[GRASS-SVN] r52741 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Sun Aug 19 16:07:43 PDT 2012
Author: turek
Date: 2012-08-19 16:07:43 -0700 (Sun, 19 Aug 2012)
New Revision: 52741
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
vnet: Layout changed, bugs fixing, added hidden columns into history, added comments, small improvements
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-19 22:57:53 UTC (rev 52740)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-19 23:07:43 UTC (rev 52741)
@@ -50,7 +50,7 @@
from gui_core.gselect import Select, LayerSelect, ColumnSelect
from vnet.widgets import PointsList
-from vnet.toolbars import MainToolbar, PointListToolbar
+from vnet.toolbars import MainToolbar, PointListToolbar, AnalysisToolbar
#Main TODOs
# when layer tree is lmgr is changed, tmp layer is removed from render list
@@ -67,21 +67,29 @@
"""!Dialog for vector network analysis"""
wx.Dialog.__init__(self, parent, id, style=style, title = title, **kwargs)
+ self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
- self.parent = parent # mapdisp.frame MapFrame
- self.mapWin = parent.MapWindow
- self.inputData = {}
- self.cmdParams = {}
- self.snapData = {}
- self.snapping = False
- self.tmp_result = None
+ self.parent = parent # mapdisp.frame MapFrame class
+ self.mapWin = parent.MapWindow
+ # contains current analysis result (do not have to be last one, when is history browsed),
+ # it is instance of VectMap class
+ self.tmp_result = None
+ # initialization of History class used for saving and reading data from file
+ # used for browsing analysis results
self.history = History(self)
+ # variable, which appends unique number to every name of map, which is saved into history
self.histTmpVectMapNum = 0
+ # list of maps, which will be saved into history
self.tmpVectMapsToHist = []
+ # this class instance manages all temporary vector maps created during life of VNETDialog
self.tmpMaps = VnetTmpVectMaps(parent = self)
+ # setting initialization
self._initSettings()
# registration graphics for drawing
@@ -89,26 +97,28 @@
setStatusFunc = self.SetPointStatus)
self.SetPointDrawSettings()
- # getting attribute table columns only with numbers (costs)
+ # information, whether mouse event handler is registered in map window
+ self.handlerRegistered = False
+ # get attribute table columns only with numbers (for cost culumns in vnet analysis)
self.columnTypes = ['integer', 'double precision']
- self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
- # initialization of v.net.* analysis parameters
+ # initialization of v.net.* analysis parameters (data which characterizes particular analysis)
self._initVnetParams()
# toobars
self.toolbars = {}
self.toolbars['mainToolbar'] = MainToolbar(parent = self)
+ self.toolbars['analysisToolbar'] = AnalysisToolbar(parent = self)
# Fancy gui
self._mgr = wx.aui.AuiManager(self)
# Columns in points list
+ # TODO init dynamically, not hard typed v.net.path
self.cols = [
- ['type', _('type'), [_(""), _("Start point"), _("End point")], 0], #TODO init dynamically
+ ['type', _('type'), [_(""), _("Start point"), _("End point")], 0],
['topology', _('topology'), None, ""]
@@ -117,39 +127,55 @@
style = FN.FNB_FANCY_TABS | FN.FNB_BOTTOM |
FN.FNB_NO_X_BUTTON)
+ # statusbar
self.stPriorities = {'important' : 5, 'iformation' : 1}
self.stBar = VnetStatusbar(parent = self.mainPanel, style = 0)
self.stBar.SetFieldsCount(number = 1)
- # Creates tabs
+ # Create tabs
+ # Stores all data related to snapping
+ self.snapData = {}
+ self.snapData['snap_mode'] = False
+ # Stores widgets which sets analysis parameters (e. g. v.ne..iso -> costs)
+ self.anSettings = {}
self._createPointsPage()
+ # stores widgets which are shown on parameters page
+ # they set data, on which analysis will be done
+ self.inputData = {}
self._createParametersPage()
+ # Output console for analysis
self._createOutputPage()
+ # Stores data which are need for attribute table browser of analysis input map layers
+ self.inpDbMgrData = {}
self._createInputDbMgrPage()
+ # Stores data which are need for attribute table browser of analysis result map layers
+ self.resultDbMgrData = {}
self._createResultDbMgrPage()
self.Bind(FN.EVT_FLATNOTEBOOK_PAGE_CHANGED, self.OnPageChanged)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
self._addPanes()
- self._doDialogLayout()
+ self._doVnetDialogLayout()
self._mgr.Update()
- self.handlerRegistered = False
- self.tmpResultLayer = None
# adds 2 points into list
for i in range(2):
self.list.AddItem()
- self.list.EditCellIndex(i, 'type', self.cols[1][2][1 + i])
+ self.list.EditCellIndex(i, 'type', i + 1)
self.list.CheckItem(i, True)
# selects first point
self.list.selected = 0
self.list.Select(self.list.selected)
- self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
- dlgSize = (400, 520)
+ dlgSize = (420, 560)
self.SetMinSize(dlgSize)
self.SetInitialSize(dlgSize)
@@ -159,6 +185,7 @@
self.OnAnalysisChanged(None)
self.notebook.SetSelectionByName("parameters")
+ self.toolbars['analysisToolbar'].SetMinSize((-1, self.toolbars['mainToolbar'].GetSize()[1]))
def __del__(self):
"""!Removes temp layers, unregisters handlers and graphics"""
@@ -182,9 +209,16 @@
self._mgr.AddPane(self.toolbars['mainToolbar'],
wx.aui.AuiPaneInfo().
Name("pointlisttools").Caption(_("Point list toolbar")).
- ToolbarPane().Top().
+ ToolbarPane().Top().Row(0).
Dockable(False).
CloseButton(False).Layer(0))
+ self._mgr.AddPane(self.toolbars['analysisToolbar'],
+ wx.aui.AuiPaneInfo().
+ Name("pointlisttools").Caption(_("Point list toolbar")).
+ ToolbarPane().Top().Row(1).
+ Dockable(False).
+ CloseButton(False).Layer(0))
self._mgr.AddPane(self.mainPanel,
@@ -192,7 +226,7 @@
Center().
Dockable(False).
- def _doDialogLayout(self):
+ def _doVnetDialogLayout(self):
sizer = wx.BoxSizer(wx.VERTICAL)
@@ -210,7 +244,6 @@
"""!Tab with points list and analysis settings"""
pointsPanel = wx.Panel(parent = self)
- self.anSettings = {} #TODO
maxValue = 1e8
listBox = wx.StaticBox(parent = pointsPanel, id = wx.ID_ANY,
@@ -228,16 +261,9 @@
anSettingsBox = wx.StaticBox(parent = anSettingsPanel, id = wx.ID_ANY,
label =" %s " % _("Analysis settings:"))
- #lineIdPanel = wx.Panel(parent = anSettingsPanel)
- #lineIdLabel = wx.StaticText(parent = lineIdPanel, id = wx.ID_ANY, label =_("Id of line:"))
- #elf.anSettings["line_id"] = wx.SpinCtrl(parent = lineIdPanel, id = wx.ID_ANY, min = 1, max = maxValue)
- #resId = int(UserSettings.Get(group ='vnet', key ='analysis_settings', subkey = 'resultId'))
- #self.anSettings["line_id"].SetValue(resId)
maxDistPanel = wx.Panel(parent = anSettingsPanel)
maxDistLabel = wx.StaticText(parent = maxDistPanel, id = wx.ID_ANY, label = _("Maximum distance of point to the network:"))
self.anSettings["max_dist"] = wx.SpinCtrl(parent = maxDistPanel, id = wx.ID_ANY, min = 0, max = maxValue) #TODO
- #maxDist = int(UserSettings.Get(group = 'vnet', key = 'analysis_settings', subkey ='maxDist'))
self.anSettings["max_dist"].SetValue(100000) #TODO init val
#showCutPanel = wx.Panel(parent = anSettingsPanel)
@@ -260,13 +286,6 @@
anSettingsSizer = wx.StaticBoxSizer(anSettingsBox, wx.VERTICAL)
- #lineIdSizer = wx.BoxSizer(wx.HORIZONTAL)
- #lineIdSizer.Add(item = lineIdLabel, flag = wx.EXPAND | wx.ALL, border = 5, proportion = 0)
- #lineIdSizer.Add(item = self.anSettings["line_id"],
- # flag = wx.EXPAND | wx.ALL, border = 5, proportion = 0)
- #lineIdPanel.SetSizer(lineIdSizer)
- #anSettingsSizer.Add(item = lineIdPanel, proportion = 1, flag = wx.EXPAND)
maxDistSizer = wx.BoxSizer(wx.HORIZONTAL)
maxDistSizer.Add(item = maxDistLabel, flag = wx.ALIGN_CENTER_VERTICAL, proportion = 1)
maxDistSizer.Add(item = self.anSettings["max_dist"],
@@ -296,7 +315,7 @@
def OnShowCut(self, event):
"""!Shows vector map with minimal cut (v.net.flow) - not yet implemented"""
val = event.IsChecked()
- if val:
+ if val and self.tmp_result:
self.tmp_result.DeleteRenderLayer()
cmd = self.GetLayerStyle()
self.vnetFlowTmpCut.AddRenderLayer(cmd)
@@ -321,10 +340,9 @@
self.goutput = GMConsole(parent = outputPanel, margin = False)
+ #Layout
outputSizer = wx.BoxSizer(wx.VERTICAL)
outputSizer.Add(item = self.goutput, proportion = 1, flag = wx.EXPAND)
- # overridden outputSizer.SetSizeHints(self) in GMConsole _layout
self.goutput.SetMinSize((-1,-1))
outputPanel.SetSizer(outputSizer)
@@ -406,7 +424,7 @@
dataPanel.SetSizer(mainSizer)
def _doSelLayout(self, title, sel, btn = None):
+ # helper function for layout of self.inputData widgets initialized in _createParametersPage
selSizer = wx.BoxSizer(orient = wx.VERTICAL)
selTitleSizer = wx.BoxSizer(wx.HORIZONTAL)
@@ -434,12 +452,11 @@
return selSizer
def _createInputDbMgrPage(self):
- self.inpDbMgrData = {}
+ """!Tab with attribute tables of analysis input layers"""
self.inpDbMgrData['dbMgr'] = DbMgrBase()
selMapName = None
- # if selected vector map in layer tree then set it
+ # if selected vector map is in layer tree then set it
if self.mapWin.tree and self.mapWin.tree.layer_selected:
selMapData = self.mapWin.tree.GetPyData(self.mapWin.tree.layer_selected)[0]
if selMapData['type'] == 'vector': # wrap somehow in LayerTree
@@ -455,7 +472,7 @@
self.OnVectSel(None)
def _updateInputDbMgrPage(self, show):
+ """!Show or Hide Input tables tab"""
if show and self.notebook.GetPageIndexByName('inputDbMgr') == -1:
self.notebook.AddPage(page = self.inpDbMgrData['browse'],
text=_('Input tables'),
@@ -464,8 +481,7 @@
self.notebook.RemovePage(page = 'inputDbMgr')
def _createResultDbMgrPage(self):
- self.resultDbMgrData = {}
+ """!Tab with attribute tables of analysis result layers"""
self.resultDbMgrData['dbMgr'] = DbMgrBase()
self.resultDbMgrData['browse'] = self.resultDbMgrData['dbMgr'].CreateDbMgrPage(parent = self.notebook,
pageName = 'browse')
@@ -477,8 +493,10 @@
self.resultDbMgrData['input'] = None
def _updateResultDbMgrPage(self):
+ """!Show or Hide Result tables tab"""
+ # analysis, which created result
analysis = self.resultDbMgrData['analysis']
+ #TODO maybe no need to store this information, just check it has attr table, if so show it
haveDbMgr = self.vnetParams[analysis]["resultProps"]["dbMgr"]
if haveDbMgr and self.notebook.GetPageIndexByName('resultDbMgr') == -1:
@@ -489,6 +507,7 @@
self.notebook.RemovePage(page = 'resultDbMgr')
def OnPageChanged(self, event):
+ """!Tab switched"""
if event.GetEventObject() == self.notebook:
dbMgrIndxs = []
dbMgrIndxs.append(self.notebook.GetPageIndexByName('inputDbMgr'))
@@ -499,8 +518,13 @@
priority = self.stPriorities['important'])
self._updateDbMgrData()
self.stBar.RemoveStatusItem(key = 'dbMgr')
+ # update of columns (when some is added in input tables browser), TODO needs optimization
+ elif self.notebook.GetSelection() == self.notebook.GetPageIndexByName('parameters'):
+ self.OnALayerSel(None)
+ self.OnNLayerSel(None)
def _updateDbMgrData(self):
+ """!Updates input/result tables page """
if self.notebook.GetSelection() == self.notebook.GetPageIndexByName('inputDbMgr'):
self._updateInputDbMgrData()
elif self.notebook.GetSelection() == self.notebook.GetPageIndexByName('resultDbMgr'):
@@ -509,7 +533,9 @@
self.stBar.RemoveStatusItem('manager')
def _updateInputDbMgrData(self):
+ """!Loads data according to selected layers in Parameters tab"""
inpSel = self.inputData['input'].GetValue().strip()
+ # changed vector map
if self.inpDbMgrData['input'] != inpSel:
wx.BeginBusyCursor()
self.inpDbMgrData['dbMgr'].ChangeVectorMap(vectorName = inpSel)
@@ -521,6 +547,7 @@
continue
self.inpDbMgrData['browse'].AddLayer(layer)
wx.EndBusyCursor()
+ # same vector map
else:
needLayers = []
browseLayers = self.inpDbMgrData['browse'].GetAddedLayers()
@@ -544,20 +571,24 @@
self.inpDbMgrData['browse'].DeletePage(layer)
def _updateResultDbMgrData(self):
+ """!Loads data from analysis result map"""
+ if not self.tmp_result:
+ return
+ vectName = self.tmp_result.GetVectMapName()
- if not self.tmp_result:
- pass
- elif self.resultDbMgrData['input'] != self.tmp_result.GetVectMapName():
+ if self.resultDbMgrData['input'] != vectName:
- vectName = self.tmp_result.GetVectMapName()
- self.resultDbMgrData['dbMgr'].ChangeVectorMap(vectorName = self.tmp_result.GetVectMapName())
- for layer in self.resultDbMgrData['dbMgr'].GetVectorLayers():
+ dbMgr = self.resultDbMgrData['dbMgr']
+ dbMgr.ChangeVectorMap(vectorName = vectName)
+ for layer in dbMgr.GetVectorLayers():
self.resultDbMgrData['browse'].AddLayer(layer)
- self.resultDbMgrData['input'] = self.tmp_result.GetVectMapName()
+ self.resultDbMgrData['input'] = vectName
wx.EndBusyCursor()
def OnToTreeBtn(self, event):
- """!Adds vector map into layer tree (button next to map select)"""
+ """!Add vector map into layer tree"""
vectorMap = self.inputData['input'].GetValue()
vectMapName, mapSet = self._parseMapStr(vectorMap)
vectorMap = vectMapName + '@' + mapSet
@@ -577,8 +608,8 @@
lchecked = True)
def OnVectSel(self, event):
- """!When vector map is selected populates other selects (layer selects, columns selects)"""
- if self.snapping:
+ """!When vector map is selected populates other comboboxes in Parametrs tab (layer selects, columns selects)"""
+ if self.snapData['snap_mode']:
self.OnSnapping(event = None)
vectMapName, mapSet = self._parseMapStr(self.inputData['input'].GetValue())
@@ -634,7 +665,7 @@
def OnNLayerSel(self, event):
"""!When node layer from vector map is selected, populates corespondent column select"""
- if self.snapping:
self.inputData['ncolumn'].InsertColumns(vector = self.inputData['input'].GetValue(),
@@ -694,7 +725,7 @@
return mapName, mapSet
- def InputsErrorMsgs(self, strToStart, inpToTest = None):#TODO strToStart don like it
+ def InputsErrorMsgs(self, msg, inpToTest = None):
errInput = self._getInvalidInputs(inpToTest)
@@ -709,7 +740,7 @@
if errMapStr:
GMessage(parent = self,
- message = strToStart + "\n" + errMapStr)
+ message = msg + "\n" + errMapStr)
return False
errLayerStr = ""
@@ -725,7 +756,7 @@
(layerLabel)
if errLayerStr:
- message = strToStart + "\n" + errLayerStr)
+ message = msg + "\n" + errLayerStr)
return False
errColStr = ""
@@ -737,7 +768,7 @@
if errColStr:
- message =strToStart + "\n" + errColStr)
+ message = msg + "\n" + errColStr)
return False
return True
@@ -750,7 +781,7 @@
def SetPointStatus(self, item, itemIndex):
"""!Before point is drawn, decides properties of drawing style"""
key = self.list.GetItemData(itemIndex)
- point = self.list.itemDataMap[key] #TODO public method in list?
+ idxs = self.list.selIdxs[key] #TODO public method in list?
cats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
@@ -760,7 +791,7 @@
wxPen = "unused"
item.hide = False
elif len(cats) > 1:
- if point[1] == cats[1][1]:
+ if idxs[1] == 2: #End/To/Sink point
wxPen = "used2cat"
else:
wxPen = "used1cat"
@@ -789,7 +820,7 @@
index = self.list.selected
key = self.list.GetItemData(index)
- if self.snapping:
coords = [e, n]
if self._snapPoint(coords):
self.list.EditCellKey(key = self.list.selected ,
@@ -816,8 +847,6 @@
self.list.selected += 1
- self.mapWin.UpdateMap(render=False, renderVector=False)
def _snapPoint(self, coords):
e = coords[0]
@@ -875,7 +904,7 @@
def OnAnalyze(self, event):
"""!Called when network analysis is started"""
# Check of parameters for analysis
- if not self.InputsErrorMsgs(strToStart = _("Analysis can not be done.")):
+ if not self.InputsErrorMsgs(msg = _("Analysis can not be done.")):
return
if self.tmp_result:
@@ -891,6 +920,10 @@
self.stBar.AddStatusItem(text = _('Analysing...'),
key = 'analyze',
+ RunCommand('g.remove',
+ vect = self.tmp_result.GetVectMapName())
self._saveAnInputToHist()
self.resultDbMgrData['analysis'] = self.currAnModule
@@ -911,23 +944,17 @@
"""!Called when analysis is run for v.net.path module"""
if len(self.pointsToDraw.GetAllItems()) < 1:
return
- catPts = self._getPtByCat()
cmdPts = []
for cat in cats:
if len(catPts[cat[0]]) < 1:
- message=_("Pleas choose 'to' and 'from' point."))
+ message=_("Please choose '%s' and '%s' point.") % (cats[0][1], cats[1][1]))
return
cmdPts.append(catPts[cat[0]][0])
- resId = 1 #int(UserSettings.Get(group ='vnet',
- # key = 'analysis_settings',
- # subkey = 'resultId'))
+ resId = 1
inpPoints = str(resId) + " " + str(cmdPts[0][0]) + " " + str(cmdPts[0][1]) + \
" " + str(cmdPts[1][0]) + " " + str(cmdPts[1][1])
@@ -938,10 +965,6 @@
cmdParams.append("file=" + self.coordsTmpFile)
- #dmax = int(UserSettings.Get(group = 'vnet',
- # key ='analysis_settings',
- # subkey ='maxDist'))
cmdParams.append("dmax=" + str(self.anSettings["max_dist"].GetValue()))
cmdParams.append("input=" + self.inputData['input'].GetValue())
@@ -963,24 +986,41 @@
self.tmp_result.AddRenderLayer(cmd)
self.mapWin.UpdateMap(render=True, renderVector=True)
+ mainToolbar = self.toolbars['mainToolbar']
+ id = vars(mainToolbar)['showResult']
+ mainToolbar.ToggleTool(id =id,
+ toggle = True)
self.stBar.RemoveStatusItem(key = 'analyze')
def _runAn(self, cmdParams, catPts):
"""!Called for all v.net.* analysis (except v.net.path)"""
- # TODO how to get output in ondone function
- #cmdCategory = [ "v.category",
- # "input=" + self.inputData['input'].GetValue(),
- # "option=report",
- # "-g",
- cats = RunCommand("v.category",
+ cats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
+ if len(cats) > 1:
+ for cat in cats:
+ if len(catPts[cat[0]]) < 1:
+ GMessage(parent = self,
+ message = _("Please choose '%s' and '%s' point.") \
+ % (cats[0][1], cats[1][1]))
+ return
+ else:
+ for cat in cats:
+ if len(catPts[cat[0]]) < 2:
+ message = _("Please choose at least two points."))
+ return
+ # TODO add also to thread for analysis?
+ vcatResult = RunCommand("v.category",
input = self.inputData['input'].GetValue(),
option = "report",
flags = "g",
read = True)
- cats = cats.splitlines()
- for cat in cats:#TODO
+ vcatResult = vcatResult.splitlines()
+ for cat in vcatResult:#TODO
cat = cat.split()
if "all" in cat:
maxCat = int(cat[4])
@@ -992,7 +1032,7 @@
maxCat = maxCat,
layerNum = layerNum)
- self.tmpPtsAsciiFile = grass.tempfile()#TODO tmp files cleanup
+ self.tmpPtsAsciiFile = grass.tempfile()#TODO better tmp files cleanup (when interrupt)
tmpPtsAsciiFileOpened = open(self.tmpPtsAsciiFile, 'w')
tmpPtsAsciiFileOpened.write(pt_ascii)
tmpPtsAsciiFileOpened.close()
@@ -1004,9 +1044,6 @@
self.tmpInPtsConnected = self._addTmpMapAnalysisMsg("vnet_tmp_in_pts_connected")
if not self.tmpInPtsConnected:
return
cmdParams.append("input=" + self.tmpInPtsConnected.GetVectMapName())
cmdParams.append("--overwrite")
@@ -1074,6 +1111,11 @@
+ toggle = True)
def _getInputParams(self):
@@ -1143,13 +1185,12 @@
def CheckAnMapState(self, vectMap):
vectMapState = vectMap.VectMapState()
if vectMapState == 0:
dlg = wx.MessageDialog(parent = self,
message = _("Map %s was changed outside " +
"of vector network analysis tool. " +
"Do you want to continue in analysis and " +
- "overwrite it?") % (self.vectMap.GetVectMapName()),
+ "overwrite it?") % (vectMap.GetVectMapName()),
caption = _("Overwrite map"),
style = wx.YES_NO | wx.NO_DEFAULT |
wx.ICON_QUESTION | wx.CENTRE)
@@ -1196,17 +1237,21 @@
return layerStyleCmd
def OnShowResult(self, event):
- """!Shows, hides analysis result - not yet implemented"""
+ """!Shows, hides analysis result"""
- id = vars(mainToolbar)['showResult'] #TODO
toggleState = mainToolbar.GetToolState(id)
- if toggleState:
+ toggle = False)
+ elif toggleState:
+ self.CheckAnMapState(self.tmp_result)
else:
- self.tmp_result.DeleteRenderLayer(cmd)
+ self.tmp_result.DeleteRenderLayer()
@@ -1296,7 +1341,7 @@
"""!Updates dialog when analysis is changed"""
# finds module name according to value in anChoice
for module, params in self.vnetParams.iteritems():
- chLabel = self.toolbars['mainToolbar'].anChoice.GetValue()
+ chLabel = self.toolbars['analysisToolbar'].anChoice.GetValue()
if params["label"] == chLabel:
self.currAnModule = module
break
@@ -1344,11 +1389,8 @@
if not self.list.IsShown('type'):
self.list.ShowColumn('type', 1)
- prevParamsCats = self.vnetParams[self.prev2catsAnModule]["cmdParams"]["cats"]
currParamsCats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
- self.list._adaptPointsList(currParamsCats, prevParamsCats)
- self.prev2catsAnModule = self.currAnModule
+ self.list.AdaptPointsList(currParamsCats)
else:
if self.list.IsShown('type'):
self.list.HideColumn('type')
@@ -1357,7 +1399,7 @@
ptListToolbar = self.toolbars['pointsList']
if not haveCtypes:
- ptListToolbar.ToggleTool(id = ptListToolbar.GetToolId("snapping"),
+ ptListToolbar.ToggleTool(id = ptListToolbar.GetToolId("snappingsnapping"),
toggle = False)
message = _("Unable to use ctypes. \n") + \
@@ -1373,10 +1415,10 @@
self.mapWin.UpdateMap(render = False, renderVector = False)
if self.snapData.has_key('cmdThread'):
self.snapData['cmdThread'].abort()
return
- if not self.InputsErrorMsgs(strToStart = _("Snapping mode can not be activated."),
+ if not self.InputsErrorMsgs(msg = _("Snapping mode can not be activated."),
inpToTest = ["input", "nlayer"]):
@@ -1410,9 +1452,8 @@
toggle = False)
return
- self.snapping = True
+ self.snapData['snap_mode'] = True
- currMapSet = grass.gisenv()['MAPSET']
inpName = self.inputData['input'].GetValue()
inpName, mapSet = self._parseMapStr(inpName)
inpFullName = inpName + '@' + mapSet
@@ -1483,11 +1524,15 @@
subkey = [ptName, "coords"],
value = coords)
- if self.list.IsShown('type'):
+ if len(self.vnetParams[self.currAnModule]["cmdParams"]["cats"]) > 1:
cat = self.list.GetCellText(iPt, 'type')
self.history.Add(key = "points",
- subkey = [ptName, "cat"],
+ subkey = [ptName, "catIdx"],
value = cat)
+ else:
+ self.history.Add(key = 'points_hidden_cols',
+ subkey = 'type',
+ value = self.list.GetHiddenColSelIdxs('type'))
topology = self.list.GetCellText(iPt, 'topology')
@@ -1501,22 +1546,26 @@
for inpName, inp in self.inputData.iteritems():
if inpName == "input":
- inpMap = VectMap(self, inp.GetValue() + "@" + currMapSet)
+ vectMapName, mapSet = self._parseMapStr(inp.GetValue())
+ vectorMap = vectMapName + '@' + mapSet
+ inpMap = VectMap(self, vectorMap)
self.history.Add(key = "other",
subkey = "input_modified",
value = inpMap.GetLastModified())
self.history.Add(key = "input_data",
subkey = inpName,
value = inp.GetValue())
- #else:
- # self.history.Add(key = "points",
- # subkey = [ptName, "prev2catsAnModule"],
- # value = self.prev2catsAnModule)
- self.history.Add(key = "vnet_modules", subkey = "curr_module", value = self.currAnModule)
+ self.history.Add(key = "vnet_modules",
+ subkey = "curr_module",
+ value = self.currAnModule)
+ for settName, sett in self.anSettings.iteritems():
+ self.history.Add(key = "an_settings",
+ subkey = settName,
+ value = sett.GetValue())
def _saveHistStep(self):
removedHistData = self.history.SaveHistStep()
@@ -1534,13 +1583,19 @@
def _updateHistStepData(self, histStepData):
self.currAnModule = histStepData["vnet_modules"]["curr_module"]
- anChoice = self.toolbars['mainToolbar'].anChoice
- anChoice.SetStringSelection(self.vnetParams[self.currAnModule]["label"]) #TODO
+ anChoice = self.toolbars['analysisToolbar'].anChoice
self.list.SetUpdateMap(updateMap = False)
while self.list.GetSelected() != wx.NOT_FOUND:
self.list.DeleteItem()
+ hasType = True
+ self.list.ShowColumn('type', 1)
+ else:
+ hasType = False
+ self.list.HideColumn('type')
for iPt in range(len(histStepData["points"])):
ptData = histStepData["points"]["pt" + str(iPt)]
@@ -1549,17 +1604,22 @@
item = self.pointsToDraw.GetItem(iPt)
item.SetCoords(coords)
- if ptData.has_key('cat'):
- self.list.ShowColumn('type', 1)
- self.list.EditCellKey(iPt, 'type', ptData["cat"])
- else:
- self.list.HideColumn('type')
+ if hasType:
+ self.list.EditCellKey(iPt, 'type', int(ptData["catIdx"]))
self.list.EditCellKey(iPt, 'topology', ptData["topology"])
if ptData["checked"]:
self.list.CheckItem(iPt, True)
+ if hasType:
+ currParamsCats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
+ else:
+ self.list.SetHiddenSelIdxs('type', histStepData["points_hidden_cols"]["type"])
+ anChoice.SetStringSelection(self.vnetParams[self.currAnModule]["label"])
mapsNames = histStepData["tmp_data"]["maps"]
for vectMapName in mapsNames:
if "vnet_tmp_result" in vectMapName:
@@ -1571,18 +1631,24 @@
histInputData = histStepData["input_data"]
for inpName, inp in histInputData.iteritems():
- self.inputData[inpName].SetValue(str(inp)) #TODO order?
+ self.inputData[inpName].SetValue(str(inp))
inpMap = inp
- prevInpModTime = histStepData["other"]["input_modified"]
+ histAnSettData = histStepData["an_settings"]
+ for settName, sett in histAnSettData.iteritems():
+ if settName == 'iso_lines':
+ sett = str(sett)
+ self.anSettings[settName].SetValue(sett)
+ prevInpModTime = str(histStepData["other"]["input_modified"])
inpMapFullName = inpMap + "@" + grass.gisenv()['MAPSET'] #TODO mapset changed?
currInpModTime = VectMap(self, inpMapFullName).GetLastModified()
- if currInpModTime != prevInpModTime:
+ if currInpModTime.strip()!= prevInpModTime.strip():
message = _("Input map '%s' for analysis was changed outside " +
"vector network analysis tool.\n" +
@@ -1595,6 +1661,7 @@
dlg.Destroy()
+ self._updateResultDbMgrPage()
self.list.SetUpdateMap(updateMap = True)
@@ -1617,6 +1684,7 @@
mapName = prefMapName + str(self.histTmpVectMapNum)
self.histTmpVectMapNum += 1
tmpMap = self._addTmpMapAnalysisMsg(mapName)
if not tmpMap:
return tmpMap
@@ -1630,8 +1698,10 @@
def _addTmpMapAnalysisMsg(self, mapName):
- endStr = _("Do you want to continue in analysis and overwrite it?")#TODO
- tmpMap = self.tmpMaps.AddTmpVectMap(mapName, endStr)
+ msg = _("Temporary map %s already exists.\n" +
+ "Do you want to continue in analysis and overwrite it?") \
+ % (mapName +'@' + grass.gisenv()['MAPSET'])
+ tmpMap = self.tmpMaps.AddTmpVectMap(mapName, msg)
return tmpMap
@@ -1679,7 +1749,7 @@
"v.net.salesman" : {
- "label" : _("Salesman %s") % "(v.net.salesman)",
+ "label" : _("Traveling salesman %s") % "(v.net.salesman)",
"cmdParams" : {
"cats" : [["ccats", None]],
"cols" : [
@@ -1693,7 +1763,7 @@
"v.net.flow" : {
- "label" : _("Flow %s") % "(v.net.flow)",
+ "label" : _("Maximum flow %s") % "(v.net.flow)",
"cmdParams" : {
"cats" : [
["source_cats", _("Source point")],
@@ -1711,7 +1781,7 @@
"v.net.alloc" : {
- "label" : _("Allocate subnets for nearest centers %s") % "(v.net.alloc)",
+ "label" : _("Subnets for nearest centers %s") % "(v.net.alloc)",
"cmdParams" : {
"cols" : [
@@ -1726,7 +1796,7 @@
"v.net.steiner" : {
- "label" : _("Create Steiner tree for the network and given terminals %s") % "(v.net.steiner)",
+ "label" : _("Steiner tree for the network and given terminals %s") % "(v.net.steiner)",
"cmdParams" : {
"cats" : [["tcats", None]],
"cols" : [
@@ -1739,7 +1809,7 @@
"v.net.distance" : {
- "label" : _("Computes shortest distance via the network %s") % "(v.net.distance)",
+ "label" : _("Shortest distance via the network %s") % "(v.net.distance)",
"cmdParams" : {
"cats" : [
["from_cats", "From point"],
@@ -1757,7 +1827,7 @@
"v.net.iso" : {
- "label" : _("Splits net by cost isolines %s") % "(v.net.iso)",
+ "label" : _("Cost isolines %s") % "(v.net.iso)",
"cmdParams" : {
"cols" : [
@@ -1779,10 +1849,9 @@
"v.net.alloc",
"v.net.distance",
"v.net.iso",
- "v.net.steiner"
+ #"v.net.steiner"
] # order in the choice of analysis
self.currAnModule = self.vnetModulesOrder[0]
- self.prev2catsAnModule = self.vnetModulesOrder[0]
def _initSettings(self):
"""!Initialization of settings (if not already defined)"""
@@ -1877,22 +1946,17 @@
if self.updateMap:
self.dialog.mapWin.UpdateMap(render=False, renderVector=False)
- def _adaptPointsList(self, currParamsCats, prevParamsCats):
+ def AdaptPointsList(self, currParamsCats):
"""Rename category values when module is changed. Expample: Start point -> Sink point"""
- for iItem, item in enumerate(self.itemDataMap):
- iCat = 0
- for ptCat in prevParamsCats:
- if self.itemDataMap[iItem][1] == ptCat[1]:
- self.EditCellKey(iItem, 'type', currParamsCats[iCat][1])
- iCat += 1
- if not item[1]:
- self.CheckItem(iItem, False)
colValues = [""]
for ptCat in currParamsCats:
colValues.append(ptCat[1])
+ colNum = self._getColumnNum('type')
self.ChangeColEditable('type', colValues)
+ for iItem, item in enumerate(self.itemDataMap):
+ self.EditCellKey(iItem, 'type', self.selIdxs[iItem][colNum])
+ if not item[1]:
+ self.CheckItem(iItem, False)
def OnCheckItem(self, index, flag):
"""!Item is checked/unchecked"""
@@ -1937,16 +2001,31 @@
def SetUpdateMap(self, updateMap):
self.updateMap = updateMap
+ def GetHiddenColSelIdxs(self, colName):
+ if self.hiddenCols.has_key(colName):
+ return self.hiddenCols[colName]['selIdxs']
+ return None
+ def SetHiddenSelIdxs(self, colName, selIdxs):
+ self.hiddenCols[colName]['selIdxs'] = map(int, selIdxs)
+ self.hiddenCols[colName]['itemDataMap'] = []
+ for idx in self.hiddenCols[colName]['selIdxs']:
+ self.hiddenCols[colName]['itemDataMap'].append(self.hiddenCols[colName]['colsData'][2][idx])
+ return True
+ return False
class SettingsDialog(wx.Dialog):
def __init__(self, parent, id, title, pos=wx.DefaultPosition, size=wx.DefaultSize,
style=wx.DEFAULT_DIALOG_STYLE):
"""!Settings for v.net analysis dialog"""
wx.Dialog.__init__(self, parent, id, title, pos, size, style)
- self.settings = {}
maxValue = 1e8
+ self.settings = {}
rules = RunCommand('v.colors',
read = True,
@@ -2159,16 +2238,17 @@
class AddLayerDialog(wx.Dialog):
def __init__(self, parent,id=wx.ID_ANY,
- title =_("Add analysis result into layer tree"), style=wx.DEFAULT_DIALOG_STYLE):
- """!Adds vector map with analysis result into layer tree"""
+ title =_("Save analysis result"), style=wx.DEFAULT_DIALOG_STYLE):
+ """!Save analysis result"""
wx.Dialog.__init__(self, parent, id, title = _(title), style = style)
self.panel = wx.Panel(parent = self)
# text fields and it's captions
- self.vectSel = Select(parent = self.panel, type = 'vector', size = (-1, -1))
+ self.vectSel = Select(parent = self.panel, type = 'vector',
+ mapsets = [grass.gisenv()['MAPSET']],size = (-1, -1))
self.vectSellabel = wx.StaticText(parent = self.panel, id = wx.ID_ANY,
- label = _("Map name:"))
+ label = _("Name:"))
# buttons
self.btnCancel = wx.Button(self.panel, wx.ID_CANCEL)
@@ -2183,7 +2263,7 @@
box = wx.StaticBox (parent = self.panel, id = wx.ID_ANY,
- label = "Added vector map")
+ label = "Vector map")
boxSizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
@@ -2215,7 +2295,7 @@
self.mapWin = self.parent.mapWin
- def AddTmpVectMap(self, mapName, endStr):
+ def AddTmpVectMap(self, mapName, msg):
tmpMap = grass.find_file(name = mapName,
@@ -2225,8 +2305,7 @@
fullName = tmpMap["fullname"]
if fullName:
dlg = wx.MessageDialog(parent = self.parent,
- message = _("Temporary map %s already exists.\n" +
- endStr) % fullName,
+ message = msg,
caption = _("Overwrite map layer"),
@@ -2275,12 +2354,14 @@
return False
def DeleteTmpMap(self, vectMap):
+ if vectMap:
+ vectMap.DeleteRenderLayer()
+ vect = vectMap.GetVectMapName())
+ self.RemoveFromTmpMaps(vectMap)
+ return True
+ return False
- vectMap.DeleteRenderLayer()
- RunCommand('g.remove',
- vect = vectMap.GetVectMapName())
- self.RemoveFromTmpMaps(vectMap)
def DeleteAllTmpMaps(self):
update = False
@@ -2354,12 +2435,15 @@
def GetLastModified(self):
- name = self.fullName.split("@")[0]
+ mapValSpl = self.fullName.split("@")
+ mapSet = mapValSpl[1]
+ mapName = mapValSpl[0]
headPath = os.path.join(grass.gisenv()['GISDBASE'],
grass.gisenv()['LOCATION_NAME'],
- grass.gisenv()['MAPSET'],
+ mapSet,
"vector",
- name,
+ mapName,
"head")
try:
head = open(headPath, 'r')
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-08-19 22:57:53 UTC (rev 52740)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/toolbars.py 2012-08-19 23:07:43 UTC (rev 52741)
@@ -19,7 +19,7 @@
from icon import MetaIcon
from gui_core.toolbars import BaseToolbar, BaseIcons
+from core.gcmd import RunCommand
class PointListToolbar(BaseToolbar):
"""!Toolbar for managing list of points
@@ -38,9 +38,9 @@
icons = {
'insertPoint' : MetaIcon(img = 'pointer',
- label = _('Insert point with mouse')),
+ label = _('Insert points from Map Display')),
'snapping' : MetaIcon(img = 'move',
- label = _('Snap to nodes')),
+ label = _('Activate snapping to nodes')),
'pointAdd' : MetaIcon(img = 'point-create',
label = _('Add new point')),
'pointDelete' : MetaIcon(img = 'gcp-delete',
@@ -76,23 +76,10 @@
for moduleName in self.parent.vnetModulesOrder:
choices.append(self.parent.vnetParams[moduleName]['label'])
- self.anChoice = wx.ComboBox(parent = self, id = wx.ID_ANY,
- choices = choices,
- style = wx.CB_READONLY, size = (180, -1))
- self.anChoice.SetSelection(0)
- self.anChoiceId = self.AddControl(self.anChoice)
- self.parent.Bind(wx.EVT_COMBOBOX, self.parent.OnAnalysisChanged, self.anChoiceId)
- # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
- self.anChoice.Hide()
- self.anChoice.Show()
self.UpdateUndoRedo()
# realize the toolbar
self.Realize()
def _toolbarData(self):
icons = {
@@ -105,27 +92,35 @@
'showResult' : MetaIcon(img = 'layer-add',
label = _("Show analysis result")),
'saveTempLayer' : MetaIcon(img = 'map-export',
- label = _('Save temporary result map')),
- 'settings' : BaseIcons['settings'].SetLabel( _('Vector network analysis settings'))
+ label = _('Save temporary result')),
+ 'settings' : BaseIcons['settings'].SetLabel( _('Vector network analysis settings')),
+ 'help' : MetaIcon(img = 'help',
+ label = _('Show manual'))
return self._getToolbarData((
("run", icons['run'],
self.parent.OnAnalyze),
- #("showResult", icons['showResult'], TODO
- #self.parent.OnShowResult, wx.ITEM_CHECK),
+ (None, ),
("undo", icons['undo'],
self.parent.OnUndo),
("redo", icons['redo'],
- self.parent.OnRedo),
+ self.parent.OnRedo),
+ (None, ),
+ ("showResult", icons['showResult'],
+ self.parent.OnShowResult, wx.ITEM_CHECK),
("saveTempLayer", icons['saveTempLayer'],
self.parent.OnSaveTmpLayer),
+ (None, ),
('settings', icons["settings"],
- self.parent.OnSettings),
+ self.parent.OnSettings),
+ ('help', icons["help"],
+ self.OnHelp),
("quit", BaseIcons['quit'],
self.parent.OnCloseDialog)
def UpdateUndoRedo(self):
if self.parent.history.GetCurrHistStep() >= self.parent.history.GetStepsNum():
@@ -136,4 +131,42 @@
if self.parent.history.GetCurrHistStep() <= 0:
self.Enable("redo", False)
else:
- self.Enable("redo", True)
\ No newline at end of file
+ self.Enable("redo", True)
+ def OnHelp(self, event) :
+ RunCommand('g.manual',
+ entry = 'wxGUI.VNet')
+class AnalysisToolbar(BaseToolbar):
+ """!Main toolbar
+ def __init__(self, parent):
+ BaseToolbar.__init__(self, parent)
+ self.InitToolbar(self._toolbarData())
+ choices = []
+ for moduleName in self.parent.vnetModulesOrder:
+ choices.append(self.parent.vnetParams[moduleName]['label'])
+ self.anChoice = wx.ComboBox(parent = self, id = wx.ID_ANY,
+ choices = choices,
+ style = wx.CB_READONLY, size = (350, 30))#FIXME
+ self.anChoice.SetToolTipString(_('Availiable analyses'))
+ self.anChoice.SetSelection(0)
+ self.anChoiceId = self.AddControl(self.anChoice)
+ self.parent.Bind(wx.EVT_COMBOBOX, self.parent.OnAnalysisChanged, self.anChoiceId)
+ # workaround for Mac bug. May be fixed by 2.8.8, but not before then.
+ self.anChoice.Hide()
+ self.anChoice.Show()
+ # realize the toolbar
+ self.Realize()
+ def _toolbarData(self):
+ icons = {}
+ return self._getToolbarData(())
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-08-19 22:57:53 UTC (rev 52740)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-08-19 23:07:43 UTC (rev 52741)
@@ -91,7 +91,7 @@
self.dataTypes = {"colName" : 0,
"colLabel" : 1,
"colEditable" : 2,
- "itemDefaultVal" : 3} # just for better understanding
+ "itemDefaultValue" : 3} # just for better understanding
# tracks whether list items are checked or not
self.CheckList = []
@@ -117,13 +117,16 @@
self.sm_up = self.il.Add(SmallUpArrow)
# initialize column sorter
- self.itemDataMap = []
+ self.itemDataMap = []
ncols = self.GetColumnCount()
ColumnSorterMixin.__init__(self, ncols)
# init to ascending sort on first click
self._colSortFlag = [1] * ncols
+ # holds information about which index in choise is set
+ self.selIdxs = []
self.ResizeColumns()
self.SetColumnWidth(0, 50)
@@ -150,17 +153,29 @@
def AddItem(self, event):
"""!Appends an item to list with default values
- iDefVal = self.dataTypes["itemDefaultVal"]
+ iDefVal = self.dataTypes["itemDefaultValue"]
iColEd = self.dataTypes["colEditable"]
itemData = []
+ itemIndexes = []
for col in self.colsData:
if type(col[iColEd]).__name__ == "list":
itemData.append(col[iColEd][col[iDefVal]])
+ itemIndexes.append(col[iDefVal])
else:
itemData.append(col[iDefVal])
+ itemIndexes.append(-1)# not a choise column
+ self.selIdxs.append(itemIndexes)
for hCol in self.hiddenCols.itervalues():
defVal = hCol['colsData'][iDefVal]
- hCol['itemDataMap'].append(defVal)
+ if type(col[iColEd]).__name__ == "list":
+ hCol['itemDataMap'].append(hCol[iColEd][defVal])
+ hCol['selIdxs'].append(defVal)
+ else:
+ hCol['itemDataMap'].append(defVal)
+ hCol['selIdxs'].append(-1)
self.selectedkey = self.GetItemCount()
@@ -182,24 +197,47 @@
def GetCellText(self, key, colName):
"""!Get value in cell of list using key (same regardless of sorting)
- colNum = self._getColumnNum(colName)
- return self.itemDataMap[key][colNum]
+ colNum = self._getColumnNum(colName)
+ iColEd = self.dataTypes["colEditable"]
+ if type(self.colsData[colNum][iColEd]).__name__ == "list":
+ return self.selIdxs[key][colNum]
+ else:
+ return self.itemDataMap[key][colNum]
def EditCellIndex(self, index, colName, cellData):
"""!Changes value in list using key (same regardless of sorting)
- self.itemDataMap[self.GetItemData(index)][colNum] = cellData
- self.SetStringItem(index, colNum, str(cellData))
+ key = self.GetItemData(index)
+ cellVal = self.colsData[colNum][iColEd][cellData]
+ self.selIdxs[key][colNum] = cellData
+ else:
+ cellVal = cellData
+ self.selIdxs[key][colNum] = -1
+ self.itemDataMap[key][colNum] = cellVal
+ self.SetStringItem(index, colNum, str(cellVal))
def EditCellKey(self, key, colName, cellData):
"""!Changes value in list using index (changes during sorting)
- index = self.FindItemData(-1, key)
- self.itemDataMap[key][colNum] = cellData
+ index = self.FindItemData(-1, key)
+ else:
def ChangeColEditable(self, colName, colType):
"""!Changes 3. item in constructor parameter cols (see the class constructor hint)
@@ -216,10 +254,12 @@
wx.ListCtrl.DeleteItem(self, self.selected)
del self.itemDataMap[key]
+ self.selIdxs.pop(key)
# update hidden columns
- hCol['itemDataMap'].pop(key)
+ hCol['itemDataMap'].pop(key)
+ hCol['selIdxs'].pop(key)
# update key and point number
for newkey in range(key, len(self.itemDataMap)):
@@ -243,14 +283,13 @@
self.selected = wx.NOT_FOUND
self.selectedkey = -1
def ClearItem(self, event):
""""!Clears all values in selected item of points list and unchecks it."""
if self.selected == wx.NOT_FOUND:
return
index = self.selected
i = 0
@@ -321,6 +360,7 @@
changed = True
i += 1
+ self.selIdxs[key] = dlg.GetSelectionIndexes()
return changed
def CreateEditDialog(self, data, pointNo):
@@ -400,10 +440,14 @@
self.hiddenCols[colName] = {}
self.hiddenCols[colName]['wxCol'] = hiddenCol
hiddenMaps = []
+ hiddenSelIdxs = []
for item in self.itemDataMap:
hiddenMaps.append(item.pop(colNum))
+ for item in self.selIdxs:
+ hiddenSelIdxs.append(item.pop(colNum))
self.hiddenCols[colName]['itemDataMap'] = hiddenMaps
+ self.hiddenCols[colName]['selIdxs'] = hiddenSelIdxs
self.hiddenCols[colName]['colsData'] = self.colsData.pop(colNum)
@@ -425,6 +469,8 @@
for item in enumerate(self.itemDataMap):
item[1].insert(pos, col['itemDataMap'][item[0]])
+ for item in enumerate(self.selIdxs):
+ item[1].insert(pos, col['selIdxs'][item[0]])
self.colsData.insert(pos, col['colsData'])
@@ -457,6 +503,7 @@
wx.Dialog.__init__(self, parent, id, title=_(title), style=style)
panel = wx.Panel(parent=self)
@@ -549,7 +596,6 @@
iField = 0
- self.data
for cell in self.data:
value = self.fields[iField].GetValue()
@@ -564,6 +610,20 @@
return self.data
+ def GetSelectionIndexes(self):
+ """!Return indexes of selected values (works just for choice columns).
+ iField = 0
+ itemIndexes = []
+ for cell in self.parent.colsData:
+ if type(cell[2]).__name__ == "list":
+ itemIndexes.append(self.fields[iField].GetSelection())
+ else:
+ itemIndexes.append(-1) # not a choise column
+ if cell[2]:
+ iField += 1
+ return itemIndexes
