[GRASS-SVN] r52892 - grass/trunk/vector/v.what
svn_grass at osgeo.org
Sat Aug 25 05:34:31 PDT 2012
Author: mmetz
Date: 2012-08-25 05:34:31 -0700 (Sat, 25 Aug 2012)
New Revision: 52892
grass/trunk/vector/v.what/what.c
v.what: fix segfault when querying multiple maps
Modified: grass/trunk/vector/v.what/what.c
--- grass/trunk/vector/v.what/what.c 2012-08-25 12:07:04 UTC (rev 52891)
+++ grass/trunk/vector/v.what/what.c 2012-08-25 12:34:31 UTC (rev 52892)
@@ -107,11 +107,11 @@
int type;
char east_buf[40], north_buf[40];
double sq_meters, sqm_to_sqft, acres, hectares, sq_miles;
- double z = 0, l = 0;
+ double z, l;
int notty = 0;
- int getz = 0;
+ int getz;
struct field_info *Fi;
- plus_t line, area = 0, centroid;
+ plus_t line, area, centroid;
int i;
struct line_pnts *Points;
struct line_cats *Cats;
@@ -130,22 +130,32 @@
for (i = 0; i < nvects; i++) {
+ /* init variables */
+ area = 0;
+ getz = 0;
+ z = 0;
+ l = 0;
+ line = 0;
Vect_reset_cats(Cats);
+ Vect_reset_line(Points);
/* Try to find point first and only if no one was found try lines,
* otherwise point on line could not be selected and similarly for areas */
- type = ((GV_POINT | GV_CENTROID) & qtype);
- line =
- Vect_find_line(&Map[i], east, north, 0.0, GV_POINT | GV_CENTROID,
- maxdist, 0, 0);
- if (line == 0) {
- type = ((GV_LINE | GV_BOUNDARY | GV_FACE) & qtype);
+ type = (GV_POINTS & qtype);
+ if (type) {
+ line =
+ Vect_find_line(&Map[i], east, north, 0.0, type,
+ maxdist, 0, 0);
+ type = ((GV_LINE | GV_BOUNDARY | GV_FACE) & qtype);
+ if (line == 0 && type) {
line = Vect_find_line(&Map[i], east, north, 0.0,
type, maxdist, 0, 0);
- if (line == 0) {
+ if (line == 0 && (qtype & GV_AREA)) {
area = Vect_find_area(&Map[i], east, north);
getz = Vect_tin_get_z(&Map[i], east, north, &z, NULL, NULL);
@@ -191,7 +201,7 @@
nlines++;
if (line + area == 0) {
- if (line + area > 0 || G_verbose() >= G_verbose_std()) {
+ if (G_verbose() >= G_verbose_std()) {
fprintf(stdout, _("Nothing Found.\n"));
if (notty)
fprintf(stderr, _("Nothing Found.\n"));
