[GRASS-SVN] r52716 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Fri Aug 17 08:52:21 PDT 2012
Author: turek
Date: 2012-08-17 08:52:20 -0700 (Fri, 17 Aug 2012)
New Revision: 52716
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
vnet: Added statusbar, other minor changes
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-17 15:38:27 UTC (rev 52715)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-17 15:52:20 UTC (rev 52716)
@@ -7,9 +7,11 @@
- dialogs::VNETDialog
- dialogs::PtsList
- dialogs::SettingsDialog
+ - dialogs::AddLayerDialog
- dialogs::VnetTmpVectMaps
- dialogs::VectMap
- dialogs::History
+ - dialogs::VnetStatusbar
(C) 2012 by the GRASS Development Team
@@ -57,10 +59,9 @@
# tmp maps add number of process
# destructor problem
class VNETDialog(wx.Dialog):
def __init__(self, parent,
- id = wx.ID_ANY, title = _("GRASS GIS Vector network analysis"),
+ id = wx.ID_ANY, title = _("GRASS GIS Vector Network Analysis Tool"),
style = wx.DEFAULT_DIALOG_STYLE | wx.RESIZE_BORDER, **kwargs):
"""!Dialog for vector network analysis"""
@@ -115,6 +116,10 @@
style = FN.FNB_FANCY_TABS | FN.FNB_BOTTOM |
FN.FNB_NO_X_BUTTON)
+ self.stPriorities = {'important' : 5, 'iformation' : 1}
+ self.stBar = VnetStatusbar(parent = self.mainPanel, style = 0)
+ self.stBar.SetFieldsCount(number = 1)
# Creates tabs
self._createPointsPage()
self._createParametersPage()
@@ -124,7 +129,6 @@
self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
self._addPanes()
self._doDialogLayout()
@@ -187,14 +191,15 @@
Center().
Dockable(False).
CloseButton(False).Layer(0))
def _doDialogLayout(self):
sizer = wx.BoxSizer(wx.VERTICAL)
sizer.Add(item = self.notebook, proportion = 1,
flag = wx.EXPAND)
+ sizer.Add(item = self.stBar, proportion = 0)
self.mainPanel.SetSizer(sizer)
sizer.Fit(self)
@@ -363,7 +368,7 @@
name = dataSel[0])
label[dataSel[0]].SetLabel(dataSel[1])
- self.inputData['input'].Bind(wx.EVT_TEXT, self.OnVectSel) # TODO optimization
+ self.inputData['input'].Bind(wx.EVT_TEXT, self.OnVectSel)
self.inputData['alayer'].Bind(wx.EVT_TEXT, self.OnALayerSel)
self.inputData['nlayer'].Bind(wx.EVT_TEXT, self.OnNLayerSel)
@@ -483,12 +488,29 @@
self.notebook.RemovePage(page = 'resultDbMgr')
def OnPageChanged(self, event):
+ if event.GetEventObject() == self.notebook:
+ dbMgrIndxs = []
+ dbMgrIndxs.append(self.notebook.GetPageIndexByName('inputDbMgr'))
+ dbMgrIndxs.append(self.notebook.GetPageIndexByName('resultDbMgr'))
+ if self.notebook.GetSelection() in dbMgrIndxs:
+ self.stBar.AddStatusItem(text = _('Loading tables'),
+ key = 'dbMgr',
+ priority = self.stPriorities['important'])
+ self._updateDbMgrData()
+ self.stBar.RemoveStatusItem(key = 'dbMgr')
- if event.GetSelection() != self.notebook.GetPageIndexByName('inputDbMgr'):
- pass
- elif self.inpDbMgrData['input'] != self.inputData['input'].GetValue().strip():
+ def _updateDbMgrData(self):
+ if self.notebook.GetSelection() == self.notebook.GetPageIndexByName('inputDbMgr'):
+ self._updateInputDbMgrData()
+ elif self.notebook.GetSelection() == self.notebook.GetPageIndexByName('resultDbMgr'):
+ self._updateResultDbMgrData()
+ else:
+ self.stBar.RemoveStatusItem('manager')
+ def _updateInputDbMgrData(self):
+ inpSel = self.inputData['input'].GetValue().strip()
+ if self.inpDbMgrData['input'] != inpSel:
wx.BeginBusyCursor()
- inpSel = self.inputData['input'].GetValue().strip()
self.inpDbMgrData['dbMgr'].ChangeVectorMap(vectorName = inpSel)
self.inpDbMgrData['input'] = inpSel
for layerName in ['alayer', 'nlayer']:
@@ -520,8 +542,9 @@
if layer not in needLayers:
self.inpDbMgrData['browse'].DeletePage(layer)
- if event.GetSelection() != self.notebook.GetPageIndexByName('resultDbMgr') or \
- not self.tmp_result:
+ def _updateResultDbMgrData(self):
+ if not self.tmp_result:
pass
elif self.resultDbMgrData['input'] != self.tmp_result.GetVectMapName():
@@ -531,7 +554,6 @@
self.resultDbMgrData['browse'].AddLayer(layer)
self.resultDbMgrData['input'] = self.tmp_result.GetVectMapName()
wx.EndBusyCursor()
def OnToTreeBtn(self, event):
"""!Adds vector map into layer tree (button next to map select)"""
@@ -864,9 +886,12 @@
return
elif not self.CheckAnMapState(self.tmp_result):
return
+ self.stBar.AddStatusItem(text = _('Analysing'),
+ key = 'analyze',
self._saveAnInputToHist()
self.resultDbMgrData['analysis'] = self.currAnModule
# Creates part of cmd fro analysis
@@ -932,10 +957,12 @@
self.tmp_result.SaveVectMapState()
self._updateResultDbMgrPage()
cmd = self.GetLayerStyle()
self.tmp_result.AddRenderLayer(cmd)
self.mapWin.UpdateMap(render=True, renderVector=True)
+ self.stBar.RemoveStatusItem(key = 'analyze')
def _runAn(self, cmdParams, catPts):
"""!Called for all v.net.* analysis (except v.net.path)"""
@@ -1016,7 +1043,7 @@
cmdVNet = [
"v.net",
"points=" + self.tmpInPts.GetVectMapName(),
- "input=" + self.inputData["input"].GetValue(),
+ "input=" + self.inputData['input'].GetValue(),
"output=" + self.tmpInPtsConnected.GetVectMapName(),
"alayer=" + self.inputData["alayer"].GetValue().strip(),
"nlayer=" + self.inputData["nlayer"].GetValue().strip(),
@@ -1040,10 +1067,12 @@
def _getInputParams(self):
inParams = []
@@ -1334,6 +1363,8 @@
if self.tmpMaps.HasTmpVectMap("vnet_snap_points"):
self.snapPts.DeleteRenderLayer()
self.mapWin.UpdateMap(render = False, renderVector = False)
+ if self.snapData.has_key('cmdThread'):
+ self.snapData['cmdThread'].abort()
self.snapping = False
return
@@ -1374,9 +1405,9 @@
self.snapping = True
currMapSet = grass.gisenv()['MAPSET']
- inpName = self.inputData["input"].GetValue()
- inpFullName = inpName + "@" + currMapSet
+ inpName = self.inputData['input'].GetValue()
+ inpName, mapSet = self._parseMapStr(inpName)
+ inpFullName = inpName + '@' + mapSet
computeNodes = True
if not self.snapData:
@@ -1388,17 +1419,23 @@
computeNodes = False
if computeNodes:
- self.cmdThread = CmdThread(self)
+ self.stBar.AddStatusItem(text = _('Computing nodes'),
+ key = 'snap',
+ if not self.snapData.has_key('cmdThread'):
+ self.snapData['cmdThread'] = CmdThread(self)
- cmd = ["v.to.points", "input=" + self.inputData["input"].GetValue(),
+ cmd = ["v.to.points", "input=" + self.inputData['input'].GetValue(),
"output=" + self.snapPts.GetVectMapName(),
"llayer=" + self.inputData["nlayer"].GetValue(),
"-n", "--overwrite"]
# process GRASS command with argument
+ self.snapData["inputMap"] = VectMap(self, inpFullName)
+ self.snapData["inputMap"].SaveVectMapState()
self.Bind(EVT_CMD_DONE, self._onToPointsDone)
- self.cmdThread.RunCmd(cmd)
+ self.snapData['cmdThread'].RunCmd(cmd)
- self.snapData["inputMap"] = VectMap(self, inpFullName)
self.snapData["inputMapNlayer"] = self.inputData["nlayer"].GetValue()
else:
self.snapPts.AddRenderLayer()
@@ -1406,11 +1443,12 @@
def _onToPointsDone(self, event):
+ self.stBar.RemoveStatusItem(key = 'snap')
+ if not event.aborted:
+ self.snapPts.SaveVectMapState()
+ self.snapPts.AddRenderLayer()
+ self.mapWin.UpdateMap(render = True, renderVector = True)
- self.snapPts.SaveVectMapState()
- self.snapPts.AddRenderLayer()
- self.mapWin.UpdateMap(render = True, renderVector = True)
def OnUndo(self, event):
histStepData = self.history.GetPrev()
self.toolbars['mainToolbar'].UpdateUndoRedo()
@@ -1485,7 +1523,7 @@
tmpMap = self.tmpMaps.GetTmpVectMap(vectMapName)
self.tmpMaps.DeleteTmpMap(tmpMap)
- def _updateHistStepData(self, histStepData):#TODO need optimization
+ def _updateHistStepData(self, histStepData):
self.currAnModule = histStepData["vnet_modules"]["curr_module"]
anChoice = self.toolbars['mainToolbar'].anChoice
@@ -1519,7 +1557,7 @@
if "vnet_tmp_result" in vectMapName:
self.tmp_result.DeleteRenderLayer()
self.tmp_result = self.tmpMaps.GetTmpVectMap(vectMapName)
- if self.tmp_result.VectMapState() == 0:#TODO test only 0
+ if self.tmp_result.VectMapState() == 0:
dlg = wx.MessageDialog(parent = self,
message = _("Temporary map '%s' with result " +
"was changed outside vector network analysis tool.\n" +
@@ -1559,7 +1597,7 @@
dlg.Destroy()
- self._updateResultDbMgrPage()
self.list.SetUpdateMap(updateMap = True)
@@ -2530,6 +2568,56 @@
histStepData[key][subkey] = value
idx += 2
+class VnetStatusbar(wx.StatusBar):
+ def __init__(self, parent, style, id = wx.ID_ANY, **kwargs):
+ wx.StatusBar.__init__(self, parent, id, style, **kwargs)
+ self.maxPriority = 0
+ self.statusItems = []
+ def AddStatusItem(self, text, key, priority):
+ statusTextItem = {
+ 'text' : text,
+ 'key' : key,
+ 'priority' : priority
+ for item in self.statusItems:
+ if item['key'] == statusTextItem['key']:
+ self.statusItems.remove(item)
+ self.statusItems.append(statusTextItem)
+ if self.maxPriority < statusTextItem['priority']:
+ self.maxPriority = statusTextItem['priority']
+ self._updateStatus()
+ def _updateStatus(self):
+ currStatusText = ''
+ for item in reversed(self.statusItems):
+ if item['priority'] == self.maxPriority:
+ if currStatusText:
+ currStatusText += '; '
+ currStatusText += item['text']
+ wx.StatusBar.SetStatusText(self, currStatusText)
+ def RemoveStatusItem(self, key):
+ update = False
+ for iItem, item in enumerate(self.statusItems):
+ if item['key'] == key:
+ update = True
+ self.statusItems.pop(iItem)
+ if update:
+ if self.maxPriority < item['priority']:
+ self.maxPriority = item['priority']
#TODO ugly hack - just for GMConsole to be satisfied
class CmdPanelHack:
def createCmd(self, ignoreErrors = False, ignoreRequired = False):
