[GRASS-SVN] r52664 - grass/trunk/lib/vector/rtree
    svn_grass at osgeo.org
    Mon Aug 13 06:33:36 PDT 2012
Author: mmetz
Date: 2012-08-13 06:33:35 -0700 (Mon, 13 Aug 2012)
New Revision: 52664
   grass/trunk/lib/vector/rtree/index.c
rtree: doxygenize
Modified: grass/trunk/lib/vector/rtree/index.c
--- grass/trunk/lib/vector/rtree/index.c	2012-08-13 13:21:16 UTC (rev 52663)
+++ grass/trunk/lib/vector/rtree/index.c	2012-08-13 13:33:35 UTC (rev 52664)
@@ -1,36 +1,63 @@
+   \file lib/vector/rtree/index.c
-* MODULE:       R-Tree library
-* AUTHOR(S):    Antonin Guttman - original code
-*               Daniel Green (green at superliminal.com) - major clean-up
-*                               and implementation of bounding spheres
-*               Markus Metz - file-based and memory-based R*-tree
-* PURPOSE:      Multidimensional index
-* COPYRIGHT:    (C) 2010 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*               License (>=v2). Read the file COPYING that comes with GRASS
-*               for details.
+   \brief R-Tree library - Multidimensional index
+   Higher level functions for managing R*-Trees.
+   (C) 2010-2012 by the GRASS Development Team
+   This program is free software under the
+   GNU General Public License (>=v2).
+   Read the file COPYING that comes with GRASS
+   for details.
+   \author Antonin Guttman - original code
+   \author Daniel Green (green at superliminal.com) - major clean-up
+	       and implementation of bounding spheres
+   \author Markus Metz - file-based and memory-based R*-tree
+/* Read these articles first before attempting to modify the code
+ * R-Tree reference:
+ * Guttman, A. (1984). "R-Trees: A Dynamic Index Structure for Spatial
+ * Searching". Proceedings of the 1984 ACM SIGMOD international
+ * conference on Management of data - SIGMOD '84. pp. 47.
+ * DOI:10.1145/602259.602266
+ * ISBN 0897911288
+ * R*-Tree reference:
+ * Beckmann, N.; Kriegel, H. P.; Schneider, R.; Seeger, B. (1990).
+ * "The R*-tree: an efficient and robust access method for points and
+ * rectangles". Proceedings of the 1990 ACM SIGMOD international
+ * conference on Management of data - SIGMOD '90. pp. 322.
+ * DOI:10.1145/93597.98741
+ * ISBN 0897913655
 #include <stdlib.h>
 #include <sys/types.h>
 #include <unistd.h>
 #include <assert.h>
 #include <grass/gis.h>
 #include "index.h"
-//#include "card.h"
- * Make a new index, empty.
- * fp pointer to file holding index, file must be opened as w+
- * rootpos postion of rootnode (past any header info)
- * ndims number of dimensions
- * returns pointer to RTree structure
+  \brief Create new empty R*-Tree
+  This method creates a new RTree, either in memory (fd < 0) or in file.
+  If the file descriptor is positive, the corresponding file must have
+  been opened for reading and writing.
+  This method must also be called if an existing tree previously saved
+  to file is going to be accessed.
+  \param fd file descriptor to hold data, negative toggles memory mode
+  \param rootpos offset in file to root node (past any header info)
+  \param ndims number of dimensions for the new tree: min 2, max 20
+  \return pointer to new RTree structure
 struct RTree *RTreeCreateTree(int fd, off_t rootpos, int ndims)
     struct RTree *new_rtree;
@@ -154,6 +181,19 @@
     return new_rtree;
+  \brief Destroy an R*-Tree
+  This method releases all memory allocated to a RTree. It deletes all
+  rectangles and all memory allocated for internal support data.
+  Note that for a file-based RTree, the file is not deleted and not
+  closed. The file can thus be used to permanently store an RTree.
+  \param t pointer to RTree structure
+  \return nothing
 void RTreeDestroyTree(struct RTree *t)
     int i, j;
@@ -202,10 +242,23 @@
     return;
+  \brief Search an R*-Tree
+  Search in an RTree for all data retangles that overlap or touch the
+  argument rectangle.
+  Return the number of qualifying data rectangles.
+  The search stops if the SearchHitCallBack function returns 0 (zero)
+  or if there are no more qualifying data rectangles.
+  \param r pointer to rectangle to use for searching
+  \param shcb Search Hit CallBack function
+  \param cbarg custom pointer used as argument for the shcb fn
+  \return number of qualifying data rectangles
- * Search in an index tree for all data retangles that
- * overlap or touch the argument rectangle.
- * Return the number of qualifying data rects.
  * add option to select operator to select rectangles ?
  * current: overlap
@@ -221,12 +274,15 @@
     return t->search_rect(t, r, shcb, cbarg);
- * Insert a data rectangle into an RTree index structure.
- * r pointer to rectangle
- * tid data id stored with rectangle, must be > 0
- * t RTree where rectangle should be inserted
+  \brief Insert an item into a R*-Tree
+  \param tid data id stored with rectangle, must be > 0
 int RTreeInsertRect(struct RTree_Rect *r, int tid, struct RTree *t)
     union RTree_Child newchild;
@@ -239,18 +295,21 @@
     return t->insert_rect(r, newchild, 0, t);
- * Delete a data rectangle from an index structure.
- * Pass in a pointer to a Rect, the tid of the record, ptr RTree.
- * Returns 1 if record not found, 0 if success.
- * RTreeDeleteRect1 provides for eliminating the root.
- * RTreeDeleteRect() should be called by external functions instead of
- * RTreeDeleteRect1()
- * wrapper for RTreeDeleteRect1 not really needed, but restricts
- * compile warnings to rtree lib
- * this way it's easier to fix if necessary?
+  \brief Delete an item from a R*-Tree
+  This method deletes an item from the RTree. The rectangle passed to
+  this method does not need to be the exact rectangle, the only
+  requirement is that this rectangle overlaps with the rectangle to
+  be deleted. The rectangle to be deleted is identified by its id.
+  \param tid id of the data to be deleted, must be > 0
+  \return 0 on success
+  \return 1 if data item not found
 int RTreeDeleteRect(struct RTree_Rect *r, int tid, struct RTree *t)
     union RTree_Child child;
@@ -262,6 +321,12 @@
     return t->delete_rect(r, child, t);
+ *    internally used functions    *
  * Allocate space for a node in the list used in DeleteRect to
  * store Nodes that are too empty.
@@ -290,7 +355,7 @@
- * Free ListBranch
+ * Free ListBranch, used by R*-type forced reinsertion
 void RTreeFreeListBranch(struct RTree_ListBranch *p)
