[GRASS-SVN] r52877 - grass-addons/grass6/raster/r.sun.angle
    svn_grass at osgeo.org
    Fri Aug 24 11:13:55 PDT 2012
Author: mmetz
Date: 2012-08-24 11:13:55 -0700 (Fri, 24 Aug 2012)
New Revision: 52877
Removed:
   grass-addons/grass6/raster/r.sun.angle/README
   grass-addons/grass6/raster/r.sun.angle/TODO
   grass-addons/grass6/raster/r.sun.angle/g_solposition.c
   grass-addons/grass6/raster/r.sun.angle/global.h
   grass-addons/grass6/raster/r.sun.angle/Makefile
   grass-addons/grass6/raster/r.sun.angle/description.html
   grass-addons/grass6/raster/r.sun.angle/main.c
   grass-addons/grass6/raster/r.sun.angle/solpos00.c
   grass-addons/grass6/raster/r.sun.angle/solpos00.h
r.sun.angle: sun elevation, azimuth, photoperiod
Modified: grass-addons/grass6/raster/r.sun.angle/Makefile
--- grass-addons/grass6/raster/r.sun.angle/Makefile	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/Makefile	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = r.sunmask
+PGM = r.sun.angle
 LIBES =  $(GPROJLIB) $(GISLIB)
 DEPENDENCIES = $(GPROJDEP) $(GISDEP)
Deleted: grass-addons/grass6/raster/r.sun.angle/README
--- grass-addons/grass6/raster/r.sun.angle/README	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/README	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,45 +0,0 @@
-r.sunmask can be used in two ways:
-a) define sun position:
-r.sunmask elev=dgm25 output=dgm25.shadow alt=47.394203 azim=138.604904
-b) define location, date, time
-r.sunmask -v el=dgm5 out=shadow year=1997 month=9 day=25 hour=11 minute=15 \
-          sec=0 timezone=1 east=3570720 north=5766095
-or (using map center coordinates)
-          sec=0 timezone=1
-Calculating sun position... (using solpos (V. 11 April 2001) from NREL)
- 1997.09.25, daynum 268, time: 11:15:00
- long: 10.030458, lat: 52.025555, timezone: 2.000000
- Solar position: sun azimuth 145.121445,
-   sun angle above horz.(refraction corrected) 31.662413
- Sunrise time (without refraction): 07:16
- Sunset time  (without refraction): 19:07
-Calculating shadows from DEM...
-Since the solpos algorithm expects lat/long coordinates, the module
-transforms the local coordinates to lat/long on-the-fly
-daylight savings: Rather than convert time to GMT, the solpos
-algorithm uses what is called Local Standard Time, which is generally
-defined politically as an offset from GMT.  So the key is the offset from
-GMT, which the solpos Time Zone parameter.  If the user specifies clock time
-(different for winter and summer), he/she would have to change the Time Zone
-parameter seasonally in r.sunmask (timezone parameter).
-solpos questions can be directed to
-> Steve Wilcox (Stephen_Wilcox at nrel.gov)
-> National Renewable Energy Laboratory
-> 1617 Cole Boulevard, Golden, CO 80401-3393
-> voice: 1-303-275-4061; fax: 1-303-275-4675
-  http://rredc.nrel.gov/solar/codes_algs/solpos/
Deleted: grass-addons/grass6/raster/r.sun.angle/TODO
--- grass-addons/grass6/raster/r.sun.angle/TODO	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/TODO	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,2 +0,0 @@
-improve speed for FP maps
Modified: grass-addons/grass6/raster/r.sun.angle/description.html
--- grass-addons/grass6/raster/r.sun.angle/description.html	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/description.html	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,114 +1,36 @@
 <h2>DESCRIPTION</h2>
-<em>r.sunmask</em> creates an output map layer based on an input elevation
-raster map layer and the sun position. The output map layer contains the
-cast shadow areas arising from sun shine and elevations. The user can define
-the sun position either directly or the module calculates it from given
-location and date/time parameters using the
-<a href=http://rredc.nrel.gov/>NREL</a> sun position algorithm. So either
-"A:"-parameters to specify the exact known sun position or "B:-parameters"
-to specify date/time for sun position calculation by r.sunmask itself have
-to be used.
+<em>r.sun.angle</em> calculates sun elevation and sun azimuth angles for
+the given time of day and each grid cell in the current region.
+Additionally, the photoperiod (sunshine hours) can be calculated.
 <p>
-The module performs sunset/sunrise checks and refraction correction for sun
-position calculation. Local coordinate systems are internally transformed to
-latitude/longitude for the SOLPOS algorithm. The elevation is not considered
-in the sunset/sunrise calculations.
-<h2>NOTES</h2>
-r.sunmask and daylight savings: Rather than convert time to GMT, the solpos
-parameter seasonally in r.sunmask (timezone parameter). See also
-<a href="http://en.wikipedia.org/wiki/Daylight_saving_time_by_country">Daylight saving time by region and country</a>.
+Sun elevation, height, height angle, or solar altitude angle is the
+angle in degrees between the horizon and a line that points from the
+site towards the centre of the sun.
 <p>
-Note: In latitude/longitude locations the position coordinates pair
-(east/west) has to be specified in decimal degree (not D:M:S). If
-not specified, the map center's coordinates will be used.
-Also <em>g.region -l</em> displays the map center's coordinates.
+The sun azimuth angle is here defined as the azimuth angle in degrees
+of the sun from due north in a clockwise direction.
 <p>
-Note for module usage with <em>-g</em> flag and calculations
-close to sunset/sunrise:
+The time used here is defined such that 12:00 (high noon) is the time
+when the sun has reached its highest point in the sky at the current site,
+unless the <em>-t</em> flag is used in which case time is interpreted as
+Greenwich standard time.
+<p>
+If a <em>sunhour</em> output map is specified, the module calculates
+sunshine hours for the given day. This option requires both Greenwhich
+standard time (<em>-t</em> flag) and the solpos algorithm of NREL
+(<em>-s</em> flag).
-<pre>
- sunangleabovehorizont=0.434240
- sunrise=07:59:19
- sunset=16:25:17
- Time (07:59:02) is before sunrise (07:59:19)!
- WARNING: Nothing to calculate. Please verify settings.
- No map calculation requested. Finished.
-</pre>
+<h2>EXAMPLES</h2>
-In above calculation appears to be a mistake as
-the program indicates that we are before sunrise while
-the <i>sun angle above horizon</i> is already positive.
-The reason is that <i>sun angle above horizon</i> is
-calculated with correction for atmosphere refraction while
-<i>sunrise</i> and <i>sunset</i> are calculated <b>without</b>
-correction for atmosphere refraction. The output without
-<em>-g</em> flag contains related indications.
-<h2>EXAMPLE</H2>
-Example for North Carolina sample data set for the calculation
-of sun position angles and more:
+Calculate sun's elevation angle map for 2010-10-11 at 14:00h solar time:
 <div class="code"><pre>
-# set the region to a place near Raleigh (NC)
-g.region rast=elev_lid792_1m -p
-# compute the sun position
-r.sunmask -s --v elev_lid792_1m out=dummy year=2012 month=2 \
-          day=22 hour=10 minute=30 sec=0 timezone=-5
-Using map center coordinates: 638650.000000 220375.000000
-2012/02/22, daynum: 53, time: 10:30:00 (decimal time: 10.500000)
-long: -78.678856, lat: 35.736160, timezone: -5.000000
-Solar position: sun azimuth: 143.006424, sun angle above horz. (refraction corrected): 36.233883
-Sunrise time (without refraction): 06:58:11
-Sunset time  (without refraction): 17:58:47
-# with -g flag
-r.sunmask -s -g --v elev_lid792_1m out=dummy year=2012 month=2 \
-date=2012/02/22
-daynum=53
-time=10:30:00
-decimaltime=10.500000
-longitudine=-78.678856
-latitude=35.736160
-timezone=-5.000000
-sunazimuth=143.006424
-sunangleabovehorizon=36.233883
-sunrise=06:58:11
-sunset=17:58:47
+r.sun.angle elevation=sun_elev year=2010 month=10 day=11 hour=14 minute=00
 </pre></div>
-<h2>Acknowledgements</h2>
-Acknowledgements: National Renewable Energy Laboratory for
-their <a href=http://rredc.nrel.gov/solar/codes_algs/solpos/>SOLPOS 2.0</a> sun position
-algorithm.
-<h2>SEE ALSO</h2>
-<em>
-<a href="g.region.html">g.region</a>,
-<a href="r.sun.html">r.sun</a>,
-<a href="r.slope.aspect.html">r.slope.aspect</a>
-</em>
 <h2>AUTHOR</h2>
-Janne Soimasuo, Finland 1994<br>
-update to FP by Huidae Cho 2001<br>
-added solpos algorithm feature by Markus Neteler 2001
+Markus Metz
 <p><i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/raster/r.sun.angle/g_solposition.c
--- grass-addons/grass6/raster/r.sun.angle/g_solposition.c	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/g_solposition.c	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,173 +0,0 @@
- * G_calc_solar_position() calculates solar position parameters from
- * given position, date and time
- * Written by Markus Neteler <neteler at geog.uni-hannover.de>
- * with kind help from Morten Hulden <morten untamo.net>
- * using solpos.c with permission from
- *   From rredc at nrel.gov Wed Mar 21 18:37:25 2001
- *   Message-Id: <v04220805b6de9b1ad6ff@[192.174.39.30]>
- *   Mary Anderberg
- *   http://rredc.nrel.gov
- *   National Renewable Energy Laboratory
- *   1617 Cole Boulevard
- *   Golden, Colorado, USA 80401
- *   http://rredc.nrel.gov/solar/codes_algs/solpos/
- *  G_calc_solar_position is based on: soltest.c
- *    by
- *    Martin Rymes
- *    25 March 1998
-/* uncomment to get debug output */
-#include <math.h>
-#include <string.h>
-#include <stdio.h>
-#include <grass/gis.h>
-#include <grass/glocale.h>
-#include <grass/gprojects.h>
-#include "solpos00.h"
-struct posdata pd, *pdat;	/* declare solpos data struct and a pointer for it */
-long calc_solar_position(double longitude, double latitude, double timezone,
-			 int year, int month, int day, int hour, int minute,
-			 int second)
-    /* Note: this code is valid from year 1950 to 2050 (solpos restriction)
-       - the algorithm will compensate for leap year.
-       - longitude, latitude: decimal degree
-       - timezone: DO NOT ADJUST FOR DAYLIGHT SAVINGS TIME.
-       - timezone: negative for zones west of Greenwich
-       - lat/long: east and north positive
-       - the atmospheric refraction is calculated for 1013hPa, 15°C
-       - time: local time from your watch
-    long retval;		/* to capture S_solpos return codes */
-    struct Key_Value *in_proj_info, *in_unit_info;	/* projection information of input map */
-    struct pj_info iproj;	/* input map proj parameters  */
-    struct pj_info oproj;	/* output map proj parameters  */
-    extern struct Cell_head window;
-    int inside;
-    /* we don't like to run G_calc_solar_position in xy locations */
-    if (window.proj == 0)
-	G_fatal_error(_("Unable to calculate sun position in un-projected locations. "
-			"Specify sunposition directly."));
-    pdat = &pd;			/* point to the structure for convenience */
-    /* Initialize structure to default values. (Optional only if ALL input
-       parameters are initialized in the calling code, which they are not
-       in this example.) */
-    S_init(pdat);
-    /* check if given point is in current window */
-    G_debug(1, "window.north: %f, window.south: %f\n", window.north,
-	    window.south);
-    G_debug(1, "window.west:  %f, window.east : %f\n", window.west,
-	    window.east);
-    inside = 0;
-    if (latitude >= window.south && latitude <= window.north &&
-	longitude >= window.west && longitude <= window.east)
-	inside = 1;
-    if (!inside)
-	G_warning(_("Specified point %f, %f outside of current region, "
-		    "is that intended? Anyway, it will be used."),
-		  longitude, latitude);
-    /* if coordinates are not in lat/long format, transform them: */
-    if ((G_projection() != PROJECTION_LL) && window.proj != 0) {
-	G_debug(1, "Transforming input coordinates to lat/long (req. for solar position)");
-	/* read current projection info */
-	if ((in_proj_info = G_get_projinfo()) == NULL)
-	    G_fatal_error(_("Unable to get projection info of current location"));
-	if ((in_unit_info = G_get_projunits()) == NULL)
-	    G_fatal_error(_("Unable to get projection units of current location"));
-	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
-	    G_fatal_error(_("Unable to get projection key values of current location"));
-	G_free_key_value(in_proj_info);
-	G_free_key_value(in_unit_info);
-	/* Try using pj_print_proj_params() instead of all this */
-	G_debug(1, "Projection found in location:");
-	G_debug(1, "IN: meter: %f zone: %i proj: %s (iproj struct)",
-		iproj.meters, iproj.zone, iproj.proj);
-	G_debug(1, "IN coord: longitude: %f, latitude: %f", longitude,
-		latitude);
-	/* see src/include/projects.h, struct PJconsts */
-	/* set output projection to lat/long for solpos */
-	oproj.zone = 0;
-	oproj.meters = 1.;
-	sprintf(oproj.proj, "ll");
-	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
-	    G_fatal_error("Unable to set up lat/long projection parameters");
-	/* XX do the transform
-	 *               outx        outy    in_info  out_info */
-	if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
-	    G_fatal_error(_("Error in pj_do_proj (projection of input coordinate pair)"));
-	G_debug(1, "Transformation to lat/long:");
-	G_debug(1, "OUT: longitude: %f, latitude: %f", longitude,
-		latitude);
-    }				/* transform if not LL */
-    pdat->longitude = longitude;	/* Note that latitude and longitude are  */
-    pdat->latitude = latitude;	/*   in DECIMAL DEGREES, not Deg/Min/Sec */
-    pdat->timezone = timezone;	/* DO NOT ADJUST FOR DAYLIGHT SAVINGS TIME. */
-    pdat->year = year;		/* The year */
-    pdat->function &= ~S_DOY;
-    pdat->month = month;
-    pdat->day = day;		/* the algorithm will compensate for leap year, so
-				   you just count days). S_solpos can be
-				   configured to accept day-of-the year */
-    /* The time of day (STANDARD (GMT) time) */
-    pdat->hour = hour;
-    pdat->minute = minute;
-    pdat->second = second;
-    /* Let's assume that the temperature is 20 degrees C and that
-       the pressure is 1013 millibars.  The temperature is used for the
-       atmospheric refraction correction, and the pressure is used for the
-       refraction correction and the pressure-corrected airmass. */
-    pdat->temp = 20.0;
-    pdat->press = 1013.0;
-    /* Finally, we will assume that you have a flat surface
-       facing nowhere, tilted at latitude. */
-    pdat->tilt = pdat->latitude;	/* tilted at latitude */
-    pdat->aspect = 180.0;
-    /* perform the calculation */
-    retval = S_solpos(pdat);	/* S_solpos function call: returns long value */
-    S_decode(retval, pdat);	/* prints an error in case of problems */
-    return retval;
Deleted: grass-addons/grass6/raster/r.sun.angle/global.h
--- grass-addons/grass6/raster/r.sun.angle/global.h	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/global.h	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,12 +0,0 @@
-#ifdef MAIN
-#define GLOBAL
-#else
-#define GLOBAL extern
-#endif
-GLOBAL float asol, phi0, sun_zenith, sun_azimuth;	/* from nadir, from north */
-GLOBAL int sunset;
-/* proto */
-long calc_solar_position(double, double, double, int, int, int, int, int,
-			 int);
Modified: grass-addons/grass6/raster/r.sun.angle/main.c
--- grass-addons/grass6/raster/r.sun.angle/main.c	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/main.c	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,44 +1,19 @@
- * MODULE:       r.sunmask
- * AUTHOR(S):    Janne Soimasuo, Finland 1994 (original contributor)
- *               update to FP by Huidae Cho <grass4u gmail.com> 2001
- *               added solpos algorithm feature by Markus Neteler 2001
- *               Brad Douglas <rez touchofmadness.com>, Glynn Clements <glynn gclements.plus.com>,
- *               Hamish Bowman <hamish_b yahoo.com>, Paul Kelly <paul-grass stjohnspoint.co.uk>
- * PURPOSE:
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ * MODULE:       r.sun.angle
+ * AUTHOR(S):    Markus Metz
+ * PURPOSE:      Calculates solar azimuth and angle
+ * COPYRIGHT:    (C) 2010 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
  *               for details.
- * r.sunmask:
- *   Calculates the cast shadow areas from a DEM
- * input: DEM (int, float, double)
- * output: binary shadow map
- *    no shadow: null()
- *    shadow:    1
- * Algorithm source: unknown (Janne Soimasuo?)
- * Original module author: Janne Soimasuo, Finland 1994
- * GPL >= 2
- * Added solpol sun position calculation:
- * Markus Neteler 4/2001
- * MN 2/2001: attempt to update to FP
- * Huidae Cho 3/2001: FP update done
- *                    but it's somewhat slow with non-CELL maps
+/* TODO: always use solpos if time is Greenwich standard time */
 #define MAIN
 #include <stdio.h>
@@ -46,105 +21,78 @@
 #include <string.h>
 #include <math.h>
+#include <grass/gprojects.h>
-#include "global.h"
-/* to be displayed in r.sunmask */
-static char *SOLPOSVERSION = "11 April 2001";
+void set_solpos_time(struct posdata *, int, int, int, int, int, int);
+void set_solpos_longitude(struct posdata *, double );
+int roundoff(double *);
-extern struct posdata pd, *pdat;	/* declare a posdata struct and a pointer for
-					   it (if desired, the structure could be
-					   allocated dynamically with G_malloc) */
-struct Cell_head window;
-union RASTER_PTR
-    void *v;
-    CELL *c;
-    FCELL *f;
-    DCELL *d;
-#ifdef	RASTER_VALUE_FUNC
-double raster_value(union RASTER_PTR buf, int data_type, int col);
-#else
-#define	raster_value(buf, data_type, col)	((double)(data_type == CELL_TYPE ? buf.c[col] : (data_type == FCELL_TYPE ? buf.f[col] : buf.d[col])))
-#endif
 int main(int argc, char *argv[])
-    char *mapset;
-    union RASTER_PTR elevbuf, tmpbuf, outbuf;
-    CELL min, max;
-    DCELL dvalue, dvalue2, dmin, dmax;
-    struct History hist;
-    RASTER_MAP_TYPE data_type;
-    struct Range range;
-    struct FPRange fprange;
-    double drow, dcol;
-    int elev_fd, output_fd, zeros;
+    struct GModule *module;
     struct
-	struct Option *opt1, *opt2, *opt3, *opt4, *north, *east, *year,
-	    *month, *day, *hour, *minutes, *seconds, *timezone;
+	struct Option *elev, *azimuth, *sunhours, *year,
+	    *month, *day, *hour, *minutes, *seconds;
+	struct Flag *gst_time, *solpos;
     } parm;
-    struct Flag *flag1, *flag2, *flag3, *flag4;
-    struct GModule *module;
-    char *name, *outname;
-    double dazi, dalti;
-    double azi, alti;
-    double nstep, estep;
-    double maxh;
-    double east, east1, north, north1;
-    int row1, col1;
-    char OK;
-    double timezone;
+    struct Cell_head window;
+    FCELL *elevbuf, *azimuthbuf, *sunhourbuf;
+    struct History hist;
+    /* projection information of input map */
+    struct Key_Value *in_proj_info, *in_unit_info;
+    struct pj_info iproj;	/* input map proj parameters  */
+    struct pj_info oproj;	/* output map proj parameters  */
+    char *elev_name, *azimuth_name, *sunhour_name;
+    int elev_fd, azimuth_fd, sunhour_fd;
+    double ha, ha_cos, s_gamma, s_elevation, s_azimuth;
+    double s_declination, sd_sin, sd_cos;
+    double se_sin, sa_cos;
+    double east, east_ll, north, north_ll;
+    double north_gc, north_gc_sin, north_gc_cos;  /* geocentric latitude */
+    double ba2;
     int year, month, day, hour, minutes, seconds;
-    long retval;
-    int solparms, locparms, use_solpos;
-    double sunrise, sunset, current_time;
-    int sretr = 0, ssetr = 0, sretr_sec = 0, ssetr_sec = 0;
-    double dsretr, dssetr;
+    int doy;   					/* day of year */
+    int row, col, nrows, ncols;
+    int do_reproj = 0;
+    int lst_time = 1;
+    int use_solpos = 0;
+    struct posdata pd;
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("raster, sun position");
-    module->label = _("Calculates cast shadow areas from sun position and elevation raster map.");
-    module->description = _("Either exact sun position (A) is specified, or date/time to calculate "
-			    "the sun position (B) by r.sunmask itself.");
+    module->keywords = _("raster");
+    module->label = _("Calculates solar elevation and azimuth.");
+    module->description = _("Solar elevation: the angle between the direction of the geometric center "
+			    "of the sun's apparent disk and the (idealized) horizon. "
+			    "Solar azimuth: the angle from due north in clockwise direction.");
-    parm.opt1 = G_define_standard_option(G_OPT_R_ELEV);
+    parm.elev = G_define_standard_option(G_OPT_R_OUTPUT);
+    parm.elev->key = "elevation";
+    parm.elev->label = _("Output raster map with solar elevation angle");
+    parm.elev->required = NO;
+    parm.azimuth = G_define_standard_option(G_OPT_R_OUTPUT);
+    parm.azimuth->key = "azimuth";
+    parm.azimuth->label = _("Output raster map with solar azimuth angle");
+    parm.azimuth->required = NO;
-    parm.opt2 = G_define_standard_option(G_OPT_R_OUTPUT);
-    parm.opt2->required = NO;
-    parm.opt3 = G_define_option();
-    parm.opt3->key = "altitude";
-    parm.opt3->type = TYPE_DOUBLE;
-    parm.opt3->required = NO;
-    parm.opt3->options = "0-89.999";
-    parm.opt3->description =
-	_("Altitude of the sun above horizon, degrees (A)");
-    parm.opt3->guisection = _("Position");
+    parm.sunhours = G_define_standard_option(G_OPT_R_OUTPUT);
+    parm.sunhours->key = "sunhour";
+    parm.sunhours->label = _("Output raster map with sunshine hours");
+    parm.sunhours->description = _("Sunshine hours require solpos and Greenwich standard time");
+    parm.sunhours->required = NO;
-    parm.opt4 = G_define_option();
-    parm.opt4->key = "azimuth";
-    parm.opt4->type = TYPE_DOUBLE;
-    parm.opt4->required = NO;
-    parm.opt4->options = "0-360";
-    parm.opt4->description =
-	_("Azimuth of the sun from the north, degrees (A)");
-    parm.opt4->guisection = _("Position");
     parm.year = G_define_option();
     parm.year->key = "year";
     parm.year->type = TYPE_INTEGER;
-    parm.year->required = NO;
-    parm.year->description = _("Year (B)");
+    parm.year->required = YES;
+    parm.year->description = _("Year");
     parm.year->options = "1950-2050";
     parm.year->guisection = _("Time");
@@ -152,411 +100,415 @@
     parm.month->key = "month";
     parm.month->type = TYPE_INTEGER;
     parm.month->required = NO;
-    parm.month->description = _("Month (B)");
+    parm.month->label = _("Month");
+    parm.month->description = _("If not given, day is interpreted as day of the year");
     parm.month->options = "0-12";
     parm.month->guisection = _("Time");
     parm.day = G_define_option();
     parm.day->key = "day";
     parm.day->type = TYPE_INTEGER;
-    parm.day->required = NO;
-    parm.day->description = _("Day (B)");
-    parm.day->options = "0-31";
+    parm.day->required = YES;
+    parm.day->description = _("Day");
+    parm.day->options = "0-365";
     parm.day->guisection = _("Time");
     parm.hour = G_define_option();
     parm.hour->key = "hour";
     parm.hour->type = TYPE_INTEGER;
-    parm.hour->required = NO;
-    parm.hour->description = _("Hour (B)");
+    parm.hour->required = YES;
+    parm.hour->description = _("Hour");
     parm.hour->options = "0-24";
+    parm.hour->answer = "12";
     parm.hour->guisection = _("Time");
     parm.minutes = G_define_option();
     parm.minutes->key = "minute";
     parm.minutes->type = TYPE_INTEGER;
-    parm.minutes->required = NO;
-    parm.minutes->description = _("Minutes (B)");
+    parm.minutes->required = YES;
+    parm.minutes->description = _("Minutes");
     parm.minutes->options = "0-60";
+    parm.minutes->answer = "0";
     parm.minutes->guisection = _("Time");
     parm.seconds = G_define_option();
     parm.seconds->key = "second";
     parm.seconds->type = TYPE_INTEGER;
-    parm.seconds->required = NO;
-    parm.seconds->description = _("Seconds (B)");
+    parm.seconds->required = YES;
+    parm.seconds->description = _("Seconds");
     parm.seconds->options = "0-60";
+    parm.seconds->answer = "0";
     parm.seconds->guisection = _("Time");
-    parm.timezone = G_define_option();
-    parm.timezone->key = "timezone";
-    parm.timezone->type = TYPE_INTEGER;
-    parm.timezone->required = NO;
-    parm.timezone->label =
-	_("Timezone");
-    parm.timezone->description = _("East positive, offset from GMT, also use to adjust daylight savings");
-    parm.timezone->guisection = _("Time");
+    parm.gst_time = G_define_flag();
+    parm.gst_time->key = 't';
+    parm.gst_time->description = _("Time is Greenwich standard time, not local sidereal time");
-    parm.east = G_define_option();
-    parm.east->key = "east";
-    parm.east->key_desc = "value";
-    parm.east->type = TYPE_STRING;
-    parm.east->required = NO;
-    parm.east->label =
-	_("Easting coordinate (point of interest)");
-    parm.east->description = _("Default: map center");
-    parm.east->guisection = _("Position");
+    parm.solpos = G_define_flag();
+    parm.solpos->key = 's';
+    parm.solpos->description = _("Use solpos algorithm of NREL");
-    parm.north = G_define_option();
-    parm.north->key = "north";
-    parm.north->key_desc = "value";
-    parm.north->type = TYPE_STRING;
-    parm.north->required = NO;
-    parm.north->label =
-	_("Northing coordinate (point of interest)");
-    parm.north->description = _("Default: map center");
-    parm.north->guisection = _("Position");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
-    flag1 = G_define_flag();
-    flag1->key = 'z';
-    flag1->description = _("Don't ignore zero elevation");
+    G_get_window(&window);
-    flag2 = G_define_flag();
-    flag2->key = 'v';
-    flag2->description =
-	_("Verbose output (also print out sun position etc.)");
+    /* require at least one output */
+    elev_name = parm.elev->answer;
+    azimuth_name = parm.azimuth->answer;
+    sunhour_name = parm.sunhours->answer;
+    if (!elev_name && !azimuth_name && !sunhour_name)
+	G_fatal_error(_("No output requested, exiting."));
-    flag3 = G_define_flag();
-    flag3->key = 's';
-    flag3->description = _("Calculate sun position only and exit");
-    flag3->guisection = _("Print");
-    flag4 = G_define_flag();
-    flag4->key = 'g';
-    flag4->description =
-	_("Print the sun position output in shell script style");
-    flag4->guisection = _("Print");
+    sscanf(parm.year->answer, "%i", &year);
+    if (parm.month->answer)
+	sscanf(parm.month->answer, "%i", &month);
+    else
+	month = -1;
+    sscanf(parm.day->answer, "%i", &day);
+    sscanf(parm.hour->answer, "%i", &hour);
+    sscanf(parm.minutes->answer, "%i", &minutes);
+    sscanf(parm.seconds->answer, "%i", &seconds);
-    if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
+    lst_time = (parm.gst_time->answer == 0);
+    use_solpos = parm.solpos->answer;
-    zeros = flag1->answer;
+    /* init variables */
+    ha = 180;
+    ha_cos = 0;
+    sd_cos = 0;
+    sd_sin = 1;
+    north_gc_cos = 0;
+    north_gc_sin = 1;
+    se_sin = 0;
-    G_get_window(&window);
+    if (use_solpos && lst_time) {
+	G_warning(_("NREL solpos algorithm uses Greenwich standard time."));
+	G_warning(_("Time will be interpreted as Greenwich standard time."));
-    /* if not given, get east and north: XX */
-    if (!parm.north->answer || !parm.east->answer) {
-	north = (window.north - window.south) / 2. + window.south;
-	east = (window.west - window.east) / 2. + window.east;
-	G_verbose_message(_("Using map center coordinates: %f %f"), east, north);
+	lst_time = 0;
-    else {			/* user defined east, north: */
-	sscanf(parm.north->answer, "%lf", &north);
-	sscanf(parm.east->answer, "%lf", &east);
-	if (strlen(parm.east->answer) == 0)
-	    G_fatal_error(_("Empty east coordinate specified"));
-	if (strlen(parm.north->answer) == 0)
-	    G_fatal_error(_("Empty north coordinate specified"));
+    if (!use_solpos) {
+	if (lst_time)
+	    G_message(_("Time will be interpreted as local sidereal time."));
+	else
+	    G_message(_("Time will be interpreted as Greenwich standard time."));
+	if (sunhour_name)
+	    G_fatal_error(_("Sunshine hours require solpos"));
-    /* check which method to use for sun position:
-       either user defines directly sun position or it is calculated */
+    if ((G_projection() != PROJECTION_LL)) {
+	if (window.proj == 0)
+	    G_fatal_error(_("Current projection is x,y (undefined)."));
-    if (parm.opt3->answer && parm.opt4->answer)
-	solparms = 1;		/* opt3 & opt4 complete */
-    else
-	solparms = 0;		/* calculate sun position */
+	do_reproj = 1;
-    if (parm.year->answer && parm.month->answer && parm.day->answer &&
-	parm.hour->answer && parm.minutes->answer && parm.seconds->answer &&
-	parm.timezone->answer)
-	locparms = 1;		/* complete */
-    else
-	locparms = 0;
+	/* read current projection info */
+	if ((in_proj_info = G_get_projinfo()) == NULL)
+	    G_fatal_error(_("Can't get projection info of current location"));
-    if (solparms && locparms)	/* both defined */
-	G_fatal_error(_("Either define sun position or location/date/time parameters"));
+	if ((in_unit_info = G_get_projunits()) == NULL)
+	    G_fatal_error(_("Can't get projection units of current location"));
-    if (!solparms && !locparms)	/* nothing defined */
-	G_fatal_error(_("Neither sun position nor east/north, date/time/timezone definition are complete"));
+	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+	    G_fatal_error(_("Can't get projection key values of current location"));
-    /* if here, one definition was complete */
-    if (locparms) {
-	G_message(_("Calculating sun position... (using solpos (V. %s) from NREL)"),
-		  SOLPOSVERSION);
-	use_solpos = 1;
+	G_free_key_value(in_proj_info);
+	G_free_key_value(in_unit_info);
+	/*  output projection to lat/long w/ same ellipsoid as input */
+	oproj.zone = 0;
+	oproj.meters = 1.;
+	sprintf(oproj.proj, "ll");
+	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+	    G_fatal_error(_("Unable to update lat/long projection parameters"));
-    else {
-	G_message(_("Using user defined sun azimuth, altitude settings (ignoring eventual other values)"));
-	use_solpos = 0;
-    name = parm.opt1->answer;
-    outname = parm.opt2->answer;
-    if (!use_solpos) {
-	sscanf(parm.opt3->answer, "%lf", &dalti);
-	sscanf(parm.opt4->answer, "%lf", &dazi);
+    /* always init pd */
+    S_init(&pd);
+    pd.function = S_GEOM;
+    if (use_solpos) {
+	pd.function = S_ZENETR;
+	if (azimuth_name)
+	    pd.function = S_SOLAZM;
+	if (sunhour_name)
+	    pd.function |= S_SRSS;
-    else {
-	sscanf(parm.year->answer, "%i", &year);
-	sscanf(parm.month->answer, "%i", &month);
-	sscanf(parm.day->answer, "%i", &day);
-	sscanf(parm.hour->answer, "%i", &hour);
-	sscanf(parm.minutes->answer, "%i", &minutes);
-	sscanf(parm.seconds->answer, "%i", &seconds);
-	sscanf(parm.timezone->answer, "%lf", &timezone);
+    if (month == -1)
+	doy = day;
+    else
+	doy = dom2doy2(year, month, day);
+    set_solpos_time(&pd, year, 1, doy, hour, minutes, seconds);
+    set_solpos_longitude(&pd, 0);
+    pd.latitude = 0;
+    S_solpos(&pd);
-    /* NOTES: G_calc_solar_position ()
-       - the atmospheric refraction is calculated for 1013hPa, 15�C
+    if (lst_time) {
+	/* hour angle */
+	 * The hour angle of a point on the Earth's surface is the angle
+	 * through which the earth would turn to bring the meridian of
+	 * the point directly under the sun. This angular displacement
+	 * represents time (1 hour = 15 degrees).
+	 * The hour angle is negative in the morning, zero at 12:00,
+	 * and positive in the afternoon
-       Order of parameters:
-       long, lat, timezone, year, month, day, hour, minutes, seconds
+	ha = 15.0 * (hour + minutes / 60.0 + seconds / 3600.0) - 180.;
+	G_debug(1, "Solar hour angle, degrees: %.2f", ha);
+	ha *= DEG2RAD;
+	ha_cos = cos(ha);
+	roundoff(&ha_cos);
-    if (use_solpos) {
-	G_debug(3, "\nlat:%f  long:%f", north, east);
-	retval =
-	    calc_solar_position(east, north, timezone, year, month, day,
-				hour, minutes, seconds);
+	/* sun declination */
+	 * The declination of the sun is the angle between
+	 * the rays of the sun and the plane of the Earth's equator.
-	/* Remove +0.5 above if you want round-down instead of round-to-nearest */
-	sretr = (int)floor(pdat->sretr);	/* sunrise */
-	dsretr = pdat->sretr;
-	sretr_sec = (int)
-	    floor(((dsretr - floor(dsretr)) * 60 -
-		   floor((dsretr - floor(dsretr)) * 60)) * 60);
-	ssetr = (int)floor(pdat->ssetr);	/* sunset */
-	dssetr = pdat->ssetr;
-	ssetr_sec = (int)
-	    floor(((dssetr - floor(dssetr)) * 60 -
-		   floor((dssetr - floor(dssetr)) * 60)) * 60);
+	s_gamma = (2 * M_PI * (doy - 1)) / 365;
+	G_debug(1, "fractional year in radians: %.2f", s_gamma);
+	/* sun declination for day of year with Fourier series representation
+	 * NOTE: based on 1950, override with solpos */
+	s_declination = (0.006918 - 0.399912 * cos(s_gamma) + 0.070257 * sin(s_gamma) -
+			 0.006758 * cos(2 * s_gamma) + 0.000907 * sin(2 * s_gamma) -
+			 0.002697 * cos(3 * s_gamma) + 0.00148 * sin(3 * s_gamma));
-	/* print the results */
-	if (retval == 0) {	/* error check */
-	    if (flag2->answer || (flag3->answer && !flag2->answer)) {
-		if (flag4->answer) {
-		    fprintf(stdout, "date=%d/%02d/%02d\n", pdat->year,
-			    pdat->month, pdat->day);
-		    fprintf(stdout, "daynum=%d\n", pdat->daynum);
-		    fprintf(stdout, "time=%02i:%02i:%02i\n", pdat->hour,
-			    pdat->minute, pdat->second);
-		    fprintf(stdout, "decimaltime=%f\n",
-			    pdat->hour + (pdat->minute * 100.0 / 60.0 +
-					  pdat->second * 100.0 / 3600.0) /
-			    100.);
-		    fprintf(stdout, "longitudine=%f\n", pdat->longitude);
-		    fprintf(stdout, "latitude=%f\n", pdat->latitude);
-		    fprintf(stdout, "timezone=%f\n", pdat->timezone);
-		    fprintf(stdout, "sunazimuth=%f\n", pdat->azim);
-		    fprintf(stdout, "sunangleabovehorizon=%f\n",
-			    pdat->elevref);
+	G_debug(1, "sun declination: %.5f", s_declination * RAD2DEG);
+	G_debug(1, "sun declination (solpos): %.5f", pd.declin);
-		    if (sretr / 60 <= 24.0) {
-			fprintf(stdout, "sunrise=%02d:%02d:%02d\n",
-				sretr / 60, sretr % 60, sretr_sec);
-			fprintf(stdout, "sunset=%02d:%02d:%02d\n", ssetr / 60,
-				ssetr % 60, ssetr_sec);
-		else {
-		    fprintf(stdout, "%d/%02d/%02d, daynum: %d, time: %02i:%02i:%02i (decimal time: %f)\n",
-			    pdat->year, pdat->month, pdat->day,
-			    pdat->daynum, pdat->hour, pdat->minute,
-			    pdat->second,
-			    100.);
-		    fprintf(stdout, "long: %f, lat: %f, timezone: %f\n",
-			    pdat->longitude, pdat->latitude,
-			    pdat->timezone);
-		    fprintf(stdout, "Solar position: sun azimuth: %f, sun angle above horz. (refraction corrected): %f\n",
-			    pdat->azim, pdat->elevref);
-			fprintf(stdout, "Sunrise time (without refraction): %02d:%02d:%02d\n",
-			fprintf(stdout, "Sunset time  (without refraction): %02d:%02d:%02d\n",
-				ssetr / 60, ssetr % 60, ssetr_sec);
+	if (lst_time) {
+	    north_ll = (window.north + window.south) / 2;
+	    east_ll = (window.east + window.west) / 2;
+	    if (do_reproj) {
+		if (pj_do_proj(&east_ll, &north_ll, &iproj, &oproj) < 0)
+		    G_fatal_error(_("Error in pj_do_proj (projection of input coordinate pair)"));
-	    sunrise = pdat->sretr / 60.;	/* decimal minutes */
-	    sunset = pdat->ssetr / 60.;
-	    current_time =
-		pdat->hour + (pdat->minute / 60.) + (pdat->second / 3600.);
+	    pd.timezone = east_ll / 15.;
+	    pd.time_updated = 1;
+	    set_solpos_longitude(&pd, east_ll);
+	    G_debug(1, "fake timezone: %.2f", pd.timezone);
+	    S_solpos(&pd);
+	    G_debug(1, "Solar hour angle (solpos), degrees: %.2f", pd.hrang);
-	else			/* fatal error in G_calc_solar_position() */
-	    G_fatal_error(_("Please correct settings"));
-    if (use_solpos) {
-	dalti = pdat->elevref;
-	dazi = pdat->azim;
-    }				/* otherwise already defined */
+	/* always use solpos sun declination */
+	s_declination = pd.declin * DEG2RAD;
+	sd_sin = sin(s_declination);
+	roundoff(&sd_sin);
+	sd_cos = cos(s_declination);
+	roundoff(&sd_cos);
+	G_debug(1, "sun declination (solpos): %.5f", s_declination * RAD2DEG);
-    /* check sunrise */
-    if (use_solpos) {
-	G_debug(3, "current_time:%f sunrise:%f", current_time, sunrise);
-	if ((current_time < sunrise)) {
-		G_message(_("Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"),
-			  pdat->hour, pdat->minute, pdat->second, sretr / 60,
-			  sretr % 60, sretr_sec);
-	    else
-		G_message(_("Time (%02i:%02i:%02i) is before sunrise"),
-			  pdat->hour, pdat->minute, pdat->second);
-	    G_warning(_("Nothing to calculate. Please verify settings."));
+	if (0 && lst_time) {
+	    pd.timezone = 0;
+	    pd.time_updated = pd.longitude_updated = 1;
+	    S_solpos(&pd);
-	if ((current_time > sunset)) {
-		G_message(_("Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"),
-			  pdat->hour, pdat->minute, pdat->second, ssetr / 60,
-	    else
-		G_message(_("Time (%02i:%02i:%02i) is after sunset"),
-    if (flag3->answer && (use_solpos == 1)) {	/* we only want the sun position */
-	exit(EXIT_SUCCESS);
+    if (elev_name) {
+	if ((elev_fd = G_open_raster_new(elev_name, FCELL_TYPE)) < 0)
+	    G_fatal_error(_("Unable to create raster map <%s>"), elev_name);
+	elevbuf = G_allocate_f_raster_buf();
-    else if (flag3->answer && (use_solpos == 0)) {
-	/* are you joking ? */
-	G_message(_("You already know the sun position"));
+    else {
+	elevbuf = NULL;
+	elev_fd = -1;
-    if (!outname)
-	G_fatal_error(_("Option <%s> required"), parm.opt2->key);
-    /* Search for output layer in all mapsets ? yes. */
-    mapset = G_find_cell2(name, "");
+    if (azimuth_name) {
+	if ((azimuth_fd = G_open_raster_new(azimuth_name, FCELL_TYPE)) < 0)
+	    G_fatal_error(_("Unable to create raster map <%s>"), azimuth_name);
-    if ((elev_fd = G_open_cell_old(name, mapset)) < 0)
-	G_fatal_error(_("Unable to open raster map <%s>"), name);
-    if ((output_fd = G_open_cell_new(outname)) < 0)
-	G_fatal_error(_("Unable to create raster map <%s>"), outname);
+	azimuthbuf = G_allocate_f_raster_buf();
+    else {
+	azimuthbuf = NULL;
+	azimuth_fd = -1;
-    data_type = G_get_raster_map_type(elev_fd);
-    elevbuf.v = G_allocate_raster_buf(data_type);
-    tmpbuf.v = G_allocate_raster_buf(data_type);
-    outbuf.v = G_allocate_raster_buf(CELL_TYPE);	/* binary map */
+    if (sunhour_name) {
+	if ((sunhour_fd = G_open_raster_new(sunhour_name, FCELL_TYPE)) < 0)
+	    G_fatal_error(_("Unable to create raster map <%s>"), sunhour_name);
-    if (data_type == CELL_TYPE) {
-	if ((G_read_range(name, mapset, &range)) < 0)
-	    G_fatal_error(_("Unable to open range file for raster map <%s>"), name);
-	G_get_range_min_max(&range, &min, &max);
-	dmin = (double)min;
-	dmax = (double)max;
+	sunhourbuf = G_allocate_f_raster_buf();
     else {
-	G_read_fp_range(name, mapset, &fprange);
-	G_get_fp_range_min_max(&fprange, &dmin, &dmax);
+	sunhourbuf = NULL;
+	sunhour_fd = -1;
-    azi = 2 * M_PI * dazi / 360;
-    alti = 2 * M_PI * dalti / 360;
-    nstep = cos(azi) * window.ns_res;
-    estep = sin(azi) * window.ew_res;
-    row1 = 0;
+    if (elev_name && azimuth_name) {
+	G_message(_("Calculating solar elevation and azimuth..."));
+    else if (elev_name) {
+	G_message(_("Calculating solar elevation..."));
+    else if (azimuth_name) {
+	G_message(_("Calculating solar azimuth..."));
-    G_message(_("Calculating shadows from DEM..."));
-    while (row1 < window.rows) {
-	G_percent(row1, window.rows, 2);
-	col1 = 0;
-	drow = -1;
-	if (G_get_raster_row(elev_fd, elevbuf.v, row1, data_type) < 0)
-	    G_fatal_error(_("Unable to read raster map <%s> row %d"),
-			  name, row1);
+    nrows = G_window_rows();
+    ncols = G_window_cols();
-	while (col1 < window.cols) {
-	    dvalue = raster_value(elevbuf, data_type, col1);
-	    /*              outbuf.c[col1]=1; */
-	    G_set_null_value(&outbuf.c[col1], 1, CELL_TYPE);
-	    OK = 1;
-	    east = G_col_to_easting(col1 + 0.5, &window);
-	    north = G_row_to_northing(row1 + 0.5, &window);
-	    east1 = east;
-	    north1 = north;
-	    if (dvalue == 0.0 && !zeros)
-		OK = 0;
-	    while (OK == 1) {
-		east += estep;
-		north += nstep;
-		if (north > window.north || north < window.south
-		    || east > window.east || east < window.west)
-		    OK = 0;
-		else {
-		    maxh = tan(alti) *
-			sqrt((north1 - north) * (north1 - north) +
-			     (east1 - east) * (east1 - east));
-		    if ((maxh) > (dmax - dvalue))
-			OK = 0;
-		    else {
-			dcol = G_easting_to_col(east, &window);
-			if (drow != G_northing_to_row(north, &window)) {
-			    drow = G_northing_to_row(north, &window);
-			    G_get_raster_row(elev_fd, tmpbuf.v, (int)drow,
-					     data_type);
-			dvalue2 = raster_value(tmpbuf, data_type, (int)dcol);
-			if ((dvalue2 - dvalue) > (maxh)) {
-			    OK = 0;
-			    outbuf.c[col1] = 1;
+    ba2 = 6356752.3142 / 6378137.0;
+    ba2 = ba2 * ba2;
+    for (row = 0; row < nrows; row++) {
+	G_percent(row, nrows, 2);
+	/* get cell center northing */
+	north = window.north - (row + 0.5) * window.ns_res;
+	north_ll = north;
+	for (col = 0; col < ncols; col++) {
+	    long int retval;
+	    s_elevation = s_azimuth = -1.;
+	    /* get cell center easting */
+	    east = window.west + (col + 0.5) * window.ew_res;
+	    east_ll = east;
+	    if (do_reproj) {
+		north_ll = north;
+	    /* geocentric latitude */
+	    north_gc = atan(ba2 * tan(DEG2RAD * north_ll));
+	    north_gc_sin = sin(north_gc);
+	    roundoff(&north_gc_sin);
+	    north_gc_cos = cos(north_gc);
+	    roundoff(&north_gc_cos);
+	    if (!lst_time) {
+		pd.latitude = north_gc * RAD2DEG;
+		retval = S_solpos(&pd);
+		S_decode(retval, &pd);
+		G_debug(3, "solpos hour angle: %.5f", pd.hrang);
+	    /* solar elevation angle */
+		if (!lst_time) {
+		    ha = pd.hrang;
+		    ha_cos = cos(ha * DEG2RAD);
+		se_sin = ha_cos * sd_cos * north_gc_cos + sd_sin * north_gc_sin;
+		roundoff(&se_sin);
+		s_elevation = RAD2DEG * asin(se_sin);
-	    G_debug(3, "Analysing col %i", col1);
-	    col1 += 1;
+	    else /* use_solpos && !lst_time */
+		s_elevation = pd.elevetr;
+	    if (elev_name)
+		elevbuf[col] = s_elevation;
+		/* solar azimuth angle */
+		    sa_cos = (se_sin * north_gc_sin - sd_sin) /
+		             (cos(DEG2RAD * s_elevation) * north_gc_cos);
+		    roundoff(&sa_cos);
+		    s_azimuth = RAD2DEG * acos(sa_cos);
+		    /* morning */
+		    s_azimuth = 180. - RAD2DEG * acos(sa_cos);
+		    if (ha > 0)   /* afternoon */
+			s_azimuth = 360.0 - s_azimuth;
+		else
+		    s_azimuth = pd.azim;
+		azimuthbuf[col] = s_azimuth;
+	    if (sunhour_name)
+		sunhourbuf[col] = (pd.ssetr - pd.sretr) / 60.;
-	G_debug(3, "Writing result row %i of %i", row1, window.rows);
-	G_put_raster_row(output_fd, outbuf.c, CELL_TYPE);
-	row1 += 1;
+	if (elev_name)
+	    G_put_f_raster_row(elev_fd, elevbuf);
+	if (azimuth_name)
+	    G_put_f_raster_row(azimuth_fd, azimuthbuf);
+	if (sunhour_name)
+	    G_put_f_raster_row(sunhour_fd, sunhourbuf);
-    G_percent(1, 1, 1);
+    G_percent(1, 1, 2);
-    G_close_cell(output_fd);
-    G_close_cell(elev_fd);
+    if (elev_name) {
+	G_close_cell(elev_fd);
+	/* writing history file */
+	G_short_history(elev_name, "raster", &hist);
+	G_command_history(&hist);
+	G_write_history(elev_name, &hist);
+	G_close_cell(azimuth_fd);
+	G_short_history(azimuth_name, "raster", &hist);
+	G_write_history(azimuth_name, &hist);
+	G_close_cell(sunhour_fd);
+	G_short_history(sunhour_name, "raster", &hist);
+	G_write_history(sunhour_name, &hist);
-    /* writing history file */
-    G_short_history(outname, "raster", &hist);
-    G_snprintf(hist.datsrc_1, RECORD_LEN, "raster elevation map: %s", name);
-    G_command_history(&hist);
-    G_write_history(outname, &hist);
+    G_done_msg(" ");
     exit(EXIT_SUCCESS);
+void set_solpos_time(struct posdata *pdat, int year, int month, int day,
+                    int hour, int minute, int second)
-    double retval;
+    pdat->year = year;
+    pdat->month = month;
+    pdat->day = day;
+    pdat->daynum = day;
+    pdat->hour = hour;
+    pdat->minute = minute;
+    pdat->second = second;
+    pdat->timezone = 0;
-    switch (data_type) {
-    case CELL_TYPE:
-	retval = (double)buf.c[col];
-	break;
-    case FCELL_TYPE:
-	retval = (double)buf.f[col];
-	break;
-    case DCELL_TYPE:
-	retval = (double)buf.d[col];
-	break;
+    pdat->time_updated = 1;
+    pdat->longitude_updated = 1;
+void set_solpos_longitude(struct posdata *pdat, double longitude)
+    pdat->longitude = longitude;
+int roundoff(double *x)
+    /* watch out for the roundoff errors */
+    if (fabs(*x) > 1.0) {
+	if (*x > 0.0)
+	    *x = 1.0;
+	else
+	    *x = -1.0;
+	return 1;
-    return retval;
+    return 0;
-#endif
Modified: grass-addons/grass6/raster/r.sun.angle/solpos00.c
--- grass-addons/grass6/raster/r.sun.angle/solpos00.c	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/solpos00.c	2012-08-24 18:13:55 UTC (rev 52877)
@@ -127,8 +127,6 @@
 		   /* cumulative number of days prior to beginning of month */
-static float degrad = 57.295779513;	/* converts from radians to degrees */
-static float raddeg = 0.0174532925;	/* converts from degrees to radians */
 *    Local function prototypes
@@ -289,6 +287,9 @@
     pdat->sbrad = 31.7;		/* Eppley shadow band radius */
     pdat->sbsky = 0.04;		/* Drummond factor for partly cloudy skies */
     pdat->function = S_ALL;	/* compute all parameters */
+    pdat->time_updated = 0;
+    pdat->longitude_updated = 0;
@@ -392,6 +393,19 @@
+int dom2doy2(int year, int month, int day)
+    int doy = day + month_days[0][month];
+    /* (adjust for leap year) */
+    if (((year % 4) == 0) &&
+	(((year % 100) != 0) || ((year % 400) == 0)) &&
+	(month > 2))
+	doy += 1;
+    return doy;
 *    Local void function doy2dom
@@ -447,147 +461,178 @@
     float top;			/* numerator (top) of the fraction */
     int leap;			/* leap year counter */
-    /* Day angle */
-    /*  Iqbal, M.  1983.  An Introduction to Solar Radiation.
-       Academic Press, NY., page 3 */
-    pdat->dayang = 360.0 * (pdat->daynum - 1) / 365.0;
+    /** time-dependent variables **/
+    if (pdat->time_updated) {
+	/* Day angle */
+	/*  Iqbal, M.  1983.  An Introduction to Solar Radiation.
+	   Academic Press, NY., page 3 */
+	pdat->dayang = 360.0 * (pdat->daynum - 1) / 365.0;
-    /* Earth radius vector * solar constant = solar energy */
-    /*  Spencer, J. W.  1971.  Fourier series representation of the
-       position of the sun.  Search 2 (5), page 172 */
-    sd = sin(raddeg * pdat->dayang);
-    cd = cos(raddeg * pdat->dayang);
-    d2 = 2.0 * pdat->dayang;
-    c2 = cos(raddeg * d2);
-    s2 = sin(raddeg * d2);
+	/* Earth radius vector * solar constant = solar energy */
+	/*  Spencer, J. W.  1971.  Fourier series representation of the
+	   position of the sun.  Search 2 (5), page 172 */
+	sd = sin(DEG2RAD * pdat->dayang);
+	cd = cos(DEG2RAD * pdat->dayang);
+	d2 = 2.0 * pdat->dayang;
+	c2 = cos(DEG2RAD * d2);
+	s2 = sin(DEG2RAD * d2);
-    pdat->erv = 1.000110 + 0.034221 * cd + 0.001280 * sd;
-    pdat->erv += 0.000719 * c2 + 0.000077 * s2;
+	pdat->erv = 1.000110 + 0.034221 * cd + 0.001280 * sd;
+	pdat->erv += 0.000719 * c2 + 0.000077 * s2;
-    /* Universal Coordinated (Greenwich standard) time */
-    /*  Michalsky, J.  1988.  The Astronomical Almanac's algorithm for
-       approximate solar position (1950-2050).  Solar Energy 40 (3),
-       pp. 227-235. */
-    pdat->utime =
-	pdat->hour * 3600.0 +
-	pdat->minute * 60.0 + pdat->second - (float)pdat->interval / 2.0;
-    pdat->utime = pdat->utime / 3600.0 - pdat->timezone;
+	/* Universal Coordinated (Greenwich standard) time */
+	/*  Michalsky, J.  1988.  The Astronomical Almanac's algorithm for
+	   approximate solar position (1950-2050).  Solar Energy 40 (3),
+	   pp. 227-235. */
+	pdat->utime =
+	    pdat->hour * 3600.0 +
+	    pdat->minute * 60.0 + pdat->second - (float)pdat->interval / 2.0;
+	pdat->utime = pdat->utime / 3600.0 - pdat->timezone;
-    /* Julian Day minus 2,400,000 days (to eliminate roundoff errors) */
-       pp. 227-235. */
+	/* Julian Day minus 2,400,000 days (to eliminate roundoff errors) */
+	   pp. 227-235. */
-    /* No adjustment for century non-leap years since this function is
-       bounded by 1950 - 2050 */
-    delta = pdat->year - 1949;
-    leap = (int)(delta / 4.0);
-    pdat->julday =
-	32916.5 + delta * 365.0 + leap + pdat->daynum + pdat->utime / 24.0;
+	/* No adjustment for century non-leap years since this function is
+	   bounded by 1950 - 2050 */
+	delta = pdat->year - 1949;
+	leap = (int)(delta / 4.0);
+	pdat->julday =
+	    32916.5 + delta * 365.0 + leap + pdat->daynum + pdat->utime / 24.0;
-    /* Time used in the calculation of ecliptic coordinates */
-    /* Noon 1 JAN 2000 = 2,400,000 + 51,545 days Julian Date */
-       pp. 227-235. */
-    pdat->ectime = pdat->julday - 51545.0;
+	/* Time used in the calculation of ecliptic coordinates */
+	/* Noon 1 JAN 2000 = 2,400,000 + 51,545 days Julian Date */
+	   pp. 227-235. */
+	pdat->ectime = pdat->julday - 51545.0;
-    /* Mean longitude */
-       pp. 227-235. */
-    pdat->mnlong = 280.460 + 0.9856474 * pdat->ectime;
+	/* Mean longitude */
+	   pp. 227-235. */
+	pdat->mnlong = 280.460 + 0.9856474 * pdat->ectime;
-    /* (dump the multiples of 360, so the answer is between 0 and 360) */
-    pdat->mnlong -= 360.0 * (int)(pdat->mnlong / 360.0);
-    if (pdat->mnlong < 0.0)
-	pdat->mnlong += 360.0;
+	/* (dump the multiples of 360, so the answer is between 0 and 360) */
+	pdat->mnlong -= 360.0 * (int)(pdat->mnlong / 360.0);
+	if (pdat->mnlong < 0.0)
+	    pdat->mnlong += 360.0;
-    /* Mean anomaly */
-       pp. 227-235. */
-    pdat->mnanom = 357.528 + 0.9856003 * pdat->ectime;
+	/* Mean anomaly */
+	   pp. 227-235. */
+	pdat->mnanom = 357.528 + 0.9856003 * pdat->ectime;
-    pdat->mnanom -= 360.0 * (int)(pdat->mnanom / 360.0);
-    if (pdat->mnanom < 0.0)
-	pdat->mnanom += 360.0;
+	pdat->mnanom -= 360.0 * (int)(pdat->mnanom / 360.0);
+	if (pdat->mnanom < 0.0)
+	    pdat->mnanom += 360.0;
-    /* Ecliptic longitude */
-       pp. 227-235. */
-    pdat->eclong = pdat->mnlong + 1.915 * sin(pdat->mnanom * raddeg) +
-	0.020 * sin(2.0 * pdat->mnanom * raddeg);
+	/* Ecliptic longitude */
+	   pp. 227-235. */
+	pdat->eclong = pdat->mnlong + 1.915 * sin(pdat->mnanom * DEG2RAD) +
+	    0.020 * sin(2.0 * pdat->mnanom * DEG2RAD);
-    pdat->eclong -= 360.0 * (int)(pdat->eclong / 360.0);
-    if (pdat->eclong < 0.0)
-	pdat->eclong += 360.0;
+	pdat->eclong -= 360.0 * (int)(pdat->eclong / 360.0);
+	if (pdat->eclong < 0.0)
+	    pdat->eclong += 360.0;
-    /* Obliquity of the ecliptic */
-       pp. 227-235. */
+	/* Obliquity of the ecliptic */
+	   pp. 227-235. */
-    /* 02 Feb 2001 SMW corrected sign in the following line */
-    /*  pdat->ecobli = 23.439 + 4.0e-07 * pdat->ectime;     */
-    pdat->ecobli = 23.439 - 4.0e-07 * pdat->ectime;
+	/* 02 Feb 2001 SMW corrected sign in the following line */
+	/*  pdat->ecobli = 23.439 + 4.0e-07 * pdat->ectime;     */
+	/* more precisely: */
+	/*  pdat->ecobli = 23.43929 - 3.56237e-07 * pdat->ectime;     */
+	pdat->ecobli = 23.439 - 4.0e-07 * pdat->ectime;
+	G_debug(1, "axial tilt (solpos): %.5f", pdat->ecobli);
-    /* Declination */
-       pp. 227-235. */
-    pdat->declin = degrad * asin(sin(pdat->ecobli * raddeg) *
-				 sin(pdat->eclong * raddeg));
+	if (pdat->ectime != 0) {
+	    /* convert ectime from days to years */
+	    double ectime = pdat->ectime / 36525.0;
+	    double ectime2 = ectime * ectime;
+	    double ectime3 = ectime2 * ectime;
-    /* Right ascension */
-       pp. 227-235. */
-    top = cos(raddeg * pdat->ecobli) * sin(raddeg * pdat->eclong);
-    bottom = cos(raddeg * pdat->eclong);
+	    /* recommended by the International Astronomical Union in 2000: */
+	    /* accurate for the year 2000 +- 5000 years
+	     * result is in arc seconds */
+	    pdat->ecobli = 84381.448 - 46.84024 * ectime - 5.9e-5 * ectime2 + 1.813e-3 * ectime3;
+	    /* convert to degrees */
+	    pdat->ecobli /= 3600.0;
-    pdat->rascen = degrad * atan2(top, bottom);
+	    G_debug(1, "axial tilt (IAU 2000): %.5f", pdat->ecobli);
+	else
+	    pdat->ecobli = 23.43929;
-    /* (make it a positive angle) */
-    if (pdat->rascen < 0.0)
-	pdat->rascen += 360.0;
+	/* Declination */
+	   pp. 227-235. */
+	pdat->declin = RAD2DEG * asin(sin(pdat->ecobli * DEG2RAD) *
+				      sin(pdat->eclong * DEG2RAD));
-    /* Greenwich mean sidereal time */
-       pp. 227-235. */
-    pdat->gmst = 6.697375 + 0.0657098242 * pdat->ectime + pdat->utime;
+	/* Right ascension */
+	   pp. 227-235. */
+	top = cos(DEG2RAD * pdat->ecobli) * sin(DEG2RAD * pdat->eclong);
+	bottom = cos(DEG2RAD * pdat->eclong);
-    /* (dump the multiples of 24, so the answer is between 0 and 24) */
-    pdat->gmst -= 24.0 * (int)(pdat->gmst / 24.0);
-    if (pdat->gmst < 0.0)
-	pdat->gmst += 24.0;
+	pdat->rascen = RAD2DEG * atan2(top, bottom);
-    /* Local mean sidereal time */
-       pp. 227-235. */
-    pdat->lmst = pdat->gmst * 15.0 + pdat->longitude;
+	/* (make it a positive angle) */
+	if (pdat->rascen < 0.0)
+	    pdat->rascen += 360.0;
-    pdat->lmst -= 360.0 * (int)(pdat->lmst / 360.0);
-    if (pdat->lmst < 0.)
-	pdat->lmst += 360.0;
+	/* Greenwich mean sidereal time */
+	   pp. 227-235. */
+	pdat->gmst = 6.697375 + 0.0657098242 * pdat->ectime + pdat->utime;
-    /* Hour angle */
-       pp. 227-235. */
-    pdat->hrang = pdat->lmst - pdat->rascen;
+	/* (dump the multiples of 24, so the answer is between 0 and 24) */
+	pdat->gmst -= 24.0 * (int)(pdat->gmst / 24.0);
+	if (pdat->gmst < 0.0)
+	    pdat->gmst += 24.0;
-    /* (force it between -180 and 180 degrees) */
-    if (pdat->hrang < -180.0)
-	pdat->hrang += 360.0;
-    else if (pdat->hrang > 180.0)
-	pdat->hrang -= 360.0;
+    /** longitude-dependent variables **/
+    if (pdat->longitude_updated) {
+	/* Local mean sidereal time */
+	   pp. 227-235. */
+	pdat->lmst = pdat->gmst * 15.0 + pdat->longitude;
+	pdat->lmst -= 360.0 * (int)(pdat->lmst / 360.0);
+	if (pdat->lmst < 0.)
+	    pdat->lmst += 360.0;
+	/* Hour angle */
+	   pp. 227-235. */
+	pdat->hrang = pdat->lmst - pdat->rascen;
+	/* (force it between -180 and 180 degrees) */
+	if (pdat->hrang < -180.0)
+	    pdat->hrang += 360.0;
+	else if (pdat->hrang > 180.0)
+	    pdat->hrang -= 360.0;
@@ -613,7 +658,7 @@
 	    cz = -1.0;
-    pdat->zenetr = acos(cz) * degrad;
+    pdat->zenetr = acos(cz) * RAD2DEG;
     /* (limit the degrees below the horizon to 9 [+90 -> 99]) */
     if (pdat->zenetr > 99.0)
@@ -647,7 +692,7 @@
 	else if (cssha > 1.0)
 	    pdat->ssha = 0.0;
 	else
-	    pdat->ssha = degrad * acos(cssha);
+	    pdat->ssha = RAD2DEG * acos(cssha);
     else if (((pdat->declin >= 0.0) && (pdat->latitude > 0.0)) ||
 	     ((pdat->declin < 0.0) && (pdat->latitude < 0.0)))
@@ -670,8 +715,8 @@
     localtrig(pdat, tdat);
     p = 0.6366198 * pdat->sbwid / pdat->sbrad * pow(tdat->cd, 3);
-    t1 = tdat->sl * tdat->sd * pdat->ssha * raddeg;
-    t2 = tdat->cl * tdat->cd * sin(pdat->ssha * raddeg);
+    t1 = tdat->sl * tdat->sd * pdat->ssha * DEG2RAD;
+    t2 = tdat->cl * tdat->cd * sin(pdat->ssha * DEG2RAD);
     pdat->sbcf = pdat->sbsky + 1.0 / (1.0 - p * (t1 + t2));
@@ -739,8 +784,8 @@
     float se;			/* sine of the solar elevation */
-    ce = cos(raddeg * pdat->elevetr);
-    se = sin(raddeg * pdat->elevetr);
+    ce = cos(DEG2RAD * pdat->elevetr);
+    se = sin(DEG2RAD * pdat->elevetr);
     pdat->azim = 180.0;
     cecl = ce * tdat->cl;
@@ -751,7 +796,7 @@
 	else if (ca < -1.0)
 	    ca = -1.0;
-	pdat->azim = 180.0 - acos(ca) * degrad;
+	pdat->azim = 180.0 - acos(ca) * RAD2DEG;
 	if (pdat->hrang > 0)
 	    pdat->azim = 360.0 - pdat->azim;
@@ -779,7 +824,7 @@
     /* Otherwise, we have refraction */
     else {
-	tanelev = tan(raddeg * pdat->elevetr);
+	tanelev = tan(DEG2RAD * pdat->elevetr);
 	if (pdat->elevetr >= 5.0)
 	    refcor = 58.1 / tanelev -
 		0.07 / (pow(tanelev, 3)) + 0.000086 / (pow(tanelev, 5));
@@ -806,7 +851,7 @@
     /* Refracted solar zenith angle */
     pdat->zenref = 90.0 - pdat->elevref;
-    pdat->coszen = cos(raddeg * pdat->zenref);
+    pdat->coszen = cos(DEG2RAD * pdat->zenref);
@@ -826,7 +871,7 @@
     else {
 	pdat->amass =
-	    1.0 / (cos(raddeg * pdat->zenref) + 0.50572 *
+	    1.0 / (cos(DEG2RAD * pdat->zenref) + 0.50572 *
 		   pow((96.07995 - pdat->zenref), -1.6364));
 	pdat->ampress = pdat->amass * pdat->press / 1013.0;
@@ -886,15 +931,15 @@
     if (tdat->sd < -900.0) {	/* sd was initialized -999 as flag */
 	tdat->sd = 1.0;		/* reflag as having completed calculations */
 	if (pdat->function | CD_MASK)
-	    tdat->cd = cos(raddeg * pdat->declin);
+	    tdat->cd = cos(DEG2RAD * pdat->declin);
 	if (pdat->function | CH_MASK)
-	    tdat->ch = cos(raddeg * pdat->hrang);
+	    tdat->ch = cos(DEG2RAD * pdat->hrang);
 	if (pdat->function | CL_MASK)
-	    tdat->cl = cos(raddeg * pdat->latitude);
+	    tdat->cl = cos(DEG2RAD * pdat->latitude);
 	if (pdat->function | SD_MASK)
-	    tdat->sd = sin(raddeg * pdat->declin);
+	    tdat->sd = sin(DEG2RAD * pdat->declin);
 	if (pdat->function | SL_MASK)
-	    tdat->sl = sin(raddeg * pdat->latitude);
+	    tdat->sl = sin(DEG2RAD * pdat->latitude);
@@ -917,13 +962,13 @@
     /* Cosine of the angle between the sun and a tipped flat surface,
        useful for calculating solar energy on tilted surfaces */
-    ca = cos(raddeg * pdat->azim);
-    cp = cos(raddeg * pdat->aspect);
-    ct = cos(raddeg * pdat->tilt);
-    sa = sin(raddeg * pdat->azim);
-    sp = sin(raddeg * pdat->aspect);
-    st = sin(raddeg * pdat->tilt);
-    sz = sin(raddeg * pdat->zenref);
+    ca = cos(DEG2RAD * pdat->azim);
+    cp = cos(DEG2RAD * pdat->aspect);
+    ct = cos(DEG2RAD * pdat->tilt);
+    sa = sin(DEG2RAD * pdat->azim);
+    sp = sin(DEG2RAD * pdat->aspect);
+    st = sin(DEG2RAD * pdat->tilt);
+    sz = sin(DEG2RAD * pdat->zenref);
     pdat->cosinc = pdat->coszen * ct + sz * st * (ca * cp + sa * sp);
     if (pdat->cosinc > 0.0)
Modified: grass-addons/grass6/raster/r.sun.angle/solpos00.h
--- grass-addons/grass6/raster/r.sun.angle/solpos00.h	2012-08-24 17:55:38 UTC (rev 52876)
+++ grass-addons/grass6/raster/r.sun.angle/solpos00.h	2012-08-24 18:13:55 UTC (rev 52877)
@@ -1,4 +1,9 @@
+#define RAD2DEG 57.295779513	/* converts from radians to degrees */
+#define DEG2RAD 0.0174532925	/* converts from degrees to radians */
+int dom2doy2(int year, int month, int day);
 *    NAME:  solpos.h
@@ -178,6 +183,9 @@
     int year;			/* I:              4-digit year (2-digit year is NOT
 				   allowed */
+    int time_updated;           /* recalculate time-dependent variables */
+    int longitude_updated;      /* recalculate longitude-dependent variables */
   /***** FLOATS *****/
     float amass;		/* O:  S_AMASS    Relative optical airmass */
