[GRASS-SVN] r52838 - in grass/trunk: display/d.colorlist display/d.font display/d.fontlist imagery/i.pca ps/ps.map raster/r.random raster/r.random.cells raster/r.random.surface raster3d/r3.out.netcdf raster3d/r3.retile scripts/v.dissolve scripts/v.in.sites.all scripts/v.what.vect temporal/t.create temporal/t.rast.mapcalc temporal/t.rast3d.mapcalc temporal/t.register temporal/t.remove temporal/t.sample temporal/t.vect.db.select vector/v.buffer vector/v.build vector/v.build.polylines vector/v.clean vector/v.distance vector/v.edit vector/v.net.visibility vector/v.random vector/v.sample vector/v.what vector/v.what.rast vector/v.what.rast3
svn_grass at osgeo.org
Wed Aug 22 12:17:25 PDT 2012
Author: neteler
Date: 2012-08-22 12:17:24 -0700 (Wed, 22 Aug 2012)
New Revision: 52838
grass/trunk/display/d.colorlist/main.c
grass/trunk/display/d.font/main.c
grass/trunk/display/d.fontlist/main.c
grass/trunk/imagery/i.pca/main.c
grass/trunk/ps/ps.map/main.c
grass/trunk/raster/r.random.cells/main.c
grass/trunk/raster/r.random.surface/main.c
grass/trunk/raster/r.random/main.c
grass/trunk/raster3d/r3.out.netcdf/main.c
grass/trunk/raster3d/r3.retile/main.c
grass/trunk/scripts/v.dissolve/v.dissolve.py
grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
grass/trunk/scripts/v.what.vect/v.what.vect.py
grass/trunk/temporal/t.create/t.create.py
grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/trunk/temporal/t.register/t.register.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/t.sample/t.sample.py
grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
grass/trunk/vector/v.buffer/main.c
grass/trunk/vector/v.build.polylines/main.c
grass/trunk/vector/v.build/main.c
grass/trunk/vector/v.clean/main.c
grass/trunk/vector/v.distance/main.c
grass/trunk/vector/v.edit/main.c
grass/trunk/vector/v.net.visibility/main.c
grass/trunk/vector/v.random/main.c
grass/trunk/vector/v.sample/main.c
grass/trunk/vector/v.what.rast/main.c
grass/trunk/vector/v.what.rast3/main.c
grass/trunk/vector/v.what/main.c
homogenize keywords
Modified: grass/trunk/display/d.colorlist/main.c
--- grass/trunk/display/d.colorlist/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/display/d.colorlist/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -33,7 +33,7 @@
module = G_define_module();
G_add_keyword(_("display"));
- G_add_keyword(_("setup"));
+ G_add_keyword(_("settings"));
module->description =
"Output a list of all available display colors with a configurable "
"separator (default is comma).";
Modified: grass/trunk/display/d.font/main.c
--- grass/trunk/display/d.font/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/display/d.font/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -44,7 +44,7 @@
_("Selects the font in which text will be displayed "
"on the user's graphics monitor.");
Modified: grass/trunk/display/d.fontlist/main.c
--- grass/trunk/display/d.fontlist/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/display/d.fontlist/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -36,7 +36,7 @@
module->description = _("Lists the available fonts.");
flagl = G_define_flag();
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/imagery/i.pca/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -65,7 +65,7 @@
G_add_keyword(_("imagery"));
- G_add_keyword(_("image transformation"));
+ G_add_keyword(_("transformation"));
G_add_keyword(_("PCA"));
module->description = _("Principal components analysis (PCA) "
"for image processing.");
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/ps/ps.map/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -91,7 +91,6 @@
/* Set description */
G_add_keyword(_("postscript"));
- G_add_keyword(_("map"));
G_add_keyword(_("printing"));
module->description = _("Produces hardcopy PostScript map output.");
Modified: grass/trunk/raster/r.random/main.c
--- grass/trunk/raster/r.random/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/raster/r.random/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -49,8 +49,9 @@
G_add_keyword(_("raster"));
+ G_add_keyword(_("sampling"));
+ G_add_keyword(_("vector"));
G_add_keyword(_("random"));
- G_add_keyword(_("vector"));
_("Creates a raster map layer and vector point map "
"containing randomly located points.");
Modified: grass/trunk/raster/r.random.cells/main.c
--- grass/trunk/raster/r.random.cells/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/raster/r.random.cells/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -43,8 +43,8 @@
- G_add_keyword(_("cell"));
_("Generates random cell values with spatial dependence.");
Modified: grass/trunk/raster/r.random.surface/main.c
--- grass/trunk/raster/r.random.surface/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/raster/r.random.surface/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -55,8 +55,8 @@
+ G_add_keyword(_("surface"));
- G_add_keyword(_("surface"));
_("Generates random surface(s) with spatial dependence.");
Modified: grass/trunk/raster3d/r3.out.netcdf/main.c
--- grass/trunk/raster3d/r3.out.netcdf/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/raster3d/r3.out.netcdf/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -584,8 +584,8 @@
G_gisinit(argv[0]);
G_add_keyword(_("raster3d"));
+ G_add_keyword(_("export"));
G_add_keyword(_("netCDF"));
- G_add_keyword(_("export"));
module->description = _("Export a 3D raster map as netCDF file.");
/* Get parameters from user */
Modified: grass/trunk/raster3d/r3.retile/main.c
--- grass/trunk/raster3d/r3.retile/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/raster3d/r3.retile/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -99,9 +99,9 @@
- G_add_keyword(_("retile"));
+ G_add_keyword(_("tiling"));
G_add_keyword(_("voxel"));
- module->description = _("Retiles an existing RASTER3D map with user defined x, y and z tile size");
+ module->description = _("Retiles an existing 3D raster map with user defined x, y and z tile size.");
set_params();
@@ -110,7 +110,7 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- G_debug(3, _("Open 3d raster map <%s>"), param.input->answer);
+ G_debug(3, "Open 3d raster map <%s>", param.input->answer);
mapset = G_find_raster3d(param.input->answer, "");
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -18,8 +18,8 @@
#%module
#% description: Dissolves boundaries between adjacent areas sharing a common category number or attribute.
#% keywords: vector
+#% keywords: dissolve
#% keywords: area
-#% keywords: dissolve
#%end
#%option G_OPT_V_INPUT
#%end
Modified: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
--- grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -16,8 +16,8 @@
#%module
#% description: Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps.
#% keywords: sites
+#% keywords: import
#% keywords: vector
-#% keywords: import
#%end
import sys
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -16,6 +16,7 @@
#%module
#% description: Uploads vector values at positions of vector points to the table.
#% keywords: vector
+#% keywords: sampling
#% keywords: database
#% keywords: attribute table
#%end
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/temporal/t.create/t.create.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -17,6 +17,7 @@
#%module
#% description: Creates a space time dataset.
#% keywords: temporal
+#% keywords: map management
#% keywords: create
#%end
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -17,7 +17,7 @@
#%module
#% description: Performs r.mapcalc expressions on maps of sampled space time raster datasets.
-#% keywords: mapcalc
+#% keywords: algebra
#%end
#%option G_OPT_STRDS_INPUTS
Modified: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -17,7 +17,7 @@
#%module
#% description: Performs r3.mapcalc expressions on maps of sampled space time raster3d datasets.
#%end
#%option G_OPT_STR3DS_INPUTS
Modified: grass/trunk/temporal/t.register/t.register.py
--- grass/trunk/temporal/t.register/t.register.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/temporal/t.register/t.register.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -17,6 +17,7 @@
#%module
#% description: Registers raster, vector and raster3d maps in a space time datasets.
#% keywords: register
#%end
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/temporal/t.remove/t.remove.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -17,6 +17,7 @@
#%module
#% description: Removes space time datasets from temporal database.
#% keywords: remove
#%end
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/temporal/t.sample/t.sample.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -17,7 +17,7 @@
#%module
#% description: Samples the input space time dataset(s) with a sample space time dataset and print the result to stdout.
-#% keywords: sample
#%end
#%option G_OPT_STDS_INPUTS
Modified: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
--- grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2012-08-22 19:17:24 UTC (rev 52838)
@@ -19,6 +19,7 @@
#% keywords: vector
+#% keywords: attribute table
#% keywords: select
#%end
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.buffer/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -218,8 +218,8 @@
+ G_add_keyword(_("buffer"));
G_add_keyword(_("geometry"));
- G_add_keyword(_("buffer"));
_("Creates a buffer around vector features of given type.");
Modified: grass/trunk/vector/v.build/main.c
--- grass/trunk/vector/v.build/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.build/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -34,8 +34,8 @@
+ G_add_keyword(_("topology"));
- G_add_keyword(_("topology"));
module->label = _("Creates topology for vector map.");
module->description = _("Optionaly also checks for topological errors.");
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.build.polylines/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -110,8 +110,8 @@
module->description = _("Builds polylines from lines or boundaries.");
/* Define the options */
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.clean/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -48,6 +48,7 @@
+ G_add_keyword(_("geometry"));
module->description = _("Toolset for cleaning topology of vector map.");
opt.in = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.distance/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -82,6 +82,7 @@
+ G_add_keyword(_("distance"));
G_add_keyword(_("database"));
G_add_keyword(_("attribute table"));
Modified: grass/trunk/vector/v.edit/main.c
--- grass/trunk/vector/v.edit/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.edit/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -53,8 +53,8 @@
module->overwrite = TRUE;
G_add_keyword(_("editing"));
- G_add_keyword(_("geometry"));
module->description = _("Edits a vector map, allows adding, deleting "
"and modifying selected vector features.");
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.net.visibility/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -43,6 +43,7 @@
/* initialize module */
+ G_add_keyword(_("network"));
G_add_keyword(_("path"));
G_add_keyword(_("visibility"));
module->description = _("Visibility graph construction.");
Modified: grass/trunk/vector/v.random/main.c
--- grass/trunk/vector/v.random/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.random/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -83,6 +83,7 @@
G_add_keyword(_("statistics"));
module->description = _("Generates randomly 2D/3D vector points map.");
Modified: grass/trunk/vector/v.sample/main.c
--- grass/trunk/vector/v.sample/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.sample/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -73,8 +73,8 @@
- G_add_keyword(_("resample"));
_("Samples a raster map at vector point locations.");
Modified: grass/trunk/vector/v.what/main.c
--- grass/trunk/vector/v.what/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.what/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -58,8 +58,8 @@
+ G_add_keyword(_("querying"));
G_add_keyword(_("position"));
- G_add_keyword(_("querying"));
module->description = _("Queries a vector map at given locations.");
opt.map = G_define_standard_option(G_OPT_V_MAPS);
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.what.rast/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -66,6 +66,7 @@
Modified: grass/trunk/vector/v.what.rast3/main.c
--- grass/trunk/vector/v.what.rast3/main.c 2012-08-22 15:47:59 UTC (rev 52837)
+++ grass/trunk/vector/v.what.rast3/main.c 2012-08-22 19:17:24 UTC (rev 52838)
@@ -62,6 +62,7 @@
