[GRASS-SVN] r54270 - grass-addons/grass6/raster/r.basin
svn_grass at osgeo.org
Wed Dec 12 09:11:16 PST 2012
Author: madi
Date: 2012-12-12 09:11:15 -0800 (Wed, 12 Dec 2012)
New Revision: 54270
grass-addons/grass6/raster/r.basin/r.basin.py
added controls to check dependencies
Modified: grass-addons/grass6/raster/r.basin/r.basin.py
--- grass-addons/grass6/raster/r.basin/r.basin.py 2012-12-12 15:53:50 UTC (rev 54269)
+++ grass-addons/grass6/raster/r.basin/r.basin.py 2012-12-12 17:11:15 UTC (rev 54270)
@@ -141,7 +141,8 @@
th = options['threshold']
# Stream extraction
- grass.run_command('r.stream.extract', elevation = r_elevation,
+ try:
+ grass.run_command('r.stream.extract', elevation = r_elevation,
accumulation = r_accumulation,
threshold = th,
d8cut = 'infinity',
@@ -149,14 +150,20 @@
stream_rast = r_stream_e,
direction = r_drainage_e,
overwrite = True)
+ except:
+ grass.fatal("Some dependencies seem to be missing, please make sure that you have r.stream.* modules installed.")
try:
# Delineation of basin
- grass.run_command('r.stream.basins', dir = r_drainage,
+ try:
+ grass.run_command('r.stream.basins', dir = r_drainage,
basins = r_basin,
coors = '%s,%s' % (east , north),
overwrite = True)
+ except:
grass.message( "Delineation of basin done" )
# Mask and cropping
@@ -261,13 +268,18 @@
# Creation of order maps: strahler, horton, hack, shreeve
grass.message( "Creating %s" % r_hack )
- grass.run_command('r.stream.order', stream = r_stream_e,
+ try:
+ grass.run_command('r.stream.order', stream = r_stream_e,
dir = r_drainage_e,
strahler = r_strahler,
shreve = r_shreve,
horton = r_horton,
hack = r_hack,
overwrite = True)
+ except:
# Distance to outlet
grass.write_command('v.in.ascii', output = v_outlet,
@@ -282,30 +294,45 @@
value = 1,
rows = 4096,
overwrite = True)
- grass.run_command('r.stream.distance', stream = r_outlet,
+ try:
+ grass.run_command('r.stream.distance', stream = r_outlet,
dir = r_drainage,
flags = 'o',
distance = r_distance,
overwrite = True)
+ except:
# Ipsographic curve
grass.message( "##################################" )
- grass.run_command('r.ipso', map = 'r_elevation_crop',
+ try:
+ grass.run_command('r.ipso', map = 'r_elevation_crop',
image = prefix, flags = 'ab')
+ except:
+ grass.fatal("Some dependencies seem to be missing, please make sure that you have r.ipso installed.")
# Width Function
- grass.run_command('r.wf', map = r_distance,
+ try:
+ grass.run_command('r.wf', map = r_distance,
image = prefix)
+ except:
+ grass.fatal("Some dependencies seem to be missing, please make sure that you have r.wf installed.")
# Creation of map of hillslope distance to river network
- grass.run_command('r.stream.distance', stream = r_stream_e,
+ try:
+ grass.run_command('r.stream.distance', stream = r_stream_e,
dir = r_drainage,
dem = 'r_elevation_crop' ,
distance = r_hillslope_distance,
overwrite = True)
+ except:
# Mean elevation
grass.run_command('r.average' , base = r_basin,
@@ -479,9 +506,12 @@
FSF = magnitudo / area_basin
# Statistics
- stream_stats = grass.read_command('r.stream.stats', stream = r_strahler,
+ try:
+ stream_stats = grass.read_command('r.stream.stats', stream = r_strahler,
dir = r_drainage_e,
dem = 'r_elevation_crop' )
+ except:
print "##################################"
print "Output of r.stream.stats: "
