[GRASS-SVN] r54284 - grass/trunk/raster/r.in.gdal
svn_grass at osgeo.org
Fri Dec 14 13:36:48 PST 2012
Author: mmetz
Date: 2012-12-14 13:36:47 -0800 (Fri, 14 Dec 2012)
New Revision: 54284
grass/trunk/raster/r.in.gdal/main.c
r.in.gdal: prefer color rules over color tables
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c 2012-12-14 14:07:08 UTC (rev 54283)
+++ grass/trunk/raster/r.in.gdal/main.c 2012-12-14 21:36:47 UTC (rev 54284)
@@ -731,6 +731,9 @@
char outputReal[GNAME_MAX], outputImg[GNAME_MAX];
char *nullFlags = NULL;
struct History history;
+ char **GDALmetadata;
+ int have_colors = 0;
+ GDALRasterAttributeTableH gdal_rat;
/* Select a cell type for the new cell. */
@@ -930,8 +933,150 @@
/* Transfer colormap, if there is one. */
+ /* prefer color rules over color tables, search: */
+ /* 1. GRASS color rules in metadata */
+ /* 2. Raster attribute table with color rules */
+ /* 3. Raster color table */
- if (!complex && GDALGetRasterColorTable(hBand) != NULL) {
+ /* GRASS color rules in metadata? */
+ GDALmetadata = GDALGetMetadata(hBand, "");
+ if (GDALmetadata) {
+ struct Colors colors;
+ DCELL val1, val2;
+ int r1, g1, b1, r2, g2, b2;
+ Rast_init_colors(&colors);
+ while (GDALmetadata && GDALmetadata[0]) {
+ G_debug(2, "%s", GDALmetadata[0]);
+ if (!strncmp("COLOR_TABLE_RULE_RGB_", GDALmetadata[0], 21)) {
+ char *p;
+ for (p = GDALmetadata[0]; *p != '=' && *p != '\0'; p++);
+ if (*p == '=') {
+ p++;
+ if (p && *p != '\0') {
+ if (sscanf(p, "%lf %lf %d %d %d %d %d %d",
+ &val1, &val2, &r1, &g1, &b1, &r2, &g2, &b2) == 8) {
+ Rast_add_d_color_rule(&val1, r1, g1, b1,
+ &val2, r2, g2, b2,
+ &colors);
+ have_colors = 1;
+ GDALmetadata++;
+ if (have_colors)
+ Rast_write_colors((char *)output, G_mapset(), &colors);
+ Rast_free_colors(&colors);
+ /* colors in raster attribute table? */
+ if (!have_colors && (gdal_rat = GDALGetDefaultRAT(hBand)) != NULL) {
+ nrows = GDALRATGetRowCount(gdal_rat);
+ ncols = GDALRATGetColumnCount(gdal_rat);
+ if (nrows > 0 && ncols > 0) {
+ int minc, maxc, minmaxc;
+ int rc, gc, bc, rminc, rmaxc, gminc, gmaxc, bminc, bmaxc;
+ GDALRATFieldUsage field_use;
+ DCELL val1, val2;
+ minc = maxc = minmaxc = -1;
+ rc = gc = bc = rminc = rmaxc = gminc = gmaxc = bminc = bmaxc = -1;
+ for (indx = 0; indx < ncols; indx++) {
+ field_use = GDALRATGetUsageOfCol(gdal_rat, indx);
+ if (field_use == GFU_Min)
+ minc = indx;
+ else if (field_use == GFU_Max)
+ maxc = indx;
+ else if (field_use == GFU_MinMax)
+ minmaxc = indx;
+ else if (field_use == GFU_Red)
+ rc = indx;
+ else if (field_use == GFU_Green)
+ gc = indx;
+ else if (field_use == GFU_Blue)
+ bc = indx;
+ else if (field_use == GFU_RedMin)
+ rminc = indx;
+ else if (field_use == GFU_GreenMin)
+ gminc = indx;
+ else if (field_use == GFU_BlueMin)
+ bminc = indx;
+ else if (field_use == GFU_RedMax)
+ rmaxc = indx;
+ else if (field_use == GFU_GreenMax)
+ gmaxc = indx;
+ else if (field_use == GFU_BlueMax)
+ bmaxc = indx;
+ if (minc >= 0 && maxc >= 0 && rminc >= 0 && rmaxc >= 0 &&
+ gminc >= 0 && gmaxc >= 0 && bminc >= 0 && bmaxc >= 0) {
+ /* fetch color rules */
+ for (indx = 0; indx < nrows; indx++) {
+ val1 = GDALRATGetValueAsDouble(gdal_rat, indx, minc);
+ val2 = GDALRATGetValueAsDouble(gdal_rat, indx, maxc);
+ r1 = GDALRATGetValueAsDouble(gdal_rat, indx, rminc);
+ g1 = GDALRATGetValueAsDouble(gdal_rat, indx, gminc);
+ b1 = GDALRATGetValueAsDouble(gdal_rat, indx, bminc);
+ r2 = GDALRATGetValueAsDouble(gdal_rat, indx, rmaxc);
+ g2 = GDALRATGetValueAsDouble(gdal_rat, indx, gmaxc);
+ b2 = GDALRATGetValueAsDouble(gdal_rat, indx, bmaxc);
+ &colors);
+ else if (minmaxc >= 0 && rc >= 0 && gc >= 0 && bc >= 0) {
+ if (minc < 0)
+ minc = maxc;
+ /* fetch color table */
+ val1 = GDALRATGetValueAsDouble(gdal_rat, indx, minmaxc);
+ r1 = GDALRATGetValueAsDouble(gdal_rat, indx, rc);
+ g1 = GDALRATGetValueAsDouble(gdal_rat, indx, gc);
+ b1 = GDALRATGetValueAsDouble(gdal_rat, indx, bc);
+ Rast_set_d_color(val1, r1, g1, b1, &colors);
+ have_colors = Rast_colors_count(&colors) > 0;
+ if (have_colors)
+ /* colors in raster color table? */
+ if (!have_colors && !complex && GDALGetRasterColorTable(hBand) != NULL) {
GDALColorTableH hCT;
int iColor;
@@ -952,8 +1097,10 @@
+ have_colors = 1;
- else { /* no color table present */
+ if (!have_colors) { /* no color table present */
/* types are defined in GDAL: ./core/gdal.h */
if ((GDALGetRasterDataType(hBand) == GDT_Byte)) {
@@ -966,6 +1113,7 @@
Rast_make_grey_scale_colors(&colors, 0, 255); /* full range */
if ((GDALGetRasterDataType(hBand) == GDT_UInt16)) {
/* found 0..65535 data: we set to grey scale: */
@@ -981,6 +1129,7 @@
Rast_make_grey_scale_colors(&colors, min, max); /* image range */
