[GRASS-SVN] r52977 - grass/branches/releasebranch_6_4/locale/po
svn_grass at osgeo.org
Wed Aug 29 06:24:38 PDT 2012
Author: neteler
Date: 2012-08-29 06:24:37 -0700 (Wed, 29 Aug 2012)
New Revision: 52977
grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
Sylvain Maillard: cont'ed; typo fix
Modified: grass/branches/releasebranch_6_4/locale/po/grassmods_de.po
--- grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-08-29 12:55:21 UTC (rev 52976)
+++ grass/branches/releasebranch_6_4/locale/po/grassmods_de.po 2012-08-29 13:24:37 UTC (rev 52977)
@@ -3830,7 +3830,7 @@
#: ../raster/r.support/modhead/modhead.c:248
#: ../raster/r.support/modhead/modhead.c:257
msgid "Most likely the header is wrong, but I want you to decide.\n"
-msgstr "Höhstwahrscheinlich ist die Information aus dem Header falsch, aber ich möchte, dass Sie entscheiden.\n"
+msgstr "Höchstwahrscheinlich ist die Information aus dem Header falsch, aber ich möchte, dass Sie entscheiden.\n"
#: ../raster/r.support/modhead/modhead.c:254
#, c-format
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2012-08-29 12:55:21 UTC (rev 52976)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_fr.po 2012-08-29 13:24:37 UTC (rev 52977)
@@ -10,8 +10,8 @@
"Project-Id-Version: grasswxpy_fr\n"
"Report-Msgid-Bugs-To: \n"
"POT-Creation-Date: 2012-02-01 08:43+0100\n"
-"PO-Revision-Date: 2012-02-07 10:49+0100\n"
-"Last-Translator: Vincent Bain <bain at toraval.fr>\n"
+"PO-Revision-Date: 2012-08-26 20:29+0100\n"
+"Last-Translator: Sylvain Maillard <sylvain.maillard at gmail.com>\n"
"Language-Team: français <grass-translations at lists.osgeo.org>\n"
"Language: fr\n"
"MIME-Version: 1.0\n"
@@ -1338,7 +1338,7 @@
msgstr "Commande / Condition"
#: ../gui/wxpython/gui_modules/gmodeler.py:4469
-#, fuzzy, python-format
+#, python-format
msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
msgstr "Les enregistrements sélectionnés (%d) vont être définitivement supprimés de la table. Souhaitez-vous les supprimer ?"
@@ -1416,15 +1416,15 @@
#: ../gui/wxpython/gui_modules/preferences.py:675
msgid "box"
-msgstr ""
+msgstr "boite"
#: ../gui/wxpython/gui_modules/preferences.py:676
msgid "sphere"
-msgstr ""
+msgstr "sphère"
#: ../gui/wxpython/gui_modules/preferences.py:677
msgid "cube"
-msgstr ""
+msgstr "cube"
#: ../gui/wxpython/gui_modules/preferences.py:678
msgid "diamond"
@@ -2088,11 +2088,12 @@
msgstr "Ouvrir la boite de dialogue %s"
#: ../gui/wxpython/gui_modules/gdialogs.py:1283
-#, fuzzy
msgid ""
"No layers marked for import.\n"
"Operation canceled."
-msgstr "Aucune extension sélectionnée pour suppression. Opération annulée."
+msgstr ""
+"Aucune couche sélectionnée pour l'import.\n"
+"Opération annulée."
#: ../gui/wxpython/gui_modules/gdialogs.py:1356
msgid "Import DXF layers"
@@ -2995,9 +2996,9 @@
msgstr "Rectification des images en cours, merci de patienter ..."
#: ../gui/wxpython/gui_modules/gcpmanager.py:1387
+#, python-format
msgid "Transforming <%s>..."
-msgstr "Transformation <%s>..."
+msgstr "Transformation de <%s>..."
#: ../gui/wxpython/gui_modules/gcpmanager.py:1404
#: ../gui/wxpython/gui_modules/gcpmanager.py:1475
@@ -4391,9 +4392,9 @@
msgstr "Paramètres de la carte vecteur"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:2979
+#, python-format
msgid "%s properties"
-msgstr "propriétés"
+msgstr "Propriétés de %s"
#: ../gui/wxpython/gui_modules/psmap_dialogs.py:3029
msgid "Data selection"
@@ -5006,9 +5007,9 @@
msgstr "Récupérer la liste des extensions disponibles en cliquant sur le bouton 'Récupérer'"
#: ../gui/wxpython/gui_modules/ghelp.py:940
+#, python-format
msgid "%d items match"
-msgstr "%d items correspondent"
+msgstr "%d éléments correspondent"
#: ../gui/wxpython/gui_modules/ghelp.py:953
msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
@@ -5136,9 +5137,8 @@
msgstr "Aperçu"
#: ../gui/wxpython/gui_modules/colorrules.py:396
-#, fuzzy
msgid "fp range"
-msgstr "Plage de validité"
+msgstr "Plage de valeurs"
#: ../gui/wxpython/gui_modules/colorrules.py:397
#, python-format
@@ -5181,9 +5181,8 @@
msgstr "Hauteur de la carte de surface"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:272
-#, fuzzy
msgid "Surface map color"
-msgstr "Carte de couleur pour la surface"
+msgstr "Couleur de la carte de surface"
#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:281
msgid "XY distance from previous"
@@ -5855,9 +5854,9 @@
msgstr "Pas de carte rater ou couche de carte vecteur sélectionnée pour interrogation."
#: ../gui/wxpython/gui_modules/mapdisp.py:1304
+#, python-format
msgid "Vector map <%s> opened for editing - skipped."
-msgstr "Carte vecteur <%s> ouverte pour édition - ."
+msgstr "Carte vectorielle <%s> ouverte pour édition - sautée."
#: ../gui/wxpython/gui_modules/mapdisp.py:1309
msgid "Nothing to query."
@@ -6550,7 +6549,7 @@
msgstr "Impossible de mettre à jour la carte vecteur."
#: ../gui/wxpython/gui_modules/vdigit.py:1241
+#, python-format
msgid ""
"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
"Layer and category number must be integer.\n"
@@ -9688,9 +9687,8 @@
msgstr "Afficher la table d'attributs de la carte vecteur."
#: ../gui/wxpython/menustrings.py:564
-#, fuzzy
msgid "Feature selection"
-msgstr "Sélection des données"
+msgstr "Sélection d'entité"
#: ../gui/wxpython/menustrings.py:565
msgid "Query with attributes"
@@ -11105,9 +11103,8 @@
msgstr "Ajouter le numéro des cellules (raster)"
#: ../gui/wxpython/icons/icon.py:251
-#, fuzzy
msgid "Add thematic area (choropleth) map layer"
-msgstr "Ajouter une charte thématique (chloropète)"
+msgstr "Ajouter une carte thématique (choroplèthe)"
#: ../gui/wxpython/icons/icon.py:253
msgid "Add thematic chart layer"
@@ -11122,9 +11119,8 @@
msgstr "Ajouter une couche avec ligne géodésique"
#: ../gui/wxpython/icons/icon.py:259
-#, fuzzy
msgid "Add rhumbline layer"
-msgstr "Ajouter une rhumbline"
+msgstr "Ajouter une loxodromie"
#: ../gui/wxpython/icons/icon.py:261
msgid "Add labels"
