[GRASS-SVN] r54196 - in grass/trunk: lib/python/temporal temporal/t.create temporal/t.sample
svn_grass at osgeo.org
Wed Dec 5 02:42:09 PST 2012
Author: huhabla
Date: 2012-12-05 02:42:08 -0800 (Wed, 05 Dec 2012)
New Revision: 54196
grass/trunk/lib/python/temporal/space_time_datasets_tools.py
grass/trunk/temporal/t.create/t.create.py
grass/trunk/temporal/t.sample/t.sample.py
grass/trunk/temporal/t.sample/test.t.sample.sh
Temporal sampling method now returns the map matrix.
Sampling was moved from t.sample into the temporal library.
STDS creation was moved from t.create into the temporal library.
Modified: grass/trunk/lib/python/temporal/space_time_datasets_tools.py
--- grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-12-05 10:18:06 UTC (rev 54195)
+++ grass/trunk/lib/python/temporal/space_time_datasets_tools.py 2012-12-05 10:42:08 UTC (rev 54196)
@@ -606,9 +606,12 @@
-def sample_stds_by_stds_topology(intype, sampletype, inputs, sampler, header, separator, method, spatial=False):
+def sample_stds_by_stds_topology(intype, sampletype, inputs, sampler, header,
+ separator, method, spatial=False,
+ print_only=True):
"""!Sample the input space time datasets with a sample
- space time dataset and print the result to stdout
+ space time dataset, return the created map matrix and optionally
+ print the result to stdout
In case multiple maps are located in the current granule,
the map names are separated by comma.
@@ -616,20 +619,29 @@
In case a layer is present, the names map ids are extended
in this form: name:layer at mapset
- Attention: Do not use the comma as separator
+ Attention: Do not use the comma as separator for printing
@param intype: Type of the input space time dataset (strds, stvds or str3ds)
@param samtype: Type of the sample space time dataset (strds, stvds or str3ds)
- @param input: Name of a space time dataset
+ @param inputs: Name or comma separated names of space time datasets
@param sampler: Name of a space time dataset used for temporal sampling
@param header: Set True to print column names
@param separator: The field separator character between the columns
@param method: The method to be used for temporal sampling
(start,during,contain,overlap,equal)
@param spatial: Perform spatial overlapping check
+ @param print_only: If set True (default) then the result of the sampling will be
+ printed to stdout, if set to False the resulting map matrix
+ will be returned.
+ @return The map matrix or None if nothing found
mapset = core.gisenv()["MAPSET"]
+ # Make a method list
+ method = method.split(",")
+ # Split the inputs
input_list = inputs.split(",")
sts = []
@@ -672,6 +684,11 @@
mapmatrizes.append(mapmatrix)
if len(mapmatrizes) > 0:
+ # Simply return the map matrix
+ if not print_only:
+ dbif.close()
+ return mapmatrizes
if header:
string = ""
@@ -726,6 +743,10 @@
print string
dbif.close()
+ if len(mapmatrizes) > 0:
+ return None
@@ -821,3 +842,60 @@
return output
+def create_space_time_dataset(name, type, temporaltype, title, descr, semantic,
+ dbif=None, overwrite=False):
+ """!Create a new space time dataset
+ This function is sensitive to the settings in grass.core.overwrite to
+ overwrute existing space time datasets.
+ @param name: The name of the new space time dataset
+ @param type: The type (strds, stvds, str3ds) of the new space time dataset
+ @param temporaltype: The temporal type (relative or absolute)
+ @param title: The title
+ @param descr: The dataset description
+ @param semantic: Semantical information
+ @param dbif: The temporal database interface to be used
+ @return The new created space time dataset
+ This function will raise a ScriptError in case of an error.
+ #Get the current mapset to create the id of the space time dataset
+ mapset = core.gisenv()["MAPSET"]
+ id = name + "@" + mapset
+ sp = dataset_factory(type, id)
+ dbif, connect = init_dbif(dbif)
+ if sp.is_in_db(dbif) and overwrite == False:
+ if connect:
+ dbif.close()
+ core.fatal(_("Space time %s dataset <%s> is already in the database. "
+ "Use the overwrite flag.") %
+ (sp.get_new_map_instance(None).get_type(), name))
+ return None
+ if sp.is_in_db(dbif) and overwrite == True:
+ core.info(_("Overwrite space time %s dataset <%s> "
+ "and unregister all maps.") %
+ sp.delete(dbif)
+ sp = sp.get_new_instance(id)
+ core.verbose(_("Create space time %s dataset.") %
+ sp.get_new_map_instance(None).get_type())
+ sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
+ title=title, description=descr)
+ sp.insert(dbif)
+ if connect:
+ dbif.close()
+ return sp
Modified: grass/trunk/temporal/t.create/t.create.py
--- grass/trunk/temporal/t.create/t.create.py 2012-12-05 10:18:06 UTC (rev 54195)
+++ grass/trunk/temporal/t.create/t.create.py 2012-12-05 10:42:08 UTC (rev 54196)
@@ -75,38 +75,9 @@
tgis.init()
- #Get the current mapset to create the id of the space time dataset
+ tgis.create_space_time_dataset(name, type, temporaltype, title, descr,
+ semantic, None, grass.overwrite())
- mapset = grass.gisenv()["MAPSET"]
- id = name + "@" + mapset
- sp = tgis.dataset_factory(type, id)
- dbif = tgis.SQLDatabaseInterfaceConnection()
- dbif.connect()
- if sp.is_in_db(dbif) and grass.overwrite() == False:
- dbif.close()
- grass.fatal(_("Space time %s dataset <%s> is already in the database. "
- "Use the overwrite flag.") %
- (sp.get_new_map_instance(None).get_type(), name))
- if sp.is_in_db(dbif) and grass.overwrite() == True:
- grass.info(_("Overwrite space time %s dataset <%s> "
- "and unregister all maps.") %
- sp.delete(dbif)
- sp = sp.get_new_instance(id)
- grass.verbose(_("Create space time %s dataset.") %
- sp.get_new_map_instance(None).get_type())
- sp.set_initial_values(temporal_type=temporaltype, semantic_type=semantic,
- title=title, description=descr)
- sp.insert(dbif)
- dbif.close()
if __name__ == "__main__":
options, flags = grass.parser()
main()
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py 2012-12-05 10:18:06 UTC (rev 54195)
+++ grass/trunk/temporal/t.sample/t.sample.py 2012-12-05 10:42:08 UTC (rev 54196)
@@ -77,14 +77,12 @@
method = options["method"]
header = flags["c"]
spatial = flags["s"]
- method = method.split(",")
# Make sure the temporal database exists
tgis.init()
tgis.sample_stds_by_stds_topology(intype, samtype, inputs, sampler,
- header, separator, method, spatial)
+ header, separator, method, spatial, True)
Modified: grass/trunk/temporal/t.sample/test.t.sample.sh
--- grass/trunk/temporal/t.sample/test.t.sample.sh 2012-12-05 10:18:06 UTC (rev 54195)
+++ grass/trunk/temporal/t.sample/test.t.sample.sh 2012-12-05 10:42:08 UTC (rev 54196)
@@ -51,15 +51,18 @@
EOF
-t.create --o type=strds temporaltype=absolute output=precip_abs0 title="A test with raster input files" descr="A test with raster input files"
-t.create --o type=stvds temporaltype=absolute output=pnts_abs0 title="A test with vector input files" descr="A test with vector input files"
-t.create --o type=stvds temporaltype=absolute output=pnts_abs1 title="A test with vector input files" descr="A test with vector input files"
+t.create --o type=strds temporaltype=absolute output=precip_abs0 \
+ title="A test with raster input files" descr="A test with raster input files"
+t.create --o type=stvds temporaltype=absolute output=pnts_abs0 \
+ title="A test with vector input files" descr="A test with vector input files"
+t.create --o type=stvds temporaltype=absolute output=pnts_abs1 \
-t.register type=rast -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
+t.register --o type=rast -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
t.rast.list precip_abs0 -h
-t.register type=vect input=pnts_abs0 file="${n2}" start=file end=file
+t.register --o type=vect input=pnts_abs0 file="${n2}"
t.vect.list pnts_abs0 -h
-t.register type=vect input=pnts_abs1 file="${n3}" start=file end=file
+t.register --o type=vect input=pnts_abs1 file="${n3}"
t.vect.list pnts_abs1 -h
# The @test
@@ -74,7 +77,7 @@
# Test with temporal point data
-t.register type=rast input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
+t.register --o type=rast input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
t.sample input=precip_abs0 samtype=stvds sample=pnts_abs0 -cs
t.sample input=precip_abs0 samtype=stvds sample=pnts_abs1 -cs
