[GRASS-SVN] r52788 - grass-addons/grass7/gui/wxpython/wx.vnet
svn_grass at osgeo.org
Mon Aug 20 09:22:23 PDT 2012
Author: turek
Date: 2012-08-20 09:22:22 -0700 (Mon, 20 Aug 2012)
New Revision: 52788
grass-addons/grass7/gui/wxpython/wx.vnet/wxGUI.VNet.html
vnet: Manual cosmetics
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/wxGUI.VNet.html
--- grass-addons/grass7/gui/wxpython/wx.vnet/wxGUI.VNet.html 2012-08-20 16:19:18 UTC (rev 52787)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/wxGUI.VNet.html 2012-08-20 16:22:22 UTC (rev 52788)
@@ -33,8 +33,6 @@
<li> Allocate subnets for nearest centers
(<em><a href="v.net.alloc.html">v.net.alloc</a></em>)</li>
<li> Steiner tree for the network and given terminals
- (<em><a href="v.net.steiner.html">v.net.steiner</a></em>)</li>
- <li> Find shortest distance via the network
(<em><a href="v.net.distance.html">v.net.distance</a></em>)</li>
<li> Splits net by cost isolines
(<em><a href="v.net.iso.html">v.net.iso</a></em>)</li>
@@ -53,12 +51,12 @@
<ul>
<li> <tt>Parameters</tt> tab - It is used for setting vector map and
it's layer on which analysis will be done. Also it is possible to
- set cost values from attribute table connected to particular
- layer.</li>
+ set columns with cost values from attribute table connected
+ to particular layer.</li>
<li> <tt>Points</tt> tab - It manages points, which are used for
analysis.</li>
- <li> <tt>Output</tt> tab - There is output console, which shows
- report during analysis. </li>
+ <li> <tt>Output</tt> tab - There is a output console, which shows
+ information about running analysis. </li>
<li> <tt>Input tables</tt> tab - When existing vector map and it's
existing layers are set in <tt>Parameters</tt> tab, this tab is
dynamically added. It shows attribute tables of node and arc layers,
@@ -78,7 +76,8 @@
<h2>KNOWN ISSUES</h2>
When some change is done in layer tree of Map Display, temporary
-vector map representing result of analysis is not rendered anymore.
+vector map representing result of analysis is not rendered
+(use <tt>Show result</tt> button in toolbar to render it again).
<h2>SEE ALSO</h2>
