[GRASS-SVN] r54295 - grass/trunk/vector/v.in.db
svn_grass at osgeo.org
Sat Dec 15 04:58:09 PST 2012
Author: martinl
Date: 2012-12-15 04:58:09 -0800 (Sat, 15 Dec 2012)
New Revision: 54295
grass/trunk/vector/v.in.db/main.c
v.in.db: use Vect_set_error_handler_io()
Modified: grass/trunk/vector/v.in.db/main.c
--- grass/trunk/vector/v.in.db/main.c 2012-12-15 12:47:43 UTC (rev 54294)
+++ grass/trunk/vector/v.in.db/main.c 2012-12-15 12:58:09 UTC (rev 54295)
@@ -117,7 +117,8 @@
db_init_string(&sql);
Vect_open_new(&Map, outvect->answer, with_z);
+ Vect_set_error_handler_io(NULL, &Map);
Vect_hist_command(&Map);
fi = Vect_default_field_info(&Map, 1, NULL, GV_1TABLE);
