[GRASS-SVN] r54323 - grass/trunk/imagery/i.smap
svn_grass at osgeo.org
Mon Dec 17 05:58:20 PST 2012
Author: mmetz
Date: 2012-12-17 05:58:20 -0800 (Mon, 17 Dec 2012)
New Revision: 54323
grass/trunk/imagery/i.smap/interp.c
grass/trunk/imagery/i.smap/region.h
grass/trunk/imagery/i.smap/segment.c
i.smap: add goodness of fit for MLE
Modified: grass/trunk/imagery/i.smap/interp.c
--- grass/trunk/imagery/i.smap/interp.c 2012-12-17 13:38:19 UTC (rev 54322)
+++ grass/trunk/imagery/i.smap/interp.c 2012-12-17 13:58:20 UTC (rev 54323)
@@ -15,7 +15,7 @@
static void print_alpha(double *);
static void interp(unsigned char **, struct Region *, unsigned char **,
LIKELIHOOD ***, int, double *, int, double ***, int, float **);
-void MLE(unsigned char **, LIKELIHOOD ***, struct Region *, int);
+void MLE(unsigned char **, LIKELIHOOD ***, struct Region *, int, float **);
static int up_char(int, int, struct Region *, unsigned char **,
unsigned char **);
@@ -46,7 +46,7 @@
LIKELIHOOD **** ll_pym, /* pyramid of class statistics */
int M, /* number of classes */
double *alpha_dec, /* decimation parameters returned by seq_MAP */
- float **goodness /* goodness of fit */
+ float **goodness /* goodness of fit */
int j, k; /* loop index */
@@ -89,7 +89,7 @@
/* Compute Maximum Likelihood estimate at coarsest resolution */
- MLE(sf_pym[D], ll_pym[D], &(regionary[D]), M);
+ MLE(sf_pym[D], ll_pym[D], &(regionary[D]), M, NULL);
/* Initialize the transition parameters */
alpha[0] = 0.5 * (3.0 / 7.0);
@@ -201,7 +201,7 @@
int period, /* sampling period of interpolation */
double ***N, /* transition probability statistics; N[2][3][2] */
int statflag, /* compute transition statistics if == 1 */
- float **goodness /* cost of best class */
+ float **goodness /* cost of best class */
int i, j; /* pixel index */
@@ -292,7 +292,8 @@
unsigned char **sf, /* segmentation classes */
LIKELIHOOD *** ll, /* texture statistics */
struct Region *region, /* image region */
- int M /* number of classes */
+ int M, /* number of classes */
int i, j, m, best;
@@ -309,6 +310,8 @@
sf[i][j] = best;
+ if (goodness)
+ goodness[i][j] = max;
Modified: grass/trunk/imagery/i.smap/region.h
--- grass/trunk/imagery/i.smap/region.h 2012-12-17 13:38:19 UTC (rev 54322)
+++ grass/trunk/imagery/i.smap/region.h 2012-12-17 13:58:20 UTC (rev 54323)
@@ -22,7 +22,7 @@
/* interp.c */
void seq_MAP(unsigned char ***, struct Region *, LIKELIHOOD ****, int,
double *, float **);
/* reg_util.c */
int levels_reg(struct Region *);
Modified: grass/trunk/imagery/i.smap/segment.c
--- grass/trunk/imagery/i.smap/segment.c 2012-12-17 13:38:19 UTC (rev 54322)
+++ grass/trunk/imagery/i.smap/segment.c 2012-12-17 13:58:20 UTC (rev 54323)
@@ -110,7 +110,7 @@
extract(img, ®ion, ll_pym[0], S);
if (ml)
- MLE(sf_pym[0], ll_pym[0], ®ion, nclasses);
+ MLE(sf_pym[0], ll_pym[0], ®ion, nclasses, goodness);
else {
for (i = 0; i < D; i++)
alpha_dec[i] = 1.0;
