[GRASS-SVN] r54219 - in grass/trunk/gui/wxpython: core gmodeler
svn_grass at osgeo.org
Thu Dec 6 04:52:22 PST 2012
Author: martinl
Date: 2012-12-06 04:52:21 -0800 (Thu, 06 Dec 2012)
New Revision: 54219
grass/trunk/gui/wxpython/core/gcmd.py
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/gui/wxpython/core/workspace.py
grass/trunk/gui/wxpython/gmodeler/model.py
wxGUI: add GetDefaultEncoding
fix writing workspace and model file
Modified: grass/trunk/gui/wxpython/core/gcmd.py
--- grass/trunk/gui/wxpython/core/gcmd.py 2012-12-06 12:29:07 UTC (rev 54218)
+++ grass/trunk/gui/wxpython/core/gcmd.py 2012-12-06 12:52:21 UTC (rev 54219)
@@ -14,6 +14,7 @@
Functions:
- RunCommand
+ - GetDefaultEncoding
(C) 2007-2008, 2010-2011 by the GRASS Development Team
@@ -29,8 +30,8 @@
import time
import errno
import signal
+import traceback
import locale
-import traceback
import subprocess
if subprocess.mswindows:
from win32file import ReadFile, WriteFile
@@ -67,13 +68,8 @@
if not string:
return string
- try:
- enc = locale.getdefaultlocale()[1]
- except ValueError, e:
- sys.stderr.write(_("ERROR: %s\n") % str(e))
- return string
+ enc = GetDefaultEncoding()
if enc:
Debug.msg(5, "DecodeString(): enc=%s" % enc)
return string.decode(enc)
@@ -89,7 +85,8 @@
if not string:
return string
if enc:
Debug.msg(5, "EncodeString(): enc=%s" % enc)
return string.encode(enc)
@@ -467,14 +464,13 @@
"""!Get error message or ''"""
if not self.cmdThread.module:
return _("Unable to exectute command: '%s'") % ' '.join(self.cmd)
for type, msg in self.__ProcessStdErr():
if type == 'ERROR':
if enc:
return unicode(msg, enc)
- else:
- return msg
+ return msg
return ''
@@ -704,3 +700,17 @@
Debug.msg(2, "gcmd.RunCommand(): return result")
return stdout, _formatMsg(stderr)
+def GetDefaultEncoding(forceUTF8 = False):
+ """!Get default system encoding
+ @param forceUTF8 return UTF8 when encoding is not defined
+ @return system encoding (can be None)
+ enc = locale.getdefaultlocale()[1]
+ if forceUTF8 and (enc is None or enc != 'UTF8'):
+ return 'UTF-8'
+ Debug.msg(1, "GetSystemEncoding(): %s" % enc)
+ return enc
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2012-12-06 12:29:07 UTC (rev 54218)
+++ grass/trunk/gui/wxpython/core/utils.py 2012-12-06 12:52:21 UTC (rev 54219)
@@ -3,7 +3,7 @@
@brief Misc utilities for wxGUI
-(C) 2007-2009, 2011 by the GRASS Development Team
+(C) 2007-2009, 2011-2012 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py 2012-12-06 12:29:07 UTC (rev 54218)
+++ grass/trunk/gui/wxpython/core/workspace.py 2012-12-06 12:52:21 UTC (rev 54219)
@@ -17,13 +17,12 @@
import os
-import locale
import wx
from core.utils import normalize_whitespace
from core.settings import UserSettings
-from core.gcmd import EncodeString
+from core.gcmd import EncodeString, GetDefaultEncoding
from nviz.main import NvizSettings
class ProcessWorkspaceFile:
@@ -562,8 +561,8 @@
self.indent = 0
# write header
- self.file.write('<?xml version="1.0" encoding="%s"?>\n' % enc)
+ self.file.write('<?xml version="1.0" encoding="%s"?>\n' % GetDefaultEncoding(forceUTF8 = True))
self.file.write('<!DOCTYPE gxw SYSTEM "grass-gxw.dtd">\n')
self.file.write('%s<gxw>\n' % (' ' * self.indent))
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2012-12-06 12:29:07 UTC (rev 54218)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2012-12-06 12:52:21 UTC (rev 54219)
@@ -31,7 +31,6 @@
import re
import mimetypes
import time
-import locale
try:
import xml.etree.ElementTree as etree
except ImportError:
@@ -42,7 +41,7 @@
from core import globalvar
from core import utils
-from core.gcmd import GMessage, GException, GError, RunCommand, EncodeString, GWarning
+from core.gcmd import GMessage, GException, GError, RunCommand, EncodeString, GWarning, GetDefaultEncoding
from gui_core.forms import GUI, CmdPanel
from gui_core.widgets import GNotebook
@@ -1779,8 +1778,7 @@
def _header(self):
"""!Write header"""
- self.fd.write('<?xml version="1.0" encoding="%s"?>\n' % enc)
+ self.fd.write('<?xml version="1.0" encoding="%s"?>\n' % GetDefaultEncoding(forceUTF8 = True))
self.fd.write('<!DOCTYPE gxm SYSTEM "grass-gxm.dtd">\n')
self.fd.write('%s<gxm>\n' % (' ' * self.indent))
self.indent += 4
