[GRASS-SVN] r52784 - grass/branches/releasebranch_6_4/vector/v.transform
svn_grass at osgeo.org
Mon Aug 20 08:32:51 PDT 2012
Author: mmetz
Date: 2012-08-20 08:32:51 -0700 (Mon, 20 Aug 2012)
New Revision: 52784
grass/branches/releasebranch_6_4/vector/v.transform/main.c
v.transform fix for #1615
Modified: grass/branches/releasebranch_6_4/vector/v.transform/main.c
--- grass/branches/releasebranch_6_4/vector/v.transform/main.c 2012-08-20 15:32:49 UTC (rev 52783)
+++ grass/branches/releasebranch_6_4/vector/v.transform/main.c 2012-08-20 15:32:51 UTC (rev 52784)
@@ -58,11 +58,11 @@
BOUND_BOX box;
double ztozero;
- double trans_params[7]; // xshift, ..., xscale, ..., zrot
+ double trans_params[7]; /* xshift, ..., xscale, ..., zrot */
/* columns */
unsigned int i;
- int idx;
+ int idx, out3d;
char **tokens;
char *columns_name[7]; /* xshift, yshift, zshift, xscale, yscale, zscale, zrot */
@@ -200,6 +200,8 @@
G_strcpy(Trans.name, vnew->answer);
Vect_check_input_output_name(vold->answer, vnew->answer, GV_FATAL_EXIT);
+ out3d = WITHOUT_Z;
/* please remove in GRASS7 */
if (shift_flag->answer)
@@ -237,52 +239,6 @@
Coord.name);
- /* open vector maps */
- if ((mapset = G_find_vector2(vold->answer, "")) == NULL)
- G_fatal_error(_("Vector map <%s> not found"), vold->answer);
- Vect_open_old(&Old, vold->answer, mapset);
- Vect_open_new(&New, vnew->answer, Vect_is_3d(&Old) || tozero_flag->answer ||
- strcmp(zshift->answer, "0.0") || strcmp(zscale->answer, "1.0") ||
- strcmp(zrot->answer, "0.0") ? WITH_Z : WITHOUT_Z);
- /* copy and set header */
- Vect_copy_head_data(&Old, &New);
- Vect_hist_copy(&Old, &New);
- Vect_hist_command(&New);
- sprintf(date, "%s", G_date());
- sscanf(date, "%*s%s%d%*s%d", mon, &day, &yr);
- sprintf(date, "%s %d %d", mon, day, yr);
- Vect_set_date(&New, date);
- Vect_set_person(&New, G_whoami());
- sprintf(buf, "transformed from %s", vold->answer);
- Vect_set_map_name(&New, buf);
- Vect_set_scale(&New, 1);
- Vect_set_zone(&New, 0);
- Vect_set_thresh(&New, 0.0);
- /* points file */
- if (Coord.name[0]) {
- create_transform_from_file(&Coord, quiet_flag->answer);
- if (Coord.name[0] != '\0')
- fclose(Coord.fp);
- Vect_get_map_box(&Old, &box);
- /* z to zero */
- if (tozero_flag->answer)
- ztozero = 0 - box.B;
- else
- ztozero = 0;
/* tokenize columns names */
for (i = 0; i <= IDX_ZROT; i++) {
columns_name[i] = NULL;
@@ -331,6 +287,57 @@
trans_params[IDX_ZSCALE] = atof(zscale->answer);
trans_params[IDX_ZROT] = atof(zrot->answer);
+ /* open vector maps */
+ if ((mapset = G_find_vector2(vold->answer, "")) == NULL)
+ G_fatal_error(_("Vector map <%s> not found"), vold->answer);
+ Vect_open_old(&Old, vold->answer, mapset);
+ /* should output be 3D ?
+ * note that z-scale and ztozero have no effect with input 2D */
+ if (Vect_is_3d(&Old) || trans_params[IDX_ZSHIFT] != 0. ||
+ columns_name[IDX_ZSHIFT])
+ out3d = WITH_Z;
+ Vect_open_new(&New, vnew->answer, out3d);
+ /* copy and set header */
+ Vect_copy_head_data(&Old, &New);
+ Vect_hist_copy(&Old, &New);
+ Vect_hist_command(&New);
+ sprintf(date, "%s", G_date());
+ sscanf(date, "%*s%s%d%*s%d", mon, &day, &yr);
+ sprintf(date, "%s %d %d", mon, day, yr);
+ Vect_set_date(&New, date);
+ Vect_set_person(&New, G_whoami());
+ sprintf(buf, "transformed from %s", vold->answer);
+ Vect_set_map_name(&New, buf);
+ Vect_set_scale(&New, 1);
+ Vect_set_zone(&New, 0);
+ Vect_set_thresh(&New, 0.0);
+ /* points file */
+ if (Coord.name[0]) {
+ create_transform_from_file(&Coord, quiet_flag->answer);
+ if (Coord.name[0] != '\0')
+ fclose(Coord.fp);
+ Vect_get_map_box(&Old, &box);
+ /* z to zero */
+ if (tozero_flag->answer)
+ ztozero = 0 - box.B;
+ else
+ ztozero = 0;
+ /* do the transformation */
transform_digit_file(&Old, &New, Coord.name[0] ? 1 : 0,
ztozero, trans_params,
table->answer, columns_name, atoi(field->answer));
