[GRASS-SVN] r52972 - in grass/trunk: display/d.colors display/d.his display/d.profile display/d.rast display/d.rast.arrow display/d.rast.num display/d.rgb display/d.vect misc/m.nviz.image misc/m.nviz.script raster/r.neighbors raster/r.profile raster3d/r3.cross.rast raster3d/r3.to.rast scripts/d.correlate scripts/d.rast.edit scripts/i.spectral scripts/r.in.aster scripts/v.krige scripts/v.rast.stats scripts/wxpyimgview vector/v.neighbors visualization/wximgview visualization/ximgview
Wed Aug 29 04:58:21 PDT 2012
Author: neteler
Date: 2012-08-29 04:58:20 -0700 (Wed, 29 Aug 2012)
New Revision: 52972
   grass/trunk/display/d.colors/main.c
   grass/trunk/display/d.his/main.c
   grass/trunk/display/d.profile/d.profile.html
   grass/trunk/display/d.profile/main.c
   grass/trunk/display/d.rast.arrow/main.c
   grass/trunk/display/d.rast.num/main.c
   grass/trunk/display/d.rast/main.c
   grass/trunk/display/d.rgb/main.c
   grass/trunk/display/d.vect/main.c
   grass/trunk/misc/m.nviz.image/main.c
   grass/trunk/misc/m.nviz.script/main.c
   grass/trunk/raster/r.neighbors/main.c
   grass/trunk/raster/r.profile/r.profile.html
   grass/trunk/raster3d/r3.cross.rast/main.c
   grass/trunk/raster3d/r3.to.rast/main.c
   grass/trunk/scripts/d.correlate/d.correlate.py
   grass/trunk/scripts/d.rast.edit/d.rast.edit.py
   grass/trunk/scripts/i.spectral/i.spectral.py
   grass/trunk/scripts/r.in.aster/r.in.aster.py
   grass/trunk/scripts/v.krige/v.krige.py
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
   grass/trunk/scripts/wxpyimgview/wxpyimgview.py
   grass/trunk/vector/v.neighbors/main.c
   grass/trunk/visualization/wximgview/main.cpp
   grass/trunk/visualization/ximgview/main.c
homogenize keywords
Modified: grass/trunk/display/d.colors/main.c
--- grass/trunk/display/d.colors/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.colors/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -38,6 +38,7 @@
     module = G_define_module();
     G_add_keyword(_("display"));
+    G_add_keyword(_("color table"));
     G_add_keyword(_("raster"));
     module->description =
 	"Allows the user to interactively change the color table "
Modified: grass/trunk/display/d.his/main.c
--- grass/trunk/display/d.his/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.his/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -60,6 +60,7 @@
+    G_add_keyword(_("graphics"));
     G_add_keyword(_("color transformation"));
     G_add_keyword(_("RGB"));
     G_add_keyword(_("HIS"));
Modified: grass/trunk/display/d.profile/d.profile.html
--- grass/trunk/display/d.profile/d.profile.html	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.profile/d.profile.html	2012-08-29 11:58:20 UTC (rev 52972)
@@ -6,6 +6,13 @@
 None known.
+<em>
+<a href="d.where.html">d.where</a>,
+<a href="r.profile.html">r.profile</a>,
+<a href="r.transect.html">r.transect</a>,
+<a href="gm_profile.html">gis.m: PROFILE TOOL</a>  <!-- TODO update to wx tool -->
+</em>
 <h2>AUTHOR</h2>
 Glynn Clements
Modified: grass/trunk/display/d.profile/main.c
--- grass/trunk/display/d.profile/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.profile/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -189,8 +189,8 @@
     /* Set description */
+    G_add_keyword(_("profile"));
-    G_add_keyword(_("profile"));
     module->description = _("Plots profile of a transect.");
     /* set up command line */
Modified: grass/trunk/display/d.rast/main.c
--- grass/trunk/display/d.rast/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.rast/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -51,6 +51,7 @@
     module->description = _("Displays user-specified raster map in the active "
 			    "graphics frame.");
Modified: grass/trunk/display/d.rast.arrow/main.c
--- grass/trunk/display/d.rast.arrow/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.rast.arrow/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -93,6 +93,7 @@
+    G_add_keyword(_("map annotations"));
 	_("Draws arrows representing cell aspect direction "
Modified: grass/trunk/display/d.rast.num/main.c
--- grass/trunk/display/d.rast.num/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.rast.num/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -73,6 +73,7 @@
 	_("Overlays cell category values on a raster map "
Modified: grass/trunk/display/d.rgb/main.c
--- grass/trunk/display/d.rgb/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.rgb/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -51,6 +51,7 @@
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/display/d.vect/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -69,6 +69,7 @@
     G_add_keyword(_("vector"));
     module->description = _("Displays user-specified vector map "
 			    "in the active graphics frame.");
Modified: grass/trunk/misc/m.nviz.image/main.c
--- grass/trunk/misc/m.nviz.image/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/misc/m.nviz.image/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -48,6 +48,7 @@
     G_add_keyword(_("visualization"));
     G_add_keyword(_("raster3d"));
Modified: grass/trunk/misc/m.nviz.script/main.c
--- grass/trunk/misc/m.nviz.script/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/misc/m.nviz.script/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -67,6 +67,7 @@
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/raster/r.neighbors/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -117,6 +117,7 @@
     G_add_keyword(_("algebra"));
     G_add_keyword(_("statistics"));
+    G_add_keyword(_("aggregation"));
 	_("Makes each cell category value a "
 	  "function of the category values assigned to the cells "
Modified: grass/trunk/raster/r.profile/r.profile.html
--- grass/trunk/raster/r.profile/r.profile.html	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/raster/r.profile/r.profile.html	2012-08-29 11:58:20 UTC (rev 52972)
@@ -123,12 +123,14 @@
 <h2>SEE ALSO</h2>
-<em><a href="v.in.ascii.html">v.in.ascii</a></em>,
-<em><a href="d.where.html">d.where</a></em>,
-<em><a href="d.profile.html">d.profile</a></em>,
-<em><a href="r.what.html">r.what</a></em>,
-<em><a href="r.transect.html">r.transect</a></em>,
-<em><a href="gm_profile.html">gis.m: PROFILE TOOL</a></em>
+<em>
+<a href="v.in.ascii.html">v.in.ascii</a>,
+<a href="d.profile.html">d.profile</a>,
+<a href="r.what.html">r.what</a>,
+</em>
 <h2>AUTHOR</h2>
 <a href="mailto:bcovill at tekmap.ns.ca">Bob Covill</a>
Modified: grass/trunk/raster3d/r3.cross.rast/main.c
--- grass/trunk/raster3d/r3.cross.rast/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/raster3d/r3.cross.rast/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -226,6 +226,7 @@
     G_add_keyword(_("voxel"));
Modified: grass/trunk/raster3d/r3.to.rast/main.c
--- grass/trunk/raster3d/r3.to.rast/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/raster3d/r3.to.rast/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -204,6 +204,7 @@
+    G_add_keyword(_("conversion"));
     module->description = _("Converts 3D raster maps to 2D raster maps");
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/scripts/d.correlate/d.correlate.py	2012-08-29 11:58:20 UTC (rev 52972)
@@ -18,6 +18,7 @@
 #%module
 #% description: Prints a graph of the correlation between raster maps (in pairs).
 #% keywords: display
+#% keywords: statistics
 #% keywords: raster
 #% keywords: diagram
 #% keywords: correlation
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2012-08-29 11:58:20 UTC (rev 52972)
@@ -21,8 +21,8 @@
 #%module
 #% description: Edits cell values in a raster map.
+#% keywords: editing
 #% keywords: raster
-#% keywords: edit
 #%end
 #%option G_OPT_R_INPUT
 #%end
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/scripts/i.spectral/i.spectral.py	2012-08-29 11:58:20 UTC (rev 52972)
@@ -24,6 +24,7 @@
 #%Module
 #%  description: Displays spectral response at user specified locations in group or images.
 #%  keywords: imagery
+#%  keywords: querying
 #%  keywords: raster
 #%  keywords: multispectral
 #%End
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py	2012-08-29 11:58:20 UTC (rev 52972)
@@ -23,8 +23,8 @@
 #%Module
 #%  description: Georeference, rectify, and import Terra-ASTER imagery and relative DEMs using gdalwarp.
 #%  keywords: raster
+#%  keywords: import
-#%  keywords: import
 #%  keywords: Terra-ASTER
 #%End
 #%option G_OPT_F_INPUT
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/scripts/v.krige/v.krige.py	2012-08-29 11:58:20 UTC (rev 52972)
@@ -20,8 +20,8 @@
 #%module
 #% description: Performs ordinary or block kriging for vector maps.
 #% keywords: vector
+#% keywords: interpolation
 #% keywords: raster
-#% keywords: interpolation
 #% keywords: kriging
 #%end
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2012-08-29 11:58:20 UTC (rev 52972)
@@ -19,8 +19,8 @@
 #%module
 #% description: Calculates univariate statistics from a raster map based on vector polygon map and uploads statistics to new attribute columns.
 #% keywords: vector
 #% keywords: raster
-#% keywords: statistics
 #%end
 #%flag
 #% key: c
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview.py
--- grass/trunk/scripts/wxpyimgview/wxpyimgview.py	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview.py	2012-08-29 11:58:20 UTC (rev 52972)
@@ -21,6 +21,7 @@
 #%module
 #% description: Views BMP images from the PNG driver.
+#% keywords: graphics
 #% keywords: raster
 #%end
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/vector/v.neighbors/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -47,6 +47,8 @@
+    G_add_keyword(_("algebra"));
+    G_add_keyword(_("statistics"));
     module->label = _("Neighborhood analysis tool for vector point maps.");
Modified: grass/trunk/visualization/wximgview/main.cpp
--- grass/trunk/visualization/wximgview/main.cpp	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/visualization/wximgview/main.cpp	2012-08-29 11:58:20 UTC (rev 52972)
@@ -250,6 +250,7 @@
Modified: grass/trunk/visualization/ximgview/main.c
--- grass/trunk/visualization/ximgview/main.c	2012-08-29 08:34:56 UTC (rev 52971)
+++ grass/trunk/visualization/ximgview/main.c	2012-08-29 11:58:20 UTC (rev 52972)
@@ -288,6 +288,7 @@
