[GRASS-SVN] r52864 - grass/branches/develbranch_6/gui/wxpython/nviz
Thu Aug 23 10:27:11 PDT 2012
Author: annakrat
Date: 2012-08-23 10:27:11 -0700 (Thu, 23 Aug 2012)
New Revision: 52864
   grass/branches/develbranch_6/gui/wxpython/nviz/tools.py
wxNviz: tooltips added (merge from trunk, r52863)
Modified: grass/branches/develbranch_6/gui/wxpython/nviz/tools.py
--- grass/branches/develbranch_6/gui/wxpython/nviz/tools.py	2012-08-23 17:19:25 UTC (rev 52863)
+++ grass/branches/develbranch_6/gui/wxpython/nviz/tools.py	2012-08-23 17:27:11 UTC (rev 52864)
@@ -235,8 +235,9 @@
         # perspective
         # set initial defaults here (or perhaps in a default values file), not in user settings
         #todo: consider setting an absolute max at 360 instead of undefined. (leave the default max value at pi)
+        tooltip = _("Adjusts the viewer's angle of view")
         self._createControl(panel, data = self.win['view'], name = 'persp',
-                            range = (1,180),
+                            tooltip = tooltip, range = (1, 120),
                             bind = (self.OnViewChange, self.OnViewChanged, self.OnViewChangedText))
         gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Perspective:")),
@@ -247,8 +248,10 @@
                       flag = wx.ALIGN_CENTER)
         # twist
+        tooltip = _("Rotates the scene about the horizontal axis."
+                   " An angle of 0 is flat. The scene rotates between -90 and 90 degrees.")
         self._createControl(panel, data = self.win['view'], name = 'twist',
-                            range = (-180,180),
+                            tooltip = tooltip, range = (-180,180),
         gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Twist:")),
                       pos = (1, 1), flag = wx.ALIGN_CENTER)
@@ -257,11 +260,15 @@
         # height + z-exag
+        tooltip = _("Adjusts the viewer's height above the scene")
         self._createControl(panel, data = self.win['view'], name = 'height', sliderHor = False,
-                            range = (0, 1),
+                            tooltip = tooltip, range = (0, 1),
+        tooltip = _("Adjusts the vertical exaggeration of the surface. "
+                    "As an example, if the easting and northing are in meters and the elevation in feet, "
+                    "a vertical exaggeration of .305 would produce a true (unexaggerated) surface. ")
         self._createControl(panel, data = self.win['view'], name = 'z-exag', sliderHor = False,
-                            range = (0, 10), floatSlider = True,
+                            tooltip = tooltip, range = (0, 10), floatSlider = True,
         self.FindWindowById(self.win['view']['z-exag']['slider']).SetValue(1)
         self.FindWindowById(self.win['view']['z-exag']['text']).SetValue(1)
@@ -292,18 +299,23 @@
         here = wx.ToggleButton(panel, id = wx.ID_ANY, label = _("here"))
         here.Bind(wx.EVT_TOGGLEBUTTON, self.OnLookAt)
         here.SetName('here')
+        here.SetToolTipString(_("Allows you to select a point on the surface "
+                                "that becomes the new center of view. "
+                                "Click on the button and then on the surface."))
         viewSizer.Add(item = here, flag = wx.TOP|wx.BOTTOM|wx.LEFT|wx.ALIGN_CENTER_VERTICAL,
                       border = 5)
         center = wx.Button(panel, id = wx.ID_ANY, label = _("center"))
         center.Bind(wx.EVT_BUTTON, self.OnLookAt)
         center.SetName('center')
+        center.SetToolTipString(_("Resets the view to the original default center of view"))
         viewSizer.Add(item = center, flag = wx.TOP|wx.BOTTOM | wx.ALIGN_CENTER_VERTICAL,
                       border = 5)
         top = wx.Button(panel, id = wx.ID_ANY, label = _("top"))
         top.Bind(wx.EVT_BUTTON, self.OnLookAt)
         top.SetName('top')
+        top.SetToolTipString(_("Sets the viewer directly over the scene's center position. This top view orients approximately north south."))
         viewSizer.Add(item = top, flag = wx.TOP|wx.BOTTOM | wx.ALIGN_CENTER_VERTICAL,
                       border = 5)
@@ -845,8 +857,9 @@
         gridSizer.AddGrowableCol(3)
         # position
+        tooltip = _("Changes the x, y, and z position of the current surface")
         self._createControl(panel, data = self.win['surface'], name = 'position',
-                            range = (-10000, 10000), floatSlider = True,
+                            tooltip = tooltip, range = (-10000, 10000), floatSlider = True,
                             bind = (self.OnSurfacePosition, self.OnSurfacePositionChanged, self.OnSurfacePositionText))
         axis = wx.Choice (parent = panel, id = wx.ID_ANY, size = (75, -1),
@@ -960,8 +973,9 @@
         gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
                                          label = _("Horizontal X:")),
                       pos = (0, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+        tooltip = _("Sets the X coordinate of the current cutting plane")
         self._createControl(panel, data = self.win['cplane']['position'], name = 'x', size = 250,
-                            range = (-1000, 1000), sliderHor = True, floatSlider = True,
+                            range = (-1000, 1000), sliderHor = True, floatSlider = True, tooltip = tooltip,
                             bind = (self.OnCPlaneChanging, self.OnCPlaneChangeDone, self.OnCPlaneChangeText))
         self.FindWindowById(self.win['cplane']['position']['x']['slider']).SetValue(0)
         self.FindWindowById(self.win['cplane']['position']['x']['text']).SetValue(0)
@@ -975,8 +989,9 @@
                                          label = _("Horizontal Y:")),
                       pos = (1, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+        tooltip = _("Sets the Y coordinate of the current cutting plane")
         self._createControl(panel, data = self.win['cplane']['position'], name = 'y', size = 250,
         self.FindWindowById(self.win['cplane']['position']['y']['slider']).SetValue(0)
         self.FindWindowById(self.win['cplane']['position']['y']['text']).SetValue(0)
@@ -991,8 +1006,9 @@
                                          label = _("Rotation:")),
                       pos = (2, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+        tooltip = _("Rotates the current cutting plane about vertical axis")
         self._createControl(panel, data = self.win['cplane']['rotation'], name = 'rot', size = 250,
-                            range = (0, 360), sliderHor = True,
+                            range = (0, 360), sliderHor = True, tooltip = tooltip,
         self.FindWindowById(self.win['cplane']['rotation']['rot']['slider']).SetValue(0)
         self.FindWindowById(self.win['cplane']['rotation']['rot']['text']).SetValue(0)
@@ -1005,9 +1021,10 @@
         # cutting plane tilt
                                          label = _("Tilt:")),
-                      pos = (3, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+                      pos = (3, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+        tooltip = _("Rotates the current cutting plane about horizontal axis")
         self._createControl(panel, data = self.win['cplane']['rotation'], name = 'tilt', size = 250,
         self.FindWindowById(self.win['cplane']['rotation']['tilt']['slider']).SetValue(0)
         self.FindWindowById(self.win['cplane']['rotation']['tilt']['text']).SetValue(0)
@@ -1020,9 +1037,10 @@
         # cutting pland height
                                          label = _("Height:")),
-                      pos = (4, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+                      pos = (4, 0), flag = wx.ALIGN_CENTER_VERTICAL)
+        tooltip = _("Sets the Z coordinate of the current cutting plane (only meaningful when tilt is not 0)")
         self._createControl(panel, data = self.win['cplane']['position'], name = 'z', size = 250,
+                            range = (-1000, 1000), sliderHor = True, tooltip = tooltip,
         self.FindWindowById(self.win['cplane']['position']['z']['slider']).SetValue(0)
         self.FindWindowById(self.win['cplane']['position']['z']['text']).SetValue(0)
@@ -1650,8 +1668,9 @@
         gridSizer.Add(item = posSizer, pos = (0, 0))
         # height
+        tooltip = _("Adjusts the light height")
         self._createControl(panel, data = self.win['light'], name = 'z', sliderHor = False,
-                            range = (0, 100),
+                            range = (0, 100), tooltip = tooltip,
                             bind = (self.OnLightChange, self.OnLightChanged, self.OnLightChange))
         heightSizer = wx.GridBagSizer(vgap = 3, hgap = 3)
@@ -1689,8 +1708,9 @@
         gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Brightness:")),
+        tooltip = _("Adjusts the brightness of the light")
         self._createControl(panel, data = self.win['light'], name = 'bright', size = 300,
-                            range = (0, 100),
                             bind = (self.OnLightValue, self.OnLightChanged, self.OnLightValue))
         gridSizer.Add(item = self.FindWindowById(self.win['light']['bright']['slider']),
                       pos = (1, 1), flag = wx.ALIGN_CENTER_VERTICAL)
@@ -1699,8 +1719,9 @@
         gridSizer.Add(item = wx.StaticText(panel, id = wx.ID_ANY, label = _("Ambient:")),
+        tooltip = _("Adjusts the ambient light")
         self._createControl(panel, data = self.win['light'], name = 'ambient', size = 300,
-                            range = (0, 100),
         gridSizer.Add(item = self.FindWindowById(self.win['light']['ambient']['slider']),
                       pos = (2, 1), flag = wx.ALIGN_CENTER_VERTICAL)
@@ -2444,7 +2465,7 @@
         return panel
-    def _createControl(self, parent, data, name, range, bind = (None, None, None),
+    def _createControl(self, parent, data, name, range, tooltip = None, bind = (None, None, None),
                        sliderHor = True, size = 200, floatSlider = False):
         """!Add control (Slider + TextCtrl)"""
         data[name] = dict()
@@ -2480,6 +2501,8 @@
                             style = wx.TE_PROCESS_ENTER)
         text.SetName('text')
+        if tooltip:
+            text.SetToolTipString(tooltip)
         if bind[2]:
             text.Bind(wx.EVT_TEXT_ENTER, bind[2])
             text.Bind(wx.EVT_KILL_FOCUS, bind[2])
@@ -4814,7 +4837,8 @@
     def __init__(self, parent, mapwindow, id = wx.ID_ANY,
                  **kwargs):
         PositionWindow.__init__(self, parent, mapwindow, id, **kwargs)
+        self.SetToolTipString(_("Adjusts the look direction (azimuth). "
+                                "Click and drag the puck to change the current eye position."))
         self.data = self.mapWindow.view
         self.PostDraw()
@@ -4846,6 +4870,8 @@
                  **kwargs):
+        self.SetToolTipString(_("Adjusts the light direction. "
+                                "Click and drag the puck to change the light direction."))
         self.data = self.mapWindow.light
         self.quick = False
