[GRASS-SVN] r52637 - in grass/trunk: display/d.thematic.area display/d.vect general/g.gui imagery/i.landsat.toar imagery/i.modis.qc imagery/i.vi misc/m.nviz.image misc/m.transform raster/r.report raster/r.usler vector/v.build.polylines vector/v.category vector/v.class vector/v.distance vector/v.drape vector/v.edit vector/v.in.ascii vector/v.in.ogr vector/v.kernel vector/v.mkgrid vector/v.net vector/v.net.bridge vector/v.net.components vector/v.out.ascii vector/v.overlay vector/v.parallel vector/v.select vector/v.to.db vector/v.to.rast
svn_grass at osgeo.org
Sun Aug 12 07:29:09 PDT 2012
Author: annakrat
Date: 2012-08-12 07:29:08 -0700 (Sun, 12 Aug 2012)
New Revision: 52637
grass/trunk/display/d.thematic.area/main.c
grass/trunk/display/d.vect/main.c
grass/trunk/general/g.gui/main.c
grass/trunk/imagery/i.landsat.toar/main.c
grass/trunk/imagery/i.modis.qc/main.c
grass/trunk/imagery/i.vi/main.c
grass/trunk/misc/m.nviz.image/args.c
grass/trunk/misc/m.transform/main.c
grass/trunk/raster/r.report/parse.c
grass/trunk/raster/r.usler/main.c
grass/trunk/vector/v.build.polylines/main.c
grass/trunk/vector/v.category/main.c
grass/trunk/vector/v.class/main.c
grass/trunk/vector/v.distance/main.c
grass/trunk/vector/v.drape/main.c
grass/trunk/vector/v.edit/args.c
grass/trunk/vector/v.in.ascii/main.c
grass/trunk/vector/v.in.ogr/main.c
grass/trunk/vector/v.kernel/main.c
grass/trunk/vector/v.mkgrid/main.c
grass/trunk/vector/v.net.bridge/main.c
grass/trunk/vector/v.net.components/main.c
grass/trunk/vector/v.net/args.c
grass/trunk/vector/v.out.ascii/args.c
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.parallel/main.c
grass/trunk/vector/v.select/args.c
grass/trunk/vector/v.to.db/parse.c
grass/trunk/vector/v.to.rast/main.c
option name in descriptions must not be translatable
Modified: grass/trunk/display/d.thematic.area/main.c
--- grass/trunk/display/d.thematic.area/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/display/d.thematic.area/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -55,6 +55,7 @@
struct Option *field_opt;
struct Option *legend_file_opt;
struct Flag *legend_flag, *algoinfo_flag, *nodraw_flag;
+ char *desc;
struct cat_list *Clist;
int *cats, ncat, nrec, ctype;
@@ -102,10 +103,14 @@
algo_opt->multiple = NO;
algo_opt->options = "int,std,qua,equ,dis";
algo_opt->description = _("Algorithm to use for classification");
- algo_opt->descriptions = _("int;simple intervals;"
- "std;standard deviations;"
- "qua;quantiles;"
- "equ;equiprobable (normal distribution);");
+ desc = NULL;
+ G_asprintf(&desc,
+ "int;%s;std;%s;qua;%s;equ;%s",
+ _("simple intervals"),
+ _("standard deviations"),
+ _("quantiles"),
+ _("equiprobable (normal distribution)"));
+ algo_opt->descriptions = desc;
/*currently disabled because of bugs "dis;discontinuities"); */
nbclass_opt = G_define_option();
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/display/d.vect/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -54,6 +54,7 @@
struct Option *width_opt, *wcolumn_opt, *wscale_opt;
struct Flag *id_flag, *table_acolors_flag, *cats_acolors_flag,
*zcol_flag, *sqrt_flag;
+ char *desc;
LATTR lattr;
@@ -84,12 +85,16 @@
display_opt->answer = "shape";
display_opt->options = "shape,cat,topo,dir,attr,zcoor";
display_opt->description = _("Display");
- display_opt->descriptions = _("shape;Display geometry of features;"
- "cat;Display category numbers of features;"
- "topo;Display topology information (nodes, edges);"
- "dir;Display direction of linear features;"
- "attr;Display selected attribute based on 'attrcolumn';"
- "zcoor;Display z-coordinate of features (only for 3D vector maps)");
+ desc = NULL;
+ G_asprintf(&desc,
+ "shape;%s;cat;%s;topo;%s;dir;%s;attr;%s;zcoor;%s",
+ _("Display geometry of features"),
+ _("Display category numbers of features"),
+ _("Display topology information (nodes, edges)"),
+ _("Display direction of linear features"),
+ _("Display selected attribute based on 'attrcolumn'"),
+ _("Display z-coordinate of features (only for 3D vector maps)"));
+ display_opt->descriptions = desc;
/* Query */
type_opt = G_define_standard_option(G_OPT_V_TYPE);
Modified: grass/trunk/general/g.gui/main.c
--- grass/trunk/general/g.gui/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/general/g.gui/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -29,6 +29,7 @@
struct GModule *module;
const char *gui_type_env;
char progname[GPATH_MAX];
+ char *desc;
G_gisinit(argv[0]);
@@ -43,8 +44,12 @@
type->type = TYPE_STRING;
type->label = _("GUI type");
type->description = _("Default value: GRASS_GUI if defined otherwise wxpython");
- type->descriptions = _("wxpython;wxPython based GUI (wxGUI);"
- "text;command line interface only");
+ desc = NULL;
+ G_asprintf(&desc,
+ "wxpython;%s;text;%s",
+ _("wxPython based GUI (wxGUI)"),
+ _("command line interface only"));
+ type->descriptions = desc;
type->options = "wxpython,text";
rc_file = G_define_standard_option(G_OPT_F_INPUT);
Modified: grass/trunk/imagery/i.landsat.toar/main.c
--- grass/trunk/imagery/i.landsat.toar/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/imagery/i.landsat.toar/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -31,6 +31,7 @@
struct History history;
+ char *desc;
struct Cell_head cellhd;
@@ -97,13 +98,16 @@
sensor->label = _("Spacecraft sensor");
sensor->description = _("Required only if 'metfile' not given");
sensor->options = "mss1,mss2,mss3,tm4,tm5,tm7";
- sensor->descriptions =
- _("mss1;Landsat-1 MSS;"
- "mss2;Landsat-2 MSS;"
- "mss3;Landsat-3 MSS;"
- "tm4;Landsat-4 TM;"
- "tm5;Landsat-5 TM;"
- "tm7;Landsat-7 ETM+");
+ desc = NULL;
+ G_asprintf(&desc,
+ "mss1;%s;mss2;%s;mss3;%s;tm4;%s;tm5;%s;tm7;%s",
+ _("Landsat-1 MSS"),
+ _("Landsat-2 MSS"),
+ _("Landsat-3 MSS"),
+ _("Landsat-4 TM"),
+ _("Landsat-5 TM"),
+ _("Landsat-7 ETM+"));
+ sensor->descriptions = desc;
sensor->required = NO;
sensor->guisection = _("Metadata");
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/imagery/i.modis.qc/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -97,6 +97,7 @@
struct Option *productname, *qcname, *input, *input_band, *output;
struct History history; /*metadata */
struct Colors colors; /*Color rules */
+ char *desc_productname, *desc_qcname, *desc_input_band;
char *result; /*output raster name */
@@ -138,15 +139,25 @@
productname->type = TYPE_STRING;
productname->required = YES;
productname->description = _("Name of MODIS product type");
- productname->descriptions =_("mod09Q1;surf. refl. 250m 8-days;"
- "mod09A1;surf. refl. 500m 8-days;"
- "mod09A1s;surf. refl. 500m 8-days, State QA;"
- "mod11A1;LST 1Km daily (Day/Night);"
- "mod11A2;LST 1Km 8-days (Day/Night);"
- "mod13A2;VI 1Km 16-days;"
- "mcd43B2;Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days;"
- "mcd43B2q;Brdf-Albedo Quality (BRDF SDS) 1Km 8-days;"
+ desc_productname = NULL;
+ G_asprintf(&desc_productname,
+ "mod09Q1;%s;"
+ "mod09A1;%s;"
+ "mod09A1s;%s;"
+ "mod11A1;%s;"
+ "mod11A2;%s;"
+ "mod13A2;%s;"
+ "mcd43B2;%s;"
+ "mcd43B2q;%s",
+ _("surf. refl. 250m 8-days"),
+ _("surf. refl. 500m 8-days"),
+ _("surf. refl. 500m 8-days, State QA"),
+ _("LST 1Km daily (Day/Night)"),
+ _("LST 1Km 8-days (Day/Night)"),
+ _("VI 1Km 16-days"),
+ _("Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days"),
+ _("Brdf-Albedo Quality (BRDF SDS) 1Km 8-days"));
+ productname->descriptions = desc_productname;
productname->options = "mod09Q1,mod09A1,mod09A1s,mod11A1,mod11A2,mod13A2,mcd43B2,mcd43B2q";
productname->answer = "mod13A2";
@@ -155,45 +166,85 @@
qcname->type = TYPE_STRING;
qcname->required = YES;
qcname->description = _("Name of QC type to extract");
- qcname->descriptions =_("adjcorr;mod09: Adjacency Correction;"
- "atcorr;mod09: Atmospheric Correction;"
- "cloud;mod09: Cloud State;"
- "data_quality;mod09: Band-Wise Data Quality Flag;"
- "diff_orbit_from_500m;mod09: 250m Band is at Different Orbit than 500m;"
- "modland_qa;mod09: MODIS Land General Quality Assessment;"
- "mandatory_qa_11A1;mod11A1: MODIS Land General Quality Assessment;"
- "data_quality_flag_11A1;mod11A1: Detailed Quality Indications;"
- "emis_error_11A1;mod11A1: Average Emissivity Error Classes;"
- "lst_error_11A1;mod11A1: Average LST Error Classes;"
- "data_quality_flag_11A2;mod11A2: Detailed Quality Indications;"
- "emis_error_11A2;mod11A2: Average Emissivity Error Classes;"
- "mandatory_qa_11A2;mod11A2: MODIS Land General Quality Assessment;"
- "lst_error_11A2;mod11A2: Average LST Error Classes;"
- "aerosol_quantity;mod09A1s: StateQA Internal Snow Mask;"
- "brdf_correction_performed;mod09A1s: StateQA Internal Snow Mask;"
- "cirrus_detected;mod09A1s: StateQA Internal Snow Mask;"
- "cloud_shadow;mod09A1s: StateQA Internal Snow Mask;"
- "cloud_state;mod09A1s: StateQA Internal Snow Mask;"
- "internal_cloud_algorithm;mod09A1s: StateQA Internal Snow Mask;"
- "internal_fire_algorithm;mod09A1s: StateQA Internal Snow Mask;"
- "internal_snow_mask;mod09A1s: StateQA Internal Snow Mask;"
- "land_water;mod09A1s: StateQA Internal Snow Mask;"
- "mod35_snow_ice;mod09A1s: StateQA Internal Snow Mask;"
- "pixel_adjacent_to_cloud;mod09A1s: StateQA Internal Snow Mask;"
- "modland_qa;mod13A2: MODIS Land General Quality Assessment;"
- "vi_usefulness;mod13A2: Quality estimation of the pixel;"
- "aerosol_quantity;mod13A2: Quantity range of Aerosol;"
- "pixel_adjacent_to_cloud;mod13A2: if pixel is a cloud neighbour;"
- "brdf_correction_performed;mod13A2: if BRDF correction performed;"
- "mixed_clouds;mod13A2: if pixel mixed with clouds;"
- "land_water;mod13A2: separate land from various water objects;"
- "possible_snow_ice;mod13A2: if snow/ice present in pixel;"
- "possible_shadow;mod13A2: if shadow is present in pixel;"
- "platform;mcd43B2: Quality of BRDF correction performed;"
- "land_water;mcd43B2: Quality of BRDF correction performed;"
- "sun_z_angle_at_local_noon;mcd43B2: Quality of BRDF correction performed;"
- "brdf_correction_performed;mcd43B2q: Quality of BRDF correction performed"
+ desc_qcname = NULL;
+ G_asprintf(&desc_qcname,
+ "adjcorr;%s;"
+ "atcorr;%s;"
+ "cloud;%s;"
+ "data_quality;%s;"
+ "diff_orbit_from_500m;%s;"
+ "modland_qa;%s;"
+ "mandatory_qa_11A1;%s;"
+ "data_quality_flag_11A1;%s;"
+ "emis_error_11A1;%s;"
+ "lst_error_11A1;%s;"
+ "data_quality_flag_11A2;%s;"
+ "emis_error_11A2;%s;"
+ "mandatory_qa_11A2;%s;"
+ "lst_error_11A2;%s;"
+ "aerosol_quantity;%s;"
+ "brdf_correction_performed;%s;"
+ "cirrus_detected;%s;"
+ "cloud_shadow;%s;"
+ "cloud_state;%s;"
+ "internal_cloud_algorithm;%s;"
+ "internal_fire_algorithm;%s;"
+ "internal_snow_mask;%s;"
+ "land_water;%s;"
+ "mod35_snow_ice;%s;"
+ "pixel_adjacent_to_cloud;%s;"
+ "modland_qa;%s;"
+ "vi_usefulness;%s;"
+ "mixed_clouds;%s;"
+ "land_water;%s;"
+ "possible_snow_ice;%s;"
+ "possible_shadow;%s;"
+ "platform;%s;"
+ "land_water;%s;"
+ "sun_z_angle_at_local_noon;%s;"
+ "brdf_correction_performed;%s",
+ _("mod09: Adjacency Correction"),
+ _("mod09: Atmospheric Correction"),
+ _("mod09: Cloud State"),
+ _("mod09: Band-Wise Data Quality Flag"),
+ _("mod09: 250m Band is at Different Orbit than 500m"),
+ _("mod09: MODIS Land General Quality Assessment"),
+ _("mod11A1: MODIS Land General Quality Assessment"),
+ _("mod11A1: Detailed Quality Indications"),
+ _("mod11A1: Average Emissivity Error Classes"),
+ _("mod11A1: Average LST Error Classes"),
+ _("mod11A2: Detailed Quality Indications"),
+ _("mod11A2: Average Emissivity Error Classes"),
+ _("mod11A2: MODIS Land General Quality Assessment"),
+ _("mod11A2: Average LST Error Classes"),
+ _("mod09A1s: StateQA Internal Snow Mask"),
+ _("mod13A2: MODIS Land General Quality Assessment"),
+ _("mod13A2: Quality estimation of the pixel"),
+ _("mod13A2: Quantity range of Aerosol"),
+ _("mod13A2: if pixel is a cloud neighbour"),
+ _("mod13A2: if BRDF correction performed"),
+ _("mod13A2: if pixel mixed with clouds"),
+ _("mod13A2: separate land from various water objects"),
+ _("mod13A2: if snow/ice present in pixel"),
+ _("mod13A2: if shadow is present in pixel"),
+ _("mcd43B2: Quality of BRDF correction performed"),
+ _("mcd43B2q: Quality of BRDF correction performed"));
+ qcname->descriptions = desc_qcname;
qcname->options = "adjcorr,atcorr,cloud,data_quality,diff_orbit_from_500m,modland_qa,mandatory_qa_11A1,data_quality_flag_11A1,emis_error_11A1,lst_error_11A1,data_quality_flag_11A2,emis_error_11A2,mandatory_qa_11A2,lst_error_11A2,aerosol_quantity,brdf_correction_performed,cirrus_detected,cloud_shadow,cloud_state,internal_cloud_algorithm,internal_fire_algorithm,internal_snow_mask,land_water,mod35_snow_ice,pixel_adjacent_to_cloud,modland_qa,vi_usefulness,aerosol_quantity,pixel_adjacent_to_cloud,brdf_correction_performed,mixed_clouds,land_water,possible_snow_ice,possible_shadow,platform,land_water,sun_z_angle_at_local_noon,brdf_correction_performed";
qcname->answer = "modland_qa";
@@ -203,13 +254,17 @@
input_band->required = NO;
input_band->description =
_("Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])");
- input_band->descriptions =_("1;Band 1: Red;"
- "2;Band 2: NIR;"
- "3;Band 3: Blue;"
- "4;Band 4: Green;"
- "5;Band 5: SWIR 1;"
- "6;Band 6: SWIR 2;"
- "7;Band 7: SWIR 3;");
+ desc_input_band = NULL;
+ G_asprintf(&desc_input_band,
+ "1;%s;2;%s;3;%s;4;%s;5;%s;6;%s;7;%s",
+ _("Band 1: Red"),
+ _("Band 2: NIR"),
+ _("Band 3: Blue"),
+ _("Band 4: Green"),
+ _("Band 5: SWIR 1"),
+ _("Band 6: SWIR 2"),
+ _("Band 7: SWIR 3"));
+ input_band->descriptions = desc_input_band;
input_band->options = "1,2,3,4,5,6,7";
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/imagery/i.vi/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -56,6 +56,7 @@
int nrows, ncols;
int row, col;
char *viflag; /*Switch for particular index */
+ char *desc;
struct Option *input1, *input2, *input3, *input4, *input5, *input6,
*input7, *input8, *input9, *input10, *input11, *output;
@@ -94,21 +95,26 @@
input1->type = TYPE_STRING;
input1->required = YES;
input1->description = _("Name of vegetation index");
- input1->descriptions =_("arvi;Atmospherically Resistant Vegetation Indices;"
- "dvi;Difference Vegetation Index;"
- "evi;Enhanced Vegetation Index;"
- "gvi;Green Vegetation Index;"
- "gari;Green atmospherically resistant vegetation index;"
- "gemi;Global Environmental Monitoring Index;"
- "ipvi;Infrared Percentage Vegetation Index;"
- "msavi;Modified Soil Adjusted Vegetation Index;"
- "msavi2;second Modified Soil Adjusted Vegetation Index;"
- "ndvi;Normalized Difference Vegetation Index;"
- "pvi;Perpendicular Vegetation Index;"
- "savi;Soil Adjusted Vegetation Index;"
- "sr;Simple Ratio;"
- "vari;Visible Atmospherically Resistant Index;"
- "wdvi;Weighted Difference Vegetation Index;");
+ desc = NULL;
+ G_asprintf(&desc,
+ "arvi;%s;dvi;%s;evi;%s;gvi;%s;gari;%s;gemi;%s;ipvi;%s;msavi;%s;"
+ "msavi2;%s;ndvi;%s;pvi;%s;savi;%s;sr;%s;vari;%s;wdvi;%s",
+ _("Atmospherically Resistant Vegetation Indices"),
+ _("Difference Vegetation Index"),
+ _("Enhanced Vegetation Index"),
+ _("Green Vegetation Index"),
+ _("Green atmospherically resistant vegetation index"),
+ _("Global Environmental Monitoring Index"),
+ _("Infrared Percentage Vegetation IndexInfrared Percentage Vegetation Index"),
+ _("Modified Soil Adjusted Vegetation Index"),
+ _("second Modified Soil Adjusted Vegetation Index"),
+ _("Normalized Difference Vegetation Index"),
+ _("Perpendicular Vegetation Index"),
+ _("Soil Adjusted Vegetation Index"),
+ _("Simple Ratio"),
+ _("Visible Atmospherically Resistant Index"),
+ _("Weighted Difference Vegetation Index"));
+ input1->descriptions = desc;
input1->options = "arvi,dvi,evi,gvi,gari,gemi,ipvi,msavi,msavi2,ndvi,pvi,savi,sr,vari,wdvi";
input1->answer = "ndvi";
Modified: grass/trunk/misc/m.nviz.image/args.c
--- grass/trunk/misc/m.nviz.image/args.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/misc/m.nviz.image/args.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -815,14 +815,20 @@
void args_fringe(struct GParams *params)
+ char *desc;
params->fringe = G_define_option();
params->fringe->key = "fringe";
params->fringe->type = TYPE_STRING;
params->fringe->options = "nw,ne,sw,se";
- params->fringe->descriptions = _("nw;North-West edge;"
- "ne;North-East edge;"
- "sw;South-West edge;"
- "se;South-East edge");
+ desc = NULL;
+ G_asprintf(&desc,
+ "nw;%s;ne;%s;sw;%s;se;%s",
+ _("North-West edge"),
+ _("North-East edge"),
+ _("South-West edge"),
+ _("South-East edge"));
+ params->fringe->descriptions = desc;
params->fringe->description = _("Fringe edges");
params->fringe->guisection = _("Fringe");
params->fringe->multiple = YES;
Modified: grass/trunk/misc/m.transform/main.c
--- grass/trunk/misc/m.transform/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/misc/m.transform/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -307,6 +307,7 @@
struct Option *grp, *val, *fmt, *xfm_pts;
struct Flag *sum, *rev_flag, *dump_flag;
+ char *desc;
G_gisinit(argv[0]);
@@ -333,15 +334,19 @@
fmt->required = NO;
fmt->multiple = YES;
fmt->options = "idx,src,dst,fwd,rev,fxy,rxy,fd,rd";
- fmt->descriptions = _("idx;point index;"
- "src;source coordinates;"
- "dst;destination coordinates;"
- "fwd;forward coordinates (destination);"
- "rev;reverse coordinates (source);"
- "fxy;forward coordinates difference (destination);"
- "rxy;reverse coordinates difference (source);"
- "fd;forward error (destination);"
- "rd;reverse error (source)");
+ desc = NULL;
+ G_asprintf(&desc,
+ "idx;%s;src;%s;dst;%s;fwd;%s;rev;%s;fxy;%s;rxy;%s;fd;%s;rd;%s",
+ _("point index"),
+ _("source coordinates"),
+ _("destination coordinates"),
+ _("forward coordinates (destination)"),
+ _("reverse coordinates (source)"),
+ _("forward coordinates difference (destination)"),
+ _("reverse coordinates difference (source)"),
+ _("forward error (destination)"),
+ _("reverse error (source)"));
+ fmt->descriptions = desc;
fmt->answer = "fd,rd";
fmt->description = _("Output format");
Modified: grass/trunk/raster/r.report/parse.c
--- grass/trunk/raster/r.report/parse.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/raster/r.report/parse.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -9,6 +9,7 @@
char pl_desc[256];
char pw_desc[256];
int i;
+ char *desc;
struct
struct Option *cell;
@@ -43,9 +44,17 @@
parms.units->required = NO;
parms.units->multiple = YES;
parms.units->description = _("Units");
- parms.units->descriptions =
- _("mi;miles;me;meters;k;kilometers;a;acres;"
- "h;hectares;c;cell counts;p;percent cover");
+ desc = NULL;
+ G_asprintf(&desc,
+ "mi;%s;me;%s;k;%s;a;%s;h;%s;c;%s;p;%s",
+ _("miles"),
+ _("meters"),
+ _("kilometers"),
+ _("acres"),
+ _("hectares"),
+ _("cell counts"),
+ _("percent cover"));
+ parms.units->descriptions = desc;
parms.units->options = "mi,me,k,a,h,c,p";
parms.units->guisection = _("Output settings");
Modified: grass/trunk/raster/r.usler/main.c
--- grass/trunk/raster/r.usler/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/raster/r.usler/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -34,6 +34,7 @@
struct Option *input1, *input2, *output;
+ char *desc;
@@ -67,10 +68,14 @@
input1->description = _("Name of USLE R equation");
input1->options = "roose, morgan, foster, elswaify";
- input1->descriptions = _("roose;Roosle (1975);"
- "morgan;Morgan (1974);"
- "foster;Foster (1981);"
- "elswaify;El-Swaify (1985)");
+ desc = NULL;
+ G_asprintf(&desc,
+ "roose;%s;morgan;%s;foster;%s;elswaify;%s",
+ _("Roosle (1975)"),
+ _("Morgan (1974)"),
+ _("Foster (1981)"),
+ _("El-Swaify (1985)"));
input1->answer = "morgan";
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.build.polylines/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -94,6 +94,7 @@
struct Option *output;
struct Option *cats;
struct Option *type_opt;
+ char *desc;
int polyline;
int *lines_visited;
@@ -123,9 +124,13 @@
cats->type = TYPE_STRING;
cats->description = _("Category number mode");
cats->options = "no,first,multi";
- cats->descriptions = _("no;Do not assign any category number to polyline;"
- "first;Assign category number of first line to polyline;"
- "multi;Assign multiple category numbers to polyline");
+ desc = NULL;
+ G_asprintf(&desc,
+ "no;%s;first;%s;multi;%s",
+ _("Do not assign any category number to polyline"),
+ _("Assign category number of first line to polyline"),
+ _("Assign multiple category numbers to polyline"));
+ cats->descriptions = desc;
cats->answer = "no";
Modified: grass/trunk/vector/v.category/main.c
--- grass/trunk/vector/v.category/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.category/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -68,6 +68,7 @@
struct Flag *shell;
FREPORT **freps;
int nfreps, rtype, fld;
+ char *desc;
module = G_define_module();
G_add_keyword(_("vector"));
@@ -98,13 +99,23 @@
option_opt->multiple = NO;
option_opt->options = "add,del,chlayer,sum,report,print,transfer";
option_opt->description = _("Action to be done");
- option_opt->descriptions = _("add;add a new category;"
- "del;delete category (-1 to delete all categories of given layer);"
- "chlayer;change layer number (e.g. layer=3,1 changes layer 3 to layer 1);"
- "sum;add the value specified by cat option to the current category value;"
- "transfer;copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3);"
- "report;print report (statistics), in shell style: layer type count min max;"
- "print;print category values, more cats in the same layer are separated by '/'");
+ desc = NULL;
+ G_asprintf(&desc,
+ "add;%s;"
+ "del;%s;"
+ "chlayer;%s;"
+ "sum;%s;"
+ "transfer;%s;"
+ "report;%s;"
+ "print;%s",
+ _("add a new category"),
+ _("delete category (-1 to delete all categories of given layer)"),
+ _("change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"),
+ _("add the value specified by cat option to the current category value"),
+ _("copy values from one layer to another (e.g. layer=1,2,3 copies values from layer 1 to layer 2 and 3)"),
+ _("print report (statistics), in shell style: layer type count min max"),
+ _("print category values, more cats in the same layer are separated by '/'"));
+ option_opt->descriptions = desc;
cat_opt = G_define_standard_option(G_OPT_V_CAT);
cat_opt->answer = "1";
Modified: grass/trunk/vector/v.class/main.c
--- grass/trunk/vector/v.class/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.class/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -39,6 +39,7 @@
double finfo;
double *classbreaks, min, max, *data;
struct GASTATS stats;
+ char *desc;
@@ -64,11 +65,19 @@
- "qua;quantiles;"
-/* "dis;discontinuities"); currently disabled because of bugs*/
+ desc = NULL;
+ G_asprintf(&desc,
+ "int;%s;"
+ "std;%s;"
+ "qua;%s;"
+ "equ;%s",
+ /* "dis;%s" */
+ _("quantiles"),
+ /* _("discontinuities"));currently disabled because of bugs */
nbclass_opt->key = "nbclasses";
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.distance/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -47,6 +47,7 @@
struct {
struct Flag *print, *all;
} flag;
+ char *desc;
struct Map_info From, To, Out, *Outp;
int from_type, to_type, from_field, to_field;
double max, min;
@@ -148,23 +149,32 @@
opt.upload->options = "cat,dist,to_x,to_y,to_along,to_angle,to_attr";
opt.upload->description =
_("Values describing the relation between two nearest features");
- opt.upload->descriptions =
- _("cat;category of the nearest feature;"
- "dist;minimum distance to nearest feature;"
- "to_x;x coordinate of the nearest point on the 'to' feature;"
- "to_y;y coordinate of the nearest point on the 'to' feature;"
- "to_along;distance to the nearest point on the 'to' feature along "
- "that linear feature;"
- "to_angle;angle along the nearest linear feature in the 'to' map, "
- "measured CCW from the +x axis, in radians, between -Pi and Pi "
- "inclusive;"
- "to_attr;attribute of nearest feature given by to_column option");
+ desc = NULL;
+ G_asprintf(&desc,
+ "cat;%s;"
+ "dist;%s;"
+ "to_x;%s;"
+ "to_y;%s;"
+ "to_along;%s;"
+ "to_angle;%s;"
+ "to_attr;%s",
+ _("category of the nearest feature"),
+ _("minimum distance to nearest feature"),
+ _("x coordinate of the nearest point on the 'to' feature"),
+ _("y coordinate of the nearest point on the 'to' feature"),
+ _("distance to the nearest point on the 'to' feature along "
+ "that linear feature"),
+ _("angle along the nearest linear feature in the 'to' map, "
+ "measured CCW from the +x axis, in radians, between -Pi and Pi "
+ "inclusive"),
+ _("attribute of nearest feature given by to_column option"));
/* "from_x - x coordinate of the nearest point on 'from' feature;" */
/* "from_y - y coordinate of the nearest point on 'from' feature;" */
/* "from_along - distance to the nearest point on 'from' feature along linear feature;" */
/* "from_angle - angle between the linear feature in 'to' map and the +x "
"axis, at the location of point/centroid in 'from' map, CCW, in "
"radians, between -Pi and Pi inclusive;" */
+ opt.upload->descriptions = desc;
opt.column = G_define_standard_option(G_OPT_DB_COLUMN);
opt.column->required = YES;
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.drape/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -114,6 +114,7 @@
struct Option *in_opt, *out_opt, *type_opt, *rast_opt, *method_opt,
*scale_opt, *where_opt, *layer_opt, *null_opt;
+ char *desc;
struct Map_info In, Out;
struct line_pnts *Points;
@@ -165,9 +166,13 @@
method_opt->multiple = NO;
method_opt->options = "nearest,bilinear,cubic";
method_opt->answer = "nearest";
- method_opt->descriptions = "nearest;nearest neighbor;"
- "bilinear;bilinear interpolation;"
- "cubic;cubic convolution interpolation;";
+ desc = NULL;
+ G_asprintf(&desc,
+ "nearest;%s;bilinear;%s;cubic;%s",
+ _("nearest neighbor"),
+ _("bilinear interpolation"),
+ _("cubic convolution interpolation"));
+ method_opt->descriptions = desc;
method_opt->description = _("Sampling method");
scale_opt = G_define_option();
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.edit/args.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -13,8 +13,8 @@
int parser(int argc, char *argv[], struct GParams *params,
enum mode *action_mode)
- char *desc;
+ char *desc_tool, *desc_query, *desc_snap;
/* parameters */
params->map = G_define_standard_option(G_OPT_V_MAP);
params->map->label = _("Name of vector map to edit");
@@ -34,8 +34,8 @@
params->tool->required = YES;
params->tool->multiple = NO;
params->tool->description = _("Tool");
- desc = NULL;
- G_asprintf(&desc,
+ desc_tool = NULL;
+ G_asprintf(&desc_tool,
"create;%s;"
"add;%s;"
"delete;%s;"
@@ -77,7 +77,7 @@
"vector lines)"),
_("Change feature type (point<->centroid, line<->boundary)"),
_("Delete selected areas from vector map (based on selected centroids)"));
- params->tool->descriptions = desc;
+ params->tool->descriptions = desc_tool;
params->tool->options = "create,add,delete,copy,move,flip,catadd,catdel,"
"merge,break,snap,connect,chtype,"
"vertexadd,vertexdel,vertexmove,areadel,zbulk,select";
@@ -153,10 +153,14 @@
params->query->description =
_("For 'shorter' use negative threshold value, "
"positive value for 'longer'");
- params->query->descriptions =
- _("length;Select only lines or boundaries shorter"
- "/longer than threshold distance;"
- "dangle;Select dangles shorter/longer than " "threshold distance");
+ desc_query = NULL;
+ G_asprintf(&desc_query,
+ "length;%s;"
+ "dangle;%s",
+ _("Select only lines or boundaries shorter"
+ "/longer than threshold distance"),
+ _("Select dangles shorter/longer than threshold distance"));
+ params->query->descriptions = desc_query;
params->query->guisection = _("Selection");
params->bmaps = G_define_standard_option(G_OPT_V_MAPS);
@@ -170,9 +174,15 @@
params->snap->options = "no,node,vertex";
params->snap->description =
_("Snap added or modified features in the given threshold to the nearest existing feature");
- params->snap->descriptions =
- _("no;Not apply snapping;" "node;Snap only to node;"
- "vertex;Allow snapping also to vertex");
+ desc_snap = NULL;
+ G_asprintf(&desc_snap,
+ "no;%s;"
+ "node;%s;"
+ "vertex;%s",
+ _("Not apply snapping"),
+ _("Snap only to node"),
+ _("Allow snapping also to vertex"));
+ params->snap->descriptions = desc_snap;
params->snap->answer = "no";
params->zbulk = G_define_option();
Modified: grass/trunk/vector/v.in.ascii/main.c
--- grass/trunk/vector/v.in.ascii/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.in.ascii/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -38,6 +38,7 @@
*region_flag;
char *table;
char *fs;
+ char *desc;
int zcoor = WITHOUT_Z, make_table;
struct Map_info Map;
@@ -63,8 +64,12 @@
format_opt->required = NO;
format_opt->multiple = NO;
format_opt->options = "point,standard";
- format_opt->descriptions = _("point;simple x,y[,z] list;"
- "standard;GRASS vector ASCII format");
+ desc = NULL;
+ G_asprintf(&desc,
+ "point;%s;standard;%s",
+ _("simple x,y[,z] list"),
+ _("GRASS vector ASCII format"));
+ format_opt->descriptions = desc;
format_opt->answer = "point";
format_opt->description = _("Input file format");
format_opt->guisection = _("Input format");
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.in.ogr/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -59,6 +59,8 @@
struct Flag *over, *extend, *formats, *tolower, *no_import;
} flag;
+ char *desc;
int i, j, layer, arg_s_num, nogeom, ncnames;
float xmin, ymin, xmax, ymax;
int ncols = 0, type;
@@ -176,11 +178,14 @@
param.type->options = "point,line,boundary,centroid";
param.type->answer = "";
param.type->description = _("Optionally change default input type");
- param.type->descriptions =
- _("point;import area centroids as points;"
- "line;import area boundaries as lines;"
- "boundary;import lines as area boundaries;"
- "centroid;import points as centroids");
+ desc = NULL;
+ G_asprintf(&desc,
+ "point;%s;line;%s;boundary;%s;centroid;%s",
+ _("import area centroids as points"),
+ _("import area boundaries as lines"),
+ _("import lines as area boundaries"),
+ _("import points as centroids"));
+ param.type->descriptions = desc;
param.type->guisection = _("Selection");
param.snap = G_define_option();
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.kernel/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -78,6 +78,7 @@
struct Option *stddev_opt, *dsize_opt, *segmax_opt, *netmax_opt,
*multip_opt, *node_opt, *kernel_opt;
struct Flag *flag_o, *flag_q, *flag_normalize, *flag_multiply;
+ char *desc;
struct Map_info In, Net, Out;
int fdout = -1, maskfd = -1;
@@ -165,9 +166,12 @@
node_opt->description = _("Node method");
node_opt->options = "none,split";
node_opt->answer = "none";
- node_opt->descriptions =
- _("none;No method applied at nodes with more than 2 arcs;"
- "split;Equal split (Okabe 2009) applied at nodes;");
+ desc = NULL;
+ G_asprintf(&desc,
+ "none;%s;split;%s",
+ _("No method applied at nodes with more than 2 arcs"),
+ _("Equal split (Okabe 2009) applied at nodes"));
+ node_opt->descriptions = desc;
kernel_opt = G_define_option();
kernel_opt->key = "kernel";
Modified: grass/trunk/vector/v.mkgrid/main.c
--- grass/trunk/vector/v.mkgrid/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.mkgrid/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -48,6 +48,7 @@
struct Flag *points_fl;
int points_p;
+ char *desc;
struct line_cats *Cats;
@@ -85,8 +86,12 @@
position_opt->options = "region,coor";
position_opt->answer = "region";
position_opt->description = _("Where to place the grid");
- position_opt->descriptions = _("region;current region;"
- "coor;use 'coor' and 'box' options");
+ desc = NULL;
+ G_asprintf(&desc,
+ "region;%s;coor;%s",
+ _("current region"),
+ _("use 'coor' and 'box' options"));
+ position_opt->descriptions = desc;
coord = G_define_option();
coord->key = "coor";
Modified: grass/trunk/vector/v.net/args.c
--- grass/trunk/vector/v.net/args.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.net/args.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -7,6 +7,8 @@
void define_options(struct opt *opt)
+ char *desc;
opt->input = G_define_standard_option(G_OPT_V_INPUT);
opt->input->required = NO;
opt->input->label = _("Name of input vector line map (arcs)");
@@ -32,22 +34,20 @@
opt->action->multiple = NO;
opt->action->options = "nodes,connect,arcs,report,nreport";
opt->action->description = _("Operation to be performed");
- opt->action->descriptions =
- _("nodes;"
- "new point is placed on each node (line end) "
- "if doesn't exist;"
- "connect;"
- "connect still unconnected points to vector network "
- "by inserting new line(s);"
- "arcs;"
- "new line is created from start point "
- "to end point;"
- "report;"
- "print to standard output "
- "{line_category start_point_category end_point_category};"
- "nreport;"
- "{point_category line_category[,line_category...]}");
+ desc = NULL;
+ G_asprintf(&desc,
+ "nodes;%s;connect;%s;arcs;%s;report;%s;nreport;%s",
+ _("new point is placed on each node (line end) "
+ "if doesn't exist"),
+ _("connect still unconnected points to vector network "
+ "by inserting new line(s)"),
+ _("new line is created from start point "
+ "to end point"),
+ _("print to standard output "
+ "{line_category start_point_category end_point_category}"),
+ "{point_category line_category[,line_category...]}"));
+ opt->action->descriptions = desc;
opt->afield_opt = G_define_standard_option(G_OPT_V_FIELD);
opt->afield_opt->key = "alayer";
Modified: grass/trunk/vector/v.net.bridge/main.c
--- grass/trunk/vector/v.net.bridge/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.net.bridge/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -32,6 +32,7 @@
struct Option *map_in, *map_out;
struct Option *afield_opt, *nfield_opt, *abcol, *afcol, *ncol,
*method_opt;
+ char *desc;
int with_z;
int afield, nfield, mask_type;
dglGraph_s *graph;
@@ -91,8 +92,12 @@
method_opt->required = YES;
method_opt->options = "bridge,articulation";
- method_opt->descriptions = _("bridge;Finds bridges;"
- "articulation;Finds articulation points;");
+ desc = NULL;
+ G_asprintf(&desc,
+ "bridge;%s;articulation;%s",
+ _("Finds bridges"),
+ _("Finds articulation points"));
method_opt->description = _("Feature type");
/* options and flags parser */
Modified: grass/trunk/vector/v.net.components/main.c
--- grass/trunk/vector/v.net.components/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.net.components/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -56,6 +56,7 @@
dglGraph_s *graph;
int *component, nnodes, type, i, nlines, components, j, max_cat;
char buf[2000], *covered;
+ char *desc;
/* Attribute table */
dbString sql;
@@ -116,8 +117,12 @@
method_opt->options = "weak,strong";
- method_opt->descriptions = _("weak;Weakly connected components;"
- "strong;Strongly connected components;");
+ desc = NULL;
+ G_asprintf(&desc,
+ "weak;%s;strong;%s",
+ _("Weakly connected components"),
+ _("Strongly connected components"));
method_opt->description = _("Type of components");
add_f = G_define_flag();
Modified: grass/trunk/vector/v.out.ascii/args.c
--- grass/trunk/vector/v.out.ascii/args.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.out.ascii/args.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -16,6 +16,8 @@
*field_opt, *column_opt, *where_opt, *cats_opt, *type_opt;
struct Flag *old_flag, *header_flag, *region_flag;
+ char * desc;
input_opt = G_define_standard_option(G_OPT_V_INPUT);
@@ -49,9 +51,13 @@
format_opt->options = "point,standard,wkt";
format_opt->description = _("Output format");
- format_opt->descriptions = _("point;Simple point format (point per row);"
- "standard;GRASS ASCII vector format;"
- "wkt;OGC well-known text;");
+ desc = NULL;
+ G_asprintf(&desc,
+ "point;%s;standard;%s;wkt;%s",
+ _("Simple point format (point per row)"),
+ _("GRASS ASCII vector format"),
+ _("OGC well-known text"));
delim_opt = G_define_standard_option(G_OPT_F_SEP);
delim_opt->description = _("Field separator (points mode)");
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.overlay/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -40,6 +40,7 @@
struct Map_info In[2], Out;
+ char *desc;
struct field_info *Fi = NULL;
char buf[1000];
@@ -96,13 +97,16 @@
"of operation 'ainput operator binput' is true. "
"Input feature is considered to be true, if "
"category of given layer is defined.");
- operator_opt->descriptions =
- _("and;also known as 'intersection' in GIS;"
- "or;also known as 'union' in GIS (only for atype=area);"
- "not;features from ainput not overlayed by features " "from binput;"
- "xor;features from either ainput or binput but "
- "not those from ainput overlayed by binput (only "
- "for atype=area)");
+ desc = NULL;
+ G_asprintf(&desc,
+ "and;%s;or;%s;not;%s;xor;%s",
+ _("also known as 'intersection' in GIS"),
+ _("also known as 'union' in GIS (only for atype=area)"),
+ _("features from ainput not overlayed by features from binput"),
+ _("features from either ainput or binput but "
+ "not those from ainput overlayed by binput (only "
+ "for atype=area)"));
+ operator_opt->descriptions = desc;
out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
Modified: grass/trunk/vector/v.parallel/main.c
--- grass/trunk/vector/v.parallel/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.parallel/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -35,6 +35,8 @@
struct line_pnts *Points, *Points2, *oPoints, **iPoints;
+ char *desc;
int line, nlines, inner_count, j;
int layer;
@@ -87,10 +89,13 @@
side_opt->multiple = NO;
side_opt->options = "left,right,both";
side_opt->description = _("Side");
- side_opt->descriptions =
- _("left;Parallel line is on the left;"
- "right;Parallel line is on the right;"
- "both;Parallel lines on both sides");
+ desc = NULL;
+ G_asprintf(&desc,
+ "left;%s;right;%s;both;%s",
+ _("Parallel line is on the left"),
+ _("Parallel line is on the right"),
+ _("Parallel lines on both sides"));
+ side_opt->descriptions = desc;
tol_opt = G_define_option();
tol_opt->key = "tolerance";
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.select/args.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -6,6 +6,8 @@
void parse_options(struct GParm *parm, struct GFlag *flag)
+ char *desc;
parm->input[0] = G_define_standard_option(G_OPT_V_INPUT);
parm->input[0]->description = _("Name of input vector map (A)");
parm->input[0]->key = "ainput";
@@ -47,24 +49,40 @@
_("A feature is written to output if the result of operation 'ainput operator binput' is true. "
"An input feature is considered to be true, if category of given layer is defined.");
parm->operator->answer = "overlap";
+ desc = NULL;
#ifndef HAVE_GEOS
parm->operator->options = "overlap";
- parm->operator->descriptions = _("overlap;features partially or completely overlap");
+ G_asprintf(&desc,
+ "overlap;%s",
+ _("features partially or completely overlap"));
+ parm->operator->descriptions = desc;
parm->relate = NULL;
#else
+ G_asprintf(&desc,
+ "overlap;%s;"
+ "equals;%s;"
+ "disjoint;%s;"
+ "intersects;%s;"
+ "touches;%s;"
+ "crosses;%s;"
+ "within;%s;"
+ "contains;%s;"
+ "overlaps;%s;"
+ "relate;%s;",
+ _("features partially or completely overlap"),
+ _("features are spatially equals (using GEOS)"),
+ _("features do not spatially intersect (using GEOS)"),
+ _("features spatially intersect (using GEOS)"),
+ _("features spatially touches (using GEOS)"),
+ _("features spatially crosses (using GEOS)"),
+ _("feature A is completely inside feature B (using GEOS)"),
+ _("feature B is completely inside feature A (using GEOS)"),
+ _("features spatially overlap (using GEOS)"),
+ _("feature A is spatially related to feature B (using GEOS, "
+ "requires 'relate' option)"));
parm->operator->options = "overlap,equals,disjoint,intersects,touches,crosses,within,contains,overlaps,relate";
- parm->operator->descriptions = _("overlap;features partially or completely overlap;"
- "equals;features are spatially equals (using GEOS);"
- "disjoint;features do not spatially intersect (using GEOS);"
- "intersects;features spatially intersect (using GEOS);"
- "touches;features spatially touches (using GEOS);"
- "crosses;features spatially crosses (using GEOS);"
- "within;feature A is completely inside feature B (using GEOS);"
- "contains;feature B is completely inside feature A (using GEOS);"
- "overlaps;features spatially overlap (using GEOS);"
- "relate;feature A is spatially related to feature B (using GEOS, "
- "requires 'relate' option);");
parm->relate = G_define_option();
parm->relate->key = "relate";
Modified: grass/trunk/vector/v.to.db/parse.c
--- grass/trunk/vector/v.to.db/parse.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.to.db/parse.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -27,6 +27,7 @@
struct Flag *p, *s, *t;
} flags;
+ char *desc;
parms.vect = G_define_standard_option(G_OPT_V_MAP);
@@ -54,26 +55,43 @@
parms.option->options =
"cat,area,compact,fd,perimeter,length,count,coor,start,end,sides,query,slope,sinuous,azimuth";
parms.option->description = _("Value to upload");
- parms.option->descriptions =
- "cat;insert new row for each category if doesn't exist yet;"
- "area;area size;"
- "compact;compactness of an area, calculated as \n"
- " compactness = perimeter / (2 * sqrt(PI * area));"
- "fd;fractal dimension of boundary defining a polygon, calculated as \n"
- " fd = 2 * (log(perimeter) / log(area));"
- "perimeter;perimeter length of an area;"
- "length;line length;"
- "count;number of features for each category;"
- "coor;point coordinates, X,Y or X,Y,Z;"
- "start;line/boundary starting point coordinates, X,Y or X,Y,Z;"
- "end;line/boundary end point coordinates, X,Y or X,Y,Z;"
- "sides;categories of areas on the left and right side of the boundary, "
- "'qlayer' is used for area category;"
- "query;result of a database query for all records of the geometry"
- "(or geometries) from table specified by 'qlayer' option;"
- "slope;slope steepness of vector line or boundary;"
- "sinuous;line sinuousity, calculated as line length / distance between end points;"
- "azimuth;line azimuth, calculated as angle between North direction and endnode direction at startnode";
+ desc = NULL;
+ G_asprintf(&desc,
+ "cat;%s;"
+ "area;%s;"
+ "compact;%s;"
+ "fd;%s;"
+ "perimeter;%s;"
+ "length;%s;"
+ "count;%s;"
+ "coor;%s;"
+ "start;%s;"
+ "end;%s;"
+ "sides;%s;"
+ "query;%s;"
+ "slope;%s;"
+ "sinuous;%s;"
+ "azimuth;%s;",
+ _("insert new row for each category if doesn't exist yet"),
+ _("area size"),
+ _("compactness of an area, calculated as \n"
+ " compactness = perimeter / (2 * sqrt(PI * area))"),
+ _("fractal dimension of boundary defining a polygon, calculated as \n"
+ " fd = 2 * (log(perimeter) / log(area))"),
+ _("perimeter length of an area"),
+ _("line length"),
+ _("number of features for each category"),
+ _("point coordinates, X,Y or X,Y,Z"),
+ _("line/boundary starting point coordinates, X,Y or X,Y,Z"),
+ _("line/boundary end point coordinates, X,Y or X,Y,Z"),
+ _("categories of areas on the left and right side of the boundary, "
+ "'qlayer' is used for area category"),
+ _("result of a database query for all records of the geometry"
+ "(or geometries) from table specified by 'qlayer' option"),
+ _("slope steepness of vector line or boundary"),
+ _("line sinuousity, calculated as line length / distance between end points"),
+ _("line azimuth, calculated as angle between North direction and endnode direction at startnode"));
+ parms.option->descriptions = desc;
parms.units = G_define_standard_option(G_OPT_M_UNITS);
Modified: grass/trunk/vector/v.to.rast/main.c
--- grass/trunk/vector/v.to.rast/main.c 2012-08-12 10:33:51 UTC (rev 52636)
+++ grass/trunk/vector/v.to.rast/main.c 2012-08-12 14:29:08 UTC (rev 52637)
@@ -33,6 +33,7 @@
*val_opt, *rgbcol_opt, *label_opt, *type_opt;
int nrows, use, value_type, type;
double value;
+ char *desc;
G_gisinit(argv[0]);
@@ -61,11 +62,15 @@
use_opt->multiple = NO;
use_opt->options = "attr,cat,val,z,dir";
use_opt->description = _("Source of raster values");
- use_opt->descriptions = _("attr;read values from attribute table;"
- "cat;use category values;"
- "val;use value specified by value option;"
- "z;use z coordinate (points or contours only);"
- "dir;output as flow direction (lines only)");
+ desc = NULL;
+ G_asprintf(&desc,
+ "attr;%s;cat;%s;val;%s;z;%s;dir;%s",
+ _("read values from attribute table"),
+ _("use category values"),
+ _("use value specified by value option"),
+ _("use z coordinate (points or contours only)"),
+ _("output as flow direction (lines only)"));
+ use_opt->descriptions = desc;
col = G_define_standard_option(G_OPT_DB_COLUMN);
col->key = "attrcolumn";
