get_map_register(self):
         """!Return the name of the map register table"""
     def set_map_register(self, name):
         """!Set the name of the map register table
@@ -60,7 +60,7 @@
            @param name: The name of the register table
Modified: grass/trunk/lib/python/temporal/base.py
--- grass/trunk/lib/python/temporal/base.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/base.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -11,13 +11,14 @@
 Usage:
- at code
+>>> rbase = tgis.RasterBase(ident="soil at PERMANENT")
+>>> vbase = tgis.VectorBase(ident="soil:1 at PERMANENT")
+>>> r3base = tgis.Raster3DBase(ident="soil at PERMANENT")
+>>> strdsbase = tgis.STRDSBase(ident="soil at PERMANENT")
+>>> stvdsbase = tgis.STVDSBase(ident="soil at PERMANENT")
+>>> str3dsbase = tgis.STR3DSBase(ident="soil at PERMANENT")
-rbase = tgis.raster_base(ident="soil")
- at endcode
@@ -26,168 +27,205 @@
 @author Soeren Gebbert
+from datetime import datetime, date, time, timedelta
 from core import *
-class dict_sql_serializer(object):
+class DictSQLSerializer(object):
     def __init__(self):
         self.D = {}
     def serialize(self, type, table, where=None):
-	"""!Convert the internal dictionary into a string of semicolon separated SQL statements
-	   The keys are the column names and the values are the row entries
+        """!Convert the internal dictionary into a string of semicolon separated SQL statements
+            The keys are the column names and the values are the row entries
+            >>> import grass.temporal as tgis
+            >>> from datetime import datetime, date, time, timedelta
+            >>> t = tgis.DictSQLSerializer()
+            >>> t.D["id"] = "soil at PERMANENT"
+            >>> t.D["name"] = "soil"
+            >>> t.D["mapset"] = "PERMANENT"
+            >>> t.D["creator"] = "soeren"
+            >>> t.D["creation_time"] = datetime(2001,1,1)
+            >>> t.D["modification_time"] = datetime(2001,1,1)
+            >>> t.serialize(type="SELECT", table="raster_base")
+            ('SELECT  name  , creator  , creation_time  , modification_time  , mapset  , id  FROM raster_base ;\\n', ())
+            >>> t.serialize(type="INSERT", table="raster_base")
+            ('INSERT INTO raster_base ( name  ,creator  ,creation_time  ,modification_time  ,mapset  ,id ) VALUES (? ,? ,? ,? ,? ,?) ;\\n', ('soil', 'soeren', datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2001, 1, 1, 0, 0), 'PERMANENT', 'soil at PERMANENT'))
+            >>> t.serialize(type="UPDATE", table="raster_base")
+            ('UPDATE raster_base SET  name = ?  ,creator = ?  ,creation_time = ?  ,modification_time = ?  ,mapset = ?  ,id = ? ;\\n', ('soil', 'soeren', datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2001, 1, 1, 0, 0), 'PERMANENT', 'soil at PERMANENT'))
+            >>> t.serialize(type="UPDATE ALL", table="raster_base")
+            @type must be SELECT. INSERT, UPDATE
+            @table The name of the table to select, insert or update
+            @where The optional where statement
+            @return a tuple containing the SQL string and the arguments
-	   @param type must be SELECT. INSERT, UPDATE
-	   @param table The name of the table to select, insert or update
-	   @param where The optional where statement
-	   @return the sql string
+        sql = ""
+        args = []
-	sql = ""
-	args = []
-	# Create ordered select statement
-	if type == "SELECT":
-	    sql += 'SELECT '
-	    count = 0
+        # Create ordered select statement
+        if type == "SELECT":
+            sql += 'SELECT '
+            count = 0
             for key in self.D.keys():
-		if count == 0:
+                if count == 0:
                     sql += ' %s ' % key
-		else:
+                else:
                     sql += ' , %s ' % key
-		count += 1
+                count += 1
             sql += ' FROM ' + table + ' '
-	    if where:
-	        sql += where
+            if where:
+                sql += where
             sql += ";\n"
-	# Create insert statement
-	if type =="INSERT":
-	    count = 0
-	    sql += 'INSERT INTO ' + table + ' ('
+        # Create insert statement
+        if type == "INSERT":
+            count = 0
+            sql += 'INSERT INTO ' + table + ' ('
-		if count == 0:
+                if count == 0:
                     sql += ' %s ' % key
-		else:
+                else:
                     sql += ' ,%s ' % key
-		count += 1
+                count += 1
-	    count = 0
-	    sql += ') VALUES ('
+            count = 0
+            sql += ') VALUES ('
-		if count == 0:
-		    if dbmi.paramstyle == "qmark":
-			sql += '?'
-		    else:
-			sql += '%s'
-		else:
-			sql += ' ,?'
-		    else:
-			sql += ' ,%s'
-		count += 1
-		args.append(self.D[key])
-	    sql += ') '
+                if count == 0:
+                    if dbmi.paramstyle == "qmark":
+                        sql += '?'
+                    else:
+                        sql += '%s'
+                else:
+                        sql += ' ,?'
+                    else:
+                        sql += ' ,%s'
+                count += 1
+                args.append(self.D[key])
+            sql += ') '
-	    if where:
-	        sql += where
+            if where:
+                sql += where
             sql += ";\n"
-	# Create update statement for existing entries
-	if type =="UPDATE":
-	    count = 0
-	    sql += 'UPDATE ' + table + ' SET '
+        # Create update statement for existing entries
+        if type == "UPDATE":
+            count = 0
+            sql += 'UPDATE ' + table + ' SET '
-		# Update only entries which are not None
-		if self.D[key] != None:
-		    if count == 0:
-			    sql += ' %s = ? ' % key
-			else:
-			    sql += ' %s ' % key
-			    sql += '= %s '
-		    else:
-			    sql += ' ,%s = ? ' % key
-			else:
-			    sql += ' ,%s ' % key
-			    sql += '= %s '
-		    count += 1
-	    if where:
-	        sql += where
+                # Update only entries which are not None
+                if self.D[key] is not None:
+                    if count == 0:
+                            sql += ' %s = ? ' % key
+                        else:
+                            sql += ' %s ' % key
+                            sql += '= %s '
+                    else:
+                            sql += ' ,%s = ? ' % key
+                        else:
+                            sql += ' ,%s ' % key
+                            sql += '= %s '
+                    count += 1
+            if where:
+                sql += where
             sql += ";\n"
-	# Create update statement for all entries
-	if type =="UPDATE ALL":
-	    count = 0
+        # Create update statement for all entries
+        if type == "UPDATE ALL":
+            count = 0
                 if count == 0:
-		    else:
-			sql += '= %s '
+                    else:
+                        sql += '= %s '
                 else:
-		    else:
-			sql += '= %s '
+                    else:
+                        sql += '= %s '
                 count += 1
-	    if where:
-	        sql += where
+            if where:
+                sql += where
             sql += ";\n"
-    	return sql, tuple(args)
+        return sql, tuple(args)
     def deserialize(self, row):
-	"""!Convert the content of the dbmi dictionary like row into the internal dictionary
+        """!Convert the content of the dbmi dictionary like row into the internal dictionary
            @param row: The dictionary like row to store in the internal dict
-	self.D = {}
-	for key in row.keys():
-	    self.D[key] = row[key]
+        self.D = {}
+        for key in row.keys():
+            self.D[key] = row[key]
     def clear(self):
-	"""!Initialize the internal storage"""
-	self.D = {}
+        """!Initialize the internal storage"""
+        self.D = {}
+        """!Print the content of the internal dictionary to stdout
         print self.D
-    def test(self):
-        t = dict_sql_serializer()
-	t.D["id"] = "soil at PERMANENT"
-	t.D["name"] = "soil"
-	t.D["mapset"] = "PERMANENT"
-	t.D["creator"] = "soeren"
-	t.D["creation_time"] = datetime.now()
-	t.D["modification_time"] = datetime.now()
-	t.D["revision"] = 1
-	sql, values = t.serialize(type="SELECT", table="raster_base")
-	print sql, '\n', values
-	sql, values = t.serialize(type="INSERT", table="raster_base")
-	sql, values = t.serialize(type="UPDATE", table="raster_base")
-class sql_database_interface(dict_sql_serializer):
+class SQLDatabaseInterface(DictSQLSerializer):
     """!This class represents the SQL database interface
        Functions to insert, select and update the internal structure of this class
-       in the temporal database are implemented.
+       in the temporal database are implemented.
        This is the base class for raster, raster3d, vector and space time datasets
        data management classes:
        * Identification information (base)
        * Spatial extent
        * Temporal extent
        * Metadata
+       Usage:
+        >>> t = tgis.SQLDatabaseInterface("raster", "soil at PERMANENT")
+        >>> t.get_delete_statement()
+        "DELETE FROM raster WHERE id = 'soil at PERMANENT';\\n"
+        >>> t.get_is_in_db_statement()
+        "SELECT id FROM raster WHERE id = 'soil at PERMANENT';\\n"
+        >>> t.get_select_statement()
+        ("SELECT  creation_time  , mapset  , name  , creator  FROM raster WHERE id = 'soil at PERMANENT';\\n", ())
+        >>> t.get_select_statement_mogrified()
+        "SELECT  creation_time  , mapset  , name  , creator  FROM raster WHERE id = 'soil at PERMANENT';\\n"
+        >>> t.get_insert_statement()
+        ('INSERT INTO raster ( creation_time  ,mapset  ,name  ,creator ) VALUES (? ,? ,? ,?) ;\\n', (datetime.datetime(2001, 1, 1, 0, 0), 'PERMANENT', 'soil', 'soeren'))
+        >>> t.get_insert_statement_mogrified()
+        "INSERT INTO raster ( creation_time  ,mapset  ,name  ,creator ) VALUES ('2001-01-01 00:00:00' ,'PERMANENT' ,'soil' ,'soeren') ;\\n"
+        >>> t.get_update_statement()
+        ("UPDATE raster SET  creation_time = ?  ,mapset = ?  ,name = ?  ,creator = ? WHERE id = 'soil at PERMANENT';\\n", (datetime.datetime(2001, 1, 1, 0, 0), 'PERMANENT', 'soil', 'soeren'))
+        >>> t.get_update_statement_mogrified()
+        "UPDATE raster SET  creation_time = '2001-01-01 00:00:00'  ,mapset = 'PERMANENT'  ,name = 'soil'  ,creator = 'soeren' WHERE id = 'soil at PERMANENT';\\n"
+        >>> t.get_update_all_statement()
+        >>> t.get_update_all_statement_mogrified()
     def __init__(self, table=None, ident=None):
         """!Constructor of this class
@@ -195,9 +233,9 @@
            @param table: The name of the table
            @param ident: The identifier (primary key) of this object in the database table
-        dict_sql_serializer.__init__(self)
+        DictSQLSerializer.__init__(self)
-        self.table = table # Name of the table, set in the subclass
+        self.table = table  # Name of the table, set in the subclass
         self.ident = ident
     def get_table_name(self):
@@ -206,27 +244,27 @@
     def get_delete_statement(self):
         """!Return the delete string"""
-	return "DELETE FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
+        return "DELETE FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
     def delete(self, dbif=None):
         """!Delete the entry of this object from the temporal database
            @param dbif: The database interface to be used, if None a temporary connection will be established
-	sql = self.get_delete_statement()
+        sql = self.get_delete_statement()
         #print sql
-	if dbif:
-	    dbif.cursor.execute(sql)
-	else:
-	    dbif = sql_database_interface_connection()
-	    dbif.connect()
-	    dbif.close()
+        if dbif:
+            dbif.cursor.execute(sql)
+        else:
+            dbif = SQLDatabaseInterfaceConnection()
+            dbif.connect()
+            dbif.close()
     def get_is_in_db_statement(self):
         """Return the selection string"""
-	return "SELECT id FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
+        return "SELECT id FROM " + self.get_table_name() + " WHERE id = \'" + str(self.ident) + "\';\n"
         """!Check if this object is present in the temporal database
@@ -234,48 +272,48 @@
-	sql = self.get_is_in_db_statement()
+        sql = self.get_is_in_db_statement()
         #print sql
-	if dbif:
-	    row = dbif.cursor.fetchone()
-	else:
-	    dbif.connect()
-	    dbif.close()
+        if dbif:
+            row = dbif.cursor.fetchone()
+        else:
+            dbif.connect()
+            dbif.close()
-	# Nothing found
-	if row == None:
-	    return False
+        # Nothing found
+        if row is None:
+            return False
-	return True
+        return True
     def get_select_statement(self):
         """!Return the sql statement and the argument list in database specific style"""
-	return self.serialize("SELECT", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+        return self.serialize("SELECT", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
     def get_select_statement_mogrified(self, dbif=None):
         """!Return the select statement as mogrified string
         if not dbif:
         return dbif.mogrify_sql_statement(self.get_select_statement())
         """!Select the content from the temporal database and store it
            in the internal dictionary structure
-	sql, args = self.get_select_statement()
-	#print sql
-	#print args
+        sql, args = self.get_select_statement()
+        #print sql
+        #print args
         if dbif:
             if len(args) == 0:
@@ -284,38 +322,39 @@
                 dbif.cursor.execute(sql, args)
         else:
-	    dbif.connect()
-	    if len(args) == 0:
-	    else:
-		dbif.cursor.execute(sql, args)
-	    dbif.close()
+            dbif.connect()
+            if len(args) == 0:
+            else:
+                dbif.cursor.execute(sql, args)
+            dbif.close()
-	# Nothing found
-	if row == None:
-	    return False
+        # Nothing found
+        if row is None:
+            return False
-	if len(row) > 0:
-	    self.deserialize(row)
-	else:
-            core.fatal(_("Object <%s> not found in the temporal database") % self.get_id())
+        if len(row) > 0:
+            self.deserialize(row)
+        else:
+            core.fatal(_("Object <%s> not found in the temporal database")
+                       % self.get_id())
-	return True
+        return True
     def get_insert_statement(self):
-	return self.serialize("INSERT", self.get_table_name())
+        return self.serialize("INSERT", self.get_table_name())
     def get_insert_statement_mogrified(self, dbif=None):
         """!Return the insert statement as mogrified string
         if not dbif:
         return dbif.mogrify_sql_statement(self.get_insert_statement())
     def insert(self, dbif=None):
@@ -324,30 +363,30 @@
-	sql, args = self.get_insert_statement()
-	#print sql
-	#print args
+        sql, args = self.get_insert_statement()
+        #print sql
+        #print args
-	if dbif:
-	else:
-	    dbif.connect()
-	    dbif.close()
+        if dbif:
+        else:
+            dbif.connect()
+            dbif.close()
     def get_update_statement(self):
-	return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+        return self.serialize("UPDATE", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
-    def get_update_statement_mogrified(self,dbif=None):
+    def get_update_statement_mogrified(self, dbif=None):
         """!Return the update statement as mogrified string
         if not dbif:
         return dbif.mogrify_sql_statement(self.get_update_statement())
     def update(self, dbif=None):
@@ -358,24 +397,24 @@
-	if self.ident == None:
-	    raise IOError("Missing identifer");
+        if self.ident is None:
+            raise IOError("Missing identifer")
-	sql, args = self.get_update_statement()
-	#print sql
-	#print args
+        sql, args = self.get_update_statement()
+        #print sql
+        #print args
-	if dbif:
-	else:
-	    dbif.connect()
-	    dbif.close()
+        if dbif:
+        else:
+            dbif.connect()
+            dbif.close()
     def get_update_all_statement(self):
-	return self.serialize("UPDATE ALL", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
+        return self.serialize("UPDATE ALL", self.get_table_name(), "WHERE id = \'" + str(self.ident) + "\'")
     def get_update_all_statement_mogrified(self, dbif=None):
         """!Return the update all statement as mogrified string
@@ -383,8 +422,8 @@
         if not dbif:
         return dbif.mogrify_sql_statement(self.get_update_all_statement())
     def update_all(self, dbif=None):
@@ -393,213 +432,278 @@
-	sql, args = self.get_update_all_statement()
-	#print sql
-	#print args
+        sql, args = self.get_update_all_statement()
+        #print sql
+        #print args
-	if dbif:
-	else:
-	    dbif.connect()
-	    dbif.close()
+        if dbif:
+        else:
+            dbif.connect()
+            dbif.close()
-class dataset_base(sql_database_interface):
-    """!This is the base class for all maps and spacetime datasets storing basic identification information"""
-    def __init__(self, table=None, ident=None, name=None, mapset=None, creator=None, ctime=None,\
-		    mtime=None, ttype=None, revision=1):
-	sql_database_interface.__init__(self, table, ident)
+class DatasetBase(SQLDatabaseInterface):
+    """!This is the base class for all maps and spacetime datasets storing
+        basic identification information
+        Usage:
-	self.set_id(ident)
-        if ident != None and name == None and mapset == None:
+        >>> t = tgis.DatasetBase("raster", "soil at PERMANENT", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
+        >>> t.id
+        'soil at PERMANENT'
+        >>> t.name
+        'soil'
+        >>> t.mapset
+        'PERMANENT'
+        >>> t.creator
+        'soeren'
+        >>> t.ctime
+        datetime.datetime(2001, 1, 1, 0, 0)
+        >>> t.ttype
+        'absolute'
+        >>> t.print_info()
+         +-------------------- Basic information -------------------------------------+
+         | Id: ........................ soil at PERMANENT
+         | Name: ...................... soil
+         | Mapset: .................... PERMANENT
+         | Creator: ................... soeren
+         | Creation time: ............. 2001-01-01 00:00:00
+         | Temporal type: ............. absolute
+        >>> t.print_shell_info()
+        id=soil at PERMANENT
+        name=soil
+        mapset=PERMANENT
+        creator=soeren
+        creation_time=2001-01-01 00:00:00
+        temporal_type=absolute
+    def __init__(self, table=None, ident=None, name=None, mapset=None,
+                 creator=None, ctime=None,ttype=None):
+        """!Constructor
+            @param table: The name of the temporal database table that should be used to store the values
+            @param ident: The unique identifier must be a combination of the dataset name,
+                          layer name and the mapset name at mapset or name:1 at mapset
+                          used as as primary key in the temporal database
+            @param name: The name of the map or dataset
+            @param mapset: The name of the mapset
+            @param creator: The name of the creator
+            @param ctime: The creation datetime object
+            @param ttype: The temporal type
+                * "absolute" Identifier for absolute time
+                * "relative" Identifier for relative time
+        SQLDatabaseInterface.__init__(self, table, ident)
+        self.set_id(ident)
+        if ident is not None and name is None and mapset is None:
             if ident.find("@") >= 0:
                 name, mapset = ident.split("@")
                 name, layer = ident.split(":")
-	self.set_name(name)
-	self.set_mapset(mapset)
-	self.set_creator(creator)
-	self.set_ctime(ctime)
-	self.set_ttype(ttype)
-	#self.set_mtime(mtime)
-	#self.set_revision(revision)
+        self.set_name(name)
+        self.set_mapset(mapset)
+        self.set_creator(creator)
+        self.set_ctime(ctime)
+        self.set_ttype(ttype)
+        # Commented out for performance reasons
+        #self.set_mtime(mtime)
+        #self.set_revision(revision)
-	"""!Convenient method to set the unique identifier (primary key)
+        """!Convenient method to set the unique identifier (primary key)
-           @param ident: The unique identifier should be a combination of the dataset name, layer name and the mapset name at mapset
-	self.ident = ident
-	self.D["id"] = ident
-        if ident != None:
+        self.ident = ident
+        self.D["id"] = ident
+        if ident is not None:
+            else:
+                core.fatal(_("Wrong identifier, the mapset is missing"))
-		self.set_layer(layer)
+                self.set_layer(layer)
     def set_name(self, name):
-	"""!Set the name of the dataset
+        """!Set the name of the dataset
            @param name: The name of the dataset
-	self.D["name"] = name
+        self.D["name"] = name
     def set_mapset(self, mapset):
-	"""!Set the mapset of the dataset
+        """!Set the mapset of the dataset
            @param mapsets: The name of the mapset in which this dataset is stored
-	self.D["mapset"] = mapset
+        self.D["mapset"] = mapset
     def set_layer(self, layer):
-	"""!Convenient method to set the layer of the map (part of primary key)
-	   Layer are currently supported for vector maps
+        """!Convenient method to set the layer of the map (part of primary key)
+           Layer are supported for vector maps
            @param layer: The layer of the map
-	self.D["layer"] = layer
+        self.D["layer"] = layer
     def set_creator(self, creator):
-	"""!Set the creator of the dataset
+        """!Set the creator of the dataset
-	self.D["creator"] = creator
+        self.D["creator"] = creator
     def set_ctime(self, ctime=None):
-	"""!Set the creation time of the dataset, if nothing set the current time is used
+        """!Set the creation time of the dataset, if nothing set the current time is used
            @param ctime: The current time of type datetime
-	if ctime == None:
+        if ctime is None:
             self.D["creation_time"] = datetime.now()
-	else:
+        else:
             self.D["creation_time"] = ctime
     def set_ttype(self, ttype):
-	"""!Set the temporal type of the dataset: absolute or relative, if nothing set absolute time will assumed
+        """!Set the temporal type of the dataset: absolute or relative,
+           if nothing set absolute time will assumed
            @param ttype: The temporal type of the dataset "absolute or relative"
-	if ttype == None or (ttype != "absolute" and ttype != "relative"):
-	    self.D["temporal_type"] = "absolute"
+        if ttype is None or (ttype != "absolute" and ttype != "relative"):
+            self.D["temporal_type"] = "absolute"
         else:
-	    self.D["temporal_type"] = ttype
+            self.D["temporal_type"] = ttype
 #    def set_mtime(self, mtime=None):
-#	"""!Set the modification time of the map, if nothing set the current time is used"""
-#	if mtime == None:
+#       """!Set the modification time of the map, if nothing set the current time is used"""
+#       if mtime == None:
 #            self.D["modification_time"] = datetime.now()
-#	else:
+#       else:
 #            self.D["modification_time"] = mtime
 #    def set_revision(self, revision=1):
-#	"""!Set the revision of the map: if nothing set revision 1 will assumed"""
-#	self.D["revision"] = revision
+#       """!Set the revision of the map: if nothing set revision 1 will assumed"""
+#       self.D["revision"] = revision
     def get_id(self):
-	"""!Convenient method to get the unique identifier (primary key)
-	   @return None if not found
-	if self.D.has_key("id"):
-	    return self.D["id"]
+        """!Convenient method to get the unique identifier (primary key)
+           @return None if not found
+        if "id" in self.D:
+            return self.D["id"]
         else:
-	    return None
+            return None
-	"""!Convenient method to get the unique map identifier without layer information
+        """!Convenient method to get the unique map identifier without layer information
            @param return the name of the vector map as name at mapset
-        id = self.get_id()
-        if id.find(":") >= 0:
-	    # Remove the layer identifier from the id
-	    return id.split("@")[0].split(":")[0] + "@" + id.split("@")[1]
-	else:
-	    return id
+        if self.id.find(":") >= 0:
+            # Remove the layer identifier from the id
+            return iself.d.split("@")[0].split(":")[0] + "@" + self.id.split("@")[1]
+        else:
+            return self.id
-	"""!Convenient method to get the layer of the map (part of primary key)
-	if self.D.has_key("layer"):
-	    return self.D["layer"]
+        """!Convenient method to get the layer of the map (part of primary key)
+           Layer are currently supported for vector maps
+        if "layer" in self.D:
+            return self.D["layer"]
         else:
-	    return None
+            return None
     def get_name(self):
-	"""!Get the name of the dataset
-	   @return None if not found"""
-	if self.D.has_key("name"):
-	    return self.D["name"]
+        """!Get the name of the dataset
+           @return None if not found"""
+        if "name" in self.D:
+            return self.D["name"]
         else:
-	    return None
+            return None
     def get_mapset(self):
-	"""!Get the name of mapset of this dataset
-	if self.D.has_key("mapset"):
-	    return self.D["mapset"]
+        """!Get the name of mapset of this dataset
+        if "mapset" in self.D:
+            return self.D["mapset"]
         else:
-	    return None
+            return None
     def get_creator(self):
-	"""!Get the creator of the dataset
-	if self.D.has_key("creator"):
-	    return self.D["creator"]
+        """!Get the creator of the dataset
+        if "creator" in self.D:
+            return self.D["creator"]
         else:
-	    return None
+            return None
     def get_ctime(self):
-	"""!Get the creation time of the dataset, datatype is datetime
-	if self.D.has_key("creation_time"):
-	    return self.D["creation_time"]
+        """!Get the creation time of the dataset, datatype is datetime
+        if "creation_time" in self.D:
+            return self.D["creation_time"]
         else:
-	    return None
+            return None
     def get_ttype(self):
-	"""!Get the temporal type of the map
-	if self.D.has_key("temporal_type"):
-	    return self.D["temporal_type"]
+        """!Get the temporal type of the map
+        if "temporal_type" in self.D:
+            return self.D["temporal_type"]
         else:
-	    return None
+            return None
 #    def get_mtime(self):
-#	"""!Get the modification time of the map, datatype is datetime
-#	   @return None if not found"""
-#	if self.D.has_key("modification_time"):
-#	    return self.D["modification_time"]
+#       """!Get the modification time of the map, datatype is datetime
+#          @return None if not found"""
+#       if self.D.has_key("modification_time"):
+#           return self.D["modification_time"]
 #       else:
-#	    return None
+#           return None
 #    def get_revision(self):
-#	"""!Get the revision of the map
-#	if self.D.has_key("revision"):
-#	    return self.D["revision"]
+#       """!Get the revision of the map
+#       if self.D.has_key("revision"):
+#           return self.D["revision"]
 #       else:
-#	    return None
+#           return None
+    # Properties of this class
+    id = property(fget=get_id, fset=set_id)
+    map_id = property(fget=get_map_id, fset=None)
+    name = property(fget=get_name, fset=set_name)
+    mapset = property(fget=get_mapset, fset=set_mapset)
+    ctime = property(fget=get_ctime, fset=set_ctime)
+    ttype = property(fget=get_ttype, fset=set_ttype)
+    creator = property(fget=get_creator, fset=set_creator)
     def print_info(self):
@@ -608,109 +712,167 @@
         print " | Name: ...................... " + str(self.get_name())
         print " | Mapset: .................... " + str(self.get_mapset())
-	    print " | Layer:...................... " + str(self.get_layer())
+            print " | Layer:...................... " + str(self.get_layer())
         print " | Creator: ................... " + str(self.get_creator())
         print " | Creation time: ............. " + str(self.get_ctime())
+        print " | Temporal type: ............. " + str(self.get_ttype())
 #        print " | Modification time: ......... " + str(self.get_mtime())
-        print " | Temporal type: ............. " + str(self.get_ttype())
 #        print " | Revision in database: ...... " + str(self.get_revision())
     def print_shell_info(self):
         print "id=" + str(self.get_id())
         print "name=" + str(self.get_name())
         print "mapset=" + str(self.get_mapset())
-	    print "layer=" + str(self.get_layer())
+            print "layer=" + str(self.get_layer())
         print "creator=" + str(self.get_creator())
         print "creation_time=" + str(self.get_ctime())
+        print "temporal_type=" + str(self.get_ttype())
 #        print "modification_time=" + str(self.get_mtime())
-        print "temporal_type=" + str(self.get_ttype())
 #        print "revision=" + str(self.get_revision())
-class raster_base(dataset_base):
-    def __init__(self, ident=None, name=None, mapset=None, creator=None, creation_time=None,\
-		    modification_time=None, temporal_type=None, revision=1):
-        dataset_base.__init__(self, "raster_base", ident, name, mapset, creator, creation_time,\
-	            modification_time, temporal_type, revision)
-class raster3d_base(dataset_base):
-        dataset_base.__init__(self, "raster3d_base", ident, name, mapset, creator, creation_time,\
+class RasterBase(DatasetBase):
+    """!Time stamped raster map base information class"""
+    def __init__(self, ident=None, name=None, mapset=None, creator=None,
+                 creation_time=None, temporal_type=None):
+        DatasetBase.__init__(self, "raster_base", ident, name, mapset,
+                              creator, creation_time, temporal_type)
-class vector_base(dataset_base):
-    def __init__(self, ident=None, name=None, mapset=None, layer=None, creator=None, creation_time=None,\
-        dataset_base.__init__(self, "vector_base", ident, name, mapset, creator, creation_time,\
+class Raster3DBase(DatasetBase):
+    """!Time stamped 3D raster map base information class"""
+                 creation_time=None, temporal_type=None,):
+        DatasetBase.__init__(self, "raster3d_base", ident, name,
+                              mapset, creator, creation_time,
+                              temporal_type)
+class VectorBase(DatasetBase):
+    """!Time stamped vector map base information class"""
+    def __init__(self, ident=None, name=None, mapset=None, layer=None,
+                 creator=None, creation_time=None, temporal_type=None):
+        DatasetBase.__init__(self, "vector_base", ident, name, mapset,
-            if layer == None:
-	# Layer currently only in use by vector maps
+            if layer is None:
+        # Layer currently only in use by vector maps
-class stds_base(dataset_base):
-    def __init__(self, table=None, ident=None, name=None, mapset=None, semantic_type=None, creator=None, creation_time=None,\
-        dataset_base.__init__(self, table, ident, name, mapset, creator, creation_time,\
-	self.set_semantic_type(semantic_type)
+class STDSBase(DatasetBase):
+    """!Base class for space time datasets
+       This class adds the semantic type member variable to the dataset
+       base class.
+    Usage:
+    >>> t = tgis.STDSBase("stds", "soil at PERMANENT", semantic_type="average", creator="soeren", ctime=datetime(2001,1,1), ttype="absolute")
+    >>> t.semantic_type
+    'average'
+     | Semantic type:.............. average
+    name=soil
+    mapset=PERMANENT
+    creator=soeren
+    semantic_type=average
+                 semantic_type=None, creator=None, ctime=None,
+                 ttype=None):
+        DatasetBase.__init__(self, table, ident, name, mapset, creator,
+                              ctime, ttype)
+        self.set_semantic_type(semantic_type)
     def set_semantic_type(self, semantic_type):
-	"""!Set the semantic type of the space time dataset"""
-	self.D["semantic_type"] = semantic_type
+        """!Set the semantic type of the space time dataset"""
+        self.D["semantic_type"] = semantic_type
     def get_semantic_type(self):
-	"""!Get the semantic type of the space time dataset
-	if self.D.has_key("semantic_type"):
-	    return self.D["semantic_type"]
+        """!Get the semantic type of the space time dataset
+        if "semantic_type" in self.D:
+            return self.D["semantic_type"]
         else:
-	    return None
+            return None
+    semantic_type = property(fget=get_semantic_type, fset=set_semantic_type)
-        dataset_base.print_info(self)
+        DatasetBase.print_info(self)
-        print " | Semantic type:.............. " + str(self.get_semantic_type())
+        print " | Semantic type:.............. " + str(
+            self.get_semantic_type())
-        dataset_base.print_shell_info(self)
+        DatasetBase.print_shell_info(self)
         print "semantic_type=" + str(self.get_semantic_type())
-class strds_base(stds_base):
-    def __init__(self, ident=None, name=None, mapset=None, semantic_type=None,  creator=None, creation_time=None,\
-        stds_base.__init__(self, "strds_base", ident, name, mapset, semantic_type, creator, creation_time,\
-class str3ds_base(stds_base):
-        stds_base.__init__(self, "str3ds_base", ident, name, mapset, semantic_type, creator, creation_time,\
+class STRDSBase(STDSBase):
+    """!Space time raster dataset base information class"""
+                 ttype=None):
+        STDSBase.__init__(self, "strds_base", ident, name, mapset,
+                           semantic_type, creator, ctime,
+                           ttype)
-class stvds_base(stds_base):
-        stds_base.__init__(self, "stvds_base", ident, name, mapset, semantic_type, creator, creation_time,\
+class STR3DSBase(STDSBase):
+    """!Space time 3D raster dataset base information class"""
+                 ttype=None):
+        STDSBase.__init__(self, "str3ds_base", ident, name, mapset,
+                           ttype)
+class STVDSBase(STDSBase):
+    """!Space time vector dataset base information class"""
+                 ttype=None):
+        STDSBase.__init__(self, "stvds_base", ident, name, mapset,
+                           ttype)
+if __name__ == "__main__":
+    import doctest
+    doctest.testmod()
Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/core.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -2,17 +2,26 @@
 @brief GRASS Python scripting module (temporal GIS functions)
-Temporal GIS core functions to be used in Python scripts.
+Temporal GIS core functions to be used in library modules and scripts.
+This module provides the functionality to create the temporal
+SQL database and to establish a connection to the database.
 Usage:
- at code
-import grass.temporal as tgis
+>>> import grass.temporal as tgis
+>>> # Create the temporal database
+>>> tgis.create_temporal_database()
+>>> # Establish a database connection
+>>> dbif, connected = tgis.init_dbif(None)
+>>> dbif.connect()
+>>> # Execute a SQL statement
+>>> dbif.execute_transaction("SELECT datetime(0, 'unixepoch', 'localtime');")
+>>> # Mogrify an SQL statement
+>>> dbif.mogrify_sql_statement(["SELECT name from raster_base where name = ?", ("precipitation",)])
+"SELECT name from raster_base where name = 'precipitation'"
+>>> dbif.close()
-tgis.create_temporal_database()
- at endcode
 (C) 2008-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
@@ -22,7 +31,6 @@
 import os
 import copy
-from datetime import datetime, date, time, timedelta
 import grass.script.core as core
@@ -31,7 +39,7 @@
 # Check the grass environment before import
 core.run_command("t.connect", flags="c")
 kv = core.parse_command("t.connect", flags="pg")
-if kv.has_key("driver"):
+if "driver" in kv:
     if kv["driver"] == "sqlite":
         import sqlite3 as dbmi
     elif kv["driver"] == "pg":
@@ -47,50 +55,54 @@
 def get_temporal_dbmi_init_string():
     grassenv = core.gisenv()
     if dbmi.__name__ == "sqlite3":
-        if kv.has_key("database"):
-            string =  kv["database"]
+        if "database" in kv:
+            string = kv["database"]
             string = string.replace("$GISDBASE", grassenv["GISDBASE"])
-            string = string.replace("$LOCATION_NAME", grassenv["LOCATION_NAME"])
+            string = string.replace(
+                "$LOCATION_NAME", grassenv["LOCATION_NAME"])
             return string
         else:
             core.fatal(_("Unable to initialize the temporal GIS DBMI interface. Use t.connect to specify the driver and the database string"))
     elif dbmi.__name__ == "psycopg2":
             return string
         else:
-	    return "dbname=grass_test user=soeren password=abcdefgh"
+            return "dbname=grass_test user=soeren password=abcdefgh"
 def get_sql_template_path():
     base = os.getenv("GISBASE")
-    base_etc  = os.path.join(base, "etc")
+    base_etc = os.path.join(base, "etc")
     return os.path.join(base_etc, "sql")
 def create_temporal_database():
     """!This function creates the grass location database structure for raster, vector and raster3d maps
        as well as for the space-time datasets strds, str3ds and stvds
-       This functions must be called before any spatio-temporal processing is started
+       This functions must be called before any spatio-temporal processing can be started
     database = get_temporal_dbmi_init_string()
     db_exists = False
     # Check if the database already exists
-	# Check path of the sqlite database
-	if os.path.exists(database):
-	    db_exists = True
+        # Check path of the sqlite database
+        if os.path.exists(database):
+            db_exists = True
         # Connect to database
         connection = dbmi.connect(database)
@@ -102,25 +114,34 @@
         cursor.close()
     if db_exists == True:
-	return
-    core.message(_("Create temporal database: %s"%(database)))
+        return
+    core.message(_("Create temporal database: %s" % (database)))
     # Read all SQL scripts and templates
-    map_tables_template_sql = open(os.path.join(get_sql_template_path(), "map_tables_template.sql"), 'r').read()
-    raster_metadata_sql = open(os.path.join(get_sql_template_path(), "raster_metadata_table.sql"), 'r').read()
-    raster3d_metadata_sql = open(os.path.join(get_sql_template_path(), "raster3d_metadata_table.sql"), 'r').read()
-    vector_metadata_sql = open(os.path.join(get_sql_template_path(), "vector_metadata_table.sql"), 'r').read()
-    stds_tables_template_sql = open(os.path.join(get_sql_template_path(), "stds_tables_template.sql"), 'r').read()
-    strds_metadata_sql = open(os.path.join(get_sql_template_path(), "strds_metadata_table.sql"), 'r').read()
-    str3ds_metadata_sql = open(os.path.join(get_sql_template_path(), "str3ds_metadata_table.sql"), 'r').read()
-    stvds_metadata_sql = open(os.path.join(get_sql_template_path(), "stvds_metadata_table.sql"), 'r').read()
+    map_tables_template_sql = open(os.path.join(
+        get_sql_template_path(), "map_tables_template.sql"), 'r').read()
+    raster_metadata_sql = open(os.path.join(
+        get_sql_template_path(), "raster_metadata_table.sql"), 'r').read()
+    raster3d_metadata_sql = open(os.path.join(get_sql_template_path(
+        ), "raster3d_metadata_table.sql"), 'r').read()
+    vector_metadata_sql = open(os.path.join(
+        get_sql_template_path(), "vector_metadata_table.sql"), 'r').read()
+    stds_tables_template_sql = open(os.path.join(
+        get_sql_template_path(), "stds_tables_template.sql"), 'r').read()
+    strds_metadata_sql = open(os.path.join(
+        get_sql_template_path(), "strds_metadata_table.sql"), 'r').read()
+    str3ds_metadata_sql = open(os.path.join(
+        get_sql_template_path(), "str3ds_metadata_table.sql"), 'r').read()
+    stvds_metadata_sql = open(os.path.join(
+        get_sql_template_path(), "stvds_metadata_table.sql"), 'r').read()
     # Create the raster, raster3d and vector tables
     raster_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster")
     vector_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "vector")
-    raster3d_tables_sql = map_tables_template_sql.replace("GRASS_MAP", "raster3d")
+    raster3d_tables_sql = map_tables_template_sql.replace(
+        "GRASS_MAP", "raster3d")
     # Create the space-time raster, raster3d and vector dataset tables
     strds_tables_sql = stds_tables_template_sql.replace("STDS", "strds")
     stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
@@ -131,58 +152,60 @@
     cursor = connection.cursor()
-	sqlite3_delete_trigger_sql = open(os.path.join(get_sql_template_path(), "sqlite3_delete_trigger.sql"), 'r').read()
-	# Execute the SQL statements for sqlite
-	# Create the global tables for the native grass datatypes
-	cursor.executescript(raster_tables_sql)
-	cursor.executescript(raster_metadata_sql)
-	cursor.executescript(vector_tables_sql)
-	cursor.executescript(vector_metadata_sql)
-	cursor.executescript(raster3d_tables_sql)
-	cursor.executescript(raster3d_metadata_sql)
-	# Create the tables for the new space-time datatypes
-	cursor.executescript(strds_tables_sql)
-	cursor.executescript(strds_metadata_sql)
-	cursor.executescript(stvds_tables_sql)
-	cursor.executescript(stvds_metadata_sql)
-	cursor.executescript(str3ds_tables_sql)
-	cursor.executescript(str3ds_metadata_sql)
-	cursor.executescript(sqlite3_delete_trigger_sql)
+        sqlite3_delete_trigger_sql = open(os.path.join(get_sql_template_path(
+        ), "sqlite3_delete_trigger.sql"), 'r').read()
+        # Execute the SQL statements for sqlite
+        # Create the global tables for the native grass datatypes
+        cursor.executescript(raster_tables_sql)
+        cursor.executescript(raster_metadata_sql)
+        cursor.executescript(vector_tables_sql)
+        cursor.executescript(vector_metadata_sql)
+        cursor.executescript(raster3d_tables_sql)
+        cursor.executescript(raster3d_metadata_sql)
+        # Create the tables for the new space-time datatypes
+        cursor.executescript(strds_tables_sql)
+        cursor.executescript(strds_metadata_sql)
+        cursor.executescript(stvds_tables_sql)
+        cursor.executescript(stvds_metadata_sql)
+        cursor.executescript(str3ds_tables_sql)
+        cursor.executescript(str3ds_metadata_sql)
+        cursor.executescript(sqlite3_delete_trigger_sql)
-	# Execute the SQL statements for postgresql
-	cursor.execute(raster_tables_sql)
-	cursor.execute(raster_metadata_sql)
-	cursor.execute(vector_tables_sql)
-	cursor.execute(vector_metadata_sql)
-	cursor.execute(raster3d_tables_sql)
-	cursor.execute(raster3d_metadata_sql)
-	cursor.execute(strds_tables_sql)
-	cursor.execute(strds_metadata_sql)
-	cursor.execute(stvds_tables_sql)
-	cursor.execute(stvds_metadata_sql)
-	cursor.execute(str3ds_tables_sql)
-	cursor.execute(str3ds_metadata_sql)
+        # Execute the SQL statements for postgresql
+        cursor.execute(raster_tables_sql)
+        cursor.execute(raster_metadata_sql)
+        cursor.execute(vector_tables_sql)
+        cursor.execute(vector_metadata_sql)
+        cursor.execute(raster3d_tables_sql)
+        cursor.execute(raster3d_metadata_sql)
+        cursor.execute(strds_tables_sql)
+        cursor.execute(strds_metadata_sql)
+        cursor.execute(stvds_tables_sql)
+        cursor.execute(stvds_metadata_sql)
+        cursor.execute(str3ds_tables_sql)
+        cursor.execute(str3ds_metadata_sql)
     connection.commit()
     cursor.close()
-class sql_database_interface_connection():
+class SQLDatabaseInterfaceConnection():
     """!This class represents the database interface connection
        The following DBMS are supported:
        * sqlite via the sqlite3 standard library
        * postgresql via psycopg2
     def __init__(self):
-	self.connected = False
+        self.connected = False
     def connect(self):
         """!Connect to the DBMI to execute SQL statements
@@ -191,24 +214,25 @@
         init = get_temporal_dbmi_init_string()
         #print "Connect to",  self.database
-	    self.connection = dbmi.connect(init, detect_types=dbmi.PARSE_DECLTYPES|dbmi.PARSE_COLNAMES)
-	    self.connection.row_factory = dbmi.Row
+            self.connection = dbmi.connect(init, detect_types=dbmi.PARSE_DECLTYPES | dbmi.PARSE_COLNAMES)
+            self.connection.row_factory = dbmi.Row
             self.connection.isolation_level = None
-	    self.cursor = self.connection.cursor()
+            self.cursor = self.connection.cursor()
             self.cursor.execute("PRAGMA synchronous = OFF")
             self.cursor.execute("PRAGMA journal_mode = MEMORY")
-	    self.connection = dbmi.connect(init)
-	    #self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
-	    self.cursor = self.connection.cursor(cursor_factory=dbmi.extras.DictCursor)
-	self.connected = True
+            self.connection = dbmi.connect(init)
+            #self.connection.set_isolation_level(dbmi.extensions.ISOLATION_LEVEL_AUTOCOMMIT)
+                cursor_factory=dbmi.extras.DictCursor)
+        self.connected = True
     def close(self):
         """!Close the DBMI connection"""
         #print "Close connection to",  self.database
-	self.connection.commit()
+        self.connection.commit()
         self.cursor.close()
     def mogrify_sql_statement(self, content):
         """!Return the SQL statement and arguments as executable SQL string
@@ -231,16 +255,16 @@
                     statement = self.cursor.mogrify(sql, args)
                     self.close()
                     return statement
         elif dbmi.__name__ == "sqlite3":
             if len(args) == 0:
                 return sql
             else:
-                # Unfortunately as sqlite does not support
+                # Unfortunately as sqlite does not support
                 # the transformation of sql strings and qmarked or
                 # named arguments we must make our hands dirty
                 # and do it by ourself. :(
-                # Doors are open for SQL injection because of the
+                # Doors are open for SQL injection because of the
                 # limited python sqlite3 implementation!!!
                 pos = 0
                 count = 0
@@ -251,56 +275,59 @@
                     pos = statement.find("?", pos + 1)
                     if pos == -1:
                         break
-                    if args[count] == None:
-                        statement = "%sNULL%s"%(statement[0:pos], statement[pos+1:])
+                    if args[count] is None:
+                        statement = "%sNULL%s" % (statement[0:
+                                                            pos], statement[pos + 1:])
                     elif isinstance(args[count], (int, long)):
-                        statement = "%s%d%s"%(statement[0:pos], args[count],statement[pos+1:])
+                        statement = "%s%d%s" % (statement[0:pos], args[count],
+                                                statement[pos + 1:])
                     elif isinstance(args[count], float):
-                        statement = "%s%f%s"%(statement[0:pos], args[count],statement[pos+1:])
+                        statement = "%s%f%s" % (statement[0:pos], args[count],
                     else:
                         # Default is a string, this works for datetime objects too
-                        statement = "%s\'%s\'%s"%(statement[0:pos], str(args[count]),statement[pos+1:])
+                        statement = "%s\'%s\'%s" % (statement[0:pos], str(args[count]), statement[pos + 1:])
                     count += 1
                 return statement
     def execute_transaction(self, statement):
-	"""!Execute a transactional SQL statement
+        """!Execute a transactional SQL statement
-	    The BEGIN and END TRANSACTION statements will be added automatically
-	    to the sql statement
+            The BEGIN and END TRANSACTION statements will be added automatically
+            to the sql statement
-	    @param statement The executable SQL statement or SQL script
-	connect = False
-	if self.connected == False:
-	    self.connect()
-	    connect = True
+            @param statement The executable SQL statement or SQL script
+        connect = False
+        if self.connected == False:
+            self.connect()
+            connect = True
-	sql_script = ""
-	sql_script += "BEGIN TRANSACTION;\n"
-	sql_script += statement
-	sql_script += "END TRANSACTION;"
-	try:
-	    if dbmi.__name__ == "sqlite3":
-		self.cursor.executescript(statement)
-	    else:
-		self.cursor.execute(statement)
-	except:
-	    if connect == True:
-		self.close()
-	    core.error(_("Unable to execute transaction:\n %s") % (statement))
-	    raise
+        sql_script = ""
+        sql_script += "BEGIN TRANSACTION;\n"
+        sql_script += statement
+        sql_script += "END TRANSACTION;"
+        try:
+            if dbmi.__name__ == "sqlite3":
+                self.cursor.executescript(statement)
+            else:
+                self.cursor.execute(statement)
+        except:
+            if connect == True:
+                self.close()
+            core.error(_("Unable to execute transaction:\n %s") % (statement))
+            raise
-	if connect:
-	    self.close()
+        if connect:
+            self.close()
 def init_dbif(dbif):
-    """!This method checks if the database interface connection exists, if not a new one
+    """!This method checks if the database interface connection exists, if not a new one
         will be created, connected and True will be returned
         Usage code sample:
@@ -308,9 +335,15 @@
         if connect:
             dbif.close()
-    if dbif == None:
+    if dbif is None:
         dbif.connect()
         return dbif, True
     return dbif, False
+    import doctest
+    doctest.testmod()
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/extract.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -62,7 +62,7 @@
     dummy = sp.get_new_map_instance(None)
+    dbif = ()
     dbif.connect()
     if sp.is_in_db(dbif) == False:
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/mapcalc.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -42,7 +42,7 @@
     # We need a database interface for fast computation
+    dbif = ()
     dbif.connect()
     mapset =  core.gisenv()["MAPSET"]
Modified: grass/trunk/lib/python/temporal/metadata.py
--- grass/trunk/lib/python/temporal/metadata.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/metadata.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -6,13 +6,14 @@
 Usage:
- at code
+>>> meta = tgis.RasterMetadata()
+>>> meta = tgis.Raster3DMetadata()
+>>> meta = tgis.VectorMetadata()
+>>> meta = tgis.STRDSMetadata()
+>>> meta = tgis.STR3DSMetadata()
+>>> meta = tgis.STVDSMetadata()
-meta = tgis.raster_metadata()
- at endcode
@@ -24,139 +25,217 @@
-class raster_metadata_base(sql_database_interface):
-    """!This is the raster metadata base class for raster and raster3d maps"""
-    def __init__(self, table=None, ident=None, datatype=None, cols=None, rows=None, number_of_cells=None, nsres=None, ewres=None, min=None, max=None):
+class RasterMetadataBase(SQLDatabaseInterface):
+    """!This is the metadata base class for time stamped raster and raster3d maps
+        Usage:
+        >>> meta = tgis.RasterMetadataBase(table="metadata", ident="soil at PERMANENT",
+        ... datatype="CELL", cols=100, rows=100, number_of_cells=10000, nsres=0.1,
+        ... ewres=0.1, min=0, max=100)
+        >>> meta.datatype
+        'CELL'
+        >>> meta.cols
+        100
+        >>> meta.rows
+        100
+        >>> meta.number_of_cells
+        10000
+        >>> meta.nsres
+        0.1
+        >>> meta.ewres
+        0.1
+        >>> meta.min
+        0.0
+        >>> meta.max
+        100.0
+        >>> meta.print_info()
+         | Datatype:................... CELL
+         | Number of columns:.......... 100
+         | Number of rows:............. 100
+         | Number of cells:............ 10000
+         | North-South resolution:..... 0.1
+         | East-west resolution:....... 0.1
+         | Minimum value:.............. 0.0
+         | Maximum value:.............. 100.0
+        >>> meta.print_shell_info()
+        datatype=CELL
+        cols=100
+        rows=100
+        number_of_cells=10000
+        nsres=0.1
+        ewres=0.1
+        min=0.0
+        max=100.0
+    def __init__(self, table=None, ident=None, datatype=None, cols=None,
+		rows=None, number_of_cells=None, nsres=None, ewres=None,
+		min=None, max=None):
-	self.set_datatype(datatype)
-	self.set_cols(cols)
-	self.set_rows(rows)
-	self.set_number_of_cells(number_of_cells)
-	self.set_nsres(nsres)
-	self.set_ewres(ewres)
-	self.set_min(min)
-	self.set_max(max)
+        self.set_datatype(datatype)
+        self.set_cols(cols)
+        self.set_rows(rows)
+        self.set_number_of_cells(number_of_cells)
+        self.set_nsres(nsres)
+        self.set_ewres(ewres)
+        self.set_min(min)
+        self.set_max(max)
     def set_id(self, ident):
-	"""!Convenient method to set the unique identifier (primary key)"""
+        """!Convenient method to set the unique identifier (primary key)"""
     def set_datatype(self, datatype):
-	"""!Set the datatype"""
-	self.D["datatype"] = datatype
+        """!Set the datatype"""
+        self.D["datatype"] = datatype
     def set_cols(self, cols):
-	"""!Set the number of cols"""
-	self.D["cols"] = cols
+        """!Set the number of cols"""
+        if cols is not None:
+            self.D["cols"] = int(cols)
+        else:
+            self.D["cols"] = None
     def set_rows(self, rows):
-	"""!Set the number of rows"""
-	self.D["rows"] = rows
+        """!Set the number of rows"""
+        if rows is not None:
+            self.D["rows"] = int(rows)
+        else:
+            self.D["rows"] = None
     def set_number_of_cells(self, number_of_cells):
-	"""!Set the number of cells"""
-	self.D["number_of_cells"] = number_of_cells
+        """!Set the number of cells"""
+        if number_of_cells is not None:
+            self.D["number_of_cells"] = int(number_of_cells)
+        else:
+            self.D["number_of_cells"] = None
     def set_nsres(self, nsres):
-	"""!Set the north-south resolution"""
-	self.D["nsres"] = nsres
+        """!Set the north-south resolution"""
+        if nsres is not None:
+            self.D["nsres"] = float(nsres)
+        else:
+            self.D["nsres"] = None
     def set_ewres(self, ewres):
-	"""!Set the east-west resolution"""
-	self.D["ewres"] = ewres
+        """!Set the east-west resolution"""
+        if ewres is not None:
+            self.D["ewres"] = float(ewres)
+        else:
+            self.D["ewres"] = None
     def set_min(self, min):
-	"""!Set the minimum raster value"""
-	self.D["min"] = min
+        """!Set the minimum raster value"""
+        if min is not None:
+            self.D["min"] = float(min)
+        else:
+            self.D["min"] = None
     def set_max(self, max):
-	"""!Set the maximum raster value"""
-	self.D["max"] = max
+        """!Set the maximum raster value"""
+        if max is not None:
+            self.D["max"] = float(max)
+        else:
+            self.D["max"] = None
     def get_id(self):
         else:
-	    return None
+            return None
     def get_datatype(self):
-	"""!Get the map type
-	if self.D.has_key("datatype"):
-	    return self.D["datatype"]
+        """!Get the map type
+        if "datatype" in self.D:
+            return self.D["datatype"]
         else:
-	    return None
+            return None
     def get_cols(self):
-	"""!Get number of cols
-	if self.D.has_key("cols"):
-	    return self.D["cols"]
+        """!Get number of cols
+        if "cols" in self.D:
+            return self.D["cols"]
         else:
-	    return None
+            return None
     def get_rows(self):
-	"""!Get number of rows
-	if self.D.has_key("rows"):
-	    return self.D["rows"]
+        """!Get number of rows
+        if "rows" in self.D:
+            return self.D["rows"]
         else:
-	    return None
+            return None
     def get_number_of_cells(self):
-	"""!Get number of cells
-	if self.D.has_key("number_of_cells"):
-	    return self.D["number_of_cells"]
+        """!Get number of cells
+        if "number_of_cells" in self.D:
+            return self.D["number_of_cells"]
         else:
-	    return None
+            return None
     def get_nsres(self):
-	"""!Get the north-south resolution
-	if self.D.has_key("nsres"):
-	    return self.D["nsres"]
+        """!Get the north-south resolution
+        if "nsres" in self.D:
+            return self.D["nsres"]
         else:
-	    return None
+            return None
     def get_ewres(self):
-	"""!Get east-west resolution
-	if self.D.has_key("ewres"):
-	    return self.D["ewres"]
+        """!Get east-west resolution
+        if "ewres" in self.D:
+            return self.D["ewres"]
         else:
-	    return None
+            return None
     def get_min(self):
-	"""!Get the minimum cell value
-	if self.D.has_key("min"):
-	    return self.D["min"]
+        """!Get the minimum cell value
+        if "min" in self.D:
+            return self.D["min"]
         else:
-	    return None
+            return None
     def get_max(self):
-	"""!Get the maximum cell value
-	if self.D.has_key("max"):
-	    return self.D["max"]
+        """!Get the maximum cell value
+        if "max" in self.D:
+            return self.D["max"]
         else:
-	    return None
+            return None
+    # Properties
+    datatype = property(fget=get_datatype, fset=set_datatype)
+    cols = property(fget=get_cols, fset=set_cols)
+    rows = property(fget=get_rows, fset=set_rows)
+    number_of_cells = property(fget=get_number_of_cells, fset=set_number_of_cells)
+    nsres = property(fget=get_nsres, fset=set_nsres)
+    ewres = property(fget=get_ewres, fset=set_ewres)
+    min = property(fget=get_min, fset=set_min)
+    max = property(fget=get_max, fset=set_max)
         """!Print information about this class in human readable style"""
         #      0123456789012345678901234567890
         print " | Datatype:................... " + str(self.get_datatype())
         print " | Number of columns:.......... " + str(self.get_cols())
         print " | Number of rows:............. " + str(self.get_rows())
-        print " | Number of cells:............ " + str(self.get_number_of_cells())
+        print " | Number of cells:............ " + str(
+            self.get_number_of_cells())
         print " | North-South resolution:..... " + str(self.get_nsres())
         print " | East-west resolution:....... " + str(self.get_ewres())
         print " | Minimum value:.............. " + str(self.get_min())
@@ -175,413 +254,695 @@
-class raster_metadata(raster_metadata_base):
-    """!This is the raster metadata class"""
-    def __init__(self, ident=None, strds_register=None, datatype=None, cols=None, rows=None, number_of_cells=None, nsres=None, ewres=None, min=None, max=None):
-	raster_metadata_base.__init__(self, "raster_metadata", ident, datatype, cols, rows, number_of_cells, nsres, ewres, min, max)
+class RasterMetadata(RasterMetadataBase):
+    """!This is the raster metadata class
+        This class is the interface to the raster_metadata table in the
+        temporal database that stores the metadata of all registered raster maps.
+        The metadata includes the datatype, number of cols, rows and cells and
+        the north-south and east west resolution of the map. Additionally the
+        minimum and maximum values and the name of the space time raster dataset
+        register table is stored.
+        Usage:
+        >>> meta = tgis.RasterMetadata(ident="soil at PERMANENT",
+        >>> meta.datatype
+        'CELL'
+        >>> meta.cols
+        100
+        >>> meta.rows
+        100
+        10000
+        >>> meta.nsres
+        0.1
+        >>> meta.ewres
+        0.1
+        >>> meta.min
+        0.0
+        >>> meta.max
+        100.0
+        >>> meta.strds_register
+         +-------------------- Metadata information ----------------------------------+
+         | STRDS register table ....... None
+        datatype=CELL
+        cols=100
+        rows=100
+        nsres=0.1
+        ewres=0.1
+        min=0.0
+        max=100.0
+        strds_register=None
+    def __init__(self, ident=None, strds_register=None, datatype=None,
+		 cols=None, rows=None, number_of_cells=None, nsres=None,
+		 ewres=None, min=None, max=None):
-	self.set_strds_register(strds_register)
+        RasterMetadataBase.__init__(self, "raster_metadata", ident, datatype,
+                                      cols, rows, number_of_cells, nsres,
+                                      ewres, min, max)
+        self.set_strds_register(strds_register)
     def set_strds_register(self, strds_register):
-	"""!Set the space time raster dataset register table name"""
-	self.D["strds_register"] = strds_register
+        """!Set the space time raster dataset register table name"""
+        self.D["strds_register"] = strds_register
     def get_strds_register(self):
-	"""!Get the space time raster dataset register table name
-	if self.D.has_key("strds_register"):
-	    return self.D["strds_register"]
+        """!Get the space time raster dataset register table name
+        if "strds_register" in self.D:
+            return self.D["strds_register"]
         else:
-	    return None
+            return None
+    strds_register = property(fget=get_strds_register, fset=set_strds_register)
         print " +-------------------- Metadata information ----------------------------------+"
-        raster_metadata_base.print_info(self)
-        print " | STRDS register table ....... " + str(self.get_strds_register())
+        RasterMetadataBase.print_info(self)
+        print " | STRDS register table ....... " + str(
+            self.get_strds_register())
         """!Print information about this class in shell style"""
-        raster_metadata_base.print_shell_info(self)
+        RasterMetadataBase.print_shell_info(self)
         print "strds_register=" + str(self.get_strds_register())
-class raster3d_metadata(raster_metadata_base):
-    """!This is the raster3d metadata class"""
-    def __init__(self, ident=None, str3ds_register=None, datatype=None, cols=None, rows=None, depths=None, number_of_cells=None, nsres=None, ewres=None, tbres=None, min=None, max=None):
-	raster_metadata_base.__init__(self, "raster3d_metadata", ident, datatype, cols, rows, number_of_cells, nsres, ewres, min, max)
+class Raster3DMetadata(RasterMetadataBase):
+    """!This is the raster3d metadata class
+        This class is the interface to the raster3d_metadata table in the
+        3D raster maps.
+        The metadata includes all raster metadata variables and additional
+        the number of depths, the top-bottom resolution and the space time 3D
+        raster dataset register table is stored.
+        Usage:
+        >>> meta = tgis.Raster3DMetadata(ident="soil at PERMANENT",
+        ... datatype="FCELL", cols=100, rows=100, depths=100,
+        ... number_of_cells=1000000, nsres=0.1, ewres=0.1, tbres=0.1,
+        ... min=0, max=100)
+        >>> meta.datatype
+        'FCELL'
+        >>> meta.cols
+        100
+        >>> meta.rows
+        100
+        >>> meta.depths
+        100
+        1000000
+        >>> meta.nsres
+        0.1
+        >>> meta.ewres
+        0.1
+        >>> meta.tbres
+        0.1
+        >>> meta.min
+        0.0
+        >>> meta.max
+        100.0
+        >>> meta.str3ds_register
+         | Datatype:................... FCELL
+         | Number of cells:............ 1000000
+         | Number of depths:........... 100
+         | Top-Bottom resolution:...... 0.1
+         | STR3DS register table ...... None
+        datatype=FCELL
+        cols=100
+        rows=100
+        number_of_cells=1000000
+        nsres=0.1
+        ewres=0.1
+        min=0.0
+        max=100.0
+        str3ds_register=None
+        depths=100
+        tbres=0.1
+    def __init__(self, ident=None, str3ds_register=None, datatype=None,
+		 cols=None, rows=None, depths=None, number_of_cells=None,
+		 nsres=None, ewres=None, tbres=None, min=None, max=None):
-	self.set_str3ds_register(str3ds_register)
-	self.set_tbres(tbres)
-	self.set_depths(depths)
+        RasterMetadataBase.__init__(self, "raster3d_metadata", ident,
+				datatype, cols, rows, number_of_cells, nsres,
+				ewres, min, max)
+        self.set_str3ds_register(str3ds_register)
+        self.set_tbres(tbres)
+        self.set_depths(depths)
     def set_str3ds_register(self, str3ds_register):
-	"""!Set the space time raster3d dataset register table name"""
-	self.D["str3ds_register"] = str3ds_register
+        """!Set the space time raster3d dataset register table name"""
+        self.D["str3ds_register"] = str3ds_register
     def set_depths(self, depths):
-	"""!Set the number of depths"""
-	self.D["depths"] = depths
+        """!Set the number of depths"""
+        if depths is not None:
+            self.D["depths"] = int(depths)
+        else:
+            self.D["depths"] = None
     def set_tbres(self, tbres):
-	"""!Set the top-bottom resolution"""
-	self.D["tbres"] = tbres
+        """!Set the top-bottom resolution"""
+        if tbres is not None:
+            self.D["tbres"] = float(tbres)
+        else:
+            self.D["tbres"] = None
     def get_str3ds_register(self):
-	"""!Get the space time raster3d dataset register table name
-	if self.D.has_key("str3ds_register"):
-	    return self.D["str3ds_register"]
+        """!Get the space time raster3d dataset register table name
+        if "str3ds_register" in self.D:
+            return self.D["str3ds_register"]
         else:
-	    return None
+            return None
     def get_depths(self):
-	"""!Get number of depths
-	if self.D.has_key("depths"):
-	    return self.D["depths"]
+        """!Get number of depths
+        if "depths" in self.D:
+            return self.D["depths"]
         else:
-	    return None
+            return None
     def get_tbres(self):
-	"""!Get top-bottom resolution
-	if self.D.has_key("tbres"):
-	    return self.D["tbres"]
+        """!Get top-bottom resolution
+        if "tbres" in self.D:
+            return self.D["tbres"]
         else:
-	    return None
+            return None
+    depths = property(fget=get_depths, fset=set_depths)
+    tbres = property(fget=get_tbres, fset=set_tbres)
+    str3ds_register = property(fget=get_str3ds_register, fset=set_str3ds_register)
         print " | Number of depths:........... " + str(self.get_depths())
         print " | Top-Bottom resolution:...... " + str(self.get_tbres())
-        print " | STR3DS register table ...... " + str(self.get_str3ds_register())
+        print " | STR3DS register table ...... " + str(
+                                                self.get_str3ds_register())
         print "str3ds_register=" + str(self.get_str3ds_register())
         print "depths=" + str(self.get_depths())
         print "tbres=" + str(self.get_tbres())
-class vector_metadata(sql_database_interface):
-    """!This is the vector metadata class"""
-    def __init__(self, ident=None, stvds_register=None, is_3d=False, points=None, lines=None, boundaries=None,\
-                 centroids=None, faces=None, kernels=None, primitives=None, nodes=None, areas=None, \
-                 islands=None, holes=None, volumes=None):
-	sql_database_interface.__init__(self, "vector_metadata", ident)
+class VectorMetadata(SQLDatabaseInterface):
+    """!This is the vector metadata class
+        This class is the interface to the vector_metadata table in the
+        3D raster maps.
+        Usage:
+        >>> meta = VectorMetadata(ident="lidar at PERMANENT", is_3d=True,
+        ... number_of_points=1, number_of_lines=2, number_of_boundaries=3,
+        ... number_of_centroids=4, number_of_faces=5, number_of_kernels=6,
+        ... number_of_primitives=7, number_of_nodes=8, number_of_areas=9,
+        ... number_of_islands=10, number_of_holes=11, number_of_volumes=12)
+        >>> meta.id
+        'lidar at PERMANENT'
+        >>> meta.is_3d
+        True
+        >>> meta.number_of_points
+        1
+        >>> meta.number_of_lines
+        2
+        >>> meta.number_of_boundaries
+        3
+        >>> meta.number_of_centroids
+        4
+        >>> meta.number_of_faces
+        5
+        >>> meta.number_of_kernels
+        6
+        >>> meta.number_of_primitives
+        7
+        >>> meta.number_of_nodes
+        8
+        >>> meta.number_of_areas
+        9
+        >>> meta.number_of_islands
+        10
+        >>> meta.number_of_holes
+        11
+        >>> meta.number_of_volumes
+        12
+         | STVDS register table ....... None
+         | Is map 3d .................. True
+         | Number of points ........... 1
+         | Number of lines ............ 2
+         | Number of boundaries ....... 3
+         | Number of centroids ........ 4
+         | Number of faces ............ 5
+         | Number of kernels .......... 6
+         | Number of primitives ....... 7
+         | Number of nodes ............ 8
+         | Number of areas ............ 9
+         | Number of islands .......... 10
+         | Number of holes ............ 11
+         | Number of volumes .......... 12
+        stvds_register=None
+        is_3d=True
+        points=1
+        lines=2
+        boundaries=3
+        centroids=4
+        faces=5
+        kernels=6
+        primitives=7
+        nodes=8
+        areas=9
+        islands=10
+        holes=11
+        volumes=12
+    def __init__(
+        self, ident=None, stvds_register=None, is_3d=False,
+        number_of_points=None, number_of_lines=None, number_of_boundaries=None,
+        number_of_centroids=None, number_of_faces=None, number_of_kernels=None,
+        number_of_primitives=None, number_of_nodes=None, number_of_areas=None,
+        number_of_islands=None, number_of_holes=None, number_of_volumes=None):
-	self.set_stvds_register(stvds_register)
-	self.set_3d_info(is_3d)
-	self.set_points(points)
-	self.set_lines(lines)
-	self.set_boundaries(boundaries)
-	self.set_centroids(centroids)
-	self.set_faces(faces)
-	self.set_kernels(kernels)
-	self.set_primitives(primitives)
-	self.set_nodes(nodes)
-	self.set_areas(areas)
-	self.set_islands(islands)
-	self.set_holes(holes)
-	self.set_volumes(volumes)
+        SQLDatabaseInterface.__init__(self, "vector_metadata", ident)
+        self.set_stvds_register(stvds_register)
+        self.set_3d_info(is_3d)
+        self.set_number_of_points(number_of_points)
+        self.set_number_of_lines(number_of_lines)
+        self.set_number_of_boundaries(number_of_boundaries)
+        self.set_number_of_centroids(number_of_centroids)
+        self.set_number_of_faces(number_of_faces)
+        self.set_number_of_kernels(number_of_kernels)
+        self.set_number_of_primitives(number_of_primitives)
+        self.set_number_of_nodes(number_of_nodes)
+        self.set_number_of_areas(number_of_areas)
+        self.set_number_of_islands(number_of_islands)
+        self.set_number_of_holes(number_of_holes)
+        self.set_number_of_volumes(number_of_volumes)
     def set_stvds_register(self, stvds_register):
-	"""!Set the space time vector dataset register table name"""
-	self.D["stvds_register"] = stvds_register
+        """!Set the space time vector dataset register table name"""
+        self.D["stvds_register"] = stvds_register
     def set_3d_info(self, is_3d):
-	"""!Set True if the vector map is three dimensional"""
-	self.D["is_3d"] = is_3d
+        """!Set True if the vector map is three dimensional"""
+        self.D["is_3d"] = is_3d
-    def set_points(self, points):
-	"""!Set the number of points of the vector map"""
-	self.D["points"] = points
+    def set_number_of_points(self, number_of_points):
+        """!Set the number of points of the vector map"""
+        self.D["points"] = number_of_points
-    def set_lines(self, lines):
-	"""!Set the number of lines of the vector map"""
-	self.D["lines"] = lines
+    def set_number_of_lines(self, number_of_lines):
+        """!Set the number of lines of the vector map"""
+        self.D["lines"] = number_of_lines
-    def set_boundaries(self, boundaries):
-	"""!Set the number of boundaries of the vector map"""
-	self.D["boundaries"] = boundaries
+    def set_number_of_boundaries(self, number_of_boundaries):
+        """!Set the number of boundaries of the vector map"""
+        self.D["boundaries"] = number_of_boundaries
-    def set_centroids(self, centroids):
-	"""!Set the number of centroids of the vector map"""
-	self.D["centroids"] = centroids
+    def set_number_of_centroids(self, number_of_centroids):
+        """!Set the number of centroids of the vector map"""
+        self.D["centroids"] = number_of_centroids
-    def set_faces(self, faces):
-	"""!Set the number of faces of the vector map"""
-	self.D["faces"] = faces
+    def set_number_of_faces(self, number_of_faces):
+        """!Set the number of faces of the vector map"""
+        self.D["faces"] = number_of_faces
-    def set_kernels(self, kernels):
-	"""!Set the number of kernels of the vector map"""
-	self.D["kernels"] = kernels
+    def set_number_of_kernels(self, number_of_kernels):
+        """!Set the number of kernels of the vector map"""
+        self.D["kernels"] = number_of_kernels
-    def set_primitives(self, primitives):
-	"""!Set the number of primitives of the vector map"""
-	self.D["primitives"] = primitives
+    def set_number_of_primitives(self, number_of_primitives):
+        """!Set the number of primitives of the vector map"""
+        self.D["primitives"] = number_of_primitives
-    def set_nodes(self, nodes):
-	"""!Set the number of nodes of the vector map"""
-	self.D["nodes"] = nodes
+    def set_number_of_nodes(self, number_of_nodes):
+        """!Set the number of nodes of the vector map"""
+        self.D["nodes"] = number_of_nodes
-    def set_areas(self, areas):
-	"""!Set the number of areas of the vector map"""
-	self.D["areas"] = areas
-    def set_islands(self, islands):
-	"""!Set the number of islands of the vector map"""
-	self.D["islands"] = islands
-    def set_holes(self, holes):
-	"""!Set the number of holes of the vector map"""
-	self.D["holes"] = holes
-    def set_volumes(self, volumes):
-	"""!Set the number of volumes of the vector map"""
-	self.D["volumes"] = volumes
+    def set_number_of_areas(self, number_of_areas):
+        """!Set the number of areas of the vector map"""
+        self.D["areas"] = number_of_areas
+    def set_number_of_islands(self, number_of_islands):
+        """!Set the number of islands of the vector map"""
+        self.D["islands"] = number_of_islands
+    def set_number_of_holes(self, number_of_holes):
+        """!Set the number of holes of the vector map"""
+        self.D["holes"] = number_of_holes
+    def set_number_of_volumes(self, number_of_volumes):
+        """!Set the number of volumes of the vector map"""
+        self.D["volumes"] = number_of_volumes
     def get_id(self):
         else:
-	    return None
+            return None
     def get_stvds_register(self):
-	"""!Get the space time vector dataset register table name
-	if self.D.has_key("stvds_register"):
-	    return self.D["stvds_register"]
+        """!Get the space time vector dataset register table name
+        if "stvds_register" in self.D:
+            return self.D["stvds_register"]
         else:
-	    return None
+            return None
     def get_3d_info(self):
-	"""!Return True if the map is three dimensional, False if not and None if not info was found"""
-	if self.D.has_key("is_3d"):
-	    return self.D["is_3d"]
+        """!Return True if the map is three dimensional, False if not and None if not info was found"""
+        if "is_3d" in self.D:
+            return self.D["is_3d"]
         else:
-	    return None
+            return None
-    def get_points(self):
-	"""!Get the number of points of the vector map
-	if self.D.has_key("points"):
-	    return self.D["points"]
+    def get_number_of_points(self):
+        """!Get the number of points of the vector map
+        if "points" in self.D:
+            return self.D["points"]
         else:
-	    return None
-    def get_lines(self):
-	"""!Get the number of lines of the vector map
-	if self.D.has_key("lines"):
-	    return self.D["lines"]
+            return None
+    def get_number_of_lines(self):
+        """!Get the number of lines of the vector map
+        if "lines" in self.D:
+            return self.D["lines"]
         else:
-	    return None
-    def get_boundaries(self):
-	"""!Get the number of boundaries of the vector map
-	if self.D.has_key("boundaries"):
-	    return self.D["boundaries"]
+            return None
+    def get_number_of_boundaries(self):
+        """!Get the number of boundaries of the vector map
+        if "boundaries" in self.D:
+            return self.D["boundaries"]
         else:
-	    return None
-    def get_centroids(self):
-	"""!Get the number of centroids of the vector map
-	if self.D.has_key("centroids"):
-	    return self.D["centroids"]
+            return None
+    def get_number_of_centroids(self):
+        """!Get the number of centroids of the vector map
+        if "centroids" in self.D:
+            return self.D["centroids"]
         else:
-	    return None
-    def get_faces(self):
-	"""!Get the number of faces of the vector map
-	if self.D.has_key("faces"):
-	    return self.D["faces"]
+            return None
+    def get_number_of_faces(self):
+        """!Get the number of faces of the vector map
+        if "faces" in self.D:
+            return self.D["faces"]
         else:
-	    return None
-    def get_kernels(self):
-	"""!Get the number of kernels of the vector map
-	if self.D.has_key("kernels"):
-	    return self.D["kernels"]
+            return None
+    def get_number_of_kernels(self):
+        """!Get the number of kernels of the vector map
+        if "kernels" in self.D:
+            return self.D["kernels"]
         else:
-	    return None
-    def get_primitives(self):
-	"""!Get the number of primitives of the vector map
-	if self.D.has_key("primitives"):
-	    return self.D["primitives"]
+            return None
+    def get_number_of_primitives(self):
+        """!Get the number of primitives of the vector map
+        if "primitives" in self.D:
+            return self.D["primitives"]
         else:
-	    return None
-    def get_nodes(self):
-	"""!Get the number of nodes of the vector map
-	if self.D.has_key("nodes"):
-	    return self.D["nodes"]
+            return None
+    def get_number_of_nodes(self):
+        """!Get the number of nodes of the vector map
+        if "nodes" in self.D:
+            return self.D["nodes"]
         else:
-	    return None
-    def get_areas(self):
-	"""!Get the number of areas of the vector map
-	if self.D.has_key("areas"):
-	    return self.D["areas"]
+            return None
+    def get_number_of_areas(self):
+        """!Get the number of areas of the vector map
+        if "areas" in self.D:
+            return self.D["areas"]
         else:
-	    return None
-    def get_islands(self):
-	"""!Get the number of islands of the vector map
-	if self.D.has_key("islands"):
-	    return self.D["islands"]
+            return None
+    def get_number_of_islands(self):
+        """!Get the number of islands of the vector map
+        if "islands" in self.D:
+            return self.D["islands"]
         else:
-	    return None
-    def get_holes(self):
-	"""!Get the number of holes of the vector map
-	if self.D.has_key("holes"):
-	    return self.D["holes"]
+            return None
+    def get_number_of_holes(self):
+        """!Get the number of holes of the vector map
+        if "holes" in self.D:
+            return self.D["holes"]
         else:
-	    return None
-    def get_volumes(self):
-	"""!Get the number of volumes of the vector map
-	if self.D.has_key("volumes"):
-	    return self.D["volumes"]
+            return None
+    def get_number_of_volumes(self):
+        """!Get the number of volumes of the vector map
+        if "volumes" in self.D:
+            return self.D["volumes"]
         else:
-	    return None
+            return None
+    # Set the properties
+    stvds_register  = property(fget=get_stvds_register,
+                               fset=set_stvds_register)
+    is_3d  = property(fget=get_3d_info, fset=set_3d_info)
+    number_of_points = property(fget=get_number_of_points,
+                                fset=set_number_of_points)
+    number_of_lines = property(fget=get_number_of_lines,
+                               fset=set_number_of_lines)
+    number_of_boundaries = property(fget=get_number_of_boundaries,
+                                    fset=set_number_of_boundaries)
+    number_of_centroids = property(fget=get_number_of_centroids,
+                                   fset=set_number_of_centroids)
+    number_of_faces = property(fget=get_number_of_faces,
+                               fset=set_number_of_faces)
+    number_of_kernels = property(fget=get_number_of_kernels,
+                                 fset=set_number_of_kernels)
+    number_of_primitives = property(fget=get_number_of_primitives,
+                                    fset=set_number_of_primitives)
+    number_of_nodes = property(fget=get_number_of_nodes,
+                               fset=set_number_of_nodes)
+    number_of_areas = property(fget=get_number_of_areas,
+                               fset=set_number_of_areas)
+    number_of_islands = property(fget=get_number_of_islands,
+                                 fset=set_number_of_islands)
+    number_of_holes = property(fget=get_number_of_holes,
+                               fset=set_number_of_holes)
+    number_of_volumes = property(fget=get_number_of_volumes,
+                                 fset=set_number_of_volumes)
-        print " | STVDS register table ....... " + str(self.get_stvds_register())
+        print " | STVDS register table ....... " + str(
+            self.get_stvds_register())
         print " | Is map 3d .................. " + str(self.get_3d_info())
-        print " | Number of points ........... " + str(self.get_points())
-        print " | Number of lines ............ " + str(self.get_lines())
-        print " | Number of boundaries ....... " + str(self.get_boundaries())
-        print " | Number of centroids ........ " + str(self.get_centroids())
-        print " | Number of faces ............ " + str(self.get_faces())
-        print " | Number of kernels .......... " + str(self.get_kernels())
-        print " | Number of primitives ....... " + str(self.get_primitives())
-        print " | Number of nodes ............ " + str(self.get_nodes())
-        print " | Number of areas ............ " + str(self.get_areas())
-        print " | Number of islands .......... " + str(self.get_islands())
-        print " | Number of holes ............ " + str(self.get_holes())
-        print " | Number of volumes .......... " + str(self.get_volumes())
+        print " | Number of points ........... " + str(self.get_number_of_points())
+        print " | Number of lines ............ " + str(self.get_number_of_lines())
+        print " | Number of boundaries ....... " + str(self.get_number_of_boundaries())
+        print " | Number of centroids ........ " + str(self.get_number_of_centroids())
+        print " | Number of faces ............ " + str(self.get_number_of_faces())
+        print " | Number of kernels .......... " + str(self.get_number_of_kernels())
+        print " | Number of primitives ....... " + str(self.get_number_of_primitives())
+        print " | Number of nodes ............ " + str(self.get_number_of_nodes())
+        print " | Number of areas ............ " + str(self.get_number_of_areas())
+        print " | Number of islands .......... " + str(self.get_number_of_islands())
+        print " | Number of holes ............ " + str(self.get_number_of_holes())
+        print " | Number of volumes .......... " + str(self.get_number_of_volumes())
         print "stvds_register=" + str(self.get_stvds_register())
         print "is_3d=" + str(self.get_3d_info())
-        print "points=" + str(self.get_points())
-        print "lines=" + str(self.get_lines())
-        print "boundaries=" + str(self.get_boundaries())
-        print "centroids=" + str(self.get_centroids())
-        print "faces=" + str(self.get_faces())
-        print "kernels=" + str(self.get_kernels())
-        print "primitives=" + str(self.get_primitives())
-        print "nodes=" + str(self.get_nodes())
-        print "areas=" + str(self.get_areas())
-        print "islands=" + str(self.get_islands())
-        print "holes=" + str(self.get_holes())
-        print "volumes=" + str(self.get_volumes())
+        print "points=" + str(self.get_number_of_points())
+        print "lines=" + str(self.get_number_of_lines())
+        print "boundaries=" + str(self.get_number_of_boundaries())
+        print "centroids=" + str(self.get_number_of_centroids())
+        print "faces=" + str(self.get_number_of_faces())
+        print "kernels=" + str(self.get_number_of_kernels())
+        print "primitives=" + str(self.get_number_of_primitives())
+        print "nodes=" + str(self.get_number_of_nodes())
+        print "areas=" + str(self.get_number_of_areas())
+        print "islands=" + str(self.get_number_of_islands())
+        print "holes=" + str(self.get_number_of_holes())
+        print "volumes=" + str(self.get_number_of_volumes())
-class stds_metadata_base(sql_database_interface):
+class STDSMetadataBase(SQLDatabaseInterface):
     """!This is the space time dataset metadata base class for strds, stvds and str3ds datasets
        setting/getting the id, the title and the description
+        Usage:
+        >>> import grass.temporal as tgis
+        >>> meta = tgis.STDSMetadataBase(ident="soils at PERMANENT",
+        ... title="Soils", description="Soils 1950 - 2010")
+        >>> meta.id
+        'soils at PERMANENT'
+        >>> meta.title
+        'Soils'
+        >>> meta.description
+        'Soils 1950 - 2010'
+        >>> meta.number_of_maps
+         | Number of registered maps:.. None
+         | Title:
+         | Soils
+         | Description:
+         | Soils 1950 - 2010
+        number_of_maps=None
     def __init__(self, table=None, ident=None, title=None, description=None):
-	sql_database_interface.__init__(self, table, ident)
-	self.set_id(ident)
-	self.set_title(title)
-	self.set_description(description)
+        self.set_title(title)
+        self.set_description(description)
         # No setter for this
         self.D["number_of_maps"] = None
     def set_title(self, title):
-	"""!Set the title"""
-	self.D["title"] = title
+        """!Set the title"""
+        self.D["title"] = title
     def set_description(self, description):
-	self.D["description"] = description
+        self.D["description"] = description
     def get_id(self):
         else:
-	    return None
+            return None
     def get_title(self):
-	"""!Get the title
-	if self.D.has_key("title"):
-	    return self.D["title"]
+        """!Get the title
+        if "title" in self.D:
+            return self.D["title"]
         else:
-	    return None
+            return None
     def get_description(self):
-	"""!Get description
-	if self.D.has_key("description"):
-	    return self.D["description"]
+        """!Get description
+        if "description" in self.D:
+            return self.D["description"]
         else:
-	    return None
+            return None
     def get_number_of_maps(self):
-	"""!Get the number of registered maps, this value is set in the database
-           automatically via SQL trigger, so no setter exists
-	if self.D.has_key("number_of_maps"):
-	    return self.D["number_of_maps"]
+        """!Get the number of registered maps,
+           this value is set in the database
+           automatically via SQL, so no setter exists
+        if "number_of_maps" in self.D:
+            return self.D["number_of_maps"]
         else:
-	    return None
+            return None
+    title  = property(fget=get_title, fset=set_title)
+    description  = property(fget=get_description, fset=set_description)
+    number_of_maps  = property(fget=get_number_of_maps)
-        print " | Number of registered maps:.. " + str(self.get_number_of_maps())
+        print " | Number of registered maps:.. " + str(
+            self.get_number_of_maps())
         print " | Title:"
         print " | " + str(self.get_title())
         print " | Description:"
@@ -592,18 +953,64 @@
         print "number_of_maps=" + str(self.get_number_of_maps())
-class stds_raster_metadata_base(stds_metadata_base):
+class STDSRasterMetadataBase(STDSMetadataBase):
     """!This is the space time dataset metadata base class for strds and str3ds datasets
+       Most of the metadata values are set by triggers in the database when
+       new raster or voxel maps are added. Therefor only some set- an many get-functions
+       are available.
-       Most of the metadata values are set by triggers in the database when
-       new raster of voxel maps are added. Therefor only some set- an many get-functions
-       are available.
+        Usage:
+        >>> meta = tgis.STDSRasterMetadataBase(ident="soils at PERMANENT",
+        >>> meta.id
+        >>> meta.title
+        'Soils'
+        >>> meta.min_max
+        >>> meta.max_max
+        >>> meta.min_min
+        >>> meta.max_min
+        >>> meta.nsres_min
+        >>> meta.nsres_max
+        >>> meta.ewres_min
+        >>> meta.ewres_max
+         | Title:
+         | Soils
+         | Description:
+         | North-South resolution min:. None
+         | North-South resolution max:. None
+         | East-west resolution min:... None
+         | East-west resolution max:... None
+         | Minimum value min:.......... None
+         | Minimum value max:.......... None
+         | Maximum value min:.......... None
+         | Maximum value max:.......... None
+        nsres_min=None
+        nsres_max=None
+        ewres_min=None
+        ewres_max=None
+        min_min=None
+        min_max=None
+        max_min=None
+        max_max=None
-	stds_metadata_base.__init__(self, table, ident, title, description)
+        STDSMetadataBase.__init__(self, table, ident, title, description)
         # Initialize the dict to select all values from the db
         self.D["min_max"] = None
         self.D["max_max"] = None
@@ -615,80 +1022,97 @@
         self.D["ewres_max"] = None
     def get_max_min(self):
-	"""!Get the minimal maximum of all registered maps, this value is set in the database
-	if self.D.has_key("max_min"):
-	    return self.D["max_min"]
+        """!Get the minimal maximum of all registered maps,
+        if "max_min" in self.D:
+            return self.D["max_min"]
         else:
-	    return None
+            return None
     def get_min_min(self):
-	"""!Get the minimal minimum of all registered maps, this value is set in the database
-	if self.D.has_key("min_min"):
-	    return self.D["min_min"]
+        """!Get the minimal minimum of all registered maps,
+        if "min_min" in self.D:
+            return self.D["min_min"]
         else:
-	    return None
+            return None
     def get_max_max(self):
-	"""!Get the maximal maximum of all registered maps, this value is set in the database
-	if self.D.has_key("max_max"):
-	    return self.D["max_max"]
+        """!Get the maximal maximum of all registered maps,
+        if "max_max" in self.D:
+            return self.D["max_max"]
         else:
-	    return None
+            return None
     def get_min_max(self):
-	"""!Get the maximal minimum of all registered maps, this value is set in the database
-	if self.D.has_key("min_max"):
-	    return self.D["min_max"]
+        """!Get the maximal minimum of all registered maps,
+        if "min_max" in self.D:
+            return self.D["min_max"]
         else:
-	    return None
+            return None
     def get_nsres_min(self):
-	"""!Get the minimal north-south resolution of all registered maps, this value is set in the database
-	if self.D.has_key("nsres_min"):
-	    return self.D["nsres_min"]
+        """!Get the minimal north-south resolution of all registered maps,
+        if "nsres_min" in self.D:
+            return self.D["nsres_min"]
         else:
-	    return None
+            return None
     def get_nsres_max(self):
-	"""!Get the maximal north-south resolution of all registered maps, this value is set in the database
-	if self.D.has_key("nsres_max"):
-	    return self.D["nsres_max"]
+        """!Get the maximal north-south resolution of all registered maps,
+        if "nsres_max" in self.D:
+            return self.D["nsres_max"]
         else:
-	    return None
+            return None
     def get_ewres_min(self):
-	"""!Get the minimal east-west resolution of all registered maps, this value is set in the database
-	if self.D.has_key("ewres_min"):
-	    return self.D["ewres_min"]
+        """!Get the minimal east-west resolution of all registered maps,
+        if "ewres_min" in self.D:
+            return self.D["ewres_min"]
         else:
-	    return None
+            return None
     def get_ewres_max(self):
-	"""!Get the maximal east-west resolution of all registered maps, this value is set in the database
-	if self.D.has_key("ewres_max"):
-	    return self.D["ewres_max"]
+        """!Get the maximal east-west resolution of all registered maps,
+        if "ewres_max" in self.D:
+            return self.D["ewres_max"]
         else:
-	    return None
+            return None
+    nsres_min = property(fget=get_nsres_min)
+    nsres_max = property(fget=get_nsres_max)
+    ewres_min = property(fget=get_ewres_min)
+    ewres_max = property(fget=get_ewres_max)
+    min_min = property(fget=get_min_min)
+    min_max = property(fget=get_min_max)
+    max_min = property(fget=get_max_min)
+    max_max = property(fget=get_max_max)
-        stds_metadata_base.print_info(self)
+        STDSMetadataBase.print_info(self)
         print " | North-South resolution min:. " + str(self.get_nsres_min())
         print " | North-South resolution max:. " + str(self.get_nsres_max())
@@ -701,7 +1125,7 @@
-        stds_metadata_base.print_shell_info(self)
+        STDSMetadataBase.print_shell_info(self)
         print "nsres_min=" + str(self.get_nsres_min())
         print "nsres_max=" + str(self.get_nsres_max())
         print "ewres_min=" + str(self.get_ewres_min())
@@ -714,312 +1138,500 @@
-class strds_metadata(stds_raster_metadata_base):
-    def __init__(self, ident=None, raster_register=None,  title=None, description=None):
+class STRDSMetadata(STDSRasterMetadataBase):
+        This class is the interface to the strds_metadata table in the
+        space time raster datasets
+        Usage:
+        >>> meta = tgis.STRDSMetadata(ident="soils at PERMANENT",
+        >>> meta.id
+        >>> meta.title
+        'Soils'
+        >>> meta.min_max
+        >>> meta.max_max
+        >>> meta.min_min
+        >>> meta.max_min
+        >>> meta.raster_register
+         | Title:
+         | Soils
+         | Description:
+         | Raster register table:...... None
+        nsres_min=None
+        nsres_max=None
+        ewres_min=None
+        ewres_max=None
+        min_min=None
+        min_max=None
+        max_min=None
+        max_max=None
+        raster_register=None
+    def __init__(self, ident=None, raster_register=None, title=None, description=None):
-	stds_raster_metadata_base.__init__(self, "strds_metadata", ident, title, description)
+        STDSRasterMetadataBase.__init__(
+            self, "strds_metadata", ident, title, description)
-	self.set_raster_register(raster_register)
+        self.set_raster_register(raster_register)
     def set_raster_register(self, raster_register):
-	"""!Set the raster map register table name"""
-	self.D["raster_register"] = raster_register
+        """!Set the raster map register table name"""
+        self.D["raster_register"] = raster_register
     def get_raster_register(self):
-	"""!Get the raster map register table name
-	   @return None if not found"""
-	if self.D.has_key("raster_register"):
-	    return self.D["raster_register"]
+        """!Get the raster map register table name
+           @return None if not found"""
+        if "raster_register" in self.D:
+            return self.D["raster_register"]
         else:
-	    return None
+            return None
+    raster_register = property(fget=get_raster_register,
+                               fset=set_raster_register)
-        stds_raster_metadata_base.print_info(self)
-        print " | Raster register table:...... " + str(self.get_raster_register())
+        STDSRasterMetadataBase.print_info(self)
+        print " | Raster register table:...... " + str(
+            self.get_raster_register())
-        stds_raster_metadata_base.print_shell_info(self)
+        STDSRasterMetadataBase.print_shell_info(self)
         print "raster_register=" + str(self.get_raster_register())
-class str3ds_metadata(stds_raster_metadata_base):
-    """!This is the space time raster3d metadata class"""
-    def __init__(self, ident=None, raster3d_register=None,  title=None, description=None):
-	stds_raster_metadata_base.__init__(self, "str3ds_metadata", ident, title, description)
+class STR3DSMetadata(STDSRasterMetadataBase):
+    """!This is the space time raster3d metadata class
+        This class is the interface to the str3ds_metadata table in the
+        space time 3D raster datasets
+        Usage:
+        >>> meta = tgis.STR3DSMetadata(ident="soils at PERMANENT",
+        >>> meta.id
+        >>> meta.title
+        'Soils'
+        >>> meta.min_max
+        >>> meta.max_max
+        >>> meta.min_min
+        >>> meta.max_min
+        >>> meta.tbres_min
+        >>> meta.tbres_max
+        >>> meta.raster3d_register
+         | Title:
+         | Soils
+         | Description:
+         | Top-bottom resolution min:.. None
+         | Top-bottom resolution max:.. None
+         | 3D raster register table:... None
+        nsres_min=None
+        nsres_max=None
+        ewres_min=None
+        ewres_max=None
+        min_min=None
+        min_max=None
+        max_min=None
+        max_max=None
+        tbres_min=None
+        tbres_max=None
+        raster3d_register=None
+    def __init__(self, ident=None, raster3d_register=None, title=None, description=None):
-	self.set_raster3d_register(raster3d_register)
+            self, "str3ds_metadata", ident, title, description)
+        self.set_raster3d_register(raster3d_register)
         self.D["tbres_min"] = None
         self.D["tbres_max"] = None
     def set_raster3d_register(self, raster3d_register):
-	self.D["raster3d_register"] = raster3d_register
+        self.D["raster3d_register"] = raster3d_register
     def get_raster3d_register(self):
-	"""!Get the raster3d map register table name
-	if self.D.has_key("raster3d_register"):
-	    return self.D["raster3d_register"]
+        """!Get the raster3d map register table name
+        if "raster3d_register" in self.D:
+            return self.D["raster3d_register"]
         else:
-	    return None
+            return None
     def get_tbres_min(self):
-	"""!Get the minimal top-bottom resolution of all registered maps, this value is set in the database
-	if self.D.has_key("tbres_min"):
-	    return self.D["tbres_min"]
+        """!Get the minimal top-bottom resolution of all registered maps,
+        if "tbres_min" in self.D:
+            return self.D["tbres_min"]
         else:
-	    return None
+            return None
     def get_tbres_max(self):
-	"""!Get the maximal top-bottom resolution of all registered maps, this value is set in the database
-	if self.D.has_key("tbres_max"):
-	    return self.D["tbres_max"]
+        """!Get the maximal top-bottom resolution of all registered maps,
+        if "tbres_max" in self.D:
+            return self.D["tbres_max"]
         else:
-	    return None
+            return None
+    raster3d_register = property(fget=get_raster3d_register,
+                               fset=set_raster3d_register)
+    tbres_min = property(fget=get_tbres_min)
+    tbres_max = property(fget=get_tbres_max)
     def print_info(self):
         print " | Top-bottom resolution min:.. " + str(self.get_ewres_min())
         print " | Top-bottom resolution max:.. " + str(self.get_ewres_max())
-        print " | Raster3d register table:.... " + str(self.get_raster3d_register())
+        print " | 3D raster register table:... " + str(
+            self.get_raster3d_register())
     def print_shell_info(self):
         print "tbres_min=" + str(self.get_tbres_min())
         print "tbres_max=" + str(self.get_tbres_max())
         print "raster3d_register=" + str(self.get_raster3d_register())
-class stvds_metadata(stds_metadata_base):
-    def __init__(self, ident=None, vector_register=None,  title=None, description=None, \
-                 points=None, lines=None, boundaries=None,\
+class STVDSMetadata(STDSMetadataBase):
+    """!This is the space time vector dataset metadata class
+       new vector maps are added. Therefor only some set- an many get-functions
+       are available.
+        >>> meta = tgis.STVDSMetadata(ident="lidars at PERMANENT",
+        ... title="LIDARS", description="LIDARS 2008 - 2010")
+        >>> meta.id
+        'lidars at PERMANENT'
+        >>> meta.title
+        'LIDARS'
+        'LIDARS 2008 - 2010'
+         | Title:
+         | LIDARS
+         | Description:
+         | LIDARS 2008 - 2010
+         | Vector register table:...... None
+         | Number of points ........... None
+         | Number of lines ............ None
+         | Number of boundaries ....... None
+         | Number of centroids ........ None
+         | Number of faces ............ None
+         | Number of kernels .......... None
+         | Number of primitives ....... None
+         | Number of nodes ............ None
+         | Number of areas ............ None
+         | Number of islands .......... None
+         | Number of holes ............ None
+         | Number of volumes .......... None
+        vector_register=None
+        points=None
+        lines=None
+        boundaries=None
+        centroids=None
+        faces=None
+        kernels=None
+        primitives=None
+        nodes=None
+        areas=None
+        islands=None
+        holes=None
+        volumes=None
+    def __init__(
+        self, ident=None, vector_register=None, title=None, description=None):
-	stds_metadata_base.__init__(self, "stvds_metadata", ident, title, description)
+            self, "stvds_metadata", ident, title, description)
-	self.set_vector_register(vector_register)
+        self.set_vector_register(vector_register)
+        self.D["points"] = None
+        self.D["lines"] = None
+        self.D["boundaries"] = None
+        self.D["centroids"] = None
+        self.D["faces"] = None
+        self.D["kernels"] = None
+        self.D["primitives"] = None
+        self.D["nodes"] = None
+        self.D["areas"] = None
+        self.D["islands"] = None
+        self.D["holes"] = None
+        self.D["volumes"] = None
     def set_vector_register(self, vector_register):
-	"""!Set the vector map register table name"""
-	self.D["vector_register"] = vector_register
+        """!Set the vector map register table name"""
+        self.D["vector_register"] = vector_register
     def get_vector_register(self):
-	"""!Get the vector map register table name
-	if self.D.has_key("vector_register"):
-	    return self.D["vector_register"]
+        """!Get the vector map register table name
+        if "vector_register" in self.D:
+            return self.D["vector_register"]
         else:
-	    return None
+            return None
+        """!Get the number of points of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of lines of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of boundaries of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of centroids of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of faces of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of kernels of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of primitives of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of nodes of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of areas of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of islands of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of holes of all registered maps,
         else:
-	    return None
+            return None
+        """!Get the number of volumes of all registered maps,
         else:
-	    return None
+            return None
+    vector_register  = property(fget=get_vector_register,
+                                fset=set_vector_register)
+    number_of_points = property(fget=get_number_of_points)
+    number_of_lines = property(fget=get_number_of_lines)
+    number_of_boundaries = property(fget=get_number_of_boundaries)
+    number_of_centroids = property(fget=get_number_of_centroids)
+    number_of_faces = property(fget=get_number_of_faces)
+    number_of_kernels = property(fget=get_number_of_kernels)
+    number_of_primitives = property(fget=get_number_of_primitives)
+    number_of_nodes = property(fget=get_number_of_nodes)
+    number_of_areas = property(fget=get_number_of_areas)
+    number_of_islands = property(fget=get_number_of_islands)
+    number_of_holes = property(fget=get_number_of_holes)
+    number_of_volumes = property(fget=get_number_of_volumes)
-        print " | Vector register table:...... " + str(self.get_vector_register())
+        print " | Vector register table:...... " + str(
+            self.get_vector_register())
         print "vector_register=" + str(self.get_vector_register())
+if __name__ == "__main__":
+    import doctest
+    doctest.testmod()
\ No newline at end of file
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -98,11 +98,11 @@
     def reset(self, ident):
 	"""!Reset the internal structure and set the identifier"""
-	self.base = raster_base(ident=ident)
-	self.absolute_time = raster_absolute_time(ident=ident)
-	self.relative_time = raster_relative_time(ident=ident)
-	self.spatial_extent = raster_spatial_extent(ident=ident)
-	self.metadata = raster_metadata(ident=ident)
+	self.base = RasterBase(ident=ident)
+	self.absolute_time = RasterAbslouteTime(ident=ident)
+	self.relative_time = RasterRelativeTime(ident=ident)
+	self.spatial_extent = RasterSpatialExtent(ident=ident)
+	self.metadata = RasterMetadata(ident=ident)
     def has_grass_timestamp(self):
         """!Check if a grass file bsased time stamp exists for this map.
@@ -306,11 +306,11 @@
-	self.base = raster3d_base(ident=ident)
-	self.absolute_time = raster3d_absolute_time(ident=ident)
-	self.relative_time = raster3d_relative_time(ident=ident)
-	self.spatial_extent = raster3d_spatial_extent(ident=ident)
-	self.metadata = raster3d_metadata(ident=ident)
+	self.base = Raster3DBase(ident=ident)
+	self.absolute_time = Raster3DAbslouteTime(ident=ident)
+	self.relative_time = Raster3DRelativeTime(ident=ident)
+	self.spatial_extent = Raster3DSpatialExtent(ident=ident)
+	self.metadata = Raster3DMetadata(ident=ident)
@@ -515,11 +515,11 @@
-	self.base = vector_base(ident=ident)
-	self.absolute_time = vector_absolute_time(ident=ident)
-	self.relative_time = vector_relative_time(ident=ident)
-	self.spatial_extent = vector_spatial_extent(ident=ident)
-	self.metadata = vector_metadata(ident=ident)
+	self.base = VectorBase(ident=ident)
+	self.absolute_time = VectorAbslouteTime(ident=ident)
+	self.relative_time = VectorRelativeTime(ident=ident)
+	self.spatial_extent = VectorSpatialExtent(ident=ident)
+	self.metadata = VectorMetadata(ident=ident)
@@ -724,12 +724,12 @@
-	self.base = strds_base(ident=ident)
+	self.base = STRDSBase(ident=ident)
         self.base.set_creator(str(getpass.getuser()))
-        self.absolute_time = strds_absolute_time(ident=ident)
-        self.relative_time = strds_relative_time(ident=ident)
-	self.spatial_extent = strds_spatial_extent(ident=ident)
-	self.metadata = strds_metadata(ident=ident)
+        self.absolute_time = STRDSAbslouteTime(ident=ident)
+        self.relative_time = STRDSRelativeTime(ident=ident)
+	self.spatial_extent = STRDSSpatialExtent(ident=ident)
+	self.metadata = STRDSMetadata(ident=ident)
@@ -778,12 +778,12 @@
-	self.base = str3ds_base(ident=ident)
+	self.base = STR3DSBase(ident=ident)
-        self.absolute_time = str3ds_absolute_time(ident=ident)
-        self.relative_time = str3ds_relative_time(ident=ident)
-	self.spatial_extent = str3ds_spatial_extent(ident=ident)
-	self.metadata = str3ds_metadata(ident=ident)
+        self.absolute_time = STR3DSAbslouteTime(ident=ident)
+        self.relative_time = STR3DSRelativeTime(ident=ident)
+	self.spatial_extent = STR3DSSpatialExtent(ident=ident)
+	self.metadata = STR3DSMetadata(ident=ident)
@@ -826,10 +826,104 @@
-	self.base = stvds_base(ident=ident)
+	self.base = STVDSBase(ident=ident)
-        self.absolute_time = stvds_absolute_time(ident=ident)
-        self.relative_time = stvds_relative_time(ident=ident)
-	self.spatial_extent = stvds_spatial_extent(ident=ident)
-	self.metadata = stvds_metadata(ident=ident)
+        self.absolute_time = STVDSAbslouteTime(ident=ident)
+        self.relative_time = STVDSRelativeTime(ident=ident)
+	self.spatial_extent = STVDSSpatialExtent(ident=ident)
+	self.metadata = STVDSMetadata(ident=ident)
+class AbstractDatasetComparisonKeyStartTime(object):
+    """!This comparison key can be used to sort lists of abstract datasets by start time
+        Example:
+        # Return all maps in a space time raster dataset as map objects
+        map_list = strds.get_registered_maps_as_objects()
+        # Sort the maps in the list by start time
+        sorted_map_list = sorted(
+            map_list, key=AbstractDatasetComparisonKeyStartTime)
+    def __init__(self, obj, *args):
+        self.obj = obj
+    def __lt__(self, other):
+        startA, endA = self.obj.get_valid_time()
+        startB, endB = other.obj.get_valid_time()
+        return startA < startB
+    def __gt__(self, other):
+        return startA > startB
+    def __eq__(self, other):
+        return startA == startB
+    def __le__(self, other):
+        return startA <= startB
+    def __ge__(self, other):
+        return startA >= startB
+    def __ne__(self, other):
+        return startA != startB
+class AbstractDatasetComparisonKeyEndTime(object):
+    """!This comparison key can be used to sort lists of abstract datasets by end time
+        Example:
+        # Sort the maps in the list by end time
+            map_list, key=AbstractDatasetComparisonKeyEndTime)
+        self.obj = obj
+        return endA < endB
+        return endA > endB
+        return endA == endB
+        return endA <= endB
+        return endA >= endB
+        return endA != endB
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -541,7 +541,7 @@
     sst = dataset_factory(sampletype, sid)
-    dbif = sql_database_interface_connection()
+    dbif = ()
     dbif.connect()
     for st in sts:
Modified: grass/trunk/lib/python/temporal/spatial_extent.py
--- grass/trunk/lib/python/temporal/spatial_extent.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/spatial_extent.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -6,12 +6,26 @@
 Usage:
- at code
-import grass.temporal as tgis
+>>> import grass.temporal as tgis
+>>> extent = tgis.RasterSpatialExtent(
+... ident="raster at PERMANENT", north=90, south=90, east=180, west=180,
+... top=100, bottom=-20)
+>>> extent = tgis.Raster3DSpatialExtent(
+... ident="raster3d at PERMANENT", north=90, south=90, east=180, west=180,
+>>> extent = tgis.VectorSpatialExtent(
+... ident="vector at PERMANENT", north=90, south=90, east=180, west=180,
+>>> extent = tgis.STRDSSpatialExtent(
+... ident="strds at PERMANENT", north=90, south=90, east=180, west=180,
+>>> extent = tgis.STR3DSSpatialExtent(
+... ident="str3ds at PERMANENT", north=90, south=90, east=180, west=180,
+>>> extent = tgis.STVDSSpatialExtent(
+... ident="stvds at PERMANENT", north=90, south=90, east=180, west=180,
-extent = tgis.raster_spatial_extent()
- at endcode
 (C) 2008-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
@@ -22,35 +36,76 @@
 from base import *
-class spatial_extent(sql_database_interface):
-    """!This is the spatial extent base class for all maps and space time datasets"""
-    def __init__(self, table=None, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None, proj="XY"):
+class SpatialExtent(SQLDatabaseInterface):
+    """!This is the spatial extent base class for all maps and space time datasets
+        This class implements a three dimensional axis aligned bounding box
+        and functions to compute topological relationships
+        >>> extent = tgis.SpatialExtent(table="raster_spatial_extent",
+        ... ident="soil at PERMANENT", north=90, south=90, east=180, west=180,
+        ... top=100, bottom=-20)
+        >>> extent.id
+        'soil at PERMANENT'
+        >>> extent.north
+        90.0
+        >>> extent.south
+        90.0
+        >>> extent.east
+        180.0
+        >>> extent.west
+        180.0
+        >>> extent.top
+        100.0
+        >>> extent.bottom
+        -20.0
+        >>> extent.print_info()
+         +-------------------- Spatial extent ----------------------------------------+
+         | North:...................... 90.0
+         | South:...................... 90.0
+         | East:.. .................... 180.0
+         | West:....................... 180.0
+         | Top:........................ 100.0
+         | Bottom:..................... -20.0
+        >>> extent.print_shell_info()
+        north=90.0
+        south=90.0
+        east=180.0
+        west=180.0
+        top=100.0
+        bottom=-20.0
+    def __init__(self, table=None, ident=None, north=None, south=None,
+                 east=None, west=None, top=None, bottom=None, proj="XY"):
+        SQLDatabaseInterface.__init__(self, table, ident)
         self.set_id(ident)
         self.set_spatial_extent(north, south, east, west, top, bottom)
-	self.set_projection(proj)
+        self.set_projection(proj)
     def overlapping_2d(self, extent):
-        """!Return True if the two dimensional extents overlap. Code is lend from wind_overlap.c in lib/gis
-	   Overlapping includes the spatial relations:
-	   * contain
-	   * in
-	   * cover
-	   * covered
-	   * equivalent
+        """!Return True if the two dimensional extents overlap.
+           Code is lend from wind_overlap.c in lib/gis
+           Overlapping includes the spatial relations:
+           * contain
+           * in
+           * cover
+           * covered
+           * equivalent
         if self.get_projection() != extent.get_projection():
             core.error(_("Projections are different. Unable to compute overlapping_2d for spatial extents"))
             return False
         N = extent.get_north()
         S = extent.get_south()
         E = extent.get_east()
         W = extent.get_west()
         # Adjust the east and west in case of LL projection
         if self.get_projection() == "LL":
             while E < self.get_west():
@@ -60,64 +115,72 @@
             while W > self.get_east():
                 E -= 360.0
                 W -= 360.0
         if(self.get_north() <= S):
             return False
         if(self.get_south() >= N):
             return False
         if self.get_east() <= W:
             return False
         if self.get_west() >= E:
             return False
         return True
     def overlapping(self, extent):
         """!Return True if the three dimensional extents overlap
+       * contain
+       * in
+       * cover
+       * covered
+       * equivalent
+        Usage:
-	   * contain
-	   * in
-	   * cover
-	   * covered
-	   * equivalent
+        >>> A = tgis.SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+        >>> B = tgis.SpatialExtent(north=80, south=20, east=60, west=10, bottom=-50, top=50)
+        >>> A.overlapping(B)
+        True
         if not self.overlapping_2d(extent):
             return False
         T = extent.get_top()
         B = extent.get_bottom()
         if self.get_top() <= B:
             return False
         if self.get_bottom() >= T:
             return False
         return True
     def intersect_2d(self, extent):
-	"""!Return the two dimensional intersection as spatial_extent object or None
-	   in case no intersection was found.
-	if not self.overlapping_2d(extent):
-	    return None
-	eN = extent.get_north()
+        """!Return the two dimensional intersection as spatial_extent object or None
+           in case no intersection was found.
+        if not self.overlapping_2d(extent):
+            return None
+        eN = extent.get_north()
         eS = extent.get_south()
         eE = extent.get_east()
         eW = extent.get_west()
-	N = self.get_north()
+        N = self.get_north()
         S = self.get_south()
         E = self.get_east()
         W = self.get_west()
             while eE < W:
@@ -126,79 +189,133 @@
             while eW > E:
                 eE -= 360.0
-                eW -= 360.0
+                eW -= 360.0
         # Compute the extent
         nN = N
         nS = S
         nE = E
         nW = W
         if W < eW:
-	    nW = eW
-	if E > eE:
-	    nE = eE
-	if N > eN:
-	    nN = eN
-	if S < eS:
-	    nS = eS
-	new = spatial_extent(north=nN, south=nS, east=nE, west=nW, top=0, bottom=0, proj=self.get_projection())
-	return new
+            nW = eW
+        if E > eE:
+            nE = eE
+        if N > eN:
+            nN = eN
+        if S < eS:
+            nS = eS
+        new = SpatialExtent(north=nN, south=nS, east=nE, west=nW,
+                             top=0, bottom=0, proj=self.get_projection())
+        return new
     def intersect(self, extent):
-	"""!Return the three dimensional intersection as spatial_extent object or None
-	if not self.overlapping(extent):
-	    return None
-	new = self.intersect_2d(extent)
-	eT = extent.get_top()
-	eB = extent.get_bottom()
-	T = self.get_top()
-	B = self.get_bottom()
-	nT = T
-	nB = B
-	if B < eB:
-	    nB = eB
-	if T > eT:
-	    nT = eT
-	new.set_top(nT)
-	new.set_bottom(nB)
-	return new
+        """!Return the three dimensional intersection as spatial_extent object or None
+        Usage:
+        >>> C = A.intersect(B)
+        >>> C.print_info()
+         | North:...................... 80.0
+         | South:...................... 20.0
+         | East:.. .................... 60.0
+         | West:....................... 10.0
+         | Top:........................ 50.0
+         | Bottom:..................... -50.0
+        >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=10, bottom=-50, top=50)
+         | North:...................... 40.0
+         | South:...................... 30.0
+        >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=30, bottom=-50, top=50)
+         | West:....................... 30.0
+        >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=50)
+         | Bottom:..................... -30.0
+        >>> B = tgis.SpatialExtent(north=40, south=30, east=60, west=30, bottom=-30, top=30)
+         | Top:........................ 30.0
+        if not self.overlapping(extent):
+            return None
+        new = self.intersect_2d(extent)
+        eT = extent.get_top()
+        eB = extent.get_bottom()
+        T = self.get_top()
+        B = self.get_bottom()
+        nT = T
+        nB = B
+        if B < eB:
+            nB = eB
+        if T > eT:
+            nT = eT
+        new.set_top(nT)
+        new.set_bottom(nB)
+        return new
     def is_in_2d(self, extent):
-	"""Check two dimensional if the self is located in extent
-         _____
-	|A _  |
-	| |_| |
-	|_____|
+        """Check two dimensional if the self is located in extent
+         _____
+        |A _  |
+        | |_| |
+        |_____|B
             core.error(_("Projections are different. Unable to compute is_in_2d for spatial extents"))
             return False
         E = self.get_east()
         W = self.get_west()
             while eE < W:
@@ -207,62 +324,73 @@
             while eW > E:
                 eE -= 360.0
-                eW -= 360.0
+                eW -= 360.0
         if W <= eW:
-	    return False
-	if E >= eE:
-	    return False
-	if N >= eN:
-	    return False
-	if S <= eS:
-	    return False
-	return True
+            return False
+        if E >= eE:
+            return False
+        if N >= eN:
+            return False
+        if S <= eS:
+            return False
+        return True
     def is_in(self, extent):
-	"""Check three dimensional if the self is located in extent """
-	if not self.is_in_2d(extent):
-	    return False
-	if B <= eB:
-	    return False
-	if T >= eT:
-	    return False
-	return True
+        """Check three dimensional if the self is located in extent
+        Usage:
+        >>> A = tgis.SpatialExtent(north=79, south=21, east=59, west=11, bottom=-49, top=49)
+        >>> A.is_in(B)
+        True
+        >>> B.is_in(A)
+        False
+        if not self.is_in_2d(extent):
+            return False
+        if B <= eB:
+            return False
+        if T >= eT:
+            return False
+        return True
     def contain_2d(self, extent):
-	"""Check two dimensional if self contains extent """
-	return extent.is_in_2d(self)
+        """Check two dimensional if self contains extent """
+        return extent.is_in_2d(self)
     def contain(self, extent):
-	"""Check three dimensional if self contains extent """
-	return extent.is_in(self)
+        """Check three dimensional if self contains extent """
+        return extent.is_in(self)
     def equivalent_2d(self, extent):
-	"""Check two dimensional if self is equivalent to extent """
+        """Check two dimensional if self is equivalent to extent """
             core.error(_("Projections are different. Unable to compute equivalent_2d for spatial extents"))
             return False
         E = self.get_east()
         W = self.get_west()
             while eE < W:
@@ -271,80 +399,79 @@
             while eW > E:
                 eE -= 360.0
-                eW -= 360.0
+                eW -= 360.0
         if W != eW:
-	    return False
-	if E != eE:
-	    return False
-	if N != eN:
-	    return False
-	if S != eS:
-	    return False
-	return True
+            return False
+        if E != eE:
+            return False
+        if N != eN:
+            return False
+        if S != eS:
+            return False
+        return True
     def equivalent(self, extent):
-	"""Check three dimensional if self is equivalent to extent """
+        """Check three dimensional if self is equivalent to extent """
-	if not self.equivalent_2d(extent):
-	    return False
-	if B != eB:
-	    return False
-	if T != eT:
-	    return False
-	return True
+        if not self.equivalent_2d(extent):
+            return False
+        if B != eB:
+            return False
+        if T != eT:
+            return False
+        return True
     def cover_2d(self, extent):
-        """Return True if two dimensional self covers extent
+        """Return True if two dimensional self covers extent
             _____    _____    _____    _____
            |A  __|  |__  A|  |A | B|  |B | A|
            |  |B |  | B|  |  |  |__|  |__|  |
            |__|__|  |__|__|  |_____|  |_____|
            |A|B| |  |A  __|  |A _  |  |__  A|
            | |_| |  |  |__|B | |B| | B|__|  |
            |_____|  |_____|  |_|_|_|  |_____|
            |A|B  |  |_____|A |A|B|A|  |_____|A
            | |   |  |B    |  | | | |  |_____|B
            |_|___|  |_____|  |_|_|_|  |_____|A
            The following cases are excluded:
-	   * contain
-	   * in
-	   * equivalent
+           * contain
+           * in
+           * equivalent
             core.error(_("Projections are different. Unable to compute cover_2d for spatial extents"))
             return False
-	# Exclude equivalent_2d
+        # Exclude equivalent_2d
         if self.equivalent_2d(extent):
-	    return False
+            return False
         E = self.get_east()
         W = self.get_west()
             while eE < W:
@@ -353,71 +480,71 @@
             while eW > E:
                 eE -= 360.0
-                eW -= 360.0
-	# Edges of extent located outside of self are not allowed
+                eW -= 360.0
+        # Edges of extent located outside of self are not allowed
         if E < eW:
-	    return False
-	if W > eE:
-	    return False
-	if N < eS:
-	    return False
-	if S > eN:
-	    return False
+            return False
+        if W > eE:
+            return False
+        if N < eS:
+            return False
+        if S > eN:
+            return False
         # First we check that at least one edge of extent meets an edge of self
         if W != eW and E != eE and N != eN and S != eS:
-	    return False
-	# We check that at least one edge of extent is located in self
-	edge_count = 0
-	if W < eW and E > eW:
-	    edge_count += 1
-	if E > eE and W < eE:
-	    edge_count += 1
-	if N > eN and S < eN:
-	    edge_count += 1
-	if S < eS and N > eS:
-	    edge_count += 1
-	if edge_count == 0:
-	    return False
-	return True
+            return False
+        # We check that at least one edge of extent is located in self
+        edge_count = 0
+        if W < eW and E > eW:
+            edge_count += 1
+        if E > eE and W < eE:
+            edge_count += 1
+        if N > eN and S < eN:
+            edge_count += 1
+        if S < eS and N > eS:
+            edge_count += 1
+        if edge_count == 0:
+            return False
+        return True
     def cover(self, extent):
-        """Return True if three dimensional self covers extent
+        """Return True if three dimensional self covers extent
-	   * contain
-	   * in
-	   * equivalent
+           * contain
+           * in
+           * equivalent
             core.error(_("Projections are different. Unable to compute cover for spatial extents"))
             return False
-	    return False
+            return False
         E = self.get_east()
         W = self.get_west()
             while eE < W:
@@ -426,60 +553,60 @@
             while eW > E:
                 eE -= 360.0
-                eW -= 360.0
+                eW -= 360.0
         if E <= eW:
-	    return False
-	if W >= eE:
-	    return False
-	if N <= eS:
-	    return False
-	if S >= eN:
-	    return False
-	if T <= eB:
-	    return False
-	if B >= eT:
-	    return False
+            return False
+        if W >= eE:
+            return False
+        if N <= eS:
+            return False
+        if S >= eN:
+            return False
+        if T <= eB:
+            return False
+        if B >= eT:
+            return False
         if W != eW and E != eE and N != eN and S != eS and B != eB and T != eT:
-	    return False
-	edge_count = 0
-	    edge_count += 1
-	    edge_count += 1
-	    edge_count += 1
-	    edge_count += 1
-	    edge_count += 1
-	    edge_count += 1
-	if T > eT and B < eT:
-	    edge_count += 1
-	if B < eB and T > eB:
-	    edge_count += 1
-	    return False
-	return True
+            return False
+        edge_count = 0
+            edge_count += 1
+            edge_count += 1
+            edge_count += 1
+            edge_count += 1
+            edge_count += 1
+            edge_count += 1
+        if T > eT and B < eT:
+            edge_count += 1
+        if B < eB and T > eB:
+            edge_count += 1
+            return False
+        return True
     def covered_2d(self, extent):
-	"""Check two dimensional if self is covered by  extent """
+        """Check two dimensional if self is covered by  extent """
-	return extent.cover_2d(self)
+        return extent.cover_2d(self)
     def covered(self, extent):
-	"""Check three dimensional if self is covered by extent """
-	return extent.cover(self)
+        """Check three dimensional if self is covered by extent """
+        return extent.cover(self)
     def overlap_2d(self, extent):
         """Return True if the two dimensional extents overlap. Code is lend from wind_overlap.c in lib/gis
             _____
@@ -487,35 +614,35 @@
            |  |  | B|
            |__|__|  |
               |_____|
-	   * contain
-	   * in
-	   * cover
-	   * covered
-	   * equivalent
+           * contain
+           * in
+           * cover
+           * covered
+           * equivalent
         if self.contain_2d(extent):
-	    return False
+            return False
         if self.is_in_2d(extent):
-	    return False
+            return False
         if self.cover_2d(extent):
-	    return False
+            return False
         if self.covered_2d(extent):
-	    return False
+            return False
-	    return False
+            return False
@@ -525,54 +652,54 @@
                 E -= 360.0
                 W -= 360.0
             return False
             return False
             return False
             return False
         return True
     def overlap(self, extent):
         """Return True if the three dimensional extents overlap
-	   * contain
-	   * in
-	   * cover
-	   * covered
-	   * equivalent
+           * contain
+           * in
+           * cover
+           * covered
+           * equivalent
         if self.is_in(extent):
-	    return False
+            return False
         if self.contain(extent):
-	    return False
+            return False
         if self.cover(extent):
-	    return False
+            return False
         if self.covered(extent):
-	    return False
+            return False
         if self.equivalent(extent):
-	    return False
+            return False
@@ -582,60 +709,60 @@
                 E -= 360.0
                 W -= 360.0
             return False
             return False
             return False
             return False
             return False
             return False
         return True
-    def meet_2d(self,extent):
-	""" Check if self and extent meet each other in two dimensions
-	  _____ _____    _____ _____
-	 |  A  |  B  |  |  B  |  A  |
-	 |_____|     |  |     |     |
-	       |_____|  |_____|_____|
-	         ___
-	        | A |
-	        |___|    _____
-	       |  B  |  |  B  |
-	       |_____|  |_____|_
-	                  |  A  |
-	                  |_____|
+    def meet_2d(self, extent):
+        """ Check if self and extent meet each other in two dimensions
+          _____ _____    _____ _____
+         |  A  |  B  |  |  B  |  A  |
+         |_____|     |  |     |     |
+               |_____|  |_____|_____|
+                 ___
+                | A |
+                |___|    _____
+               |  B  |  |  B  |
+               |_____|  |_____|_
+                          |  A  |
+                          |_____|
         E = self.get_east()
         W = self.get_west()
             while eE < W:
@@ -644,57 +771,57 @@
             while eW > E:
                 eE -= 360.0
-                eW -= 360.0
+                eW -= 360.0
         edge = None
         edge_count = 0
         if E == eW:
-	    edge = "E"
-	    edge_count += 1
+            edge = "E"
+            edge_count += 1
         if W == eE:
-	    edge = "W"
-	    edge_count += 1
+            edge = "W"
+            edge_count += 1
         if N == eS:
-	    edge = "N"
-	    edge_count += 1
+            edge = "N"
+            edge_count += 1
         if S == eN:
-	    edge = "S"
-	    edge_count += 1
-	# Meet a a single edge only
-	if edge_count != 1:
-	    return False
-	# Check boundaries of the faces
-	if edge == "E" or edge == "W":
-	    if N < eS or S > eN:
-		return False
-	if edge == "N" or edge == "S":
-	    if E < eW or W > eE:
-		return False
-	return True
+            edge = "S"
+            edge_count += 1
-    def meet(self,extent):
-	""" Check if self and extent meet each other in three dimensions"""
+        # Meet a a single edge only
+        if edge_count != 1:
+            return False
+        # Check boundaries of the faces
+        if edge == "E" or edge == "W":
+            if N < eS or S > eN:
+                return False
+        if edge == "N" or edge == "S":
+            if E < eW or W > eE:
+                return False
+        return True
+    def meet(self, extent):
+        """ Check if self and extent meet each other in three dimensions"""
         E = self.get_east()
         W = self.get_west()
             while eE < W:
@@ -703,295 +830,476 @@
             while eW > E:
                 eE -= 360.0
-                eW -= 360.0
+                eW -= 360.0
         edge = None
         edge_count = 0
         if E == eW:
-	    edge = "E"
-	    edge_count += 1
+            edge = "E"
+            edge_count += 1
         if W == eE:
-	    edge = "W"
-	    edge_count += 1
+            edge = "W"
+            edge_count += 1
         if N == eS:
-	    edge = "N"
-	    edge_count += 1
+            edge = "N"
+            edge_count += 1
         if S == eN:
-	    edge = "S"
-	    edge_count += 1
+            edge = "S"
+            edge_count += 1
         if T == eB:
-	    edge = "T"
-	    edge_count += 1
+            edge = "T"
+            edge_count += 1
         if B == eT:
-	    edge = "B"
-	    edge_count += 1
-	# Meet a single edge only
-	    return False
-		return False
-	    if T < eB or B > eT:
-		return False
-		return False
-		return False
-	if edge == "T" or edge == "B":
-		return False
-		return False
-	return True
+            edge = "B"
+            edge_count += 1
+        # Meet a single edge only
+            return False
+                return False
+            if T < eB or B > eT:
+                return False
+                return False
+                return False
+        if edge == "T" or edge == "B":
+                return False
+                return False
+        return True
     def disjoint_2d(self, extent):
-        """Return True if the two dimensional extents are disjoint
+        """Return True if the two dimensional extents are disjoint
         if self.overlapping_2d(extent) or self.meet_2d(extent):
-	    return False
-	return True
+            return False
+        return True
     def disjoint(self, extent):
-        """Return True if the three dimensional extents are disjoint
+        """Return True if the three dimensional extents are disjoint
         if self.overlapping(extent) or self.meet(extent):
-	    return False
-	return True
+            return False
+        return True
     def spatial_relation_2d(self, extent):
-	"""Returns the two dimensional spatial relation between self and extent
-	    Spatial relations are:
-	    * disjoint
-	    * meet
-	    * overlap
-	    * cover
-	    * covered
-	    * in
-	    * contain
-	    * equivalent
+        """Returns the two dimensional spatial relation between self and extent
+        Spatial relations are:
+        * disjoint
+        * meet
+        * overlap
+        * cover
+        * covered
+        * in
+        * contain
+        * equivalent
-	if self.equivalent_2d(extent):
-	    return "equivalent"
-	if self.contain_2d(extent):
-	    return "contain"
-	if self.is_in_2d(extent):
-	    return "in"
-	if self.cover_2d(extent):
-	    return "cover"
-	if self.covered_2d(extent):
-	    return "covered"
-	if self.overlap_2d(extent):
-	    return "overlap"
-	if self.meet_2d(extent):
-	    return "meet"
-	if self.disjoint_2d(extent):
-	    return "disjoint"
+        Usage: see self.spatial_relation()
+        if self.equivalent_2d(extent):
+            return "equivalent"
+        if self.contain_2d(extent):
+            return "contain"
+        if self.is_in_2d(extent):
+            return "in"
+        if self.cover_2d(extent):
+            return "cover"
+        if self.covered_2d(extent):
+            return "covered"
+        if self.overlap_2d(extent):
+            return "overlap"
+        if self.meet_2d(extent):
+            return "meet"
+        if self.disjoint_2d(extent):
+            return "disjoint"
         return "unknown"
     def spatial_relation(self, extent):
-	"""Returns the three dimensional spatial relation between self and extent
-	    * disjoint
-	    * meet
-	    * overlap
-	    * cover
-	    * covered
-	    * in
-	    * contain
-	    * equivalent
+        """Returns the three dimensional spatial relation between self and extent
+        * disjoint
+        * meet
+        * overlap
+        * cover
+        * covered
+        * in
+        * contain
+        * equivalent
-	if self.equivalent(extent):
-	if self.contain(extent):
-	    return "contain"
-	if self.is_in(extent):
-	    return "in"
-	if self.cover(extent):
-	    return "cover"
-	if self.covered(extent):
-	    return "covered"
-	if self.overlap(extent):
-	    return "overlap"
-	if self.meet(extent):
-	    return "meet"
-	if self.disjoint(extent):
-	    return "disjoint"
+        Usage:
+        >>> A.spatial_relation(B)
+        'equivalent'
+        >>> B.spatial_relation(A)
+        'equivalent'
+        >>> B = tgis.SpatialExtent(north=70, south=20, east=60, west=10, bottom=-50, top=50)
+        >>> A.spatial_relation_2d(B)
+        'cover'
+        'cover'
+        >>> B = tgis.SpatialExtent(north=70, south=30, east=60, west=10, bottom=-50, top=50)
+        'cover'
+        'cover'
+        >>> B.spatial_relation_2d(A)
+        'covered'
+        'covered'
+        >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=10, bottom=-50, top=50)
+        'cover'
+        'covered'
+        'cover'
+        >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=20, bottom=-50, top=50)
+        'covered'
+        'contain'
+        'cover'
+        >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=20, bottom=-40, top=50)
+        'cover'
+        >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=20, bottom=-40, top=40)
+        'contain'
+        'in'
+        >>> B = tgis.SpatialExtent(north=90, south=30, east=50, west=20, bottom=-40, top=40)
+        'overlap'
+        'overlap'
+        >>> B = tgis.SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=40)
+        'in'
+        'overlap'
+        >>> B = tgis.SpatialExtent(north=90, south=5, east=70, west=5, bottom=-40, top=60)
+        'overlap'
+        >>> B = tgis.SpatialExtent(north=90, south=5, east=70, west=5, bottom=-60, top=60)
+        'in'
+        >>> A = tgis.SpatialExtent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
+        >>> B = tgis.SpatialExtent(north=60, south=20, east=60, west=10, bottom=-50, top=50)
+        'meet'
+        'meet'
+        >>> A = tgis.SpatialExtent(north=60, south=40, east=60, west=10, bottom=-50, top=50)
+        >>> B = tgis.SpatialExtent(north=80, south=60, east=60, west=10, bottom=-50, top=50)
+        'meet'
+        'meet'
+        >>> A = tgis.SpatialExtent(north=80, south=40, east=60, west=40, bottom=-50, top=50)
+        >>> B = tgis.SpatialExtent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
+        'meet'
+        'meet'
+        >>> A = tgis.SpatialExtent(north=80, south=40, east=40, west=20, bottom=-50, top=50)
+        >>> B = tgis.SpatialExtent(north=90, south=30, east=60, west=40, bottom=-50, top=50)
+        'meet'
+        'meet'
+        >>> B = tgis.SpatialExtent(north=70, south=50, east=60, west=40, bottom=-50, top=50)
+        'meet'
+        'meet'
+        >>> B = tgis.SpatialExtent(north=60, south=20, east=60, west=40, bottom=-50, top=50)
+        'meet'
+        'meet'
+        >>> B = tgis.SpatialExtent(north=40, south=20, east=60, west=40, bottom=-50, top=50)
+        'disjoint'
+        'disjoint'
+        >>> B = tgis.SpatialExtent(north=60, south=20, east=60, west=40, bottom=-60, top=60)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=90, south=30, east=60, west=40, bottom=-40, top=40)
+        'meet'
+        >>> A = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
+        >>> B = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=80, south=50, east=60, west=30, bottom=-50, top=0)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=70, south=50, east=50, west=30, bottom=-50, top=0)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=90, south=30, east=70, west=10, bottom=-50, top=0)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=10, bottom=-50, top=0)
+        'meet'
+        >>> A = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=-50, top=0)
+        >>> B = tgis.SpatialExtent(north=80, south=40, east=60, west=20, bottom=0, top=50)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=80, south=50, east=60, west=30, bottom=0, top=50)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=70, south=50, east=50, west=30, bottom=0, top=50)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=90, south=30, east=70, west=10, bottom=0, top=50)
+        'meet'
+        >>> B = tgis.SpatialExtent(north=70, south=30, east=50, west=10, bottom=0, top=50)
+        'meet'
+        if self.equivalent(extent):
+        if self.contain(extent):
+            return "contain"
+        if self.is_in(extent):
+            return "in"
+        if self.cover(extent):
+            return "cover"
+        if self.covered(extent):
+            return "covered"
+        if self.overlap(extent):
+            return "overlap"
+        if self.meet(extent):
+            return "meet"
+        if self.disjoint(extent):
+            return "disjoint"
         return "unknown"
     def set_spatial_extent(self, north, south, east, west, top, bottom):
         """Set the spatial extent"""
-	self.set_north(north)
-	self.set_south(south)
-	self.set_east(east)
-	self.set_west(west)
-	self.set_top(top)
-	self.set_bottom(bottom)
+        self.set_north(north)
+        self.set_south(south)
+        self.set_east(east)
+        self.set_west(west)
+        self.set_top(top)
+        self.set_bottom(bottom)
     def set_projection(self, proj):
         """Set the projection of the spatial extent it should be XY or LL.
            As default the projection is XY
-        if proj == None or (proj != "XY" and proj != "LL"):
+        if proj is None or (proj != "XY" and proj != "LL"):
             self.D["proj"] = "XY"
         else:
             self.D["proj"] = proj
     def set_spatial_extent_2d(self, north, south, east, west):
-	self.set_top(0)
-	self.set_bottom(0)
     def set_id(self, ident):
-	"""Convenient method to set the unique identifier (primary key)"""
-	self.ident = ident
-	self.D["id"] = ident
+        """Convenient method to set the unique identifier (primary key)"""
+        self.ident = ident
+        self.D["id"] = ident
     def set_north(self, north):
-	"""Set the northern edge of the map"""
-	self.D["north"] = north
+        """Set the northern edge of the map"""
+        if north is not None:
+            self.D["north"] = float(north)
+        else:
+            self.D["north"] = None
-    def set_south(self, sourth):
-	"""Set the southern edge of the map"""
-	self.D["south"] = sourth
+    def set_south(self, south):
+        """Set the southern edge of the map"""
+        if south is not None:
+            self.D["south"] = float(south)
+        else:
+            self.D["south"] = None
     def set_west(self, west):
-	"""Set the western edge of the map"""
-	self.D["west"] = west
+        """Set the western edge of the map"""
+        if west is not None:
+            self.D["west"] = float(west)
+        else:
+            self.D["west"] = None
     def set_east(self, east):
-	"""Set the eastern edge of the map"""
-	self.D["east"] = east
+        """Set the eastern edge of the map"""
+        if east is not None:
+            self.D["east"] = float(east)
+        else:
+            self.D["east"] = None
     def set_top(self, top):
-	"""Set the top edge of the map"""
-	self.D["top"] = top
+        """Set the top edge of the map"""
+        if top is not None:
+            self.D["top"] = float(top)
+        else:
+            self.D["top"] = None
     def set_bottom(self, bottom):
-	"""Set the bottom edge of the map"""
-	self.D["bottom"] = bottom
+        """Set the bottom edge of the map"""
+        if bottom is not None:
+            self.D["bottom"] = float(bottom)
+        else:
+            self.D["bottom"] = None
     def get_id(self):
-	"""Convenient method to get the unique identifier (primary key)
-	if self.D.has_key("id"):
-	    return self.D["id"]
+        """Convenient method to get the unique identifier (primary key)
+        if "id" in self.D:
+            return self.D["id"]
         else:
-	    return None
+            return None
     def get_projection(self):
         """Get the projection of the spatial extent"""
         return self.D["proj"]
     def get_volume(self):
-        """Compute the volume of the extent, in case z is zero (top == bottom or top - bottom = 1) the area is returned"""
+        """Compute the volume of the extent, in case z is zero
+           (top == bottom or top - bottom = 1) the area is returned"""
             core.error(_("Volume computation is not supported for LL projections"))
         area = self.get_area()
         bbox = self.get_spatial_extent()
         z = abs(bbox[4] - bbox[5])
         if z == 0:
             z = 1.0
-        return area*z
+        return area * z
     def get_area(self):
         """Compute the area of the extent, extent in z direction is ignored"""
             core.error(_("Area computation is not supported for LL projections"))
         y = abs(bbox[0] - bbox[1])
         x = abs(bbox[2] - bbox[3])
-        return x*y
+        return x * y
     def get_spatial_extent(self):
         """Return a tuple (north, south, east, west, top, bottom) of the spatial extent"""
-        return (self.get_north(), self.get_south, self.get_east(), self.get_west(), \
-                self.get_top(), self.get_bottom())
+        return (
+            self.get_north(), self.get_south, self.get_east(), self.get_west(),
+            self.get_top(), self.get_bottom())
     def get_spatial_extent_2d(self):
         """Return a tuple (north, south, east, west,) of the 2d spatial extent"""
         return (self.get_north(), self.get_south, self.get_east(), self.get_west())
     def get_north(self):
-	"""Get the northern edge of the map
-	if self.D.has_key("north"):
-	    return self.D["north"]
+        """Get the northern edge of the map
+        if "north" in self.D:
+            return self.D["north"]
         else:
-	    return None
+            return None
     def get_south(self):
-	"""Get the southern edge of the map
-	if self.D.has_key("south"):
-	    return self.D["south"]
+        """Get the southern edge of the map
+        if "south" in self.D:
+            return self.D["south"]
         else:
-	    return None
+            return None
     def get_east(self):
-	"""Get the eastern edge of the map
-	if self.D.has_key("east"):
-	    return self.D["east"]
+        """Get the eastern edge of the map
+        if "east" in self.D:
+            return self.D["east"]
         else:
-	    return None
+            return None
     def get_west(self):
-	"""Get the western edge of the map
-	if self.D.has_key("west"):
-	    return self.D["west"]
+        """Get the western edge of the map
+        if "west" in self.D:
+            return self.D["west"]
         else:
-	    return None
+            return None
     def get_top(self):
-	"""Get the top edge of the map
-	if self.D.has_key("top"):
-	    return self.D["top"]
+        """Get the top edge of the map
+        if "top" in self.D:
+            return self.D["top"]
         else:
-	    return None
+            return None
     def get_bottom(self):
-	"""Get the bottom edge of the map
-	if self.D.has_key("bottom"):
-	    return self.D["bottom"]
+        """Get the bottom edge of the map
+        if "bottom" in self.D:
+            return self.D["bottom"]
         else:
-	    return None
+            return None
+    id = property(fget=get_id, fset=set_id)
+    north = property(fget=get_north, fset=set_north)
+    south = property(fget=get_south, fset=set_south)
+    east = property(fget=get_east, fset=set_east)
+    west = property(fget=get_west, fset=set_west)
+    top = property(fget=get_top, fset=set_top)
+    bottom= property(fget=get_bottom, fset=set_bottom)
         """Print information about this class in human readable style"""
@@ -1016,26 +1324,43 @@
-class raster_spatial_extent(spatial_extent):
+class RasterSpatialExtent(SpatialExtent):
     def __init__(self, ident=None, north=None, south=None, east=None, west=None, top=None, bottom=None):
-        spatial_extent.__init__(self, "raster_spatial_extent", ident, north, south, east, west, top, bottom)
+        SpatialExtent.__init__(self, "raster_spatial_extent",
+                                ident, north, south, east, west, top, bottom)
-class raster3d_spatial_extent(spatial_extent):
+class Raster3DSpatialExtent(SpatialExtent):
-        spatial_extent.__init__(self, "raster3d_spatial_extent", ident, north, south, east, west, top, bottom)
+        SpatialExtent.__init__(self, "raster3d_spatial_extent",
-class vector_spatial_extent(spatial_extent):
+class VectorSpatialExtent(SpatialExtent):
-        spatial_extent.__init__(self, "vector_spatial_extent", ident, north, south, east, west, top, bottom)
+        SpatialExtent.__init__(self, "vector_spatial_extent",
-class strds_spatial_extent(spatial_extent):
+class STRDSSpatialExtent(SpatialExtent):
-        spatial_extent.__init__(self, "strds_spatial_extent", ident, north, south, east, west, top, bottom)
+        SpatialExtent.__init__(self, "strds_spatial_extent",
-class str3ds_spatial_extent(spatial_extent):
+class STR3DSSpatialExtent(SpatialExtent):
-        spatial_extent.__init__(self, "str3ds_spatial_extent", ident, north, south, east, west, top, bottom)
+        SpatialExtent.__init__(self, "str3ds_spatial_extent",
-class stvds_spatial_extent(spatial_extent):
+class STVDSSpatialExtent(SpatialExtent):
-        spatial_extent.__init__(self, "stvds_spatial_extent", ident, north, south, east, west, top, bottom)
+        SpatialExtent.__init__(self, "stvds_spatial_extent",
+    import doctest
+    doctest.testmod()
Modified: grass/trunk/lib/python/temporal/temporal_extent.py
--- grass/trunk/lib/python/temporal/temporal_extent.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/temporal_extent.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -6,13 +6,11 @@
 Usage:
- at code
+>>> from datetime import datetime
+>>> t = tgis.RasterRelativeTime()
+>>> t = tgis.RasterAbsoluteTime()
-tgis.raster_temporal_extent()
- at endcode
 License (>=v2). Read the file COPYING that comes with GRASS
@@ -24,313 +22,585 @@
-class abstract_temporal_extent(sql_database_interface):
-    """!This is the abstract time base class for relative and absolute time objects"""
+class AbstractTemporalExtent(SQLDatabaseInterface):
+    """!This is the abstract time base class for relative and absolute time objects
+        It abstract class implements the interface to absolute and relative time.
+        Absolute time is represented by datetime time stamps,
+        relative time is represented by a unit an integer value.
+        This class implements temporal topology relationships computation
+        after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic].
+        Usage:
+        >>> A = tgis.AbstractTemporalExtent(table="raster_absolute_time",
+        ... ident="soil at PERMANENT", start_time=datetime(2001, 01, 01),
+        ... end_time=datetime(2005,01,01) )
+        >>> A.id
+        >>> A.start_time
+        datetime.datetime(2001, 1, 1, 0, 0)
+        >>> A.end_time
+        datetime.datetime(2005, 1, 1, 0, 0)
+        >>> A.print_info()
+         | Start time:................. 2001-01-01 00:00:00
+         | End time:................... 2005-01-01 00:00:00
+        >>> A.print_shell_info()
+        start_time=2001-01-01 00:00:00
+        end_time=2005-01-01 00:00:00
+        >>> # relative time
+        ... ident="soil at PERMANENT", start_time=0, end_time=1 )
+        >>> A.id
+        >>> A.start_time
+        0
+        >>> A.end_time
+        1
+         | Start time:................. 0
+         | End time:................... 1
+        start_time=0
+        end_time=1
     def __init__(self, table=None, ident=None, start_time=None, end_time=None):
-	self.set_start_time(start_time)
-	self.set_end_time(end_time)
+        self.set_id(ident)
+        self.set_start_time(start_time)
+        self.set_end_time(end_time)
     def starts(self, extent):
-	"""!Return True if this time object starts at the start of the provided time object and finishes within it
-	   A  |-----|
-	   B  |---------|
-        if  self.D["end_time"] == None or extent.D["end_time"] == None :
+        """!Return True if this temporal extent (A) starts at the start of the
+           provided temporal extent (B) and finishes within it
+           A  |-----|
+           B  |---------|
+           @param extent: The temporal extent object with which this extent starts
+           Usage:
+           >>> A = tgis.AbstractTemporalExtent(start_time=5, end_time=6 )
+           >>> B = tgis.AbstractTemporalExtent(start_time=5, end_time=7 )
+           >>> A.starts(B)
+           True
+           >>> B.starts(A)
+           False
+        if  self.D["end_time"] is None or extent.D["end_time"] is None:
             return False
-	if self.D["start_time"] == extent.D["start_time"] and self.D["end_time"] < extent.D["end_time"]:
-	    return True
+        if self.D["start_time"] == extent.D["start_time"] and \
+           self.D["end_time"] < extent.D["end_time"]:
+            return True
         else:
-	    return False
+            return False
     def started(self, extent):
-	"""!Return True if this time object is started at the start of the provided time object
-	   A  |---------|
-	   B  |-----|
+        """!Return True if this temporal extent (A) started at the start of the
+           provided temporal extent (B) and finishes after it
+           A  |---------|
+           B  |-----|
+           @param extent: The temporal extent object with which this extent started
+           Usage:
+           >>> A = tgis.AbstractTemporalExtent(start_time=5, end_time=7 )
+           >>> B = tgis.AbstractTemporalExtent(start_time=5, end_time=6 )
+           >>> A.started(B)
+           True
+           >>> B.started(A)
+           False
             return False
-	if self.D["start_time"] == extent.D["start_time"] and self.D["end_time"] > extent.D["end_time"]:
-	    return True
+           self.D["end_time"] > extent.D["end_time"]:
+            return True
         else:
-	    return False
+            return False
     def finishes(self, extent):
-	"""!Return True if this time object finishes at the end and within of the provided time object
-	   A      |-----|
-	   B  |---------|
+        """!Return True if this temporal extent (A) starts after the start of the
+           provided temporal extent (B) and finishes with it
+           A      |-----|
+           B  |---------|
+           @param extent: The temporal extent object with which this extent finishes
+           Usage:
+           >>> A = tgis.AbstractTemporalExtent(start_time=6, end_time=7 )
+           >>> A.finishes(B)
+           True
+           >>> B.finishes(A)
+           False
             return False
-	if self.D["end_time"] == extent.D["end_time"] and  self.D["start_time"] > extent.D["start_time"] :
-	    return True
+        if self.D["end_time"] == extent.D["end_time"] and \
+           self.D["start_time"] > extent.D["start_time"]:
+            return True
         else:
-	    return False
+            return False
     def finished(self, extent):
-	"""!Return True if this time object finished at the end of the provided time object
-	   A  |---------|
-	   B      |-----|
+        """!Return True if this temporal extent (A) starts before the start of the
+           A  |---------|
+           B      |-----|
+           Usage:
+           >>> B = tgis.AbstractTemporalExtent(start_time=6, end_time=7 )
+           >>> A.finished(B)
+           True
+           >>> B.finished(A)
+           False
             return False
-	if self.D["end_time"] == extent.D["end_time"] and  self.D["start_time"] < extent.D["start_time"] :
-	    return True
+           self.D["start_time"] < extent.D["start_time"]:
+            return True
         else:
-	    return False
+            return False
     def after(self, extent):
-	"""!Return True if this time object is temporal located after the provided time object
-	   A             |---------|
-	   B  |---------|
-        if extent.D["end_time"] == None:
+        """!Return True if this temporal extent (A) is located after the
+           A             |---------|
+           B  |---------|
+           @param extent: The temporal extent object that is located before this extent
+           Usage:
+           >>> import grass.temporal as tgis
+           >>> A = tgis.AbstractTemporalExtent(start_time=8, end_time=9 )
+           >>> A.after(B)
+           True
+           >>> B.after(A)
+           False
+        if extent.D["end_time"] is None:
             if self.D["start_time"] > extent.D["start_time"]:
                 return True
             else:
                 return False
-	if self.D["start_time"] > extent.D["end_time"]:
-	    return True
+        if self.D["start_time"] > extent.D["end_time"]:
+            return True
         else:
-	    return False
+            return False
     def before(self, extent):
-	"""!Return True if this time object is temporal located before the provided time object
-	   A  |---------|
-	   B             |---------|
-        if self.D["end_time"] == None:
+        """!Return True if this temporal extent (A) is located before the
+           A  |---------|
+           B             |---------|
+           @param extent: The temporal extent object that is located after this extent
+           Usage:
+           >>> B = tgis.AbstractTemporalExtent(start_time=8, end_time=9 )
+           >>> A.before(B)
+           True
+           >>> B.before(A)
+           False
+        if self.D["end_time"] is None:
             if self.D["start_time"] < extent.D["start_time"]:
                 return True
             else:
                 return False
-	if self.D["end_time"] < extent.D["start_time"]:
-	    return True
+        if self.D["end_time"] < extent.D["start_time"]:
+            return True
         else:
-	    return False
+            return False
     def adjacent(self, extent):
-	"""!Return True if this time object is a meeting neighbour the provided time object
-	   A            |---------|
-	   B  |---------|
-	   A  |---------|
-	   B            |---------|
-        if  self.D["end_time"] == None and extent.D["end_time"] == None :
+        """!Return True if this temporal extent (A) is a meeting neighbor the
+           A            |---------|
+           B  |---------|
+           A  |---------|
+           B            |---------|
+           @param extent: The temporal extent object that is a meeting neighbor
+                          of this extent
+           Usage:
+           >>> B = tgis.AbstractTemporalExtent(start_time=7, end_time=9 )
+           >>> A.adjacent(B)
+           True
+           >>> B.adjacent(A)
+           True
+           >>> B = tgis.AbstractTemporalExtent(start_time=3, end_time=5 )
+           >>> A.adjacent(B)
+           True
+           >>> B.adjacent(A)
+           True
+        if  self.D["end_time"] is None and extent.D["end_time"] is None:
             return False
-	if (self.D["start_time"] == extent.D["end_time"]) or (self.D["end_time"] == extent.D["start_time"]):
-	    return True
+        if (self.D["start_time"] == extent.D["end_time"]) or \
+           (self.D["end_time"] == extent.D["start_time"]):
+            return True
         else:
-	    return False
+            return False
     def follows(self, extent):
-	"""!Return True if this time object temporally follows the provided time object
-	   A            |---------|
-	   B  |---------|
-        if  extent.D["end_time"] == None :
+        """!Return True if this temporal extent (A) follows the
+           A            |---------|
+           B  |---------|
+           @param extent: The temporal extent object that is the predecessor
+                          of this extent
+           >>> A.follows(B)
+           True
+           >>> B.follows(A)
+           False
             return False
-	if self.D["start_time"] == extent.D["end_time"]:
-	    return True
+        if self.D["start_time"] == extent.D["end_time"]:
+            return True
         else:
-	    return False
+            return False
     def precedes(self, extent):
-	"""!Return True if this time object is temporal precedes the provided time object
-	   A  |---------|
-	   B            |---------|
+        """!Return True if this temporal extent (A) precedes the provided
+           temporal extent (B)
+           A  |---------|
+           B            |---------|
+           @param extent: The temporal extent object that is the successor
+                          of this extent
+           Usage:
+           >>> A.precedes(B)
+           True
+           >>> B.precedes(A)
+           False
             return False
-	if self.D["end_time"] == extent.D["start_time"]:
-	    return True
+        if self.D["end_time"] == extent.D["start_time"]:
+            return True
         else:
-	    return False
+            return False
     def during(self, extent):
-	"""!Return True if this time object is temporal located during the provided time object
-	   A   |-------|
-	   B  |---------|
+        """!Return True if this temporal extent (A) is located during the provided
+           A   |-------|
+           B  |---------|
+           @param extent: The temporal extent object that contains this extent
+           Usage:
+           >>> B = tgis.AbstractTemporalExtent(start_time=4, end_time=9 )
+           >>> A.during(B)
+           True
+           >>> B.during(A)
+           False
         # Check single point of time in interval
-                return False
+            return False
-            if self.D["start_time"] > extent.D["start_time"] and self.D["start_time"] < extent.D["end_time"]:
+            if self.D["start_time"] > extent.D["start_time"] and \
+               self.D["start_time"] < extent.D["end_time"]:
                 return True
             else:
                 return False
-	if self.D["start_time"] > extent.D["start_time"] and self.D["end_time"] < extent.D["end_time"]:
-	    return True
+            return True
         else:
-	    return False
+            return False
     def contains(self, extent):
-	"""!Return True if this time object contains the provided time object
-	   A  |---------|
-	   B   |-------|
+        """!Return True if this temporal extent (A) contains the provided
+           A  |---------|
+           B   |-------|
+                          during this extent
+           Usage:
+           >>> A = tgis.AbstractTemporalExtent(start_time=4, end_time=9 )
+           >>> B = tgis.AbstractTemporalExtent(start_time=5, end_time=8 )
+           >>> A.contains(B)
+           True
+           >>> B.contains(A)
+           False
-                return False
+            return False
-            if self.D["start_time"] < extent.D["start_time"] and self.D["end_time"] > extent.D["start_time"]:
+            if self.D["start_time"] < extent.D["start_time"] and \
+               self.D["end_time"] > extent.D["start_time"]:
                 return True
             else:
                 return False
-	if self.D["start_time"] < extent.D["start_time"] and self.D["end_time"] > extent.D["end_time"]:
-	    return True
+            return True
         else:
-	    return False
+            return False
-	"""!Return True if this time object is temporal located equivalent the provided time object
-	   A  |---------|
-	   B  |---------|
+        """!Return True if this temporal extent (A) is equivalent to the provided
+           A  |---------|
+           B  |---------|
+           @param extent: The temporal extent object that is equivalent
+           Usage:
+           >>> A.equivalent(B)
+           True
+           >>> B.equivalent(A)
+           True
             if self.D["start_time"] == extent.D["start_time"]:
                 return True
             else:
                 return False
             return False
-	if self.D["start_time"] == extent.D["start_time"] and self.D["end_time"] == extent.D["end_time"]:
-	    return True
+           self.D["end_time"] == extent.D["end_time"]:
+            return True
         else:
-	    return False
+            return False
     def overlapped(self, extent):
-	"""!Return True if this time object temporally overlapped the provided time object
+        """!Return True if this temporal extent (A) overlapped the provided
            A  |---------|
-	   B    |---------|
+           B    |---------|
+           @param extent: The temporal extent object that is overlaps
+                          this extent
+           Usage:
+           >>> B = tgis.AbstractTemporalExtent(start_time=6, end_time=8 )
+           >>> A.overlapped(B)
+           True
+           >>> B.overlapped(A)
+           False
             return False
-	if self.D["start_time"] < extent.D["start_time"] and self.D["end_time"] < extent.D["end_time"] and\
-	   self.D["end_time"] > extent.D["start_time"]:
-	    return True
+           self.D["end_time"] < extent.D["end_time"] and \
+            return True
         else:
-	    return False
+            return False
     def overlaps(self, extent):
-	"""!Return True if this time object temporally overlaps the provided time object
-	   A    |---------|
+        """!Return True if this temporal extent (A) overlapps the provided
+           A    |---------|
            B  |---------|
+           @param extent: The temporal extent object that is overlapped
+                          this extent
+           Usage:
+           >>> A = tgis.AbstractTemporalExtent(start_time=6, end_time=8 )
+           >>> A.overlaps(B)
+           True
+           >>> B.overlaps(A)
+           False
             return False
-	if self.D["start_time"] > extent.D["start_time"] and self.D["end_time"] > extent.D["end_time"] and\
-	   self.D["start_time"] < extent.D["end_time"]:
-	    return True
+           self.D["end_time"] > extent.D["end_time"] and \
+            return True
         else:
-	    return False
+            return False
     def temporal_relation(self, extent):
-	"""!Returns the temporal relation between temporal objects
-	   Temporal relationships are implemented after [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
+        """!Returns the temporal relation between temporal objects
+           Temporal relationships are implemented after
+           [Allen and Ferguson 1994 Actions and Events in Interval Temporal Logic]
+           The following temporal relationships are supported:
+           * equivalent
+           * during
+           * contains
+           * overlaps
+           * overlapped
+           * after
+           * before
+           * starts
+           * finishes
+           * started
+           * finished
+           * follows
+           * precedes
+           @return The name of the temporal relation or None if no relation found
         # First check for correct time
-        if not self.D.has_key("start_time"):
+        if "start_time" not in self.D:
             return None
-        if not self.D.has_key("end_time"):
+        if "end_time" not in self.D:
             return None
-        if not extent.D.has_key("start_time"):
+        if "start_time" not in extent.D:
             return None
-        if not extent.D.has_key("end_time"):
+        if "end_time" not in extent.D:
             return None
-        if self.D["start_time"] == None or extent.D["start_time"] == None:
+        # Return None if the start_time is undefined
+        if self.D["start_time"] is None or extent.D["start_time"] is None:
             return None
-	if self.during(extent):
-	    return "during"
-	if self.contains(extent):
-	    return "contains"
-	if self.overlaps(extent):
-	    return "overlaps"
-	if self.overlapped(extent):
-	    return "overlapped"
-	if self.after(extent):
-	    return "after"
-	if self.before(extent):
-	    return "before"
-	if self.starts(extent):
-	    return "starts"
-	if self.finishes(extent):
-	    return "finishes"
-	if self.started(extent):
-	    return "started"
-	if self.finished(extent):
-	    return "finished"
-	if self.follows(extent):
-	    return "follows"
-	if self.precedes(extent):
-	    return "precedes"
+        if self.during(extent):
+            return "during"
+        if self.contains(extent):
+            return "contains"
+        if self.overlaps(extent):
+            return "overlaps"
+        if self.overlapped(extent):
+            return "overlapped"
+        if self.after(extent):
+            return "after"
+        if self.before(extent):
+            return "before"
+        if self.starts(extent):
+            return "starts"
+        if self.finishes(extent):
+            return "finishes"
+        if self.started(extent):
+            return "started"
+        if self.finished(extent):
+            return "finished"
+        if self.follows(extent):
+            return "follows"
+        if self.precedes(extent):
+            return "precedes"
         return None
-	"""!Convenient method to set the unique identifier (primary key)"""
+        """!Convenient method to set the unique identifier (primary key)"""
     def set_start_time(self, start_time):
-	"""!Set the valid start time of the extent"""
-	self.D["start_time"] = start_time
+        """!Set the valid start time of the extent"""
+        self.D["start_time"] = start_time
     def set_end_time(self, end_time):
-	"""!Set the valid end time of the extent"""
-	self.D["end_time"] = end_time
+        """!Set the valid end time of the extent"""
+        self.D["end_time"] = end_time
     def get_id(self):
-	"""!Convenient method to get the unique identifier (primary key)
-	   @return None if not found
+        """!Convenient method to get the unique identifier (primary key)
+           @return None if not found
         else:
-	    return None
+            return None
     def get_start_time(self):
-	"""!Get the valid start time of the extent
-	   @return None if not found"""
-	if self.D.has_key("start_time"):
-	    return self.D["start_time"]
+        """!Get the valid start time of the extent
+           @return None if not found"""
+        if "start_time" in self.D:
+            return self.D["start_time"]
         else:
-	    return None
+            return None
     def get_end_time(self):
-	"""!Get the valid end time of the extent
-	if self.D.has_key("end_time"):
-	    return self.D["end_time"]
+        """!Get the valid end time of the extent
+        if "end_time" in self.D:
+            return self.D["end_time"]
         else:
-	    return None
+            return None
+    # Set the properties
+    start_time = property(fget=get_start_time, fset=set_start_time)
+    end_time = property(fget=get_end_time, fset=set_end_time)
         """!Print information about this class in human readable style"""
@@ -345,93 +615,139 @@
-class absolute_temporal_extent(abstract_temporal_extent):
+class AbsoluteTemporalExtent(AbstractTemporalExtent):
     """!This is the absolute time class for all maps and spacetime datasets
-       start_time and end_time must be of type datetime
+        start_time and end_time must be of type datetime
-    def __init__(self, table=None, ident=None, start_time=None, end_time=None, timezone=None):
+    def __init__(self, table=None, ident=None, start_time=None, end_time=None,
+                 timezone=None):
-	abstract_temporal_extent.__init__(self, table, ident, start_time, end_time)
+        AbstractTemporalExtent.__init__(
+            self, table, ident, start_time, end_time)
-	self.set_timezone(timezone)
+        self.set_timezone(timezone)
     def set_timezone(self, timezone):
-	"""!Set the timezone of the map, the timezone is of type string.
-           Timezones are not supported yet, instead the timezone is set in the datetime string as offset in minutes.
+        """!Set the timezone of the map, the timezone is of type string.
+           Timezones are not supported yet, instead the timezone
+           is set in the datetime string as offset in minutes.
-	self.D["timezone"] = timezone
+        self.D["timezone"] = timezone
     def get_timezone(self):
-	"""!Get the timezone of the map
-	if self.D.has_key("timezone"):
-	    return self.D["timezone"]
+        """!Get the timezone of the map
+        if "timezone" in self.D:
+            return self.D["timezone"]
         else:
-	    return None
+            return None
+    timezone = property(fget=get_timezone, fset=set_timezone)
     def print_info(self):
         #      0123456789012345678901234567890
         print " +-------------------- Absolute time -----------------------------------------+"
-        abstract_temporal_extent.print_info(self)
+        AbstractTemporalExtent.print_info(self)
         #print " | Timezone:................... " + str(self.get_timezone())
     def print_shell_info(self):
         """!Print information about this class in shell style"""
-        abstract_temporal_extent.print_shell_info(self)
+        AbstractTemporalExtent.print_shell_info(self)
         #print "timezone=" + str(self.get_timezone())
-class raster_absolute_time(absolute_temporal_extent):
+class RasterAbsoluteTime(AbsoluteTemporalExtent):
     def __init__(self, ident=None, start_time=None, end_time=None, timezone=None):
-        absolute_temporal_extent.__init__(self, "raster_absolute_time", ident, start_time, end_time, timezone)
+        AbsoluteTemporalExtent.__init__(self, "raster_absolute_time",
+            ident, start_time, end_time, timezone)
-class raster3d_absolute_time(absolute_temporal_extent):
+class Raster3DAbsoluteTime(AbsoluteTemporalExtent):
-        absolute_temporal_extent.__init__(self, "raster3d_absolute_time", ident, start_time, end_time, timezone)
+        AbsoluteTemporalExtent.__init__(self, "raster3d_absolute_time",
-class vector_absolute_time(absolute_temporal_extent):
+class VectorAbsoluteTime(AbsoluteTemporalExtent):
-        absolute_temporal_extent.__init__(self, "vector_absolute_time", ident, start_time, end_time, timezone)
+        AbsoluteTemporalExtent.__init__(self, "vector_absolute_time",
-class stds_absolute_time(absolute_temporal_extent):
-    def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, timezone=None, map_time=None):
-        absolute_temporal_extent.__init__(self, table, ident, start_time, end_time, timezone)
+class STDSAbsoluteTime(AbsoluteTemporalExtent):
+    """!This class implements the absolute time extent for space time dataset
+        In addition to the existing functionality the granularity and the
+        map_time are added.
+        Usage:
+        >>> A = tgis.STDSAbsoluteTime(table="strds_absolute_time",
+        ... ident="strds at PERMANENT", start_time=datetime(2001, 01, 01),
+        ... end_time=datetime(2005,01,01), granularity="1 days",
+        ... map_time="interval")
+        >>> A.id
+        'strds at PERMANENT'
+        >>> A.start_time
+        >>> A.end_time
+        >>> A.granularity
+        '1 days'
+        >>> A.map_time
+        'interval'
+         +-------------------- Absolute time -----------------------------------------+
+         | Granularity:................ 1 days
+         | Temporal type of maps:...... interval
+        granularity=1 days
+        map_time=interval
+                 granularity=None, timezone=None, map_time=None):
+            self, table, ident, start_time, end_time, timezone)
-	self.set_granularity(granularity)
+        self.set_granularity(granularity)
         self.set_map_time(map_time)
     def set_granularity(self, granularity):
-	"""!Set the granularity of the space time dataset"""
-	self.D["granularity"] = granularity
+        """!Set the granularity of the space time dataset"""
+        self.D["granularity"] = granularity
     def set_map_time(self, map_time):
-	"""!Set the type of the map time
+        """!Set the type of the map time
            Registered maps may have different types of time:
-           Single point of time "point"
-           Time intervals "interval"
-           Or single point and interval time "mixed"
+           * Single point of time "point"
+           * Time intervals "interval"
+           * Single point and interval time "mixed"
            This variable will be set automatically when maps are registered.
-	self.D["map_time"] = map_time
+        self.D["map_time"] = map_time
     def get_granularity(self):
-	"""!Get the granularity of the space time dataset
-	if self.D.has_key("granularity"):
-	    return self.D["granularity"]
+        """!Get the granularity of the space time dataset
+        if "granularity" in self.D:
+            return self.D["granularity"]
         else:
-	    return None
+            return None
     def get_map_time(self):
-	"""!Get the type of the map time
+        """!Get the type of the map time
@@ -440,49 +756,86 @@
-	if self.D.has_key("map_time"):
-	    return self.D["map_time"]
+        if "map_time" in self.D:
+            return self.D["map_time"]
         else:
-	    return None
+            return None
+    # Properties
+    granularity = property(fget=get_granularity, fset=set_granularity)
+    map_time = property(fget=get_map_time, fset=set_map_time)
-        absolute_temporal_extent.print_info(self)
+        AbsoluteTemporalExtent.print_info(self)
         print " | Granularity:................ " + str(self.get_granularity())
         print " | Temporal type of maps:...... " + str(self.get_map_time())
-        absolute_temporal_extent.print_shell_info(self)
+        AbsoluteTemporalExtent.print_shell_info(self)
         print "granularity=" + str(self.get_granularity())
         print "map_time=" + str(self.get_map_time())
-class strds_absolute_time(stds_absolute_time):
-    def __init__(self, ident=None, start_time=None, end_time=None, granularity=None, timezone=None):
-        stds_absolute_time.__init__(self, "strds_absolute_time", ident, start_time, end_time, granularity, timezone)
+class STRDSAbsoluteTime(STDSAbsoluteTime):
+    def __init__(self, ident=None, start_time=None, end_time=None,
+                 granularity=None, timezone=None):
+        STDSAbsoluteTime.__init__(self, "strds_absolute_time",
+            ident, start_time, end_time, granularity, timezone)
-class str3ds_absolute_time(stds_absolute_time):
-        stds_absolute_time.__init__(self, "str3ds_absolute_time", ident, start_time, end_time, granularity, timezone)
-class stvds_absolute_time(stds_absolute_time):
-        stds_absolute_time.__init__(self, "stvds_absolute_time", ident, start_time, end_time, granularity, timezone)
+class STR3DSAbsoluteTime(STDSAbsoluteTime):
+        STDSAbsoluteTime.__init__(self, "str3ds_absolute_time",
+class STVDSAbsoluteTime(STDSAbsoluteTime):
+        STDSAbsoluteTime.__init__(self, "RelativeTemporalExtent",
-class relative_temporal_extent(abstract_temporal_extent):
+class RelativeTemporalExtent(AbstractTemporalExtent):
     """!This is the relative time class for all maps and spacetime datasets
-       start_time and end_time must be of type integer
+        start_time and end_time must be of type integer
+        Usage:
+        >>> A = tgis.RelativeTemporalExtent(table="raster_absolute_time",
+        ... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years")
+        >>> A.id
+        >>> A.start_time
+        0
+        >>> A.end_time
+        1
+        >>> A.unit
+        'years'
+         +-------------------- Relative time -----------------------------------------+
+         | Relative time unit:......... years
+        start_time=0
+        end_time=1
+        unit=years
-    def __init__(self, table=None, ident=None, start_time=None, end_time=None, unit=None):
+                 unit=None):
-	self.D["unit"] = unit
+        self.D["unit"] = unit
     def set_unit(self, unit):
         """!Set the unit of the relative time. Valid units are:
@@ -493,74 +846,121 @@
            * minutes
            * seconds
     def get_unit(self):
-	"""!Get the unit of the relative time
-	if self.D.has_key("unit"):
-	    return self.D["unit"]
+        """!Get the unit of the relative time
+        if "unit" in self.D:
+            return self.D["unit"]
         else:
-	    return None
+            return None
     def temporal_relation(self, map):
         # Check units for relative time
-        if not self.D.has_key("unit"):
+        if "unit" not in self.D:
             return None
-        if not map.D.has_key("unit"):
+        if "unit" not in map.D:
             return None
         # Units must be equal
         if self.D["unit"] != map.D["unit"]:
             return None
-	return abstract_temporal_extent.temporal_relation(self, map)
+        return AbstractTemporalExtent.temporal_relation(self, map)
+    # Properties
+    unit = property(fget=get_unit, fset=set_unit)
         print " +-------------------- Relative time -----------------------------------------+"
         print " | Relative time unit:......... " + str(self.get_unit())
         print "unit=" + str(self.get_unit())
-class raster_relative_time(relative_temporal_extent):
+class RasterRelativeTime(RelativeTemporalExtent):
     def __init__(self, ident=None, start_time=None, end_time=None):
-        relative_temporal_extent.__init__(self, "raster_relative_time", ident, start_time, end_time)
+        RelativeTemporalExtent.__init__(
+            self, "raster_relative_time", ident, start_time, end_time)
-class raster3d_relative_time(relative_temporal_extent):
+class Raster3DRelativeTime(RelativeTemporalExtent):
-        relative_temporal_extent.__init__(self, "raster3d_relative_time", ident, start_time, end_time)
+        RelativeTemporalExtent.__init__(self,
+            "raster3d_relative_time", ident, start_time, end_time)
-class vector_relative_time(relative_temporal_extent):
+class VectorRelativeTime(RelativeTemporalExtent):
-        relative_temporal_extent.__init__(self, "vector_relative_time", ident, start_time, end_time)
+            self, "vector_relative_time", ident, start_time, end_time)
-class stds_relative_time(relative_temporal_extent):
-    def __init__(self, table=None, ident=None, start_time=None, end_time=None, granularity=None, map_time=None):
-        relative_temporal_extent.__init__(self, table, ident, start_time, end_time)
+class STDSRelativeTime(RelativeTemporalExtent):
+    """!This is the relative time class for all maps and spacetime datasets
+        Usage:
+        >>> A = tgis.STDSRelativeTime(table="raster_absolute_time",
+        ... ident="soil at PERMANENT", start_time=0, end_time=1, unit="years",
+        ... granularity=5, map_time="interval")
+        >>> A.id
+        >>> A.start_time
+        0
+        >>> A.end_time
+        1
+        >>> A.unit
+        'years'
+        >>> A.granularity
+        5
+        >>> A.map_time
+        'interval'
+         | Granularity:................ 5
+        start_time=0
+        end_time=1
+        unit=years
+        granularity=5
+        map_time=interval
+                 unit=None, granularity=None, map_time=None):
+            self, table, ident, start_time, end_time, unit)
@@ -569,18 +969,18 @@
         else:
-	    return None
+            return None
@@ -589,34 +989,52 @@
         else:
-	    return None
+            return None
+    # Properties
-        relative_temporal_extent.print_info(self)
+        RelativeTemporalExtent.print_info(self)
-        relative_temporal_extent.print_shell_info(self)
+        RelativeTemporalExtent.print_shell_info(self)
-class strds_relative_time(stds_relative_time):
-    def __init__(self, ident=None, start_time=None, end_time=None, granularity=None):
-        stds_relative_time.__init__(self, "strds_relative_time", ident, start_time, end_time, granularity)
+class STRDSRelativeTime(STDSRelativeTime):
+                 granularity=None):
+        STDSRelativeTime.__init__(self, "strds_relative_time",
+            ident, start_time, end_time, granularity)
-class str3ds_relative_time(stds_relative_time):
-        stds_relative_time.__init__(self, "str3ds_relative_time", ident, start_time, end_time, granularity)
-class stvds_relative_time(stds_relative_time):
-        stds_relative_time.__init__(self, "stvds_relative_time", ident, start_time, end_time, granularity)
+class STR3DSRelativeTime(STDSRelativeTime):
+        STDSRelativeTime.__init__(self, "str3ds_relative_time",
+class STVDSRelativeTime(STDSRelativeTime):
+        STDSRelativeTime.__init__(self, "stvds_relative_time",
+if __name__ == "__main__":
+    import doctest
+    doctest.testmod()
\ No newline at end of file
Modified: grass/trunk/lib/python/temporal/temporal_relationships.py
--- grass/trunk/lib/python/temporal/temporal_relationships.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/temporal_relationships.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -29,7 +29,7 @@
     """!This class is designed to build the temporal topology based on a lists of maps
 	Example:
+	@code
 	# We have a space time raster dataset and build a map list
 	# from all registered maps ordered by start time
 	maps = strds.get_registered_maps_as_objects()
@@ -56,7 +56,7 @@
 	# Dictionary like accessed
 	_map = tb["name at mapset"]
+	@endcode
     def __init__(self):
Modified: grass/trunk/lib/python/temporal/univar_statistics.py
--- grass/trunk/lib/python/temporal/univar_statistics.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/lib/python/temporal/univar_statistics.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -38,7 +38,7 @@
     # We need a database interface
-    dbif = sql_database_interface_connection()
+    dbif = SQLDatabaseInterfaceConnection()
     dbif.connect()
     mapset =  core.gisenv()["MAPSET"]
@@ -115,7 +115,7 @@
     dbif.connect()
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.create/t.create.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -80,7 +80,7 @@
     sp = tgis.dataset_factory(type, id)
-    dbif = tgis.sql_database_interface_connection()
+    dbif = tgis.SQLDatabaseInterfaceConnection()
     dbif.connect()
     if sp.is_in_db(dbif) and grass.overwrite() == False:
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.list/t.list.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -89,7 +89,7 @@
     id = None
     dbif.connect()
     # Create the sql selection statement
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -85,7 +85,7 @@
     # Make sure the temporal database exists
     tgis.create_temporal_database()
     dbif.connect()
     mapset =  grass.gisenv()["MAPSET"]
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -82,7 +82,7 @@
     dbif.connect()
Modified: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -73,7 +73,7 @@
         id = input + "@" + mapset
     dbif.connect()
     sp = tgis.space_time_raster_dataset(id)
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.remove/t.remove.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -59,7 +59,7 @@
     dbif.connect()
     dataset_list = []
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.support/t.support.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -89,7 +89,7 @@
     else:
         id = name + "@" + mapset
     dbif.connect()
     stds = tgis.dataset_factory(type, id)
Modified: grass/trunk/temporal/t.unregister/t.unregister.py
--- grass/trunk/temporal/t.unregister/t.unregister.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.unregister/t.unregister.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -63,7 +63,7 @@
     dbif.connect()
     # In case a space time dataset is specified
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -74,7 +74,7 @@
     dbif.connect()
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	2012-08-10 12:33:02 UTC (rev 52620)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py	2012-08-10 14:48:01 UTC (rev 52621)
@@ -80,7 +80,7 @@
     dbif.connect()
