[GRASS-SVN] r54258 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Dec 10 02:06:30 PST 2012
Author: martinl
Date: 2012-12-10 02:06:29 -0800 (Mon, 10 Dec 2012)
New Revision: 54258
grass/trunk/lib/vector/Vlib/remove_areas.c
Vect_remove_small_areas(): report number of removed areas on standard message level (it's quite important info)
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c 2012-12-09 20:13:28 UTC (rev 54257)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c 2012-12-10 10:06:29 UTC (rev 54258)
@@ -173,8 +173,8 @@
if (removed_area)
*removed_area = size_removed;
- G_verbose_message(_("%d areas of total size %g removed"), nremoved,
- size_removed);
+ G_message(_("%d areas of total size %g removed"), nremoved,
+ size_removed);
return (nremoved);
