[GRASS-SVN] r54243 - grass/trunk/gui/wxpython/dbmgr
Fri Dec 7 15:37:29 PST 2012
Author: martinl
Date: 2012-12-07 15:37:28 -0800 (Fri, 07 Dec 2012)
New Revision: 54243
Added:
   grass/trunk/gui/wxpython/dbmgr/dbmgr_frame.jpg
   grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html
wxGUI/dbmgr: update manual + add screenshot
Added: grass/trunk/gui/wxpython/dbmgr/dbmgr_frame.jpg
(Binary files differ)
Property changes on: grass/trunk/gui/wxpython/dbmgr/dbmgr_frame.jpg
___________________________________________________________________
Added: svn:mime-type
   + image/jpeg
Modified: grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html
--- grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html	2012-12-07 23:15:27 UTC (rev 54242)
+++ grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.html	2012-12-07 23:37:28 UTC (rev 54243)
@@ -2,20 +2,34 @@
 <!-- meta page index: wxGUI -->
 <h2>DESCRIPTION</h2>
+The <b>Attribute Table Manager</b> is
+a <em><a href="wxGUI.html">wxGUI</a></em> compoment to query, edit,
+and manage attribute data for vector maps. The attribute table manager
+can be launched by clicking on icon <img src="icons/table.png"
+alt="icon"> in the toolbar. It's also available as a stand-alone
+module <em>g.gui.dbmgr</em>.
+<p>
 <em>Attribute table manager</em> allows to:
 <ul>
-  <li>Browse attribute data of vector map, perform SQL select
-  statements</li>
-  <li>Modify attribute data, insert new records to attribute table,
-  delete existing records</li>
-  <li>Highlight selected items in the Map Display Window</li>
-  <li>Extract selected items into a new vector map</li>
-  <li>Modify attribute table - add, drop, rename columns</li>
-  <li>Modify vector map DB connection settings - add, remove or
-  modify layers</li>
+  <li>browse attribute data of vector map, perform SQL select
+  statements;</li>
+  <li>modify attribute data, insert new records to attribute table,
+  delete existing records;</li>
+  <li>highlight selected items in the Map Display Window;</li>
+  <li>extract selected items into a new vector map;</li>
+  <li>modify attribute table - add, drop, rename columns;</li>
+  <li>modify vector map DB connection settings - add, remove or
+  modify layers.</li>
 </ul>
+<center>
+<br>
+<img src="dbmgr_frame.jpg" border="1" alt="Attribute Table Manager">
+<br><br>
+</center>
 <h2>SEE ALSO</h2>
 <em>
