[GRASS-SVN] r52992 - grass/trunk/gui/wxpython/location_wizard
svn_grass at osgeo.org
Thu Aug 30 03:20:37 PDT 2012
Author: annakrat
Date: 2012-08-30 03:20:37 -0700 (Thu, 30 Aug 2012)
New Revision: 52992
grass/trunk/gui/wxpython/location_wizard/dialogs.py
wxGUI: attempt to fix default region dialog on Windows (still don't understand how collapsible pane should be treated)
Modified: grass/trunk/gui/wxpython/location_wizard/dialogs.py
--- grass/trunk/gui/wxpython/location_wizard/dialogs.py 2012-08-30 08:22:43 UTC (rev 52991)
+++ grass/trunk/gui/wxpython/location_wizard/dialogs.py 2012-08-30 10:20:37 UTC (rev 52992)
@@ -23,6 +23,9 @@
import wx
import wx.lib.scrolledpanel as scrolled
+if __name__ == '__main__':
+ sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "gui", "wxpython"))
from core import globalvar
from core.gcmd import RunCommand
from location_wizard.base import BaseClass
@@ -32,9 +35,9 @@
class RegionDef(BaseClass, wx.Dialog):
"""!Page for setting default region extents and resolution
- def __init__(self, parent, id = wx.ID_ANY,
+ def __init__(self, parent, id = wx.ID_ANY, size = (650, 800),
title = _("Set default region extent and resolution"), location = None):
- wx.Dialog.__init__(self, parent, id, title, size = (650,300))
+ wx.Dialog.__init__(self, parent, id, title)
panel = wx.Panel(self, id = wx.ID_ANY)
self.SetIcon(wx.Icon(os.path.join(globalvar.ETCICONDIR, 'grass.ico'), wx.BITMAP_TYPE_ICO))
@@ -205,6 +208,7 @@
self.__DoLayout(panel)
self.SetMinSize(self.GetBestSize())
self.minWindowSize = self.GetMinSize()
+ wx.CallAfter(self.settings3D.Collapse, True)
def MakeSettings3DPaneContent(self, pane):
"""!Create 3D region settings pane"""
@@ -611,3 +615,19 @@
self.transnum = self.translist.GetSelection()
self.transnum = self.transnum - 1
return self.transnum
+def testRegionDef():
+ import sys
+ import gettext
+ import wx.lib.inspection
+ import grass.script as grass
+ gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
+ app = wx.PySimpleApp()
+ dlg = RegionDef(None, location = grass.gisenv()["LOCATION_NAME"])
+ dlg.Show()
+ wx.lib.inspection.InspectionTool().Show()
+ app.MainLoop()
+ testRegionDef()
