[GRASS-SVN] r52682 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Thu Aug 16 04:23:29 PDT 2012
Author: turek
Date: 2012-08-16 04:23:29 -0700 (Thu, 16 Aug 2012)
New Revision: 52682
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
vnet: Integrated Attribute table browser for input and result, bug fixed: work with data in other mapset, import of selected vector map in layer tree to the dialog during start
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-16 09:31:49 UTC (rev 52681)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-16 11:23:29 UTC (rev 52682)
@@ -113,14 +113,18 @@
self.mainPanel = wx.Panel(parent=self)
self.notebook = GNotebook(parent = self.mainPanel,
style = FN.FNB_FANCY_TABS | FN.FNB_BOTTOM |
- FN.FNB_NO_NAV_BUTTONS | FN.FNB_NO_X_BUTTON)
+ FN.FNB_NO_X_BUTTON)
# Creates tabs
self._createPointsPage()
self._createParametersPage()
self._createOutputPage()
- #self._createInputAtmPage()
+ self._createInputDbMgrPage()
+ self._createResultDbMgrPage()
+ self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
self._addPanes()
self._doDialogLayout()
@@ -140,7 +144,7 @@
self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
- dlgSize = (410, 520)
+ dlgSize = (400, 520)
self.SetMinSize(dlgSize)
self.SetInitialSize(dlgSize)
@@ -351,7 +355,7 @@
size = globalvar.DIALOG_COLOR_SIZE)
self.addToTreeBtn.SetToolTipString(_("Add vector map into layer tree"))
self.addToTreeBtn.Disable()
- self.addToTreeBtn .Bind(wx.EVT_BUTTON, self.OnToTreeBtn)
+ self.addToTreeBtn.Bind(wx.EVT_BUTTON, self.OnToTreeBtn)
else:
self.inputData[dataSel[0]] = dataSel[2](parent = selPanels[dataSel[0]],
size = (-1, -1))
@@ -423,12 +427,121 @@
border = 5)
return selSizer
+ def _createInputDbMgrPage(self):
+ self.inpDbMgrData = {}
+ self.inpDbMgrData['dbMgr'] = DbMgrBase()
+ # if selected vector map in layer tree then set it
+ if self.mapWin.tree and self.mapWin.tree.layer_selected:
+ selMapData = self.mapWin.tree.GetPyData(self.mapWin.tree.layer_selected)[0]
+ if selMapData['type'] == 'vector': # wrap somehow in LayerTree
+ selMapName = selMapData['maplayer'].name
+ else:
+ selMapName = None
+ self.inpDbMgrData['browse'] = self.inpDbMgrData['dbMgr'].CreateDbMgrPage(parent = self.notebook,
+ pageName = 'browse')
+ self.inpDbMgrData['browse'].SetTabAreaColour(globalvar.FNPageColor)
+ self.inpDbMgrData['input'] = None
+ if selMapName:
+ self.inputData['input'].SetValue(selMapName)
+ self.OnVectSel(None)
+ def _updateInputDbMgrPage(self, show):
+ if show and self.notebook.GetPageIndexByName('inputDbMgr') == -1:
+ self.notebook.AddPage(page = self.inpDbMgrData['browse'],
+ text=_('Input tables'),
+ name = 'inputDbMgr')
+ elif not show:
+ self.notebook.RemovePage(page = 'inputDbMgr')
+ def _createResultDbMgrPage(self):
+ self.resultDbMgrData = {}
+ self.resultDbMgrData['dbMgr'] = DbMgrBase()
+ self.resultDbMgrData['browse'] = self.resultDbMgrData['dbMgr'].CreateDbMgrPage(parent = self.notebook,
+ self.resultDbMgrData['browse'].SetTabAreaColour(globalvar.FNPageColor)
+ if self.tmp_result:
+ self.resultDbMgrData['input'] = self.tmp_result.GetVectMapName()
+ else:
+ self.resultDbMgrData['input'] = None
+ def _updateResultDbMgrPage(self):
+ analysis = self.resultDbMgrData['analysis']
+ haveDbMgr = self.vnetParams[analysis]["resultProps"]["dbMgr"]
+ if haveDbMgr and self.notebook.GetPageIndexByName('resultDbMgr') == -1:
+ self.notebook.AddPage(page = self.resultDbMgrData['browse'],
+ text=_('Result tables'),
+ name = 'resultDbMgr')
+ elif not haveDbMgr:
+ self.notebook.RemovePage(page = 'resultDbMgr')
+ def OnPageChanged(self, event):
+ if event.GetSelection() != self.notebook.GetPageIndexByName('inputDbMgr'):
+ pass
+ elif self.inpDbMgrData['input'] != self.inputData['input'].GetValue().strip():
+ wx.BeginBusyCursor()
+ inpSel = self.inputData['input'].GetValue().strip()
+ self.inpDbMgrData['dbMgr'].ChangeVectorMap(vectorName = inpSel)
+ self.inpDbMgrData['input'] = inpSel
+ for layerName in ['alayer', 'nlayer']:
+ try:
+ layer = int(self.inputData[layerName].GetValue())
+ except ValueError:
+ continue
+ self.inpDbMgrData['browse'].AddLayer(layer)
+ wx.EndBusyCursor()
+ else:
+ needLayers = []
+ browseLayers = self.inpDbMgrData['browse'].GetAddedLayers()
+ try:
+ inpLayer = int(self.inputData[layerName].GetValue())
+ continue
+ if inpLayer in browseLayers:
+ needLayers.append(inpLayer)
+ continue
+ else:
+ self.inpDbMgrData['browse'].AddLayer(inpLayer)
+ for layer in browseLayers:
+ if layer not in needLayers:
+ self.inpDbMgrData['browse'].DeletePage(layer)
+ if event.GetSelection() != self.notebook.GetPageIndexByName('resultDbMgr') or \
+ not self.tmp_result:
+ pass
+ elif self.resultDbMgrData['input'] != self.tmp_result.GetVectMapName():
+ vectName = self.tmp_result.GetVectMapName()
+ self.resultDbMgrData['dbMgr'].ChangeVectorMap(vectorName = self.tmp_result.GetVectMapName())
+ for layer in self.resultDbMgrData['dbMgr'].GetVectorLayers():
+ self.resultDbMgrData['browse'].AddLayer(layer)
def OnToTreeBtn(self, event):
"""!Adds vector map into layer tree (button next to map select)"""
vectorMap = self.inputData['input'].GetValue()
- existsMap = grass.find_file(name = vectorMap,
+ vectMapName, mapSet = self._parseMapStr(vectorMap)
+ vectorMap = vectMapName + '@' + mapSet
+ existsMap = grass.find_file(name = vectMapName,
element = 'vector',
- mapset = grass.gisenv()['MAPSET'])
+ mapset = mapSet)
if not existsMap["name"]:
return
@@ -446,17 +559,21 @@
if self.snapping:
self.OnSnapping(event = None)
+ vectMapName, mapSet = self._parseMapStr(self.inputData['input'].GetValue())
self.inputData['alayer'].Clear()
self.inputData['nlayer'].Clear()
- self.inputData['alayer'].InsertLayers(vector = self.inputData['input'].GetValue().strip())
- self.inputData['nlayer'].InsertLayers(vector = self.inputData['input'].GetValue().strip())
+ self.inputData['alayer'].InsertLayers(vector = vectorMap)
+ self.inputData['nlayer'].InsertLayers(vector = vectorMap)
items = self.inputData['alayer'].GetItems()
itemsLen = len(items)
if itemsLen < 1:
if self.mapWin.tree:
+ self._updateInputDbMgrPage(show = False)
self.inputData['alayer'].SetValue("")
self.inputData['nlayer'].SetValue("")
for sel in ['afcolumn', 'abcolumn', 'ncolumn']:
@@ -476,6 +593,8 @@
self.addToTreeBtn.Enable()
+ if hasattr(self, 'inpDbMgrData'):
+ self._updateInputDbMgrPage(show = True)
self.OnALayerSel(event)
self.OnNLayerSel(event)
@@ -503,13 +622,12 @@
errInput = {}
- curr_mapset = grass.gisenv()['MAPSET']
- vectMaps = grass.list_grouped('vect')[curr_mapset]
mapVal = self.inputData['input'].GetValue()
- mapVal = mapVal.split("@")[0]
+ mapName, mapSet = self._parseMapStr(mapVal)
+ vectMaps = grass.list_grouped('vect')[mapSet]
if not inpToTest or "input" in inpToTest:
- if mapVal not in vectMaps:
+ if mapName not in vectMaps:
errInput['input'] = mapVal
for layerSelName in ['alayer', 'nlayer'] :
@@ -543,8 +661,18 @@
return errInput
- def InputsErrorMsgs(self, strToStart, inpToTest = None):
+ def _parseMapStr(self, vectMapStr):
+ mapValSpl = vectMapStr.strip().split("@")
+ if len(mapValSpl) > 1:
+ mapSet = mapValSpl[1]
+ else:
+ mapSet = grass.gisenv()['MAPSET']
+ mapName = mapValSpl[0]
+ return mapName, mapSet
+ def InputsErrorMsgs(self, strToStart, inpToTest = None):#TODO strToStart don like it
errInput = self._getInvalidInputs(inpToTest)
errMapStr = ""
@@ -736,6 +864,9 @@
return
self._saveAnInputToHist()
+ self.resultDbMgrData['analysis'] = self.currAnModule
# Creates part of cmd fro analysis
cmdParams = [self.currAnModule]
cmdParams.extend(self._getInputParams())
@@ -796,9 +927,10 @@
grass.try_remove(self.coordsTmpFile)
self._saveHistStep()
self.tmp_result.SaveVectMapState()
+ self._updateResultDbMgrPage()
cmd = self.GetLayerStyle()
self.tmp_result.AddRenderLayer(cmd)
self.mapWin.UpdateMap(render=True, renderVector=True)
@@ -903,8 +1035,10 @@
grass.try_remove(self.tmpPtsAsciiFile)
+ self.tmp_result.SaveVectMapState()
- self.tmp_result.SaveVectMapState()
@@ -997,23 +1131,23 @@
def GetLayerStyle(self):
"""!Returns cmd for d.vect, with set style for analysis result"""
- resStyle = self.vnetParams[self.currAnModule]["resultStyle"]
+ resProps = self.vnetParams[self.currAnModule]["resultProps"]
width = UserSettings.Get(group='vnet', key='res_style', subkey= "line_width")
layerStyleCmd = ["layer=1",'width=' + str(width)]
- if "catColor" in resStyle:
+ if "catColor" in resProps:
layerStyleCmd.append('flags=c')
- elif "singleColor" in resStyle:
+ elif "singleColor" in resProps:
col = UserSettings.Get(group='vnet', key='res_style', subkey= "line_color")
layerStyleCmd.append('color=' + str(col[0]) + ':' + str(col[1]) + ':' + str(col[2]))
- if "attrColColor" in resStyle:
+ if "attrColColor" in resProps:
self.layerStyleVnetColors = [
"v.colors",
"map=" + self.tmp_result.GetVectMapName(),
"color=byr",#TODO
- "column=" + resStyle["attrColColor"],
+ "column=" + resProps["attrColColor"],
self.layerStyleVnetColors = utils.CmdToTuple(self.layerStyleVnetColors)
@@ -1054,7 +1188,7 @@
dlg = AddLayerDialog(parent = self)#TODO import location check?
msg = _("Vector map with analysis result does not exist.")
- if dlg.ShowModal() == wx.ID_OK:
+ if dlg.ShowModal() == wx.ID_OK: #TODO destroy
if not hasattr(self.tmp_result, "GetVectMapName"):
GMessage(parent = self,
@@ -1069,13 +1203,14 @@
if not mapToAddEx["name"]:
message = msg)
+ dlg.Destroy()
return
addedMap = dlg.vectSel.GetValue()
existsMap = grass.find_file(name = addedMap,
element = 'vector',
+ dlg.Destroy()
if existsMap["name"]:
dlg = wx.MessageDialog(parent = self.parent.parent,
message = _("Vector map %s already exists. " +
@@ -1086,6 +1221,7 @@
wx.ICON_QUESTION | wx.CENTRE)
ret = dlg.ShowModal()
if ret == wx.ID_NO:
+ dlg.Destroy()
return
RunCommand("g.copy",
@@ -1097,6 +1233,7 @@
cmd.append('map=%s' % addedMap)
if not self.mapWin.tree:
+ dlg.Destroy()
return
if self.mapWin.tree.FindItemByData(key = 'name', value = addedMap) is None:
@@ -1368,7 +1505,6 @@
self.list.ShowColumn('type', 1)
self.list.EditCellKey(iPt, 'type', ptData["cat"])
else:
- pass
self.list.HideColumn('type')
self.list.EditCellKey(iPt, 'topology', ptData["topology"])
@@ -1420,6 +1556,9 @@
dlg.ShowModal()
dlg.Destroy()
self.list.SetUpdateMap(updateMap = True)
@@ -1482,7 +1621,10 @@
'ncolumn'
- "resultStyle" : {"singleColor" : None}
+ "resultProps" : {
+ "singleColor" : None,
+ "dbMgr" : True
"v.net.salesman" : {
@@ -1494,7 +1636,10 @@
'abcolumn'
+ "resultProps" : {
+ "dbMgr" : False
"v.net.flow" : {
"label" : _("Flow %s") % "(v.net.flow)",
@@ -1509,7 +1654,10 @@
'ncolumn'
- "resultStyle" : {"attrColColor": "flow"}
+ "resultProps" : {
+ "attrColColor": "flow",
+ "dbMgr" : True
"v.net.alloc" : {
"label" : _("Allocate subnets for nearest centers %s") % "(v.net.alloc)",
@@ -1521,7 +1669,10 @@
'ncolumn'
- "resultStyle" : {"catColor" : None }
+ "resultProps" : {
+ "catColor" : None,
+ "dbMgr" : False
"v.net.steiner" : {
"label" : _("Create Steiner tree for the network and given terminals %s") % "(v.net.steiner)",
@@ -1531,7 +1682,10 @@
'acolumn',
+ "resultProps" : {
+ "dbMgr" : False #TODO
"v.net.distance" : {
"label" : _("Computes shortest distance via the network %s") % "(v.net.distance)",
@@ -1546,7 +1700,10 @@
'ncolumn'
+ "resultProps" : {
+ "dbMgr" : True
"v.net.iso" : {
"label" : _("Splits net by cost isolines %s") % "(v.net.iso)",
@@ -1558,7 +1715,10 @@
'ncolumn'
+ "resultProps" : {
+ "dbMgr" : False
@@ -2112,17 +2272,19 @@
"vector",
name,
"head")
+ try:
+ head = open(headPath, 'r')
+ for line in head.readlines():
+ i = line.find('MAP DATE:', )
+ if i == 0:
+ head.close()
+ return line.split(':', 1)[1].strip()
- head = open(headPath, 'r')
- for line in head.readlines():
- i = line.find('MAP DATE:', )
- if i == 0:
- head.close()
- return line.split(':', 1)[1].strip()
+ head.close()
+ return ""
+ except IOError:
+ return ""
- head.close()
- return ""
class History:
def __init__(self, parent):
