[GRASS-SVN] r54167 - grass/trunk
svn_grass at osgeo.org
Mon Dec 3 11:12:38 PST 2012
Author: glynn
Date: 2012-12-03 11:12:38 -0800 (Mon, 03 Dec 2012)
New Revision: 54167
grass/trunk/aclocal.m4
grass/trunk/configure
Accept "*-pc-msys" as an alias for "*-pc-mingw32"
Modified: grass/trunk/aclocal.m4
--- grass/trunk/aclocal.m4 2012-12-03 18:50:01 UTC (rev 54166)
+++ grass/trunk/aclocal.m4 2012-12-03 19:12:38 UTC (rev 54167)
@@ -506,6 +506,7 @@
LD_LIBRARY_PATH_VAR="PATH"
*-pc-mingw32)
+ *-pc-msys)
SHLIB_LD_LIBS='${LIBS}'
SHLIB_SUFFIX=".dll"
SHLIB_LD="${CC} -shared"
Modified: grass/trunk/configure
--- grass/trunk/configure 2012-12-03 18:50:01 UTC (rev 54166)
+++ grass/trunk/configure 2012-12-03 19:12:38 UTC (rev 54167)
@@ -1504,6 +1504,7 @@
*-pc-mingw32)
+ *-pc-msys)
SHLIB_SUFFIX=".dll"
@@ -2230,7 +2231,7 @@
# Done checking fortran
echo $ac_n "checking for additional include dirs""... $ac_c" 1>&6
-echo "configure:2234: checking for additional include dirs" >&5
+echo "configure:2235: checking for additional include dirs" >&5
case "$with_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to list --with-includes." 1>&2; exit 1; }
@@ -2253,7 +2254,7 @@
# With libs option
echo $ac_n "checking for additional library dirs""... $ac_c" 1>&6
-echo "configure:2257: checking for additional library dirs" >&5
+echo "configure:2258: checking for additional library dirs" >&5
case "$with_libs" in
{ echo "configure: error: *** You must supply a directory list to --with-libs." 1>&2; exit 1; }
@@ -2287,7 +2288,7 @@
# SVR4 /usr/ucb/install, which tries to use the nonexistent group "staff"
# ./install, which can be erroneously created by make from ./install.sh.
echo $ac_n "checking for a BSD compatible install""... $ac_c" 1>&6
-echo "configure:2291: checking for a BSD compatible install" >&5
+echo "configure:2292: checking for a BSD compatible install" >&5
if test -z "$INSTALL"; then
IFS="${IFS= }"; ac_save_IFS="$IFS"; IFS=":"
@@ -2340,7 +2341,7 @@
# Extract the first word of "flex", so it can be a program name with args.
set dummy flex; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:2344: checking for $ac_word" >&5
+echo "configure:2345: checking for $ac_word" >&5
if test -n "$LEX"; then
ac_cv_prog_LEX="$LEX" # Let the user override the test.
@@ -2371,13 +2372,13 @@
*) ac_lib=l ;;
esac
echo $ac_n "checking for yywrap in -l$ac_lib""... $ac_c" 1>&6
-echo "configure:2375: checking for yywrap in -l$ac_lib" >&5
+echo "configure:2376: checking for yywrap in -l$ac_lib" >&5
ac_lib_var=`echo $ac_lib'_'yywrap | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-l$ac_lib $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 2381 "configure"
+#line 2382 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -2388,7 +2389,7 @@
yywrap()
; return 0; }
EOF
-if { (eval echo configure:2392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:2393: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -2413,7 +2414,7 @@
# Extract the first word of "lex", so it can be a program name with args.
set dummy lex; ac_word=$2
-echo "configure:2417: checking for $ac_word" >&5
+echo "configure:2418: checking for $ac_word" >&5
case "$LEXPATH" in
@@ -2453,7 +2454,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:2457: checking for $ac_word" >&5
+echo "configure:2458: checking for $ac_word" >&5
if test -n "$YACC"; then
ac_cv_prog_YACC="$YACC" # Let the user override the test.
@@ -2484,7 +2485,7 @@
# Extract the first word of "yacc", so it can be a program name with args.
set dummy yacc; ac_word=$2
-echo "configure:2488: checking for $ac_word" >&5
+echo "configure:2489: checking for $ac_word" >&5
case "$YACCPATH" in
@@ -2522,7 +2523,7 @@
# Extract the first word of "ranlib", so it can be a program name with args.
set dummy ranlib; ac_word=$2
-echo "configure:2526: checking for $ac_word" >&5
+echo "configure:2527: checking for $ac_word" >&5
if test -n "$RANLIB"; then
ac_cv_prog_RANLIB="$RANLIB" # Let the user override the test.
@@ -2551,7 +2552,7 @@
-echo "configure:2555: checking for $ac_word" >&5
+echo "configure:2556: checking for $ac_word" >&5
if test -n "$AR"; then
ac_cv_prog_AR="$AR" # Let the user override the test.
@@ -2582,7 +2583,7 @@
-echo "configure:2586: checking for $ac_word" >&5
+echo "configure:2587: checking for $ac_word" >&5
if test -n "$ENV"; then
ac_cv_prog_ENV="$ENV" # Let the user override the test.
@@ -2611,7 +2612,7 @@
# Extract the first word of "perl", so it can be a program name with args.
set dummy perl; ac_word=$2
-echo "configure:2615: checking for $ac_word" >&5
+echo "configure:2616: checking for $ac_word" >&5
case "$PERL" in
@@ -2642,7 +2643,7 @@
fi
echo $ac_n "checking how to run the C preprocessor""... $ac_c" 1>&6
-echo "configure:2646: checking how to run the C preprocessor" >&5
+echo "configure:2647: checking how to run the C preprocessor" >&5
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
@@ -2655,13 +2656,13 @@
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp.
-#line 2659 "configure"
+#line 2660 "configure"
#include <assert.h>
Syntax Error
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:2665: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2666: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
@@ -2672,13 +2673,13 @@
rm -rf conftest*
CPP="${CC-cc} -E -traditional-cpp"
-#line 2676 "configure"
+#line 2677 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2682: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2683: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2689,13 +2690,13 @@
rm -rf conftest*
CPP="${CC-cc} -nologo -E"
-#line 2693 "configure"
+#line 2694 "configure"
#include <assert.h>
Syntax Error
EOF
-{ (eval echo configure:2699: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2700: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
@@ -2719,10 +2720,10 @@
echo "$ac_t""$CPP" 1>&6
echo $ac_n "checking for ANSI C header files""... $ac_c" 1>&6
-echo "configure:2723: checking for ANSI C header files" >&5
+echo "configure:2724: checking for ANSI C header files" >&5
-#line 2726 "configure"
+#line 2727 "configure"
#include <stdlib.h>
#include <stdarg.h>
@@ -2730,7 +2731,7 @@
#include <float.h>
EOF
-{ (eval echo configure:2734: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2735: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2747,7 +2748,7 @@
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
-#line 2751 "configure"
+#line 2752 "configure"
#include <string.h>
EOF
@@ -2765,7 +2766,7 @@
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
-#line 2769 "configure"
+#line 2770 "configure"
#include <stdlib.h>
EOF
@@ -2786,7 +2787,7 @@
else
-#line 2790 "configure"
+#line 2791 "configure"
#include <ctype.h>
#define ISLOWER(c) ('a' <= (c) && (c) <= 'z')
@@ -2797,7 +2798,7 @@
exit (0); }
EOF
-if { (eval echo configure:2801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:2802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
else
@@ -2824,15 +2825,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:2828: checking for $ac_hdr" >&5
+echo "configure:2829: checking for $ac_hdr" >&5
-#line 2831 "configure"
+#line 2832 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2836: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2837: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2861,15 +2862,15 @@
do
-echo "configure:2865: checking for $ac_hdr" >&5
+echo "configure:2866: checking for $ac_hdr" >&5
-#line 2868 "configure"
+#line 2869 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2873: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2874: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2898,15 +2899,15 @@
do
-echo "configure:2902: checking for $ac_hdr" >&5
+echo "configure:2903: checking for $ac_hdr" >&5
-#line 2905 "configure"
+#line 2906 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2910: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2911: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2935,15 +2936,15 @@
do
-echo "configure:2939: checking for $ac_hdr" >&5
+echo "configure:2940: checking for $ac_hdr" >&5
-#line 2942 "configure"
+#line 2943 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2948: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -2972,15 +2973,15 @@
do
-echo "configure:2976: checking for $ac_hdr" >&5
+echo "configure:2977: checking for $ac_hdr" >&5
-#line 2979 "configure"
+#line 2980 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:2984: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:2985: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3006,10 +3007,10 @@
done
echo $ac_n "checking whether time.h and sys/time.h may both be included""... $ac_c" 1>&6
-echo "configure:3010: checking whether time.h and sys/time.h may both be included" >&5
+echo "configure:3011: checking whether time.h and sys/time.h may both be included" >&5
-#line 3013 "configure"
+#line 3014 "configure"
#include <sys/types.h>
#include <sys/time.h>
@@ -3018,7 +3019,7 @@
struct tm *tp;
; return 0; }
EOF
-if { (eval echo configure:3022: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3023: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_header_time=yes
else
@@ -3038,10 +3039,10 @@
fi
echo $ac_n "checking for off_t""... $ac_c" 1>&6
-echo "configure:3042: checking for off_t" >&5
+echo "configure:3043: checking for off_t" >&5
-#line 3045 "configure"
+#line 3046 "configure"
#if STDC_HEADERS
@@ -3068,10 +3069,10 @@
fi
echo $ac_n "checking for uid_t in sys/types.h""... $ac_c" 1>&6
-echo "configure:3072: checking for uid_t in sys/types.h" >&5
+echo "configure:3073: checking for uid_t in sys/types.h" >&5
-#line 3075 "configure"
+#line 3076 "configure"
EOF
@@ -3099,10 +3100,10 @@
fi
echo $ac_n "checking return type of signal handlers""... $ac_c" 1>&6
-echo "configure:3103: checking return type of signal handlers" >&5
+echo "configure:3104: checking return type of signal handlers" >&5
-#line 3106 "configure"
+#line 3107 "configure"
#include <signal.h>
@@ -3119,7 +3120,7 @@
int i;
; return 0; }
EOF
-if { (eval echo configure:3123: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3124: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_type_signal=void
else
@@ -3137,10 +3138,10 @@
echo $ac_n "checking for Cygwin environment""... $ac_c" 1>&6
-echo "configure:3141: checking for Cygwin environment" >&5
+echo "configure:3142: checking for Cygwin environment" >&5
-#line 3144 "configure"
+#line 3145 "configure"
int main() {
@@ -3151,7 +3152,7 @@
return __CYGWIN__;
; return 0; }
EOF
-if { (eval echo configure:3155: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3156: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_cygwin=yes
else
@@ -3169,10 +3170,10 @@
for ac_func in ftime gethostname gettimeofday lseek nice time uname
do
echo $ac_n "checking for $ac_func""... $ac_c" 1>&6
-echo "configure:3173: checking for $ac_func" >&5
+echo "configure:3174: checking for $ac_func" >&5
-#line 3176 "configure"
+#line 3177 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char $ac_func(); below. */
@@ -3195,7 +3196,7 @@
; return 0; }
EOF
-if { (eval echo configure:3199: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3200: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_$ac_func=yes"
else
@@ -3221,10 +3222,10 @@
for ac_func in seteuid setpriority setreuid setruid
do
-echo "configure:3225: checking for $ac_func" >&5
+echo "configure:3226: checking for $ac_func" >&5
-#line 3228 "configure"
+#line 3229 "configure"
@@ -3247,7 +3248,7 @@
; return 0; }
EOF
-if { (eval echo configure:3251: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3273,10 +3274,10 @@
for ac_func in drand48
do
-echo "configure:3277: checking for $ac_func" >&5
+echo "configure:3278: checking for $ac_func" >&5
-#line 3280 "configure"
+#line 3281 "configure"
@@ -3299,7 +3300,7 @@
; return 0; }
EOF
-if { (eval echo configure:3303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3325,10 +3326,10 @@
for ac_func in putenv setenv
do
-echo "configure:3329: checking for $ac_func" >&5
+echo "configure:3330: checking for $ac_func" >&5
-#line 3332 "configure"
+#line 3333 "configure"
@@ -3351,7 +3352,7 @@
; return 0; }
EOF
-if { (eval echo configure:3355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3356: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3377,10 +3378,10 @@
for ac_func in nanosleep
do
-echo "configure:3381: checking for $ac_func" >&5
+echo "configure:3382: checking for $ac_func" >&5
-#line 3384 "configure"
+#line 3385 "configure"
@@ -3403,7 +3404,7 @@
; return 0; }
EOF
-if { (eval echo configure:3407: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3408: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3428,13 +3429,13 @@
if test "$cross_compiling" != "yes" ; then
echo $ac_n "checking whether setpgrp takes no argument""... $ac_c" 1>&6
-echo "configure:3432: checking whether setpgrp takes no argument" >&5
+echo "configure:3433: checking whether setpgrp takes no argument" >&5
if test "$cross_compiling" = yes; then
{ echo "configure: error: cannot check setpgrp if cross compiling" 1>&2; exit 1; }
else
-#line 3438 "configure"
+#line 3439 "configure"
#ifdef HAVE_UNISTD_H
@@ -3454,7 +3455,7 @@
EOF
-if { (eval echo configure:3458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:3459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
ac_cv_func_setpgrp_void=no
else
@@ -3482,16 +3483,16 @@
fi
echo $ac_n "checking for long long int""... $ac_c" 1>&6
-echo "configure:3486: checking for long long int" >&5
+echo "configure:3487: checking for long long int" >&5
-#line 3488 "configure"
+#line 3489 "configure"
int main() {
long long int x;
; return 0; }
EOF
-if { (eval echo configure:3495: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:3496: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
echo "$ac_t""yes" 1>&6
@@ -3511,7 +3512,7 @@
rm -f conftest*
echo $ac_n "checking for W11""... $ac_c" 1>&6
-echo "configure:3515: checking for W11" >&5
+echo "configure:3516: checking for W11" >&5
case "$enable_w11" in
yes|no) echo "$ac_t"""$enable_w11"" 1>&6 ;;
*) { echo "configure: error: *** You must answer yes or no." 1>&2; exit 1; } ;;
@@ -3539,7 +3540,7 @@
# Uses ac_ vars as temps to allow command line to override cache and checks.
# --without-x overrides everything else, but does not touch the cache.
echo $ac_n "checking for X""... $ac_c" 1>&6
-echo "configure:3543: checking for X" >&5
+echo "configure:3544: checking for X" >&5
# Check whether --with-x or --without-x was given.
if test "${with_x+set}" = set; then
@@ -3599,12 +3600,12 @@
# First, try using that file with no special directory specified.
-#line 3603 "configure"
+#line 3604 "configure"
#include <$x_direct_test_include>
EOF
-{ (eval echo configure:3608: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:3609: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -3673,14 +3674,14 @@
LIBS="-l$x_direct_test_library $LIBS"
-#line 3677 "configure"
+#line 3678 "configure"
int main() {
${x_direct_test_function}()
; return 0; }
EOF
-if { (eval echo configure:3684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LIBS="$ac_save_LIBS"
# We can link X programs with no special library path.
@@ -3785,17 +3786,17 @@
case "`(uname -sr) 2>/dev/null`" in
"SunOS 5"*)
echo $ac_n "checking whether -R must be followed by a space""... $ac_c" 1>&6
-echo "configure:3789: checking whether -R must be followed by a space" >&5
+echo "configure:3790: checking whether -R must be followed by a space" >&5
ac_xsave_LIBS="$LIBS"; LIBS="$LIBS -R$x_libraries"
-#line 3792 "configure"
+#line 3793 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3799: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_nospace=yes
else
@@ -3811,14 +3812,14 @@
else
LIBS="$ac_xsave_LIBS -R $x_libraries"
-#line 3815 "configure"
+#line 3816 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:3822: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_R_space=yes
else
@@ -3850,13 +3851,13 @@
# libraries were built with DECnet support. And karl at cs.umb.edu says
# the Alpha needs dnet_stub (dnet does not exist).
echo $ac_n "checking for dnet_ntoa in -ldnet""... $ac_c" 1>&6
-echo "configure:3854: checking for dnet_ntoa in -ldnet" >&5
+echo "configure:3855: checking for dnet_ntoa in -ldnet" >&5
ac_lib_var=`echo dnet'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet $LIBS"
-#line 3860 "configure"
+#line 3861 "configure"
@@ -3867,7 +3868,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3888,13 +3889,13 @@
if test $ac_cv_lib_dnet_dnet_ntoa = no; then
echo $ac_n "checking for dnet_ntoa in -ldnet_stub""... $ac_c" 1>&6
-echo "configure:3892: checking for dnet_ntoa in -ldnet_stub" >&5
+echo "configure:3893: checking for dnet_ntoa in -ldnet_stub" >&5
ac_lib_var=`echo dnet_stub'_'dnet_ntoa | sed 'y%./+-%__p_%'`
LIBS="-ldnet_stub $LIBS"
-#line 3898 "configure"
+#line 3899 "configure"
@@ -3905,7 +3906,7 @@
dnet_ntoa()
; return 0; }
EOF
-if { (eval echo configure:3909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3910: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -3933,10 +3934,10 @@
# The nsl library prevents programs from opening the X display
# on Irix 5.2, according to dickey at clark.net.
echo $ac_n "checking for gethostbyname""... $ac_c" 1>&6
-echo "configure:3937: checking for gethostbyname" >&5
+echo "configure:3938: checking for gethostbyname" >&5
-#line 3940 "configure"
+#line 3941 "configure"
which can conflict with char gethostbyname(); below. */
@@ -3959,7 +3960,7 @@
; return 0; }
EOF
-if { (eval echo configure:3963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:3964: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gethostbyname=yes"
else
@@ -3979,13 +3980,13 @@
if test $ac_cv_func_gethostbyname = no; then
echo $ac_n "checking for gethostbyname in -lnsl""... $ac_c" 1>&6
-echo "configure:3983: checking for gethostbyname in -lnsl" >&5
+echo "configure:3984: checking for gethostbyname in -lnsl" >&5
ac_lib_var=`echo nsl'_'gethostbyname | sed 'y%./+-%__p_%'`
LIBS="-lnsl $LIBS"
-#line 3989 "configure"
+#line 3990 "configure"
@@ -3996,7 +3997,7 @@
gethostbyname()
; return 0; }
EOF
-if { (eval echo configure:4000: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4001: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4025,10 +4026,10 @@
# -lsocket must be given before -lnsl if both are needed.
# We assume that if connect needs -lnsl, so does gethostbyname.
echo $ac_n "checking for connect""... $ac_c" 1>&6
-echo "configure:4029: checking for connect" >&5
+echo "configure:4030: checking for connect" >&5
-#line 4032 "configure"
+#line 4033 "configure"
which can conflict with char connect(); below. */
@@ -4051,7 +4052,7 @@
; return 0; }
EOF
-if { (eval echo configure:4055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_connect=yes"
else
@@ -4071,13 +4072,13 @@
if test $ac_cv_func_connect = no; then
echo $ac_n "checking for connect in -lsocket""... $ac_c" 1>&6
-echo "configure:4075: checking for connect in -lsocket" >&5
+echo "configure:4076: checking for connect in -lsocket" >&5
ac_lib_var=`echo socket'_'connect | sed 'y%./+-%__p_%'`
LIBS="-lsocket $X_EXTRA_LIBS $LIBS"
-#line 4081 "configure"
+#line 4082 "configure"
@@ -4088,7 +4089,7 @@
connect()
; return 0; }
EOF
-if { (eval echo configure:4092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4111,10 +4112,10 @@
# gomez at mi.uni-erlangen.de says -lposix is necessary on A/UX.
echo $ac_n "checking for remove""... $ac_c" 1>&6
-echo "configure:4115: checking for remove" >&5
+echo "configure:4116: checking for remove" >&5
-#line 4118 "configure"
+#line 4119 "configure"
which can conflict with char remove(); below. */
@@ -4137,7 +4138,7 @@
; return 0; }
EOF
-if { (eval echo configure:4141: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_remove=yes"
else
@@ -4157,13 +4158,13 @@
if test $ac_cv_func_remove = no; then
echo $ac_n "checking for remove in -lposix""... $ac_c" 1>&6
-echo "configure:4161: checking for remove in -lposix" >&5
+echo "configure:4162: checking for remove in -lposix" >&5
ac_lib_var=`echo posix'_'remove | sed 'y%./+-%__p_%'`
LIBS="-lposix $LIBS"
-#line 4167 "configure"
+#line 4168 "configure"
@@ -4174,7 +4175,7 @@
remove()
; return 0; }
EOF
-if { (eval echo configure:4178: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4197,10 +4198,10 @@
# BSDI BSD/OS 2.1 needs -lipc for XOpenDisplay.
echo $ac_n "checking for shmat""... $ac_c" 1>&6
-echo "configure:4201: checking for shmat" >&5
+echo "configure:4202: checking for shmat" >&5
-#line 4204 "configure"
+#line 4205 "configure"
which can conflict with char shmat(); below. */
@@ -4223,7 +4224,7 @@
; return 0; }
EOF
-if { (eval echo configure:4227: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4228: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_shmat=yes"
else
@@ -4243,13 +4244,13 @@
if test $ac_cv_func_shmat = no; then
echo $ac_n "checking for shmat in -lipc""... $ac_c" 1>&6
-echo "configure:4247: checking for shmat in -lipc" >&5
+echo "configure:4248: checking for shmat in -lipc" >&5
ac_lib_var=`echo ipc'_'shmat | sed 'y%./+-%__p_%'`
LIBS="-lipc $LIBS"
-#line 4253 "configure"
+#line 4254 "configure"
@@ -4260,7 +4261,7 @@
shmat()
; return 0; }
EOF
-if { (eval echo configure:4264: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4265: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4292,13 +4293,13 @@
# libraries we check for below, so use a different variable.
# --interran at uluru.Stanford.EDU, kb at cs.umb.edu.
echo $ac_n "checking for IceConnectionNumber in -lICE""... $ac_c" 1>&6
-echo "configure:4296: checking for IceConnectionNumber in -lICE" >&5
+echo "configure:4297: checking for IceConnectionNumber in -lICE" >&5
ac_lib_var=`echo ICE'_'IceConnectionNumber | sed 'y%./+-%__p_%'`
LIBS="-lICE $X_EXTRA_LIBS $LIBS"
-#line 4302 "configure"
+#line 4303 "configure"
@@ -4309,7 +4310,7 @@
IceConnectionNumber()
; return 0; }
EOF
-if { (eval echo configure:4313: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4314: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4349,12 +4350,12 @@
LIBS=""
echo $ac_n "checking for library containing cuserid""... $ac_c" 1>&6
-echo "configure:4353: checking for library containing cuserid" >&5
+echo "configure:4354: checking for library containing cuserid" >&5
ac_func_search_save_LIBS="$LIBS"
ac_cv_search_cuserid="no"
-#line 4358 "configure"
+#line 4359 "configure"
@@ -4365,7 +4366,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4370: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="none required"
else
@@ -4376,7 +4377,7 @@
test "$ac_cv_search_cuserid" = "no" && for i in compat; do
LIBS="-l$i $ac_func_search_save_LIBS"
-#line 4380 "configure"
+#line 4381 "configure"
@@ -4387,7 +4388,7 @@
cuserid()
; return 0; }
EOF
-if { (eval echo configure:4391: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4392: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_search_cuserid="-l$i"
break
@@ -4413,10 +4414,10 @@
for ac_func in asprintf
do
-echo "configure:4417: checking for $ac_func" >&5
+echo "configure:4418: checking for $ac_func" >&5
-#line 4420 "configure"
+#line 4421 "configure"
@@ -4439,7 +4440,7 @@
; return 0; }
EOF
-if { (eval echo configure:4443: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4444: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4466,10 +4467,10 @@
# Test if mathlib needs -lm flag or is included with libc
echo $ac_n "checking for atan""... $ac_c" 1>&6
-echo "configure:4470: checking for atan" >&5
+echo "configure:4471: checking for atan" >&5
-#line 4473 "configure"
+#line 4474 "configure"
which can conflict with char atan(); below. */
@@ -4492,7 +4493,7 @@
; return 0; }
EOF
-if { (eval echo configure:4496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_atan=yes"
else
@@ -4510,13 +4511,13 @@
echo "$ac_t""no" 1>&6
echo $ac_n "checking for atan in -lm""... $ac_c" 1>&6
-echo "configure:4514: checking for atan in -lm" >&5
+echo "configure:4515: checking for atan in -lm" >&5
ac_lib_var=`echo m'_'atan | sed 'y%./+-%__p_%'`
LIBS="-lm $LIBS"
-#line 4520 "configure"
+#line 4521 "configure"
@@ -4527,7 +4528,7 @@
atan()
; return 0; }
EOF
-if { (eval echo configure:4531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4554,10 +4555,10 @@
echo $ac_n "checking for dlsym""... $ac_c" 1>&6
-echo "configure:4558: checking for dlsym" >&5
+echo "configure:4559: checking for dlsym" >&5
-#line 4561 "configure"
+#line 4562 "configure"
which can conflict with char dlsym(); below. */
@@ -4580,7 +4581,7 @@
; return 0; }
EOF
-if { (eval echo configure:4584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4585: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dlsym=yes"
else
@@ -4598,13 +4599,13 @@
echo $ac_n "checking for dlsym in -ldl""... $ac_c" 1>&6
-echo "configure:4602: checking for dlsym in -ldl" >&5
+echo "configure:4603: checking for dlsym in -ldl" >&5
ac_lib_var=`echo dl'_'dlsym | sed 'y%./+-%__p_%'`
LIBS="-ldl $LIBS"
-#line 4608 "configure"
+#line 4609 "configure"
@@ -4615,7 +4616,7 @@
dlsym()
; return 0; }
EOF
-if { (eval echo configure:4619: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4642,10 +4643,10 @@
echo $ac_n "checking for iconv""... $ac_c" 1>&6
-echo "configure:4646: checking for iconv" >&5
+echo "configure:4647: checking for iconv" >&5
-#line 4649 "configure"
+#line 4650 "configure"
which can conflict with char iconv(); below. */
@@ -4668,7 +4669,7 @@
; return 0; }
EOF
-if { (eval echo configure:4672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4673: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_iconv=yes"
else
@@ -4686,13 +4687,13 @@
echo $ac_n "checking for iconv in -liconv""... $ac_c" 1>&6
-echo "configure:4690: checking for iconv in -liconv" >&5
+echo "configure:4691: checking for iconv in -liconv" >&5
ac_lib_var=`echo iconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-liconv $LIBS"
-#line 4696 "configure"
+#line 4697 "configure"
@@ -4703,7 +4704,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4707: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4708: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4722,13 +4723,13 @@
echo $ac_n "checking for iconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4726: checking for iconv in -lgiconv" >&5
+echo "configure:4727: checking for iconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'iconv | sed 'y%./+-%__p_%'`
LIBS="-lgiconv $LIBS"
-#line 4732 "configure"
+#line 4733 "configure"
@@ -4739,7 +4740,7 @@
iconv()
; return 0; }
EOF
-if { (eval echo configure:4743: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4744: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4758,10 +4759,10 @@
echo $ac_n "checking for libiconv""... $ac_c" 1>&6
-echo "configure:4762: checking for libiconv" >&5
+echo "configure:4763: checking for libiconv" >&5
-#line 4765 "configure"
+#line 4766 "configure"
which can conflict with char libiconv(); below. */
@@ -4784,7 +4785,7 @@
; return 0; }
EOF
-if { (eval echo configure:4788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_libiconv=yes"
else
@@ -4802,13 +4803,13 @@
echo $ac_n "checking for libiconv in -liconv""... $ac_c" 1>&6
-echo "configure:4806: checking for libiconv in -liconv" >&5
+echo "configure:4807: checking for libiconv in -liconv" >&5
ac_lib_var=`echo iconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4812 "configure"
+#line 4813 "configure"
@@ -4819,7 +4820,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4823: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4824: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4838,13 +4839,13 @@
echo $ac_n "checking for libiconv in -lgiconv""... $ac_c" 1>&6
-echo "configure:4842: checking for libiconv in -lgiconv" >&5
+echo "configure:4843: checking for libiconv in -lgiconv" >&5
ac_lib_var=`echo giconv'_'libiconv | sed 'y%./+-%__p_%'`
-#line 4848 "configure"
+#line 4849 "configure"
@@ -4855,7 +4856,7 @@
libiconv()
; return 0; }
EOF
-if { (eval echo configure:4859: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4860: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -4892,10 +4893,10 @@
have_socket=1
echo $ac_n "checking for socket""... $ac_c" 1>&6
-echo "configure:4896: checking for socket" >&5
+echo "configure:4897: checking for socket" >&5
-#line 4899 "configure"
+#line 4900 "configure"
which can conflict with char socket(); below. */
@@ -4918,7 +4919,7 @@
; return 0; }
EOF
-if { (eval echo configure:4922: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4923: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_socket=yes"
else
@@ -4936,13 +4937,13 @@
echo $ac_n "checking for socket in -lsocket""... $ac_c" 1>&6
-echo "configure:4940: checking for socket in -lsocket" >&5
+echo "configure:4941: checking for socket in -lsocket" >&5
ac_lib_var=`echo socket'_'socket | sed 'y%./+-%__p_%'`
LIBS="-lsocket $LIBS"
-#line 4946 "configure"
+#line 4947 "configure"
@@ -4953,7 +4954,7 @@
socket()
; return 0; }
EOF
-if { (eval echo configure:4957: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:4958: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5001,7 +5002,7 @@
echo $ac_n "checking for location of zlib includes""... $ac_c" 1>&6
-echo "configure:5005: checking for location of zlib includes" >&5
+echo "configure:5006: checking for location of zlib includes" >&5
case "$with_zlib_includes" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-includes." 1>&2; exit 1; }
@@ -5027,15 +5028,15 @@
do
-echo "configure:5031: checking for $ac_hdr" >&5
+echo "configure:5032: checking for $ac_hdr" >&5
-#line 5034 "configure"
+#line 5035 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5039: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5040: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5069,7 +5070,7 @@
echo $ac_n "checking for location of zlib library""... $ac_c" 1>&6
-echo "configure:5073: checking for location of zlib library" >&5
+echo "configure:5074: checking for location of zlib library" >&5
case "$with_zlib_libs" in
{ echo "configure: error: *** You must supply a directory to --with-zlib-libs." 1>&2; exit 1; }
@@ -5094,13 +5095,13 @@
echo $ac_n "checking for deflate in -lz""... $ac_c" 1>&6
-echo "configure:5098: checking for deflate in -lz" >&5
+echo "configure:5099: checking for deflate in -lz" >&5
ac_lib_var=`echo z'_'deflate | sed 'y%./+-%__p_%'`
LIBS="-lz $LIBS"
-#line 5104 "configure"
+#line 5105 "configure"
@@ -5111,7 +5112,7 @@
deflate()
; return 0; }
EOF
-if { (eval echo configure:5115: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5116: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5159,7 +5160,7 @@
echo $ac_n "checking for location of External PROJ.4 includes""... $ac_c" 1>&6
-echo "configure:5163: checking for location of External PROJ.4 includes" >&5
+echo "configure:5164: checking for location of External PROJ.4 includes" >&5
case "$with_proj_includes" in
{ echo "configure: error: *** You must supply a directory to --with-proj-includes." 1>&2; exit 1; }
@@ -5185,15 +5186,15 @@
do
-echo "configure:5189: checking for $ac_hdr" >&5
+echo "configure:5190: checking for $ac_hdr" >&5
-#line 5192 "configure"
+#line 5193 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5197: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5198: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5230,7 +5231,7 @@
else
echo $ac_n "checking External PROJ.4 version""... $ac_c" 1>&6
-echo "configure:5234: checking External PROJ.4 version" >&5
+echo "configure:5235: checking External PROJ.4 version" >&5
ac_save_cppflags="$CPPFLAGS"
CPPFLAGS="$PROJINC $CPPFLAGS"
@@ -5238,7 +5239,7 @@
echo "$ac_t""unknown (cross-compiling)" 1>&6
else
-#line 5242 "configure"
+#line 5243 "configure"
#include <stdio.h>
@@ -5250,7 +5251,7 @@
EOF
-if { (eval echo configure:5254: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:5255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
then
proj_ver=`cat conftestdata`
echo "$ac_t""$proj_ver" 1>&6
@@ -5275,7 +5276,7 @@
echo $ac_n "checking for location of External PROJ.4 library""... $ac_c" 1>&6
-echo "configure:5279: checking for location of External PROJ.4 library" >&5
+echo "configure:5280: checking for location of External PROJ.4 library" >&5
case "$with_proj_libs" in
{ echo "configure: error: *** You must supply a directory to --with-proj-libs." 1>&2; exit 1; }
@@ -5300,13 +5301,13 @@
echo $ac_n "checking for pj_get_def in -lproj""... $ac_c" 1>&6
-echo "configure:5304: checking for pj_get_def in -lproj" >&5
+echo "configure:5305: checking for pj_get_def in -lproj" >&5
ac_lib_var=`echo proj'_'pj_get_def | sed 'y%./+-%__p_%'`
LIBS="-lproj $LIBS"
-#line 5310 "configure"
+#line 5311 "configure"
@@ -5317,7 +5318,7 @@
pj_get_def()
; return 0; }
EOF
-if { (eval echo configure:5321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5351,7 +5352,7 @@
echo $ac_n "checking for location of External PROJ.4 data files""... $ac_c" 1>&6
-echo "configure:5355: checking for location of External PROJ.4 data files" >&5
+echo "configure:5356: checking for location of External PROJ.4 data files" >&5
case "$with_proj_share" in
{ echo "configure: error: *** You must supply a directory to --with-proj-share." 1>&2; exit 1; }
@@ -5375,14 +5376,14 @@
# LOC_CHECK_SHARE does not work when cross compiling
if test "$cross_compiling" = "yes" ; then
echo $ac_n "checking for epsg""... $ac_c" 1>&6
-echo "configure:5379: checking for epsg" >&5
+echo "configure:5380: checking for epsg" >&5
else
ac_safe=`echo "$PROJSHARE/epsg" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $PROJSHARE/epsg""... $ac_c" 1>&6
-echo "configure:5386: checking for $PROJSHARE/epsg" >&5
+echo "configure:5387: checking for $PROJSHARE/epsg" >&5
{ echo "configure: error: Cannot check for file existence when cross compiling" 1>&2; exit 1; }
@@ -5414,7 +5415,7 @@
# Extract the first word of "nad2bin", so it can be a program name with args.
set dummy nad2bin; ac_word=$2
-echo "configure:5418: checking for $ac_word" >&5
+echo "configure:5419: checking for $ac_word" >&5
case "$NAD2BIN" in
@@ -5454,7 +5455,7 @@
echo $ac_n "checking whether to use regex""... $ac_c" 1>&6
-echo "configure:5458: checking whether to use regex" >&5
+echo "configure:5459: checking whether to use regex" >&5
echo "$ac_t"""$with_regex"" 1>&6
case "$with_regex" in
"no") USE_REGEX= ;;
@@ -5474,7 +5475,7 @@
echo $ac_n "checking for location of regex includes""... $ac_c" 1>&6
-echo "configure:5478: checking for location of regex includes" >&5
+echo "configure:5479: checking for location of regex includes" >&5
case "$with_regex_includes" in
{ echo "configure: error: *** You must supply a directory to --with-regex-includes." 1>&2; exit 1; }
@@ -5500,15 +5501,15 @@
do
-echo "configure:5504: checking for $ac_hdr" >&5
+echo "configure:5505: checking for $ac_hdr" >&5
-#line 5507 "configure"
+#line 5508 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5512: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5513: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5542,7 +5543,7 @@
echo $ac_n "checking for location of regex library""... $ac_c" 1>&6
-echo "configure:5546: checking for location of regex library" >&5
+echo "configure:5547: checking for location of regex library" >&5
case "$with_regex_libs" in
{ echo "configure: error: *** You must supply a directory to --with-regex-libs." 1>&2; exit 1; }
@@ -5567,10 +5568,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for regcomp""... $ac_c" 1>&6
-echo "configure:5571: checking for regcomp" >&5
+echo "configure:5572: checking for regcomp" >&5
-#line 5574 "configure"
+#line 5575 "configure"
which can conflict with char regcomp(); below. */
@@ -5593,7 +5594,7 @@
; return 0; }
EOF
-if { (eval echo configure:5597: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5598: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_regcomp=yes"
else
@@ -5620,13 +5621,13 @@
echo $ac_n "checking for regcomp in -lregex""... $ac_c" 1>&6
-echo "configure:5624: checking for regcomp in -lregex" >&5
+echo "configure:5625: checking for regcomp in -lregex" >&5
ac_lib_var=`echo regex'_'regcomp | sed 'y%./+-%__p_%'`
LIBS="-lregex $LIBS"
-#line 5630 "configure"
+#line 5631 "configure"
@@ -5637,7 +5638,7 @@
regcomp()
; return 0; }
EOF
-if { (eval echo configure:5641: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5642: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5687,7 +5688,7 @@
echo $ac_n "checking whether to use Readline""... $ac_c" 1>&6
-echo "configure:5691: checking whether to use Readline" >&5
+echo "configure:5692: checking whether to use Readline" >&5
echo "$ac_t"""$with_readline"" 1>&6
case "$with_readline" in
"no") USE_READLINE= ;;
@@ -5708,7 +5709,7 @@
echo $ac_n "checking for location of Readline includes""... $ac_c" 1>&6
-echo "configure:5712: checking for location of Readline includes" >&5
+echo "configure:5713: checking for location of Readline includes" >&5
case "$with_readline_includes" in
{ echo "configure: error: *** You must supply a directory to --with-readline-includes." 1>&2; exit 1; }
@@ -5734,15 +5735,15 @@
do
-echo "configure:5738: checking for $ac_hdr" >&5
+echo "configure:5739: checking for $ac_hdr" >&5
-#line 5741 "configure"
+#line 5742 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5746: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5747: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5778,15 +5779,15 @@
do
-echo "configure:5782: checking for $ac_hdr" >&5
+echo "configure:5783: checking for $ac_hdr" >&5
-#line 5785 "configure"
+#line 5786 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:5790: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:5791: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -5820,7 +5821,7 @@
echo $ac_n "checking for location of Readline library""... $ac_c" 1>&6
-echo "configure:5824: checking for location of Readline library" >&5
+echo "configure:5825: checking for location of Readline library" >&5
case "$with_readline_libs" in
{ echo "configure: error: *** You must supply a directory to --with-readline-libs." 1>&2; exit 1; }
@@ -5845,13 +5846,13 @@
echo $ac_n "checking for readline in -lreadline""... $ac_c" 1>&6
-echo "configure:5849: checking for readline in -lreadline" >&5
+echo "configure:5850: checking for readline in -lreadline" >&5
ac_lib_var=`echo readline'_'readline | sed 'y%./+-%__p_%'`
LIBS="-lreadline $LIBS"
-#line 5855 "configure"
+#line 5856 "configure"
@@ -5862,7 +5863,7 @@
readline()
; return 0; }
EOF
-if { (eval echo configure:5866: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5867: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5897,13 +5898,13 @@
echo $ac_n "checking for add_history in -lhistory""... $ac_c" 1>&6
-echo "configure:5901: checking for add_history in -lhistory" >&5
+echo "configure:5902: checking for add_history in -lhistory" >&5
ac_lib_var=`echo history'_'add_history | sed 'y%./+-%__p_%'`
LIBS="-lhistory $LIBS"
-#line 5907 "configure"
+#line 5908 "configure"
@@ -5914,7 +5915,7 @@
add_history()
; return 0; }
EOF
-if { (eval echo configure:5918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:5919: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -5956,7 +5957,7 @@
# GDAL option
echo $ac_n "checking whether to use GDAL""... $ac_c" 1>&6
-echo "configure:5960: checking whether to use GDAL" >&5
+echo "configure:5961: checking whether to use GDAL" >&5
GDAL_LIBS=
GDAL_CFLAGS=
@@ -5974,7 +5975,7 @@
# Extract the first word of "gdal-config", so it can be a program name with args.
set dummy gdal-config; ac_word=$2
-echo "configure:5978: checking for $ac_word" >&5
+echo "configure:5979: checking for $ac_word" >&5
case "$GDAL_CONFIG" in
@@ -6029,14 +6030,14 @@
LIBS="$LIBS $GDAL_LIBS"
CFLAGS="$CFLAGS $GDAL_CFLAGS"
-#line 6033 "configure"
+#line 6034 "configure"
#include <gdal.h>
int main() {
GDALOpen("foo", GA_ReadOnly);
; return 0; }
EOF
-if { (eval echo configure:6040: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6041: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
echo "configure: failed program was:" >&5
@@ -6045,14 +6046,14 @@
LIBS="$LIBS $GDAL_DEP_LIBS"
-#line 6049 "configure"
+#line 6050 "configure"
#include <gdal.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6057: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
GDAL_LIBS="$GDAL_LIBS $GDAL_DEP_LIBS"
else
@@ -6084,7 +6085,7 @@
# libLAS option
echo $ac_n "checking whether to use libLAS""... $ac_c" 1>&6
-echo "configure:6088: checking whether to use libLAS" >&5
+echo "configure:6089: checking whether to use libLAS" >&5
LIBLAS_LIBS=
LIBLAS_CFLAGS=
@@ -6101,7 +6102,7 @@
# Extract the first word of "liblas-config", so it can be a program name with args.
set dummy liblas-config; ac_word=$2
-echo "configure:6105: checking for $ac_word" >&5
+echo "configure:6106: checking for $ac_word" >&5
case "$LIBLAS_CONFIG" in
@@ -6149,14 +6150,14 @@
LIBS="$LIBS $LIBLAS_LIBS"
CFLAGS="$CFLAGS $LIBLAS_CFLAGS"
-#line 6153 "configure"
+#line 6154 "configure"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
EOF
-if { (eval echo configure:6160: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6161: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6164,14 +6165,14 @@
rm -rf conftest*
-#line 6168 "configure"
+#line 6169 "configure"
int main() {
; return 0; }
EOF
-if { (eval echo configure:6175: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
LAS_LIBS="$LAS_LIBS"
else
@@ -6203,7 +6204,7 @@
# NetCDF option
echo $ac_n "checking whether to use NetCDF""... $ac_c" 1>&6
-echo "configure:6207: checking whether to use NetCDF" >&5
+echo "configure:6208: checking whether to use NetCDF" >&5
NETCDF_LIBS=
NETCDF_CFLAGS=
@@ -6220,7 +6221,7 @@
# Extract the first word of "nc-config", so it can be a program name with args.
set dummy nc-config; ac_word=$2
-echo "configure:6224: checking for $ac_word" >&5
+echo "configure:6225: checking for $ac_word" >&5
case "$NETCDF_CONFIG" in
@@ -6267,14 +6268,14 @@
LIBS="$LIBS $NETCDF_LIBS"
CFLAGS="$CFLAGS $NETCDF_CFLAGS"
-#line 6271 "configure"
+#line 6272 "configure"
#include <netcdf.h>
int main() {
nc_create("foo", NC_CLOBBER, NULL);
; return 0; }
EOF
-if { (eval echo configure:6278: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6279: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
else
@@ -6282,14 +6283,14 @@
rm -rf conftest*
-#line 6286 "configure"
+#line 6287 "configure"
#include <netcdf.h>
int main() {
; return 0; }
EOF
-if { (eval echo configure:6293: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6294: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
NETCDF_LIBS="$NETCDF_LIBS"
else
@@ -6320,7 +6321,7 @@
# GEOS option
echo $ac_n "checking whether to use GEOS""... $ac_c" 1>&6
-echo "configure:6324: checking whether to use GEOS" >&5
+echo "configure:6325: checking whether to use GEOS" >&5
GEOS_LIBS=
GEOS_CFLAGS=
@@ -6338,7 +6339,7 @@
# Extract the first word of "geos-config", so it can be a program name with args.
set dummy geos-config; ac_word=$2
-echo "configure:6342: checking for $ac_word" >&5
+echo "configure:6343: checking for $ac_word" >&5
case "$GEOS_CONFIG" in
@@ -6386,15 +6387,15 @@
do
-echo "configure:6390: checking for $ac_hdr" >&5
+echo "configure:6391: checking for $ac_hdr" >&5
-#line 6393 "configure"
+#line 6394 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6399: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6430,13 +6431,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c_i""... $ac_c" 1>&6
-echo "configure:6434: checking for initGEOS in -lgeos_c_i" >&5
+echo "configure:6435: checking for initGEOS in -lgeos_c_i" >&5
ac_lib_var=`echo geos_c_i'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c_i $LIBS"
-#line 6440 "configure"
+#line 6441 "configure"
@@ -6447,7 +6448,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6451: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6452: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6483,13 +6484,13 @@
echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
-echo "configure:6487: checking for initGEOS in -lgeos_c" >&5
+echo "configure:6488: checking for initGEOS in -lgeos_c" >&5
ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
LIBS="-lgeos_c $LIBS"
-#line 6493 "configure"
+#line 6494 "configure"
@@ -6500,7 +6501,7 @@
initGEOS()
; return 0; }
EOF
-if { (eval echo configure:6504: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6544,7 +6545,7 @@
echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:6548: checking whether to use TIFF" >&5
+echo "configure:6549: checking whether to use TIFF" >&5
echo "$ac_t"""$with_tiff"" 1>&6
case "$with_tiff" in
"no") USE_TIFF= ;;
@@ -6564,7 +6565,7 @@
echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:6568: checking for location of TIFF includes" >&5
+echo "configure:6569: checking for location of TIFF includes" >&5
case "$with_tiff_includes" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -6590,15 +6591,15 @@
do
-echo "configure:6594: checking for $ac_hdr" >&5
+echo "configure:6595: checking for $ac_hdr" >&5
-#line 6597 "configure"
+#line 6598 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:6602: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:6603: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -6632,7 +6633,7 @@
echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:6636: checking for location of TIFF library" >&5
+echo "configure:6637: checking for location of TIFF library" >&5
case "$with_tiff_libs" in
{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -6663,13 +6664,13 @@
echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:6667: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6668: checking for TIFFOpen in -ltiff" >&5
ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
LIBS="-ltiff $LIBS"
-#line 6673 "configure"
+#line 6674 "configure"
@@ -6680,7 +6681,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6684: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6685: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6699,13 +6700,13 @@
-echo "configure:6703: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6704: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $MATHLIB $LIBS"
-#line 6709 "configure"
+#line 6710 "configure"
@@ -6716,7 +6717,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6721: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6735,13 +6736,13 @@
-echo "configure:6739: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6740: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $LIBS"
-#line 6745 "configure"
+#line 6746 "configure"
@@ -6752,7 +6753,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6757: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6771,13 +6772,13 @@
-echo "configure:6775: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6776: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 6781 "configure"
+#line 6782 "configure"
@@ -6788,7 +6789,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6792: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6793: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6807,13 +6808,13 @@
-echo "configure:6811: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6812: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $LIBS"
-#line 6817 "configure"
+#line 6818 "configure"
@@ -6824,7 +6825,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6843,13 +6844,13 @@
-echo "configure:6847: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6848: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $MATHLIB $LIBS"
-#line 6853 "configure"
+#line 6854 "configure"
@@ -6860,7 +6861,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6864: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6879,13 +6880,13 @@
-echo "configure:6883: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6884: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $LIBS"
-#line 6889 "configure"
+#line 6890 "configure"
@@ -6896,7 +6897,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6901: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -6915,13 +6916,13 @@
-echo "configure:6919: checking for TIFFOpen in -ltiff" >&5
+echo "configure:6920: checking for TIFFOpen in -ltiff" >&5
LIBS="-ltiff -ljpeg $ZLIB $MATHLIB $LIBS"
-#line 6925 "configure"
+#line 6926 "configure"
@@ -6932,7 +6933,7 @@
TIFFOpen()
; return 0; }
EOF
-if { (eval echo configure:6936: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:6937: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7030,7 +7031,7 @@
echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:7034: checking whether to use PNG" >&5
+echo "configure:7035: checking whether to use PNG" >&5
echo "$ac_t"""$with_png"" 1>&6
case "$with_png" in
"no") USE_PNG= ;;
@@ -7049,7 +7050,7 @@
echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:7053: checking for location of PNG includes" >&5
+echo "configure:7054: checking for location of PNG includes" >&5
case "$with_png_includes" in
{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -7075,15 +7076,15 @@
do
-echo "configure:7079: checking for $ac_hdr" >&5
+echo "configure:7080: checking for $ac_hdr" >&5
-#line 7082 "configure"
+#line 7083 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7087: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7117,7 +7118,7 @@
echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:7121: checking for location of PNG library" >&5
+echo "configure:7122: checking for location of PNG library" >&5
case "$with_png_libs" in
{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -7142,13 +7143,13 @@
echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:7146: checking for png_read_image in -lpng" >&5
+echo "configure:7147: checking for png_read_image in -lpng" >&5
ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 7152 "configure"
+#line 7153 "configure"
@@ -7159,7 +7160,7 @@
png_read_image()
; return 0; }
EOF
-if { (eval echo configure:7163: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7164: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7201,7 +7202,7 @@
echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:7205: checking whether to use PostgreSQL" >&5
+echo "configure:7206: checking whether to use PostgreSQL" >&5
echo "$ac_t"""$with_postgres"" 1>&6
case "$with_postgres" in
"no") USE_POSTGRES= ;;
@@ -7228,7 +7229,7 @@
echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:7232: checking for location of PostgreSQL includes" >&5
+echo "configure:7233: checking for location of PostgreSQL includes" >&5
case "$with_postgres_includes" in
{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -7254,15 +7255,15 @@
do
-echo "configure:7258: checking for $ac_hdr" >&5
+echo "configure:7259: checking for $ac_hdr" >&5
-#line 7261 "configure"
+#line 7262 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:7266: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7267: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -7300,7 +7301,7 @@
echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:7304: checking for location of PostgreSQL library" >&5
+echo "configure:7305: checking for location of PostgreSQL library" >&5
case "$with_postgres_libs" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -7329,13 +7330,13 @@
echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:7333: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7334: checking for PQsetdbLogin in -lpq" >&5
ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7339 "configure"
+#line 7340 "configure"
@@ -7346,7 +7347,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7350: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7351: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7365,13 +7366,13 @@
-echo "configure:7369: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7370: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 7375 "configure"
+#line 7376 "configure"
@@ -7382,7 +7383,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7387: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7401,13 +7402,13 @@
-echo "configure:7405: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7406: checking for PQsetdbLogin in -lpq" >&5
ac_save_LIBS="$LIBS"
LIBS="-lpq -lcrypt $LIBS"
cat > conftest.$ac_ext <<EOF
-#line 7411 "configure"
+#line 7412 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -7418,7 +7419,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7423: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -7437,13 +7438,13 @@
-echo "configure:7441: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:7442: checking for PQsetdbLogin in -lpq" >&5
LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 7447 "configure"
+#line 7448 "configure"
@@ -7454,7 +7455,7 @@
PQsetdbLogin()
; return 0; }
EOF
-if { (eval echo configure:7458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7459: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7511,13 +7512,13 @@
ac_save_ldflags="$LDFLAGS"
LDFLAGS="$LDFLAGS $PQLIBPATH"
echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:7515: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7516: checking for PQcmdTuples in -lpq" >&5
ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
LIBS="-lpq $LIBS"
-#line 7521 "configure"
+#line 7522 "configure"
@@ -7528,7 +7529,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7532: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7550,13 +7551,13 @@
-echo "configure:7554: checking for PQcmdTuples in -lpq" >&5
+echo "configure:7555: checking for PQcmdTuples in -lpq" >&5
-#line 7560 "configure"
+#line 7561 "configure"
@@ -7567,7 +7568,7 @@
PQcmdTuples()
; return 0; }
EOF
-if { (eval echo configure:7571: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7610,7 +7611,7 @@
echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:7614: checking whether to use MySQL" >&5
+echo "configure:7615: checking whether to use MySQL" >&5
echo "$ac_t"""$with_mysql"" 1>&6
case "$with_mysql" in
"no") USE_MYSQL= ;;
@@ -7630,7 +7631,7 @@
echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:7634: checking for location of MySQL includes" >&5
+echo "configure:7635: checking for location of MySQL includes" >&5
case "$with_mysql_includes" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -7656,15 +7657,15 @@
do
-echo "configure:7660: checking for $ac_hdr" >&5
+echo "configure:7661: checking for $ac_hdr" >&5
-#line 7663 "configure"
+#line 7664 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:7668: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:7669: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -7701,7 +7702,7 @@
echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:7705: checking for location of MySQL library" >&5
+echo "configure:7706: checking for location of MySQL library" >&5
case "$with_mysql_libs" in
{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -7732,13 +7733,13 @@
echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:7736: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7737: checking for mysql_query in -lmysqlclient" >&5
ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
LIBS="-lmysqlclient $LIBS"
-#line 7742 "configure"
+#line 7743 "configure"
@@ -7749,7 +7750,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7754: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7768,13 +7769,13 @@
-echo "configure:7772: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7773: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 7778 "configure"
+#line 7779 "configure"
@@ -7785,7 +7786,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7789: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7790: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7804,13 +7805,13 @@
-echo "configure:7808: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7809: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 7814 "configure"
+#line 7815 "configure"
@@ -7821,7 +7822,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7825: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7826: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7840,13 +7841,13 @@
-echo "configure:7844: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7845: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 7850 "configure"
+#line 7851 "configure"
@@ -7857,7 +7858,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7861: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7862: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7876,13 +7877,13 @@
-echo "configure:7880: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7881: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 7886 "configure"
+#line 7887 "configure"
@@ -7893,7 +7894,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7897: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7898: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7912,13 +7913,13 @@
-echo "configure:7916: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7917: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 7922 "configure"
+#line 7923 "configure"
@@ -7929,7 +7930,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7933: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7934: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7948,13 +7949,13 @@
-echo "configure:7952: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7953: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 7958 "configure"
+#line 7959 "configure"
@@ -7965,7 +7966,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:7969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:7970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -7984,13 +7985,13 @@
-echo "configure:7988: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:7989: checking for mysql_query in -lmysqlclient" >&5
LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 7994 "configure"
+#line 7995 "configure"
@@ -8001,7 +8002,7 @@
mysql_query()
; return 0; }
EOF
-if { (eval echo configure:8005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8091,7 +8092,7 @@
# Extract the first word of "mysql_config", so it can be a program name with args.
set dummy mysql_config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:8095: checking for $ac_word" >&5
+echo "configure:8096: checking for $ac_word" >&5
case "$MYSQLD_CONFIG" in
@@ -8140,10 +8141,10 @@
LIBS="$MYSQLDLIB $LIBS"
echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:8144: checking for mysql_server_init" >&5
+echo "configure:8145: checking for mysql_server_init" >&5
-#line 8147 "configure"
+#line 8148 "configure"
which can conflict with char mysql_server_init(); below. */
@@ -8169,7 +8170,7 @@
; return 0; }
EOF
-if { (eval echo configure:8173: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8174: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_mysql_server_init=yes"
else
@@ -8221,7 +8222,7 @@
echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:8225: checking whether to use SQLite" >&5
+echo "configure:8226: checking whether to use SQLite" >&5
echo "$ac_t"""$with_sqlite"" 1>&6
case "$with_sqlite" in
"no") USE_SQLITE= ;;
@@ -8241,7 +8242,7 @@
echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:8245: checking for location of SQLite includes" >&5
+echo "configure:8246: checking for location of SQLite includes" >&5
case "$with_sqlite_includes" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -8267,15 +8268,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8271: checking for $ac_hdr" >&5
+echo "configure:8272: checking for $ac_hdr" >&5
-#line 8274 "configure"
+#line 8275 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8279: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8280: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8318,7 +8319,7 @@
echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:8322: checking for location of SQLite library" >&5
+echo "configure:8323: checking for location of SQLite library" >&5
case "$with_sqlite_libs" in
{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -8347,13 +8348,13 @@
echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:8351: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8352: checking for sqlite3_open in -lsqlite3" >&5
ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
LIBS="-lsqlite3 $LIBS"
-#line 8357 "configure"
+#line 8358 "configure"
@@ -8364,7 +8365,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8369: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8383,13 +8384,13 @@
-echo "configure:8387: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8388: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $DLLIB $LIBS"
-#line 8393 "configure"
+#line 8394 "configure"
@@ -8400,7 +8401,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8405: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8419,13 +8420,13 @@
-echo "configure:8423: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8424: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 8429 "configure"
+#line 8430 "configure"
@@ -8436,7 +8437,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8455,13 +8456,13 @@
-echo "configure:8459: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:8460: checking for sqlite3_open in -lsqlite3" >&5
LIBS="-lsqlite3 $MATHLIB $DLLIB $LIBS"
-#line 8465 "configure"
+#line 8466 "configure"
@@ -8472,7 +8473,7 @@
sqlite3_open()
; return 0; }
EOF
-if { (eval echo configure:8476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8541,7 +8542,7 @@
echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:8545: checking whether to use FFMPEG" >&5
+echo "configure:8546: checking whether to use FFMPEG" >&5
echo "$ac_t"""$with_ffmpeg"" 1>&6
case "$with_ffmpeg" in
"no") USE_FFMPEG= ;;
@@ -8561,7 +8562,7 @@
echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:8565: checking for location of FFMPEG includes" >&5
+echo "configure:8566: checking for location of FFMPEG includes" >&5
case "$with_ffmpeg_includes" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -8587,15 +8588,15 @@
do
-echo "configure:8591: checking for $ac_hdr" >&5
+echo "configure:8592: checking for $ac_hdr" >&5
-#line 8594 "configure"
+#line 8595 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8599: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8600: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8631,15 +8632,15 @@
do
-echo "configure:8635: checking for $ac_hdr" >&5
+echo "configure:8636: checking for $ac_hdr" >&5
-#line 8638 "configure"
+#line 8639 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8643: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8644: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8675,15 +8676,15 @@
do
-echo "configure:8679: checking for $ac_hdr" >&5
+echo "configure:8680: checking for $ac_hdr" >&5
-#line 8682 "configure"
+#line 8683 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:8687: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8688: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -8726,7 +8727,7 @@
echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:8730: checking for location of FFMPEG library" >&5
+echo "configure:8731: checking for location of FFMPEG library" >&5
case "$with_ffmpeg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -8753,13 +8754,13 @@
echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:8757: checking for av_free in -lavutil" >&5
+echo "configure:8758: checking for av_free in -lavutil" >&5
ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
LIBS="-lavutil $LIBS"
-#line 8763 "configure"
+#line 8764 "configure"
@@ -8770,7 +8771,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8774: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8775: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8789,13 +8790,13 @@
-echo "configure:8793: checking for av_free in -lavutil" >&5
+echo "configure:8794: checking for av_free in -lavutil" >&5
LIBS="-lavutil $MATHLIB $LIBS"
-#line 8799 "configure"
+#line 8800 "configure"
@@ -8806,7 +8807,7 @@
av_free()
; return 0; }
EOF
-if { (eval echo configure:8810: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8811: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8851,13 +8852,13 @@
echo $ac_n "checking for avcodec_register in -lavcodec""... $ac_c" 1>&6
-echo "configure:8855: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8856: checking for avcodec_register in -lavcodec" >&5
ac_lib_var=`echo avcodec'_'avcodec_register | sed 'y%./+-%__p_%'`
LIBS="-lavcodec $FFMPEGLIB $LIBS"
-#line 8861 "configure"
+#line 8862 "configure"
@@ -8868,7 +8869,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8873: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8887,13 +8888,13 @@
-echo "configure:8891: checking for avcodec_register in -lavcodec" >&5
+echo "configure:8892: checking for avcodec_register in -lavcodec" >&5
LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 8897 "configure"
+#line 8898 "configure"
@@ -8904,7 +8905,7 @@
avcodec_register()
; return 0; }
EOF
-if { (eval echo configure:8908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8909: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8949,13 +8950,13 @@
echo $ac_n "checking for avformat_alloc_context in -lavformat""... $ac_c" 1>&6
-echo "configure:8953: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8954: checking for avformat_alloc_context in -lavformat" >&5
ac_lib_var=`echo avformat'_'avformat_alloc_context | sed 'y%./+-%__p_%'`
LIBS="-lavformat $FFMPEGLIB $LIBS"
-#line 8959 "configure"
+#line 8960 "configure"
@@ -8966,7 +8967,7 @@
avformat_alloc_context()
; return 0; }
EOF
-if { (eval echo configure:8970: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8971: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -8985,13 +8986,13 @@
-echo "configure:8989: checking for avformat_alloc_context in -lavformat" >&5
+echo "configure:8990: checking for avformat_alloc_context in -lavformat" >&5
LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 8995 "configure"
+#line 8996 "configure"
@@ -9002,7 +9003,7 @@
; return 0; }
EOF
-if { (eval echo configure:9006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9061,7 +9062,7 @@
OPENGL_WINDOWS=
echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:9065: checking whether to use OpenGL" >&5
+echo "configure:9066: checking whether to use OpenGL" >&5
echo "$ac_t"""$with_opengl"" 1>&6
case "$with_opengl" in
n|no)
@@ -9095,7 +9096,7 @@
echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:9099: checking for location of OpenGL includes" >&5
+echo "configure:9100: checking for location of OpenGL includes" >&5
case "$with_opengl_includes" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -9121,15 +9122,15 @@
do
-echo "configure:9125: checking for $ac_hdr" >&5
+echo "configure:9126: checking for $ac_hdr" >&5
-#line 9128 "configure"
+#line 9129 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9133: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9134: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9163,7 +9164,7 @@
echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:9167: checking for location of OpenGL library" >&5
+echo "configure:9168: checking for location of OpenGL library" >&5
case "$with_opengl_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -9192,13 +9193,13 @@
echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:9196: checking for glBegin in -lGL" >&5
+echo "configure:9197: checking for glBegin in -lGL" >&5
ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9202 "configure"
+#line 9203 "configure"
@@ -9209,7 +9210,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9213: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9214: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9228,13 +9229,13 @@
-echo "configure:9232: checking for glBegin in -lGL" >&5
+echo "configure:9233: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 9238 "configure"
+#line 9239 "configure"
@@ -9245,7 +9246,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9249: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9264,13 +9265,13 @@
-echo "configure:9268: checking for glBegin in -lGL" >&5
+echo "configure:9269: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 9274 "configure"
+#line 9275 "configure"
@@ -9281,7 +9282,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9285: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9286: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9300,13 +9301,13 @@
-echo "configure:9304: checking for glBegin in -lGL" >&5
+echo "configure:9305: checking for glBegin in -lGL" >&5
LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 9310 "configure"
+#line 9311 "configure"
@@ -9317,7 +9318,7 @@
glBegin()
; return 0; }
EOF
-if { (eval echo configure:9321: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9322: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9379,13 +9380,13 @@
echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:9383: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9384: checking for gluBeginCurve in -lGLU" >&5
ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $LIBS"
-#line 9389 "configure"
+#line 9390 "configure"
@@ -9396,7 +9397,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9400: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9401: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9415,13 +9416,13 @@
-echo "configure:9419: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:9420: checking for gluBeginCurve in -lGLU" >&5
LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 9425 "configure"
+#line 9426 "configure"
@@ -9432,7 +9433,7 @@
gluBeginCurve()
; return 0; }
EOF
-if { (eval echo configure:9436: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -9479,10 +9480,10 @@
LIBS=" $OPENGLLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:9483: checking for glXCreatePbuffer" >&5
+echo "configure:9484: checking for glXCreatePbuffer" >&5
-#line 9486 "configure"
+#line 9487 "configure"
/* System header to define __stub macros and hopefully few prototypes,
which can conflict with char glXCreatePbuffer(); below. */
@@ -9505,7 +9506,7 @@
; return 0; }
EOF
-if { (eval echo configure:9509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9510: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreatePbuffer=yes"
else
@@ -9542,10 +9543,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:9546: checking for glXCreateGLXPixmap" >&5
+echo "configure:9547: checking for glXCreateGLXPixmap" >&5
-#line 9549 "configure"
+#line 9550 "configure"
which can conflict with char glXCreateGLXPixmap(); below. */
@@ -9568,7 +9569,7 @@
; return 0; }
EOF
-if { (eval echo configure:9572: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glXCreateGLXPixmap=yes"
else
@@ -9611,7 +9612,7 @@
echo $ac_n "checking for location of OpenGL framework""... $ac_c" 1>&6
-echo "configure:9615: checking for location of OpenGL framework" >&5
+echo "configure:9616: checking for location of OpenGL framework" >&5
case "$with_opengl_framework" in
{ echo "configure: error: *** You must supply a directory to --with-opengl-framework." 1>&2; exit 1; }
@@ -9635,15 +9636,15 @@
do
-echo "configure:9639: checking for $ac_hdr" >&5
+echo "configure:9640: checking for $ac_hdr" >&5
-#line 9642 "configure"
+#line 9643 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9647: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9648: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9679,10 +9680,10 @@
LIBS="-framework OpenGL -framework AGL -framework ApplicationServices $LIBS"
LDFLAGS="$OPENGLPATH $LDFLAGS"
echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:9683: checking for glBegin" >&5
+echo "configure:9684: checking for glBegin" >&5
-#line 9686 "configure"
+#line 9687 "configure"
which can conflict with char glBegin(); below. */
@@ -9705,7 +9706,7 @@
; return 0; }
EOF
-if { (eval echo configure:9709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9710: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_glBegin=yes"
else
@@ -9742,10 +9743,10 @@
echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:9746: checking for gluBeginCurve" >&5
+echo "configure:9747: checking for gluBeginCurve" >&5
-#line 9749 "configure"
+#line 9750 "configure"
which can conflict with char gluBeginCurve(); below. */
@@ -9768,7 +9769,7 @@
; return 0; }
EOF
-if { (eval echo configure:9772: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9773: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gluBeginCurve=yes"
else
@@ -9816,7 +9817,7 @@
-echo "configure:9820: checking for location of OpenGL includes" >&5
+echo "configure:9821: checking for location of OpenGL includes" >&5
@@ -9842,15 +9843,15 @@
do
-echo "configure:9846: checking for $ac_hdr" >&5
+echo "configure:9847: checking for $ac_hdr" >&5
-#line 9849 "configure"
+#line 9850 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:9854: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9855: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -9884,7 +9885,7 @@
-echo "configure:9888: checking for location of OpenGL library" >&5
+echo "configure:9889: checking for location of OpenGL library" >&5
@@ -9909,18 +9910,18 @@
ac_save_libs="$LIBS"
echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:9913: checking for OpenGL library" >&5
+echo "configure:9914: checking for OpenGL library" >&5
LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
LIBS="-lopengl32 "
-#line 9917 "configure"
+#line 9918 "configure"
#include <GL/gl.h>
int main() {
glEnd();
; return 0; }
EOF
-if { (eval echo configure:9924: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
echo "$ac_t""found" 1>&6
@@ -9944,18 +9945,18 @@
echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:9948: checking for GLU library" >&5
+echo "configure:9949: checking for GLU library" >&5
LIBS="-lglu32 $OPENGLLIB "
-#line 9952 "configure"
+#line 9953 "configure"
#include <GL/glu.h>
int main() {
gluNewQuadric();
; return 0; }
EOF
-if { (eval echo configure:9959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9960: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10004,7 +10005,7 @@
echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:10008: checking whether to use ODBC" >&5
+echo "configure:10009: checking whether to use ODBC" >&5
echo "$ac_t"""$with_odbc"" 1>&6
case "$with_odbc" in
"no") USE_ODBC= ;;
@@ -10023,7 +10024,7 @@
echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:10027: checking for location of ODBC includes" >&5
+echo "configure:10028: checking for location of ODBC includes" >&5
case "$with_odbc_includes" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -10049,15 +10050,15 @@
do
-echo "configure:10053: checking for $ac_hdr" >&5
+echo "configure:10054: checking for $ac_hdr" >&5
-#line 10056 "configure"
+#line 10057 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10061: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10062: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10091,7 +10092,7 @@
echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:10095: checking for location of ODBC library" >&5
+echo "configure:10096: checking for location of ODBC library" >&5
case "$with_odbc_libs" in
{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -10116,13 +10117,13 @@
echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:10120: checking for SQLConnect in -lodbc" >&5
+echo "configure:10121: checking for SQLConnect in -lodbc" >&5
ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-lodbc $ICONVLIB $LIBS"
-#line 10126 "configure"
+#line 10127 "configure"
@@ -10133,7 +10134,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10137: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10138: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10158,13 +10159,13 @@
echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:10162: checking for SQLConnect in -liodbc" >&5
+echo "configure:10163: checking for SQLConnect in -liodbc" >&5
ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
LIBS="-liodbc $LIBS"
-#line 10168 "configure"
+#line 10169 "configure"
@@ -10175,7 +10176,7 @@
SQLConnect()
; return 0; }
EOF
-if { (eval echo configure:10179: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10180: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10200,11 +10201,11 @@
echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:10204: checking for ODBC library" >&5
+echo "configure:10205: checking for ODBC library" >&5
LDFLAGS="$ODBCLIB $LDFLAGS"
LIBS="-lodbc32 "
-#line 10208 "configure"
+#line 10209 "configure"
#include <windows.h>
#include <sql.h>
@@ -10212,7 +10213,7 @@
SQLAllocEnv((SQLHENV *)0);
; return 0; }
EOF
-if { (eval echo configure:10216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10217: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
@@ -10261,7 +10262,7 @@
echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:10265: checking whether to use FFTW" >&5
+echo "configure:10266: checking whether to use FFTW" >&5
echo "$ac_t"""$with_fftw"" 1>&6
case "$with_fftw" in
"no") USE_FFTW= ;;
@@ -10280,7 +10281,7 @@
echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:10284: checking for location of FFTW includes" >&5
+echo "configure:10285: checking for location of FFTW includes" >&5
case "$with_fftw_includes" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -10306,15 +10307,15 @@
do
-echo "configure:10310: checking for $ac_hdr" >&5
+echo "configure:10311: checking for $ac_hdr" >&5
-#line 10313 "configure"
+#line 10314 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10318: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10319: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10342,15 +10343,15 @@
do
-echo "configure:10346: checking for $ac_hdr" >&5
+echo "configure:10347: checking for $ac_hdr" >&5
-#line 10349 "configure"
+#line 10350 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10354: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10355: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10378,15 +10379,15 @@
do
-echo "configure:10382: checking for $ac_hdr" >&5
+echo "configure:10383: checking for $ac_hdr" >&5
-#line 10385 "configure"
+#line 10386 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10390: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10391: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10432,7 +10433,7 @@
echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:10436: checking for location of FFTW library" >&5
+echo "configure:10437: checking for location of FFTW library" >&5
case "$with_fftw_libs" in
{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -10457,13 +10458,13 @@
echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:10461: checking for fftw_execute in -lfftw3" >&5
+echo "configure:10462: checking for fftw_execute in -lfftw3" >&5
ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 10467 "configure"
+#line 10468 "configure"
@@ -10474,7 +10475,7 @@
fftw_execute()
; return 0; }
EOF
-if { (eval echo configure:10478: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10479: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10499,13 +10500,13 @@
echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:10503: checking for fftwnd_one in -lfftw" >&5
+echo "configure:10504: checking for fftwnd_one in -lfftw" >&5
ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-lfftw $MATHLIB $LIBS"
-#line 10509 "configure"
+#line 10510 "configure"
@@ -10516,7 +10517,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10520: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10521: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10541,13 +10542,13 @@
echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:10545: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:10546: checking for fftwnd_one in -ldfftw" >&5
ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
LIBS="-ldfftw $MATHLIB $LIBS"
-#line 10551 "configure"
+#line 10552 "configure"
@@ -10558,7 +10559,7 @@
fftwnd_one()
; return 0; }
EOF
-if { (eval echo configure:10562: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10563: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10615,7 +10616,7 @@
echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:10619: checking whether to use BLAS" >&5
+echo "configure:10620: checking whether to use BLAS" >&5
echo "$ac_t"""$with_blas"" 1>&6
case "$with_blas" in
"no") USE_BLAS= ;;
@@ -10636,7 +10637,7 @@
echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:10640: checking for location of BLAS includes" >&5
+echo "configure:10641: checking for location of BLAS includes" >&5
case "$with_blas_includes" in
{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -10656,7 +10657,7 @@
echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:10660: checking for location of BLAS library" >&5
+echo "configure:10661: checking for location of BLAS library" >&5
case "$with_blas_libs" in
{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -10682,15 +10683,15 @@
do
-echo "configure:10686: checking for $ac_hdr" >&5
+echo "configure:10687: checking for $ac_hdr" >&5
-#line 10689 "configure"
+#line 10690 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:10694: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10695: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -10725,13 +10726,13 @@
echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:10729: checking for dnrm2_ in -lblas" >&5
+echo "configure:10730: checking for dnrm2_ in -lblas" >&5
ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $MATHLIB $LIBS"
-#line 10735 "configure"
+#line 10736 "configure"
@@ -10742,7 +10743,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10746: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10747: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10761,13 +10762,13 @@
echo "$ac_t""no" 1>&6
-echo "configure:10765: checking for dnrm2_ in -lblas" >&5
+echo "configure:10766: checking for dnrm2_ in -lblas" >&5
LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 10771 "configure"
+#line 10772 "configure"
@@ -10778,7 +10779,7 @@
dnrm2_()
; return 0; }
EOF
-if { (eval echo configure:10782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10783: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10822,13 +10823,13 @@
save_LDFLAGS="$LDFLAGS"
LDFLAGS="$BLASLIB $LDFLAGS"
echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:10826: checking for ATL_xerbla in -latlas" >&5
+echo "configure:10827: checking for ATL_xerbla in -latlas" >&5
ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
LIBS="-latlas $LIBS"
-#line 10832 "configure"
+#line 10833 "configure"
@@ -10839,7 +10840,7 @@
ATL_xerbla()
; return 0; }
EOF
-if { (eval echo configure:10843: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10844: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10854,13 +10855,13 @@
if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
echo "$ac_t""yes" 1>&6
echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:10858: checking for sgemm_ in -lf77blas" >&5
+echo "configure:10859: checking for sgemm_ in -lf77blas" >&5
ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lf77blas -latlas $LIBS"
-#line 10864 "configure"
+#line 10865 "configure"
@@ -10871,7 +10872,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10875: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10876: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10886,13 +10887,13 @@
echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:10890: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:10891: checking for cblas_dgemm in -lcblas" >&5
ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 10896 "configure"
+#line 10897 "configure"
@@ -10903,7 +10904,7 @@
cblas_dgemm()
; return 0; }
EOF
-if { (eval echo configure:10907: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10908: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -10949,16 +10950,16 @@
save_LIBS="$LIBS"
LIBS="$vlib_flags $LIBS"
echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:10953: checking for sgemm in $vlib_flags" >&5
+echo "configure:10954: checking for sgemm in $vlib_flags" >&5
-#line 10955 "configure"
+#line 10956 "configure"
int main() {
sgemm
; return 0; }
EOF
-if { (eval echo configure:10962: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10963: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
blas_ok=yes; BLASLIB="$vlib_flags"
else
@@ -10976,13 +10977,13 @@
# BLAS in PhiPACK libraries? (requires generic BLAS, too)
if test $blas_ok = no; then
echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:10980: checking for sgemm_ in -lblas" >&5
+echo "configure:10981: checking for sgemm_ in -lblas" >&5
ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lblas $LIBS"
-#line 10986 "configure"
+#line 10987 "configure"
@@ -10993,7 +10994,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:10997: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10998: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11008,13 +11009,13 @@
echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:11012: checking for dgemm_ in -ldgemm" >&5
+echo "configure:11013: checking for dgemm_ in -ldgemm" >&5
ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
LIBS="-ldgemm -lblas $LIBS"
-#line 11018 "configure"
+#line 11019 "configure"
@@ -11025,7 +11026,7 @@
dgemm_()
; return 0; }
EOF
-if { (eval echo configure:11029: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11030: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11040,13 +11041,13 @@
echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:11044: checking for sgemm_ in -lsgemm" >&5
+echo "configure:11045: checking for sgemm_ in -lsgemm" >&5
ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsgemm -lblas $LIBS"
-#line 11050 "configure"
+#line 11051 "configure"
@@ -11057,7 +11058,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11062: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11091,13 +11092,13 @@
if test "x$GCC" != xyes; then # only works with Sun CC
echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:11095: checking for acosp in -lsunmath" >&5
+echo "configure:11096: checking for acosp in -lsunmath" >&5
ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
LIBS="-lsunmath $LIBS"
-#line 11101 "configure"
+#line 11102 "configure"
@@ -11108,7 +11109,7 @@
acosp()
; return 0; }
EOF
-if { (eval echo configure:11112: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11113: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11123,13 +11124,13 @@
echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:11127: checking for sgemm_ in -lsunperf" >&5
+echo "configure:11128: checking for sgemm_ in -lsunperf" >&5
ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
LIBS="-lsunperf -lsunmath $LIBS"
-#line 11133 "configure"
+#line 11134 "configure"
@@ -11140,7 +11141,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11144: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11145: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11170,13 +11171,13 @@
# Generic BLAS library
-echo "configure:11174: checking for sgemm_ in -lblas" >&5
+echo "configure:11175: checking for sgemm_ in -lblas" >&5
LIBS="-lblas $LIBS"
-#line 11180 "configure"
+#line 11181 "configure"
@@ -11187,7 +11188,7 @@
sgemm_()
; return 0; }
EOF
-if { (eval echo configure:11191: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11192: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11226,7 +11227,7 @@
echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:11230: checking whether to use LAPACK" >&5
+echo "configure:11231: checking whether to use LAPACK" >&5
echo "$ac_t"""$with_lapack"" 1>&6
case "$with_lapack" in
"no") USE_LAPACK= ;;
@@ -11251,7 +11252,7 @@
echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:11255: checking for location of LAPACK includes" >&5
+echo "configure:11256: checking for location of LAPACK includes" >&5
case "$with_lapack_includes" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -11271,7 +11272,7 @@
echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:11275: checking for location of LAPACK library" >&5
+echo "configure:11276: checking for location of LAPACK library" >&5
case "$with_lapack_libs" in
{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -11297,15 +11298,15 @@
do
-echo "configure:11301: checking for $ac_hdr" >&5
+echo "configure:11302: checking for $ac_hdr" >&5
-#line 11304 "configure"
+#line 11305 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11309: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11310: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11337,10 +11338,10 @@
save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:11341: checking for dsegv_" >&5
+echo "configure:11342: checking for dsegv_" >&5
-#line 11344 "configure"
+#line 11345 "configure"
which can conflict with char dsegv_(); below. */
@@ -11363,7 +11364,7 @@
; return 0; }
EOF
-if { (eval echo configure:11367: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_dsegv_=yes"
else
@@ -11390,13 +11391,13 @@
save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11394: checking for desgv_ in -llapack" >&5
+echo "configure:11395: checking for desgv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $FLIBS $LIBS"
-#line 11400 "configure"
+#line 11401 "configure"
@@ -11407,7 +11408,7 @@
desgv_()
; return 0; }
EOF
-if { (eval echo configure:11411: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11412: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11439,13 +11440,13 @@
echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:11443: checking for dgesv_ in -llapack" >&5
+echo "configure:11444: checking for dgesv_ in -llapack" >&5
ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
LIBS="-llapack $BLASLIB $MATHLIB $LIBS"
-#line 11449 "configure"
+#line 11450 "configure"
@@ -11456,7 +11457,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11460: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11475,13 +11476,13 @@
-echo "configure:11479: checking for dgesv_ in -llapack" >&5
+echo "configure:11480: checking for dgesv_ in -llapack" >&5
LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 11485 "configure"
+#line 11486 "configure"
@@ -11492,7 +11493,7 @@
dgesv_()
; return 0; }
EOF
-if { (eval echo configure:11496: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -11548,7 +11549,7 @@
echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:11552: checking whether to use Cairo" >&5
+echo "configure:11553: checking whether to use Cairo" >&5
echo "$ac_t"""$with_cairo"" 1>&6
case "$with_cairo" in
"no") USE_CAIRO= ;;
@@ -11580,7 +11581,7 @@
echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:11584: checking for location of cairo includes" >&5
+echo "configure:11585: checking for location of cairo includes" >&5
case "$with_cairo_includes" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -11606,15 +11607,15 @@
do
-echo "configure:11610: checking for $ac_hdr" >&5
+echo "configure:11611: checking for $ac_hdr" >&5
-#line 11613 "configure"
+#line 11614 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11618: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11619: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11650,7 +11651,7 @@
echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:11654: checking for location of cairo library" >&5
+echo "configure:11655: checking for location of cairo library" >&5
case "$with_cairo_libs" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -11670,7 +11671,7 @@
echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:11674: checking for cairo linking flags" >&5
+echo "configure:11675: checking for cairo linking flags" >&5
case "$with_cairo_ldflags" in
{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -11686,10 +11687,10 @@
LIBS=" $CAIROLIB $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:11690: checking for cairo_create" >&5
+echo "configure:11691: checking for cairo_create" >&5
-#line 11693 "configure"
+#line 11694 "configure"
which can conflict with char cairo_create(); below. */
@@ -11712,7 +11713,7 @@
; return 0; }
EOF
-if { (eval echo configure:11716: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11717: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_create=yes"
else
@@ -11746,10 +11747,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:11750: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:11751: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 11753 "configure"
+#line 11754 "configure"
which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below. */
@@ -11772,7 +11773,7 @@
; return 0; }
EOF
-if { (eval echo configure:11776: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11777: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
else
@@ -11805,10 +11806,10 @@
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
-echo "configure:11809: checking for cairo_xlib_surface_get_xrender_format" >&5
+echo "configure:11810: checking for cairo_xlib_surface_get_xrender_format" >&5
-#line 11812 "configure"
+#line 11813 "configure"
which can conflict with char cairo_xlib_surface_get_xrender_format(); below. */
@@ -11831,7 +11832,7 @@
; return 0; }
EOF
-if { (eval echo configure:11835: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
else
@@ -11873,7 +11874,7 @@
echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:11877: checking whether to use FreeType" >&5
+echo "configure:11878: checking whether to use FreeType" >&5
echo "$ac_t"""$with_freetype"" 1>&6
case "$with_freetype" in
"no") USE_FREETYPE= ;;
@@ -11892,7 +11893,7 @@
echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:11896: checking for location of FreeType includes" >&5
+echo "configure:11897: checking for location of FreeType includes" >&5
case "$with_freetype_includes" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -11918,15 +11919,15 @@
do
-echo "configure:11922: checking for $ac_hdr" >&5
+echo "configure:11923: checking for $ac_hdr" >&5
-#line 11925 "configure"
+#line 11926 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:11930: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11931: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -11960,7 +11961,7 @@
echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:11964: checking for location of FreeType library" >&5
+echo "configure:11965: checking for location of FreeType library" >&5
case "$with_freetype_libs" in
{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -11985,13 +11986,13 @@
echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:11989: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:11990: checking for FT_Init_FreeType in -lfreetype" >&5
ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
LIBS="-lfreetype $LIBS"
-#line 11995 "configure"
+#line 11996 "configure"
@@ -12002,7 +12003,7 @@
FT_Init_FreeType()
; return 0; }
EOF
-if { (eval echo configure:12006: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12007: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12043,7 +12044,7 @@
echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:12047: checking whether to use NLS" >&5
+echo "configure:12048: checking whether to use NLS" >&5
echo "$ac_t"""$with_nls"" 1>&6
case "$with_nls" in
"no") USE_NLS= ;;
@@ -12063,10 +12064,10 @@
echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:12067: checking for gettext" >&5
+echo "configure:12068: checking for gettext" >&5
-#line 12070 "configure"
+#line 12071 "configure"
which can conflict with char gettext(); below. */
@@ -12089,7 +12090,7 @@
; return 0; }
EOF
-if { (eval echo configure:12093: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12094: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_gettext=yes"
else
@@ -12107,13 +12108,13 @@
echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:12111: checking for gettext in -lintl" >&5
+echo "configure:12112: checking for gettext in -lintl" >&5
ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
LIBS="-lintl $LIBS"
-#line 12117 "configure"
+#line 12118 "configure"
@@ -12124,7 +12125,7 @@
gettext()
; return 0; }
EOF
-if { (eval echo configure:12128: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12129: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12159,7 +12160,7 @@
echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:12163: checking whether to use C++" >&5
+echo "configure:12164: checking whether to use C++" >&5
echo "$ac_t"""$with_cxx"" 1>&6
case "$with_cxx" in
"no") USE_CXX= ;;
@@ -12175,7 +12176,7 @@
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
-echo "configure:12179: checking for $ac_word" >&5
+echo "configure:12180: checking for $ac_word" >&5
if test -n "$CXX"; then
ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -12204,7 +12205,7 @@
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:12208: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:12209: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
ac_ext=C
# CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -12215,12 +12216,12 @@
cat > conftest.$ac_ext << EOF
-#line 12219 "configure"
+#line 12220 "configure"
int main(){return(0);}
EOF
-if { (eval echo configure:12224: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12225: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
ac_cv_prog_cxx_works=yes
# If we can't run a trivial program, we are probably using a cross compiler.
if (./conftest; exit) 2>/dev/null; then
@@ -12246,19 +12247,19 @@
{ echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
fi
echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:12250: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:12251: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
cross_compiling=$ac_cv_prog_cxx_cross
echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:12255: checking whether we are using GNU C++" >&5
+echo "configure:12256: checking whether we are using GNU C++" >&5
cat > conftest.C <<EOF
#ifdef __GNUC__
yes;
#endif
EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12262: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:12263: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
ac_cv_prog_gxx=yes
else
ac_cv_prog_gxx=no
@@ -12276,7 +12277,7 @@
ac_save_CXXFLAGS="$CXXFLAGS"
CXXFLAGS=
echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:12280: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:12281: checking whether ${CXX-g++} accepts -g" >&5
echo 'void f(){}' > conftest.cc
if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -12317,7 +12318,7 @@
echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:12321: checking whether to use openDWG" >&5
+echo "configure:12322: checking whether to use openDWG" >&5
echo "$ac_t"""$with_opendwg"" 1>&6
case "$with_opendwg" in
"no") USE_OPENDWG= ;;
@@ -12337,7 +12338,7 @@
echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:12341: checking for location of openDGW includes" >&5
+echo "configure:12342: checking for location of openDGW includes" >&5
case "$with_opendwg_includes" in
y | ye | yes | n | no)
{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -12363,15 +12364,15 @@
do
-echo "configure:12367: checking for $ac_hdr" >&5
+echo "configure:12368: checking for $ac_hdr" >&5
cat > conftest.$ac_ext <<EOF
-#line 12370 "configure"
+#line 12371 "configure"
#include "confdefs.h"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12375: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12376: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12405,7 +12406,7 @@
echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:12409: checking for location of openDWG library" >&5
+echo "configure:12410: checking for location of openDWG library" >&5
case "$with_opendwg_libs" in
{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -12446,7 +12447,7 @@
echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:12450: checking whether to use POSIX threads" >&5
+echo "configure:12451: checking whether to use POSIX threads" >&5
echo "$ac_t"""$with_pthread"" 1>&6
case "$with_pthread" in
"no") USE_PTHREAD= ;;
@@ -12466,7 +12467,7 @@
echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:12470: checking for location of POSIX threads includes" >&5
+echo "configure:12471: checking for location of POSIX threads includes" >&5
case "$with_pthread_includes" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -12492,15 +12493,15 @@
do
-echo "configure:12496: checking for $ac_hdr" >&5
+echo "configure:12497: checking for $ac_hdr" >&5
-#line 12499 "configure"
+#line 12500 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:12504: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12505: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
@@ -12534,7 +12535,7 @@
echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:12538: checking for location of POSIX threads library" >&5
+echo "configure:12539: checking for location of POSIX threads library" >&5
case "$with_pthread_libs" in
{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -12559,10 +12560,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:12563: checking for pthread_create" >&5
+echo "configure:12564: checking for pthread_create" >&5
-#line 12566 "configure"
+#line 12567 "configure"
which can conflict with char pthread_create(); below. */
@@ -12585,7 +12586,7 @@
; return 0; }
EOF
-if { (eval echo configure:12589: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12590: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_pthread_create=yes"
else
@@ -12612,13 +12613,13 @@
echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:12616: checking for pthread_create in -lpthread" >&5
+echo "configure:12617: checking for pthread_create in -lpthread" >&5
ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
ac_save_LIBS="$LIBS"
LIBS="-lpthread $LIBS"
-#line 12622 "configure"
+#line 12623 "configure"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
@@ -12629,7 +12630,7 @@
pthread_create()
; return 0; }
EOF
-if { (eval echo configure:12633: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12634: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_lib_$ac_lib_var=yes"
else
@@ -12679,7 +12680,7 @@
echo $ac_n "checking whether to use OpenMP""... $ac_c" 1>&6
-echo "configure:12683: checking whether to use OpenMP" >&5
+echo "configure:12684: checking whether to use OpenMP" >&5
echo "$ac_t"""$with_openmp"" 1>&6
case "$with_openmp" in
"no") USE_OPENMP= ;;
@@ -12700,7 +12701,7 @@
echo $ac_n "checking for location of OpenMP includes""... $ac_c" 1>&6
-echo "configure:12704: checking for location of OpenMP includes" >&5
+echo "configure:12705: checking for location of OpenMP includes" >&5
case "$with_openmp_includes" in
{ echo "configure: error: *** You must supply a directory to --with-openmp-includes." 1>&2; exit 1; }
@@ -12726,15 +12727,15 @@
do
-echo "configure:12730: checking for $ac_hdr" >&5
+echo "configure:12731: checking for $ac_hdr" >&5
-#line 12733 "configure"
+#line 12734 "configure"
#include <$ac_hdr>
EOF
ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:12738: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12739: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
if test -z "$ac_err"; then
rm -rf conftest*
@@ -12772,7 +12773,7 @@
echo $ac_n "checking for location of OpenMP library""... $ac_c" 1>&6
-echo "configure:12776: checking for location of OpenMP library" >&5
+echo "configure:12777: checking for location of OpenMP library" >&5
case "$with_gomp_libs" in
{ echo "configure: error: *** You must supply a directory to --with-gomp-libs." 1>&2; exit 1; }
@@ -12797,10 +12798,10 @@
LIBS=" $LIBS"
LDFLAGS=" $LDFLAGS"
echo $ac_n "checking for GOMP_parallel_start""... $ac_c" 1>&6
-echo "configure:12801: checking for GOMP_parallel_start" >&5
+echo "configure:12802: checking for GOMP_parallel_start" >&5
-#line 12804 "configure"
+#line 12805 "configure"
which can conflict with char GOMP_parallel_start(); below. */
@@ -12823,7 +12824,7 @@
; return 0; }
EOF
-if { (eval echo configure:12827: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12828: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
eval "ac_cv_func_GOMP_parallel_start=yes"
else
@@ -12850,13 +12851,13 @@
echo $ac_n "checking for GOMP_parallel_start in -lgomp""... $ac_c" 1>&6
-echo "configure:12854: checking for GOMP_parallel_start in -lgomp" >&5
+echo "configure:12855: checking for GOMP_parallel_start in -lgomp" >&5
ac_lib_var=`echo gomp'_'GOMP_parallel_start | sed 'y%./+-%__p_%'`
LIBS="-lgomp $LIBS"
-#line 12860 "configure"
+#line 12861 "configure"
@@ -12867,7 +12868,7 @@
; return 0; }
EOF
-if { (eval echo configure:12871: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
else
@@ -12946,7 +12947,7 @@
if test "$enable_largefile" = yes; then
echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:12950: checking for special C compiler options needed for large files" >&5
+echo "configure:12951: checking for special C compiler options needed for large files" >&5
ac_cv_sys_largefile_CC=no
largefile_cc_opt=""
@@ -12954,7 +12955,7 @@
# IRIX 6.2 and later do not support large files by default,
# so use the C compiler's -n32 option if that helps.
-#line 12958 "configure"
+#line 12959 "configure"
#include <sys/types.h>
/* Check that off_t can represent 2**63 - 1 correctly.
@@ -12970,7 +12971,7 @@
; return 0; }
EOF
-if { (eval echo configure:12974: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:12975: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
echo "configure: failed program was:" >&5
@@ -12979,7 +12980,7 @@
ac_save_CC="${CC-cc}"
CC="$CC -n32"
-#line 12983 "configure"
+#line 12984 "configure"
@@ -12995,7 +12996,7 @@
; return 0; }
EOF
-if { (eval echo configure:12999: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13000: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_CC=' -n32'
else
@@ -13015,11 +13016,11 @@
fi
echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:13019: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:13020: checking for _FILE_OFFSET_BITS value needed for large files" >&5
ac_cv_sys_file_offset_bits=no
-#line 13023 "configure"
+#line 13024 "configure"
@@ -13035,14 +13036,14 @@
; return 0; }
EOF
-if { (eval echo configure:13039: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13040: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
cat conftest.$ac_ext >&5
rm -rf conftest*
-#line 13046 "configure"
+#line 13047 "configure"
#define _FILE_OFFSET_BITS 64
@@ -13060,7 +13061,7 @@
; return 0; }
EOF
-if { (eval echo configure:13064: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13065: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_file_offset_bits=64
else
@@ -13079,11 +13080,11 @@
fi
echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:13083: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:13084: checking for _LARGE_FILES value needed for large files" >&5
ac_cv_sys_large_files=no
-#line 13087 "configure"
+#line 13088 "configure"
@@ -13099,14 +13100,14 @@
; return 0; }
EOF
-if { (eval echo configure:13103: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13104: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13110 "configure"
+#line 13111 "configure"
#define _LARGE_FILES 1
@@ -13124,7 +13125,7 @@
; return 0; }
EOF
-if { (eval echo configure:13128: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13129: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_large_files=1
else
@@ -13143,25 +13144,25 @@
fi
echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:13147: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13148: checking for _LARGEFILE_SOURCE value needed for large files" >&5
ac_cv_sys_largefile_source=no
-#line 13151 "configure"
+#line 13152 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13158: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13159: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13165 "configure"
+#line 13166 "configure"
#define _LARGEFILE_SOURCE 1
#include <stdio.h>
@@ -13170,7 +13171,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13174: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13175: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_sys_largefile_source=1
else
@@ -13191,25 +13192,25 @@
fi
-echo "configure:13195: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:13196: checking for _LARGEFILE_SOURCE value needed for large files" >&5
-#line 13199 "configure"
+#line 13200 "configure"
#include <stdio.h>
int main() {
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13206: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13207: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
else
rm -rf conftest*
-#line 13213 "configure"
+#line 13214 "configure"
#include <stdio.h>
@@ -13218,7 +13219,7 @@
return !fseeko;
; return 0; }
EOF
-if { (eval echo configure:13222: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13223: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
else
@@ -13241,18 +13242,18 @@
# If you want fseeko and ftello with glibc, upgrade to a fixed glibc.
echo $ac_n "checking for fseeko""... $ac_c" 1>&6
-echo "configure:13245: checking for fseeko" >&5
+echo "configure:13246: checking for fseeko" >&5
ac_cv_func_fseeko=no
-#line 13249 "configure"
+#line 13250 "configure"
#include <stdio.h>
int main() {
return fseeko && fseeko (stdin, 0, 0);
; return 0; }
EOF
-if { (eval echo configure:13256: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
rm -rf conftest*
ac_cv_func_fseeko=yes
else
@@ -13269,10 +13270,10 @@
fi
echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:13273: checking if system supports Large Files at all" >&5
+echo "configure:13274: checking if system supports Large Files at all" >&5
-#line 13276 "configure"
+#line 13277 "configure"
#include <stdio.h>
@@ -13304,7 +13305,7 @@
#endif
; return 0; }
EOF
-if { (eval echo configure:13308: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:13309: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
rm -rf conftest*
ac_cv_largefiles=yes
else
@@ -13333,7 +13334,7 @@
# Enable wxWidgets support (for wxGUI)
echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:13337: checking whether to use wxWidgets" >&5
+echo "configure:13338: checking whether to use wxWidgets" >&5
WXVERSION=
WXWIDGETSCXXFLAGS=
@@ -13354,7 +13355,7 @@
# Extract the first word of "wx-config", so it can be a program name with args.
set dummy wx-config; ac_word=$2
echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:13358: checking for $ac_word" >&5
+echo "configure:13359: checking for $ac_word" >&5
case "$WX_CONFIG" in
@@ -13402,7 +13403,7 @@
REQWX="2.8.1"
echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:13406: checking wxWidgets version" >&5
+echo "configure:13407: checking wxWidgets version" >&5
if WXVERSION=`"$WX_CONFIG" --version`; then
echo "$ac_t""$WXVERSION" 1>&6
else
@@ -13425,15 +13426,15 @@
do
ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13429: checking for $ac_hdr" >&5
+echo "configure:13430: checking for $ac_hdr" >&5
-#line 13432 "configure"
+#line 13433 "configure"
#include <$ac_hdr>
EOF
-{ (eval echo configure:13437: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13438: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
rm -rf conftest*
