[GRASS-SVN] r52685 - grass-addons/grass7/imagery/i.segment
svn_grass at osgeo.org
Thu Aug 16 21:39:29 PDT 2012
Author: momsen
Date: 2012-08-16 21:39:28 -0700 (Thu, 16 Aug 2012)
New Revision: 52685
Added:
grass-addons/grass7/imagery/i.segment/testing.c
grass-addons/grass7/imagery/i.segment/create_isegs.c
grass-addons/grass7/imagery/i.segment/i.segment.html
grass-addons/grass7/imagery/i.segment/iseg.h
grass-addons/grass7/imagery/i.segment/main.c
grass-addons/grass7/imagery/i.segment/open_files.c
grass-addons/grass7/imagery/i.segment/parse_args.c
grass-addons/grass7/imagery/i.segment/write_output.c
code clean up and updating documentation
Modified: grass-addons/grass7/imagery/i.segment/create_isegs.c
--- grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-08-16 16:06:06 UTC (rev 52684)
+++ grass-addons/grass7/imagery/i.segment/create_isegs.c 2012-08-17 04:39:28 UTC (rev 52685)
@@ -20,19 +20,26 @@
#endif
#define LINKM
-#define ROWMAJOR //gave nesting error with INDENT program since this changes the for loops
+/* This will do a typical rowmajor processing of the image(s).
+ * Commenting it out will switch to z-order processing.
+ * Z-order does NOT support the bounds option, and assumes a somewhat square rectangle (otherwise the power of 2 square could overrun the long long maximum). */
+//#define ROWMAJOR /* note: gives nesting error with INDENT program since this changes the for loops. comment out when running INDENT. */
int create_isegs(struct files *files, struct functions *functions)
int lower_bound, upper_bound, row, col;
int successflag = 1;
struct Range range;
- /* todo double check this for different distance measurements and numbers of bands. */
+ /* Modify the threshold for easier similarity comparisons.
+ * For Euclidean, square the threshold so we don't need to calculate the root value in the distance calculation.
+ * In either case, multiplie by the number of input bands, so the same threshold will achieve similar thresholds even for different numbers of input bands.*/
if (functions->calculate_similarity == calculate_euclidean_similarity)
- functions->threshold = functions->threshold * functions->threshold * files->nbands; /* use modified threshold to account multiple input bands and to avoid square root in similarity comparison. */
+ functions->threshold =
+ functions->threshold * functions->threshold * files->nbands;
else
- functions->threshold = functions->threshold * files->nbands; /* use modified threshold to account for multiple input bands. */
+ functions->threshold = functions->threshold * files->nbands;
/* set parameters for outer processing loop for polygon constraints */
@@ -41,17 +48,17 @@
else {
if (Rast_read_range(files->bounds_map, files->bounds_mapset, &range) != 1) { /* returns -1 on error, 2 on empty range, quiting either way. */
- G_fatal_error(_("No min/max found in raster map <%s>"),
+ G_fatal_error(_("No min/max found in boundary raster map <%s>"),
files->bounds_map);
Rast_get_range_min_max(&range, &lower_bound, &upper_bound);
- /* TODO polish, should we instead/also get unique values?
- * As is, we will iterate at least one time over the entire raster for each integer between the upper and lower bound. */
+ /* speed enhancement, when processing with bounds: get the unique values.
+ * As is, we will iterate at one time over the entire raster for each integer between the upper and lower bound, even if no regions exist with that value. */
/* processing loop for polygon/boundary constraints */
if (files->bounds_map != NULL)
- G_message(_("Running region growing algorithm, the percent completed is based the range of values in the boundary constraints map"));
+ G_message(_("Starting image segmentation within boundary constraints, the percent complete is based the range of values in the boundary constraints map"));
for (files->current_bound = lower_bound;
files->current_bound <= upper_bound; files->current_bound++) {
@@ -111,9 +118,6 @@
- /* clear candidate flag, so only need to reset the processing area on each iteration. todo polish, can be removed after all loops only cover the processing area */
- flag_clear_all(files->candidate_flag);
} /* end of else, set up for bounded segmentation */
/* consider maxrow/maxcol as nrow, ncol, loops will have: row < maxrow
@@ -138,8 +142,13 @@
else if (functions->method == 3)
successflag = seg_speed_test(files, functions);
#endif
- } /* end outer loop for processing polygons */
+ /* check if something went wrong */
+ if (successflag == FALSE)
+ G_fatal_error(_("Error during segmentation"));
+ } /* end outer loop for processing bounds constraints (will just run once if not provided) */
/* reset null flag to the original if we have boundary constraints */
if (files->bounds_map != NULL) {
for (row = 0; row < files->nrows; row++) {
@@ -156,643 +165,19 @@
return successflag; /* todo, successflag was assuming one pass... don't have anything to pick up a failure if there is a bounds constraint */
-#ifdef DEBUG
-/* writes row+col to the output raster. Also using for the linkm speed test. */
-int io_debug(struct files *files, struct functions *functions)
- int row, col;
- /* from speed.c to test speed of malloc vs. memory manager */
- unsigned long int z, end_z; // depending on shape of the rectangle...will need a larger max i. long long is avail in C99 spec...
- register int i, j;
- int s;
- struct link_head *head;
- struct pixels *p;
- /* **************write fake data to test I/O portion of module */
- /* G_verbose_message("writing fake data to segmentation file"); */
- G_verbose_message("writing scaled input (layer 1) to output file");
- G_verbose_message("weighted flag = %d", files->weighted);
- //~ for (row = 0; row < files->nrows; row++) {
- //~ for (col = 0; col < files->ncols; col++) {
- //~ /*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
- //~ /* files->out_val[0] = col + row; */
- //~ segment_get(&files->bands_seg, (void *)files->bands_val, row,
- //~ col);
- //~ files->iseg[row][col] = files->bands_val[0] * 100; /*pushing DCELL into CELL */
- //~ G_percent(row, files->nrows, 1);
- /* Trying out peano ordering */
- /* idea is for large maps, if the width of SEG tiles in RAM is less than the width of the map, this should avoid a lot of I/O */
- /* this is probably closer to a z-order curve then peano order. */
- s = -1;
- /*blank slate */
- for (row = 0; row < files->nrows; row++) {
- for (col = 0; col < files->ncols; col++) {
- //files->iseg[row][col] = -1;
- segment_put(&files->iseg_seg, &s, row, col);
- s = 0;
- //~ for(i=1; i<9; i++)
- //~ G_message("i: %d", i);
- //~ for(j=4; j>=0; j--){
- //~ G_message("\tj=%d, 1 & (i >> j) = %d", j, 1 & (i >> j));
- /* need to get a "square" power of 2 around our processing area */
- /*largest dimension: */
- if (files->nrows > files->ncols)
- end_z = files->nrows;
- else
- end_z = files->ncols;
- /* largest power of 2: */
- end_z--; /* in case we are already a power of two. */
- end_z = (end_z >> 1) | end_z;
- end_z = (end_z >> 2) | end_z;
- end_z = (end_z >> 4) | end_z;
- end_z = (end_z >> 8) | end_z;
- end_z = (end_z >> 16) | end_z;
- end_z = (end_z >> 32) | end_z; /* only for 64-bit architecture TODO, would this mess things up on 32? */
- /*todo does this need to repeat more since it is long unsigned??? */
- end_z++;
- /*squared: */
- end_z *= end_z;
- for (z = 0; z < end_z; z++) { // if square and power of 2: files->nrows*files->ncols
- row = col = 0;
- /*bit wise construct row and col from i */
- for (j = 8 * sizeof(long int) - 1; j > 1; j--) {
- row = row | (1 & (z >> j));
- row = row << 1;
- j--;
- col = col | (1 & (z >> j));
- col = col << 1;
- j--;
- G_message("Done: z: %li, row: %d, col: %d", z, row, col);
- if (row >= files->nrows || col >= files->ncols)
- continue;
- s++;
- //~ for(i=0; i<8; i++){ //files->nrows*files->ncols
- // G_message("i: %d", i);
- //~ row=col=0;
- //~ /*bit wise construct row and col from i*/
- //~ for(j=4; j>0; j=j-2){ //8*sizeof(int)
- // G_message("j: %d", j);
- //~ row = row | ( i & (1 << (2 * j))); /* row | a[rmax-r]; */
- //~ row = row << 1;
- //~ col = col | ( i & (1 << (2 * j + 1)));
- //~ col = col << 1;
- //~ G_message("j: %d, row: %d, col: %d", j, row, col);
- //~ col = col | ( i & (1 << ((2 * j) + 1)));
- //~ G_message("(1 << ((2 * j) + 1)) = %d", (1 << ((2 * j) + 1)));
- //~ G_message("Done: i: %d, row: %d, col: %d", i, row, col);
- //~ files->iseg[row][col] = s;
- //~ s++;
- /*speed test... showed a difference of 1min 9s for G_malloc and 34s for linkm. (with i < 2000000000 */
-#ifdef LINKM
- head = (struct link_head *)link_init(sizeof(struct pixels));
-#endif
- for (i = 0; i < 10; i++) {
-#ifdef LINKM
- p = (struct pixels *)link_new(head);
- link_dispose((struct link_head *)head, (VOID_T *) p);
-#else
- p = (struct pixels *)G_malloc(sizeof(struct pixels));
- G_free(p);
-#endif
-#ifdef LINKM
- link_cleanup(head);
- G_message("used linkm");
-#else
- G_message("used G_malloc");
-#endif
- G_message("end speed test");
- return TRUE;
-int ll_test(struct files *files, struct functions *functions)
- int row, col, n, count;
- struct pixels *Rkn, *current, *newpixel, *Rin_head, *Rin_second; /*current will be used to iterate over any of the linked lists. */
- struct link_head *Rkn_token;
- G_message("testing linked lists");
- Rin_head = NULL;
- Rin_second = NULL;
- Rkn = NULL;
- Rkn_token = link_init(sizeof(struct pixels));
- if (Rkn_token == NULL)
- G_message("Rkn_token is null");
- /* make a neighbor list */
- for (n = 0; n < 5; n++) {
- newpixel = (struct pixels *)link_new(files->token);
- newpixel->next = Rin_head; /*point the new pixel to the current first pixel */
- newpixel->row = n;
- newpixel->col = n + 2;
- Rin_head = newpixel; /*change the first pixel to be the new pixel. */
- G_message("Added: Rin %d: row: %d, col: %d", n,
- Rin_head->row, Rin_head->col);
- /* make a second neighbor list, using same token */
- for (n = 0; n < 4; n++) {
- newpixel->next = Rin_second; /*point the new pixel to the current first pixel */
- newpixel->row = n * 100;
- newpixel->col = n * 100;
- Rin_second = newpixel; /*change the first pixel to be the new pixel. */
- G_message("Added: Rin (second list) %d: row: %d, col: %d", n,
- Rin_second->row, Rin_second->col);
- /* make a third neighbor list, using local token */
- newpixel = (struct pixels *)link_new(Rkn_token);
- newpixel->next = Rkn; /*point the new pixel to the current first pixel */
- newpixel->row = 5 * n;
- newpixel->col = n;
- Rkn = newpixel; /*change the first pixel to be the new pixel. */
- G_message("Added: Rkn %d: row: %d, col: %d", n, Rkn->row, Rkn->col);
- G_message(" Test pass token result: %d",
- test_pass_token(&Rin_head, files));
- G_message("Printing out:");
- /*print out neighbors */
- for (current = Rin_head; current != NULL; current = current->next)
- G_message("Rin: row: %d, col: %d", current->row, current->col);
- for (current = Rin_second; current != NULL; current = current->next)
- G_message("Rin (second): row: %d, col: %d", current->row,
- current->col);
- for (current = Rkn; current != NULL; current = current->next)
- G_message("Rkn: row: %d, col: %d", current->row, current->col);
- /* remove all from Rkn list, 5 from Rin list */
- G_message("removing 5 from Rin...");
- current = Rin_head; /* get first in list */
- Rin_head = Rin_head->next; /* point head to the next one *//*pop */
- link_dispose(files->token, (VOID_T *) current);
- G_message("Printing out, after 5 removed from Rin:");
- current->col);
- G_message("removing all from Rkn...");
- /* for (current = Rkn; current != NULL; current = current->next) { ||||this shortcut won't work, current is gone! */
- while (Rkn != NULL) {
- G_message("In Rkn remove loop");
- current = Rkn; /* rememer "old" head */
- Rkn = Rkn->next; /* move head to next pixel */
- link_dispose(Rkn_token, (VOID_T *) current); /* remove "old" head */
- G_message("removed Rkn...");
- if (Rkn == NULL)
- G_message("which set Rkn to null");
- else
- G_message("hmm, still need to set Rkn to null?!");
- G_message("Printing out, after removed Rin and Rkn:");
- current->col);
- G_message("writing fake data to segmentation file");
- /*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
- //~ files->iseg[row][col] = col + row;
- //todo need variable if this speed test will be used again..
- //segment_put(&files->iseg_seg, (void *)s, row, col);
- G_percent(row, files->nrows, 1);
- /*test how many pixels can be made and disposed of */
- for (n = 0; n < functions->threshold; n++) {
- /*make tokens */
- test_pass_token(&Rin_head, files);
- count += 5;
- G_message("estimate of tokens created %d", count + 15);
- /*dispose tokens */
- while (Rin_head != NULL) {
- current = Rin_head; /* remember "old" head */
- Rin_head = Rin_head->next; /* move head to next pixel */
- link_dispose(files->token, (VOID_T *) current); /* remove "old" head */
- G_message("are they gone?");
- link_cleanup(Rkn_token);
- G_message("after link_cleanup(Rkn_token)");
- G_message("end linked list test");
- return TRUE;
-int test_pass_token(struct pixels **head, struct files *files)
- int n;
- struct pixels *newpixel;
- for (n = 10; n < 15; n++) {
- newpixel->next = *head; /*point the new pixel to the current first pixel */
- newpixel->col = n * 2;
- *head = newpixel; /*change the first pixel to be the new pixel. */
- newpixel->row, newpixel->col);
- return TRUE;
-int seg_speed_test(struct files *files, struct functions *functions)
- int i, j, k, n, max;
- clock_t start, end;
- double temp, cpu_time_used;
- int (*get) (struct files *, int, int); /* files, row, col */
- struct RB_TREE *no_check_tree, *known_iseg_tree;
- struct RB_TRAV trav;
- struct pixels *to_check, *newpixel, *current, *tree_pix;
- FLAG *check_flag;
- G_message("checking speed of RAM vs SEG vs get function performance");
- G_message("Access in the same region, so shouldn't have any disk I/O");
- max = 100000000;
- G_message("repeating everything %d times.", max);
- { /* Array vs. SEG ... when working in local area */
- start = clock();
- for (i = 0; i < max; i++) {
- segment_get(&files->bands_seg, (void *)files->bands_val, 12, 12);
- temp = files->bands_val[0];
- end = clock();
- cpu_time_used = ((double)(end - start)) / CLOCKS_PER_SEC;
- G_message("Using SEG: %g", cpu_time_used);
- start = clock();
- //~ temp = files->iseg[12][12];
- end = clock();
- G_message("Using array in RAM: %g", cpu_time_used);
- get = &get_segID_SEG;
- start = clock();
- temp = get(files, 12, 12);
- end = clock();
- G_message("Using SEG w/ get(): %g", cpu_time_used);
- get = &get_segID_RAM;
- start = clock();
- end = clock();
- G_message("Using RAM w/ get(): %g", cpu_time_used);
- G_message("to check storage requirements... system dependent... :");
- G_message("unsigned char: %lu", sizeof(unsigned char));
- G_message("unsigned char pointer: %lu", sizeof(unsigned char *));
- G_message("int: %lu", sizeof(int));
- G_message("unsigned int: %lu", sizeof(unsigned int));
- G_message("double: %lu", sizeof(double));
- max = 100000;
- { /* compare rbtree with linked list and array */
- n = 100;
- start = clock();
- no_check_tree = rbtree_create(compare_ids, sizeof(struct pixels));
- /*build */
- for (j = 0; j < n; j++) {
- tree_pix = (struct pixels *)link_new(files->token);
- tree_pix->row = tree_pix->col = j;
- rbtree_insert(no_check_tree, &tree_pix);
- /*access */
- if (rbtree_find(no_check_tree, &tree_pix))
- continue; /* always looking for the same pixel...is this an easy or hard one to find? */
- /*free memory */
- rbtree_destroy(no_check_tree);
- end = clock();
- G_message
- ("Using rbtree of pixels ( build/find/destroy), %d elements, time: %g",
- n, cpu_time_used);
- start = clock();
- known_iseg_tree = rbtree_create(compare_ids, sizeof(int));
- /*build */
- rbtree_insert(known_iseg_tree, &j);
- /*access */
- if (rbtree_find(known_iseg_tree, &j))
- continue;
- /*free memory */
- rbtree_destroy(known_iseg_tree);
- end = clock();
- G_message
- ("Using rbtree ints ( build/find/destroy), %d elements, time: %g",
- to_check = NULL;
- start = clock();
- /*build */
- newpixel->next = to_check; /*point the new pixel to the current first pixel */
- newpixel->row = j;
- newpixel->col = i;
- to_check = newpixel; /*change the first pixel to be the new pixel. */
- /*access */
- for (current = to_check; current != NULL; current = current->next) { /* for each of Ri's neighbors */
- temp = current->row;
- /*free memory */
- my_dispose_list(files->token, &to_check);
- end = clock();
- G_message
- ("Using linked list and linkm (build/access/free), %d elements, time: %g",
- n = 1000;
- /* repeat for both with larger membership */
- start = clock();
- /*build */
- /*access */
- continue;
- /*free memory */
- end = clock();
- G_message("Using rbtree ints, %d elements, time: %g", n,
- cpu_time_used);
- to_check = NULL;
- start = clock();
- /*build */
- /*access */
- /*free memory */
- end = clock();
- G_message("Using linked list and linkm, %d elements, time: %g", n,
- cpu_time_used);
- k = 100;
- n = 50;
- check_flag = flag_create(k, k);
- start = clock();
- /*set to zero */
- flag_clear_all(check_flag);
- /*write and access */
- FLAG_SET(check_flag, j, j);
- temp = FLAG_GET(check_flag, j, j);
- end = clock();
- G_message
- ("Using %d pixel flag array (all cleared), %d elements set and get, time: %g",
- k * k, n, cpu_time_used);
- k = 10000;
- start = clock();
- /*set to zero */
- end = clock();
- G_message
- /* iff bounding constraints have been given, need to confirm neighbors are in the same area.
- * Faster to check if the bounds map is null, or if no bounds just set all the bounds flags to 1 and directly check the bounds flag? */
- max = INT_MAX;
- j = 0;
- G_message("compare if statement to FLAG_GET, repeating %d times",
- max);
- G_message("Flag = %d", FLAG_GET(files->candidate_flag, 1, 1));
- start = clock();
- if ((FLAG_GET(files->candidate_flag, 1, 1)) != 0) {
- j++;
- end = clock();
- G_message("FLAG_GET: %g, temp: %d", cpu_time_used, j);
- j = 0;
- start = clock();
- if (files->bounds_map != NULL) {
- j++;
- end = clock();
- G_message("check for NULL: %g, temp: %d", cpu_time_used, j); /* was faster by about 20% */
- /* is accessing a variable different then a value? */
- max = INT_MAX;
- j = k = 0;
- G_message("compare variable to number, repeating %d times", max);
- start = clock();
- if (i > 0) {
- j++;
- end = clock();
- G_message("compare to zero: %g, temp: %d", cpu_time_used, j);
- j = 0;
- start = clock();
- if (i > k) {
- j++;
- end = clock();
- G_message("compare to k: %g, temp: %d", cpu_time_used, j); /* was faster by about 20% */
- return TRUE;
-int get_segID_SEG(struct files *files, int row, int col)
- segment_get(&files->bands_seg, (void *)files->bands_val, row, col);
- return files->bands_val[0]; /* for accurate comparison, is converting double to int a time penalty? */
-int get_segID_RAM(struct files *files, int row, int col)
- return 0; //files->iseg[row][col];
-#endif
int region_growing(struct files *files, struct functions *functions)
int row, col, t;
double threshold, Ri_similarity, Rk_similarity, tempsim;
int endflag; /* =TRUE if there were no merges on that processing iteration */
int pathflag; /* =TRUE if we didn't find mutual neighbors, and should continue with Rk */
- struct pixels *Ri_head, *Rk_head, *Rin_head, *Rkn_head, *Rclose_head,
- *Rc_head, *Rc_tail, *Rcn_head, *current, *newpixel, *Ri_bestn;
- int Ri_count, Rk_count, Rc_count; /* number of pixels/cells in Ri and Rk */
- unsigned long int z, end_z; // depending on shape of the rectangle...will need a larger max i. long long is avail in C99 spec... (only needed for z-order)
+ struct pixels *Ri_head, *Rk_head, *Rin_head, *Rkn_head, //, *Rclose_head, *Rc_head, *Rc_tail, *Rcn_head,
+ *current, *newpixel, *Ri_bestn;
+ int Ri_count, Rk_count; //, Rc_count; /* number of pixels/cells in Ri and Rk */
+ unsigned long int z, end_z; /* only used for z-order */
int j;
#ifdef PROFILE
- //todo polish, remove or comment when done?
clock_t start, end;
clock_t merge_start, merge_end;
double merge_accum, merge_lap;
@@ -823,21 +208,24 @@
Rin_head = NULL;
Rkn_head = NULL;
Ri_bestn = NULL;
- Rclose_head = NULL;
- Rc_head = NULL;
- Rcn_head = NULL;
+ //~ Rclose_head = NULL;
+ //~ Rc_head = NULL;
+ //~ Rcn_head = NULL;
+ /* One paper mentioned gradually lowering the threshold at each iteration.
+ * if this is implemented, move this assignment inside the do loop and make it a function of t. */
+ threshold = functions->threshold;
/* do while loop until no merges are made, or until t reaches maximum number of iterations */
do {
#ifdef PROFILE
pass_start = clock();
#endif
- fprintf(stdout, "pass %d\n", t);
+ /* fprintf(stdout, "pass %d\n", t); */
G_debug(3, "####### Starting outer do loop! t = %d #######", t);
- G_percent(t, functions->end_t, 1);
+ if (files->bounds_map == NULL)
+ G_percent(t, functions->end_t, 1);
- threshold = functions->threshold; /* TODO, consider making this a function of t. */
endflag = TRUE;
/* Set candidate flag to true/1 for all pixels */
@@ -847,8 +235,8 @@
/*check each pixel, start the processing only if it is a candidate pixel */
#ifdef ROWMAJOR
+ for (row = files->minrow; row < files->maxrow; row++) {
+ for (col = files->mincol; col < files->maxcol; col++) {
#else
/* z-order traversal: */
@@ -868,7 +256,7 @@
+ /*TODO does this need to repeat more since z long unsigned??? */
end_z++;
/*squared: */
@@ -888,19 +276,20 @@
j--;
- continue; /* todo polish, if z-order is helpful, could skip to the next z that is in the processing area. */
+ continue; /* slight speed enhancement, if z-order is helpful, figure out how to skip to the next z that is in the processing area. */
#endif
G_debug(4, "Starting pixel from next row/col, not from Rk");
if (FLAG_GET(files->candidate_flag, row, col) &&
FLAG_GET(files->seeds_flag, row, col)) {
/*free memory for linked lists */
my_dispose_list(files->token, &Ri_head);
my_dispose_list(files->token, &Rk_head);
my_dispose_list(files->token, &Rin_head);
my_dispose_list(files->token, &Rkn_head);
- my_dispose_list(files->token, &Rclose_head);
+ //~ my_dispose_list(files->token, &Rclose_head);
Rk_count = 0;
/* First pixel in Ri is current row/col pixel. We may add more later if it is part of a segment */
@@ -924,11 +313,7 @@
#ifdef PROFILE
fn_start = clock();
#endif
- //~ if (find_segment_neighbors
- //~ (&Ri_head, &Rin_head, &Ri_count, files,
- //~ functions) != TRUE) {
- //~ G_fatal_error("find_segment_neighbors() failed");
functions);
@@ -998,34 +383,34 @@
* TODO... but that leaves the possibility that we have the wrong best Neighbor after doing these merges...
* but it seems we can't put this merge after the Rk/Rkn portion of the loop, because we are changing the available neighbors
* ...maybe this extra "very close" idea has to be done completely differently or dropped??? */
- for (current = Rclose_head; current != NULL;
- current = current->next) {
- my_dispose_list(files->token, &Rc_head);
- my_dispose_list(files->token, &Rcn_head);
+ //~ for (current = Rclose_head; current != NULL;
+ //~ current = current->next) {
+ //~ my_dispose_list(files->token, &Rc_head);
+ //~ my_dispose_list(files->token, &Rcn_head);
+ //~ /* get membership of neighbor segment */
+ //~ Rc_count = 1;
+ //~ newpixel =
+ //~ (struct pixels *)link_new(files->token);
+ //~ newpixel->next = NULL;
+ //~ newpixel->row = current->row;
+ //~ newpixel->col = current->col;
+ //~ Rc_head = Rc_tail = newpixel;
+ //~ find_segment_neighbors(&Rc_head, &Rcn_head, &Rc_count, files, functions); /* just to get members, not looking at neighbors now */
+ //~ merge_values(Ri_head, Rc_head, Ri_count,
+ //~ Rc_count, files);
+ //~ /* Add Rc pixels to Ri */
+ //~ Rc_tail->next = Ri_head;
+ //~ Ri_head = Rc_head;
+ //~ //todo, recurse? Check all Rcn neighbors if they are very close?
+ //~ // not needed if the combining works... my_dispose_list(files->token, &Rc_head);
- /* get membership of neighbor segment */
- Rc_count = 1;
- newpixel =
- (struct pixels *)link_new(files->token);
- newpixel->next = NULL;
- newpixel->row = current->row;
- newpixel->col = current->col;
- Rc_head = Rc_tail = newpixel;
- find_segment_neighbors(&Rc_head, &Rcn_head, &Rc_count, files, functions); /* just to get members, not looking at neighbors now */
- merge_values(Ri_head, Rc_head, Ri_count,
- Rc_count, files);
- /* Add Rc pixels to Ri */
- Rc_tail->next = Ri_head;
- Ri_head = Rc_head;
- //todo, recurse? Check all Rcn neighbors if they are very close?
- // not needed if the combining works... my_dispose_list(files->token, &Rc_head);
- Rc_head = NULL;
/* check if we have a bestn that is valid to use to look at Rk */
if (Ri_bestn != NULL) {
G_debug(4,
@@ -1192,7 +577,7 @@
if (t == 2 && files->bounds_map == NULL)
G_warning(_("No segments were created. Verify threshold and region settings."));
- /* included the bound_map check, since we check all values between min/max, intermediate values might not be present. TODO polish, add back in if we check for unique bounds values. */
+ /* future enhancement, remove the "&& bounds_map == NULL" if we check for unique bounds values. */
if (endflag == FALSE)
G_message(_("Merging processes stopped due to reaching max iteration limit, more merges may be possible"));
@@ -1204,9 +589,11 @@
if (functions->min_segment_size > 1 && t > 2) { /* NOTE: added t > 2, it doesn't make sense to force merges if no merges were made on the original pass. Something should be adjusted first */
- G_message
- (_("Final iteration, forcing merges for small segments, percent complete based on rows."));
+ if (files->bounds_map == NULL) {
+ G_message
+ (_("Final iteration, forcing merges for small segments, percent complete based on rows."));
/* for the final forced merge, the candidate flag is just to keep track if we have confirmed if:
* a. the segment size is >= to the minimum allowed size or
* b. we have merged it with its best neighbor
@@ -1214,9 +601,10 @@
set_all_candidate_flags(files);
- G_percent(row, files->nrows - 1, 5);
+ G_percent(row, files->maxrow - 1, 1);
if (FLAG_GET(files->candidate_flag, row, col)) {
@@ -1238,15 +626,9 @@
Ri_head->row, Ri_head->col);
/* find segment neighbors */
-find_segment_neighbors
- (&Ri_head, &Rin_head, &Ri_count, files,
- functions);
+ find_segment_neighbors
+ (&Ri_head, &Rin_head, &Ri_count, files, functions);
if (Rin_head != NULL) { /*found neighbors */
if (Ri_count >= functions->min_segment_size) /* don't force a merge */
set_candidate_flag(Ri_head, FALSE, files);
@@ -1291,7 +673,7 @@
newpixel->col = Ri_bestn->col;
Rk_head = newpixel;
- /* get the full pixel/cell membership list for Rk *//* todo polish: worth having a seperate function for this, since we don't need the neighbors? */
+ /* get the full pixel/cell membership list for Rk *//* speed enhancement: a seperate function for this, since we don't need the neighbors */
find_segment_neighbors(&Rk_head, &Rkn_head,
&Rk_count, files,
functions);
@@ -1321,10 +703,8 @@
} /* next row */
t++; /* to count one more "iteration" */
} /* end if for force merge */
- else
- if (t > 2)
- G_verbose_message("temporary(?) message, number of passes: %d",
- t - 1);
+ else if (t > 2 && files->bounds_map == NULL)
+ G_verbose_message("Number of passes completed: %d", t - 1);
#ifdef PROFILE
end = clock();
fprintf(stdout, "time spent merging: %g\n", merge_accum);
@@ -1335,8 +715,8 @@
return TRUE;
-/* TODO, for now will return borderPixels instead of passing a pointer, I saw mentioned that each parameter slows down the function call? */
-/* TODO, My first impression is that the borderPixels count is ONLY needed for the case of initial seeds, and not used later on. Another reason to split the function... */
+ /* TODO, for now will return borderPixels instead of passing a pointer, I saw mentioned that each parameter slows down the function call? */
+ /* TODO, My first impression is that the borderPixels count is ONLY needed for the case of initial seeds, and not used later on. Another reason to split the function... */
int find_segment_neighbors(struct pixels **R_head,
struct pixels **neighbors_head, int *seg_count,
@@ -1354,24 +734,18 @@
/* TODO, any time savings to move any variables to files (mem allocation in open_files) */
- /* neighbor list will be a listing of pixels that are neighbors? Include segment numbers? Only include unique segments?
- * MM: counting unique neighbor segments could have the advantage of dealing with special
- * segments that have only one neighbor, i.e. segments within segments
+ /* neighbor list will be a listing of pixels that are neighbors, but will be limited to just one pixel from each neighboring segment.
- * Maybe the most complete return would be a structure array, structure to include the segment ID and a list of points in it?
- * But the list of points would NOT be inclusive - just the points bordering the current segment...
/* parameter: R, current segment membership, could be single pixel (incomplete list) or list of pixels.
- * parameter: neighbors/Rin/Rik, neighbor pixels, could have a list already, or could be empty ?
+ * parameter: neighbors/Rin/Rik, neighbor pixels, could have a list already, or could be empty
* functions->num_pn int, 4 or 8, for number of pixel neighbors
/* *** initialize data *** */
borderPixels = 0;
segment_get(&files->iseg_seg, &R_iseg, (*R_head)->row,
(*R_head)->col);
@@ -1402,7 +776,7 @@
*neighbors_head = newpixel; /*change the first pixel to be the new pixel. */
/* todo polish... could use a tree and only return pixels from unique segments. */
- borderPixels++; /* increment for all non null pixels TODO perimeter: OK to ignore these cells? */
+ borderPixels++; /* increment for all non null pixels TODO perimeter: OK to ignore these cells? */
@@ -1516,9 +890,9 @@
else { /* segment id's were different */
- borderPixels++; /* increment for all non null pixels that are non in no-check or R_iseg TODO perimeter: move this to include pixels in no-check ??? */
- if (!rbtree_find(known_iseg, ¤t_seg_ID)) { /* we don't have any neighbors yet from this segment */
+ borderPixels++; /* increment for all non null pixels that are non in no-check or R_iseg TODO perimeter: move this to include pixels in no-check ??? */
+ if (!rbtree_find(known_iseg, ¤t_seg_ID)) { /* we don't have any neighbors yet from this segment */
if (current_seg_ID != 0)
/* with seeds, non seed pixels are defaulted to zero. Should we use null instead?? then could skip this check? Or we couldn't insert it??? */
/* add to known neighbors list */
@@ -1535,11 +909,11 @@
newpixel->col = pixel_neighbors[n][1];
- else { /* TODO we need to keep track of (and return!) a total count of neighbors pixels for each neighbor segment, to update the perimeter value in the similarity calculation. */
- /* todo perimeter: need to initalize this somewhere!!! */
- /* todo perimeter... need to find pixel with same segment ID.... countShared++;
- * Oh! Should we change the tree to sort on segment ID...need to think of fast way to return this count? with pixel? or with something else? */
+ else { /* TODO we need to keep track of (and return!) a total count of neighbors pixels for each neighbor segment, to update the perimeter value in the similarity calculation. */
+ /* todo perimeter: need to initalize this somewhere!!! */
+ /* todo perimeter... need to find pixel with same segment ID.... countShared++;
+ * Oh! Should we change the tree to sort on segment ID...need to think of fast way to return this count? with pixel? or with something else? */
@@ -1642,7 +1016,8 @@
files->second_val[n]);
- /* val = sqrt(val); *//* use squared distance, save the calculation time. */
+ /* use squared distance, save the calculation time. We squared the similarity threshold earlier to allow for this. */
+ /* val = sqrt(val); */
return val;
@@ -1662,35 +1037,33 @@
segment_get(&files->bands_seg, (void *)files->second_val, b->row,
b->col);
- /* euclidean distance, sum the square differences for each dimension */
+ /* Manhattan distance, sum the absolute difference between values for each dimension */
for (n = 0; n < files->nbands; n++) {
val += fabs(files->bands_val[n] - files->second_val[n]); /* todo check if fabs is the "fast" way for absolute value */
return val;
/* TODO: add shape parameter...
- In the eCognition literature, we find that the key factor in the
- multi-scale segmentation algorithm used by Definiens is the scale
- factor f:
+ In the eCognition literature, we find that the key factor in the
+ multi-scale segmentation algorithm used by Definiens is the scale
+ factor f:
- f = W.Hcolor + (1 - W).Hshape
- Hcolor = sum(b = 1:nbands)(Wb.SigmaB)
- Hshape = Ws.Hcompact + (1 - Ws).Hsmooth
- Hcompact = PL/sqrt(Npx)
- Hsmooth = PL/Pbbox
+ f = W.Hcolor + (1 - W).Hshape
+ Hcolor = sum(b = 1:nbands)(Wb.SigmaB)
+ Hshape = Ws.Hcompact + (1 - Ws).Hsmooth
+ Hcompact = PL/sqrt(Npx)
+ Hsmooth = PL/Pbbox
- Where W is a user-defined weight of importance of object radiometry vs
- shape (usually .9 vs .1), Wb is the weigh given to band B, SigmaB is
- the std dev of the object for band b, Ws is a user-defined weight
- giving the importance of compactedness vs smoothness, PL is the
- perimeter lenght of the object, Npx the number of pixels within the
- object, and Pbbox the perimeter of the bounding box of the object.
+ Where W is a user-defined weight of importance of object radiometry vs
+ shape (usually .9 vs .1), Wb is the weigh given to band B, SigmaB is
+ the std dev of the object for band b, Ws is a user-defined weight
+ giving the importance of compactedness vs smoothness, PL is the
+ perimeter lenght of the object, Npx the number of pixels within the
+ object, and Pbbox the perimeter of the bounding box of the object.
int merge_values(struct pixels *Ri_head, struct pixels *Rk_head,
@@ -1749,7 +1122,8 @@
/* calculates and stores the mean value for all pixels in a list, assuming they are all in the same segment */
- int merge_pixels(struct pixels *R_head, int borderPixels, struct files *files)
+ int merge_pixels(struct pixels *R_head, int borderPixels,
+ struct files *files)
int n, count = 0;
struct pixels *current;
@@ -1777,9 +1151,9 @@
files->second_val[n] = files->second_val[n] / count;
- /* add in the shape values */
- files->bands_val[files->nbands] = count; /* area (Num Pixels) */
- files->bands_val[files->nbands + 1] = borderPixels; /* Perimeter Length */ /* todo polish, not exact for edges...close enough for now? */
+ /* add in the shape values */
+ files->bands_val[files->nbands] = count; /* area (Num Pixels) */
+ files->bands_val[files->nbands + 1] = borderPixels; /* Perimeter Length *//* todo polish, not exact for edges...close enough for now? */
/* save the results */
for (current = R_head; current != NULL; current = current->next) {
@@ -1871,8 +1245,7 @@
/* Set candidate flag to true/1 or false/0 for all pixels in current processing area
- * checks for NULL flag and if it is in current "polygon" if a bounds map is given
- * checks if seeds were given */
+ * checks for NULL flag and if it is in current "polygon" if a bounds map is given */
int set_all_candidate_flags(struct files *files)
int row, col;
Modified: grass-addons/grass7/imagery/i.segment/i.segment.html
--- grass-addons/grass7/imagery/i.segment/i.segment.html 2012-08-16 16:06:06 UTC (rev 52684)
+++ grass-addons/grass7/imagery/i.segment/i.segment.html 2012-08-17 04:39:28 UTC (rev 52685)
@@ -1,11 +1,47 @@
<h2>DESCRIPTION</h2>
+<em>i.segment</em> generates a segmented raster based on the input imagery group. A region growing and merging algorithm is currently implemented.
<H2>NOTES</h2>
-The final forced merge (if minsize is set > 1) ignores the (optional) seed map.
+<h3>Threshold</h3>
+During normal processing, the similarity between two segments must be lower then the calculated threshold value. If a minimum segment size of 2 or larger is given with the <em>minsize</em> parameter, segments with a smaller pixel count will be merged with their most similar neighbor even if the similarity is greater then the threshold. Unless the <em>-w</em> flag for weighted data is used, the threshold should be between 0 and 1.0.
+The threshold will be multiplied by the number of rasters included in the image group. This will allow the same threshold to achieve similar segmentation results when the number of rasters in the image group varies.
+<h3>Seeds</h3>
+The seeds map can be used to provide either seed pixels (random or selected points from which to start the segmentation process) or seed segments (results of previous segmentations or classifications). The different approaches are automatically detected by the program: any pixels that have identical seed values and are contiguous will be lumped into a single segment ID.
+It is expected that the <em>minsize</em> will be set to 1 if a seed map is used, but the program will allow other values to be used. If both options are used, the final iteration that ignores the threshold also will ignore the seed map and force merges for all pixels (not just segments that have grown/merged from the seeds).
+<h3>Maximum number of starting segments</h3>
+For the region growing algorithm without starting seeds, each pixel is sequentially numbered. The current limit with CELL storage is 2 billion starting segment ID's. If the initial map has a larger number of non-null pixels, there are two workarounds:
+1. Use starting seed pixels. (Maximum 2 billion pixels can be labeled with positive integers, either as a grid or random selection.)
+2. Use starting seed segments. (By initial classification or other methods.)
<H2>EXAMPLES</h2>
+Need to give an example using NC data set.
+i.group
+i.segment (lower threshold)
+i.segment (higher threshold, using previous output as boundaries)
<h2>TODO</h2>
-For Region Growing, the current limit with CELL storage is 2 billion starting segment ID's. Workaround: If the original image has a larger number of pixels, please use the starting seeds option to limit the number of starting segments.
+Copy the remaining tasks from:
+http://grass.osgeo.org/wiki/GRASS_GSoC_2012_Image_Segmentation#ToDo_List
<h2>BUGS</h2>
+If the seeds map is used to give starting seed segments, the segments are renumbered starting from 1. There is a chance a segment could be renumbered to a seed value that has not yet been processed. If they happen to be adjacent, they would be merged. (Possible fixes: use negative segment ID's as a placeholder and negate all values after the seed map has been processed. Use an additional data structure, though this costs more RAM.)
<H2>REFERENCES</h2>
+This project was first developed during GSoC 2012. Project documentation, Image Segmentation references, and other information is at the <a href="http://grass.osgeo.org/wiki/GRASS_GSoC_2012_Image_Segmentation">project wiki</a>.
+Information about <a href="http://grass.osgeo.org/wiki/Image_classification">classification in GRASS</a> is at available on the wiki.
+<!-- TODO Markus, should the Image_classification page be updated to include i.segment in the areas where i.seg belong? -->
<h2>SEE ALSO</h2>
+<em>
+<a href="i.group.html">i.group</a>
+<a href="i.maxlik.html">i.maxlik</a>+
+<a href="r.fuzzy">r.fuzzy</a>
+<a href="i.smap.html">i.smap</a>
+<a href="r.seg.html">r.seg</a> (Addon)
+</em>
<h2>AUTHORS</h2>
-Eric Momsen
+Eric Momsen - North Dakota State University
Modified: grass-addons/grass7/imagery/i.segment/iseg.h
--- grass-addons/grass7/imagery/i.segment/iseg.h 2012-08-16 16:06:06 UTC (rev 52684)
+++ grass-addons/grass7/imagery/i.segment/iseg.h 2012-08-17 04:39:28 UTC (rev 52685)
@@ -18,7 +18,7 @@
/* DEBUG will add some additional testing options to the segmentation method drop down.
* it also add some while loops that just have G_debug statements in them. */
-#define DEBUG
+/* #define DEBUG */
/* PROFILE will add some rough time checks for finding neighbors, merging, and pass times. */
/* #define PROFILE */
@@ -29,7 +29,7 @@
struct pixels *next;
int row;
int col;
- int countShared; /* todo perimeter: will hold the count how many pixels are shared on the Border Between Ri and Rk. Not used for all pixels... see if this is an OK way to do this...*/
+ int countShared; /* todo perimeter: will hold the count how many pixels are shared on the Border Between Ri and Rk. Not used for all pixels... see if this is an OK way to do this... */
/* input and output files, as well as some other processing info */
@@ -58,7 +58,6 @@
/* results */
SEGMENT iseg_seg; /* segment ID assignment */
- // int iseg_val;
int nsegs; /* number of segments */
/* processing flags */
@@ -78,9 +77,9 @@
float threshold; /* similarity threshold */
int min_segment_size; /* smallest number of pixels/cells allowed in a final segment */
- /* Some function pointers to set one time in parse_args() */
+ /* Some function pointers to set in parse_args() */
int (*find_pixel_neighbors) (int, int, int[8][2], struct files *); /*parameters: row, col, pixel_neighbors */
- double (*calculate_similarity) (struct pixels *, struct pixels *, struct files *, struct functions *); /*parameters: two points (row,col) to compare */
+ double (*calculate_similarity) (struct pixels *, struct pixels *, struct files *, struct functions *); /*parameters: two pixels (each with row,col) to compare */
/* max number of iterations/passes */
int end_t;
@@ -93,7 +92,9 @@
/* todo: should this be an option, set at a specific value, or left out. */
// double very_close; /* segments with very_close similarity will be merged without changing or checking the candidate flag. The algorithm will continue looking for the "most similar" neighbor that isn't "very close". */
- // todo... tried this out briefly, but realized that we need to find the segment membership, might be some faster ways to do this, but first tries actually slowed down the processing.
+ // todo markus... I tried this out briefly, but realized that we need to find the segment membership (the find neighbors function only returns single pixels) , might be some faster ways to do this, but my first tries actually slowed down the processing.
+ // should I leave in the commented code for "very_close", or remove it entirely?
@@ -106,12 +107,6 @@
/* create_isegs.c */
int create_isegs(struct files *, struct functions *);
-int io_debug(struct files *, struct functions *);
-int ll_test(struct files *, struct functions *);
-int test_pass_token(struct pixels **, struct files *);
-int seg_speed_test(struct files *, struct functions *);
-int get_segID_SEG(struct files *, int, int);
-int get_segID_RAM(struct files *, int, int);
int region_growing(struct files *, struct functions *);
int find_segment_neighbors(struct pixels **, struct pixels **, int *,
@@ -132,3 +127,11 @@
/* write_output.c */
int write_output(struct files *);
int close_files(struct files *);
+/* testing.c */
+int io_debug(struct files *, struct functions *);
+int ll_test(struct files *, struct functions *);
+int test_pass_token(struct pixels **, struct files *);
+int seg_speed_test(struct files *, struct functions *);
+int get_segID_SEG(struct files *, int, int);
+int get_segID_RAM(struct files *, int, int);
Modified: grass-addons/grass7/imagery/i.segment/main.c
--- grass-addons/grass7/imagery/i.segment/main.c 2012-08-16 16:06:06 UTC (rev 52684)
+++ grass-addons/grass7/imagery/i.segment/main.c 2012-08-17 04:39:28 UTC (rev 52685)
@@ -11,8 +11,8 @@
* for details.
- * NOTE: the word "segment" is already used by the Segmentation
- * Library for the data files/tiling, so iseg (image segmentation)
+ * NOTE: the names "segment" and "SEG" are already used by the Segmentation
+ * Library for the data files/tiling, so "iseg" (image segmentation)
* will be used to refer to the image segmentation.
Modified: grass-addons/grass7/imagery/i.segment/open_files.c
--- grass-addons/grass7/imagery/i.segment/open_files.c 2012-08-16 16:06:06 UTC (rev 52684)
+++ grass-addons/grass7/imagery/i.segment/open_files.c 2012-08-17 04:39:28 UTC (rev 52685)
@@ -1,5 +1,6 @@
/* PURPOSE: opening input rasters and creating segmentation files */
+#include <limits.h> /* for INT_MAX, todo remove if there is a GRASS max CELL */
#include <stdlib.h>
#include <grass/gis.h>
#include <grass/glocale.h>
@@ -13,13 +14,15 @@
int *in_fd, seeds_fd, bounds_fd, null_check, out_fd, mean_fd;
int n, s, row, col, srows, scols, inlen, nseg, borderPixels;
DCELL **inbuf; /* buffer array, to store lines from each of the imagery group rasters */
- CELL *boundsbuf;
- void *seedsbuf, *ptr; /* todo. correct data type when allowing any data type? hmm, since have changed logic, seeds must be CELL. Could update code. */
+ CELL *boundsbuf, *seedsbuf;
+ void *ptr; /* for iterating seedsbuf */
size_t ptrsize;
- RASTER_MAP_TYPE data_type;
struct FPRange *fp_range; /* for getting min/max values on each input raster */
DCELL *min, *max;
+ struct Range range; /* for seeds range */
+ int seeds_min, seeds_max;
/* for merging seed values */
struct pixels *R_head, *Rn_head, *newpixel, *current;
int R_count;
@@ -53,7 +56,7 @@
/* ****** open the input rasters ******* */
- /* Note: I confirmed, the API does not check this. */
+ /* Note: I confirmed, the API does not check this: */
G_debug(1, "Checking image group...");
if (!I_get_group_ref(files->image_group, &Ref))
G_fatal_error(_("Unable to read REF file for group <%s>"),
@@ -80,12 +83,19 @@
Ref.file[n].mapset);
- /* open seeds raster */
+ /* open seeds raster and confirm all positive integers were given */
if (files->seeds_map != NULL) {
seeds_fd = Rast_open_old(files->seeds_map, "");
- data_type = Rast_get_map_type(seeds_fd);
- seedsbuf = Rast_allocate_buf(data_type);
- ptrsize = Rast_cell_size(data_type);
+ seedsbuf = Rast_allocate_c_buf();
+ ptrsize = sizeof(CELL);
+ if (Rast_read_range(files->seeds_map, files->seeds_mapset, &range) != 1) { /* returns -1 on error, 2 on empty range, quiting either way. */
+ G_fatal_error(_("No min/max found in seeds raster map <%s>"),
+ files->seeds_map);
+ Rast_get_range_min_max(&range, &seeds_min, &seeds_max);
+ if (seeds_min < 0)
+ G_fatal_error(_("Seeds raster should have postive integers for starting seeds, and zero or NULL for all other pixels."));
/* Get min/max values of each input raster for scaling */
@@ -134,9 +144,9 @@
G_fatal_error("Unable to create input temporary files");
/* ******* remaining memory allocation ********* */
- /* save the area and perimeter as well */
- /* TODO: currently saving this with the input DCELL values. Better to have a second segment structure to save as integers ??? */
+ /* save the area and perimeter as well */
+ /* TODO: currently saving this with the input DCELL values. Better to have a second segment structure to save as integers ??? */
inlen = inlen + sizeof(double) * 2;
files->bands_val = (double *)G_malloc(inlen);
@@ -148,7 +158,7 @@
G_fatal_error(_("Unable to allocate memory for initial segment ID's"));
/* NOTE: SEGMENT file should be initialized to zeros for all data. TODO double check this. */
- /* bounds/constraints (start here to get any possible NULL values) */
+ /* bounds/constraints (start with processing constraints to get any possible NULL values) */
if (segment_open
(&files->bounds_seg, G_tempfile(), files->nrows, files->ncols,
@@ -184,7 +194,7 @@
Rast_get_d_row(in_fd[n], inbuf[n], row);
- Rast_get_row(seeds_fd, seedsbuf, row, data_type);
+ Rast_get_c_row(seeds_fd, seedsbuf, row);
ptr = seedsbuf;
@@ -198,35 +208,37 @@
if (files->weighted == TRUE)
files->bands_val[n] = inbuf[n][col]; /*unscaled */
else
- files->bands_val[n] = (inbuf[n][col] - min[n]) / (max[n] - min[n]); /*scaled version */
+ files->bands_val[n] = (inbuf[n][col] - min[n]) / (max[n] - min[n]); /* scaled */
- files->bands_val[Ref.nfiles] = 1; /* area (Num Pixels) */
- files->bands_val[Ref.nfiles + 1] = 4; /* Perimeter Length */ /* todo polish, not exact for edges...close enough for now? */
+ files->bands_val[Ref.nfiles] = 1; /* area (just using the number of pixels) */
+ files->bands_val[Ref.nfiles + 1] = 4; /* Perimeter Length *//* todo polish, not exact for edges...close enough for now? */
segment_put(&files->bands_seg, (void *)files->bands_val, row, col); /* store input bands */
if (null_check != -1) { /*good pixel */
FLAG_UNSET(files->null_flag, row, col); /*flag */
- if (Rast_is_null_value(ptr, data_type) == TRUE) {
- // not needed, initialized to zero. files->iseg[row][col] = 0; /* place holder... todo, Markus, is this OK to leave out? Or safer to set it, since this is just done once... */
- FLAG_UNSET(files->seeds_flag, row, col); //todo shouldn't need to this, flag is initialized to zero?
+ if (Rast_is_c_null_value(ptr) == TRUE) {
+ // todo... old data structure, switch to SEG if need to initalize to zero: files->iseg[row][col] = 0;
+ FLAG_UNSET(files->seeds_flag, row, col); //todo markus, I expect iseg and seeds flag are initialized to zero, so shouldn't need to set either flag. Leave these two lines of code out?
else {
- FLAG_SET(files->seeds_flag, row, col); //todo might not need this... just look for seg ID > 0 ? If go this route, need to enforce constraints are positive integers.
- /* seed value is starting segment ID. TODO document: seeds must be positive integers, and will be assigned as starting segment IDs. */
- segment_put(&files->iseg_seg, ptr, row, col); //can I just use ptr as the address with the value I want to store? TODO enforce that seeds map is an integer.
+ FLAG_SET(files->seeds_flag, row, col); //todo might not need this... just look for seg ID > 0 ?
+ /* seed value is starting segment ID. */
+ segment_put(&files->iseg_seg, ptr, row, col);
ptr = G_incr_void_ptr(ptr, ptrsize);
else { /* no seeds provided */
s++; /* sequentially number all pixels with their own segment ID */
- segment_put(&files->iseg_seg, &s, row, col); /*starting segment number */
- FLAG_SET(files->seeds_flag, row, col); /*all pixels are seeds */
+ if (s < INT_MAX) { /* Check that the starting seeds aren't too large. (checking for < instead of <= since TODO Markus, Is there a GRASS constant for the maximum size of CELL? */
+ segment_put(&files->iseg_seg, &s, row, col); /*starting segment number */
+ FLAG_SET(files->seeds_flag, row, col); /*all pixels are seeds */
+ else
+ G_fatal_error(_("Exceeded integer storage limit, too many initial pixels."));
else { /*don't use this pixel */
- //files->iseg[row][col] = -1; /* place holder...TODO this could be a conflict if constraints included a -1 ??? wrote that awhile ago...still true???*/
- //TODO, do we need a -1 here? Or just leave as the zero it was initialized with? Need a -1 if we don't use the NULL_FLAG...
FLAG_SET(files->null_flag, row, col); /*flag */
@@ -286,6 +298,9 @@
* for now I've put it here, to make merge_pixels() more general. Unless you think initialization speed is more important then future flexibility? */
s++;
+ if (s == INT_MAX) /* Check that the starting seeds aren't too large. TODO Markus, Is there a GRASS constant for the maximum size of CELL? */
segment_put(&files->iseg_seg, &s, current->row,
Modified: grass-addons/grass7/imagery/i.segment/parse_args.c
--- grass-addons/grass7/imagery/i.segment/parse_args.c 2012-08-16 16:06:06 UTC (rev 52684)
+++ grass-addons/grass7/imagery/i.segment/parse_args.c 2012-08-17 04:39:28 UTC (rev 52685)
@@ -9,7 +9,7 @@
int parse_args(int argc, char *argv[], struct files *files,
+{ /* todo Markus, is it helpful to leave tips like this that are helpful to someone new to GRASS? Or is it just clutter now, and should go to a reference sheet? */
/* reference: http://grass.osgeo.org/programming7/gislib.html#Command_Line_Parsing */
struct Option *group, *seeds, *bounds, *output, *method, *similarity, *threshold, *min_segment_size, *endt; /* Establish an Option pointer for each option */
@@ -80,11 +80,13 @@
weighted->description =
_("Weighted input, don't perform the default scaling of input maps.");
- /* Raster for initial segment seeds *//* TODO polish: allow vector points/centroids for seed input. */
+ /* Raster for initial segment seeds *//* future enhancement: allow vector points/centroids for seed input. */
seeds = G_define_standard_option(G_OPT_R_INPUT);
seeds->key = "seeds";
seeds->required = NO;
- seeds->description = _("Optional raster map with starting seeds.");
+ seeds->label = _("Optional raster map with starting seeds.");
+ seeds->description =
+ _("Pixel values with positive integers are used as starting seeds.");
/* Polygon constraints. */
bounds = G_define_standard_option(G_OPT_R_INPUT);
@@ -125,12 +127,13 @@
/* Validation */
- /* TODO: use checker for any of the data validation steps? */
/* Check and save parameters */
files->image_group = group->answer;
+ /* TODO Markus, I saw in the GRASS Programmer's manual that I could use a checker function for the data validation steps.
+ * But when I did a find|grep for "checker" it didn't show up. Is there any reason to use it? Or just leave the validation like I have it now? */
if (G_legal_filename(output->answer) == TRUE)
files->out_name = output->answer; /* name of output (segment ID) raster map */
else
@@ -182,11 +185,14 @@
/* TODO polish, check if function pointer or IF statement is faster */
- files->weighted = weighted->answer; /* default/0 for performing the scaling, but selected/1 if user has weighted values so scaling should be skipped. */
- if (seeds->answer == NULL) { /* no starting seeds, will use all pixels as seeds */
+ /* default/0 for performing the scaling, but selected/1 if user has weighted values so scaling should be skipped. */
+ files->weighted = weighted->answer;
+ /* check if optional seeds map was given, if not, use all pixels as starting seeds. */
+ if (seeds->answer == NULL) {
files->seeds_map = NULL;
- else { /* polygon constraints given */
+ else { /* seeds provided, check if valid map */
files->seeds_map = seeds->answer;
if ((files->seeds_mapset =
G_find_raster2(files->seeds_map, "")) == NULL) {
@@ -197,10 +203,11 @@
- if (bounds->answer == NULL) { /*no polygon constraints */
+ /* check if optional processing boundaries were provided */
+ if (bounds->answer == NULL) { /*no processing constraints */
files->bounds_map = NULL;
+ else { /* processing constraints given, check if valid map */
files->bounds_map = bounds->answer;
if ((files->bounds_mapset =
G_find_raster2(files->bounds_map, "")) == NULL) {
@@ -225,7 +232,8 @@
/* debug help */
- functions->path = path->answer; /* default/0 for no pathflag, but selected/1 to use Rk as next Ri if not mutually best neighbors. */
+ /* default/0 for no pathflag, but selected/1 to use Rk as next Ri if not mutually best neighbors. */
+ functions->path = path->answer;
functions->limited = limited->answer;
Added: grass-addons/grass7/imagery/i.segment/testing.c
--- grass-addons/grass7/imagery/i.segment/testing.c (rev 0)
+++ grass-addons/grass7/imagery/i.segment/testing.c 2012-08-17 04:39:28 UTC (rev 52685)
@@ -0,0 +1,627 @@
+/* This file includes some functions that are called as "segmentation methods" when DEBUG is defined. They were used to test the I/O without doing any segmentation,
+ * but then later were modified to test the use and speed of various data structures. */
+#ifdef DEBUG
+/* writes row+col to the output raster. Also using for the linkm speed test. */
+int io_debug(struct files *files, struct functions *functions)
+ int row, col;
+ /* from speed.c to test speed of malloc vs. memory manager */
+ unsigned long int z, end_z; // depending on shape of the rectangle...will need a larger max i. long long is avail in C99 spec...
+ register int i, j;
+ int s;
+ struct link_head *head;
+ struct pixels *p;
+ /* **************write fake data to test I/O portion of module */
+ /* G_verbose_message("writing fake data to segmentation file"); */
+ G_verbose_message("writing scaled input (layer 1) to output file");
+ G_verbose_message("weighted flag = %d", files->weighted);
+ //~ for (row = 0; row < files->nrows; row++) {
+ //~ for (col = 0; col < files->ncols; col++) {
+ //~ /*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
+ //~ /* files->out_val[0] = col + row; */
+ //~ segment_get(&files->bands_seg, (void *)files->bands_val, row,
+ //~ col);
+ //~ files->iseg[row][col] = files->bands_val[0] * 100; /*pushing DCELL into CELL */
+ //~ G_percent(row, files->nrows, 1);
+ /* Trying out peano ordering */
+ /* idea is for large maps, if the width of SEG tiles in RAM is less than the width of the map, this should avoid a lot of I/O */
+ /* this is probably closer to a z-order curve then peano order. */
+ s = -1;
+ /*blank slate */
+ for (row = 0; row < files->nrows; row++) {
+ for (col = 0; col < files->ncols; col++) {
+ //files->iseg[row][col] = -1;
+ s = 0;
+ //~ for(i=1; i<9; i++)
+ //~ G_message("i: %d", i);
+ //~ for(j=4; j>=0; j--){
+ //~ G_message("\tj=%d, 1 & (i >> j) = %d", j, 1 & (i >> j));
+ /* need to get a "square" power of 2 around our processing area */
+ /*largest dimension: */
+ if (files->nrows > files->ncols)
+ end_z = files->nrows;
+ else
+ end_z = files->ncols;
+ /* largest power of 2: */
+ end_z--; /* in case we are already a power of two. */
+ end_z = (end_z >> 1) | end_z;
+ end_z = (end_z >> 2) | end_z;
+ end_z = (end_z >> 4) | end_z;
+ end_z = (end_z >> 8) | end_z;
+ end_z = (end_z >> 16) | end_z;
+ end_z = (end_z >> 32) | end_z; /* only for 64-bit architecture TODO, would this mess things up on 32? */
+ /*todo does this need to repeat more since it is long unsigned??? */
+ end_z++;
+ /*squared: */
+ end_z *= end_z;
+ for (z = 0; z < end_z; z++) { // if square and power of 2: files->nrows*files->ncols
+ row = col = 0;
+ /*bit wise construct row and col from i */
+ for (j = 8 * sizeof(long int) - 1; j > 1; j--) {
+ row = row | (1 & (z >> j));
+ row = row << 1;
+ j--;
+ col = col | (1 & (z >> j));
+ col = col << 1;
+ j--;
+ G_message("Done: z: %li, row: %d, col: %d", z, row, col);
+ if (row >= files->nrows || col >= files->ncols)
+ continue;
+ s++;
+ //~ for(i=0; i<8; i++){ //files->nrows*files->ncols
+ // G_message("i: %d", i);
+ //~ row=col=0;
+ //~ /*bit wise construct row and col from i*/
+ //~ for(j=4; j>0; j=j-2){ //8*sizeof(int)
+ // G_message("j: %d", j);
+ //~ row = row | ( i & (1 << (2 * j))); /* row | a[rmax-r]; */
+ //~ row = row << 1;
+ //~ col = col | ( i & (1 << (2 * j + 1)));
+ //~ col = col << 1;
+ //~ G_message("j: %d, row: %d, col: %d", j, row, col);
+ //~ col = col | ( i & (1 << ((2 * j) + 1)));
+ //~ G_message("(1 << ((2 * j) + 1)) = %d", (1 << ((2 * j) + 1)));
+ //~ G_message("Done: i: %d, row: %d, col: %d", i, row, col);
+ //~ files->iseg[row][col] = s;
+ //~ s++;
+ /*speed test... showed a difference of 1min 9s for G_malloc and 34s for linkm. (with i < 2000000000 */
+#ifdef LINKM
+ head = (struct link_head *)link_init(sizeof(struct pixels));
+#endif
+ for (i = 0; i < 10; i++) {
+#ifdef LINKM
+ p = (struct pixels *)link_new(head);
+ link_dispose((struct link_head *)head, (VOID_T *) p);
+#else
+ p = (struct pixels *)G_malloc(sizeof(struct pixels));
+ G_free(p);
+#endif
+#ifdef LINKM
+ link_cleanup(head);
+ G_message("used linkm");
+#else
+ G_message("used G_malloc");
+#endif
+ G_message("end speed test");
+ return TRUE;
+int ll_test(struct files *files, struct functions *functions)
+ int row, col, n, count;
+ struct pixels *Rkn, *current, *newpixel, *Rin_head, *Rin_second; /*current will be used to iterate over any of the linked lists. */
+ struct link_head *Rkn_token;
+ G_message("testing linked lists");
+ Rin_head = NULL;
+ Rin_second = NULL;
+ Rkn = NULL;
+ Rkn_token = link_init(sizeof(struct pixels));
+ if (Rkn_token == NULL)
+ G_message("Rkn_token is null");
+ /* make a neighbor list */
+ for (n = 0; n < 5; n++) {
+ newpixel = (struct pixels *)link_new(files->token);
+ newpixel->next = Rin_head; /*point the new pixel to the current first pixel */
+ newpixel->row = n;
+ newpixel->col = n + 2;
+ Rin_head = newpixel; /*change the first pixel to be the new pixel. */
+ G_message("Added: Rin %d: row: %d, col: %d", n,
+ Rin_head->row, Rin_head->col);
+ /* make a second neighbor list, using same token */
+ for (n = 0; n < 4; n++) {
+ newpixel->next = Rin_second; /*point the new pixel to the current first pixel */
+ newpixel->row = n * 100;
+ newpixel->col = n * 100;
+ Rin_second = newpixel; /*change the first pixel to be the new pixel. */
+ G_message("Added: Rin (second list) %d: row: %d, col: %d", n,
+ Rin_second->row, Rin_second->col);
+ /* make a third neighbor list, using local token */
+ newpixel = (struct pixels *)link_new(Rkn_token);
+ newpixel->next = Rkn; /*point the new pixel to the current first pixel */
+ newpixel->row = 5 * n;
+ newpixel->col = n;
+ Rkn = newpixel; /*change the first pixel to be the new pixel. */
+ G_message("Added: Rkn %d: row: %d, col: %d", n, Rkn->row, Rkn->col);
+ G_message(" Test pass token result: %d",
+ test_pass_token(&Rin_head, files));
+ G_message("Printing out:");
+ /*print out neighbors */
+ for (current = Rin_head; current != NULL; current = current->next)
+ G_message("Rin: row: %d, col: %d", current->row, current->col);
+ for (current = Rin_second; current != NULL; current = current->next)
+ G_message("Rin (second): row: %d, col: %d", current->row,
+ current->col);
+ for (current = Rkn; current != NULL; current = current->next)
+ G_message("Rkn: row: %d, col: %d", current->row, current->col);
+ /* remove all from Rkn list, 5 from Rin list */
+ G_message("removing 5 from Rin...");
+ current = Rin_head; /* get first in list */
+ Rin_head = Rin_head->next; /* point head to the next one *//*pop */
+ link_dispose(files->token, (VOID_T *) current);
+ G_message("Printing out, after 5 removed from Rin:");
+ current->col);
+ G_message("removing all from Rkn...");
+ /* for (current = Rkn; current != NULL; current = current->next) { ||||this shortcut won't work, current is gone! */
+ while (Rkn != NULL) {
+ G_message("In Rkn remove loop");
+ current = Rkn; /* rememer "old" head */
+ Rkn = Rkn->next; /* move head to next pixel */
+ link_dispose(Rkn_token, (VOID_T *) current); /* remove "old" head */
+ G_message("removed Rkn...");
+ if (Rkn == NULL)
+ G_message("which set Rkn to null");
+ else
+ G_message("hmm, still need to set Rkn to null?!");
+ G_message("Printing out, after removed Rin and Rkn:");
+ current->col);
+ G_message("writing fake data to segmentation file");
+ /*files->out_val[0] = files->out_val[0]; *//*segment number *//* just copying the map for testing. */
+ //~ files->iseg[row][col] = col + row;
+ //todo need variable if this speed test will be used again..
+ //segment_put(&files->iseg_seg, (void *)s, row, col);
+ G_percent(row, files->nrows, 1);
+ /*test how many pixels can be made and disposed of */
+ for (n = 0; n < functions->threshold; n++) {
+ /*make tokens */
+ test_pass_token(&Rin_head, files);
+ count += 5;
+ G_message("estimate of tokens created %d", count + 15);
+ /*dispose tokens */
+ while (Rin_head != NULL) {
+ current = Rin_head; /* remember "old" head */
+ Rin_head = Rin_head->next; /* move head to next pixel */
+ link_dispose(files->token, (VOID_T *) current); /* remove "old" head */
+ G_message("are they gone?");
+ link_cleanup(Rkn_token);
+ G_message("after link_cleanup(Rkn_token)");
+ G_message("end linked list test");
+ return TRUE;
+int test_pass_token(struct pixels **head, struct files *files)
+ int n;
+ struct pixels *newpixel;
+ for (n = 10; n < 15; n++) {
+ newpixel->next = *head; /*point the new pixel to the current first pixel */
+ newpixel->col = n * 2;
+ *head = newpixel; /*change the first pixel to be the new pixel. */
+ newpixel->row, newpixel->col);
+ return TRUE;
+int seg_speed_test(struct files *files, struct functions *functions)
+ int i, j, k, n, max;
+ clock_t start, end;
+ double temp, cpu_time_used;
+ int (*get) (struct files *, int, int); /* files, row, col */
+ struct RB_TREE *no_check_tree, *known_iseg_tree;
+ struct RB_TRAV trav;
+ struct pixels *to_check, *newpixel, *current, *tree_pix;
+ FLAG *check_flag;
+ G_message("checking speed of RAM vs SEG vs get function performance");
+ G_message("Access in the same region, so shouldn't have any disk I/O");
+ max = 100000000;
+ G_message("repeating everything %d times.", max);
+ { /* Array vs. SEG ... when working in local area */
+ start = clock();
+ for (i = 0; i < max; i++) {
+ segment_get(&files->bands_seg, (void *)files->bands_val, 12, 12);
+ temp = files->bands_val[0];
+ end = clock();
+ cpu_time_used = ((double)(end - start)) / CLOCKS_PER_SEC;
+ G_message("Using SEG: %g", cpu_time_used);
+ start = clock();
+ //~ temp = files->iseg[12][12];
+ end = clock();
+ G_message("Using array in RAM: %g", cpu_time_used);
+ get = &get_segID_SEG;
+ start = clock();
+ temp = get(files, 12, 12);
+ end = clock();
+ G_message("Using SEG w/ get(): %g", cpu_time_used);
+ get = &get_segID_RAM;
+ start = clock();
+ end = clock();
+ G_message("Using RAM w/ get(): %g", cpu_time_used);
+ G_message("to check storage requirements... system dependent... :");
+ G_message("unsigned char: %lu", sizeof(unsigned char));
+ G_message("unsigned char pointer: %lu", sizeof(unsigned char *));
+ G_message("int: %lu", sizeof(int));
+ G_message("unsigned int: %lu", sizeof(unsigned int));
+ G_message("double: %lu", sizeof(double));
+ max = 100000;
+ { /* compare rbtree with linked list and array */
+ n = 100;
+ start = clock();
+ no_check_tree = rbtree_create(compare_ids, sizeof(struct pixels));
+ /*build */
+ for (j = 0; j < n; j++) {
+ tree_pix = (struct pixels *)link_new(files->token);
+ tree_pix->row = tree_pix->col = j;
+ rbtree_insert(no_check_tree, &tree_pix);
+ /*access */
+ if (rbtree_find(no_check_tree, &tree_pix))
+ continue; /* always looking for the same pixel...is this an easy or hard one to find? */
+ /*free memory */
+ rbtree_destroy(no_check_tree);
+ end = clock();
+ G_message
+ ("Using rbtree of pixels ( build/find/destroy), %d elements, time: %g",
+ n, cpu_time_used);
+ start = clock();
+ known_iseg_tree = rbtree_create(compare_ids, sizeof(int));
+ /*build */
+ rbtree_insert(known_iseg_tree, &j);
+ /*access */
+ if (rbtree_find(known_iseg_tree, &j))
+ continue;
+ /*free memory */
+ rbtree_destroy(known_iseg_tree);
+ end = clock();
+ G_message
+ ("Using rbtree ints ( build/find/destroy), %d elements, time: %g",
+ to_check = NULL;
+ start = clock();
+ /*build */
+ newpixel->next = to_check; /*point the new pixel to the current first pixel */
+ newpixel->row = j;
+ newpixel->col = i;
+ to_check = newpixel; /*change the first pixel to be the new pixel. */
+ /*access */
+ for (current = to_check; current != NULL; current = current->next) { /* for each of Ri's neighbors */
+ temp = current->row;
+ /*free memory */
+ my_dispose_list(files->token, &to_check);
+ end = clock();
+ G_message
+ ("Using linked list and linkm (build/access/free), %d elements, time: %g",
+ n = 1000;
+ /* repeat for both with larger membership */
+ start = clock();
+ /*build */
+ /*access */
+ continue;
+ /*free memory */
+ end = clock();
+ G_message("Using rbtree ints, %d elements, time: %g", n,
+ cpu_time_used);
+ to_check = NULL;
+ start = clock();
+ /*build */
+ /*access */
+ /*free memory */
+ end = clock();
+ G_message("Using linked list and linkm, %d elements, time: %g", n,
+ cpu_time_used);
+ k = 100;
+ n = 50;
+ check_flag = flag_create(k, k);
+ start = clock();
+ /*set to zero */
+ flag_clear_all(check_flag);
+ /*write and access */
+ FLAG_SET(check_flag, j, j);
+ temp = FLAG_GET(check_flag, j, j);
+ end = clock();
+ G_message
+ ("Using %d pixel flag array (all cleared), %d elements set and get, time: %g",
+ k * k, n, cpu_time_used);
+ k = 10000;
+ start = clock();
+ /*set to zero */
+ end = clock();
+ G_message
+ /* iff bounding constraints have been given, need to confirm neighbors are in the same area.
+ * Faster to check if the bounds map is null, or if no bounds just set all the bounds flags to 1 and directly check the bounds flag? */
+ max = INT_MAX;
+ j = 0;
+ G_message("compare if statement to FLAG_GET, repeating %d times",
+ max);
+ G_message("Flag = %d", FLAG_GET(files->candidate_flag, 1, 1));
+ start = clock();
+ if ((FLAG_GET(files->candidate_flag, 1, 1)) != 0) {
+ j++;
+ end = clock();
+ G_message("FLAG_GET: %g, temp: %d", cpu_time_used, j);
+ j = 0;
+ start = clock();
+ if (files->bounds_map != NULL) {
+ j++;
+ end = clock();
+ G_message("check for NULL: %g, temp: %d", cpu_time_used, j); /* was faster by about 20% */
+ /* is accessing a variable different then a value? */
+ max = INT_MAX;
+ j = k = 0;
+ G_message("compare variable to number, repeating %d times", max);
+ start = clock();
+ if (i > 0) {
+ j++;
+ end = clock();
+ G_message("compare to zero: %g, temp: %d", cpu_time_used, j);
+ j = 0;
+ start = clock();
+ if (i > k) {
+ j++;
+ end = clock();
+ G_message("compare to k: %g, temp: %d", cpu_time_used, j); /* was faster by about 20% */
+ return TRUE;
+int get_segID_SEG(struct files *files, int row, int col)
+ segment_get(&files->bands_seg, (void *)files->bands_val, row, col);
+ return files->bands_val[0]; /* for accurate comparison, is converting double to int a time penalty? */
+int get_segID_RAM(struct files *files, int row, int col)
+ return 0; //files->iseg[row][col];
+#endif
Modified: grass-addons/grass7/imagery/i.segment/write_output.c
--- grass-addons/grass7/imagery/i.segment/write_output.c 2012-08-16 16:06:06 UTC (rev 52684)
+++ grass-addons/grass7/imagery/i.segment/write_output.c 2012-08-17 04:39:28 UTC (rev 52685)
@@ -60,7 +60,7 @@
/* set colors */
Rast_init_colors(&colors);
- Rast_make_random_colors(&colors, 1, files->nrows * files->ncols); /* TODO polish - number segments from 1 - max ? and then can use that max here. */
+ Rast_make_random_colors(&colors, 1, files->nrows * files->ncols);
Rast_write_colors(files->out_name, G_mapset(), &colors);
/* add command line to history */
