[GRASS-SVN] r54152 - grass/trunk/display/d.rast
Mon Dec 3 04:02:11 PST 2012
Author: martinl
Date: 2012-12-03 04:02:11 -0800 (Mon, 03 Dec 2012)
New Revision: 54152
   grass/trunk/display/d.rast/d.rast.html
d.rast: update manual, add example
Modified: grass/trunk/display/d.rast/d.rast.html
--- grass/trunk/display/d.rast/d.rast.html	2012-12-03 09:54:51 UTC (rev 54151)
+++ grass/trunk/display/d.rast/d.rast.html	2012-12-03 12:02:11 UTC (rev 54152)
@@ -1,22 +1,35 @@
 <h2>DESCRIPTION</h2>
-<em>d.rast</em> displays the specified raster map layer
-in the active display frame on the graphics monitor.
+<em>d.rast</em> displays the specified raster map in the active
+display frame on the graphics monitor.
-<!-- specify format of values=1,3,5,7,12-34,101-inf  -->
+<h2>EXAMPLE</h2>
+Display raster map "elevation" (only values between 75 and 80):
+<div class="code"><pre>
+d.rast map=elevation values=75-80
+</pre></div>
 <h2>SEE ALSO</h2>
-<em><a href="d.erase.html">d.erase</a></em><br>
-<em><a href="d.vect.html">d.vect</a></em><br>
-<!-- <em><a href="d.what.rast.html">d.what.rast</a></em><br> -->
+<em>
+  <a href="d.rast.arrow.html">d.rast.arrow</a>,
+  <a href="d.rast.leg.html">d.rast.leg</a>,
+  <a href="d.rast.num.html">d.rast.num</a>,
+  <a href="d.mon.html">d.mon</a>,
+  <a href="d.erase.html">d.erase</a>,
+  <a href="d.vect.html">d.vect</a>
+</em>
+<p>
+<em>
+  <a href="wxGUI.html">wxGUI</a>
+</em>
 <h2>AUTHOR</h2>
-James Westervelt,
-U.S. Army Construction Engineering
-Research Laboratory
+James Westervelt, U.S. Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
