[GRASS-SVN] r54254 - grass/trunk/gui/wxpython/dbmgr
svn_grass at osgeo.org
Sun Dec 9 02:18:08 PST 2012
Author: martinl
Date: 2012-12-09 02:18:08 -0800 (Sun, 09 Dec 2012)
New Revision: 54254
grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
wxGUI/sqlbuilder: cosmetics
Modified: grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py
--- grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py 2012-12-08 19:36:06 UTC (rev 54253)
+++ grass/trunk/gui/wxpython/dbmgr/sqlbuilder.py 2012-12-09 10:18:08 UTC (rev 54254)
@@ -109,7 +109,7 @@
self.btn_clear = wx.Button(parent = self.panel, id = wx.ID_CLEAR)
self.btn_clear.SetToolTipString(_("Set SQL statement to default"))
self.btn_apply = wx.Button(parent = self.panel, id = wx.ID_APPLY)
- self.btn_apply.SetToolTipString(_("Apply SQL statement and close the dialog"))
+ self.btn_apply.SetToolTipString(_("Apply SQL statement in Attribute Table Manager"))
self.btn_close = wx.Button(parent = self.panel, id = wx.ID_CLOSE)
self.btn_close.SetToolTipString(_("Close the dialog"))
@@ -365,7 +365,7 @@
self.evtHandler = evtHandler
# set dialog title
- title = _("GRASS SQL Builder (%(type)s): vector map <%(map)s>") % \
+ title = _("GRASS SQL Builder (%(type)s) - <%(map)s>") % \
{ 'type' : "SELECT", 'map' : vectmap }
modeChoices = [_("Column to show (SELECT clause)"),
@@ -507,7 +507,7 @@
self.column = column
# set dialog title
{ 'type' : "UPDATE", 'map' : vectmap }
modeChoices = [_("Column to set (SET clause)"),
