[GRASS-SVN] r54272 - grass/trunk/lib/init
svn_grass at osgeo.org
Thu Dec 13 02:31:14 PST 2012
Author: martinl
Date: 2012-12-13 02:31:14 -0800 (Thu, 13 Dec 2012)
New Revision: 54272
grass/trunk/lib/init/variables.html
variables: remove ADDON_PATH
note bashrc and env.bat
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2012-12-12 21:58:58 UTC (rev 54271)
+++ grass/trunk/lib/init/variables.html 2012-12-13 10:31:14 UTC (rev 54272)
@@ -424,11 +424,6 @@
be inherited by dependent modules as the script runs. Setting either the
GRASS_OVERWRITE environment variable or the OVERWRITE gisenv variable detailed
below will cause maps with identical names to be overwritten.</dd>
- <dt>ADDON_PATH</dt>
- <dd>[grass startup script]<br> allows to specify additional paths to
- local GRASS modules or user scripts extra to standard GRASS
- distribution.</dd>
</dl>
<h2>GRASS-related Files</h2>
@@ -436,6 +431,12 @@
<dl>
<dt><tt>$HOME/.grass7/rc</tt></dt>
<dd>stores the GRASS gisenv variables (not shell environment variables)</dd>
+ <dt><tt>$HOME/.grass7/bashrc</tt></dt>
+ <dd>stores the shell environment variables (Bash only)</dd>
+ <dt><tt>$HOME/.grass7/env.bat</tt></dt>
+ <dd>stores the shell environment variables (MS Windows only)</dd>
<dt><tt>$HOME/.grass7/login</tt></dt>
<dd>stores the DBMI passwords in this hidden file.
