[GRASS-SVN] r52797 - grass/trunk/lib/vector/Vlib
Tue Aug 21 00:47:40 PDT 2012
Author: mmetz
Date: 2012-08-21 00:47:40 -0700 (Tue, 21 Aug 2012)
New Revision: 52797
   grass/trunk/lib/vector/Vlib/cats.c
Vlib: optimized category fns
Modified: grass/trunk/lib/vector/Vlib/cats.c
--- grass/trunk/lib/vector/Vlib/cats.c	2012-08-21 07:46:46 UTC (rev 52796)
+++ grass/trunk/lib/vector/Vlib/cats.c	2012-08-21 07:47:40 UTC (rev 52797)
@@ -22,7 +22,7 @@
 #include <grass/glocale.h>
 static int cmp(const void *pa, const void *pb);
-struct line_cats *Vect__new_cats_struct(void);
+static struct line_cats *Vect__new_cats_struct(void);
@@ -54,7 +54,7 @@
    \return struct line_cats *
-struct line_cats *Vect__new_cats_struct()
+static struct line_cats *Vect__new_cats_struct()
     struct line_cats *p;
@@ -203,9 +203,8 @@
     /* go through cats and find if field exist */
     for (n = 0; n < Cats->n_cats; n++) {
-	if (Cats->field[n] != field)
-	    continue;
-	Vect_list_append(cats, Cats->cat[n]);
+	if (Cats->field[n] == field)
+	    Vect_list_append(cats, Cats->cat[n]);
     return cats->n_values;
@@ -217,12 +216,12 @@
    \param[in,out] Cats line_cats structure
    \param field layer number
-   \return 1 deleted
+   \return number of categories deleted
    \return 0 layer does not exist
 int Vect_cat_del(struct line_cats *Cats, int field)
-    int n, m, found = 0;
+    int n, m, found;
     /* check input value */
@@ -231,17 +230,16 @@
+    m = 0;
-	if (Cats->field[n] == field) {
-	    for (m = n; m < Cats->n_cats - 1; m++) {
-		Cats->field[m] = Cats->field[m + 1];
-		Cats->cat[m] = Cats->cat[m + 1];
-	    Cats->n_cats--;
-	    found = 1;
-	    n--;		/* check again this position */
+	if (Cats->field[n] != field) {
+	    Cats->field[m] = Cats->field[n];
+	    Cats->cat[m] = Cats->cat[n];
+	    m++;
+    found = Cats->n_cats - m;
+    Cats->n_cats = m;
     return (found);
@@ -253,31 +251,33 @@
    \param cat category to be deleted or -1 to delete all cats of given field
-   \return 1 deleted
    \return 0 field/category number does not exist
 int Vect_field_cat_del(struct line_cats *Cats, int field, int cat)
-    register int n, m, found = 0;
+    register int n, m, found;
        if (field < 1 || field > GV_FIELD_MAX)
        return (0);
+    if (cat == -1)
+	return Vect_cat_del(Cats, field);
+    m = 0;
-	if (Cats->field[n] == field && (Cats->cat[n] == cat || cat == -1)) {
-	    Cats->n_cats--;
-	    found = 1;
+	if (Cats->field[n] != field || Cats->cat[n] != cat) {
+	    m++;
+    Cats->n_cats = m;
     return (found);
@@ -514,12 +514,12 @@
     i = bsearch((void *)&cat, (void *)array, (size_t) ncats,
 		sizeof(int), cmp);
-    if (i != NULL)
-	return (TRUE);
-    return (FALSE);
+    return (i != NULL);
+/* return -1 if *p1 < *p2
+ * return  1 if *p1 > *p2
+ * return  0 if *p1 == *p2 */
     int *p1 = (int *)pa;
@@ -527,7 +527,5 @@
     if (*p1 < *p2)
 	return -1;
-    if (*p1 > *p2)
-	return 1;
-    return 0;
+    return (*p1 > *p2);
