[GRASS-SVN] r52794 - grass-addons/grass7/gui/wxpython/wx.vnet/vnet
svn_grass at osgeo.org
Mon Aug 20 11:30:58 PDT 2012
Author: turek
Date: 2012-08-20 11:30:58 -0700 (Mon, 20 Aug 2012)
New Revision: 52794
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
Comments correction, bug fixed
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-20 17:58:38 UTC (rev 52793)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/dialogs.py 2012-08-20 18:30:58 UTC (rev 52794)
@@ -71,12 +71,12 @@
self.parent = parent # mapdisp.frame MapFrame class
self.mapWin = parent.MapWindow
- # contains current analysis result (do not have to be last one, when is history browsed),
+ # contains current analysis result (do not have to be last one, when history is browsed),
# it is instance of VectMap class
self.tmp_result = None
# initialization of History class used for saving and reading data from file
- # used for browsing analysis results
+ # it is used for browsing analysis results
self.history = History(self)
# variable, which appends unique number to every name of map, which is saved into history
@@ -99,7 +99,7 @@
# information, whether mouse event handler is registered in map window
self.handlerRegistered = False
- # get attribute table columns only with numbers (for cost culumns in vnet analysis)
+ # get attribute table columns only with numbers (for cost columns in vnet analysis)
self.columnTypes = ['integer', 'double precision']
# initialization of v.net.* analysis parameters (data which characterizes particular analysis)
@@ -137,7 +137,7 @@
# Stores all data related to snapping
self.snapData = {}
self.snapData['snap_mode'] = False
- # Stores widgets which sets analysis parameters (e. g. v.ne..iso -> costs)
+ # Stores widgets which sets some of analysis parameters (e. g. v.ne.iso -> iso lines)
self.anSettings = {}
self._createPointsPage()
@@ -149,7 +149,7 @@
# Output console for analysis
self._createOutputPage()
- # Stores data which are need for attribute table browser of analysis input map layers
+ # Stores data which are needed for attribute table browser of analysis input map layers
self.inpDbMgrData = {}
self._createInputDbMgrPage()
@@ -188,7 +188,6 @@
def __del__(self):
"""!Removes temp layers, unregisters handlers and graphics"""
update = self.tmpMaps.DeleteAllTmpMaps()
self.mapWin.UnregisterGraphicsToDraw(self.pointsToDraw)
@@ -204,7 +203,6 @@
def _addPanes(self):
"""!Adds toolbar pane and pane with tabs"""
self._mgr.AddPane(self.toolbars['mainToolbar'],
wx.aui.AuiPaneInfo().
Name("pointlisttools").Caption(_("Point list toolbar")).
@@ -241,7 +239,6 @@
def _createPointsPage(self):
"""!Tab with points list and analysis settings"""
pointsPanel = wx.Panel(parent = self)
maxValue = 1e8
@@ -347,7 +344,7 @@
outputPanel.SetSizer(outputSizer)
def _createParametersPage(self):
- """!Tab with output console"""
+ """!Tab for selection of data for analysis"""
dataPanel = wx.Panel(parent=self)
self.notebook.AddPage(page = dataPanel,
text=_('Parameters'),
@@ -471,7 +468,7 @@
self.OnVectSel(None)
def _updateInputDbMgrPage(self, show):
- """!Show or Hide Input tables tab"""
+ """!Show or hide input tables tab"""
if show and self.notebook.GetPageIndexByName('inputDbMgr') == -1:
self.notebook.AddPage(page = self.inpDbMgrData['browse'],
text=_('Input tables'),
@@ -495,7 +492,7 @@
"""!Show or Hide Result tables tab"""
# analysis, which created result
analysis = self.resultDbMgrData['analysis']
- #TODO maybe no need to store this information, just check it has attr table, if so show it
+ #TODO maybe no need to store this information, just check it has attribute table, if so show it
haveDbMgr = self.vnetParams[analysis]["resultProps"]["dbMgr"]
if haveDbMgr and self.notebook.GetPageIndexByName('resultDbMgr') == -1:
@@ -517,7 +514,7 @@
priority = self.stPriorities['important'])
self._updateDbMgrData()
self.stBar.RemoveStatusItem(key = 'dbMgr')
- # update of columns (when some is added in input tables browser), TODO needs optimization
+ # update columns (when some is added in input tables browser), TODO needs optimization
elif self.notebook.GetSelection() == self.notebook.GetPageIndexByName('parameters'):
self.OnALayerSel(None)
self.OnNLayerSel(None)
@@ -607,7 +604,7 @@
lchecked = True)
def OnVectSel(self, event):
- """!When vector map is selected populates other comboboxes in Parameters tab (layer selects, columns selects)"""
+ """!When vector map is selected it populates other comboboxes in Parameters tab (layer selects, columns selects)"""
if self.snapData['snap_mode']:
self.OnSnapping(event = None)
@@ -680,12 +677,12 @@
mapName, mapSet = self._parseMapStr(mapVal)
vectMaps = grass.list_grouped('vect')[mapSet]
- #check of vector map
+ # check of vector map
if not inpToTest or "input" in inpToTest:
if mapName not in vectMaps:
errInput['input'] = mapVal
- #check of arc/node layer
+ # check of arc/node layer
for layerSelName in ['alayer', 'nlayer'] :
if not inpToTest or layerSelName in inpToTest:
@@ -694,7 +691,7 @@
if layerVal not in layerItems:
errInput[layerSelName] = layerVal
- #check of costs columns
+ # check of costs columns
currModCols = self.vnetParams[self.currAnModule]["cmdParams"]["cols"]
for col, colData in self.attrCols.iteritems():
if not inpToTest or col in inpToTest:
@@ -719,7 +716,7 @@
return errInput
def _parseMapStr(self, vectMapStr):
- """!Create full map name (add mapset if not present in name)"""
+ """!Create full map name (add current mapset if it is not present in name)"""
mapValSpl = vectMapStr.strip().split("@")
if len(mapValSpl) > 1:
mapSet = mapValSpl[1]
@@ -812,7 +809,7 @@
item.SetPropertyVal('penName', wxPen)
def OnMapClickHandler(self, event):
- """!Takes coordinates from map window"""
+ """!Take coordinates from map window"""
if event == 'unregistered':
ptListToolbar = self.toolbars['pointsList']
if ptListToolbar:
@@ -856,7 +853,7 @@
self.list.Select(self.list.selected)
def _snapPoint(self, coords):
- """!Finds nearest node to click coordiantes (within given threshold)"""
+ """!Find nearest node to click coordinates (within given threshold)"""
e = coords[0]
n = coords[1]
@@ -933,8 +930,8 @@
key = 'analyze',
- # just in case there is some map with same name
- # (when analysis does not produce any map, this wrong map would have been shown as result)
+ # for case there is some map with same name
+ # (when analysis does not produce any map, this map would have been shown as result)
RunCommand('g.remove',
vect = self.tmp_result.GetVectMapName())
@@ -1134,7 +1131,7 @@
self.stBar.RemoveStatusItem(key = 'analyze')
def _getInputParams(self):
- """!Returns list of chosen values (vector map, layers) from Parameters tab.
+ """!Return list of chosen values (vector map, layers) from Parameters tab.
The list items are in form to be used in command for analysis e.g. 'alayer=1'.
@@ -1155,7 +1152,7 @@
return inParams
def _getPtByCat(self):
- """!Returns points separated by theirs categories"""
+ """!Return points separated by theirs categories"""
cats = self.vnetParams[self.currAnModule]["cmdParams"]["cats"]
ptByCats = {}
@@ -1173,7 +1170,7 @@
return ptByCats
def _getAsciiPts (self, catPts, maxCat, layerNum):
- """!Returns points separated by categories in GRASS ASCII vector representation"""
+ """!Return points separated by categories in GRASS ASCII vector representation"""
catsNums = {}
pt_ascii = ""
catNum = maxCat
@@ -1268,10 +1265,10 @@
def OnSaveTmpLayer(self, event):
"""!Permanently saves temporary map of analysis result"""
- dlg = AddLayerDialog(parent = self)#TODO import location check?
+ dlg = AddLayerDialog(parent = self)
msg = _("Vector map with analysis result does not exist.")
- if dlg.ShowModal() == wx.ID_OK: #TODO destroy
+ if dlg.ShowModal() == wx.ID_OK:
if not hasattr(self.tmp_result, "GetVectMapName"):
GMessage(parent = self,
@@ -1391,13 +1388,12 @@
if self.list.IsShown('type'):
self.list.HideColumn('type')
- # for v.net.path just one start point and one end point can be checked
+ # for v.net.path just one 'Start point' and one 'End point' can be checked
if self.currAnModule == "v.net.path":
self.list.UpdateCheckedItems(index = None)
def OnSnapping(self, event):
"""!Start/stop snapping mode"""
if not haveCtypes:
@@ -1584,14 +1580,14 @@
def _saveHistStep(self):
- """!Save buffer created with (_saveAnInputToHist) into history"""
+ """!Save new step into history"""
removedHistData = self.history.SaveHistStep()
self.toolbars['mainToolbar'].UpdateUndoRedo()
if not removedHistData:
return
- # delete temporary maps saved in history steps which were deleted
+ # delete temporary maps in history steps which were deleted
for removedStep in removedHistData.itervalues():
mapsNames = removedStep["tmp_data"]["maps"]
for vectMapName in mapsNames:
@@ -1708,7 +1704,7 @@
dlg.Destroy()
def NewTmpVectMapToHist(self, prefMapName):
- """!Adds new vector map to be saved into history step"""
+ """!Add new vector map, which will be saved into history step"""
mapName = prefMapName + str(self.histTmpVectMapNum)
self.histTmpVectMapNum += 1
@@ -1725,7 +1721,7 @@
return tmpMap
def _addTmpMapAnalysisMsg(self, mapName):
- """!Wraped AddTmpVectMap method + message text, if map to be created during analysis exists"""
+ """!Wraped AddTmpVectMap"""
msg = _("Temporary map %s already exists.\n" +
"Do you want to continue in analysis and overwrite it?") \
% (mapName +'@' + grass.gisenv()['MAPSET'])
@@ -1870,7 +1866,7 @@
- # order in combobox for choosing analysis
+ # order in combobox for choose of analysis
self.vnetModulesOrder = ["v.net.path",
"v.net.salesman",
"v.net.flow",
@@ -1910,8 +1906,7 @@
def SetPointDrawSettings(self):
- """!Sets settings for drawing of points.
+ """!Set settings for drawing of points"""
ptSize = int(UserSettings.Get(group='vnet', key='point_symbol', subkey = 'point_size'))
self.pointsToDraw.SetPropertyVal("size", ptSize)
@@ -1938,7 +1933,7 @@
PointsList.__init__(self, parent = parent, cols = cols, id = id)
def AddItem(self, event = None, updateMap = True):
- """!Appends point to list"""
+ """!Append point to list"""
self.dialog.pointsToDraw.AddItem(coords = [0,0])
PointsList.AddItem(self, event)
@@ -1948,7 +1943,7 @@
cellData = _("new point"))
def DeleteItem(self, event = None):
- """!Deletes selected point in list"""
+ """!Delete selected point in list"""
key = self.GetItemData(self.selected)
if self.selected != wx.NOT_FOUND:
item = self.dialog.pointsToDraw.GetItem(key)
@@ -2000,7 +1995,7 @@
self.UpdateCheckedItems(index)
def UpdateCheckedItems(self, index):
- """!For v.net.path - max. just one checked start point and end point """
+ """!For v.net.path - max. just one checked 'Start point' and 'End point'"""
alreadyChecked = []
colNum = self._getColumnNum('type')
if colNum == -1:
@@ -2011,6 +2006,7 @@
alreadyChecked.append(checkedVal)
else:
checkedKey = -1
for iKey, idx in enumerate(self.selIdxs):
index = self._findIndex(iKey)
if (idx[colNum] in alreadyChecked and checkedKey != iKey) \
@@ -2030,10 +2026,11 @@
return None
def SetHiddenSelIdxs(self, colName, selIdxs):
- """!Set indexes of chosen values in hidden 'type' column"""
+ """!Set indexes of chosen values in hidden 'type' column and update text in it's cells"""
if self.hiddenCols.has_key(colName):
self.hiddenCols[colName]['selIdxs'] = map(int, selIdxs)
self.hiddenCols[colName]['itemDataMap'] = []
+ # update text in hidden column cells
for idx in self.hiddenCols[colName]['selIdxs']:
self.hiddenCols[colName]['itemDataMap'].append(self.hiddenCols[colName]['colsData'][2][idx])
return True
@@ -2218,7 +2215,6 @@
self.Close()
def UpdateSettings(self):
UserSettings.Set(group ='vnet', key = "res_style", subkey ='line_width',
value = self.settings["line_width"].GetValue())
@@ -2353,9 +2349,9 @@
def HasTmpVectMap(self, vectMapName):
- @param name of vector map
+ @param vectMapName name of vector map
- @return True if it has
+ @return True if it contains the map
@return False if not
@@ -2385,7 +2381,7 @@
@param vectMap instance of VectMap class to be removed
@return True if was removed
- @return False if the class instance does not contain it
+ @return False if does not contain the map
try:
self.tmpMaps.remove(vectMap)
@@ -2399,7 +2395,7 @@
@param vectMap instance of VectMap class to be deleted
if vectMap:
vectMap.DeleteRenderLayer()
@@ -2421,7 +2417,7 @@
class VectMap:
"""!Represents map
- It can checks if it was modified or render it
+ It can check if it was modified or render it
def __init__(self, parent, fullName):
self.fullName = fullName
@@ -2479,8 +2475,8 @@
"""!Checks if map was modified
@return -1 - if no modification time was saved
- @return - 0 if map was modified
- @return -1 if map was not modified
+ @return 0 - if map was modified
+ @return 1 - if map was not modified
if self.modifTime is None:
return -1
@@ -2603,7 +2599,7 @@
return removedHistData
def _savePreviousHist(self, newHist, oldHist):
- """!Save previus history into new file"""
+ """!Save previous history into new file"""
newHistStep = False
removedHistData = {}
newHistStepsNum = self.histStepsNum
@@ -2816,7 +2812,7 @@
wx.StatusBar.SetStatusText(self, currStatusText)
def RemoveStatusItem(self, key):
- """!Removes item
+ """!Remove item
@param key - item identifier
Modified: grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py
--- grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-08-20 17:58:38 UTC (rev 52793)
+++ grass-addons/grass7/gui/wxpython/wx.vnet/vnet/widgets.py 2012-08-20 18:30:58 UTC (rev 52794)
@@ -80,7 +80,7 @@
ListCtrlAutoWidthMixin.__init__(self)
# TextEditMixin.__init__(self)
- # inserts first column with points numbers and checkoboxes
+ # inserts first column with points numbers and checkboxes
cols.insert(0, ['use', _('use'), False, 0])
self.colsData = cols
@@ -89,7 +89,7 @@
"colEditable" : 2,
"itemDefaultValue" : 3} # just for better understanding
- # tracks whether list items are checked or not
+ # information whether list items are checked or not
self.CheckList = []
self._createCols()
@@ -120,7 +120,8 @@
# init to ascending sort on first click
self._colSortFlag = [1] * ncols
- # holds information about which index in choise is set
+ # same structure as itemDataMap, information about choice index selected
+ # if cell is in column without values to choose then is -1
self.selIdxs = []
self.ResizeColumns()
@@ -250,13 +251,13 @@
return -1
def ChangeColEditable(self, colName, colType):
- """!Changes 3. item in constructor parameter cols (see the class constructor hint)"""
+ """!Change 3. item in constructor parameter cols (see the class constructor hint)"""
colNum = self._getColumnNum(colName)
iColEd = self.dataTypes["colEditable"]
self.colsData[colNum][iColEd] = colType
- """!Deletes selected item in list"""
+ """!Delete selected item in list"""
if self.selected == wx.NOT_FOUND:
return
@@ -294,7 +295,7 @@
self.selectedkey = -1
def ClearItem(self, event):
- """"!Clears all values in selected item of points list and unchecks it."""
+ """"!Set all values to default in selected item of points list and uncheck it."""
return
index = self.selected
@@ -370,7 +371,8 @@
changed = True
i += 1
- self.selIdxs[key] = dlg.GetSelectionIndexes()
+ self.selIdxs[key] = dlg.GetSelectionIndexes()
+ dlg.Destroy()
return changed
def CreateEditDialog(self, data, pointNo):
