[GRASS-SVN] r52913 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Sat Aug 25 11:41:56 PDT 2012
Author: annakrat
Date: 2012-08-25 11:41:56 -0700 (Sat, 25 Aug 2012)
New Revision: 52913
grass/trunk/gui/wxpython/lmgr/layertree.py
wxGUI/lmgr: fix layer selection/checking (related ticket #1616)
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2012-08-25 15:47:47 UTC (rev 52912)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2012-08-25 18:41:56 UTC (rev 52913)
@@ -123,6 +123,7 @@
self.flag = '' # flag for drag and drop hittest
self.rerender = False # layer change requires a rerendering if auto render
self.reorder = False # layer change requires a reordering
+ self.hitCheckbox = False # if cursor points at layer checkbox (to cancel selection changes)
try:
ctstyle |= CT.TR_ALIGN_WINDOWS
@@ -225,6 +226,7 @@
self.Bind(wx.EVT_TREE_ITEM_COLLAPSED, self.OnCollapseNode)
self.Bind(wx.EVT_TREE_ITEM_ACTIVATED, self.OnActivateLayer)
self.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnChangeSel)
+ self.Bind(wx.EVT_TREE_SEL_CHANGING, self.OnChangingSel)
self.Bind(CT.EVT_TREE_ITEM_CHECKED, self.OnLayerChecked)
self.Bind(wx.EVT_TREE_DELETE_ITEM, self.OnDeleteLayer)
self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnLayerContextMenu)
@@ -232,6 +234,7 @@
self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnRenamed)
self.Bind(wx.EVT_KEY_UP, self.OnKeyUp)
self.Bind(wx.EVT_IDLE, self.OnIdle)
+ self.Bind(wx.EVT_MOTION, self.OnMotion)
def _setGradient(self, iType = None):
"""!Set gradient for items
@@ -1148,8 +1151,6 @@
# ignore when map layer is edited
self.Map.ChangeLayerActive(mapLayer, checked)
- self.SelectItem(item, False)
# update progress bar range (mapwindow statusbar)
self.mapdisplay.GetProgressBar().SetRange(len(self.Map.GetListOfLayers(l_active = True)))
@@ -1205,14 +1206,28 @@
event.Skip()
+ def OnMotion(self, event):
+ """!Mouse is moving.
+ Detects if mouse points at checkbox.
+ thisItem, flags = self.HitTest(event.GetPosition())
+ if flags & CT.TREE_HITTEST_ONITEMCHECKICON:
+ self.hitCheckbox = True
+ else:
+ def OnChangingSel(self, event):
+ """!Selection is changing.
+ If the user is clicking on checkbox, selection change is vetoed.
+ if self.hitCheckbox:
+ event.Veto()
def OnChangeSel(self, event):
"""!Selection changed"""
- oldlayer = event.GetOldItem()
layer = event.GetItem()
- if layer == oldlayer:
- event.Veto()
- return
digitToolbar = self.mapdisplay.GetToolbar('vdigit')
if digitToolbar:
mapLayer = self.GetPyData(layer)[0]['maplayer']
