[GRASS-SVN] r54316 - in grass/trunk: imagery/i.cluster imagery/i.maxlik imagery/i.smap raster/r.kappa
svn_grass at osgeo.org
Sun Dec 16 04:56:26 PST 2012
Author: neteler
Date: 2012-12-16 04:56:26 -0800 (Sun, 16 Dec 2012)
New Revision: 54316
grass/trunk/imagery/i.cluster/i.cluster.html
grass/trunk/imagery/i.maxlik/i.maxlik.html
grass/trunk/imagery/i.smap/i.smap.html
grass/trunk/raster/r.kappa/r.kappa.html
examples added; HTML cosmetics
Modified: grass/trunk/imagery/i.cluster/i.cluster.html
--- grass/trunk/imagery/i.cluster/i.cluster.html 2012-12-16 12:49:04 UTC (rev 54315)
+++ grass/trunk/imagery/i.cluster/i.cluster.html 2012-12-16 12:56:26 UTC (rev 54316)
@@ -7,7 +7,8 @@
the second pass. Both programs must be run to complete the unsupervised
classification.
-<p><em>i.cluster</em> is a clustering algorithm that reads
+<p>
+<em>i.cluster</em> is a clustering algorithm that reads
through the (raster) imagery data and builds pixel clusters
based on the spectral reflectances of the pixels (see Figure).
The pixel clusters are imagery categories that can be related
@@ -17,7 +18,8 @@
by the user. The first parameter set by the user is the
initial number of clusters to be discriminated.
-<p><center>
+<p>
+<center>
<img src="landsat_cluster.png" border=1><br>
<table border=0 width=590>
<tr><td><center>
@@ -25,6 +27,7 @@
</center></td></tr>
</table>
</center>
<p>
<em>i.cluster</em> starts by generating spectral signatures
for this number of clusters and "attempts" to end up with
@@ -37,7 +40,6 @@
the percent convergence, the maximum number of iterations,
and the row and column sampling intervals.
<p>
The cluster spectral signatures that result are composed of
cluster means and covariance matrices. These cluster means
@@ -71,24 +73,9 @@
discriminated; any parameter values left unspecified are
set to their default values.
-<h3>Flags:</h3>
-<dl>
-<dt><b>-q</b>
-<dd>Run quietly. Suppresses output of program
-percent-complete messages and the time elapsed from the
-beginning of the program. If this flag is not used, these
-messages are printed out.
-</dl>
<h3>Parameters:</h3>
<dl>
<dt><b>group=</b><em>name</em>
<dd>The name of the group file which contains the imagery
@@ -156,7 +143,7 @@
Default: 30
-<A NAME="convergence"></a>
+<a name="convergence"></a>
<dt><b>convergence=</b><em>value</em>
<dd>A high percent convergence is the point at which
@@ -197,7 +184,6 @@
(see <a href="#convergence"><em>convergence</em></a>).
<br>
Default: 0.0
<dt><b>min_size=</b><em>value</em>
@@ -208,7 +194,6 @@
calculated.
<br>
Default: 17
<A NAME="reportfile"></a>
@@ -221,7 +206,6 @@
achieve the convergence, and the separability matrix.
</dl>
<h2>NOTES</h2>
Running in command line mode, <em>i.cluster</em> will
@@ -229,6 +213,24 @@
required by the user) without prompting if the files
existed.
+<h2>EXAMPLE</h2>
+Preparing the statistics for unsupervised classification of
+a LANDSAT subscene in North Carolina:
+<div class="code"><pre>
+g.region rast=lsat7_2002_10 -p
+# store VIZ, NIR, MIR into group/subgroup
+i.group group=my_lsat7_2002 subgroup=my_lsat7_2002 \
+ input=lsat7_2002_10,lsat7_2002_20,lsat7_2002_30,lsat7_2002_40,lsat7_2002_50,lsat7_2002_70
+i.cluster group=my_lsat7_2002 subgroup=my_lsat7_2002 sigfile=sig_clust_lsat2002 \
+ classes=10 report=rep_clust_lsat2002.txt
+</pre></div>
+To complete the unsupervised classification, <em>i.maxlik</em> is subsequently used.
<h2>SEE ALSO</h2>
The GRASS 4 <em>
@@ -236,6 +238,7 @@
Processing manual</a></em>
<p>
<em>
<a href="i.class.html">i.class</a>,
<a href="i.group.html">i.group</a>,
Modified: grass/trunk/imagery/i.maxlik/i.maxlik.html
--- grass/trunk/imagery/i.maxlik/i.maxlik.html 2012-12-16 12:49:04 UTC (rev 54315)
+++ grass/trunk/imagery/i.maxlik/i.maxlik.html 2012-12-16 12:56:26 UTC (rev 54316)
@@ -5,7 +5,8 @@
step in either an unsupervised or a supervised image
classification.
-<p>Either image classification methods are performed in two
+<p>
+Either image classification methods are performed in two
steps. The first step in an unsupervised image
classification is performed by
<em><a href="i.cluster.html">i.cluster</a></em>; the
@@ -15,7 +16,8 @@
the second step in the image classification procedure is
performed by <em>i.maxlik</em>.
-<p>In an unsupervised classification, the maximum-likelihood
+<p>
+In an unsupervised classification, the maximum-likelihood
classifier uses the cluster means and covariance matrices
from the <em><a href="i.cluster.html">i.cluster</a></em>
signature file to determine to which category (spectral
@@ -29,13 +31,15 @@
to which category each cell in the image has the highest
probability of belonging.
-<p>In either case, the raster map layer output by
+<p>
+In either case, the raster map layer output by
<em>i.maxlik</em> is a classified image in which each cell
has been assigned to a spectral class (i.e., a category).
The spectral classes (categories) can be related to
specific land cover types on the ground.
-<p>The program will run non-interactively if the user
+<p>
+The program will run non-interactively if the user
specifies the names of raster map layers, i.e., group and
subgroup names, seed signature file name, result
classification file name, and any combination of
@@ -57,20 +61,8 @@
the user will be prompted for the program parameter
settings; the program will run foreground.
<h2>OPTIONS</h2>
-<h3>Flags:</h3>
-<dl>
-<dt><b>-q</b>
-<dd>Run quietly, without printing program messages to standard output.
-</dl>
<dl>
@@ -120,7 +112,6 @@
possible uses for this map layer is as a mask, to identify
cells in the classified image that have the lowest
probability of being assigned to the correct class.
</dl>
@@ -140,24 +131,42 @@
<em>i.maxlik</em>
will reject them and display a warning message.
-<p>This program runs interactively if the user types
+<p>
+This program runs interactively if the user types
<em>i.maxlik</em> only. If the user types <em>i.maxlik</em>
along with all required options, it will overwrite the
classified raster map without prompting if this map
existed.
+<h2>EXAMPLE</h2>
+Completion of the unsupervised classification of
+a LANDSAT subscene (VIZ, NIR, MIR channels) in North Carolina
+(see <em>i.cluster</em> manual page for the first part):
+i.maxlik group=my_lsat7_2002 subgroup=my_lsat7_2002 sigfile=sig_clust_lsat2002 \
+ class=lsat7_2002_clust_classes reject=lsat7_2002_clust_classes.rej
+# Visually check result
+d.mon wx0
+d.rast.leg lsat7_2002_clust_classes
+d.rast.leg lsat7_2002_clust_classes.rej
+</pre></div>
<h2>SEE ALSO</h2>
The GRASS 4 <em>
<a href="http://grass.osgeo.org/gdp/imagery/grass4_image_processing.pdf">Image
-<p><em>
+<p>
+<em>
<a href="i.cluster.html">i.cluster</a>,
<a href="i.gensig.html">i.gensig</a>,
-<a href="i.group.html">i.group</a>
+<a href="i.group.html">i.group</a>,
+<a href="r.kappa.html">r.kappa</a>
</em>
<h2>AUTHORS</h2>
@@ -171,4 +180,5 @@
University of Illinois at Urbana-Champaign,
Illinois
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.smap/i.smap.html
--- grass/trunk/imagery/i.smap/i.smap.html 2012-12-16 12:49:04 UTC (rev 54315)
+++ grass/trunk/imagery/i.smap/i.smap.html 2012-12-16 12:56:26 UTC (rev 54316)
@@ -1,6 +1,5 @@
<h2>DESCRIPTION</h2>
The <em>i.smap</em> program is used to segment
multispectral images using a spectral class model known as
a Gaussian mixture distribution. Since Gaussian mixture
@@ -10,7 +9,7 @@
covariance parameters.
<p>
-<em>i.smap</em> has two modes of operation. The first mode
+<em>i.smap</em> has two modes of operation. The first mode
is the sequential maximum a posteriori (SMAP) mode
[<a href="#ref1">1</a>,<a href="#ref2">2</a>]. The SMAP
segmentation algorithm attempts to improve segmentation
@@ -18,7 +17,6 @@
segmenting each pixel separately
(see <a href="#notes">NOTES</a>).
<p>
The second mode is the more conventional maximum likelihood (ML)
classification which classifies each pixel separately,
@@ -30,22 +28,17 @@
<h3>Flags:</h3>
<dl>
<dt><b>-m</b>
<dd>Use maximum likelihood estimation (instead of smap).
Normal operation is to use SMAP estimation (see
<dt><b>-q</b>
<dd>Run quietly, without printing messages about program
progress. Without this flag, messages will be printed (to
stderr) as the program progresses.
</dl>
<dl>
@@ -118,7 +111,7 @@
<em>i.smap</em> will interactively prompt for the names of
the maps and files.
-<A NAME="notes"></a><h2>NOTES</h2>
+<a name="notes"></a><h2>NOTES</h2>
The SMAP algorithm exploits the fact that nearby pixels in
an image are likely to have the same class. It works by
@@ -138,11 +131,43 @@
excessively large regions are not formed.
<p>
-The module i.smap does not support MASKed or NULL cells. Therefore
+The module <em>i.smap</em> does not support MASKed or NULL cells. Therefore
it might be necessary to create a copy of the classification results
-using e.g. r.mapcalc.
-<p>r.mapcalc MASKed_map=classification results
+using e.g. r.mapcalc:
+<p><div class="code"><pre>
+r.mapcalc "MASKed_map = classification_results"
+</pre></div>
+<h2>EXAMPLE</h2>
+Supervised classification of LANDSAT
+# Now digitize training areas "training" with the digitizer
+# and convert to raster model with v.to.rast
+v.to.rast training out=training use=cat labelcolumn=label
+# calculate statistics
+i.gensigset trainingmap=training group=my_lsat7_2002 subgroup=my_lsat7_2002 \
+ signaturefile=my_smap_lsat7_2002 maxsig=5
+i.smap group=my_lsat7_2002 subgroup=my_lsat7_2002 signaturefile=my_smap_lsat7_2002 \
+ output=lsat7_2002_smap_classes
+d.mon wx0
+d.rast.leg lsat7_2002_smap_classes
+# Statistically check result
+r.kappa -w classification=lsat7_2002_smap_classes reference=training
+</pre></div>
<h2>REFERENCES</h2>
<ul>
@@ -179,9 +204,10 @@
<a href="http://dynamo.ecn.purdue.edu/~bouman/software/segmentation/">Charles Bouman,
School of Electrical Engineering, Purdue University</a>
-<br>
+<p>
Michael Shapiro,
U.S.Army Construction Engineering
Research Laboratory
+<p>
Modified: grass/trunk/raster/r.kappa/r.kappa.html
--- grass/trunk/raster/r.kappa/r.kappa.html 2012-12-16 12:49:04 UTC (rev 54315)
+++ grass/trunk/raster/r.kappa/r.kappa.html 2012-12-16 12:56:26 UTC (rev 54316)
@@ -5,7 +5,8 @@
overall <em>kappa</em> (accompanied by its <em>variance</em>) and
conditional <em>kappa</em> values are calculated. This analysis program
respects the current geographic region and mask settings.
-<p><em>r.kappa</em> calculates the error matrix of the
+<p>
+<em>r.kappa</em> calculates the error matrix of the
two map layers and prepares the table from which the report
is to be created. <em>kappa</em> values for overall and
each classes are computed along with their variances. Also
@@ -14,12 +15,13 @@
counts and percentage of overall correctly classified
pixels are tabulated.
-<p>The report will be write to an output file which is in
+<p>
+The report will be write to an output file which is in
plain text format and named by user at prompt of running
the program.
-<p>The body of the report is arranged in panels. The
+<p>
+The body of the report is arranged in panels. The
classified result map layer categories is arranged along
the vertical axis of the table, while the reference map
layer categories along the horizontal axis. Each panel has
@@ -44,6 +46,14 @@
<em>NA</em>'s in output file mean non-applicable in case
<em>MASK</em> exists.
+<H2>EXAMPLE</H2>
+Verification of classified LANDSAT scene against training areas:
+r.kappa -w classification=lsat7_2002_classes reference=training
+</pre></div>
<h2>SEE ALSO</h2>
<em><a href="g.region.html">g.region</a></em>,
@@ -58,4 +68,5 @@
Tao Wen, University of Illinois at Urbana-Champaign, Illinois
+<p>
