[GRASS-SVN] r54302 - grass/trunk/scripts/r.mask
svn_grass at osgeo.org
Sat Dec 15 15:25:34 PST 2012
Author: mmetz
Date: 2012-12-15 15:25:33 -0800 (Sat, 15 Dec 2012)
New Revision: 54302
grass/trunk/scripts/r.mask/r.mask.py
r.mask: fix #1838
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py 2012-12-15 23:17:13 UTC (rev 54301)
+++ grass/trunk/scripts/r.mask/r.mask.py 2012-12-15 23:25:33 UTC (rev 54302)
@@ -21,25 +21,43 @@
#% keywords: mask
#%end
#%option G_OPT_R_INPUT
+#% key: raster
#% description: Name of raster map to use as mask
+#% required: NO
+#% guisection: Raster
#%end
#%option
#% key: maskcats
#% type: string
#% description: Category values to use for mask (format: 1 2 3 thru 7 *)
#% answer: *
-#% guisection: Create
#%end
+#%option G_OPT_V_INPUT
+#% key: vector
+#% description: Name of vector map to use as mask
+#% required: NO
+#% guisection: Vector
+#%end
+#%option G_OPT_V_FIELD
+#% required: NO
+#%end
+#%option G_OPT_V_CATS
+#%end
+#%option G_OPT_DB_WHERE
+#%end
#%flag
#% key: i
-#% description: Create inverse mask from specified 'maskcats' list
+#% description: Create inverse mask
#%end
#%flag
#% key: r
#% description: Remove existing mask (overrides other options)
#% guisection: Remove
-#% suppress_required: yes
#%end
import sys
@@ -49,46 +67,64 @@
def cleanup():
if tmp:
- grass.run_command('g.remove', rast = tmp, quiet = True)
+ grass.run_command('g.remove', rast = tmp, quiet = True)
def main():
- input = options['input']
+ raster = options['raster']
maskcats = options['maskcats']
+ vector = options['vector']
+ layer = options['layer']
+ cats = options['cats']
+ where = options['where']
remove = flags['r']
invert = flags['i']
- if not remove and not input:
- grass.fatal(_("Required parameter <input> not set"))
+ if not remove and not raster and not vector:
+ grass.fatal(_("Either parameter <raster> ot parameter <vector> is required"))
- #check if input file exists
- if not grass.find_file(input)['file'] and not remove:
- grass.fatal(_("<%s> does not exist.") % input)
- if maskcats != '*' and not remove:
- if grass.raster_info(input)['datatype'] != "CELL":
- grass.fatal(_("Raster map %s must be integer for maskcats parameter") % input)
mapset = grass.gisenv()['MAPSET']
exists = bool(grass.find_file('MASK', element = 'cell', mapset = mapset)['file'])
if remove:
- if exists:
- grass.run_command('g.remove', rast = 'MASK')
- grass.message(_("Raster MASK removed"))
- else:
- grass.fatal(_("No existing MASK to remove"))
+ if exists:
+ grass.run_command('g.remove', rast = 'MASK')
+ grass.message(_("Raster MASK removed"))
+ else:
+ grass.fatal(_("No existing MASK to remove"))
else:
- if exists:
+ if exists:
if not grass.overwrite():
grass.fatal(_("MASK already found in current mapset. Delete first or overwrite."))
else:
grass.warning(_("MASK already exists and will be overwritten"))
- p = grass.feed_command('r.reclass', input = input, output = 'MASK', overwrite = True, rules = '-')
- p.stdin.write("%s = 1" % maskcats)
- p.stdin.close()
- p.wait()
+ if raster:
+ #check if input raster exists
+ if not grass.find_file(raster)['file']:
+ grass.fatal(_("<%s> does not exist.") % raster)
+ if maskcats != '*' and not remove:
+ if grass.raster_info(raster)['datatype'] != "CELL":
+ grass.fatal(_("Raster map %s must be integer for maskcats parameter") % raster)
+ p = grass.feed_command('r.reclass', input = raster, output = 'MASK', overwrite = True, rules = '-')
+ p.stdin.write("%s = 1" % maskcats)
+ p.stdin.close()
+ p.wait()
+ elif vector:
+ if not grass.find_file(vector, 'vector')['file']:
+ grass.fatal(_("<%s> does not exist.") % vector)
+ # parser bug?
+ if len(cats) == 0:
+ cats = None
+ if len(where) == 0:
+ where = None
+ grass.run_command('v.to.rast', input = vector, layer = layer,
+ output = 'MASK', use = 'val', val = '1',
+ type = 'area', cats = cats, where = where)
if invert:
global tmp
tmp = "r_mask_%d" % os.getpid()
@@ -98,9 +134,9 @@
else:
grass.message(_("MASK created."))
- grass.message(_("All subsequent raster operations will be limited to MASK area. ") +
- "Removing or renaming raster file named MASK will " +
- "restore raster operations to normal")
+ grass.message(_("All subsequent raster operations will be limited to MASK area. ") +
+ "Removing or renaming raster file named MASK will " +
+ "restore raster operations to normal")
if __name__ == "__main__":
options, flags = grass.parser()
