[GRASS-SVN] r52857 - grass/trunk/vector/v.what.rast
svn_grass at osgeo.org
Thu Aug 23 05:17:16 PDT 2012
Author: mmetz
Date: 2012-08-23 05:17:15 -0700 (Thu, 23 Aug 2012)
New Revision: 52857
grass/trunk/vector/v.what.rast/main.c
v.what.rast: fix fp precision, close raster map, support centroids
Modified: grass/trunk/vector/v.what.rast/main.c
--- grass/trunk/vector/v.what.rast/main.c 2012-08-23 10:39:24 UTC (rev 52856)
+++ grass/trunk/vector/v.what.rast/main.c 2012-08-23 12:17:15 UTC (rev 52857)
@@ -36,6 +36,7 @@
RASTER_MAP_TYPE out_type;
CELL *cell;
DCELL *dcell;
+ int width;
double drow, dcol;
char buf[2000];
struct {
@@ -123,6 +124,10 @@
fd = Rast_open_old(opt.rast->answer, "");
out_type = Rast_get_map_type(fd);
+ width = 7;
+ if (out_type == DCELL_TYPE)
+ width = 15;
/* TODO: Later possibly category labels */
@@ -146,7 +151,7 @@
G_warning(_("Raster type is float and column type is integer, some data lost!!"));
/* Read vector points to cache */
- Cache_size = Vect_get_num_primitives(&Map, GV_POINT);
+ Cache_size = Vect_get_num_primitives(&Map, GV_POINTS);
/* Note: Some space may be wasted (outside region or no category) */
cache = (struct order *)G_calloc(Cache_size, sizeof(struct order));
@@ -165,7 +170,7 @@
G_percent(i, nlines, 2);
/* check type */
- if (!(type & GV_POINT))
+ if (!(type & GV_POINTS))
continue; /* Points only */
/* check region */
@@ -266,6 +271,7 @@
cache[point].dvalue = dcell[cache[point].col];
} /* point loop */
+ Rast_close(fd);
/* Update table from cache */
G_debug(1, "Updating db table");
@@ -317,7 +323,7 @@
sprintf(buf, "NULL");
else {
- sprintf(buf, "%.10f", cache[point].dvalue);
+ sprintf(buf, "%.*f", width, cache[point].dvalue);
db_append_string(&stmt, buf);
