[GRASS-SVN] r52985 - in grass/branches/develbranch_6: imagery/i.cluster locale/po raster/r.random.surface
svn_grass at osgeo.org
Thu Aug 30 00:49:32 PDT 2012
Author: neteler
Date: 2012-08-30 00:49:31 -0700 (Thu, 30 Aug 2012)
New Revision: 52985
grass/branches/develbranch_6/imagery/i.cluster/main.c
grass/branches/develbranch_6/locale/po/grassmods_ar.po
grass/branches/develbranch_6/locale/po/grassmods_cs.po
grass/branches/develbranch_6/locale/po/grassmods_de.po
grass/branches/develbranch_6/locale/po/grassmods_el.po
grass/branches/develbranch_6/locale/po/grassmods_es.po
grass/branches/develbranch_6/locale/po/grassmods_fr.po
grass/branches/develbranch_6/locale/po/grassmods_hi.po
grass/branches/develbranch_6/locale/po/grassmods_it.po
grass/branches/develbranch_6/locale/po/grassmods_ja.po
grass/branches/develbranch_6/locale/po/grassmods_ko.po
grass/branches/develbranch_6/locale/po/grassmods_lv.po
grass/branches/develbranch_6/locale/po/grassmods_mr.po
grass/branches/develbranch_6/locale/po/grassmods_pl.po
grass/branches/develbranch_6/locale/po/grassmods_pt.po
grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
grass/branches/develbranch_6/locale/po/grassmods_ru.po
grass/branches/develbranch_6/locale/po/grassmods_sl.po
grass/branches/develbranch_6/locale/po/grassmods_th.po
grass/branches/develbranch_6/locale/po/grassmods_tr.po
grass/branches/develbranch_6/locale/po/grassmods_vi.po
grass/branches/develbranch_6/locale/po/grassmods_zh.po
grass/branches/develbranch_6/raster/r.random.surface/init.c
Milena Nowotarska: msg typos fixed
Modified: grass/branches/develbranch_6/imagery/i.cluster/main.c
--- grass/branches/develbranch_6/imagery/i.cluster/main.c 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/imagery/i.cluster/main.c 2012-08-30 07:49:31 UTC (rev 52985)
@@ -204,7 +204,7 @@
if (sscanf(parm.iterations->answer, "%d", &iters) != 1 || iters < 1) {
- G_fatal_error(_("Illegal value of iterations (%s>)"),
+ G_fatal_error(_("Illegal value of iterations (%s)"),
parm.iterations->answer);
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6612,7 +6612,7 @@
#: ../raster/r.random.surface/init.c:425
#, fuzzy, c-format
-msgid "<%s> is an ilegal name"
+msgid "<%s> is an illegal name"
msgstr "اسÙ
ااÙ
Ù٠اÙÙ
خرج"
#: ../raster/r.random.surface/save.c:219 ../imagery/i.pca/support.c:27
@@ -16358,7 +16358,7 @@
#: ../imagery/i.cluster/main.c:207
#, fuzzy, c-format
-msgid "Illegal value of iterations (%s>)"
+msgid "Illegal value of iterations (%s)"
msgstr "Ù
Ù٠اÙÙ
دخÙ"
#: ../imagery/i.cluster/main.c:213
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6703,7 +6703,7 @@
#, fuzzy, c-format
msgstr "<%s> je neplatné jméno souboru"
@@ -16391,7 +16391,7 @@
#, c-format
msgstr "neplatná hodnota iteracÃ(%s)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6684,7 +6684,7 @@
#, c-format
msgstr "<%s> ist ein ungültiger Name."
@@ -16418,8 +16418,8 @@
#, c-format
-msgstr "Unzulässige Wert für die Iterationen (%s>)."
+msgstr "Unzulässige Wert für die Iterationen (%s)."
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6350,7 +6350,7 @@
#, fuzzy, c-format
msgstr "<%s> åßíáé ìç åðéôñåðôü üíïìá áñ÷åßïõ"
@@ -15592,7 +15592,7 @@
#, c-format
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6748,7 +6748,7 @@
#, c-format
msgstr "<%s> es un nombre no admitido"
@@ -16526,8 +16526,8 @@
#, c-format
-msgstr "Valor no admitido de iteraciones (%s>)"
+msgstr "Valor no admitido de iteraciones (%s)"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -7199,7 +7199,7 @@
#, fuzzy, c-format
msgstr "[%s] n'est pas un nom légal"
@@ -17574,10 +17574,8 @@
#, fuzzy, c-format
-msgstr ""
-"\n"
-"<%s> -- valeur d'itérations illégale"
+msgstr "Valeur d'itérations illégale (%s)"
#, fuzzy, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6758,7 +6758,7 @@
#, fuzzy, c-format
msgstr "हà¥"
@@ -16702,7 +16702,7 @@
#, fuzzy, c-format
msgstr "n à¤à¤¾"
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6491,7 +6491,7 @@
#, c-format
msgstr "<%s> è un nome non valido"
@@ -15942,7 +15942,7 @@
#, c-format
msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6476,7 +6476,7 @@
#, c-format
msgstr "<%s> ã¯ä¸æ£ãªãã¡ã¤ã«åã§ã"
@@ -15961,8 +15961,8 @@
#, c-format
-msgstr "ç¡å¹ãªå復å¤(%s>)"
+msgstr "ç¡å¹ãªå復å¤(%s)"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6384,7 +6384,7 @@
#, c-format
msgstr ""
@@ -15768,7 +15768,7 @@
#, fuzzy, c-format
msgstr "ì¶ë ¥í ëì¤í°ë§µ"
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6503,7 +6503,7 @@
#, fuzzy, c-format
msgstr "izejas lÄ«meÅa nosaukums"
@@ -16174,7 +16174,7 @@
#, fuzzy, c-format
msgstr "%s - nederīgs nosaukums"
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6404,7 +6404,7 @@
#, c-format
msgstr ""
@@ -15859,7 +15859,7 @@
#, fuzzy, c-format
msgstr "तà¤à¥à¤¤à¥à¤¯à¤¾à¤à¥ नाव"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6547,7 +6547,7 @@
#, fuzzy, c-format
msgstr "<%s> jest niedozwolonÄ
nazwÄ
pliku"
@@ -16141,7 +16141,7 @@
#, fuzzy, c-format
msgstr ""
"\n"
"<%s> -- niewÅaÅciwa iloÅÄ powtórzeÅ"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6889,7 +6889,7 @@
#, fuzzy, c-format
msgstr "[%s] é um nome ilegal"
@@ -16919,7 +16919,7 @@
#, fuzzy, c-format
msgstr ""
"\n"
"<%s> -- número ilegal de iterações"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6799,7 +6799,7 @@
#, fuzzy, c-format
@@ -16749,7 +16749,7 @@
#, fuzzy, c-format
msgstr ""
"\n"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6695,8 +6695,8 @@
#, fuzzy, c-format
-msgstr " "
+msgstr ""
#, c-format
@@ -16433,8 +16433,8 @@
#, c-format
-msgstr "ÐевеÑное ÑиÑло иÑеÑаÑий (<%s>)"
+msgstr "ÐевеÑное ÑиÑло иÑеÑаÑий (%s)"
#, c-format
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po 2012-08-30 07:49:31 UTC (rev 52985)
#, fuzzy, c-format
msgstr "Ime izhodnega rastrskega sloja"
@@ -16552,7 +16552,7 @@
#, fuzzy, c-format
msgstr "Vhodni sloj"
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6633,7 +6633,7 @@
#, fuzzy, c-format
msgstr "<%s> à¸à¸·à¹à¸à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸"
@@ -16276,7 +16276,7 @@
#, fuzzy, c-format
msgstr ""
"\n"
"<%s> -- à¸à¹à¸²à¸à¸à¸ à¸à¸²à¸£à¸§à¸à¸à¹à¸³ à¹à¸¡à¹à¸à¸¹à¸à¸à¹à¸à¸"
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6416,7 +6416,7 @@
#, fuzzy, c-format
msgstr "<%s> uygun olmayan bir addır"
@@ -15821,7 +15821,7 @@
#, fuzzy, c-format
msgstr ""
"\n"
"<%s> -- uygun olmayan iterasyon deÄeri"
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po 2012-08-30 07:49:31 UTC (rev 52985)
#, fuzzy, c-format
msgstr "[%s] là tên không hợp lá»"
@@ -16402,7 +16402,7 @@
#, c-format
msgstr "Giá trỠcác lần lặp không hợp lỠ(%s)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po 2012-08-30 07:49:31 UTC (rev 52985)
@@ -6654,7 +6654,7 @@
#, fuzzy, c-format
msgstr "<%s> æ¯éæ³çåç§°"
@@ -16412,7 +16412,7 @@
#, fuzzy, c-format
msgstr "éæ³ç空å¼"
Modified: grass/branches/develbranch_6/raster/r.random.surface/init.c
--- grass/branches/develbranch_6/raster/r.random.surface/init.c 2012-08-30 07:47:53 UTC (rev 52984)
+++ grass/branches/develbranch_6/raster/r.random.surface/init.c 2012-08-30 07:49:31 UTC (rev 52985)
@@ -422,6 +422,6 @@
static void IsLegal(char *Name)
if (G_legal_filename(Name) == -1)
- G_fatal_error(_("<%s> is an ilegal name"),
+ G_fatal_error(_("<%s> is an illegal name"),
Name);
