[GRASS-SVN] r53012 - in grass/trunk: raster/r.to.rast3 raster/r.to.rast3elev raster3d/r3.out.vtk
svn_grass at osgeo.org
Fri Aug 31 03:34:33 PDT 2012
Author: neteler
Date: 2012-08-31 03:34:32 -0700 (Fri, 31 Aug 2012)
New Revision: 53012
grass/trunk/raster/r.to.rast3/main.c
grass/trunk/raster/r.to.rast3elev/main.c
grass/trunk/raster3d/r3.out.vtk/main.c
Milena Nowotarska: msg standardization
Modified: grass/trunk/raster/r.to.rast3/main.c
--- grass/trunk/raster/r.to.rast3/main.c 2012-08-31 10:34:23 UTC (rev 53011)
+++ grass/trunk/raster/r.to.rast3/main.c 2012-08-31 10:34:32 UTC (rev 53012)
@@ -90,7 +90,7 @@
param.mask = G_define_flag();
param.mask->key = 'm';
- param.mask->description = _("Use RASTER3D mask (if exists) with output map");
+ param.mask->description = _("Use 3D raster mask (if exists) with output map");
@@ -227,7 +227,7 @@
/*If not equal, set the 2D windows correct */
if (rows != region.rows || cols != region.cols) {
- G_message(_("The 2d and 3d region settings are different. I will use the g3d settings to adjust the 2d region."));
+ G_message(_("The 2D and 3D region settings are different. I will use the 3D region settings to adjust the 2D region."));
G_get_set_window(&window2d);
window2d.ns_res = region.ns_res;
window2d.ew_res = region.ew_res;
@@ -288,7 +288,7 @@
map = Rast3d_open_new_opt_tile_size(param.output->answer, RASTER3D_USE_CACHE_XY, ®ion, globalG3dMapType, maxSize);
if (map == NULL)
- fatal_error(map, fd, opencells, _("Error opening 3d raster map"));
+ fatal_error(map, fd, opencells, _("Error opening 3D raster map"));
/*if requested set the Mask on */
if (param.mask->answer) {
Modified: grass/trunk/raster/r.to.rast3elev/main.c
--- grass/trunk/raster/r.to.rast3elev/main.c 2012-08-31 10:34:23 UTC (rev 53011)
+++ grass/trunk/raster/r.to.rast3elev/main.c 2012-08-31 10:34:32 UTC (rev 53012)
@@ -191,7 +191,7 @@
- param.mask->description = _("Use RASTER3D mask (if exists) with input map");
+ param.mask->description = _("Use 3D raster mask (if exists) with input map");
return;
@@ -284,7 +284,7 @@
/*Write the value to the 3D map */
if (Rast3d_put_double(db.map, x, y, z, value) < 0)
- fatal_error(db, _("Error writing RASTER3D double data"));
+ fatal_error(db, _("Error writing 3D raster double data"));
} else {
/*Use this method for every following 3d raster maps access */
@@ -317,7 +317,7 @@
@@ -424,7 +424,7 @@
@@ -440,7 +440,7 @@
db.map = Rast3d_open_new_opt_tile_size(param.output->answer, RASTER3D_USE_CACHE_XY, ®ion, DCELL_TYPE, maxSize);
if (db.map == NULL)
- fatal_error(db, _("Error opening 3d raster map"));
+ fatal_error(db, _("Error opening 3D raster map"));
Modified: grass/trunk/raster3d/r3.out.vtk/main.c
--- grass/trunk/raster3d/r3.out.vtk/main.c 2012-08-31 10:34:23 UTC (rev 53011)
+++ grass/trunk/raster3d/r3.out.vtk/main.c 2012-08-31 10:34:32 UTC (rev 53012)
@@ -165,7 +165,7 @@
Rast3d_fatal_error(_("3D vector map <%s> not found"),
param.vectormaps->answers[i]);
} else {
- Rast3d_fatal_error(_("Please provide three G3D vector maps [x,y,z]"));
+ Rast3d_fatal_error(_("Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"));
