[GRASS-SVN] r52680 - in grass/trunk/gui/wxpython: dbmgr gui_core
svn_grass at osgeo.org
Thu Aug 16 02:12:38 PDT 2012
Author: martinl
Date: 2012-08-16 02:12:37 -0700 (Thu, 16 Aug 2012)
New Revision: 52680
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/dbmgr/dialogs.py
grass/trunk/gui/wxpython/gui_core/widgets.py
wxGUI/ATM: change layout for 'SQL Query'
new dialog to 'add new column'
DeletePage() RemovePage() implemeneted for GNotebook
various minor changes
patch provided by Stepan Turek (GSoC 2012)
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2012-08-16 07:14:49 UTC (rev 52679)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2012-08-16 09:12:37 UTC (rev 52680)
@@ -47,7 +47,7 @@
from gui_core.dialogs import CreateNewVector
from dbmgr.vinfo import VectorDBInfo, unicodeValue, createDbInfoDesc
from core.debug import Debug
-from dbmgr.dialogs import ModifyTableRecord
+from dbmgr.dialogs import ModifyTableRecord, AddColumnDialog
from core.settings import UserSettings
class Log:
@@ -67,13 +67,15 @@
listmix.ColumnSorterMixin):
"""!Support virtual list class for Attribute Table Manager (browse page)
- def __init__(self, parent, log, dbMgrData, layer):
+ def __init__(self, parent, log, dbMgrData, layer, pages):
# initialize variables
self.parent = parent
self.log = log
self.dbMgrData = dbMgrData
self.mapDBInfo = self.dbMgrData['mapDBInfo']
self.layer = layer
+ self.pages = pages
self.fieldCalc = None
self.columns = {} # <- LoadData()
@@ -360,6 +362,7 @@
popupMenu = wx.Menu()
if not hasattr (self, "popupID1"):
+ #TODO put to dict
self.popupID1 = wx.NewId()
self.popupID2 = wx.NewId()
self.popupID3 = wx.NewId()
@@ -382,8 +385,17 @@
popupMenu.AppendMenu(self.popupID3, _("Calculate (only numeric columns)"),
subMenu)
popupMenu.Append(self.popupID13, text = _("Field calculator"))
+ if not self.pages['manageTable']:
+ popupMenu.AppendSeparator()
+ self.popupID14 = wx.NewId()
+ popupMenu.Append(self.popupID14, text = _("Add column"))
+ if not self.dbMgrData['editable']:
+ popupMenu.Enable(self.popupID14, False)
- popupMenu.Enable(self.popupID13, False)
+ popupMenu.Enable(self.popupID13, False)
if not self.dbMgrData['editable'] or \
self.columns[self.GetColumn(self._col).GetText()]['ctype'] not in (types.IntType, types.FloatType):
popupMenu.Enable(self.popupID3, False)
@@ -401,6 +413,8 @@
self.Bind (wx.EVT_MENU, self.OnColumnSortAsc, id = self.popupID10)
self.Bind (wx.EVT_MENU, self.OnColumnSortDesc, id = self.popupID2)
self.Bind(wx.EVT_MENU, self.OnFiledCalculator, id = self.popupID13)
+ self.Bind(wx.EVT_MENU, self.OnAddColumn, id = self.popupID14)
for id in (self.popupID4, self.popupID5, self.popupID6,
self.popupID7, self.popupID8, self.popupID9,
@@ -477,7 +491,6 @@
def OnFiledCalculator(self, event):
"""!Calls SQLBuilderUpdate instance"""
if not self.fieldCalc:
self.fieldCalc = SQLBuilderUpdate(parent = self, id = wx.ID_ANY,
vectmap = self.dbMgrData['vectName'],
@@ -486,6 +499,20 @@
self.fieldCalc.Show()
else:
self.fieldCalc.Raise()
+ def OnAddColumn(self, event):
+ """!Add column into table"""
+ table = self.dbMgrData['mapDBInfo'].layers[self.layer]['table']
+ dlg = AddColumnDialog(parent = self, title = _('Add column to table <%s>') % table)
+ if not dlg:
+ return
+ if dlg.ShowModal() == wx.ID_OK:
+ data = dlg.GetData()
+ self.pages['browse'].AddColumn(name = data['name'],
+ ctype = data['ctype'],
+ length = data['length'])
+ dlg.Destroy()
def SortItems(self, sorter = cmp):
"""!Sort items"""
items = list(self.itemDataMap.keys())
@@ -569,7 +596,9 @@
# vector attributes can be changed only if vector map is in
# the current mapset
- mapInfo = grass.find_file(name = self.dbMgrData['vectName'], element = 'vector')
+ mapInfo = None
+ if self.dbMgrData['vectName']:
+ mapInfo = grass.find_file(name = self.dbMgrData['vectName'], element = 'vector')
if not mapInfo or mapInfo['mapset'] != grass.gisenv()['MAPSET']:
self.dbMgrData['editable'] = False
else:
@@ -597,9 +626,9 @@
For the import use methods addLayer in DbMgrBrowsePage and DbMgrTablesPage
if self.pages['browse']:
- self.pages['browse'].DeleteAllLayerPages()
+ self.pages['browse'].DeleteAllPages()
if self.pages['manageTable']:
- self.pages['manageTable'].DeleteAllLayerPages()
+ self.pages['manageTable'].DeleteAllPages()
self.dbMgrData['vectName'] = vectorName
@@ -652,9 +681,9 @@
# self.browsePage.DeletePage(page)
# break
- self.pages['browse'].DeleteLayerPage(layer)
+ self.pages['browse'].DeletePage(layer)
- self.pages['manageTable'].DeleteLayerPage(layer)
+ self.pages['manageTable'].DeletePage(layer)
# fetch fresh db info
self.dbMgrData['mapDBInfo'] = VectorDBInfo(self.dbMgrData['vectName'])
@@ -678,6 +707,10 @@
"""!Get vector name"""
return self.dbMgrData['vectName']
+ def GetVectorLayers(self):
+ """!Get layers of vector map which have table"""
+ return self.dbMgrData['mapDBInfo'].layers.keys()
class DbMgrNotebookBase(FN.FlatNotebook):
def __init__(self, parent, parentDbMgrBase):
"""!Base class for notebook with attribute tables in tabs
@@ -727,16 +760,19 @@
def OnLayerPageChanged(self, event):
"""!Layer tab changed"""
- pageNum = event.GetSelection()
+ # because of SQL Query notebook
+ if event.GetEventObject() != self:
+ return
+ pageNum = self.GetSelection()
self.selLayer = self.layers[pageNum]
try:
idCol = self.layerPage[self.selLayer]['whereColumn']
except KeyError:
idCol = None
try:
- self.OnChangeSql(None)
# update statusbar
self.log.write(_("Number of loaded records: %d") % \
self.FindWindowById(self.layerPage[self.selLayer]['data']).\
@@ -801,11 +837,13 @@
wx.EndBusyCursor()
- def DeleteLayerPage(self, layer):
+ def DeletePage(self, layer):
"""!Removes layer page"""
- pageNum = self.GetSelection()
- self.DeletePage(self.layers.index(layer))
+ if layer not in self.layers:
+ return False
+ FN.FlatNotebook.DeletePage(self, self.layers.index(layer))
self.layers.remove(layer)
del self.layerPage[layer]
@@ -814,13 +852,56 @@
else:
self.selLayer = None
- def DeleteAllLayerPages(self):
+ return True
+ def DeleteAllPages(self):
"""!Removes all layer pages"""
- self.DeleteAllPages()
+ FN.FlatNotebook.DeleteAllPages(self)
self.layerPage = {}
self.layers = []
+ def AddColumn(self, name, ctype, length):
+ """!Add new column to the table"""
+ table = self.dbMgrData['mapDBInfo'].layers[self.selLayer]['table']
+ if not name:
+ GError(parent = self,
+ message = _("Unable to add column to the table. "
+ "No column name defined."))
+ return False
+ # cast type if needed
+ if ctype == 'double':
+ ctype = 'double precision'
+ if ctype != 'varchar':
+ length = '' # FIXME
+ # check for duplicate items
+ if name in self.dbMgrData['mapDBInfo'].GetColumns(table):
+ message = _("Column <%(column)s> already exists in table <%(table)s>.") % \
+ {'column' : name, 'table' : self.dbMgrData['mapDBInfo'].layers[self.selLayer]["table"]}
+ return False
+ # add v.db.addcolumn command to the list
+ if ctype == 'varchar':
+ ctype += ' (%d)' % length
+ self.listOfCommands.append(('v.db.addcolumn',
+ { 'map' : self.dbMgrData['vectName'],
+ 'layer' : self.selLayer,
+ 'columns' : '%s %s' % (name, ctype) }
+ # apply changes
+ self.ApplyCommands(self.listOfCommands, self.listOfSQLStatements)
+ return True
+ def GetAddedLayers(self):
+ """!Get list of added layers"""
+ return self.layers[:]
class DbMgrBrowsePage(DbMgrNotebookBase):
def __init__(self, parent, parentDbMgrBase, onlyLayer = -1):
"""!Browse page class
@@ -833,16 +914,17 @@
DbMgrNotebookBase.__init__(self, parent = parent,
parentDbMgrBase = parentDbMgrBase)
+ # for Sql Query notebook adaptation on current width
+ self.sqlBestSize = None
for layer in self.dbMgrData['mapDBInfo'].layers.keys():
if onlyLayer > 0 and layer != onlyLayer:
continue
self.AddLayer(layer)
- self.SetSelection(0) # select first layer
if self.layers:
+ self.SetSelection(0)
self.selLayer = self.layers[0]
self.FindWindowById(self.layerPage[self.selLayer]['data']).GetItemCount())
@@ -857,7 +939,14 @@
@param layer vector map layer conntected to table
@param pos position of tab, if -1 it is added to end
+ @return True if layer was added
+ @return False if layer was not added - layer has been already added or has empty table or does not exist
+ if layer in self.layers or \
+ layer not in self.parentDbMgrBase.GetVectorLayers():
+ return False
panel = wx.Panel(parent = self, id = wx.ID_ANY)
#IMPORTANT NOTE: wx.StaticBox MUST be defined BEFORE any of the
@@ -869,7 +958,7 @@
listSizer = wx.StaticBoxSizer(listBox, wx.VERTICAL)
win = VirtualAttributeList(panel, self.log,
- self.dbMgrData, layer)
+ self.dbMgrData, layer, self.pages)
if win.IsEmpty():
del panel
return False
@@ -912,33 +1001,48 @@
border = 3)
# sql statement box
- btnApply = wx.Button(parent = panel, id = wx.ID_APPLY)
+ FNPageStyle = FN.FNB_NO_NAV_BUTTONS | \
+ FN.FNB_NO_X_BUTTON
+ if globalvar.hasAgw:
+ dbmStyle = { 'agwStyle' : FNPageStyle }
+ else:
+ dbmStyle = { 'style' : FNPageStyle }
+ sqlNtb = FN.FlatNotebook(parent = panel, id = wx.ID_ANY,
+ **dbmStyle)
+ # Simple tab
+ simpleSqlPanel = wx.Panel(parent = sqlNtb, id = wx.ID_ANY)
+ sqlNtb.AddPage(page = simpleSqlPanel,
+ text = _('Simple'))
+ btnApply = wx.Button(parent = simpleSqlPanel, id = wx.ID_APPLY, name = 'btnApply')
btnApply.SetToolTipString(_("Apply SELECT statement and reload data records"))
btnApply.Bind(wx.EVT_BUTTON, self.OnApplySqlStatement)
- btnSqlBuilder = wx.Button(parent = panel, id = wx.ID_ANY, label = _("SQL Builder"))
- btnSqlBuilder.Bind(wx.EVT_BUTTON, self.OnBuilder)
- sqlSimple = wx.RadioButton(parent = panel, id = wx.ID_ANY,
- label = _("Simple"))
- sqlSimple.SetValue(True)
- sqlAdvanced = wx.RadioButton(parent = panel, id = wx.ID_ANY,
- label = _("Advanced"))
- sqlSimple.Bind(wx.EVT_RADIOBUTTON, self.OnChangeSql)
- sqlAdvanced.Bind(wx.EVT_RADIOBUTTON, self.OnChangeSql)
- sqlWhereColumn = wx.ComboBox(parent = panel, id = wx.ID_ANY,
+ whereSimpleSqlPanel = wx.Panel(parent = simpleSqlPanel, id = wx.ID_ANY, name = 'wherePanel')
+ sqlWhereColumn = wx.ComboBox(parent = whereSimpleSqlPanel, id = wx.ID_ANY,
size = (100,-1),
style = wx.CB_SIMPLE | wx.CB_READONLY,
choices = self.dbMgrData['mapDBInfo'].GetColumns(self.dbMgrData['mapDBInfo'].layers[layer]['table']))
sqlWhereColumn.SetSelection(0)
- sqlWhereCond = wx.Choice(parent = panel, id = wx.ID_ANY,
+ sqlWhereCond = wx.Choice(parent = whereSimpleSqlPanel, id = wx.ID_ANY,
size = (55,-1),
choices = ['=', '!=', '<', '<=', '>', '>='])
- sqlWhereValue = wx.TextCtrl(parent = panel, id = wx.ID_ANY, value = "",
+ sqlWhereValue = wx.TextCtrl(parent = whereSimpleSqlPanel, id = wx.ID_ANY, value = "",
style = wx.TE_PROCESS_ENTER)
sqlWhereValue.SetToolTipString(_("Example: %s") % "MULTILANE = 'no' AND OBJECTID < 10")
- sqlStatement = wx.TextCtrl(parent = panel, id = wx.ID_ANY,
+ sqlLabel = wx.StaticText(parent = simpleSqlPanel, id = wx.ID_ANY,
+ label = "SELECT * FROM %s WHERE " % \
+ self.dbMgrData['mapDBInfo'].layers[layer]['table'])
+ # Advanced tab
+ advancedSqlPanel = wx.Panel(parent = sqlNtb, id = wx.ID_ANY)
+ sqlNtb.AddPage(page = advancedSqlPanel,
+ text = _('Advanced'))
+ btnSqlBuilder = wx.Button(parent = advancedSqlPanel, id = wx.ID_ANY, label = _("SQL Builder"))
+ btnSqlBuilder.Bind(wx.EVT_BUTTON, self.OnBuilder)
+ sqlStatement = wx.TextCtrl(parent = advancedSqlPanel, id = wx.ID_ANY,
value = "SELECT * FROM %s" % \
self.dbMgrData['mapDBInfo'].layers[layer]['table'],
@@ -946,63 +1050,107 @@
sqlWhereValue.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
sqlStatement.Bind(wx.EVT_TEXT_ENTER, self.OnApplySqlStatement)
- sqlLabel = wx.StaticText(parent = panel, id = wx.ID_ANY,
- label = "SELECT * FROM %s WHERE " % \
- self.dbMgrData['mapDBInfo'].layers[layer]['table'])
- label_query = wx.StaticText(parent = panel, id = wx.ID_ANY,
- label = "")
+ # Simple tab layout
+ simpleSqlSizer = wx.GridBagSizer (hgap = 5, vgap = 5)
+ simpleSqlSizer.AddGrowableCol(1)
- sqlFlexSizer = wx.FlexGridSizer (cols = 3, hgap = 5, vgap = 5)
- sqlFlexSizer.AddGrowableCol(1)
+ sqlSimpleWhereSizer= wx.BoxSizer(wx.HORIZONTAL)
- sqlFlexSizer.Add(item = sqlSimple,
- flag = wx.ALIGN_CENTER_VERTICAL)
- sqlSimpleSizer = wx.BoxSizer(wx.HORIZONTAL)
- sqlSimpleSizer.Add(item = sqlLabel,
- sqlSimpleSizer.Add(item = sqlWhereColumn,
- flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
- sqlSimpleSizer.Add(item = sqlWhereCond,
- flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
- border = 3)
- sqlSimpleSizer.Add(item = sqlWhereValue, proportion = 1,
- sqlFlexSizer.Add(item = sqlSimpleSizer,
- flag = wx.ALIGN_CENTER_VERTICAL | wx.EXPAND)
- sqlFlexSizer.Add(item = btnApply,
- flag = wx.ALIGN_RIGHT)
- sqlFlexSizer.Add(item = sqlAdvanced,
- sqlFlexSizer.Add(item = sqlStatement,
- flag = wx.EXPAND)
- sqlFlexSizer.Add(item = btnSqlBuilder,
+ sqlSimpleWhereSizer.Add(item = sqlWhereColumn,
+ flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL| wx.LEFT,
+ border = 3)
+ sqlSimpleWhereSizer.Add(item = sqlWhereCond,
+ flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.LEFT,
+ border = 3)
+ sqlSimpleWhereSizer.Add(item = sqlWhereValue, proportion = 1,
+ border = 3)
+ whereSimpleSqlPanel.SetSizer(sqlSimpleWhereSizer)
+ simpleSqlSizer.Add(item = sqlLabel, border = 5, pos = (0, 0),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.TOP | wx.LEFT)
+ simpleSqlSizer.Add(item = whereSimpleSqlPanel, border = 5, pos = (0, 1),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.TOP | wx.EXPAND)
+ simpleSqlSizer.Add(item = btnApply, border = 5, pos = (0, 2),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.TOP)
- sqlSizer.Add(item = sqlFlexSizer,
+ simpleSqlPanel.SetSizer(simpleSqlSizer)
+ # Advanced tab layout
+ advancedSqlSizer = wx.FlexGridSizer (cols = 2, hgap = 5, vgap = 5)
+ advancedSqlSizer.AddGrowableCol(0)
+ advancedSqlSizer.Add(item = sqlStatement,
+ flag = wx.EXPAND | wx.ALL, border = 5)
+ advancedSqlSizer.Add(item = btnSqlBuilder,
+ flag = wx.ALIGN_RIGHT | wx.TOP | wx.RIGHT | wx.BOTTOM, border = 5)
+ sqlSizer.Add(item = sqlNtb,
flag = wx.ALL | wx.EXPAND,
border = 3)
+ advancedSqlPanel.SetSizer(advancedSqlSizer)
pageSizer.Add(item = listSizer,
proportion = 1,
border = 5)
pageSizer.Add(item = sqlSizer,
proportion = 0,
flag = wx.BOTTOM | wx.LEFT | wx.RIGHT | wx.EXPAND,
border = 5)
panel.SetSizer(pageSizer)
+ sqlNtb.Bind(wx.EVT_SIZE, self.OnSqlQuerySizeWrap(layer))
self.layerPage[layer]['data'] = win.GetId()
- self.layerPage[layer]['simple'] = sqlSimple.GetId()
- self.layerPage[layer]['advanced'] = sqlAdvanced.GetId()
+ self.layerPage[layer]['sqlNtb'] = sqlNtb.GetId()
self.layerPage[layer]['whereColumn'] = sqlWhereColumn.GetId()
self.layerPage[layer]['whereOperator'] = sqlWhereCond.GetId()
self.layerPage[layer]['where'] = sqlWhereValue.GetId()
self.layerPage[layer]['builder'] = btnSqlBuilder.GetId()
self.layerPage[layer]['statement'] = sqlStatement.GetId()
+ self.layerPage[layer]['sqlIsReduced'] = False # for SQL Query adaptation on width
+ return True
+ def OnSqlQuerySizeWrap(self, layer):
+ """!Helper function"""
+ return lambda event : self.OnSqlQuerySize(event, layer)
+ def OnSqlQuerySize(self, event, layer):
+ """!Adapts SQL Query Simple tab on current width"""
+ sqlNtb = event.GetEventObject()
+ if not self.sqlBestSize:
+ self.sqlBestSize = sqlNtb.GetBestSize()
+ size = sqlNtb.GetSize()
+ sqlReduce = self.sqlBestSize[0] > size[0]
+ if (sqlReduce and self.layerPage[layer]['sqlIsReduced']) or \
+ (not sqlReduce and not self.layerPage[layer]['sqlIsReduced']):
+ event.Skip()
+ return
+ wherePanel = sqlNtb.FindWindowByName('wherePanel')
+ btnApply = sqlNtb.FindWindowByName('btnApply')
+ sqlSimpleSizer = btnApply.GetContainingSizer()
+ if sqlReduce:
+ self.layerPage[layer]['sqlIsReduced'] = True
+ sqlSimpleSizer.AddGrowableCol(0)
+ sqlSimpleSizer.RemoveGrowableCol(1)
+ sqlSimpleSizer.SetItemPosition(wherePanel, (1, 0))
+ sqlSimpleSizer.SetItemPosition(btnApply, (1, 1))
+ else:
+ sqlSimpleSizer.AddGrowableCol(1)
+ sqlSimpleSizer.RemoveGrowableCol(0)
+ sqlSimpleSizer.SetItemPosition(wherePanel, (0, 1))
+ sqlSimpleSizer.SetItemPosition(btnApply, (0, 2))
+ event.Skip()
def OnDataItemActivated(self, event):
"""!Item activated, highlight selected item"""
self.OnDataDrawSelected(event)
@@ -1587,29 +1735,18 @@
cats = ListOfCatsToRange(cats))
self.mapdisplay.MapWindow.UpdateMap(render = True, renderVector = True)
- def OnChangeSql(self, event):
- """!Switch simple/advanced sql statement"""
- if self.FindWindowById(self.layerPage[self.selLayer]['simple']).GetValue():
- self.FindWindowById(self.layerPage[self.selLayer]['where']).Enable(True)
- self.FindWindowById(self.layerPage[self.selLayer]['statement']).Enable(False)
- self.FindWindowById(self.layerPage[self.selLayer]['builder']).Enable(False)
- else:
- self.FindWindowById(self.layerPage[self.selLayer]['where']).Enable(False)
- self.FindWindowById(self.layerPage[self.selLayer]['statement']).Enable(True)
- self.FindWindowById(self.layerPage[self.selLayer]['builder']).Enable(True)
def OnApplySqlStatement(self, event):
"""!Apply simple/advanced sql statement"""
keyColumn = -1 # index of key column
listWin = self.FindWindowById(self.layerPage[self.selLayer]['data'])
sql = None
- win = self.FindWindowById(self.layerPage[self.selLayer]['simple'])
+ win = self.FindWindowById(self.layerPage[self.selLayer]['sqlNtb'])
if not win:
return
wx.BeginBusyCursor()
- if win.GetValue():
+ if win.GetSelection() == 0:
# simple sql statement
whereCol = self.FindWindowById(self.layerPage[self.selLayer]['whereColumn']).GetStringSelection()
whereOpe = self.FindWindowById(self.layerPage[self.selLayer]['whereOperator']).GetStringSelection()
@@ -1766,12 +1903,19 @@
- def AddLayer(self, layer = -1, pos = -1):
+ def AddLayer(self, layer, pos = -1):
"""!Adds tab which represents table
@param layer vector map layer connected to table
+ @return False if layer was not added - layer has been already added or does not exist
+ return False
self.layers.append(layer)
self.layerPage[layer] = {}
@@ -1932,6 +2076,8 @@
column, btnAddCol, btnRenameCol]:
widget.Enable(False)
+ return True
def _createTableDesc(self, parent, table):
"""!Create list with table description"""
tlist = TableListCtrl(parent = parent, id = wx.ID_ANY,
@@ -2128,53 +2274,27 @@
def OnTableItemAdd(self, event):
- table = self.dbMgrData['mapDBInfo'].layers[self.selLayer]['table']
name = self.FindWindowById(self.layerPage[self.selLayer]['addColName']).GetValue()
- if not name:
- GError(parent = self,
- message = _("Unable to add column to the table. "
- "No column name defined."))
- return
ctype = self.FindWindowById(self.layerPage[self.selLayer]['addColType']). \
- # cast type if needed
- if ctype == 'double':
- ctype = 'double precision'
- if ctype == 'varchar':
- length = int(self.FindWindowById(self.layerPage[self.selLayer]['addColLength']). \
- GetValue())
- else:
- length = '' # FIXME
+ length = int(self.FindWindowById(self.layerPage[self.selLayer]['addColLength']). \
+ GetValue())
# add item to the list of table columns
tlist = self.FindWindowById(self.layerPage[self.selLayer]['tableData'])
- # check for duplicate items
- if tlist.FindItem(start = -1, str = name) > -1:
- message = _("Column <%(column)s> already exists in table <%(table)s>.") % \
- {'column' : name, 'table' : self.dbMgrData['mapDBInfo'].layers[self.selLayer]["table"]}
- return
index = tlist.InsertStringItem(sys.maxint, str(name))
tlist.SetStringItem(index, 0, str(name))
tlist.SetStringItem(index, 1, str(ctype))
tlist.SetStringItem(index, 2, str(length))
- # add v.db.addcolumn command to the list
- ctype += ' (%d)' % length
- self.listOfCommands.append(('v.db.addcolumn',
- { 'map' : self.dbMgrData['vectName'],
- 'layer' : self.selLayer,
- 'columns' : '%s %s' % (name, ctype) }
- # apply changes
- self.ApplyCommands(self.listOfCommands, self.listOfSQLStatements)
+ self.AddColumn(name, ctype, length)
# update widgets
self.FindWindowById(self.layerPage[self.selLayer]['addColName']).SetValue('')
self.FindWindowById(self.layerPage[self.selLayer]['renameCol']).SetItems(self.dbMgrData['mapDBInfo'].GetColumns(table))
self.FindWindowById(self.layerPage[self.selLayer]['renameCol']).SetSelection(0)
Modified: grass/trunk/gui/wxpython/dbmgr/dialogs.py
--- grass/trunk/gui/wxpython/dbmgr/dialogs.py 2012-08-16 07:14:49 UTC (rev 52679)
+++ grass/trunk/gui/wxpython/dbmgr/dialogs.py 2012-08-16 09:12:37 UTC (rev 52680)
@@ -6,13 +6,15 @@
List of classes:
- dialogs::DisplayAttributesDialog
- dialogs::ModifyTableRecord
+ - dialogs::AddColumnDialog
-(C) 2007-2011 by the GRASS Development Team
+(C) 2007-2012 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@author Martin Landa <landa.martin gmail.com>
+ at author Refactoring by Stepan Turek <stepan.turek seznam.cz> (GSoC 2012, mentor: Martin Landa)
import os
@@ -700,3 +702,96 @@
valueList.insert(self.keyId, str(self.cat))
return valueList
+class AddColumnDialog(wx.Dialog):
+ def __init__(self, parent, title, id = wx.ID_ANY,
+ style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER):
+ """!Dialog for adding column into table
+ wx.Dialog.__init__(self, parent, id, title, style = style)
+ self.CenterOnParent()
+ self.data = {}
+ self.data['addColName'] = wx.TextCtrl(parent = self, id = wx.ID_ANY, value = '',
+ size = (150, -1), style = wx.TE_PROCESS_ENTER)
+ self.data['addColType'] = wx.Choice (parent = self, id = wx.ID_ANY,
+ choices = ["integer",
+ "double",
+ "varchar",
+ "date"]) # FIXME
+ self.data['addColType'].SetSelection(0)
+ self.data['addColType'].Bind(wx.EVT_CHOICE, self.OnTableChangeType)
+ self.data['addColLength'] = wx.SpinCtrl(parent = self, id = wx.ID_ANY, size = (65, -1),
+ initial = 250,
+ min = 1, max = 1e6)
+ self.data['addColLength'].Enable(False)
+ # buttons
+ self.btnCancel = wx.Button(self, wx.ID_CANCEL)
+ self.btnOk = wx.Button(self, wx.ID_OK)
+ self.btnOk.SetDefault()
+ self._layout()
+ def _layout(self):
+ sizer = wx.BoxSizer(wx.VERTICAL)
+ addSizer = wx.BoxSizer(wx.HORIZONTAL)
+ addSizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Column")),
+ flag = wx.ALIGN_CENTER_VERTICAL | wx.LEFT | wx.RIGHT,
+ border = 5)
+ addSizer.Add(item = self.data['addColName'], proportion = 1,
+ border = 5)
+ addSizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Type")),
+ border = 5)
+ addSizer.Add(item = self.data['addColType'],
+ border = 5)
+ addSizer.Add(item = wx.StaticText(parent = self, id = wx.ID_ANY, label = _("Length")),
+ border = 5)
+ addSizer.Add(item = self.data['addColLength'],
+ border = 5)
+ sizer.Add(item = addSizer, proportion = 0,
+ flag = wx.ALIGN_RIGHT | wx.ALL, border = 5)
+ btnSizer = wx.StdDialogButtonSizer()
+ btnSizer.AddButton(self.btnCancel)
+ btnSizer.AddButton(self.btnOk)
+ btnSizer.Realize()
+ sizer.Add(item = btnSizer, proportion = 0,
+ self.SetSizer(sizer)
+ self.Fit()
+ def GetData(self):
+ """!Get inserted data from dialog's widgets"""
+ values = {}
+ values['name'] = self.data['addColName'].GetValue()
+ values['ctype'] = self.data['addColType'].GetStringSelection()
+ values['length'] = int(self.data['addColLength'].GetValue())
+ return values
+ def OnTableChangeType(self, event):
+ """!Data type for new column changed. Enable or disable
+ data length widget"""
+ if event.GetString() == "varchar":
+ self.data['addColLength'].Enable(True)
+ else:
Modified: grass/trunk/gui/wxpython/gui_core/widgets.py
--- grass/trunk/gui/wxpython/gui_core/widgets.py 2012-08-16 07:14:49 UTC (rev 52679)
+++ grass/trunk/gui/wxpython/gui_core/widgets.py 2012-08-16 09:12:37 UTC (rev 52680)
@@ -77,6 +77,34 @@
del kwargs['name']
super(GNotebook, self).InsertPage(**kwargs)
+ def DeletePage(self, page):
+ """!Delete page
+ @param page name
+ @return True if page was deleted, False if not exists
+ delPageIndex = self.GetPageIndexByName(page)
+ if delPageIndex != -1:
+ super(GNotebook, self).DeletePage(delPageIndex)
+ del self.notebookPages[page]
+ return True
+ else:
+ return False
+ def RemovePage(self, page):
+ """!Delete page without deleting the associated window.
+ @param page name
+ super(GNotebook, self).RemovePage(delPageIndex)
+ return True
+ else:
+ return False
def SetSelectionByName(self, page):
"""!Set notebook
