[GRASS-SVN] r52875 - grass-addons/grass7/raster/r.hydrodem
svn_grass at osgeo.org
Fri Aug 24 10:10:45 PDT 2012
Author: mmetz
Date: 2012-08-24 10:10:45 -0700 (Fri, 24 Aug 2012)
New Revision: 52875
grass-addons/grass7/raster/r.hydrodem/do_astar.c
grass-addons/grass7/raster/r.hydrodem/hydro_con.c
grass-addons/grass7/raster/r.hydrodem/load.c
grass-addons/grass7/raster/r.hydrodem/local_proto.h
grass-addons/grass7/raster/r.hydrodem/main.c
r.hyrodem optimization
Modified: grass-addons/grass7/raster/r.hydrodem/do_astar.c
--- grass-addons/grass7/raster/r.hydrodem/do_astar.c 2012-08-24 13:15:05 UTC (rev 52874)
+++ grass-addons/grass7/raster/r.hydrodem/do_astar.c 2012-08-24 17:10:45 UTC (rev 52875)
@@ -19,7 +19,7 @@
int do_astar(void)
int r, c, r_nbr, c_nbr, ct_dir;
- int count;
+ unsigned int count;
int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
@@ -299,7 +299,7 @@
struct heap_point heap_drop(void)
unsigned int child, childr, parent;
- int i;
+ unsigned int i;
struct heap_point child_p, childr_p, last_p, root_p;
seg_get(&search_heap, (char *)&last_p, 0, heap_size);
Modified: grass-addons/grass7/raster/r.hydrodem/hydro_con.c
--- grass-addons/grass7/raster/r.hydrodem/hydro_con.c 2012-08-24 13:15:05 UTC (rev 52874)
+++ grass-addons/grass7/raster/r.hydrodem/hydro_con.c 2012-08-24 17:10:45 UTC (rev 52875)
@@ -14,16 +14,19 @@
static struct ns *n_stack;
-static unsigned int stack_alloc;
+static int stack_alloc;
-int count_fill(int peak_r, int peak_c, CELL peak_ele, int *n_splits,
+static int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
+static int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
+static int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
+static int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
+static int count_fill(int peak_r, int peak_c, CELL peak_ele, int *n_splits,
CELL *next_ele)
- int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
- int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
- int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
- int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
CELL ele_val, ele_nbr;
int n_to_fill;
int top, done;
@@ -108,13 +111,9 @@
/* detect flat area:
* count neighbouring cells with same ele
* exclude contributing cells and cell this one is contributing to */
-int is_flat(int r, int c, CELL this_ele)
+static int is_flat(int r, int c, CELL this_ele)
int r_nbr, c_nbr, ct_dir;
CELL ele_nbr;
char drain_val, drain_val_nbr;
int counter = 0;
@@ -150,13 +149,9 @@
return (counter > 0);
-int fill_sink(int peak_r, int peak_c, CELL peak_ele)
+static int fill_sink(int peak_r, int peak_c, CELL peak_ele)
CELL ele_nbr;
int n_to_fill = 0;
int top, done;
@@ -225,17 +220,13 @@
/* carve channel */
-int carve(int bottom_r, int bottom_c, CELL bottom_ele,
+static int carve(int bottom_r, int bottom_c, CELL bottom_ele,
int peak_r, int peak_c)
int r, c, r_nbr, c_nbr, carved = 0;
char drain_val;
int ct_dir;
int top, done;
/* carve upstream from spill point --> */
@@ -343,8 +334,6 @@
CELL ele_val, ele_nbr, ele_last, peak_ele, bottom_ele;
int down_uphill, down_downhill, n_cells;
struct sink_list *last_sink;
char drain_val, flag_value;
int n_splits, n_to_fill;
int n_filled, n_carved, n_just_a_bit, n_processed;
@@ -554,7 +543,7 @@
last_ele = ele_nbr = peak_ele;
min_bottom_ele = bottom_ele;
this_is_flat = 0;
- while (ele_nbr >= bottom_ele && this_is_flat < 3) {
+ while (ele_nbr >= bottom_ele && this_is_flat < 4) {
if (ele_nbr > bottom_ele) {
down_downhill++;
/* catch min 2 consecutive cells
@@ -562,7 +551,7 @@
if (is_flat(r_nbr, c_nbr, ele_nbr)) {
if (ele_nbr == last_ele) {
this_is_flat++;
- if (this_is_flat > 1 &&
+ if (this_is_flat > 2 &&
ele_nbr > min_bottom_ele)
min_bottom_ele = bottom_ele + 1;
@@ -588,7 +577,7 @@
/* carving ok */
- if (this_is_flat < 3) {
+ if (this_is_flat < 4) {
/* count cells to carve from sink bottom to spill point */
ele_last = ele_nbr = bottom_ele;
@@ -633,6 +622,10 @@
+ /* there is no better solution by filling more */
+ if (n_to_fill > least_impact)
+ break;
G_debug(2,
"channel length to spill point %d, channel length from spill point %d, cells to fill %d",
down_uphill, down_downhill, n_to_fill);
@@ -643,7 +636,7 @@
/* remains a mystery why n_new_splits results in less modifications... */
if (sqrt(n_to_fill) < (down_uphill + down_downhill) ||
n_new_splits <= 4 ||
- bottom_ele < min_bottom_ele ||
+ bottom_ele <= min_bottom_ele ||
least_impact == li_max) {
/* continue with IRA */
G_debug(2, "IRA conditions fulfilled");
@@ -780,8 +773,6 @@
int r, c, r_nbr, c_nbr;
int ct_dir;
int skipme;
CELL ele_min, ele_max, ele_this, ele_nbr;
unsigned int n_pits = 0;
Modified: grass-addons/grass7/raster/r.hydrodem/load.c
--- grass-addons/grass7/raster/r.hydrodem/load.c 2012-08-24 13:15:05 UTC (rev 52874)
+++ grass-addons/grass7/raster/r.hydrodem/load.c 2012-08-24 17:10:45 UTC (rev 52875)
@@ -12,7 +12,7 @@
* loads elevation map to segment file and gets start points for A* Search,
* start points are edges
-int load_map(int ele_fd, int depr_fd)
+int load_map(int ele_fd)
int r, c;
char flag_value, asp_value = 0;
Modified: grass-addons/grass7/raster/r.hydrodem/local_proto.h
--- grass-addons/grass7/raster/r.hydrodem/local_proto.h 2012-08-24 13:15:05 UTC (rev 52874)
+++ grass-addons/grass7/raster/r.hydrodem/local_proto.h 2012-08-24 17:10:45 UTC (rev 52875)
@@ -70,7 +70,7 @@
extern CSEG stream;
/* load.c */
-int load_map(int, int);
+int load_map(int);
/* init_search.c */
int init_search(int);
Modified: grass-addons/grass7/raster/r.hydrodem/main.c
--- grass-addons/grass7/raster/r.hydrodem/main.c 2012-08-24 13:15:05 UTC (rev 52874)
+++ grass-addons/grass7/raster/r.hydrodem/main.c 2012-08-24 17:10:45 UTC (rev 52875)
@@ -250,7 +250,7 @@
heap_mem += (num_open_segs * 4 - num_seg_total) * seg2kb / 1024.;
/* load map */
- if (load_map(ele_fd, depr_fd) < 0) {
+ if (load_map(ele_fd) < 0) {
cseg_close(&ele);
bseg_close(&draindir);
bseg_close(&bitflags);
