[GRASS-SVN] r52969 - in grass/trunk: display/d.fontlist general/g.findetc imagery/i.eb.evapfr imagery/i.eb.h_SEBAL01 imagery/i.eb.soilheatflux imagery/i.evapo.time imagery/i.rectify imagery/i.sunhours
svn_grass at osgeo.org
Wed Aug 29 01:19:45 PDT 2012
Author: neteler
Date: 2012-08-29 01:19:44 -0700 (Wed, 29 Aug 2012)
New Revision: 52969
grass/trunk/display/d.fontlist/d.fontlist.html
grass/trunk/general/g.findetc/g.findetc.html
grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html
grass/trunk/imagery/i.eb.h_SEBAL01/i.eb.h_sebal01.html
grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
grass/trunk/imagery/i.evapo.time/i.evapo.time.html
grass/trunk/imagery/i.rectify/i.rectify.html
grass/trunk/imagery/i.sunhours/i.sunhours.html
fix broken links; HTML cosmetics
Modified: grass/trunk/display/d.fontlist/d.fontlist.html
--- grass/trunk/display/d.fontlist/d.fontlist.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/display/d.fontlist/d.fontlist.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -5,8 +5,7 @@
<h2>SEE ALSO</h2>
-<em><a href="d.text.html">d.text</a></em><br>
-<em><a href="parser.html">parser</a></em>
+<em><a href="d.text.html">d.text</a></em>
<h2>AUTHOR</h2>
Modified: grass/trunk/general/g.findetc/g.findetc.html
--- grass/trunk/general/g.findetc/g.findetc.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/general/g.findetc/g.findetc.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -12,12 +12,13 @@
<h2>SEE ALSO</h2>
-<em><a href="g.ask.html">g.ask</a></em><br>
-<em><a href="g.filename.html">g.filename</a></em><br>
-<em><a href="g.findfile.html">g.findfile</a></em><br>
-<em><a href="g.gisenv.html">g.gisenv</a></em><br>
-<em><a href="g.mapsets.html">g.mapsets</a></em><br>
+<em>
+<a href="g.ask.html">g.ask</a>,
+<a href="g.filename.html">g.filename</a>,
+<a href="g.findfile.html">g.findfile</a>,
+<a href="g.gisenv.html">g.gisenv</a>,
+<a href="g.mapsets.html">g.mapsets</a>
+</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html
--- grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/imagery/i.eb.evapfr/i.eb.evapfr.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -3,16 +3,16 @@
<em>i.eb.evapfr</em> calculates the evaporative fraction after [1]. Main
implementation in [3].
It takes input of Net Radiation (see r.sun, i.eb.netrad (grass-addons)), soil
-heat flux (see i.eb.g0) and sensible heat flux (see i.eb.h_SEBAL01).
+heat flux (see i.eb.g0) and sensible heat flux (see i.eb.h_sebal01).
A flag adds a root zone empirical soil moisture output from the article of
Makin, Molden and Bastiaanssen (2001).
<h2>SEE ALSO</h2>
<em>
-<a href="r.sun.html">r.sun</a><br>
-<a href="i.eb.soilheatflux.html">i.eb.soilheatflux</a><br>
-<a href="i.eb.h_SEBAL01.html">i.eb.h_SEBAL01</a><br>
+<a href="r.sun.html">r.sun</a>,
+<a href="i.eb.soilheatflux.html">i.eb.soilheatflux</a>,
+<a href="i.eb.h_sebal01.html">i.eb.h_sebal01</a>
</em>
<h2>REFERENCES</h2>
@@ -29,7 +29,7 @@
Zalidis G.C. Integrated methodology for estimating water use in Mediterranean
agricultural areas. Remote Sensing. -(-):,2009. (submitted))
-<h2>AUTHORS</h2>
+<h2>AUTHOR</h2>
Yann Chemin, Asian Institute of Technology, Thailand
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/i.eb.h_sebal01.html
--- grass/trunk/imagery/i.eb.h_SEBAL01/i.eb.h_sebal01.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/i.eb.h_sebal01.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -1,6 +1,6 @@
<h2>DESCRIPTION</h2>
-<p><em>i.eb.h_sebal01</em> will calculate the sensible heat flux map (h0), given
+<em>i.eb.h_sebal01</em> will calculate the sensible heat flux map (h0), given
both maps of Net Radiation and soil Heat flux (Rn, g0) at instantaneous time,
the surface roughness (z0m), a map of the altitude corrected temperature
(t0dem), a point data of the frictional velocity (u*), a value of actual vapour
@@ -16,7 +16,8 @@
(for time integration: i.evapo.time_integration)
-<p><em>i.eb.h_sebal01</em> performs the computation of <i>sensible heat flux</i>
+<p>
+<em>i.eb.h_sebal01</em> performs the computation of <i>sensible heat flux</i>
[W/m2] after Bastiaanssen, 1995 in [1], used in this form in 2001 by [2]. Implemented
in this code in [3].
@@ -32,11 +33,11 @@
<h2>SEE ALSO</h2>
-<ul>
- <li><a href=i.eb.soilheatflux.html>i.eb.soilheatflux</a>,
- <a href=i.eb.h_SEBAL01.html>i.eb.h_SEBAL01</a>,
- <a href=i.eb.evapfr.html>i.eb.evapfr</a></li>
-</ul>
+<em>
+<a href=i.eb.soilheatflux.html>i.eb.soilheatflux</a>,
+<a href=i.eb.h_sebal01.html>i.eb.h_sebal01</a>,
+<a href=i.eb.evapfr.html>i.eb.evapfr</a>
+</em>
<h2>REFERENCES</h2>
@@ -59,7 +60,7 @@
Yann Chemin, International Rice Research Institute, Los Banos, The
Philippines.
-<p>Contact: <a href="mailto:yann.chemin at gmail.com"> Yann chemin</a>
+<p>Contact: <a href="mailto:yann.chemin at gmail.com">Yann Chemin</a>
<p><i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
--- grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -9,11 +9,11 @@
<h2>SEE ALSO</h2>
<em>
-<a href="i.albedo.html">i.albedo</a><br>
-<a href="i.emissivity.html">i.emissivity</a><br>
-<a href="i.eb.evapfr.html">i.eb.evapfr</a><br>
+<a href="i.albedo.html">i.albedo</a>,
+<a href="i.emissivity.html">i.emissivity</a>,
+<a href="i.eb.h_sebal01.html">i.eb.h_sebal01</a>,
+<a href="i.eb.evapfr.html">i.eb.evapfr</a>
</em>
<h2>REFERENCES</h2>
@@ -30,7 +30,7 @@
-<h2>AUTHORS</h2>
+<h2>AUTHOR</h2>
Yann Chemin, Asian Institute of Technology, Thailand<br>
Modified: grass/trunk/imagery/i.evapo.time/i.evapo.time.html
--- grass/trunk/imagery/i.evapo.time/i.evapo.time.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/imagery/i.evapo.time/i.evapo.time.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -54,7 +54,7 @@
<em>
<a href="i.eb.eta.html">i.eb.eta</a>,
<a href="i.evapo.potrad.html">i.evapo.potrad</a>,
-<a href="i.evapo.SENAY.html">i.evapo.SENAY</a>,
+<a href="i.evapo.senay.html">i.evapo.senay</a>,
<a href="r.surf.idw.html">r.surf.idw</a>,
<a href="r.surf.idw2.html">r.surf.idw2</a>,
<a href="r.bilinear.html">r.bilinear</a>
Modified: grass/trunk/imagery/i.rectify/i.rectify.html
--- grass/trunk/imagery/i.rectify/i.rectify.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/imagery/i.rectify/i.rectify.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -1,10 +1,8 @@
<em>i.rectify</em> uses the control
-points identified in
-<em><a href="i.points.html">i.points</a></em>
-or
-<em><a href="i.vpoints.html">i.vpoints</a></em>
+points identified in the
+<a href="wxGUI.GCP_Manager.html">Ground Control Points Manager</a>
to calculate a transformation matrix based on a first,
second, or third order polynomial and then converts x,y
@@ -14,10 +12,7 @@
system than before it was rectified).
<p>
-or
+The <a href="wxGUI.GCP_Manager.html">Ground Control Points Manager</a>
must be run before <em>i.rectify</em>, and both programs
are required to rectify an image. An image must be
rectified before it can reside in a standard coordinate
@@ -156,11 +151,9 @@
<a href="r.proj.html">r.proj</a>,
<a href="v.proj.html">v.proj</a>,
<a href="i.group.html">i.group</a>,
- <a href="i.points.html">i.points</a>,
- <a href="i.vpoints.html">i.vpoints</a>,
<a href="i.target.html">i.target</a>
<br>
- <a href="wxGUI.GCP_Manager.html">Manage Ground Control Points</a>
+ <a href="wxGUI.GCP_Manager.html">Ground Control Points Manager</a>
</em>
Modified: grass/trunk/imagery/i.sunhours/i.sunhours.html
--- grass/trunk/imagery/i.sunhours/i.sunhours.html 2012-08-29 07:59:33 UTC (rev 52968)
+++ grass/trunk/imagery/i.sunhours/i.sunhours.html 2012-08-29 08:19:44 UTC (rev 52969)
@@ -24,7 +24,7 @@
<em>
<a href="i.evapo.TSA.html">i.evapo.TSA</a>,
-<a href="i.latitude.html">i.latitude</a>
+<a href="i.latlong.html">i.latlong</a>
</em>
