[GRASS-SVN] r52791 - grass/branches/releasebranch_6_4/vector/v.transform
svn_grass at osgeo.org
Mon Aug 20 10:57:22 PDT 2012
Author: mmetz
Date: 2012-08-20 10:57:21 -0700 (Mon, 20 Aug 2012)
New Revision: 52791
grass/branches/releasebranch_6_4/vector/v.transform/trans_digit.c
v.transform close database shutdown driver when done
Modified: grass/branches/releasebranch_6_4/vector/v.transform/trans_digit.c
--- grass/branches/releasebranch_6_4/vector/v.transform/trans_digit.c 2012-08-20 16:33:36 UTC (rev 52790)
+++ grass/branches/releasebranch_6_4/vector/v.transform/trans_digit.c 2012-08-20 17:57:21 UTC (rev 52791)
@@ -32,7 +32,7 @@
int shift_file, double ztozero, double *trans_params_def,
char *table, char **columns, int field)
- int i, type, cat;
+ int i, type, cat, ret;
unsigned int j;
double *trans_params;
double ang, x, y;
@@ -65,14 +65,19 @@
ang = PI * trans_params[IDX_ZROT] / 180;
+ ret = 1;
while (1) {
type = Vect_read_next_line(Old, Points, Cats);
- if (type == -1) /* error */
- return 0;
+ if (type == -1) { /* error */
+ ret = 0;
+ break;
- if (type == -2) /* EOF */
- return 1;
+ if (type == -2) { /* EOF */
+ ret = 1;
+ break;
/* get transformation parameters */
if (table) {
@@ -160,4 +165,6 @@
db_close_database_shutdown_driver(driver);
G_free((void *)trans_params);
+ return ret;
