[GRASS-SVN] r52955 - grass/branches/releasebranch_6_4/vector/v.reclass
svn_grass at osgeo.org
Tue Aug 28 08:50:23 PDT 2012
Author: mmetz
Date: 2012-08-28 08:50:22 -0700 (Tue, 28 Aug 2012)
New Revision: 52955
grass/branches/releasebranch_6_4/vector/v.reclass/main.c
v.reclass: fix #548
Modified: grass/branches/releasebranch_6_4/vector/v.reclass/main.c
--- grass/branches/releasebranch_6_4/vector/v.reclass/main.c 2012-08-28 12:55:34 UTC (rev 52954)
+++ grass/branches/releasebranch_6_4/vector/v.reclass/main.c 2012-08-28 15:50:22 UTC (rev 52955)
@@ -7,7 +7,7 @@
* Glynn Clements <glynn gclements.plus.com>,
* Jachym Cepicky <jachym les-ejk.cz>, Markus Neteler <neteler itc.it>
* PURPOSE:
- * COPYRIGHT: (C) 1999-2007 by the GRASS Development Team
+ * COPYRIGHT: (C) 1999-2009 by the GRASS Development Team
* This program is free software under the GNU General Public
* License (>=v2). Read the file COPYING that comes with GRASS
@@ -144,7 +144,7 @@
G_debug(3, "nrec = %d", nrec);
else if (ctype == DB_C_TYPE_STRING) {
- int i, more, nrows, newval, len;
+ int i, more, nrows, ncols, newval, len;
dbString stmt, stmt2;
dbString lastval;
dbCursor cursor;
@@ -167,7 +167,44 @@
database,
&Out));
+ /* get string column length */
+ db_set_string(&stmt, Fi->table);
+ if (db_describe_table(Driver, &stmt, &table) != DB_OK) {
+ G_fatal_error(_("Unable to describe table <%s>"), Fi->table);
+ column = NULL;
+ ncols = db_get_table_number_of_columns(table);
+ G_debug(3, "ncol = %d", ncols);
+ len = 0;
+ for (i = 0; i < ncols; i++) {
+ column = db_get_table_column(table, i);
+ if (G_strcasecmp(db_get_column_name(column), col_opt->answer) == 0) {
+ /* String column length */
+ len = db_get_column_length(column);
+ break;
+ db_free_table(table);
+ /* Create table */
+ sprintf(buf, "create table %s (cat integer, %s varchar(%d))",
+ NewFi->table, col_opt->answer, len);
+ db_set_string(&stmt2, buf);
+ if (db_execute_immediate(Driver2, &stmt2) != DB_OK) {
+ Vect_close(&Out);
+ db_close_database_shutdown_driver(Driver);
+ db_close_database_shutdown_driver(Driver2);
+ G_fatal_error("Unable to create table: '%s'",
+ db_get_string(&stmt2));
+ db_begin_transaction(Driver2);
+ /* select values */
sprintf(buf, "SELECT %s, %s FROM %s ORDER BY %s", Fi->key,
col_opt->answer, Fi->table, col_opt->answer);
db_set_string(&stmt, buf);
@@ -182,7 +219,7 @@
nrows = db_get_num_rows(&cursor);
G_debug(3, " %d rows selected", nrows);
- if (nrows < 0)
+ if (nrows <= 0)
G_fatal_error(_("No records selected from table <%s>"),
Fi->table);
@@ -201,34 +238,6 @@
cvarr.ctype = DB_C_TYPE_INT;
- /* String column length */
- column = db_get_table_column(table, 1);
- len = db_get_column_length(column);
- /* Create table */
- sprintf(buf, "create table %s (cat integer, %s varchar(%d))",
- NewFi->table, col_opt->answer, len);
- db_set_string(&stmt2, buf);
- if (db_execute_immediate(Driver2, &stmt2) != DB_OK) {
- Vect_close(&Out);
- db_close_database_shutdown_driver(Driver);
- db_close_database_shutdown_driver(Driver2);
- G_fatal_error("Unable to create table: '%s'",
- db_get_string(&stmt2));
- if (db_create_index2(Driver2, NewFi->table, NewFi->key) != DB_OK)
- G_warning(_("Unable to create index for table <%s>, key <%s>"),
- NewFi->table, NewFi->key);
- if (db_grant_on_table(Driver2, NewFi->table, DB_PRIV_SELECT,
- DB_GROUP | DB_PUBLIC) != DB_OK) {
- G_fatal_error(_("Unable to grant privileges on table <%s>"),
- NewFi->table);
newval = 0;
/* fetch the data */
@@ -277,12 +286,23 @@
cvarr.n_values = nrows;
db_close_cursor(&cursor);
db_free_string(&stmt);
db_free_string(&lastval);
+ db_commit_transaction(Driver2);
+ if (db_create_index2(Driver2, NewFi->table, NewFi->key) != DB_OK)
+ G_warning(_("Unable to create index for table <%s>, key <%s>"),
+ NewFi->table, NewFi->key);
+ if (db_grant_on_table(Driver2, NewFi->table, DB_PRIV_SELECT,
+ DB_GROUP | DB_PUBLIC) != DB_OK) {
+ G_fatal_error(_("Unable to grant privileges on table <%s>"),
+ NewFi->table);
qsort((void *)cvarr.value, nrows, sizeof(dbCatVal), cmpcat);
else {
