[GRASS-SVN] r52689 - in grass/branches/develbranch_6/gui/wxpython: gui_core lmgr
svn_grass at osgeo.org
Fri Aug 17 04:42:55 PDT 2012
Author: annakrat
Date: 2012-08-17 04:42:55 -0700 (Fri, 17 Aug 2012)
New Revision: 52689
grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py
wxGUI/lmgr: add apply button to opacity dialog (merge from trunk, r52687)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py 2012-08-17 10:13:50 UTC (rev 52688)
+++ grass/branches/develbranch_6/gui/wxpython/gui_core/dialogs.py 2012-08-17 11:42:55 UTC (rev 52689)
@@ -37,6 +37,7 @@
import wx
import wx.lib.filebrowsebutton as filebrowse
import wx.lib.mixins.listctrl as listmix
+from wx.lib.newevent import NewEvent
from grass.script import core as grass
from grass.script import task as gtask
@@ -50,6 +51,8 @@
from core.settings import UserSettings
from core.debug import Debug
+wxApplyOpacity, EVT_APPLY_OPACITY = NewEvent()
class ElementDialog(wx.Dialog):
def __init__(self, parent, title, label, id = wx.ID_ANY,
etype = False, style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER,
@@ -2048,6 +2051,10 @@
btnCancel = wx.Button(parent = panel, id = wx.ID_CANCEL)
btnsizer.AddButton(btnCancel)
+ btnApply = wx.Button(parent = panel, id = wx.ID_APPLY)
+ btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
+ btnsizer.AddButton(btnApply)
btnsizer.Realize()
sizer.Add(item = btnsizer, proportion = 0,
@@ -2066,6 +2073,10 @@
opacity = float(self.value.GetValue()) / 100
return opacity
+ def OnApply(self, event):
+ event = wxApplyOpacity(value = self.GetOpacity())
+ wx.PostEvent(self, event)
def GetImageHandlers(image):
"""!Get list of supported image handlers"""
lext = list()
Modified: grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py 2012-08-17 10:13:50 UTC (rev 52688)
+++ grass/branches/develbranch_6/gui/wxpython/lmgr/layertree.py 2012-08-17 11:42:55 UTC (rev 52689)
@@ -30,7 +30,7 @@
from core import globalvar
-from gui_core.dialogs import SetOpacityDialog
+from gui_core.dialogs import SetOpacityDialog, EVT_APPLY_OPACITY
from gui_core.forms import GUI
from mapdisp.frame import MapFrame
from core.render import Map
@@ -644,23 +644,38 @@
dlg = SetOpacityDialog(self, opacity = current_opacity,
title = _("Set opacity of <%s>") % maplayer.GetName())
dlg.CentreOnParent()
+ dlg.Bind(EVT_APPLY_OPACITY, self.OnApplyLayerOpacity)
if dlg.ShowModal() == wx.ID_OK:
- new_opacity = dlg.GetOpacity() # string
- self.Map.ChangeOpacity(maplayer, new_opacity)
- maplayer.SetOpacity(new_opacity)
- self.SetItemText(self.layer_selected,
- self._getLayerName(self.layer_selected))
+ self.ChangeLayerOpacity(layer = self.layer_selected, value = dlg.GetOpacity())
+ dlg.Destroy()
+ def OnApplyLayerOpacity(self, event):
+ """!Handles EVT_APPLY_OPACITY event."""
+ self.ChangeLayerOpacity(layer = self.layer_selected, value = event.value)
+ def ChangeLayerOpacity(self, layer, value):
+ """!Change opacity value of layer
+ @param layer layer for which to change (item in layertree)
+ @param value opacity value (float between 0 and 1)
+ maplayer = self.GetPyData(layer)[0]['maplayer']
+ self.Map.ChangeOpacity(maplayer, value)
+ maplayer.SetOpacity(value)
+ self.SetItemText(layer,
+ self._getLayerName(layer))
+ # vector layer currently edited
+ if self.GetMapDisplay().GetToolbar('vdigit') and \
+ self.GetMapDisplay().GetToolbar('vdigit').GetLayer() == maplayer:
+ alpha = int(value * 255)
+ self.GetMapDisplay().GetWindow().digit.GetDisplay().UpdateSettings(alpha = alpha)
- # vector layer currently edited
- if self.mapdisplay.GetToolbar('vdigit') and \
- self.mapdisplay.GetToolbar('vdigit').GetLayer() == maplayer:
- alpha = int(new_opacity * 255)
- self.mapdisplay.GetWindow().digit.GetDisplay().UpdateSettings(alpha = alpha)
- # redraw map if auto-rendering is enabled
- self.rerender = True
- self.reorder = True
+ # redraw map if auto-rendering is enabled
+ renderVector = False
+ if self.GetMapDisplay().GetToolbar('vdigit'):
+ renderVector = True
+ self.GetMapDisplay().GetWindow().UpdateMap(render = False, renderVector = renderVector)
def OnNvizProperties(self, event):
"""!Nviz-related properties (raster/vector/volume)
